[PATCH 3/3] ada: Remove task notepad support
Tue May 23 09:35:19 UTC 2017
Update #2493.
 c/src/ada/rtems-tasks.ads | 14 --------------
 1 file changed, 14 deletions(-)
diff --git a/c/src/ada/rtems-tasks.ads b/c/src/ada/rtems-tasks.ads
index 2cb31576e5..cdd95ea309 100644
--- a/c/src/ada/rtems-tasks.ads
+++ b/c/src/ada/rtems-tasks.ads
@@ -103,20 +103,6 @@ package RTEMS.Tasks is
       Result            :    out RTEMS.Status_Codes
-   procedure Get_Note (
-      ID      : in     RTEMS.ID;
-      Notepad : in     RTEMS.Notepad_Index;
-      Note    :    out RTEMS.Unsigned32;
-      Result  :    out RTEMS.Status_Codes
-   procedure Set_Note (
-      ID      : in     RTEMS.ID;
-      Note    : in     RTEMS.Unsigned32;
    procedure Wake_When (
       Time_Buffer : in     RTEMS.Time_Of_Day;
2.12.0
