[PATCH] Add the i2c driver for Beaglebone Black:
Sichen Zhao
zsc19940506 at outlook.com
Wed May 24 04:48:08 UTC 2017
I got your mean, thank you , PV.
Best Regards
Sichen Zhao
________________________________
From: devel <devel-bounces at rtems.org> on behalf of punit vara <punitvara at gmail.com>
Sent: Wednesday, May 24, 2017 2:05 AM
To: Sichen Zhao
Cc: Christian Mauderer; rtems-devel at rtems.org
Subject: Re: [PATCH] Add the i2c driver for Beaglebone Black:
On Tue, May 23, 2017 at 7:13 PM, Sichen Zhao <1473996754 at qq.com> wrote:
> Update ticket #2891 and my GSOC project
> add c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> modify c/src/lib/libbsp/arm/beagle/include/i2c.h
> modify c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
> modify c/src/lib/libcpu/arm/shared/include/am335x.h
> modify c/src/lib/libbsp/arm/beagle/Makefile.am
> Now can read the EEPROM by i2c, the test application link is: https://github.com/hahchenchen/GSOC-test-application
> c/src/lib/libbsp/arm/beagle/Makefile.am | 1 +
> c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 577 +++++++++++++++++++++++++
> c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h | 4 +-
> c/src/lib/libbsp/arm/beagle/include/i2c.h | 161 ++++++-
> c/src/lib/libcpu/arm/shared/include/am335x.h | 198 +++++++++
> 5 files changed, 921 insertions(+), 20 deletions(-)
> create mode 100644 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
> index 8bb8478..274dc0e 100644
> --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
> +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
> @@ -115,6 +115,7 @@ libbsp_a_SOURCES += ../../shared/console.c \
> # I2C
> libbsp_a_SOURCES += misc/i2c.c
> +libbsp_a_SOURCES += i2c/bbb-i2c.c
> # GPIO
> libbsp_a_SOURCES += gpio/bbb-gpio.c
> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> new file mode 100644
> index 0000000..5c8958f
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> @@ -0,0 +1,577 @@
> + * @file
> + * @ingroup arm_beagle
> + * @brief BeagleBoard I2C bus initialization and API Support.
> + * Copyright (c) 2017 Sichen Zhao <zsc19940506 at gmail.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> + * Modified on Punit Vara<punitvara at gmail.com> works, currently
> + * the i2c file is working on the Beaglebone Black board(AM335x).
> +#include <stdio.h>
> +#include <bsp/i2c.h>
> +#include <libcpu/am335x.h>
> +#include <rtems/irq-extension.h>
> +#include <rtems/counter.h>
> +#include <bsp/bbb-gpio.h>
> +#include <rtems/score/assert.h>
> +static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
> + REG(bus->regs + AM335X_CONF_I2C0_SDA) =
> + (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
> + REG(bus->regs + AM335X_CONF_I2C0_SCL) =
> +static void I2C0ModuleClkConfig(void)
> + /* Configuring L3 Interface Clocks. */
> + /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) |=
> + CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
I can see few Macros without AM335X_ . Change all those macros and
don't use same name because this function is similar to starterware. I
have used to just test my code last year. So change the macro names
completely and add AM335X as prefix.
Remove unnecessary lines in this code. Only write registers which are
required to enable clock.
> + /* Waiting for MODULEMODE field to reflect the written value. */
> + while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) &
> + CM_PER_L3_CLKCTRL_MODULEMODE));
> + /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) |=
> + CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
> + while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) &
> + CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
> + /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) |=
> + CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + /* Waiting for CLKTRCTRL field to reflect the written value. */
> + while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) &
> + CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
> + /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) |=
> + CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + /*Waiting for CLKTRCTRL field to reflect the written value. */
> + while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) &
> + CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
> + /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) |=
> + CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) &
> + CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
> + /* Checking fields for necessary values. */
> + /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */
> + while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
> + CM_PER_L3_CLKCTRL_IDLEST));
> + ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the
> + ** desired value.
> + while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
> + CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
> + CM_PER_L3_INSTR_CLKCTRL_IDLEST));
> + ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
> + ** attain the desired value.
> + while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
> + CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
> + ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
> + ** register to attain the desired value.
> + while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
> + CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
> + ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
> + ** to attain the desired value.
