[rtems commit] arm: Optimize context switch
Gedare Bloom
gedare at rtems.org
Fri May 19 18:52:06 UTC 2017
This commit causes an error when running realview_pbx_a9_qemu in the
gem5 simulator. I have only been able to identify that this is the
problematic commit. I have not been able to debug further.
On Tue, Mar 28, 2017 at 4:34 AM, Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: cd3d74793a4e2ec93cefdddb855d4536d44c7e64
> Changeset: http://git.rtems.org/rtems/commit/?id=cd3d74793a4e2ec93cefdddb855d4536d44c7e64
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Mon Mar 27 08:01:38 2017 +0200
> Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to TRUE. In this case the
> interrupts are always enabled during a context switch even after
> interrupt processing (see #2751). Remove the CPSR from the context
> control since it contains only volatile bits.
> Close #2954.
> c/src/lib/libbsp/arm/tms570/startup/bspstart.c | 12 ------
> cpukit/score/cpu/arm/cpu.c | 33 ++++----------
> cpukit/score/cpu/arm/cpu_asm.S | 41 ++++++++++--------
> cpukit/score/cpu/arm/rtems/score/cpu.h | 59 ++++++++++----------------
> 4 files changed, 55 insertions(+), 90 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/bspstart.c b/c/src/lib/libbsp/arm/tms570/startup/bspstart.c
> index 7c1e9a1..025bb74 100644
> --- a/c/src/lib/libbsp/arm/tms570/startup/bspstart.c
> +++ b/c/src/lib/libbsp/arm/tms570/startup/bspstart.c
> @@ -35,18 +35,6 @@ void bsp_start( void )
> void *need_remap_ptr;
> unsigned int need_remap_int;
> - #if BYTE_ORDER == BIG_ENDIAN
> - * If CPU is big endian (TMS570 family variant)
> - * set the CPU mode to supervisor and big endian.
> - * Do not set mode if CPU is little endian
> - * (RM48 family variant) for which default mode 0x13
> - * defined in cpukit/score/cpu/arm/cpu.c
> - * is right.
> - arm_cpu_mode = 0x213;
> - #endif
> tms570_initialize_and_clear();
> diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
> index b5738b1..01a43b3 100644
> --- a/cpukit/score/cpu/arm/cpu.c
> +++ b/cpukit/score/cpu/arm/cpu.c
> @@ -15,7 +15,7 @@
> * Copyright (c) 2007 Ray xu <rayx.cn at gmail.com>
> - * Copyright (c) 2009, 2016 embedded brains GmbH
> + * Copyright (c) 2009, 2017 embedded brains GmbH
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> @@ -26,14 +26,10 @@
> #include "config.h"
> #endif
> -#include <rtems/system.h>
> -#include <rtems.h>
> -#include <rtems/bspIo.h>
> -#include <rtems/score/isr.h>
> -#include <rtems/score/wkspace.h>
> +#include <rtems/score/assert.h>
> +#include <rtems/score/cpu.h>
> #include <rtems/score/thread.h>
> #include <rtems/score/tls.h>
> -#include <rtems/score/cpu.h>
> #ifdef ARM_MULTILIB_VFP
> RTEMS_STATIC_ASSERT(
> @@ -89,12 +85,6 @@ RTEMS_STATIC_ASSERT(
> #ifdef ARM_MULTILIB_ARCH_V4
> - * This variable can be used to change the running mode of the execution
> - * contexts.
