[PATCH v2 1/2] Add support for a mmap file handler. Add support for MAP_ANON in mmap().
Sun May 21 12:01:42 UTC 2017
On Sat, May 20, 2017 at 9:39 AM, Kevin Kirspel <kevin-kirspel at idexx.com> wrote:
>  cpukit/dev/i2c/i2c-bus.c                        |   1 +
>  cpukit/dev/i2c/i2c-dev.c                        |   1 +
>  cpukit/dev/spi/spi-bus.c                        |   1 +
>  cpukit/libblock/src/blkdev-imfs.c               |   1 +
>  cpukit/libcsupport/include/rtems/libio.h        |  38 ++++
>  cpukit/libcsupport/include/rtems/termiostypes.h |  13 ++
>  cpukit/libcsupport/src/__usrenv.c               |   1 +
>  cpukit/libcsupport/src/termios.c                |   1 +
>  cpukit/libfs/Makefile.am                        |   1 +
>  cpukit/libfs/src/defaults/default_handlers.c    |   1 +
>  cpukit/libfs/src/defaults/default_mmap.c        |  40 ++++
>  cpukit/libfs/src/devfs/devfs_init.c             |   1 +
>  cpukit/libfs/src/dosfs/msdos_handlers_dir.c     |   1 +
>  cpukit/libfs/src/dosfs/msdos_handlers_file.c    |   1 +
>  cpukit/libfs/src/imfs/imfs_dir_default.c        |   1 +
>  cpukit/libfs/src/imfs/imfs_dir_minimal.c        |   1 +
>  cpukit/libfs/src/imfs/imfs_fifo.c               |   1 +
>  cpukit/libfs/src/imfs/imfs_handlers_device.c    |   1 +
>  cpukit/libfs/src/imfs/imfs_linfile.c            |   1 +
>  cpukit/libfs/src/imfs/imfs_link.c               |   1 +
>  cpukit/libfs/src/imfs/imfs_memfile.c            |   1 +
>  cpukit/libfs/src/imfs/imfs_symlink.c            |   1 +
>  cpukit/libfs/src/jffs2/src/fs-rtems.c           |   3 +
>  cpukit/libfs/src/nfsclient/src/nfs.c            |   3 +
>  cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c      |   1 +
>  cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c      |   1 +
>  cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c     |   1 +
>  cpukit/libfs/src/rfs/rtems-rfs-rtems.c          |   1 +
>  cpukit/libnetworking/lib/ftpfs.c                |   2 +
>  cpukit/libnetworking/lib/tftpDriver.c           |   1 +
>  cpukit/libnetworking/rtems/rtems_syscall.c      |   1 +
>  cpukit/posix/src/mmap.c                         | 255 ++++++++++++++----------
>  cpukit/posix/src/munmap.c                       |  14 +-
>  cpukit/posix/src/shmopen.c                      |  30 +++
>  34 files changed, 311 insertions(+), 112 deletions(-)
>  create mode 100644 cpukit/libfs/src/defaults/default_mmap.c
> diff --git a/cpukit/dev/i2c/i2c-bus.c b/cpukit/dev/i2c/i2c-bus.c
> index 0f27d06..1297b1e 100644
> --- a/cpukit/dev/i2c/i2c-bus.c
> +++ b/cpukit/dev/i2c/i2c-bus.c
> @@ -218,6 +218,7 @@ static const rtems_filesystem_file_handlers_r i2c_bus_handler = {
>    .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
>    .fcntl_h = rtems_filesystem_default_fcntl,
>    .kqfilter_h = rtems_filesystem_default_kqfilter,
> +  .mmap_h = rtems_filesystem_default_mmap,
>    .poll_h = rtems_filesystem_default_poll,
>    .readv_h = rtems_filesystem_default_readv,
>    .writev_h = rtems_filesystem_default_writev