> + while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
> + CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
> + /* Configuring registers related to Wake-Up region. */
> + /* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
> + REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) |=
> + CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE;
> + while(CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) &
> + CM_WKUP_CONTROL_CLKCTRL_MODULEMODE));
> + REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) |=
> + CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + while(CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) &
> + CM_WKUP_CLKSTCTRL_CLKTRCTRL));
> + /* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
> + REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) |=
> + CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) &
> + CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL));
> + /* Writing to MODULEMODE field of CM_WKUP_I2C0_CLKCTRL register. */
> + REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) |=
> + CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
> + while(CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) &
> + CM_WKUP_I2C0_CLKCTRL_MODULEMODE));
> + /* Verifying if the other bits are set to required settings. */
> + ** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to attain
> + ** desired value.
> + while((CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
> + CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT) !=
> + CM_WKUP_CONTROL_CLKCTRL_IDLEST));
> + ** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
> + ** register to attain desired value.
> + while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK !=
> + CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK));
> + ** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to attain
> + ** desired value.
> + while((CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC <<
> + CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT) !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_L4WKUP_CLKCTRL) &
> + CM_WKUP_L4WKUP_CLKCTRL_IDLEST));
> + ** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL register
> + ** to attain desired value.
> + while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK !=
> + CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK));
> + ** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in CM_L4_WKUP_AON_CLKSTCTRL
> + while(CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL) &
> + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK));
> + ** Waiting for CLKACTIVITY_I2C0_GFCLK field in CM_WKUP_CLKSTCTRL
> + while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
> + CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK));
> + ** Waiting for IDLEST field in CM_WKUP_I2C0_CLKCTRL register to attain
> + ** desired value.
> + while((CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
> + CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT) !=
> + CM_WKUP_I2C0_CLKCTRL_IDLEST));
> +static void am335x_i2c_reset(bbb_i2c_bus *bus)
> + volatile bbb_i2c_regs *regs = bus->regs;
> + int timeout = I2C_TIMEOUT;
> + if (REG(®s->BBB_I2C_CON) & I2C_CON_EN) {
> + REG(®s->BBB_I2C_CON) = I2C_CON_CLR;
> + udelay(50000);
> + REG(®s->BBB_I2C_SYSC) = I2C_SYSC_SRST; /* for ES2 after soft reset */
> + udelay(1000);
> + REG(®s->BBB_I2C_CON) = I2C_CON_EN;
> + while (!(REG(®s->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
> + if (timeout <= 0) {
> + puts("ERROR: Timeout in soft-reset\n");
> + return;
> + udelay(1000);
> +Possible values for msg->flag
> + * - @ref I2C_M_TEN,
> + * - @ref I2C_M_RD,
> + * - @ref I2C_M_STOP,
> + * - @ref I2C_M_NOSTART,
> + * - @ref I2C_M_REV_DIR_ADDR,
> + * - @ref I2C_M_IGNORE_NAK,
> + * - @ref I2C_M_NO_RD_ACK, and
> + * - @ref I2C_M_RECV_LEN.
