[PATCH] Add the i2c driver for Beaglebone Black:
Sichen Zhao
1473996754 at qq.com
Tue May 23 13:43:21 UTC 2017
Update ticket #2891 and my GSOC project
add c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
modify c/src/lib/libbsp/arm/beagle/include/i2c.h
modify c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
modify c/src/lib/libcpu/arm/shared/include/am335x.h
modify c/src/lib/libbsp/arm/beagle/Makefile.am
Now can read the EEPROM by i2c, the test application link is: https://github.com/hahchenchen/GSOC-test-application
c/src/lib/libbsp/arm/beagle/Makefile.am | 1 +
c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 577 +++++++++++++++++++++++++
c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h | 4 +-
c/src/lib/libbsp/arm/beagle/include/i2c.h | 161 ++++++-
c/src/lib/libcpu/arm/shared/include/am335x.h | 198 +++++++++
5 files changed, 921 insertions(+), 20 deletions(-)
create mode 100644 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 8bb8478..274dc0e 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -115,6 +115,7 @@ libbsp_a_SOURCES += ../../shared/console.c \
# I2C
libbsp_a_SOURCES += misc/i2c.c
+libbsp_a_SOURCES += i2c/bbb-i2c.c
# GPIO
libbsp_a_SOURCES += gpio/bbb-gpio.c
diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
new file mode 100644
index 0000000..5c8958f
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
@@ -0,0 +1,577 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief BeagleBoard I2C bus initialization and API Support.
+ * Copyright (c) 2017 Sichen Zhao <zsc19940506 at gmail.com>
+ * Modified on Punit Vara<punitvara at gmail.com> works, currently
+ * the i2c file is working on the Beaglebone Black board(AM335x).
+#include <stdio.h>
+#include <bsp/i2c.h>
+#include <libcpu/am335x.h>
+#include <rtems/irq-extension.h>
+#include <rtems/counter.h>
+#include <bsp/bbb-gpio.h>
+#include <rtems/score/assert.h>
+static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
+ REG(bus->regs + AM335X_CONF_I2C0_SDA) =
+ (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
+ REG(bus->regs + AM335X_CONF_I2C0_SCL) =
+static void I2C0ModuleClkConfig(void)
+ /* Configuring L3 Interface Clocks. */
+ /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) |=
+ CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
+ /* Waiting for MODULEMODE field to reflect the written value. */
+ while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) &
+ CM_PER_L3_CLKCTRL_MODULEMODE));
+ /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) |=
+ CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
+ while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) &
+ CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
+ /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) |=
+ CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ /* Waiting for CLKTRCTRL field to reflect the written value. */
+ while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) &
+ CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
+ /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) |=
+ CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ /*Waiting for CLKTRCTRL field to reflect the written value. */
+ while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) &
+ CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
+ /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) |=
+ CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) &
+ CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
+ /* Checking fields for necessary values. */
+ /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */
+ while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
+ CM_PER_L3_CLKCTRL_IDLEST));
+ ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the
+ ** desired value.
+ while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
+ CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
+ CM_PER_L3_INSTR_CLKCTRL_IDLEST));
+ ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
+ ** attain the desired value.
+ while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
+ CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
+ ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
+ ** register to attain the desired value.
+ while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
+ CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
+ ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
+ ** to attain the desired value.
+ while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
+ CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
+ /* Configuring registers related to Wake-Up region. */
+ /* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
+ REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) |=
+ CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE;
+ while(CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) &
+ CM_WKUP_CONTROL_CLKCTRL_MODULEMODE));
+ REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) |=
+ CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ while(CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) &
+ CM_WKUP_CLKSTCTRL_CLKTRCTRL));
+ /* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
+ REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) |=
+ CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) &
+ CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL));
+ /* Writing to MODULEMODE field of CM_WKUP_I2C0_CLKCTRL register. */
+ REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) |=
+ CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
+ while(CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) &
+ CM_WKUP_I2C0_CLKCTRL_MODULEMODE));
+ /* Verifying if the other bits are set to required settings. */
+ ** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to attain
+ ** desired value.