> diff --git a/cpukit/dev/i2c/i2c-dev.c b/cpukit/dev/i2c/i2c-dev.c
> index b00a9bd..680732f 100644
> --- a/cpukit/dev/i2c/i2c-dev.c
> +++ b/cpukit/dev/i2c/i2c-dev.c
> @@ -115,6 +115,7 @@ static const rtems_filesystem_file_handlers_r i2c_dev_handler = {
> diff --git a/cpukit/dev/spi/spi-bus.c b/cpukit/dev/spi/spi-bus.c
> index dd84b02..343e203 100644
> --- a/cpukit/dev/spi/spi-bus.c
> +++ b/cpukit/dev/spi/spi-bus.c
> @@ -235,6 +235,7 @@ static const rtems_filesystem_file_handlers_r spi_bus_handler = {
> diff --git a/cpukit/libblock/src/blkdev-imfs.c b/cpukit/libblock/src/blkdev-imfs.c
> index 7a2d00b..f2008aa 100644
> --- a/cpukit/libblock/src/blkdev-imfs.c
> +++ b/cpukit/libblock/src/blkdev-imfs.c
> @@ -222,6 +222,7 @@ static const rtems_filesystem_file_handlers_r rtems_blkdev_imfs_node = {
>    .fdatasync_h = rtems_blkdev_imfs_fsync_or_fdatasync,
> diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
> index d0824b4..91733e4 100644
> --- a/cpukit/libcsupport/include/rtems/libio.h
> +++ b/cpukit/libcsupport/include/rtems/libio.h
> @@ -977,6 +977,28 @@ typedef int (*rtems_filesystem_kqfilter_t)(
> + * @brief MMAP support.
> + * @param[in, out] iop The IO pointer.
> + * @param[in, out] addr The starting address of the mapped memory.
> + * @param[in] len The maximum number of bytes to map.
> + * @param[in] prot The desired memory protection.
> + * @param[in] off The offset within the file descriptor to map.
> + * @retval 0 Successful operation.
> + * @retval error An error occurred.  This is usually EINVAL.
> + * @see rtems_filesystem_default_mmap().
> +typedef int (*rtems_filesystem_mmap_t)(
> +  rtems_libio_t *iop,
> +  void **addr,
> +  size_t len,
> +  int prot,
> +  off_t off
>   * @brief File system node operations table.
>  struct _rtems_filesystem_file_handlers_r {
> @@ -993,6 +1015,7 @@ struct _rtems_filesystem_file_handlers_r {
>    rtems_filesystem_fcntl_t fcntl_h;
>    rtems_filesystem_poll_t poll_h;
>    rtems_filesystem_kqfilter_t kqfilter_h;
> +  rtems_filesystem_mmap_t mmap_h;
>    rtems_filesystem_readv_t readv_h;
>    rtems_filesystem_writev_t writev_h;
> @@ -1216,6 +1239,21 @@ int rtems_filesystem_default_kqfilter(
>    struct knote *kn
> + * @brief Default MMAP handler.
> + * @retval EINVAL Always.
ENOTSUP?
> + * @see rtems_filesystem_mmap_t.
> +int rtems_filesystem_default_mmap(
> +  void **addr,
> +  size_t len,
> +  int prot,
> +  off_t off
> diff --git a/cpukit/libcsupport/include/rtems/termiostypes.h b/cpukit/libcsupport/include/rtems/termiostypes.h
> index 1140c61..1eb7e79 100644
> --- a/cpukit/libcsupport/include/rtems/termiostypes.h
> +++ b/cpukit/libcsupport/include/rtems/termiostypes.h
> @@ -564,6 +564,19 @@ int rtems_termios_kqfilter(
> + * @brief Termios kqueue() filter filesystem node handler
mmap?
> + * Real implementation is provided by libbsd.
> +int rtems_termios_mmap(
> +  void         **addr,
> +  size_t         len,
> +  int            prot,
> +  off_t          off
>   * @brief Termios poll() filesystem node handler.
> diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
> index a05295d..611e0d7 100644
> --- a/cpukit/libcsupport/src/__usrenv.c
> +++ b/cpukit/libcsupport/src/__usrenv.c
> @@ -56,6 +56,7 @@ const rtems_filesystem_file_handlers_r rtems_filesystem_null_handlers = {
> diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
> index 2fb9d4f..7fa8e66 100644
> --- a/cpukit/libcsupport/src/termios.c
> +++ b/cpukit/libcsupport/src/termios.c
> @@ -2211,6 +2211,7 @@ static const rtems_filesystem_file_handlers_r rtems_termios_imfs_handler = {
>    .kqfilter_h = rtems_termios_kqfilter,
> +  .mmap_h = rtems_termios_mmap,
>    .poll_h = rtems_termios_poll,
> diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
> index 89e7581..1a9c292 100644
> --- a/cpukit/libfs/Makefile.am
> +++ b/cpukit/libfs/Makefile.am
> @@ -33,6 +33,7 @@ libdefaultfs_a_SOURCES = \
>      src/defaults/default_ftruncate_directory.c \
>      src/defaults/default_handlers.c src/defaults/default_ops.c
>  libdefaultfs_a_SOURCES += src/defaults/default_kqfilter.c
> +libdefaultfs_a_SOURCES += src/defaults/default_mmap.c
>  libdefaultfs_a_SOURCES += src/defaults/default_poll.c
>  libdefaultfs_a_SOURCES += src/defaults/default_readv.c
>  libdefaultfs_a_SOURCES += src/defaults/default_writev.c
> diff --git a/cpukit/libfs/src/defaults/default_handlers.c b/cpukit/libfs/src/defaults/default_handlers.c
> index 903cddc..3730f6c 100644
> --- a/cpukit/libfs/src/defaults/default_handlers.c
> +++ b/cpukit/libfs/src/defaults/default_handlers.c
> @@ -34,6 +34,7 @@ const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default = {
> diff --git a/cpukit/libfs/src/defaults/default_mmap.c b/cpukit/libfs/src/defaults/default_mmap.c
> new file mode 100644
> index 0000000..08534ee
> --- /dev/null
> +++ b/cpukit/libfs/src/defaults/default_mmap.c
> @@ -0,0 +1,40 @@
> + * @file
> + * @brief Default MMAP Handler
> + * @ingroup LibIOFSHandler
> + * Copyright (c) 2017 Kevin Kirspel (kirspkt at gmail.com)
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#if HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/libio_.h>
> +  void          **addr,
> +  size_t          len,
> +  int             prot,
> +  off_t           off
> +  rtems_set_errno_and_return_minus_one( ENOTSUP );
> +  void          **addr,
> +  size_t          len,
> +  int             prot,
> +  off_t           off
> +) RTEMS_WEAK_ALIAS( rtems_filesystem_default_mmap );
> diff --git a/cpukit/libfs/src/devfs/devfs_init.c b/cpukit/libfs/src/devfs/devfs_init.c
> index cb5099c..1e960d2 100644
> --- a/cpukit/libfs/src/devfs/devfs_init.c
> +++ b/cpukit/libfs/src/devfs/devfs_init.c
> @@ -52,6 +52,7 @@ const rtems_filesystem_file_handlers_r devFS_file_handlers = {
> diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> index 1365ca1..bc2d896 100644
> --- a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> +++ b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> @@ -34,6 +34,7 @@ const rtems_filesystem_file_handlers_r msdos_dir_handlers = {
>    .fdatasync_h = msdos_sync,
> diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_file.c b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> index 0bea6e1..ed72fb6 100644
> --- a/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> +++ b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> @@ -34,6 +34,7 @@ const rtems_filesystem_file_handlers_r msdos_file_handlers = {
> diff --git a/cpukit/libfs/src/imfs/imfs_dir_default.c b/cpukit/libfs/src/imfs/imfs_dir_default.c
> index b31a50e..a1fc243 100644
> --- a/cpukit/libfs/src/imfs/imfs_dir_default.c
> +++ b/cpukit/libfs/src/imfs/imfs_dir_default.c
