[PATCH] Add the i2c driver for Beaglebone Black:
Sichen Zhao 1473996754 at qq.com
Tue May 23 14:56:06 UTC 2017
Update ticket #2891 and my GSOC project
add c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
modify c/src/lib/libbsp/arm/beagle/include/i2c.h
modify c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
modify c/src/lib/libcpu/arm/shared/include/am335x.h
modify c/src/lib/libbsp/arm/beagle/Makefile.am
Now can read the EEPROM by i2c, the test application link is: https://github.com/hahchenchen/GSOC-test-application
 c/src/lib/libbsp/arm/beagle/Makefile.am        |   1 +
 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c      | 578 +++++++++++++++++++++++++
 c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h |   4 +-
 c/src/lib/libbsp/arm/beagle/include/i2c.h      | 162 ++++++-
 c/src/lib/libcpu/arm/shared/include/am335x.h   | 196 +++++++++
 5 files changed, 920 insertions(+), 21 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 8bb8478..274dc0e 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -115,6 +115,7 @@ libbsp_a_SOURCES += ../../shared/console.c \
 # I2C
 libbsp_a_SOURCES += misc/i2c.c
+libbsp_a_SOURCES += i2c/bbb-i2c.c
 # GPIO
 libbsp_a_SOURCES += gpio/bbb-gpio.c
diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
new file mode 100644
index 0000000..dbab776
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
@@ -0,0 +1,578 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief BeagleBoard I2C bus initialization and API Support.
+ * Copyright (c) 2017 Sichen Zhao <zsc19940506 at gmail.com>
+ * Modified on Punit Vara<punitvara at gmail.com> works, currently
+ * the i2c file is working on the Beaglebone Black board(AM335x)
+#include <stdio.h>
+#include <bsp/i2c.h>
+#include <libcpu/am335x.h>
+#include <rtems/irq-extension.h>
+#include <rtems/counter.h>
+#include <bsp/bbb-gpio.h>
+#include <rtems/score/assert.h>
+static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
+  REG(bus->regs + AM335X_CONF_I2C0_SDA) =
+  (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
+  REG(bus->regs + AM335X_CONF_I2C0_SCL) =
+static void I2C0ModuleClkConfig(void)
+    /* Configuring L3 Interface Clocks. */
+    /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
+  REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) |=
+          CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
+    /* Waiting for MODULEMODE field to reflect the written value. */
+  while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
+          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) &
+           CM_PER_L3_CLKCTRL_MODULEMODE));
+    /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
+  REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) |=
+          CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
+  while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
+          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) &
+           CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
+    /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
+  REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) |=
+          CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+    /* Waiting for CLKTRCTRL field to reflect the written value. */
+  while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) &
+           CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
+    /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
+  REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) |=
+          CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+    /*Waiting for CLKTRCTRL field to reflect the written value. */
+  while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+          (REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) &
+           CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
+    /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
+  REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) |=
+          CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+  while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+          (REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) &
+           CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
+    /* Checking fields for necessary values.  */
+    /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */
+  while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
+           CM_PER_L3_CLKCTRL_IDLEST));
+    ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the
+    ** desired value.
+  while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
+           CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
+           CM_PER_L3_INSTR_CLKCTRL_IDLEST));
+    ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
+    ** attain the desired value.
+  while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
+           CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
+    ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
+    ** register to attain the desired value.
+  while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
+           CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
+    ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
+    ** to attain the desired value.
+  while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
+          CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
+    /* Configuring registers related to Wake-Up region. */
+    /* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
+  REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) |=
+          CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE;
+  while(CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE !=
+          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) &
+           CM_WKUP_CONTROL_CLKCTRL_MODULEMODE));
+  REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) |=
+          CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+  while(CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) &
+           CM_WKUP_CLKSTCTRL_CLKTRCTRL));
+    /* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
+  REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) |=
+          CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+  while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) &
+           CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL));
+    /* Writing to MODULEMODE field of CM_WKUP_I2C0_CLKCTRL register. */
+  REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) |=
+          CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
+  while(CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
+          (REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) &
+           CM_WKUP_I2C0_CLKCTRL_MODULEMODE));
+    /* Verifying if the other bits are set to required settings. */
+    ** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to attain
+    ** desired value.