+ while((CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
+ CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT) !=
+ CM_WKUP_CONTROL_CLKCTRL_IDLEST));
+ ** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
+ ** register to attain desired value.
+ while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK !=
+ CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK));
+ ** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to attain
+ ** desired value.
+ while((CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC <<
+ CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT) !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_L4WKUP_CLKCTRL) &
+ CM_WKUP_L4WKUP_CLKCTRL_IDLEST));
+ ** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL register
+ ** to attain desired value.
+ while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK !=
+ CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK));
+ ** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in CM_L4_WKUP_AON_CLKSTCTRL
+ while(CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL) &
+ CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK));
+ ** Waiting for CLKACTIVITY_I2C0_GFCLK field in CM_WKUP_CLKSTCTRL
+ while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
+ CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK));
+ ** Waiting for IDLEST field in CM_WKUP_I2C0_CLKCTRL register to attain
+ ** desired value.
+ while((CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
+ CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT) !=
+ CM_WKUP_I2C0_CLKCTRL_IDLEST));
+static void am335x_i2c_reset(bbb_i2c_bus *bus)
+ volatile bbb_i2c_regs *regs = bus->regs;
+ int timeout = I2C_TIMEOUT;
+ if (REG(®s->BBB_I2C_CON) & I2C_CON_EN) {
+ REG(®s->BBB_I2C_CON) = I2C_CON_CLR;
+ udelay(50000);
+ REG(®s->BBB_I2C_SYSC) = I2C_SYSC_SRST; /* for ES2 after soft reset */
+ udelay(1000);
+ REG(®s->BBB_I2C_CON) = I2C_CON_EN;
+ while (!(REG(®s->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
+ if (timeout <= 0) {
+ puts("ERROR: Timeout in soft-reset\n");
+ return;
+ udelay(1000);
+Possible values for msg->flag
+ * - @ref I2C_M_TEN,
+ * - @ref I2C_M_RD,
+ * - @ref I2C_M_STOP,
+ * - @ref I2C_M_NOSTART,
+ * - @ref I2C_M_REV_DIR_ADDR,
+ * - @ref I2C_M_IGNORE_NAK,
+ * - @ref I2C_M_NO_RD_ACK, and
+ * - @ref I2C_M_RECV_LEN.
+static void am335x_i2c_set_address_size(const i2c_msg *msgs,
+ volatile bbb_i2c_regs *regs)
+ /*can be configured multiple modes here. Need to think about own address modes*/
+ if ((msgs->flags & I2C_M_TEN) == 0) {
+ /* 7-bit mode slave address mode*/
+ REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_7BIT_SLAVE_ADDR;
+ } else {
+ /* 10-bit slave address mode*/
+ REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_10BIT_SLAVE_ADDR;
+static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
+ i2c_msg *msg;
+ ++bus->msgs;
+ --bus->msg_todo;
+ msg = &bus->msgs[0];
+ bus->current_msg_todo = msg->len;
+ bus->current_msg_byte = msg->buf;
+static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
+ return (REG(®s->BBB_I2C_IRQSTATUS_RAW));
+static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs,
+ unsigned int flag)
+ REG(®s->BBB_I2C_IRQENABLE_SET) |= flag;
+static void am335x_i2c_masterint_disable(volatile bbb_i2c_regs *regs,
+ REG(®s->BBB_I2C_IRQENABLE_CLR) = flag;
+static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
+ REG(®s->BBB_I2C_IRQSTATUS) = flag;