> @@ -130,6 +130,7 @@ static const rtems_filesystem_file_handlers_r IMFS_dir_default_handlers = {
>    .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
> diff --git a/cpukit/libfs/src/imfs/imfs_dir_minimal.c b/cpukit/libfs/src/imfs/imfs_dir_minimal.c
> index 3ef5173..e97468d 100644
> --- a/cpukit/libfs/src/imfs/imfs_dir_minimal.c
> +++ b/cpukit/libfs/src/imfs/imfs_dir_minimal.c
> @@ -32,6 +32,7 @@ static const rtems_filesystem_file_handlers_r IMFS_dir_minimal_handlers = {
> diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c b/cpukit/libfs/src/imfs/imfs_fifo.c
> index d84429d..bd80518 100644
> --- a/cpukit/libfs/src/imfs/imfs_fifo.c
> +++ b/cpukit/libfs/src/imfs/imfs_fifo.c
> @@ -125,6 +125,7 @@ static const rtems_filesystem_file_handlers_r IMFS_fifo_handlers = {
> diff --git a/cpukit/libfs/src/imfs/imfs_handlers_device.c b/cpukit/libfs/src/imfs/imfs_handlers_device.c
> index 0a7cb5f..df9f6fc 100644
> --- a/cpukit/libfs/src/imfs/imfs_handlers_device.c
> +++ b/cpukit/libfs/src/imfs/imfs_handlers_device.c
> @@ -45,6 +45,7 @@ static const rtems_filesystem_file_handlers_r IMFS_device_handlers = {
> diff --git a/cpukit/libfs/src/imfs/imfs_linfile.c b/cpukit/libfs/src/imfs/imfs_linfile.c
> index 5840c16..57e106d 100644
> --- a/cpukit/libfs/src/imfs/imfs_linfile.c
> +++ b/cpukit/libfs/src/imfs/imfs_linfile.c
> @@ -87,6 +87,7 @@ static const rtems_filesystem_file_handlers_r IMFS_linfile_handlers = {
> diff --git a/cpukit/libfs/src/imfs/imfs_link.c b/cpukit/libfs/src/imfs/imfs_link.c
> index 06794af..add93e4 100644
> --- a/cpukit/libfs/src/imfs/imfs_link.c
> +++ b/cpukit/libfs/src/imfs/imfs_link.c
> @@ -93,6 +93,7 @@ static const rtems_filesystem_file_handlers_r IMFS_link_handlers = {
> diff --git a/cpukit/libfs/src/imfs/imfs_memfile.c b/cpukit/libfs/src/imfs/imfs_memfile.c
> index 2b6a496..2227bba 100644
> --- a/cpukit/libfs/src/imfs/imfs_memfile.c
> +++ b/cpukit/libfs/src/imfs/imfs_memfile.c
> @@ -844,6 +844,7 @@ static const rtems_filesystem_file_handlers_r IMFS_memfile_handlers = {
> diff --git a/cpukit/libfs/src/imfs/imfs_symlink.c b/cpukit/libfs/src/imfs/imfs_symlink.c
> index 0f06446..4358ad6 100644
> --- a/cpukit/libfs/src/imfs/imfs_symlink.c
> +++ b/cpukit/libfs/src/imfs/imfs_symlink.c
> @@ -95,6 +95,7 @@ static const rtems_filesystem_file_handlers_r IMFS_link_handlers = {
> diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
> index 8084776..5e702ce 100644
> --- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
> +++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
> @@ -606,6 +606,7 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_directory_handlers = {
> @@ -748,6 +749,7 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_file_handlers = {
> @@ -766,6 +768,7 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_link_handlers = {
> diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c b/cpukit/libfs/src/nfsclient/src/nfs.c
> index 5673a24..87fef54 100644
> --- a/cpukit/libfs/src/nfsclient/src/nfs.c
> +++ b/cpukit/libfs/src/nfsclient/src/nfs.c
> @@ -2884,6 +2884,7 @@ struct _rtems_filesystem_file_handlers_r nfs_file_file_handlers = {
> @@ -2904,6 +2905,7 @@ struct _rtems_filesystem_file_handlers_r nfs_dir_file_handlers = {
> @@ -2924,6 +2926,7 @@ struct _rtems_filesystem_file_handlers_r nfs_link_file_handlers = {
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> index a8ba126..3c69eaa 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> @@ -195,6 +195,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_device_handlers = {