+  while((CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
+           CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT) !=
+           CM_WKUP_CONTROL_CLKCTRL_IDLEST));
+    ** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
+    ** register to attain desired value.
+  while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK !=
+           CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK));
+    ** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to attain
+    ** desired value.
+  while((CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC <<
+           CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT) !=
+          (REG(SOC_CM_WKUP_REGS + CM_WKUP_L4WKUP_CLKCTRL) &
+           CM_WKUP_L4WKUP_CLKCTRL_IDLEST));
+    ** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL register
+    ** to attain desired value.
+  while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK !=
+           CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK));
+    ** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in CM_L4_WKUP_AON_CLKSTCTRL
+  while(CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK !=
+          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL) &
+           CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK));
+    ** Waiting for CLKACTIVITY_I2C0_GFCLK field in CM_WKUP_CLKSTCTRL
+  while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
+           CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK));
+    ** Waiting for IDLEST field in CM_WKUP_I2C0_CLKCTRL register to attain
+    ** desired value.
+  while((CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
+           CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT) !=
+           CM_WKUP_I2C0_CLKCTRL_IDLEST));
+static void am335x_i2c_reset(bbb_i2c_bus *bus)
+  volatile bbb_i2c_regs *regs = bus->regs;
+   int timeout = I2C_TIMEOUT;
+  if (REG(&regs->BBB_I2C_CON) & I2C_CON_EN) {
+    REG(&regs->BBB_I2C_CON) = I2C_CON_CLR;
+    udelay(50000);
+  REG(&regs->BBB_I2C_SYSC) = I2C_SYSC_SRST; /* for ES2 after soft reset */
+  udelay(1000);
+  REG(&regs->BBB_I2C_CON) = I2C_CON_EN;
+  while (!(REG(&regs->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
+    if (timeout <= 0) {
+      puts("ERROR: Timeout in soft-reset\n");
+      return;
+    udelay(1000);
+Possible values for msg->flag
+   * - @ref I2C_M_TEN,
+   * - @ref I2C_M_RD,
+   * - @ref I2C_M_STOP,
+   * - @ref I2C_M_NOSTART,
+   * - @ref I2C_M_REV_DIR_ADDR,
+   * - @ref I2C_M_IGNORE_NAK,
+   * - @ref I2C_M_NO_RD_ACK, and
+   * - @ref I2C_M_RECV_LEN.
+static void am335x_i2c_set_address_size(const i2c_msg *msgs,
+           volatile bbb_i2c_regs *regs)
+    /*can be configured multiple modes here. Need to think about own address modes*/
+  if ((msgs->flags & I2C_M_TEN) == 0)  {
+  /* 7-bit mode slave address mode*/
+  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_7BIT_SLAVE_ADDR;
+  } else {
+  /* 10-bit slave address mode*/
+  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_10BIT_SLAVE_ADDR;
+static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
+  i2c_msg *msg;
+  ++bus->msgs;
+  --bus->msg_todo;
+  msg = &bus->msgs[0];
+  bus->current_msg_todo = msg->len;
+  bus->current_msg_byte = msg->buf;
+static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
+  return (REG(&regs->BBB_I2C_IRQSTATUS_RAW));
+static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs,
+       unsigned int flag)
+  REG(&regs->BBB_I2C_IRQENABLE_SET) |= flag;
+static void am335x_i2c_masterint_disable(volatile bbb_i2c_regs *regs,
+  REG(&regs->BBB_I2C_IRQENABLE_CLR) = flag;
+static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
