[PATCH 3/3] network: Do not use MSIZE
Mon May 22 12:16:02 UTC 2017
Do not use the MSIZE for the legacy network stack.  Instead use
_SYS_MBUF_LEGACY_MSIZE.
Update #2833.
 cpukit/libnetworking/kern/uipc_socket2.c |  4 ++--
 cpukit/libnetworking/rtems/rtems_glue.c  | 10 +++++-----
 cpukit/libnetworking/sys/mbuf.h          |  8 +++++---
 cpukit/libnetworking/sys/socketvar.h     |  4 ++--
 4 files changed, 14 insertions(+), 12 deletions(-)
diff --git a/cpukit/libnetworking/kern/uipc_socket2.c b/cpukit/libnetworking/kern/uipc_socket2.c
index c2d18b1..e6ea672 100644
--- a/cpukit/libnetworking/kern/uipc_socket2.c
+++ b/cpukit/libnetworking/kern/uipc_socket2.c
@@ -343,7 +343,7 @@ int
 sbreserve(struct sockbuf *sb, u_long cc)
-	if (cc > sb_max * MCLBYTES / (MSIZE + MCLBYTES))
+	if (cc > sb_max * MCLBYTES / (_SYS_MBUF_LEGACY_MSIZE + MCLBYTES))
 		return (0);
 	sb->sb_hiwat = cc;
 	sb->sb_mbmax = min(cc * sb_efficiency, sb_max);
@@ -424,7 +424,7 @@ sbcheck(struct sockbuf *sb)
 	for (m = sb->sb_mb; m; m = m->m_next) {
 		len += m->m_len;
-		mbcnt += MSIZE;
+		mbcnt += _SYS_MBUF_LEGACY_MSIZE;
 		if (m->m_flags & M_EXT) /*XXX*/ /* pretty sure this is bogus */
 			mbcnt += m->m_ext.ext_size;
 		if (m->m_nextpkt)
diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
index 46f8765..ac75fb0 100644
--- a/cpukit/libnetworking/rtems/rtems_glue.c
+++ b/cpukit/libnetworking/rtems/rtems_glue.c
@@ -39,7 +39,7 @@
  * Memory allocation
-static uint32_t nmbuf       = (64L * 1024L) / MSIZE;
+static uint32_t nmbuf       = (64L * 1024L) / _SYS_MBUF_LEGACY_MSIZE;
        uint32_t nmbclusters = (128L * 1024L) / MCLBYTES;
@@ -221,8 +221,8 @@ bsd_init (void)
 	 * Set up mbuf data structures
-	p = rtems_bsdnet_malloc_mbuf(nmbuf * MSIZE + MSIZE - 1,MBUF_MALLOC_MBUF);
-	p = (char *)(((uintptr_t)p + MSIZE - 1) & ~(MSIZE - 1));
+	p = rtems_bsdnet_malloc_mbuf(nmbuf * _SYS_MBUF_LEGACY_MSIZE + _SYS_MBUF_LEGACY_MSIZE - 1,MBUF_MALLOC_MBUF);
+	p = (char *)(((uintptr_t)p + _SYS_MBUF_LEGACY_MSIZE - 1) & ~(_SYS_MBUF_LEGACY_MSIZE - 1));
 	if (p == NULL) {
 		printf ("Can't get network memory.\n");
 		return -1;
@@ -230,7 +230,7 @@ bsd_init (void)
 	for (i = 0; i < nmbuf; i++) {
 		((struct mbuf *)p)->m_next = mmbfree;
 		mmbfree = (struct mbuf *)p;
-		p += MSIZE;
+		p += _SYS_MBUF_LEGACY_MSIZE;
 	mbstat.m_mbufs = nmbuf;
 	mbstat.m_mtypes[MT_FREE] = nmbuf;
@@ -296,7 +296,7 @@ rtems_bsdnet_initialize (void)
 	 * Set the memory allocation limits
 	if (rtems_bsdnet_config.mbuf_bytecount)
-		nmbuf = rtems_bsdnet_config.mbuf_bytecount / MSIZE;