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> index df0e639..ab4e56f 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> @@ -164,6 +164,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_dir_handlers = {
>    .fdatasync_h = rtems_rfs_rtems_fdatasync,
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> index 31df78a..99782db 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> @@ -348,6 +348,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_file_handlers = {
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> index 5ce526a..45455eb 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> @@ -701,6 +701,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_link_handlers =
> diff --git a/cpukit/libnetworking/lib/ftpfs.c b/cpukit/libnetworking/lib/ftpfs.c
> index e016cae..912ec82 100644
> --- a/cpukit/libnetworking/lib/ftpfs.c
> +++ b/cpukit/libnetworking/lib/ftpfs.c
> @@ -1404,6 +1404,7 @@ static const rtems_filesystem_file_handlers_r rtems_ftpfs_handlers = {
> @@ -1422,6 +1423,7 @@ static const rtems_filesystem_file_handlers_r rtems_ftpfs_root_handlers = {
> diff --git a/cpukit/libnetworking/lib/tftpDriver.c b/cpukit/libnetworking/lib/tftpDriver.c
> index 52236be..1a5823b 100644
> --- a/cpukit/libnetworking/lib/tftpDriver.c
> +++ b/cpukit/libnetworking/lib/tftpDriver.c
> @@ -1053,6 +1053,7 @@ static const rtems_filesystem_file_handlers_r rtems_tftp_handlers = {
> diff --git a/cpukit/libnetworking/rtems/rtems_syscall.c b/cpukit/libnetworking/rtems/rtems_syscall.c
> index 6bef21a..29b2b4c 100644
> --- a/cpukit/libnetworking/rtems/rtems_syscall.c
> +++ b/cpukit/libnetworking/rtems/rtems_syscall.c
> @@ -822,6 +822,7 @@ static const rtems_filesystem_file_handlers_r socket_handlers = {
>         .fcntl_h = rtems_bsdnet_fcntl,
> diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
> index 5b6ac2e..79e27ca 100644
> --- a/cpukit/posix/src/mmap.c
> +++ b/cpukit/posix/src/mmap.c
> @@ -5,6 +5,7 @@
>   * Copyright (c) 2012 Chris Johns (chrisj at rtems.org)
>   * Copyright (c) 2017 Gedare Bloom (gedare at rtems.org)
> + * Copyright (c) 2017 Kevin kirspel (kirspkt at gmail.com)
> @@ -107,30 +108,6 @@ bool mmap_mappings_lock_release(
>    return true;
> -/* Helper function only gets called for mmap mappings of shared memory objects
> - * with the MAP_SHARED flag.
> -static void *shm_mmap( rtems_libio_t *iop, size_t len, int prot, off_t off)
> -  POSIX_Shm_Control *shm = iop_to_shm( iop );
> -  void *m;
> -  _Objects_Allocator_lock();
> -  m = (*shm->shm_object.ops->object_mmap)( &shm->shm_object, len, prot, off);
> -  if ( m != NULL ) {
> -    /* Keep a reference in the shared memory to prevent its removal. */
> -    ++shm->reference_count;
> -    /* Update atime */
> -    _POSIX_Shm_Update_atime(shm);
> -  _Objects_Allocator_unlock();
> -  return m;
>  void *mmap(
>    void *addr, size_t len, int prot, int flags, int fildes, off_t off
> @@ -140,37 +117,25 @@ void *mmap(
>    ssize_t         r;
>    rtems_libio_t  *iop;
>    bool            map_fixed;
> +  bool            map_anonymous;
> +  bool            map_shared;
> +  bool            map_private;
> +  int             err;
>    map_fixed = (flags & MAP_FIXED) == MAP_FIXED;
> +  map_anonymous = (flags & MAP_ANON) == MAP_ANON;
> +  map_shared = (flags & MAP_SHARED) == MAP_SHARED;
> +  map_private = (flags & MAP_PRIVATE) == MAP_PRIVATE;
>    /* Clear errno. */
>    errno = 0;
> -   * Get a stat of the file to get the dev + inode number and to make sure the
> -   * fd is ok. The normal libio calls cannot be used because we need to return
> -   * MAP_FAILED on error and they return -1 directly without coming back to
> -   * here.