+  REG(&regs->BBB_I2C_IRQSTATUS) = flag;
+static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
+  am335x_i2c_masterint_enable(regs,I2C_ALL_FLAGS);
+  am335x_int_clear(regs,I2C_ALL_FLAGS);
+  am335x_i2c_masterint_disable(regs,I2C_ALL_FLAGS);
+static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus,
+       volatile bbb_i2c_regs *regs,
+       const i2c_msg *msgs, bool send_stop)
+  volatile unsigned int no_bytes;
+  int status;
+  REG(&regs->BBB_I2C_CNT) = bus->current_msg_todo;
+  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN;
+  if (send_stop) {
+    REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_START | AM335X_I2C_CON_STOP;
+  } else {
+  REG(&regs->BBB_I2C_CON) |=  AM335X_I2C_CON_START;
+  am335x_i2c_masterint_enable(regs,AM335X_I2C_INT_RECV_READY
+                                  | AM335X_I2C_IRQSTATUS_ARDY);
+static void am335x_i2c_continue_read_transfer(
+  bbb_i2c_bus *bus,
+  bus->current_msg_byte[bus->already_transferred] = REG(&regs->BBB_I2C_DATA);
+  bus->already_transferred++;
+  REG(&regs->BBB_I2C_IRQSTATUS) = AM335X_I2C_INT_RECV_READY;
+  if (bus->already_transferred ==  bus->current_msg_todo-1) {
+  REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
+static void am335x_i2c_continue_write(bbb_i2c_bus *bus,
+if (bus->already_transferred == bus->msg_todo) {
+  REG(&regs->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
+  REG(&regs->BBB_I2C_IRQSTATUS) = AM335X_I2C_IRQSTATUS_XRDY;
+  am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY );
+   } else {
+  writeb(bus->current_msg_byte[bus->already_transferred],&regs->BBB_I2C_DATA);
+static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,
+       volatile bbb_i2c_regs *regs, const i2c_msg *msgs)
+  no_bytes = REG(&regs->BBB_I2C_CNT);
+  REG(&regs->BBB_I2C_SA) = msgs->addr;
+  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
+  am335x_clean_interrupts(regs);
+  am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY );
+static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus,
+  const i2c_msg *msgs = bus->msgs;
+  uint32_t msg_todo = bus->msg_todo;
+  bool send_stop = false;
+  uint32_t i;
+  bus->current_todo = msgs[0].len;
+  for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
+    bus->current_todo += msgs[i].len;
+  regs = bus->regs;
+  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
+  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
+  am335x_i2c_set_address_size(msgs,regs);
+  bus->read = (msgs->flags & I2C_M_RD) != 0;
+  bus->already_transferred = (bus->read == true) ? 0 : 1;
+  if (bus->read) {
+    if (bus->current_msg_todo == 1) {
+      send_stop = true;
+  am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
+  } else {
+  am335x_i2c_setup_write_transfer(bus,regs,msgs);
+static void am335x_i2c_interrupt(void *arg)
+  bbb_i2c_bus *bus = arg;
+  /* get status of enabled interrupts */
+  uint32_t irqstatus = REG(&regs->BBB_I2C_IRQSTATUS);
+  bool done = false;
+  /* Clear all enabled interrupt except receive ready
+  and transmit ready interrupt in status register */
+  REG(&regs->BBB_I2C_IRQSTATUS) = (irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY
+                                                | AM335X_I2C_IRQSTATUS_XRDY));
+ if (irqstatus & AM335X_I2C_INT_RECV_READY ) {
+    am335x_i2c_continue_read_transfer(bus, regs);
+  if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
+    am335x_i2c_continue_write(bus,regs);
+  if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
+    done = true;
+    am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
+   if (irqstatus & AM335X_I2C_IRQSTATUS_ARDY) {
+  done = true;
+  REG(&regs->BBB_I2C_IRQSTATUS) = I2C_STAT_ARDY;