> +static void am335x_i2c_set_address_size(const i2c_msg *msgs,
> + volatile bbb_i2c_regs *regs)
> + /*can be configured multiple modes here. Need to think about own address modes*/
> + if ((msgs->flags & I2C_M_TEN) == 0) {
> + /* 7-bit mode slave address mode*/
> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_7BIT_SLAVE_ADDR;
> + } else {
> + /* 10-bit slave address mode*/
> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_10BIT_SLAVE_ADDR;
> +static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
> + i2c_msg *msg;
> + ++bus->msgs;
> + --bus->msg_todo;
> + msg = &bus->msgs[0];
> + bus->current_msg_todo = msg->len;
> + bus->current_msg_byte = msg->buf;
> +static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
> + return (REG(®s->BBB_I2C_IRQSTATUS_RAW));
> +static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs,
> + unsigned int flag)
> + REG(®s->BBB_I2C_IRQENABLE_SET) |= flag;
> +static void am335x_i2c_masterint_disable(volatile bbb_i2c_regs *regs,
> + REG(®s->BBB_I2C_IRQENABLE_CLR) = flag;
> +static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
> + REG(®s->BBB_I2C_IRQSTATUS) = flag;
> +static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
> + am335x_i2c_masterint_enable(regs,I2C_ALL_FLAGS);
> + am335x_int_clear(regs,I2C_ALL_FLAGS);
> + am335x_i2c_masterint_disable(regs,I2C_ALL_FLAGS);
> +static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus,
> + volatile bbb_i2c_regs *regs,
> + const i2c_msg *msgs, bool send_stop)
> + volatile unsigned int no_bytes;
> + int status;
> + REG(®s->BBB_I2C_CNT) = bus->current_msg_todo;
> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN;
> + if (send_stop) {
> + REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START | AM335X_I2C_CON_STOP;
> + } else {
> + REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
> + am335x_i2c_masterint_enable(regs,AM335X_I2C_INT_RECV_READY
> + | AM335X_I2C_IRQSTATUS_ARDY);
> +static void am335x_i2c_continue_read_transfer(
> + bbb_i2c_bus *bus,
> + bus->current_msg_byte[bus->already_transferred] = REG(®s->BBB_I2C_DATA);
> + bus->already_transferred++;
> + REG(®s->BBB_I2C_IRQSTATUS) = AM335X_I2C_INT_RECV_READY;
> + if (bus->already_transferred == bus->current_msg_todo-1) {
> + REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
> +static void am335x_i2c_continue_write(bbb_i2c_bus *bus,
> +if (bus->already_transferred == bus->msg_todo) {
> + REG(®s->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
> + REG(®s->BBB_I2C_IRQSTATUS) = AM335X_I2C_IRQSTATUS_XRDY;
> + am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY );
> + } else {
> + writeb(bus->current_msg_byte[bus->already_transferred],®s->BBB_I2C_DATA);
> +static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,
> + volatile bbb_i2c_regs *regs, const i2c_msg *msgs)
> + no_bytes = REG(®s->BBB_I2C_CNT);
> + REG(®s->BBB_I2C_SA) = msgs->addr;
> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
> + am335x_clean_interrupts(regs);
> + am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY );
> +static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus,
> + const i2c_msg *msgs = bus->msgs;
> + uint32_t msg_todo = bus->msg_todo;
> + bool send_stop = false;
> + uint32_t i;
> + bus->current_todo = msgs[0].len;
> + for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
> + bus->current_todo += msgs[i].len;
> + regs = bus->regs;
> + REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
> + REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
> + am335x_i2c_set_address_size(msgs,regs);
> + bus->read = (msgs->flags & I2C_M_RD) != 0;
> + bus->already_transferred = (bus->read == true) ? 0 : 1;
> + if (bus->read) {
> + if (bus->current_msg_todo == 1) {
> + send_stop = true;
> + am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
> + } else {