+static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
+ am335x_i2c_masterint_enable(regs,I2C_ALL_FLAGS);
+ am335x_int_clear(regs,I2C_ALL_FLAGS);
+ am335x_i2c_masterint_disable(regs,I2C_ALL_FLAGS);
+static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus,
+ volatile bbb_i2c_regs *regs,
+ const i2c_msg *msgs, bool send_stop)
+ volatile unsigned int no_bytes;
+ int status;
+ REG(®s->BBB_I2C_CNT) = bus->current_msg_todo;
+ REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN;
+ if (send_stop) {
+ REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START | AM335X_I2C_CON_STOP;
+ } else {
+ REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
+ am335x_i2c_masterint_enable(regs,AM335X_I2C_INT_RECV_READY
+ | AM335X_I2C_IRQSTATUS_ARDY);
+static void am335x_i2c_continue_read_transfer(
+ bbb_i2c_bus *bus,
+ bus->current_msg_byte[bus->already_transferred] = REG(®s->BBB_I2C_DATA);
+ bus->already_transferred++;
+ REG(®s->BBB_I2C_IRQSTATUS) = AM335X_I2C_INT_RECV_READY;
+ if (bus->already_transferred == bus->current_msg_todo-1) {
+ REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
+static void am335x_i2c_continue_write(bbb_i2c_bus *bus,
+if (bus->already_transferred == bus->msg_todo) {
+ REG(®s->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
+ REG(®s->BBB_I2C_IRQSTATUS) = AM335X_I2C_IRQSTATUS_XRDY;
+ am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY );
+ } else {
+ writeb(bus->current_msg_byte[bus->already_transferred],®s->BBB_I2C_DATA);
+static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,
+ volatile bbb_i2c_regs *regs, const i2c_msg *msgs)
+ no_bytes = REG(®s->BBB_I2C_CNT);
+ REG(®s->BBB_I2C_SA) = msgs->addr;
+ REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
+ am335x_clean_interrupts(regs);
+ am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY );
+static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus,
+ const i2c_msg *msgs = bus->msgs;
+ uint32_t msg_todo = bus->msg_todo;
+ bool send_stop = false;
+ uint32_t i;
+ bus->current_todo = msgs[0].len;
+ for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
+ bus->current_todo += msgs[i].len;
+ regs = bus->regs;
+ REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
+ REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
+ am335x_i2c_set_address_size(msgs,regs);
+ bus->read = (msgs->flags & I2C_M_RD) != 0;
+ bus->already_transferred = (bus->read == true) ? 0 : 1;
+ if (bus->read) {
+ if (bus->current_msg_todo == 1) {
+ send_stop = true;
+ am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
+ } else {
+ am335x_i2c_setup_write_transfer(bus,regs,msgs);
+static void am335x_i2c_interrupt(void *arg)
+ bbb_i2c_bus *bus = arg;
+ /* get status of enabled interrupts */
+ uint32_t irqstatus = REG(®s->BBB_I2C_IRQSTATUS);
+ bool done = false;
+ /* Clear all enabled interrupt except receive ready and transmit ready interrupt in status register */
+ REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY
+ | AM335X_I2C_IRQSTATUS_XRDY));
+ if (irqstatus & AM335X_I2C_INT_RECV_READY ) {
+ am335x_i2c_continue_read_transfer(bus, regs);
+ if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
+ am335x_i2c_continue_write(bus,regs);
+ if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
+ done = true;
+ am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
+ if (irqstatus & AM335X_I2C_IRQSTATUS_ARDY) {
+ done = true;
+ REG(®s->BBB_I2C_IRQSTATUS) = I2C_STAT_ARDY;