+   if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
+   REG( &regs->BBB_I2C_IRQSTATUS) = AM335X_I2C_IRQSTATUS_BF;
+  if (done) {
+    uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
+    am335x_i2c_next_byte(bus);
+    if (bus->msg_todo == 0 ) {
+    rtems_status_code sc;
+    am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY
+                                       | AM335X_I2C_IRQSTATUS_BF));
+    REG(&regs->BBB_I2C_IRQSTATUS) = err;
+    sc = rtems_event_transient_send(bus->task_id);
+    _Assert(sc == RTEMS_SUCCESSFUL);
+    (void) sc;
+    } else {
+    am335x_i2c_setup_transfer(bus, regs);
+static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
+  bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
+  volatile bbb_i2c_regs *regs;
+  uint32_t i;
+  rtems_task_wake_after(1);
+  if (msg_count < 1){
+    return 1;
+  for (i=0; i<msg_count;++i) {
+      if ((msgs[i].flags & I2C_M_RECV_LEN) != 0) {
+        return -EINVAL;
+  bus->msgs = &msgs[0];
+  bus->msg_todo = msg_count;
+  bus->current_msg_todo = msgs[0].len;
+  bus->current_msg_byte = msgs[0].buf;
+  bus->task_id = rtems_task_self();
+  regs = bus->regs;
+  am335x_i2c_setup_transfer(bus,regs);
+  REG(&regs->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
+  sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
+  if (sc != RTEMS_SUCCESSFUL) {
+    am335x_i2c_reset(bus);
+    rtems_event_transient_clear();
+    return -ETIMEDOUT;
+  return 0;
+static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
+  bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
+  uint32_t prescaler,divider;
+  prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
+  REG(&bus->regs->BBB_I2C_PSC) = prescaler;
+  divider = BBB_I2C_INTERNAL_CLK/(2*clock);
+  REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
+  REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
+  return 0;
+static void am335x_i2c_destroy(i2c_bus *base)
+  sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt, bus);
+  (void)sc;
+  i2c_bus_destroy_and_free(&bus->base);
+int am335x_i2c_bus_register(
+  const char *bus_path,
+  uintptr_t register_base,
+  uint32_t input_clock,
+  rtems_vector_number irq
+  bbb_i2c_bus *bus;
+  int err;
+  /*check bus number is >0 & <MAX*/
+  bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init(sizeof(*bus));
+  if (bus == NULL) {
+    return -1;
+  bus->regs = (volatile bbb_i2c_regs *) register_base;
+  I2C0ModuleClkConfig();
+  am335x_i2c0_pinmux(bus);
+  bus->input_clock = input_clock;
+  err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
+  if (err != 0) {
+    (*bus->base.destroy)(&bus->base);
+    rtems_set_errno_and_return_minus_one(-err);
+   bus->irq = irq;
+  REG(&bus->regs->BBB_I2C_IRQSTATUS) = I2C_ALL_IRQ_FLAGS;
+  sc  = rtems_interrupt_handler_install(
+    irq,
+    "BBB_I2C",
+    RTEMS_INTERRUPT_UNIQUE,
+    (rtems_interrupt_handler)am335x_i2c_interrupt,
+    bus
+    rtems_set_errno_and_return_minus_one(EIO);
+  bus->base.transfer = am335x_i2c_transfer;
+  bus->base.set_clock = am335x_i2c_set_clock;
+  bus->base.destroy = am335x_i2c_destroy;
+  return i2c_bus_register(&bus->base,bus_path);
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
index 8cce556..ceb12a4 100644
--- a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
+++ b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
@@ -35,9 +35,11 @@ extern "C" {
 #define BBB_PU_EN (1 << 4)
 #define BBB_PD_EN ~BBB_PU_EN
 #define BBB_MUXMODE(X) (X & 0x7)
+#define BBB_RXACTIVE (1 << 5)
+#define BBB_SLEWCTRL (1 << 6)
 #ifdef __cplusplus
 #endif /* __cplusplus */
-#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
+#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
index e7d1716..b7c71d9 100644
--- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
+++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
@@ -1,5 +1,4 @@
- * @file
@@ -24,7 +23,7 @@
 #define LIBBSP_ARM_BEAGLE_I2C_H
+#include <dev/i2c/i2c.h>
 #include <bsp.h>
 #ifdef __cplusplus
@@ -43,6 +42,7 @@ extern "C" {
 #define I2C_CON_XA  (1 << 8)   /* Expand address */
 #define I2C_CON_STP (1 << 1)   /* Stop condition (master mode only) */
 #define I2C_CON_STT (1 << 0)   /* Start condition (master mode only) */
+#define I2C_CON_CLR 0x0  /* Clear configuration register */
 /* I2C Status Register (I2C_STAT): */
@@ -57,7 +57,6 @@ extern "C" {
 #define I2C_STAT_ARDY (1 << 2)  /* Register access ready */
 #define I2C_STAT_NACK (1 << 1)  /* No acknowledgment interrupt enable */
 #define I2C_STAT_AL (1 << 0)  /* Arbitration lost interrupt enable */
 /* I2C Interrupt Enable Register (I2C_IE): */
 #define I2C_IE_GC_IE  (1 << 5)
 #define I2C_IE_XRDY_IE  (1 << 4) /* Transmit data ready interrupt enable */
@@ -65,6 +64,10 @@ extern "C" {
 #define I2C_IE_ARDY_IE  (1 << 2) /* Register access ready interrupt enable */
 #define I2C_IE_NACK_IE  (1 << 1) /* No acknowledgment interrupt enable */
 #define I2C_IE_AL_IE  (1 << 0) /* Arbitration lost interrupt enable */
+/* I2C SYSC Register (I2C_SYSC): */
+#define I2C_SYSC_SRST (1 << 1)
  * The equation for the low and high time is
  * tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed
@@ -132,7 +135,7 @@ extern "C" {
 #define DISP_LINE_LEN 128
-#define I2C_TIMEOUT 1000
+#define I2C_TIMEOUT 500
 #define I2C_BUS_MAX 3
@@ -144,6 +147,8 @@ extern "C" {
 #define CONFIG_SYS_I2C_SPEED    100000
 #define CONFIG_SYS_I2C_SLAVE    1
+#define I2C_ALL_FLAGS 0x7FFF
+#define I2C_ALL_IRQ_FLAGS 0xFFFF
 struct i2c {
   unsigned short rev;   /* 0x00 */
@@ -180,20 +185,8 @@ struct i2c {
   unsigned short res15;
-static unsigned short wait_for_pin( void );
-static void wait_for_bb( void );
-static void flush_fifo( void );
 void i2c_init( int speed, int slaveadd );
-static int i2c_read_byte(
-  unsigned char devaddr,
-  unsigned char regoffset,
-  unsigned char *value
 int i2c_write(
   unsigned char chip,
   unsigned int addr,
@@ -210,10 +203,6 @@ int i2c_read(
   int len
-static int imw ( unsigned char  chip, unsigned long addr, unsigned char byte );
-static int imd( unsigned char chip, unsigned int addr, unsigned int length );
  * @brief Initializes the I2C module @a i2c.
@@ -361,6 +350,139 @@ static inline rtems_status_code beagle_i2c_read(
   return beagle_i2c_write_and_read(i2c, addr, NULL, 0, in, in_size);
+#define BBB_I2C_SYSCLK 48000000
+#define BBB_I2C_INTERNAL_CLK 12000000
+#define BBB_I2C_SPEED_CLK 100000
+#define BBB_I2C_IRQ_ERROR \
+  (AM335X_I2C_IRQSTATUS_NACK \
+    | AM335X_I2C_IRQSTATUS_ROVR \
+    | AM335X_I2C_IRQSTATUS_AL \
+    | AM335X_I2C_IRQSTATUS_ARDY \
+    | AM335X_I2C_IRQSTATUS_RRDY \
+    | AM335X_I2C_IRQSTATUS_XRDY \
+    | AM335X_I2C_IRQSTATUS_XUDF )
+  #define BBB_I2C_IRQ_USED \
+  ( AM335X_I2C_IRQSTATUS_ARDY \
+#define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
+#define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
+#define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
+#define BBB_I2C0_IRQ 70
+#define BBB_I2C1_IRQ 71
+#define BBB_I2C2_IRQ 30
+#define MODE2 2
+#define MODE3 3
+typedef enum {
+  I2C0,
+  I2C1,
+  I2C2,
+  I2C_COUNT
+}bbb_i2c_id_t;
+typedef struct i2c_regs
+  uint32_t BBB_I2C_REVNB_LO;
+  uint32_t BBB_I2C_REVNB_HI;
+  uint32_t dummy1[2];
+  uint32_t BBB_I2C_SYSC;
+  uint32_t dummy2[4];
+  uint32_t BBB_I2C_IRQSTATUS_RAW;
+  uint32_t BBB_I2C_IRQSTATUS;
+  uint32_t BBB_I2C_IRQENABLE_SET;
+  uint32_t BBB_I2C_IRQENABLE_CLR;
+  uint32_t BBB_I2C_WE;
+  uint32_t BBB_I2C_DMARXENABLE_SET;
