[PATCH 2/2] 4.12/powerpc/gdb: Fix building the simulator on FreeBSD.
Thu May 18 05:15:44 UTC 2017
 rtems/config/tools/rtems-gdb-7.12-1.cfg | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/rtems/config/tools/rtems-gdb-7.12-1.cfg b/rtems/config/tools/rtems-gdb-7.12-1.cfg
index 52c9fa2..b8b7e91 100644
--- a/rtems/config/tools/rtems-gdb-7.12-1.cfg
+++ b/rtems/config/tools/rtems-gdb-7.12-1.cfg
@@ -23,6 +23,8 @@
  %hash  sha256 patch-gdb-gnulib-import-stddef.in.h da35940004c6fa8d113013c1019e0a3b8267d1d5e1d79b2c78becb055cd261f3
  %patch add gdb -p0 https://svnweb.freebsd.org/ports/head/devel/gdb/files/patch-gdb-python-python-config.py?revision=384978&view=co
  %hash  sha256 patch-gdb-python-python-config.py 1c5d1362828c9b343e4a48a0cc1f63775726fbe8c9ead6078dec76442c0221ea
+ %patch add gdb --rsb-file=PATCH_Define_an_error_function_in_the_PPC_simulator https://sourceware.org/cgi-bin/get-raw-msg?listname=gdb-patches&date=2016-11&msgid=20161124152917.52189-1-jhb%40FreeBSD.org
+ %hash sha256 PATCH_Define_an_error_function_in_the_PPC_simulator 26a39e952a5427207f4dc76beececbd72eaeb9ab85f984e53457df309767998c
 %endif
2.12.1