+ if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
+ REG( ®s->BBB_I2C_IRQSTATUS) = AM335X_I2C_IRQSTATUS_BF;
+ if (done) {
+ uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
+ am335x_i2c_next_byte(bus);
+ if (bus->msg_todo == 0 ) {
+ rtems_status_code sc;
+ am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY
+ | AM335X_I2C_IRQSTATUS_BF));
+ REG(®s->BBB_I2C_IRQSTATUS) = err;
+ sc = rtems_event_transient_send(bus->task_id);
+ _Assert(sc == RTEMS_SUCCESSFUL);
+ (void) sc;
+ } else {
+ am335x_i2c_setup_transfer(bus, regs);
+static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
+ bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
+ volatile bbb_i2c_regs *regs;
+ uint32_t i;
+ rtems_task_wake_after(1);
+ if (msg_count < 1){
+ return 1;
+ for (i=0; i<msg_count;++i) {
+ if ((msgs[i].flags & I2C_M_RECV_LEN) != 0) {
+ return -EINVAL;
+ bus->msgs = &msgs[0];
+ bus->msg_todo = msg_count;
+ bus->current_msg_todo = msgs[0].len;
+ bus->current_msg_byte = msgs[0].buf;
+ bus->task_id = rtems_task_self();
+ regs = bus->regs;
+ am335x_i2c_setup_transfer(bus,regs);
+ REG(®s->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
+ sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
+ if (sc != RTEMS_SUCCESSFUL) {
+ am335x_i2c_reset(bus);
+ rtems_event_transient_clear();
+ return -ETIMEDOUT;
+ return 0;
+static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
+ bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
+ uint32_t prescaler,divider;
+ prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
+ REG(&bus->regs->BBB_I2C_PSC) = prescaler;
+ divider = BBB_I2C_INTERNAL_CLK/(2*clock);
+ REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
+ REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
+ return 0;
+static void am335x_i2c_destroy(i2c_bus *base)
+ sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt, bus);
+ (void)sc;
+ i2c_bus_destroy_and_free(&bus->base);
+int am335x_i2c_bus_register(
+ const char *bus_path,
+ uintptr_t register_base,
+ uint32_t input_clock,
+ rtems_vector_number irq
+ bbb_i2c_bus *bus;
+ int err;
+ /*check bus number is >0 & <MAX*/
+ bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init(sizeof(*bus));
+ if (bus == NULL) {
+ return -1;
+ bus->regs = (volatile bbb_i2c_regs *) register_base;
+ I2C0ModuleClkConfig();
+ am335x_i2c0_pinmux(bus);
+ bus->input_clock = input_clock;
+ err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
+ if (err != 0) {
+ (*bus->base.destroy)(&bus->base);
+ rtems_set_errno_and_return_minus_one(-err);
+ bus->irq = irq;
+ REG(&bus->regs->BBB_I2C_IRQSTATUS) = I2C_ALL_IRQ_FLAGS;
+ sc = rtems_interrupt_handler_install(
+ irq,
+ "BBB_I2C",
+ RTEMS_INTERRUPT_UNIQUE,
+ (rtems_interrupt_handler)am335x_i2c_interrupt,
+ bus
+ rtems_set_errno_and_return_minus_one(EIO);
+ bus->base.transfer = am335x_i2c_transfer;
+ bus->base.set_clock = am335x_i2c_set_clock;
+ bus->base.destroy = am335x_i2c_destroy;
+ return i2c_bus_register(&bus->base,bus_path);
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
index 8cce556..ceb12a4 100644
--- a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
+++ b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
@@ -35,9 +35,11 @@ extern "C" {
#define BBB_PU_EN (1 << 4)
#define BBB_PD_EN ~BBB_PU_EN
#define BBB_MUXMODE(X) (X & 0x7)
+#define BBB_RXACTIVE (1 << 5)
+#define BBB_SLEWCTRL (1 << 6)
#ifdef __cplusplus
#endif /* __cplusplus */
-#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