> + am335x_i2c_setup_write_transfer(bus,regs,msgs);
> +static void am335x_i2c_interrupt(void *arg)
> + bbb_i2c_bus *bus = arg;
> + /* get status of enabled interrupts */
> + uint32_t irqstatus = REG(®s->BBB_I2C_IRQSTATUS);
> + bool done = false;
> + /* Clear all enabled interrupt except receive ready and transmit ready interrupt in status register */
> + REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY
> + | AM335X_I2C_IRQSTATUS_XRDY));
> + if (irqstatus & AM335X_I2C_INT_RECV_READY ) {
> + am335x_i2c_continue_read_transfer(bus, regs);
> + if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
> + am335x_i2c_continue_write(bus,regs);
> + if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
> + done = true;
> + am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
> + if (irqstatus & AM335X_I2C_IRQSTATUS_ARDY) {
> + done = true;
> + REG(®s->BBB_I2C_IRQSTATUS) = I2C_STAT_ARDY;
> + if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
> + REG( ®s->BBB_I2C_IRQSTATUS) = AM335X_I2C_IRQSTATUS_BF;
> + if (done) {
> + uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
> + am335x_i2c_next_byte(bus);
> + if (bus->msg_todo == 0 ) {
> + rtems_status_code sc;
> + am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY
> + | AM335X_I2C_IRQSTATUS_BF));
> + REG(®s->BBB_I2C_IRQSTATUS) = err;
> + sc = rtems_event_transient_send(bus->task_id);
> + _Assert(sc == RTEMS_SUCCESSFUL);
> + (void) sc;
> + } else {
> + am335x_i2c_setup_transfer(bus, regs);
> +static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
> + bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
> + volatile bbb_i2c_regs *regs;
> + uint32_t i;
> + rtems_task_wake_after(1);
> + if (msg_count < 1){
> + return 1;
> + for (i=0; i<msg_count;++i) {
> + if ((msgs[i].flags & I2C_M_RECV_LEN) != 0) {
> + return -EINVAL;
> + bus->msgs = &msgs[0];
> + bus->msg_todo = msg_count;
> + bus->current_msg_todo = msgs[0].len;
> + bus->current_msg_byte = msgs[0].buf;
> + bus->task_id = rtems_task_self();
> + regs = bus->regs;
> + am335x_i2c_setup_transfer(bus,regs);
> + REG(®s->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
> + sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
> + if (sc != RTEMS_SUCCESSFUL) {
> + am335x_i2c_reset(bus);
> + rtems_event_transient_clear();
> + return -ETIMEDOUT;
> + return 0;
> +static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
> + bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> + uint32_t prescaler,divider;
> + prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
> + REG(&bus->regs->BBB_I2C_PSC) = prescaler;
> + divider = BBB_I2C_INTERNAL_CLK/(2*clock);
> + REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
> + REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
> + return 0;
> +static void am335x_i2c_destroy(i2c_bus *base)
> + sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt, bus);
> + (void)sc;
> + i2c_bus_destroy_and_free(&bus->base);
> +int am335x_i2c_bus_register(
> + const char *bus_path,
> + uintptr_t register_base,
> + uint32_t input_clock,
> + rtems_vector_number irq
> + bbb_i2c_bus *bus;
> + int err;
> + /*check bus number is >0 & <MAX*/
> + bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init(sizeof(*bus));
> + if (bus == NULL) {
> + return -1;
> + bus->regs = (volatile bbb_i2c_regs *) register_base;
> + I2C0ModuleClkConfig();
> + am335x_i2c0_pinmux(bus);
> + bus->input_clock = input_clock;
> + err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> + if (err != 0) {
> + (*bus->base.destroy)(&bus->base);
> + rtems_set_errno_and_return_minus_one(-err);
> + bus->irq = irq;
> + REG(&bus->regs->BBB_I2C_IRQSTATUS) = I2C_ALL_IRQ_FLAGS;
> + sc = rtems_interrupt_handler_install(
> + irq,
> + "BBB_I2C",
> + RTEMS_INTERRUPT_UNIQUE,
> + (rtems_interrupt_handler)am335x_i2c_interrupt,
> + bus
> + rtems_set_errno_and_return_minus_one(EIO);