> -  if ( fstat( fildes, &sb ) < 0 ) {
> -    errno = EBADF;
> -    return MAP_FAILED;
> -  /* fstat ensures we have a good file descriptor. Hold on to iop. */
> -  iop = rtems_libio_iop( fildes );
> +  iop = NULL;
>    if ( len == 0 ) {
>      errno = EINVAL;
>      return MAP_FAILED;
> -  /* Check the type of file we have and make sure it is supported. */
> -  if ( S_ISDIR( sb.st_mode ) || S_ISLNK( sb.st_mode )) {
> -    errno = ENODEV;
>     * We can provide read, write and execute because the memory in RTEMS does
>     * not normally have protections but we cannot hide access to memory.
> @@ -180,17 +145,6 @@ void *mmap(
>      return MAP_FAILED;
> -  /* Either MAP_SHARED or MAP_PRIVATE must be defined, but not both */
> -  if ( (flags & MAP_SHARED) == MAP_SHARED ) {
> -    if ( (flags & MAP_PRIVATE) == MAP_PRIVATE ) {
> -      errno = EINVAL;
> -  } else if ( (flags & MAP_PRIVATE) != MAP_PRIVATE ) {
> -    errno = EINVAL;
>     * We can not normally provide restriction of write access. Reject any
>     * attempt to map without write permission, since we are not able to
> @@ -201,27 +155,104 @@ void *mmap(
>      return MAP_FAILED;
> -  /* Check to see if the mapping is valid for a regular file. */
> -  if ( S_ISREG( sb.st_mode )
> -  /* FIXME: Should this be using strict inequality (>) comparisons? It would
> -   * be valid to map a region exactly equal to the st_size, e.g. see below. */
> -       && (( off >= sb.st_size ) || (( off + len ) >= sb.st_size ))) {
> -    errno = EOVERFLOW;
> +   * Anonymous mappings must have file descriptor set to -1 and the offset
> +   * set to 0. Shared mappings or not supported with Anonymous mappings at
s/or/are
> +   * this time
> +  if ( map_anonymous && (fildes != -1 || off != 0 || map_shared) ) {
> +    errno = EINVAL;
>      return MAP_FAILED;
> -   * Check to see if the mapping is valid for other file/object types.
> -   * Does this satisfy for devices?
> +   * If MAP_ANON is decalred without MAP_PRIVATE or MAP_SHARED,
s/decalred/declared
> +   * force MAP_PRIVATE
> -  if ( sb.st_size < off + len ) {
> -    errno = ENXIO;
> +  if ( map_anonymous && !map_private && !map_shared ) {
> +    flags |= MAP_PRIVATE;
> +    map_private = true;
> +  /* Check for supported flags */
> +  if ((flags & ~(MAP_SHARED | MAP_PRIVATE | MAP_FIXED | MAP_ANON)) != 0) {
> +    errno = EINVAL;
>      return MAP_FAILED;
> -  /* Do not seek on character devices, pipes, sockets, or memory objects. */
> -  if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ) {
> -    if ( lseek( fildes, off, SEEK_SET ) < 0 ) {
> +  /* Either MAP_SHARED or MAP_PRIVATE must be defined, but not both */
> +  if ( map_shared ) {
> +    if ( map_private ) {
> +      errno = EINVAL;
> +      return MAP_FAILED;
> +  } else if ( !map_private ) {
> +    errno = EINVAL;
> +  /* Check for illegal addresses. Watch out for address wrap. */
> +  if ( map_fixed ) {
> +    if ((uintptr_t)addr & PAGE_MASK) {
> +      errno = EINVAL;
> +    if ( addr == NULL ) {
> +      errno = EINVAL;
> +    if (addr + len < addr) {
> +      errno = EINVAL;
> +  if ( !map_anonymous ) {
> +     * Get a stat of the file to get the dev + inode number and to make sure the
> +     * fd is ok. The normal libio calls cannot be used because we need to return
> +     * MAP_FAILED on error and they return -1 directly without coming back to
> +     * here.