+#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
index e7d1716..d111070 100644
--- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
+++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
@@ -1,5 +1,5 @@
- * @file
@@ -24,7 +24,7 @@
#define LIBBSP_ARM_BEAGLE_I2C_H
+#include <dev/i2c/i2c.h>
#include <bsp.h>
#ifdef __cplusplus
@@ -43,6 +43,7 @@ extern "C" {
#define I2C_CON_XA (1 << 8) /* Expand address */
#define I2C_CON_STP (1 << 1) /* Stop condition (master mode only) */
#define I2C_CON_STT (1 << 0) /* Start condition (master mode only) */
+#define I2C_CON_CLR 0x0 /* Clear configuration register */
/* I2C Status Register (I2C_STAT): */
@@ -57,7 +58,6 @@ extern "C" {
#define I2C_STAT_ARDY (1 << 2) /* Register access ready */
#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */
#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */
/* I2C Interrupt Enable Register (I2C_IE): */
#define I2C_IE_GC_IE (1 << 5)
#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */
@@ -65,6 +65,10 @@ extern "C" {
#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */
#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */
#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */
+/* I2C SYSC Register (I2C_SYSC): */
+#define I2C_SYSC_SRST (1 << 1)
* The equation for the low and high time is
* tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed
@@ -144,6 +148,8 @@ extern "C" {
#define CONFIG_SYS_I2C_SPEED 100000
#define CONFIG_SYS_I2C_SLAVE 1
+#define I2C_ALL_FLAGS 0x7FFF
+#define I2C_ALL_IRQ_FLAGS 0xFFFF
struct i2c {
unsigned short rev; /* 0x00 */
@@ -180,20 +186,8 @@ struct i2c {
unsigned short res15;
-static unsigned short wait_for_pin( void );
-static void wait_for_bb( void );
-static void flush_fifo( void );
void i2c_init( int speed, int slaveadd );
-static int i2c_read_byte(
- unsigned char devaddr,
- unsigned char regoffset,
- unsigned char *value
int i2c_write(
unsigned char chip,
unsigned int addr,
@@ -210,10 +204,6 @@ int i2c_read(
int len
-static int imw ( unsigned char chip, unsigned long addr, unsigned char byte );
-static int imd( unsigned char chip, unsigned int addr, unsigned int length );
* @brief Initializes the I2C module @a i2c.
@@ -361,6 +351,139 @@ static inline rtems_status_code beagle_i2c_read(
return beagle_i2c_write_and_read(i2c, addr, NULL, 0, in, in_size);
+#define BBB_I2C_SYSCLK 48000000
+#define BBB_I2C_INTERNAL_CLK 12000000
+#define BBB_I2C_SPEED_CLK 100000
+#define BBB_I2C_IRQ_ERROR \
+ (AM335X_I2C_IRQSTATUS_NACK \
+ | AM335X_I2C_IRQSTATUS_ROVR \
+ | AM335X_I2C_IRQSTATUS_AL \
+ | AM335X_I2C_IRQSTATUS_ARDY \
+ | AM335X_I2C_IRQSTATUS_RRDY \
+ | AM335X_I2C_IRQSTATUS_XRDY \
+ | AM335X_I2C_IRQSTATUS_XUDF )
+ #define BBB_I2C_IRQ_USED \
+ ( AM335X_I2C_IRQSTATUS_ARDY \
+#define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
+#define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
+#define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
+#define BBB_I2C0_IRQ 70
+#define BBB_I2C1_IRQ 71
+#define BBB_I2C2_IRQ 30
+#define MODE2 2
+#define MODE3 3
+typedef enum {
+ I2C0,
+ I2C1,
+ I2C2,
+ I2C_COUNT
+}bbb_i2c_id_t;
+typedef struct i2c_regs
+ uint32_t BBB_I2C_REVNB_LO;
+ uint32_t BBB_I2C_REVNB_HI;
+ uint32_t dummy1[2];
+ uint32_t BBB_I2C_SYSC;
+ uint32_t dummy2[4];
+ uint32_t BBB_I2C_IRQSTATUS_RAW;
+ uint32_t BBB_I2C_IRQSTATUS;
+ uint32_t BBB_I2C_IRQENABLE_SET;
+ uint32_t BBB_I2C_IRQENABLE_CLR;