> -uint32_t arm_cpu_mode = 0x13;
> void _CPU_Context_Initialize(
> Context_Control *the_context,
> void *stack_area_begin,
> @@ -105,10 +95,10 @@ void _CPU_Context_Initialize(
> void *tls_area
> + (void) new_level;
> the_context->register_sp = (uint32_t) stack_area_begin + stack_area_size;
> the_context->register_lr = (uint32_t) entry_point;
> - the_context->register_cpsr = ( ( new_level != 0 ) ? ARM_PSR_I : 0 )
> - | arm_cpu_mode;
> the_context->isr_dispatch_disable = 0;
> #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
> @@ -120,25 +110,20 @@ void _CPU_Context_Initialize(
> -/* Preprocessor magic for stringification of x */
> -#define _CPU_ISR_LEVEL_DO_STRINGOF( x) #x
> -#define _CPU_ISR_LEVEL_STRINGOF( x) _CPU_ISR_LEVEL_DO_STRINGOF( x)
> void _CPU_ISR_Set_level( uint32_t level )
> uint32_t arm_switch_reg;
> - level = ( level != 0 ) ? ARM_PSR_I : 0;
> + /* Ignore the level parameter and just enable interrupts */
> + (void) level;
> __asm__ volatile (
> ARM_SWITCH_TO_ARM
> "mrs %[arm_switch_reg], cpsr\n"
> - "bic %[arm_switch_reg], #" _CPU_ISR_LEVEL_STRINGOF( ARM_PSR_I ) "\n"
> - "orr %[arm_switch_reg], %[level]\n"
> + "bic %[arm_switch_reg], #" RTEMS_XSTRING( ARM_PSR_I ) "\n"
> "msr cpsr, %0\n"
> ARM_SWITCH_BACK
> : [arm_switch_reg] "=&r" (arm_switch_reg)
> - : [level] "r" (level)
> @@ -150,7 +135,7 @@ uint32_t _CPU_ISR_Get_level( void )
> __asm__ volatile (
> ARM_SWITCH_TO_ARM
> "mrs %[level], cpsr\n"
> - "and %[level], #" _CPU_ISR_LEVEL_STRINGOF( ARM_PSR_I ) "\n"
> + "and %[level], #" RTEMS_XSTRING( ARM_PSR_I ) "\n"
> ARM_SWITCH_BACK
> : [level] "=&r" (level) ARM_SWITCH_ADDITIONAL_OUTPUT
> diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
> index f10cd90..52ea77a 100644
> --- a/cpukit/score/cpu/arm/cpu_asm.S
> +++ b/cpukit/score/cpu/arm/cpu_asm.S
> @@ -19,7 +19,7 @@
> * COPYRIGHT (c) 2000 Canon Research Centre France SA.
> * Emmanuel Raguet, mailto:raguet at crf.canon.fr
> - * Copyright (c) 2013, 2016 embedded brains GmbH
> + * Copyright (c) 2013, 2017 embedded brains GmbH
> @@ -55,19 +55,21 @@
> DEFINE_FUNCTION_ARM(_CPU_Context_switch)
> /* Start saving context */
> - mrs r2, CPSR
> - stmia r0, {r2, r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
> GET_SELF_CPU_CONTROL r2
> + stm r0, {r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
> +#ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
> + mrc p15, 0, r3, c13, c0, 3
> +#endif
> ldr r4, [r2, #PER_CPU_ISR_DISPATCH_DISABLE]
> - add r3, r0, #ARM_CONTEXT_CONTROL_D8_OFFSET
> - vstm r3, {d8-d15}
> + add r5, r0, #ARM_CONTEXT_CONTROL_D8_OFFSET
> + vstm r5, {d8-d15}
> #endif
> - mrc p15, 0, r3, c13, c0, 3
> str r3, [r0, #ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET]
> #endif
> @@ -106,28 +108,31 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
> clrex
> #endif
> - ldr r4, [r1, #ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
> ldr r3, [r1, #ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET]
> - mcr p15, 0, r3, c13, c0, 3
> #endif
> + ldr r4, [r1, #ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
> - add r3, r1, #ARM_CONTEXT_CONTROL_D8_OFFSET
> - vldm r3, {d8-d15}
> + add r5, r1, #ARM_CONTEXT_CONTROL_D8_OFFSET
> + vldm r5, {d8-d15}
> +#endif
> + mcr p15, 0, r3, c13, c0, 3
> #endif
> str r4, [r2, #PER_CPU_ISR_DISPATCH_DISABLE]
> - ldmia r1, {r2, r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
> - msr CPSR_fsxc, r2
> -#ifdef __thumb__
> - bx lr
> - nop
> + /* In ARMv5T and above the load of PC is an interworking branch */
> +#if __ARM_ARCH >= 5
> + ldm r1, {r4, r5, r6, r7, r8, r9, r10, r11, r13, pc}
> #else
> - mov pc, lr
> + ldm r1, {r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
> + bx lr
> #endif
> * void _CPU_Context_restore( new_context )
> diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
> index b10bc71..05e236c 100644
> --- a/cpukit/score/cpu/arm/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
> @@ -8,7 +8,7 @@
> * This include file contains information pertaining to the ARM
> * processor.