> + bus->base.transfer = am335x_i2c_transfer;
> + bus->base.set_clock = am335x_i2c_set_clock;
> + bus->base.destroy = am335x_i2c_destroy;
> + return i2c_bus_register(&bus->base,bus_path);
> \ No newline at end of file
> diff --git a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
> index 8cce556..ceb12a4 100644
> --- a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
> +++ b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
> @@ -35,9 +35,11 @@ extern "C" {
> #define BBB_PU_EN (1 << 4)
> #define BBB_PD_EN ~BBB_PU_EN
> #define BBB_MUXMODE(X) (X & 0x7)
> +#define BBB_RXACTIVE (1 << 5)
> +#define BBB_SLEWCTRL (1 << 6)
> #ifdef __cplusplus
> #endif /* __cplusplus */
> -#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
> +#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
> diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> index e7d1716..d111070 100644
> --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> @@ -1,5 +1,5 @@
> - * @file
> @@ -24,7 +24,7 @@
> #define LIBBSP_ARM_BEAGLE_I2C_H
> #include <rtems.h>
> +#include <dev/i2c/i2c.h>
> #include <bsp.h>
> #ifdef __cplusplus
> @@ -43,6 +43,7 @@ extern "C" {
> #define I2C_CON_XA (1 << 8) /* Expand address */
> #define I2C_CON_STP (1 << 1) /* Stop condition (master mode only) */
> #define I2C_CON_STT (1 << 0) /* Start condition (master mode only) */
> +#define I2C_CON_CLR 0x0 /* Clear configuration register */
> /* I2C Status Register (I2C_STAT): */
> @@ -57,7 +58,6 @@ extern "C" {
> #define I2C_STAT_ARDY (1 << 2) /* Register access ready */
> #define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */
> #define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */
> /* I2C Interrupt Enable Register (I2C_IE): */
> #define I2C_IE_GC_IE (1 << 5)
> #define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */
> @@ -65,6 +65,10 @@ extern "C" {
> #define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */
> #define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */
> #define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */
> +/* I2C SYSC Register (I2C_SYSC): */
> +#define I2C_SYSC_SRST (1 << 1)
> * The equation for the low and high time is
> * tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed
> @@ -144,6 +148,8 @@ extern "C" {
> #define CONFIG_SYS_I2C_SPEED 100000
> #define CONFIG_SYS_I2C_SLAVE 1
> +#define I2C_ALL_FLAGS 0x7FFF
> +#define I2C_ALL_IRQ_FLAGS 0xFFFF
> struct i2c {
> unsigned short rev; /* 0x00 */
> @@ -180,20 +186,8 @@ struct i2c {
> unsigned short res15;
> -static unsigned short wait_for_pin( void );
> -static void wait_for_bb( void );
> -static void flush_fifo( void );
> void i2c_init( int speed, int slaveadd );
> -static int i2c_read_byte(
> - unsigned char devaddr,
> - unsigned char regoffset,
> - unsigned char *value
> int i2c_write(
> unsigned char chip,
> unsigned int addr,
> @@ -210,10 +204,6 @@ int i2c_read(
> int len
> -static int imw ( unsigned char chip, unsigned long addr, unsigned char byte );
> -static int imd( unsigned char chip, unsigned int addr, unsigned int length );
> * @brief Initializes the I2C module @a i2c.
> @@ -361,6 +351,139 @@ static inline rtems_status_code beagle_i2c_read(
> return beagle_i2c_write_and_read(i2c, addr, NULL, 0, in, in_size);
> +#define BBB_I2C_SYSCLK 48000000
> +#define BBB_I2C_INTERNAL_CLK 12000000
> +#define BBB_I2C_SPEED_CLK 100000
> +#define BBB_I2C_IRQ_ERROR \
> + (AM335X_I2C_IRQSTATUS_NACK \
> + | AM335X_I2C_IRQSTATUS_ROVR \
> + | AM335X_I2C_IRQSTATUS_AL \
> + | AM335X_I2C_IRQSTATUS_ARDY \
> + | AM335X_I2C_IRQSTATUS_RRDY \
> + | AM335X_I2C_IRQSTATUS_XRDY \
> + | AM335X_I2C_IRQSTATUS_XUDF )
> + #define BBB_I2C_IRQ_USED \
> + ( AM335X_I2C_IRQSTATUS_ARDY \
> +#define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
> +#define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
