[PATCH] Add the i2c driver for Beaglebone Black:
Christian Mauderer christian.mauderer at embedded-brains.de
Wed May 24 07:18:09 UTC 2017
Hi Sichen,
Am 24.05.2017 um 05:50 schrieb Sichen Zhao:
> Hi Christian,
> I got you, and there are some advice i don't understand:
>> +static void am335x_i2c_continue_write(bbb_i2c_bus *bus,
>> +       volatile bbb_i2c_regs *regs)
> Why the two empty lines? And again: Indentation.
> You mean the Indentation is parameter volatile bbb_i2c_regs
> *regs Indentation?
Sorry that comment hasn't been placed at a good location. The
indentation is for the lines below the comment:
+if (bus->already_transferred == bus->msg_todo) {
+  REG(&regs->BBB_I2C_DATA) =
bus->current_msg_byte[bus->already_transferred];
+  REG(&regs->BBB_I2C_IRQSTATUS) = AM335X_I2C_IRQSTATUS_XRDY;
+  am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY );
+  REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
+   } else {
writeb(bus->current_msg_byte[bus->already_transferred],&regs->BBB_I2C_DATA);
+     bus->already_transferred++;
> becausethe function is more than 80 character.
I didn't check for lines longer than 80 characters. But if there are
still some, that would be a point too ;-)
Kind regards
Christian
> *From:* devel <devel-bounces at rtems.org> on behalf of Christian Mauderer
> <christian.mauderer at embedded-brains.de>
> *Sent:* Wednesday, May 24, 2017 1:36 AM
> *To:* Sichen Zhao
> *Cc:* punit vara; devel at rtems.org
> *Subject:* Re: [PATCH] Add the i2c driver for Beaglebone Black:
> Hello Sichen Zhao,
> the patch works fine. I tested it with a (just slightly) different app.
> I added some lines of comments into the code. Please take a look at them.
> Please excuse me for being a little picky but there are still some style
> points. If you write code, you should keep in mind that most source code
> is read multiple times by different people but only written once. So it
> is really a good idea to put some more time into the writing to make it
> easy to read. A steady and readable style is one very important point in
> that context.
> By the way: If you send multiple versions of a patch, it's a good idea
> to add a version to the the subject like "[PATCH v2] ...". That
> simplifies it for all mailing list readers to find the newest version of
> the patch. If you use `git send-email` to send your patches, you can do
> that by adding a `-v2`.
> If you have some explanation to your patches (like you did in another
> mail), you can also use the `--compose` option or (like I just found out
> at [1]) the `--cover-letter` option of git send-email.
> [1]
> https://www.freedesktop.org/wiki/Software/PulseAudio/HowToUseGitSendEmail/
> Kind regards
> Christian
> ----- Ursprüngliche Mail -----
>> Von: "Sichen Zhao" <1473996754 at qq.com>
>> An: devel at rtems.org
>> CC: "punit vara" <punitvara at gmail.com>, "Christian Mauderer" <christian.mauderer at embedded-brains.de>
>> Gesendet: Dienstag, 23. Mai 2017 16:56:06
>> Betreff: [PATCH] Add the i2c driver for Beaglebone Black:
>> Update ticket #2891 and my GSOC project
>> add c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> modify c/src/lib/libbsp/arm/beagle/include/i2c.h
>> modify c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
>> modify c/src/lib/libcpu/arm/shared/include/am335x.h
>> modify c/src/lib/libbsp/arm/beagle/Makefile.am
>> Now can read the EEPROM by i2c, the test application link is:
>> https://github.com/hahchenchen/GSOC-test-application
>> c/src/lib/libbsp/arm/beagle/Makefile.am        |   1 +
>> c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c      | 578 +++++++++++++++++++++++++
>> c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h |   4 +-
>> c/src/lib/libbsp/arm/beagle/include/i2c.h      | 162 ++++++-
>> c/src/lib/libcpu/arm/shared/include/am335x.h   | 196 +++++++++
>> 5 files changed, 920 insertions(+), 21 deletions(-)
>> create mode 100644 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
>> b/c/src/lib/libbsp/arm/beagle/Makefile.am
>> index 8bb8478..274dc0e 100644
>> --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
>> +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
>> @@ -115,6 +115,7 @@ libbsp_a_SOURCES += ../../shared/console.c \
>> # I2C
>> libbsp_a_SOURCES += misc/i2c.c
>> +libbsp_a_SOURCES += i2c/bbb-i2c.c
>> # GPIO
>> libbsp_a_SOURCES += gpio/bbb-gpio.c
>> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> new file mode 100644
>> index 0000000..dbab776
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> @@ -0,0 +1,578 @@
>> + * @file
>> + * @ingroup arm_beagle
>> + * @brief BeagleBoard I2C bus initialization and API Support.