+  uint32_t BBB_I2C_DMATXENABLE_SET;
+  uint32_t BBB_I2C_DMARXENABLE_CLR;
+  uint32_t BBB_I2C_DMATXENABLE_CLR;
+  uint32_t BBB_I2C_DMARXWAKE_EN;
+  uint32_t BBB_I2C_DMATXWAKE_EN;
+  uint32_t dummy3[16];
+  uint32_t BBB_I2C_SYSS;
+  uint32_t BBB_I2C_BUF;
+  uint32_t BBB_I2C_CNT;
+  uint32_t BBB_I2C_DATA;
+  uint32_t dummy4;
+  uint32_t BBB_I2C_CON;
+  uint32_t BBB_I2C_OA;
+  uint32_t BBB_I2C_SA;
+  uint32_t BBB_I2C_PSC;
+  uint32_t BBB_I2C_SCLL;
+  uint32_t BBB_I2C_SCLH;
+  uint32_t BBB_I2C_SYSTEST;
+  uint32_t BBB_I2C_BUFSTAT;
+  uint32_t BBB_I2C_OA1;
+  uint32_t BBB_I2C_OA2;
+  uint32_t BBB_I2C_OA3;
+  uint32_t BBB_I2C_ACTOA;
+  uint32_t BBB_I2C_SBLOCK;
+}bbb_i2c_regs;
+typedef struct bbb_i2c_bus{
+  i2c_bus base;
+  i2c_msg *msgs;
+  uint32_t msg_todo;
+  uint32_t current_msg_todo;
+  uint8_t *current_msg_byte;
+  uint32_t current_todo;
+  bool read;
+  bool hold;
+  rtems_id task_id;
+  rtems_vector_number irq;
+  uint32_t input_clock;
+  uint32_t already_transferred;
+} bbb_i2c_bus;
+static inline int bbb_register_i2c_0(void)
+  return am335x_i2c_bus_register(
+    BBB_I2C_0_BUS_PATH,
+    AM335X_I2C0_BASE,
+    I2C_BUS_CLOCK_DEFAULT,
+    BBB_I2C0_IRQ
+static inline int bbb_register_i2c_1(void)
+    BBB_I2C_1_BUS_PATH,
+    AM335X_I2C1_BASE,
+    BBB_I2C1_IRQ
+static inline int bbb_register_i2c_2(void)
+    BBB_I2C_2_BUS_PATH,
+    AM335X_I2C2_BASE,
+    BBB_I2C2_IRQ
 #ifdef __cplusplus
diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
index f59f896..234ed39 100644
--- a/c/src/lib/libcpu/arm/shared/include/am335x.h
+++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
@@ -563,3 +563,199 @@
+/* I2C registers */
+#define AM335X_I2C0_BASE 0x44e0b000
+    /* I2C0 base address */
+#define AM335X_I2C1_BASE 0x4802a000
+    /* I2C1 base address */
+#define AM335X_I2C2_BASE 0x4819c000
+    /* I2C2 base address */
+#define AM335X_I2C_REVNB_LO        0x00
+    /* Module Revision Register (low bytes) */
+#define AM335X_I2C_REVNB_HI        0x04
+    /* Module Revision Register (high bytes) */
+#define AM335X_I2C_SYSC            0x10
+    /* System Configuration Register */
+#define AM335X_I2C_IRQSTATUS_RAW   0x24
+    /* I2C Status Raw Register */
+#define AM335X_I2C_IRQSTATUS       0x28
+    /* I2C Status Register */
+#define AM335X_I2C_IRQENABLE_SET   0x2c
+    /* I2C Interrupt Enable Set Register */
+#define AM335X_I2C_IRQENABLE_CLR   0x30
+    /* I2C Interrupt Enable Clear Register */
+#define AM335X_I2C_WE              0x34
+    /* I2C Wakeup Enable Register */
+#define AM335X_I2C_DMARXENABLE_SET 0x38
+    /* Receive DMA Enable Set Register */
+#define AM335X_I2C_DMATXENABLE_SET 0x3c
+    /* Transmit DMA Enable Set Register */
+#define AM335X_I2C_DMARXENABLE_CLR 0x40
+    /* Receive DMA Enable Clear Register */
+#define AM335X_I2C_DMATXENABLE_CLR 0x44
+    /* Transmit DMA Enable Clear Register */
+#define AM335X_I2C_DMARXWAKE_EN    0x48
+    /* Receive DMA Wakeup Register */
+#define AM335X_I2C_DMATXWAKE_EN    0x4c
+    /* Transmit DMA Wakeup Register */
+#define AM335X_I2C_SYSS            0x90
+    /* System Status Register */
+#define AM335X_I2C_BUF             0x94
+    /* Buffer Configuration Register */
+#define AM335X_I2C_CNT             0x98
+    /* Data Counter Register */
+#define AM335X_I2C_DATA            0x9c
+    /* Data Access Register */
+#define AM335X_I2C_CON             0xa4
+    /* I2C Configuration Register */
+#define AM335X_I2C_OA              0xa8
+    /* I2C Own Address Register */
+#define AM335X_I2C_SA              0xac
+    /* I2C Slave Address Register */
+#define AM335X_I2C_PSC             0xb0
+    /* I2C Clock Prescaler Register */
+#define AM335X_I2C_SCLL            0xb4
+    /* I2C SCL Low Time Register */