+ uint32_t BBB_I2C_WE;
+ uint32_t BBB_I2C_DMARXENABLE_SET;
+ uint32_t BBB_I2C_DMATXENABLE_SET;
+ uint32_t BBB_I2C_DMARXENABLE_CLR;
+ uint32_t BBB_I2C_DMATXENABLE_CLR;
+ uint32_t BBB_I2C_DMARXWAKE_EN;
+ uint32_t BBB_I2C_DMATXWAKE_EN;
+ uint32_t dummy3[16];
+ uint32_t BBB_I2C_SYSS;
+ uint32_t BBB_I2C_BUF;
+ uint32_t BBB_I2C_CNT;
+ uint32_t BBB_I2C_DATA;
+ uint32_t dummy4;
+ uint32_t BBB_I2C_CON;
+ uint32_t BBB_I2C_OA;
+ uint32_t BBB_I2C_SA;
+ uint32_t BBB_I2C_PSC;
+ uint32_t BBB_I2C_SCLL;
+ uint32_t BBB_I2C_SCLH;
+ uint32_t BBB_I2C_SYSTEST;
+ uint32_t BBB_I2C_BUFSTAT;
+ uint32_t BBB_I2C_OA1;
+ uint32_t BBB_I2C_OA2;
+ uint32_t BBB_I2C_OA3;
+ uint32_t BBB_I2C_ACTOA;
+ uint32_t BBB_I2C_SBLOCK;
+}bbb_i2c_regs;
+typedef struct bbb_i2c_bus{
+ i2c_bus base;
+ i2c_msg *msgs;
+ uint32_t msg_todo;
+ uint32_t current_msg_todo;
+ uint8_t *current_msg_byte;
+ uint32_t current_todo;
+ bool read;
+ bool hold;
+ rtems_id task_id;
+ rtems_vector_number irq;
+ uint32_t input_clock;
+ uint32_t already_transferred;
+} bbb_i2c_bus;
+static inline int bbb_register_i2c_0(void)
+ return am335x_i2c_bus_register(
+ BBB_I2C_0_BUS_PATH,
+ AM335X_I2C0_BASE,
+ I2C_BUS_CLOCK_DEFAULT,
+ BBB_I2C0_IRQ
+static inline int bbb_register_i2c_1(void)
+ BBB_I2C_1_BUS_PATH,
+ AM335X_I2C1_BASE,
+ BBB_I2C1_IRQ
+static inline int bbb_register_i2c_2(void)
+ BBB_I2C_2_BUS_PATH,
+ AM335X_I2C2_BASE,
+ BBB_I2C2_IRQ
#ifdef __cplusplus
diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
index f59f896..00b6ddb 100644
--- a/c/src/lib/libcpu/arm/shared/include/am335x.h
+++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
@@ -563,3 +563,201 @@
+/* I2C registers */
+#define AM335X_I2C0_BASE 0x44e0b000
+ /* I2C0 base address */
+#define AM335X_I2C1_BASE 0x4802a000
+ /* I2C1 base address */
+#define AM335X_I2C2_BASE 0x4819c000
+ /* I2C2 base address */
+#define AM335X_I2C_REVNB_LO 0x00
+ /* Module Revision Register (low bytes) */
+#define AM335X_I2C_REVNB_HI 0x04
+ /* Module Revision Register (high bytes) */
+#define AM335X_I2C_SYSC 0x10
+ /* System Configuration Register */
+#define AM335X_I2C_IRQSTATUS_RAW 0x24
+ /* I2C Status Raw Register */
+#define AM335X_I2C_IRQSTATUS 0x28
+ /* I2C Status Register */
+#define AM335X_I2C_IRQENABLE_SET 0x2c
+ /* I2C Interrupt Enable Set Register */
+#define AM335X_I2C_IRQENABLE_CLR 0x30
+ /* I2C Interrupt Enable Clear Register */
+#define AM335X_I2C_WE 0x34
+ /* I2C Wakeup Enable Register */
+#define AM335X_I2C_DMARXENABLE_SET 0x38
+ /* Receive DMA Enable Set Register */
+#define AM335X_I2C_DMATXENABLE_SET 0x3c
+ /* Transmit DMA Enable Set Register */
+#define AM335X_I2C_DMARXENABLE_CLR 0x40
+ /* Receive DMA Enable Clear Register */
+#define AM335X_I2C_DMATXENABLE_CLR 0x44
+ /* Transmit DMA Enable Clear Register */
+#define AM335X_I2C_DMARXWAKE_EN 0x48
+ /* Receive DMA Wakeup Register */
+#define AM335X_I2C_DMATXWAKE_EN 0x4c
+ /* Transmit DMA Wakeup Register */
+#define AM335X_I2C_SYSS 0x90
+ /* System Status Register */
+#define AM335X_I2C_BUF 0x94
+ /* Buffer Configuration Register */
+#define AM335X_I2C_CNT 0x98
+ /* Data Counter Register */
+#define AM335X_I2C_DATA 0x9c
+ /* Data Access Register */
+#define AM335X_I2C_CON 0xa4
+ /* I2C Configuration Register */
+#define AM335X_I2C_OA 0xa8
+ /* I2C Own Address Register */
+#define AM335X_I2C_SA 0xac
+ /* I2C Slave Address Register */
+#define AM335X_I2C_PSC 0xb0
+ /* I2C Clock Prescaler Register */
+#define AM335X_I2C_SCLL 0xb4