>> + * Copyright (c) 2017 Sichen Zhao <zsc19940506 at gmail.com>
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.org/license/LICENSE.
>> + * Modified on Punit Vara<punitvara at gmail.com> works, currently
>> + * the i2c file is working on the Beaglebone Black board(AM335x)
>> +#include <stdio.h>
>> +#include <bsp/i2c.h>
>> +#include <libcpu/am335x.h>
>> +#include <rtems/irq-extension.h>
>> +#include <rtems/counter.h>
>> +#include <bsp/bbb-gpio.h>
>> +#include <rtems/score/assert.h>
>> +static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
>> +  REG(bus->regs + AM335X_CONF_I2C0_SDA) =
>> +  (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
>> +  REG(bus->regs + AM335X_CONF_I2C0_SCL) =
>> +static void I2C0ModuleClkConfig(void)
>> +    /* Configuring L3 Interface Clocks. */
> It's a little unusual to indent the comments farther than the code. In
> my opinion it makes it a little harder to read. But it seems that you
> use this style throughout the whole file. So if no one objects, it is OK
> by me too. Note that in the RTEMS core the style guide should be
> followed a little stricter (at least for new code).
>> +    /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
>> +  REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) |=
>> +          CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
>> +    /* Waiting for MODULEMODE field to reflect the written value. */
>> +  while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
>> +          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) &
>> +           CM_PER_L3_CLKCTRL_MODULEMODE));
>> +    /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
>> +  REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) |=
>> +          CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
>> +  while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
>> +          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) &
>> +           CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
>> +    /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
>> +  REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) |=
>> +          CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
>> +    /* Waiting for CLKTRCTRL field to reflect the written value. */
>> +  while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
>> +          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) &
>> +           CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
>> +    /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
>> +  REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) |=
>> +          CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
>> +    /*Waiting for CLKTRCTRL field to reflect the written value. */
>> +  while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
>> +          (REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) &
>> +           CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
>> +    /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
>> +  REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) |=
>> +          CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
>> +  while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
>> +          (REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) &
>> +           CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
>> +    /* Checking fields for necessary values.  */
>> +    /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0.
>> +  while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
>> +           CM_PER_L3_CLKCTRL_IDLEST));
>> +    ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain
>> the
>> +    ** desired value.
>> +  while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
>> +           CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
>> +           CM_PER_L3_INSTR_CLKCTRL_IDLEST));
>> +    ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
>> +    ** attain the desired value.
>> +  while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
>> +           CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
>> +    ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
>> +    ** register to attain the desired value.
>> +  while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
>> +           CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
>> +    ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
>> +    ** to attain the desired value.
>> +  while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
>> +          CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
>> +    /* Configuring registers related to Wake-Up region. */
>> +    /* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
>> +  REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) |=
>> +          CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE;
>> +  while(CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE !=
>> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) &
>> +           CM_WKUP_CONTROL_CLKCTRL_MODULEMODE));
>> +  REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) |=
>> +          CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
>> +  while(CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
>> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) &
>> +           CM_WKUP_CLKSTCTRL_CLKTRCTRL));
>> +    /* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
>> +  REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) |=
>> +          CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
>> +  while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
>> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) &
>> +           CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL));
>> +    /* Writing to MODULEMODE field of CM_WKUP_I2C0_CLKCTRL register. */
>> +  REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) |=
>> +          CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
>> +  while(CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
>> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) &
>> +           CM_WKUP_I2C0_CLKCTRL_MODULEMODE));
>> +    /* Verifying if the other bits are set to required settings. */
>> +    ** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to attain
>> +    ** desired value.
>> +  while((CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
>> +           CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT) !=
>> +           CM_WKUP_CONTROL_CLKCTRL_IDLEST));
>> +    ** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
>> +    ** register to attain desired value.
>> +  while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK !=
>> +           CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK));
>> +    ** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to attain
>> +    ** desired value.
>> +  while((CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC <<
>> +           CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT) !=
>> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_L4WKUP_CLKCTRL) &
>> +           CM_WKUP_L4WKUP_CLKCTRL_IDLEST));
>> +    ** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL register
>> +    ** to attain desired value.