> +#define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
> +#define BBB_I2C0_IRQ 70
> +#define BBB_I2C1_IRQ 71
> +#define BBB_I2C2_IRQ 30
> +#define MODE2 2
> +#define MODE3 3
> +typedef enum {
> + I2C0,
> + I2C1,
> + I2C2,
> + I2C_COUNT
> +}bbb_i2c_id_t;
> +typedef struct i2c_regs
> + uint32_t BBB_I2C_REVNB_LO;
> + uint32_t BBB_I2C_REVNB_HI;
> + uint32_t dummy1[2];
> + uint32_t BBB_I2C_SYSC;
> + uint32_t dummy2[4];
> + uint32_t BBB_I2C_IRQSTATUS_RAW;
> + uint32_t BBB_I2C_IRQSTATUS;
> + uint32_t BBB_I2C_IRQENABLE_SET;
> + uint32_t BBB_I2C_IRQENABLE_CLR;
> + uint32_t BBB_I2C_WE;
> + uint32_t BBB_I2C_DMARXENABLE_SET;
> + uint32_t BBB_I2C_DMATXENABLE_SET;
> + uint32_t BBB_I2C_DMARXENABLE_CLR;
> + uint32_t BBB_I2C_DMATXENABLE_CLR;
> + uint32_t BBB_I2C_DMARXWAKE_EN;
> + uint32_t BBB_I2C_DMATXWAKE_EN;
> + uint32_t dummy3[16];
> + uint32_t BBB_I2C_SYSS;
> + uint32_t BBB_I2C_BUF;
> + uint32_t BBB_I2C_CNT;
> + uint32_t BBB_I2C_DATA;
> + uint32_t dummy4;
> + uint32_t BBB_I2C_CON;
> + uint32_t BBB_I2C_OA;
> + uint32_t BBB_I2C_SA;
> + uint32_t BBB_I2C_PSC;
> + uint32_t BBB_I2C_SCLL;
> + uint32_t BBB_I2C_SCLH;
> + uint32_t BBB_I2C_SYSTEST;
> + uint32_t BBB_I2C_BUFSTAT;
> + uint32_t BBB_I2C_OA1;
> + uint32_t BBB_I2C_OA2;
> + uint32_t BBB_I2C_OA3;
> + uint32_t BBB_I2C_ACTOA;
> + uint32_t BBB_I2C_SBLOCK;
> +}bbb_i2c_regs;
> +typedef struct bbb_i2c_bus{
> + i2c_bus base;
> + i2c_msg *msgs;
> + uint32_t msg_todo;
> + uint32_t current_msg_todo;
> + uint8_t *current_msg_byte;
> + uint32_t current_todo;
> + bool read;
> + bool hold;
> + rtems_id task_id;
> + rtems_vector_number irq;
> + uint32_t input_clock;
> + uint32_t already_transferred;
> +} bbb_i2c_bus;
> +static inline int bbb_register_i2c_0(void)
> + return am335x_i2c_bus_register(
> + BBB_I2C_0_BUS_PATH,
> + AM335X_I2C0_BASE,
> + I2C_BUS_CLOCK_DEFAULT,
> + BBB_I2C0_IRQ
> +static inline int bbb_register_i2c_1(void)
> + BBB_I2C_1_BUS_PATH,
> + AM335X_I2C1_BASE,
> + BBB_I2C1_IRQ
> +static inline int bbb_register_i2c_2(void)
> + BBB_I2C_2_BUS_PATH,
> + AM335X_I2C2_BASE,
> + BBB_I2C2_IRQ
> #ifdef __cplusplus
> diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
> index f59f896..00b6ddb 100644
> --- a/c/src/lib/libcpu/arm/shared/include/am335x.h
> +++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
> @@ -563,3 +563,201 @@
> +/* I2C registers */
> +#define AM335X_I2C0_BASE 0x44e0b000
> + /* I2C0 base address */
> +#define AM335X_I2C1_BASE 0x4802a000
> + /* I2C1 base address */
> +#define AM335X_I2C2_BASE 0x4819c000
> + /* I2C2 base address */
> +#define AM335X_I2C_REVNB_LO 0x00
> + /* Module Revision Register (low bytes) */
> +#define AM335X_I2C_REVNB_HI 0x04
> + /* Module Revision Register (high bytes) */
> +#define AM335X_I2C_SYSC 0x10
> + /* System Configuration Register */
> +#define AM335X_I2C_IRQSTATUS_RAW 0x24
> + /* I2C Status Raw Register */
> +#define AM335X_I2C_IRQSTATUS 0x28
> + /* I2C Status Register */
> +#define AM335X_I2C_IRQENABLE_SET 0x2c
> + /* I2C Interrupt Enable Set Register */
> +#define AM335X_I2C_IRQENABLE_CLR 0x30
> + /* I2C Interrupt Enable Clear Register */
> +#define AM335X_I2C_WE 0x34
> + /* I2C Wakeup Enable Register */
> +#define AM335X_I2C_DMARXENABLE_SET 0x38
> + /* Receive DMA Enable Set Register */
> +#define AM335X_I2C_DMATXENABLE_SET 0x3c
> + /* Transmit DMA Enable Set Register */
> +#define AM335X_I2C_DMARXENABLE_CLR 0x40
> + /* Receive DMA Enable Clear Register */
> +#define AM335X_I2C_DMATXENABLE_CLR 0x44
> + /* Transmit DMA Enable Clear Register */
> +#define AM335X_I2C_DMARXWAKE_EN 0x48
> + /* Receive DMA Wakeup Register */
> +#define AM335X_I2C_DMATXWAKE_EN 0x4c
> + /* Transmit DMA Wakeup Register */
> +#define AM335X_I2C_SYSS 0x90
> + /* System Status Register */
> +#define AM335X_I2C_BUF 0x94
> + /* Buffer Configuration Register */
> +#define AM335X_I2C_CNT 0x98