+#define AM335X_I2C_SCLH            0xb8
+    /* I2C SCL High Time Register */
+#define AM335X_I2C_SYSTEST         0xbc
+    /* System Test Register */
+#define AM335X_I2C_BUFSTAT         0xc0
+    /* I2C Buffer Status Register */
+#define AM335X_I2C_OA1             0xc4
+    /* I2C Own Address 1 Register */
+#define AM335X_I2C_OA2             0xc8
+    /* I2C Own Address 2 Register */
+#define AM335X_I2C_OA3             0xcc
+    /* I2C Own Address 3 Register */
+#define AM335X_I2C_ACTOA           0xd0
+    /* Active Own Address Register */
+#define AM335X_I2C_SBLOCK          0xd4
+    /* I2C Clock Blocking Enable Register */
+#define AM335X_CM_PER_L4LS_CLKSTCTRL  (0x0)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP  (0x2u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL  (0x00000003u)
+#define AM335X_CM_PER_L4LS_CLKCTRL  (0x60)
+#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
+#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE  (0x00000003u)
+#define AM335X_CM_PER_I2C1_CLKCTRL  (0x48)
+#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
+#define AM335X_ CM_PER_I2C1_CLKCTRL_MODULEMODE  (0x00000003u)
+#define AM335X_CM_PER_I2C2_CLKCTRL (0x44)
+#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
+#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE  (0x00000003u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK (0x00000100u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK (0x01000000u)
+#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE   (0x00000003u)
+#define AM335X_I2C_CON_XSA  (0x00000100u)
+#define AM335X_I2C_CFG_10BIT_SLAVE_ADDR  AM335X_I2C_CON_XSA
+#define AM335X_I2C_CON_XSA_SHIFT  (0x00000008u)
+#define AM335X_I2C_CFG_7BIT_SLAVE_ADDR  (0 << AM335X_I2C_CON_XSA_SHIFT)
+#define AM335X_I2C_CON_I2C_EN   (0x00008000u)
+#define AM335X_I2C_CON_TRX   (0x00000200u)
+#define AM335X_I2C_CON_MST   (0x00000400u)
+#define AM335X_I2C_CON_STB   (0x00000800u)
+#define AM335X_I2C_SYSC_AUTOIDLE   (0x00000001u)
+/*I2C0 module clock registers*/
+#define CM_PER_L3_CLKCTRL   (0xe0)
+#define CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define CM_PER_L3_CLKCTRL_MODULEMODE   (0x00000003u)
+#define CM_PER_L3_INSTR_CLKCTRL   (0xdc)
+#define CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define CM_PER_L3_INSTR_CLKCTRL_MODULEMODE   (0x00000003u)
+#define CM_PER_L3_CLKSTCTRL   (0xc)
+#define CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
+#define CM_PER_L3_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
+#define CM_PER_OCPWP_L3_CLKSTCTRL   (0x12c)
+#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
+#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
+#define CM_PER_L3S_CLKSTCTRL   (0x4)
+#define CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
+#define CM_PER_L3S_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
+#define CM_PER_L3_CLKCTRL_IDLEST_FUNC   (0x0u)
+#define CM_PER_L3_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
+#define CM_PER_L3_CLKCTRL_IDLEST   (0x00030000u)
+#define CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC   (0x0u)
+#define CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
+#define CM_PER_L3_INSTR_CLKCTRL_IDLEST   (0x00030000u)
+#define CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK   (0x00000010u)
+#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK   (0x00000010u)
+#define CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK   (0x00000008u)
+#define CM_WKUP_CONTROL_CLKCTRL   (0x4)
+#define CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define CM_WKUP_CONTROL_CLKCTRL_MODULEMODE   (0x00000003u)
+#define CM_WKUP_CLKSTCTRL   (0x0)
+#define CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