>> +  while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK !=
>> +           CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK));
>> +    ** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in
>> CM_L4_WKUP_AON_CLKSTCTRL
>> +  while(CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK !=
>> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL) &
>> +           CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK));
>> +    ** Waiting for CLKACTIVITY_I2C0_GFCLK field in CM_WKUP_CLKSTCTRL
>> +  while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
>> +           CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK));
>> +    ** Waiting for IDLEST field in CM_WKUP_I2C0_CLKCTRL register to attain
>> +    ** desired value.
>> +  while((CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
>> +           CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT) !=
>> +           CM_WKUP_I2C0_CLKCTRL_IDLEST));
>> +static void am335x_i2c_reset(bbb_i2c_bus *bus)
>> +  volatile bbb_i2c_regs *regs = bus->regs;
>> +   int timeout = I2C_TIMEOUT;
> Why the three space indent?
>> +  if (REG(&regs->BBB_I2C_CON) & I2C_CON_EN) {
>> +    REG(&regs->BBB_I2C_CON) = I2C_CON_CLR;
>> +    udelay(50000);
>> +  REG(&regs->BBB_I2C_SYSC) = I2C_SYSC_SRST; /* for ES2 after soft reset */
>> +  udelay(1000);
>> +  REG(&regs->BBB_I2C_CON) = I2C_CON_EN;
>> +  while (!(REG(&regs->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
>> +    if (timeout <= 0) {
>> +      puts("ERROR: Timeout in soft-reset\n");
>> +      return;
>> +    udelay(1000);
>> +Possible values for msg->flag
>> +   * - @ref I2C_M_TEN,
>> +   * - @ref I2C_M_RD,
>> +   * - @ref I2C_M_STOP,
>> +   * - @ref I2C_M_NOSTART,
>> +   * - @ref I2C_M_REV_DIR_ADDR,
>> +   * - @ref I2C_M_IGNORE_NAK,
>> +   * - @ref I2C_M_NO_RD_ACK, and
>> +   * - @ref I2C_M_RECV_LEN.
>> +static void am335x_i2c_set_address_size(const i2c_msg *msgs,
>> +    /*can be configured multiple modes here. Need to think about own address
>> modes*/
>> +  if ((msgs->flags & I2C_M_TEN) == 0)  {
>> +  /* 7-bit mode slave address mode*/
>> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_7BIT_SLAVE_ADDR;
>> +  } else {
>> +  /* 10-bit slave address mode*/
>> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_10BIT_SLAVE_ADDR;
> Please fix the indentation of the am335x_i2c_set_address_size function.
>> +static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
>> +  i2c_msg *msg;
>> +  ++bus->msgs;
>> +  --bus->msg_todo;
>> +  msg = &bus->msgs[0];
>> +  bus->current_msg_todo = msg->len;
>> +  bus->current_msg_byte = msg->buf;
>> +static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
>> +  return (REG(&regs->BBB_I2C_IRQSTATUS_RAW));
>> +static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs,
>> +       unsigned int flag)
>> +  REG(&regs->BBB_I2C_IRQENABLE_SET) |= flag;
>> +static void am335x_i2c_masterint_disable(volatile bbb_i2c_regs *regs,
>> +  REG(&regs->BBB_I2C_IRQENABLE_CLR) = flag;
>> +static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
>> +  REG(&regs->BBB_I2C_IRQSTATUS) = flag;
>> +static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
>> +  am335x_i2c_masterint_enable(regs,I2C_ALL_FLAGS);
>> +  am335x_int_clear(regs,I2C_ALL_FLAGS);
>> +  am335x_i2c_masterint_disable(regs,I2C_ALL_FLAGS);
>> +static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus,
>> +       volatile bbb_i2c_regs *regs,
>> +       const i2c_msg *msgs, bool send_stop)
>> +  volatile unsigned int no_bytes;
>> +  int status;
>> +  REG(&regs->BBB_I2C_CNT) = bus->current_msg_todo;
>> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN;
>> +  if (send_stop) {
>> +    REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_START | AM335X_I2C_CON_STOP;
>> +  } else {
>> +  REG(&regs->BBB_I2C_CON) |=  AM335X_I2C_CON_START;
> Again: Please fix indentation.
