Move POSIX header files to Newlib
Tue May 23 08:27:40 UTC 2017
On 22/05/17 14:07, Sebastian Huber wrote:
> Hello,
> I had some time to work on the POSIX header file move to Newlib:
> https://sourceware.org/ml/newlib/2017/msg00343.html
> I hope this is enough to build Ada without an installed BSP. It helps
> to get rid of all header file hacks in libbsd.
With an additional patch:
https://sourceware.org/ml/newlib/2017/msg00348.html
I was able to build the Ada compiler on openSUSE 42.2 without a BSP
installed.
arm-rtems4.12-gnatmake --version
GNATMAKE 6.3.1 20170523 [gcc-6-branch revision
7720ad9c4ca:28ac32f2b2a:2748c3748e109cf57e24d747d10741bfa8c0a5cc]
Copyright (C) 1995-2016, Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