+		nmbuf = rtems_bsdnet_config.mbuf_bytecount / _SYS_MBUF_LEGACY_MSIZE;
 	if (rtems_bsdnet_config.mbuf_cluster_bytecount)
 		nmbclusters = rtems_bsdnet_config.mbuf_cluster_bytecount / MCLBYTES;
diff --git a/cpukit/libnetworking/sys/mbuf.h b/cpukit/libnetworking/sys/mbuf.h
index 48e9e40..8d0c6c2 100644
--- a/cpukit/libnetworking/sys/mbuf.h
+++ b/cpukit/libnetworking/sys/mbuf.h
@@ -34,19 +34,21 @@
 #ifndef _SYS_MBUF_H_
 #define _SYS_MBUF_H_
+#include <sys/param.h>
 #ifndef M_WAITOK
 #include <sys/malloc.h>
 #endif
- * Mbufs are of a single size, MSIZE (machine/machparam.h), which
+ * Mbufs are of a single size, _SYS_MBUF_LEGACY_MSIZE (machine/machparam.h), which
  * includes overhead.  An mbuf may add a single "mbuf cluster" of size
  * MCLBYTES (also in machine/machparam.h), which has no additional overhead
  * and is used instead of the internal data area; this is done when
  * at least MINCLSIZE of data must be stored.
-#define	MLEN		(MSIZE - sizeof(struct m_hdr))	/* normal data len */
+#define	_SYS_MBUF_LEGACY_MSIZE 128
+#define	MLEN		(_SYS_MBUF_LEGACY_MSIZE - sizeof(struct m_hdr))	/* normal data len */
 #define	MHLEN		(MLEN - sizeof(struct pkthdr))	/* data len w/pkthdr */
 #define	MINCLSIZE	(MHLEN + MLEN)	/* smallest amount to put in cluster */
 #define	M_MAXCOMPRESS	(MHLEN / 2)	/* max amount to copy for compression */
@@ -59,7 +61,7 @@
  * cltom(x) 	-- Convert cluster # to ptr to beginning of cluster
 #define	mtod(m, t)	((t)((m)->m_data))
-#define	dtom(x)		((struct mbuf *)((intptr_t)(x) & ~(MSIZE-1)))
+#define	dtom(x)		((struct mbuf *)((intptr_t)(x) & ~(_SYS_MBUF_LEGACY_MSIZE-1)))
 #define	mtocl(x)	(((uintptr_t)(x) - (uintptr_t)mbutl) >> MCLSHIFT)
 #define	cltom(x)	((caddr_t)((u_long)mbutl + ((u_long)(x) << MCLSHIFT)))
diff --git a/cpukit/libnetworking/sys/socketvar.h b/cpukit/libnetworking/sys/socketvar.h
index 13b3674..bc3709c 100644
--- a/cpukit/libnetworking/sys/socketvar.h
+++ b/cpukit/libnetworking/sys/socketvar.h
@@ -160,7 +160,7 @@ struct socket {
 /* adjust counters in sb reflecting allocation of m */
 #define	sballoc(sb, m) { \
 	(sb)->sb_cc += (m)->m_len; \
-	(sb)->sb_mbcnt += MSIZE; \
+	(sb)->sb_mbcnt += _SYS_MBUF_LEGACY_MSIZE; \
 	if ((m)->m_flags & M_EXT) \
 		(sb)->sb_mbcnt += (m)->m_ext.ext_size; \
@@ -168,7 +168,7 @@ struct socket {
 /* adjust counters in sb reflecting freeing of m */
 #define	sbfree(sb, m) { \
 	(sb)->sb_cc -= (m)->m_len; \
-	(sb)->sb_mbcnt -= MSIZE; \
+	(sb)->sb_mbcnt -= _SYS_MBUF_LEGACY_MSIZE; \
 		(sb)->sb_mbcnt -= (m)->m_ext.ext_size; \
1.8.4.5