>> +  am335x_i2c_masterint_enable(regs,AM335X_I2C_INT_RECV_READY
>> +                                  | AM335X_I2C_IRQSTATUS_ARDY);
>> +static void am335x_i2c_continue_read_transfer(
>> +  bbb_i2c_bus *bus,
>> +  bus->current_msg_byte[bus->already_transferred] = REG(&regs->BBB_I2C_DATA);
>> +  REG(&regs->BBB_I2C_IRQSTATUS) = AM335X_I2C_INT_RECV_READY;
>> +  if (bus->already_transferred ==  bus->current_msg_todo-1) {
>> +  REG(&regs->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
>> +   } else {
>> +  writeb(bus->current_msg_byte[bus->already_transferred],&regs->BBB_I2C_DATA);
>> +static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,
>> +       volatile bbb_i2c_regs *regs, const i2c_msg *msgs)
>> +  no_bytes = REG(&regs->BBB_I2C_CNT);
>> +  REG(&regs->BBB_I2C_SA) = msgs->addr;
>> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
>> +  am335x_clean_interrupts(regs);
>> +  am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY );
>> +static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus,
>> +  const i2c_msg *msgs = bus->msgs;
>> +  uint32_t msg_todo = bus->msg_todo;
>> +  bool send_stop = false;
>> +  uint32_t i;
>> +  bus->current_todo = msgs[0].len;
>> +  for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
>> +    bus->current_todo += msgs[i].len;
>> +  regs = bus->regs;
>> +  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
>> +  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
>> +  am335x_i2c_set_address_size(msgs,regs);
>> +  bus->read = (msgs->flags & I2C_M_RD) != 0;
>> +  bus->already_transferred = (bus->read == true) ? 0 : 1;
>> +  if (bus->read) {
>> +    if (bus->current_msg_todo == 1) {
>> +      send_stop = true;
>> +  am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
>> +  } else {
>> +  am335x_i2c_setup_write_transfer(bus,regs,msgs);
>> +static void am335x_i2c_interrupt(void *arg)
>> +  bbb_i2c_bus *bus = arg;
>> +  /* get status of enabled interrupts */
>> +  uint32_t irqstatus = REG(&regs->BBB_I2C_IRQSTATUS);
>> +  bool done = false;
>> +  /* Clear all enabled interrupt except receive ready
>> +  and transmit ready interrupt in status register */
>> +  REG(&regs->BBB_I2C_IRQSTATUS) = (irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY
>> +                                                | AM335X_I2C_IRQSTATUS_XRDY));
>> + if (irqstatus & AM335X_I2C_INT_RECV_READY ) {
>> +    am335x_i2c_continue_read_transfer(bus, regs);
>> +  if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
>> +    am335x_i2c_continue_write(bus,regs);
>> +  if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
>> +    done = true;
>> +    am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
>> +   if (irqstatus & AM335X_I2C_IRQSTATUS_ARDY) {
>> +  done = true;
>> +  REG(&regs->BBB_I2C_IRQSTATUS) = I2C_STAT_ARDY;
> And again: Please fix indentation.
>> +   if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
>> +   REG( &regs->BBB_I2C_IRQSTATUS) = AM335X_I2C_IRQSTATUS_BF;
>> +  if (done) {
>> +    uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
>> +    am335x_i2c_next_byte(bus);
>> +    if (bus->msg_todo == 0 ) {
>> +    rtems_status_code sc;
>> +    am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY
>> +                                       | AM335X_I2C_IRQSTATUS_BF));
>> +    REG(&regs->BBB_I2C_IRQSTATUS) = err;
>> +    sc = rtems_event_transient_send(bus->task_id);
>> +    _Assert(sc == RTEMS_SUCCESSFUL);
>> +    (void) sc;
>> +    } else {
>> +    am335x_i2c_setup_transfer(bus, regs);
>> +static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t
>> msg_count)
>> +  bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
>> +  volatile bbb_i2c_regs *regs;
>> +  uint32_t i;
>> +  rtems_task_wake_after(1);
>> +  if (msg_count < 1){
>> +    return 1;
>> +  for (i=0; i<msg_count;++i) {
>> +      if ((msgs[i].flags & I2C_M_RECV_LEN) != 0) {
>> +        return -EINVAL;
>> +  bus->msgs = &msgs[0];
>> +  bus->msg_todo = msg_count;
>> +  bus->current_msg_todo = msgs[0].len;