+ /* I2C SCL Low Time Register */
+#define AM335X_I2C_SCLH 0xb8
+ /* I2C SCL High Time Register */
+#define AM335X_I2C_SYSTEST 0xbc
+ /* System Test Register */
+#define AM335X_I2C_BUFSTAT 0xc0
+ /* I2C Buffer Status Register */
+#define AM335X_I2C_OA1 0xc4
+ /* I2C Own Address 1 Register */
+#define AM335X_I2C_OA2 0xc8
+ /* I2C Own Address 2 Register */
+#define AM335X_I2C_OA3 0xcc
+ /* I2C Own Address 3 Register */
+#define AM335X_I2C_ACTOA 0xd0
+ /* Active Own Address Register */
+#define AM335X_I2C_SBLOCK 0xd4
+ /* I2C Clock Blocking Enable Register */
+#define AM335X_CM_PER_L4LS_CLKSTCTRL (0x0)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define AM335X_CM_PER_L4LS_CLKCTRL (0x60)
+#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE (0x00000003u)
+#define AM335X_CM_PER_I2C1_CLKCTRL (0x48)
+#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define AM335X_ CM_PER_I2C1_CLKCTRL_MODULEMODE (0x00000003u)
+#define AM335X_CM_PER_I2C2_CLKCTRL (0x44)
+#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE (0x00000003u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK (0x00000100u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK (0x01000000u)
+#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE (0x00000003u)
+#define AM335X_I2C_CON_XSA (0x00000100u)
+#define AM335X_I2C_CFG_10BIT_SLAVE_ADDR AM335X_I2C_CON_XSA
+#define AM335X_I2C_CON_XSA_SHIFT (0x00000008u)
+#define AM335X_I2C_CFG_7BIT_SLAVE_ADDR (0 << AM335X_I2C_CON_XSA_SHIFT)
+#define AM335X_I2C_CON_I2C_EN (0x00008000u)
+#define AM335X_I2C_CON_TRX (0x00000200u)
+#define AM335X_I2C_CON_MST (0x00000400u)
+#define AM335X_I2C_CON_STB (0x00000800u)
+#define AM335X_I2C_SYSC_AUTOIDLE (0x00000001u)
+/*I2C0 module clock registers*/
+#define CM_PER_L3_CLKCTRL (0xe0)
+#define CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define CM_PER_L3_CLKCTRL_MODULEMODE (0x00000003u)
+#define CM_PER_L3_INSTR_CLKCTRL (0xdc)
+#define CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define CM_PER_L3_INSTR_CLKCTRL_MODULEMODE (0x00000003u)
+#define CM_PER_L3_CLKSTCTRL (0xc)
+#define CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define CM_PER_L3_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define CM_PER_OCPWP_L3_CLKSTCTRL (0x12c)
+#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define CM_PER_L3S_CLKSTCTRL (0x4)
+#define CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define CM_PER_L3S_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define CM_PER_L3_CLKCTRL_IDLEST_FUNC (0x0u)
+#define CM_PER_L3_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define CM_PER_L3_CLKCTRL_IDLEST (0x00030000u)
+#define CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC (0x0u)
+#define CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define CM_PER_L3_INSTR_CLKCTRL_IDLEST (0x00030000u)
+#define CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK (0x00000010u)
+#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK (0x00000010u)
+#define CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK (0x00000008u)
+#define CM_WKUP_CONTROL_CLKCTRL (0x4)
+#define CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define CM_WKUP_CONTROL_CLKCTRL_MODULEMODE (0x00000003u)
+#define CM_WKUP_CLKSTCTRL (0x0)
+#define CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define CM_WKUP_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define CM_WKUP_CM_L3_AON_CLKSTCTRL (0x18)