> * Copyright (c) 2007 Ray Xu <Rayx.cn at gmail.com>
> @@ -120,11 +120,7 @@
> #define CPU_USE_DEFERRED_FP_SWITCH FALSE
> -#if defined(ARM_MULTILIB_ARCH_V7M)
> - #define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
> -#else
> - #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
> -#endif
> +#define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
> #if defined(ARM_MULTILIB_HAS_WFI)
> #define CPU_PROVIDES_IDLE_THREAD_BODY TRUE
> @@ -142,20 +138,6 @@
> #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
> - * The interrupt mask disables only normal interrupts (IRQ).
> - * In order to support fast interrupts (FIQ) such that they can do something
> - * useful, we have to disable the operating system support for FIQs. Having
> - * operating system support for them would require that FIQs are disabled
> - * during critical sections of the operating system and application. At this
> - * level IRQs and FIQs would be equal. It is true that FIQs could interrupt
> - * the non critical sections of IRQs, so here they would have a small
> - * advantage. Without operating system support, the FIQs can execute at any
> - * time (of course not during the service of another FIQ). If someone needs
> - * operating system support for a FIQ, she can trigger a software interrupt and
> - * service the request in a two-step process.
> #define CPU_MODES_INTERRUPT_MASK 0x1
> #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
> @@ -206,20 +188,16 @@
> #endif
> - #if defined(ARM_MULTILIB_VFP)
> - #define ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 112
> - #elif defined(ARM_MULTILIB_HAS_THREAD_ID_REGISTER)
> - #define ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 48
> - #else
> - #define ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 44
> - #endif
> + #define ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 40
> #endif
> #ifdef RTEMS_SMP
> - #ifdef ARM_MULTILIB_VFP
> - #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 116
> + #if defined(ARM_MULTILIB_VFP)
> + #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
> + #elif defined(ARM_MULTILIB_HAS_THREAD_ID_REGISTER)
> + #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
> #else
> - #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 52
> + #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 44
> #endif
> #endif
> @@ -244,7 +222,6 @@ extern "C" {
> typedef struct {
> #if defined(ARM_MULTILIB_ARCH_V4)
> - uint32_t register_cpsr;
> uint32_t register_r4;
> uint32_t register_r5;
> uint32_t register_r6;
> @@ -255,6 +232,7 @@ typedef struct {
> uint32_t register_fp;
> uint32_t register_sp;
> uint32_t register_lr;
> + uint32_t isr_dispatch_disable;
> #elif defined(ARM_MULTILIB_ARCH_V6M) || defined(ARM_MULTILIB_ARCH_V7M)
> @@ -283,9 +261,6 @@ typedef struct {
> uint64_t register_d14;
> uint64_t register_d15;
> #endif
> -#ifdef ARM_MULTILIB_ARCH_V4
> - uint32_t isr_dispatch_disable;
> -#endif
> #ifdef RTEMS_SMP
> volatile bool is_executing;
> #endif
> @@ -295,8 +270,6 @@ typedef struct {
> /* Not supported */
> } Context_Control_fp;
> -extern uint32_t arm_cpu_mode;
> static inline void _ARM_Data_memory_barrier( void )
> #ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
> @@ -331,6 +304,20 @@ static inline uint32_t arm_interrupt_disable( void )
> + * Disable only normal interrupts (IRQ).
> + * In order to support fast interrupts (FIQ) such that they can do something
> + * useful, we have to disable the operating system support for FIQs. Having
> + * operating system support for them would require that FIQs are disabled
> + * during critical sections of the operating system and application. At this
> + * level IRQs and FIQs would be equal. It is true that FIQs could interrupt
> + * the non critical sections of IRQs, so here they would have a small
> + * advantage. Without operating system support, the FIQs can execute at any
> + * time (of course not during the service of another FIQ). If someone needs
> + * operating system support for a FIQ, she can trigger a software interrupt and
> + * service the request in a two-step process.
> __asm__ volatile (
> ARM_SWITCH_TO_ARM
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