> + /* Data Counter Register */
> +#define AM335X_I2C_DATA 0x9c
> + /* Data Access Register */
> +#define AM335X_I2C_CON 0xa4
> + /* I2C Configuration Register */
> +#define AM335X_I2C_OA 0xa8
> + /* I2C Own Address Register */
> +#define AM335X_I2C_SA 0xac
> + /* I2C Slave Address Register */
> +#define AM335X_I2C_PSC 0xb0
> + /* I2C Clock Prescaler Register */
> +#define AM335X_I2C_SCLL 0xb4
> + /* I2C SCL Low Time Register */
> +#define AM335X_I2C_SCLH 0xb8
> + /* I2C SCL High Time Register */
> +#define AM335X_I2C_SYSTEST 0xbc
> + /* System Test Register */
> +#define AM335X_I2C_BUFSTAT 0xc0
> + /* I2C Buffer Status Register */
> +#define AM335X_I2C_OA1 0xc4
> + /* I2C Own Address 1 Register */
> +#define AM335X_I2C_OA2 0xc8
> + /* I2C Own Address 2 Register */
> +#define AM335X_I2C_OA3 0xcc
> + /* I2C Own Address 3 Register */
> +#define AM335X_I2C_ACTOA 0xd0
> + /* Active Own Address Register */
> +#define AM335X_I2C_SBLOCK 0xd4
> + /* I2C Clock Blocking Enable Register */
> +#define AM335X_CM_PER_L4LS_CLKSTCTRL (0x0)
> +#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define AM335X_CM_PER_L4LS_CLKCTRL (0x60)
> +#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE (0x00000003u)
> +#define AM335X_CM_PER_I2C1_CLKCTRL (0x48)
> +#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define AM335X_ CM_PER_I2C1_CLKCTRL_MODULEMODE (0x00000003u)
> +#define AM335X_CM_PER_I2C2_CLKCTRL (0x44)
> +#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE (0x00000003u)
> +#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK (0x00000100u)
> +#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK (0x01000000u)
> +#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE (0x00000003u)
> +#define AM335X_I2C_CON_XSA (0x00000100u)
> +#define AM335X_I2C_CFG_10BIT_SLAVE_ADDR AM335X_I2C_CON_XSA
> +#define AM335X_I2C_CON_XSA_SHIFT (0x00000008u)
> +#define AM335X_I2C_CFG_7BIT_SLAVE_ADDR (0 << AM335X_I2C_CON_XSA_SHIFT)
> +#define AM335X_I2C_CON_I2C_EN (0x00008000u)
> +#define AM335X_I2C_CON_TRX (0x00000200u)
> +#define AM335X_I2C_CON_MST (0x00000400u)
> +#define AM335X_I2C_CON_STB (0x00000800u)
> +#define AM335X_I2C_SYSC_AUTOIDLE (0x00000001u)
> +/*I2C0 module clock registers*/
> +#define CM_PER_L3_CLKCTRL (0xe0)
> +#define CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define CM_PER_L3_CLKCTRL_MODULEMODE (0x00000003u)
> +#define CM_PER_L3_INSTR_CLKCTRL (0xdc)
> +#define CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define CM_PER_L3_INSTR_CLKCTRL_MODULEMODE (0x00000003u)
> +#define CM_PER_L3_CLKSTCTRL (0xc)
> +#define CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define CM_PER_L3_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define CM_PER_OCPWP_L3_CLKSTCTRL (0x12c)
> +#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define CM_PER_L3S_CLKSTCTRL (0x4)
> +#define CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define CM_PER_L3S_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define CM_PER_L3_CLKCTRL_IDLEST_FUNC (0x0u)
> +#define CM_PER_L3_CLKCTRL_IDLEST_SHIFT (0x00000010u)
> +#define CM_PER_L3_CLKCTRL_IDLEST (0x00030000u)
> +#define CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC (0x0u)
> +#define CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT (0x00000010u)
> +#define CM_PER_L3_INSTR_CLKCTRL_IDLEST (0x00030000u)
> +#define CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK (0x00000010u)
> +#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK (0x00000010u)
> +#define CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK (0x00000008u)
> +#define CM_WKUP_CONTROL_CLKCTRL (0x4)
> +#define CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define CM_WKUP_CONTROL_CLKCTRL_MODULEMODE (0x00000003u)
> +#define CM_WKUP_CLKSTCTRL (0x0)
