arm/rtl22xx_t build failures
Tue May 23 08:06:05 UTC 2017
On 23/05/17 05:02, Chris Johns wrote:
> On 23/5/17 8:52 am, Chris Johns wrote:
>> These failures are showing up with ARM and I think other BSPs have a similar issue. I will build the whole architecture soon and report the failures.
>> Failures:
>>     1 posix-profiling arm/rtl22xx_t build:
>>        configure: /opt/work/chris/rtems/kernel/rtems.git/configure --target\
>>        =arm-rtems4.12 --enable-rtemsbsp=rtl22xx_t --prefix=/opt/rtems/4.12\
>>        --enable-posix --enable-profiling
>>     1 profiling arm/rtl22xx_t build:
>>        --enable-profiling
>> $ /build/rtems/tools/4.12/bin/arm-rtems4.12-gcc --version
>> arm-rtems4.12-gcc (GCC) 6.3.0 20161221 (RTEMS 4.12, RSB 5feef6503362dcc47c1175c3823935263038bf2d, Newlib 2.5.0.20170323)
> The error from the log is:
> mv -f .deps/libscorecpu_a-cpu_asm.Tpo .deps/libscorecpu_a-cpu_asm.Po
> /opt/work/chris/rtems/kernel/rtems.git/c/src/../../cpukit/score/cpu/arm/arm_exc_interrupt.S:277:
> Error: lo register required -- `add lr,pc,#1'
https://git.rtems.org/rtems/commit/?id=d5c8756660808bd1a330fd32c07a5ce9d63169bd
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
