[PATCH 0/3] Split off powerpcspe from rs6000 port
Wed May 17 06:15:49 UTC 2017
On 17/05/17 08:12, Chris Johns wrote:
> On 17/05/2017 00:03, Joel Sherrill wrote:
>> On Tue, May 16, 2017 at 8:48 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>     On 16/05/17 15:45, Joel Sherrill wrote:
>>         On Tue, May 16, 2017 at 8:28 AM, Sebastian Huber
>> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>              FYI
>>              I guess for RTEMS we should use "powerpcspe-rtems*-*".
>> Is it
>>              possible to use the RTEMS "powerpc" directories with such a
>>              target? We had an "arm-rtemseabi*" maybe due to some
>>              configure/automake limitations. So, maybe
>> "powerpc-rtemsspe*"?
>>         I personally think the GCC discussions which put SPE as part of
>>         the OS name are
>>         horribly incorrect. SPE is an architecture variant and the
>>         pattern for configure
>>         triples is very well defined. The pattern is
>>         ARCHITECTURE-VENDOR-OS[version]
>>         I would prefer powerpcspe-rtemsVERSION.
>>         On the sharing the code issue, how much gets shared? How do you
>>         envision
>>         this impacting the RTEMS tree? Split the PowerPC port like GCC?
>>         Or just
>>         somehow magically build the same powerpc directories two
>>         different ways?
>>     The reason for this split in GCC is that IBM is no longer willing to
>>     maintain the stuff from Freescale/NXP/Qualcomm. There is no reason
>>     to do this split in RTEMS.
>> I didn't either except for the purity of matching directories to tool
>> architectures.
>> So it will be configure magic to subset the BSPs I suppose.
> Does this mean we configure RTEMS with:
>   configure --target=powerpcspe-rtems4.12
> It would seem to create a new architecture and I suspect this will
> have a follow on effects with rtems_waf and the rtems-tools.
Yes, very unfortunate, but I don't think we can change the GCC directions.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