> +#define CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define CM_WKUP_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define CM_WKUP_CM_L3_AON_CLKSTCTRL (0x18)
> +#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define CM_WKUP_I2C0_CLKCTRL (0xb8)
> +#define CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define CM_WKUP_I2C0_CLKCTRL_MODULEMODE (0x00000003u)
> +#define CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC (0x0u)
> +#define CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT (0x00000010u)
> +#define CM_WKUP_CONTROL_CLKCTRL_IDLEST (0x00030000u)
> +#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK (0x00000008u)
> +#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC (0x0u)
> +#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT (0x00000010u)
> +#define CM_WKUP_L4WKUP_CLKCTRL (0xc)
> +#define CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK (0x00000004u)
> +#define CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK (0x00000004u)
> +#define CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL (0xcc)
> +#define CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK (0x00000800u)
> +#define CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC (0x0u)
> +#define CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT (0x00000010u)
> +#define CM_WKUP_I2C0_CLKCTRL_IDLEST (0x00030000u)
> +#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST (0x00030000u)
> +#define SOC_CM_WKUP_REGS (AM335X_CM_PER_ADDR + 0x400)
> +/* I2C status Register */
> +#define AM335X_I2C_IRQSTATUS_NACK (1 << 1)
> +#define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
> +#define AM335X_I2C_IRQSTATUS_AL ( 1<<0 )
> +#define AM335X_I2C_IRQSTATUS_ARDY (1 << 2)
> +#define AM335X_I2C_IRQSTATUS_RRDY (1 << 3)
> +#define AM335X_I2C_IRQSTATUS_XRDY (1 << 4)
> +#define AM335X_I2C_IRQSTATUS_XUDF (1 << 10)
> +#define AM335X_I2C_BUF_TXFIFO_CLR (0x00000040u)
> +#define AM335X_I2C_BUF_RXFIFO_CLR (0x00004000u)
> +#define AM335X_I2C_IRQSTATUS_AAS (1 << 9)
> +#define AM335X_I2C_IRQSTATUS_BF (1 << 8)
> +#define AM335X_I2C_IRQSTATUS_STC (1 << 6)
> +#define AM335X_I2C_IRQSTATUS_GC (1 << 5)
> +#define AM335X_I2C_IRQSTATUS_XDR (1 << 14)
> +#define AM335X_I2C_IRQSTATUS_RDR (1 << 13)
> +#define AM335X_I2C_INT_RECV_READY AM335X_I2C_IRQSTATUS_RRDY
> +#define AM335X_I2C_CON_STOP (0x00000002u)
> +#define AM335X_I2C_CON_START (0x00000001u)
> +#define AM335X_I2C_CFG_MST_RX AM335X_I2C_CON_MST
> +#define AM335X_I2C_CFG_MST_TX AM335X_I2C_CON_TRX | AM335X_I2C_CON_MST
> +#define AM335X_I2C_IRQSTATUS_RAW_BB (0x00001000u)
> +#define AM335X_I2C_IRQSTATUS_BF (0x00000100u)
> +#define AM335X_CM_PER_L3S_CLKSTCTRL (0x4)
> +#define AM335X_CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define AM335X_CM_PER_L3S_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define AM335X_CM_PER_L3_CLKSTCTRL (0xc)
> +#define AM335X_CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define AM335X_CM_PER_L3_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define AM335X_CM_PER_L3_INSTR_CLKCTRL (0xdc)
> +#define AM335X_CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define AM335X_CM_PER_L3_CLKCTRL (0xe0)
> +#define AM335X_CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE (0x2u)
> +#define AM335X_CM_PER_L3_CLKCTRL_MODULEMODE (0x00000003u)
> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL (0x12c)
> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL (0x00000003u)
> +#define AM335X_CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK (0x00000010u)
> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK (0x00000010u)
> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK (0x00000020u)
> +#define AM335X_CM_PER_L3_INSTR_CLKCTRL_MODULEMODE (0x00000003u)
> +#define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
> 2.7.4
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170524/59e304f2/attachment-0001.html>
