rtems_fatal() as inline in a header file
Fri May 19 05:11:17 UTC 2017
On 18/05/17 20:35, Pham, Phong wrote:
> I am only interested in moving rtems_fatal() implementation to a fatal.c (thus removing the inline) and leave the indirection issue alone.  Are you comfortable with this (b4 I do the work and checkin)?  In this manner, the API remain the same.
Why should we prevent the compiler from optimizing this function away?
For debugging you should set the break point to _Terminate().
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