> +    if ( fstat( fildes, &sb ) < 0 ) {
> +      errno = EBADF;
> +    /* fstat ensures we have a good file descriptor. Hold on to iop. */
> +    iop = rtems_libio_iop( fildes );
> +    /* Check the type of file we have and make sure it is supported. */
> +    if ( S_ISDIR( sb.st_mode ) || S_ISLNK( sb.st_mode )) {
> +      errno = ENODEV;
> +    /* Check to see if the mapping is valid for a regular file. */
> +    if ( S_ISREG( sb.st_mode )
> +    /* FIXME: Should this be using strict inequality (>) comparisons? It would
> +     * be valid to map a region exactly equal to the st_size, e.g. see below. */
> +         && (( off >= sb.st_size ) || (( off + len ) >= sb.st_size ))) {
> +      errno = EOVERFLOW;
> +    /* Check to see if the mapping is valid for other file/object types. */
> +    if ( !S_ISCHR( sb.st_mode ) && sb.st_size < off + len ) {
> +      errno = ENXIO;
> +    /* Do not seek on character devices, pipes, sockets, or memory objects. */
> +    if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ) {
> +      if ( lseek( fildes, off, SEEK_SET ) < 0 ) {
> +    /* cdevs do not provide private mappings of any kind. */
> +    if ( S_ISCHR( sb.st_mode ) && map_private ) {
> +      errno = EINVAL;
>        return MAP_FAILED;
> @@ -230,39 +261,34 @@ void *mmap(
>    mapping = malloc( sizeof( mmap_mapping ));
>    if ( !mapping ) {
>      errno = ENOMEM;
> -    return NULL;
>    memset( mapping, 0, sizeof( mmap_mapping ));
>    mapping->len = len;
>    mapping->flags = flags;
>    mapping->iop = iop;
> -   * HACK: We should have a better generic way to distinguish between
> -   * shm objects and other mmap'd files. We need to know at munmap time
> -   * if the mapping is to a shared memory object in order to refcnt shms.
> -   * We could do this by providing mmap in the file operations if needed.
> -  if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ||
> -       S_ISCHR( sb.st_mode ) || S_ISFIFO( sb.st_mode ) ||
> -       S_ISSOCK( sb.st_mode ) ) {
> -    mapping->is_shared_shm = false;
> +     * HACK: We should have a better generic way to distinguish between
> +     * shm objects and other mmap'd files. We need to know at munmap time
> +     * if the mapping is to a shared memory object in order to refcnt shms.
> +     * We could do this by providing mmap in the file operations if needed.
> +    if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ||
> +         S_ISCHR( sb.st_mode ) || S_ISFIFO( sb.st_mode ) ||
> +         S_ISSOCK( sb.st_mode ) ) {
> +      mapping->is_shared_shm = false;
> +    } else {
> +      mapping->is_shared_shm = true;
>    } else {
> -    mapping->is_shared_shm = true;
> -   * MAP_SHARED currently is only supported for shared memory objects.
> -  if ( (MAP_SHARED == (flags & MAP_SHARED)) && (mapping->is_shared_shm == false) ) {
> -    free( mapping );
> -    errno = ENOTSUP;
>    if ( map_fixed ) {
>      mapping->addr = addr;
> -  } else if ( MAP_PRIVATE == (flags & MAP_PRIVATE) ) {
> +  } else if ( map_private ) {
>      /* private mappings of shared memory do not need special treatment. */
>      mapping->addr = malloc( len );
> @@ -306,32 +332,43 @@ void *mmap(
>    /* Populate the data */
> -  if ( MAP_PRIVATE == (flags & MAP_PRIVATE) ) {
> -     * Use read() for private mappings. This updates atime as needed.
> -     * Changes to the underlying object will NOT be reflected in the mapping.
> -     * The underlying object can be removed while the mapping exists.
> -    r = read( fildes, mapping->addr, len );
> +       * Use read() for private mappings. This updates atime as needed.
> +       * Changes to the underlying object will NOT be reflected in the mapping.
> +       * The underlying object can be removed while the mapping exists.