+#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define CM_WKUP_I2C0_CLKCTRL (0xb8)
+#define CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define CM_WKUP_I2C0_CLKCTRL_MODULEMODE (0x00000003u)
+#define CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC (0x0u)
+#define CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define CM_WKUP_CONTROL_CLKCTRL_IDLEST (0x00030000u)
+#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK (0x00000008u)
+#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC (0x0u)
+#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define CM_WKUP_L4WKUP_CLKCTRL (0xc)
+#define CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK (0x00000004u)
+#define CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK (0x00000004u)
+#define CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL (0xcc)
+#define CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK (0x00000800u)
+#define CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC (0x0u)
+#define CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define CM_WKUP_I2C0_CLKCTRL_IDLEST (0x00030000u)
+#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST (0x00030000u)
+#define SOC_CM_WKUP_REGS (AM335X_CM_PER_ADDR + 0x400)
+/* I2C status Register */
+#define AM335X_I2C_IRQSTATUS_NACK (1 << 1)
+#define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
+#define AM335X_I2C_IRQSTATUS_AL ( 1<<0 )
+#define AM335X_I2C_IRQSTATUS_ARDY (1 << 2)
+#define AM335X_I2C_IRQSTATUS_RRDY (1 << 3)
+#define AM335X_I2C_IRQSTATUS_XRDY (1 << 4)
+#define AM335X_I2C_IRQSTATUS_XUDF (1 << 10)
+#define AM335X_I2C_BUF_TXFIFO_CLR (0x00000040u)
+#define AM335X_I2C_BUF_RXFIFO_CLR (0x00004000u)
+#define AM335X_I2C_IRQSTATUS_AAS (1 << 9)
+#define AM335X_I2C_IRQSTATUS_BF (1 << 8)
+#define AM335X_I2C_IRQSTATUS_STC (1 << 6)
+#define AM335X_I2C_IRQSTATUS_GC (1 << 5)
+#define AM335X_I2C_IRQSTATUS_XDR (1 << 14)
+#define AM335X_I2C_IRQSTATUS_RDR (1 << 13)
+#define AM335X_I2C_INT_RECV_READY AM335X_I2C_IRQSTATUS_RRDY
+#define AM335X_I2C_CON_STOP (0x00000002u)
+#define AM335X_I2C_CON_START (0x00000001u)
+#define AM335X_I2C_CFG_MST_RX AM335X_I2C_CON_MST
+#define AM335X_I2C_CFG_MST_TX AM335X_I2C_CON_TRX | AM335X_I2C_CON_MST
+#define AM335X_I2C_IRQSTATUS_RAW_BB (0x00001000u)
+#define AM335X_I2C_IRQSTATUS_BF (0x00000100u)
+#define AM335X_CM_PER_L3S_CLKSTCTRL (0x4)
+#define AM335X_CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define AM335X_CM_PER_L3S_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define AM335X_CM_PER_L3_CLKSTCTRL (0xc)
+#define AM335X_CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define AM335X_CM_PER_L3_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define AM335X_CM_PER_L3_INSTR_CLKCTRL (0xdc)
+#define AM335X_CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define AM335X_CM_PER_L3_CLKCTRL (0xe0)
+#define AM335X_CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define AM335X_CM_PER_L3_CLKCTRL_MODULEMODE (0x00000003u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL (0x12c)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL (0x00000003u)
+#define AM335X_CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK (0x00000010u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK (0x00000010u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK (0x00000020u)
+#define AM335X_CM_PER_L3_INSTR_CLKCTRL_MODULEMODE (0x00000003u)
+#define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
2.7.4