+#define CM_WKUP_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
+#define CM_WKUP_CM_L3_AON_CLKSTCTRL   (0x18)
+#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
+#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
+#define CM_WKUP_I2C0_CLKCTRL   (0xb8)
+#define CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define CM_WKUP_I2C0_CLKCTRL_MODULEMODE   (0x00000003u)
+#define CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC   (0x0u)
+#define CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
+#define CM_WKUP_CONTROL_CLKCTRL_IDLEST   (0x00030000u)
+#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK   (0x00000008u)
+#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC   (0x0u)
+#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
+#define CM_WKUP_L4WKUP_CLKCTRL   (0xc)
+#define CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK   (0x00000004u)
+#define CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK   (0x00000004u)
+#define CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL   (0xcc)
+#define CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK   (0x00000800u)
+#define CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC   (0x0u)
+#define CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
+#define CM_WKUP_I2C0_CLKCTRL_IDLEST   (0x00030000u)
+#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST   (0x00030000u)
+#define SOC_CM_WKUP_REGS                     (AM335X_CM_PER_ADDR + 0x400)
+/* I2C status Register */
+#define AM335X_I2C_IRQSTATUS_NACK (1 << 1)
+#define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
+#define AM335X_I2C_IRQSTATUS_AL   ( 1<<0 )
+#define AM335X_I2C_IRQSTATUS_ARDY (1 << 2)
+#define AM335X_I2C_IRQSTATUS_RRDY (1 << 3)
+#define AM335X_I2C_IRQSTATUS_XRDY (1 << 4)
+#define AM335X_I2C_IRQSTATUS_XUDF (1 << 10)
+#define AM335X_I2C_BUF_TXFIFO_CLR   (0x00000040u)
+#define AM335X_I2C_BUF_RXFIFO_CLR   (0x00004000u)
+#define AM335X_I2C_IRQSTATUS_AAS  (1 << 9)
+#define AM335X_I2C_IRQSTATUS_BF  (1 << 8)
+#define AM335X_I2C_IRQSTATUS_STC  (1 << 6)
+#define AM335X_I2C_IRQSTATUS_GC (1 << 5)
+#define AM335X_I2C_IRQSTATUS_XDR (1 << 14)
+#define AM335X_I2C_IRQSTATUS_RDR (1 << 13)
+#define AM335X_I2C_INT_RECV_READY AM335X_I2C_IRQSTATUS_RRDY
+#define AM335X_I2C_CON_STOP  (0x00000002u)
+#define AM335X_I2C_CON_START (0x00000001u)
+#define AM335X_I2C_CFG_MST_RX AM335X_I2C_CON_MST
+#define AM335X_I2C_CFG_MST_TX  AM335X_I2C_CON_TRX | AM335X_I2C_CON_MST
+#define AM335X_I2C_IRQSTATUS_RAW_BB   (0x00001000u)
+#define AM335X_I2C_IRQSTATUS_BF (0x00000100u)
+#define AM335X_CM_PER_L3S_CLKSTCTRL   (0x4)
+#define AM335X_CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
+#define AM335X_CM_PER_L3S_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
+#define AM335X_CM_PER_L3_CLKSTCTRL   (0xc)
+#define AM335X_CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
+#define AM335X_CM_PER_L3_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
+#define AM335X_CM_PER_L3_INSTR_CLKCTRL   (0xdc)
+#define AM335X_CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define AM335X_CM_PER_L3_CLKCTRL   (0xe0)
+#define AM335X_CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define AM335X_CM_PER_L3_CLKCTRL_MODULEMODE   (0x00000003u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL   (0x12c)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
+#define AM335X_CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK   (0x00000010u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK   (0x00000010u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK   (0x00000020u)
+#define AM335X_CM_PER_L3_INSTR_CLKCTRL_MODULEMODE   (0x00000003u)
+#define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
2.7.4