> +      r = read( fildes, mapping->addr, len );
> -    if ( r != len ) {
> -      mmap_mappings_lock_release( );
> -      if ( !map_fixed ) {
> -        free( mapping->addr );
> +      if ( r != len ) {
> +        mmap_mappings_lock_release( );
> +        if ( !map_fixed ) {
> +          free( mapping->addr );
> +        free( mapping );
> +        errno = ENXIO;
> +    } else if ( !map_fixed ) {
> +      memset( mapping->addr, 0, len );
> +  } else if ( map_shared ) {
> +    err = (*iop->pathinfo.handlers->mmap_h)(
> +        iop, &mapping->addr, len, prot, off );
> +    if ( err != 0 ) {
>        free( mapping );
> -      errno = ENXIO;
>        return MAP_FAILED;
> -  } else if ( MAP_SHARED == (flags & MAP_SHARED) ) {
> -    /* Currently only shm objects can be MAP_SHARED. */
> -    mapping->addr = shm_mmap(iop, len, prot, off);
> -  /* add an extra reference to the file associated with fildes that
> -   * is not removed by a subsequent close().  This reference shall be removed
> -   * when there are no more mappings to the file. */
> -  rtems_libio_increment_mapping_refcnt(iop);
> +  if ( iop != NULL ) {
> +    /* add an extra reference to the file associated with fildes that
> +     * is not removed by a subsequent close().  This reference shall be removed
> +     * when there are no more mappings to the file. */
> +    rtems_libio_increment_mapping_refcnt(iop);
>    rtems_chain_append( &mmap_mappings, &mapping->node );
> diff --git a/cpukit/posix/src/munmap.c b/cpukit/posix/src/munmap.c
> index 323a24e..2d812ae 100644
> --- a/cpukit/posix/src/munmap.c
> +++ b/cpukit/posix/src/munmap.c
> @@ -46,6 +46,12 @@ int munmap(void *addr, size_t len)
>      return -1;
> +    errno = EINVAL;
> +    return -1;
>     * Obtain the mmap lock. Sets errno on failure.
> @@ -63,9 +69,11 @@ int munmap(void *addr, size_t len)
>        if ( mapping->is_shared_shm == true ) {
>          shm_munmap(mapping->iop);
> -      refcnt = rtems_libio_decrement_mapping_refcnt(mapping->iop);
> -      if ( refcnt == 0 ) {
> -        rtems_libio_check_deferred_free(mapping->iop);
> +      if ( mapping->iop != NULL ) {
> +        refcnt = rtems_libio_decrement_mapping_refcnt(mapping->iop);
> +        if ( refcnt == 0 ) {
> +          rtems_libio_check_deferred_free(mapping->iop);
>        /* only free the mapping address for non-fixed mapping */
>        if (( mapping->flags & MAP_FIXED ) != MAP_FIXED ) {
> diff --git a/cpukit/posix/src/shmopen.c b/cpukit/posix/src/shmopen.c
> index fa1027e..36ec312 100644
> --- a/cpukit/posix/src/shmopen.c
> +++ b/cpukit/posix/src/shmopen.c
> @@ -106,6 +106,35 @@ static int shm_close( rtems_libio_t *iop )
>    return 0;
> +static int shm_mmap(
> +  void** addr,
> +  size_t len,
> +  int prot,
> +  off_t off
> +  POSIX_Shm_Control *shm = iop_to_shm( iop );
> +  _Objects_Allocator_lock();
> +  *addr = (*shm->shm_object.ops->object_mmap)( &shm->shm_object, len, prot, off);
> +  if ( addr != NULL ) {
> +    /* Keep a reference in the shared memory to prevent its removal. */
> +    ++shm->reference_count;
> +    /* Update atime */
> +    _POSIX_Shm_Update_atime(shm);
> +  } else {
> +    _Objects_Allocator_unlock();
> +    rtems_set_errno_and_return_minus_one( ENOMEM );
> +  return 0;
>  static inline POSIX_Shm_Control *shm_allocate(
>    const char *name_arg,
>    size_t name_len,
> @@ -275,6 +304,7 @@ static const rtems_filesystem_file_handlers_r shm_handlers = {
> +  .mmap_h = shm_mmap,
> 1.9.1
> devel mailing list
> devel at rtems.org