>> +  bus->current_msg_byte = msgs[0].buf;
>> +  bus->task_id = rtems_task_self();
>> +  regs = bus->regs;
>> +  am335x_i2c_setup_transfer(bus,regs);
>> +  REG(&regs->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
>> +  sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
>> +  if (sc != RTEMS_SUCCESSFUL) {
>> +    am335x_i2c_reset(bus);
>> +    rtems_event_transient_clear();
>> +    return -ETIMEDOUT;
>> +  return 0;
>> +static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
>> +  bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
>> +  uint32_t prescaler,divider;
>> +  prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
>> +  REG(&bus->regs->BBB_I2C_PSC) = prescaler;
>> +  divider = BBB_I2C_INTERNAL_CLK/(2*clock);
>> +  REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
>> +  REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
>> +  return 0;
>> +static void am335x_i2c_destroy(i2c_bus *base)
>> +  sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt, bus);
>> +  (void)sc;
>> +  i2c_bus_destroy_and_free(&bus->base);
>> +int am335x_i2c_bus_register(
>> +  const char *bus_path,
>> +  uintptr_t register_base,
>> +  uint32_t input_clock,
>> +  rtems_vector_number irq
>> +  bbb_i2c_bus *bus;
>> +  int err;
>> +  /*check bus number is >0 & <MAX*/
>> +  bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init(sizeof(*bus));
>> +  if (bus == NULL) {
>> +    return -1;
>> +  bus->regs = (volatile bbb_i2c_regs *) register_base;
>> +  I2C0ModuleClkConfig();
>> +  am335x_i2c0_pinmux(bus);
>> +  bus->input_clock = input_clock;
>> +  err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
>> +  if (err != 0) {
>> +    (*bus->base.destroy)(&bus->base);
>> +    rtems_set_errno_and_return_minus_one(-err);
>> +   bus->irq = irq;
> Three spaces again.
>> +  REG(&bus->regs->BBB_I2C_IRQSTATUS) = I2C_ALL_IRQ_FLAGS;
>> +  sc  = rtems_interrupt_handler_install(
>> +    irq,
>> +    "BBB_I2C",
>> +    RTEMS_INTERRUPT_UNIQUE,
>> +    (rtems_interrupt_handler)am335x_i2c_interrupt,
>> +    bus
>> +    rtems_set_errno_and_return_minus_one(EIO);
>> +  bus->base.transfer = am335x_i2c_transfer;
>> +  bus->base.set_clock = am335x_i2c_set_clock;
>> +  bus->base.destroy = am335x_i2c_destroy;
>> +  return i2c_bus_register(&bus->base,bus_path);
>> \ No newline at end of file
>> diff --git a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
>> b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
>> index 8cce556..ceb12a4 100644
>> --- a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
>> +++ b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
>> @@ -35,9 +35,11 @@ extern "C" {
>> #define BBB_PU_EN (1 << 4)
>> #define BBB_PD_EN ~BBB_PU_EN
>> #define BBB_MUXMODE(X) (X & 0x7)
>> +#define BBB_RXACTIVE (1 << 5)
>> +#define BBB_SLEWCTRL (1 << 6)
>> #ifdef __cplusplus
>> #endif /* __cplusplus */
>> -#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
>> +#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
>> diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> b/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> index e7d1716..b7c71d9 100644
>> --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> @@ -1,5 +1,4 @@
>> - * @file
>> @@ -24,7 +23,7 @@
>> #define LIBBSP_ARM_BEAGLE_I2C_H
>> #include <rtems.h>
>> +#include <dev/i2c/i2c.h>
>> #include <bsp.h>
>> #ifdef __cplusplus
>> @@ -43,6 +42,7 @@ extern "C" {
>> #define I2C_CON_XA  (1 << 8)   /* Expand address */
>> #define I2C_CON_STP (1 << 1)   /* Stop condition (master mode only) */
>> #define I2C_CON_STT (1 << 0)   /* Start condition (master mode only) */
>> +#define I2C_CON_CLR 0x0  /* Clear configuration register */
>> /* I2C Status Register (I2C_STAT): */
>> @@ -57,7 +57,6 @@ extern "C" {
>> #define I2C_STAT_ARDY (1 << 2)  /* Register access ready */
>> #define I2C_STAT_NACK (1 << 1)  /* No acknowledgment interrupt enable */
>> #define I2C_STAT_AL (1 << 0)  /* Arbitration lost interrupt enable */
>> /* I2C Interrupt Enable Register (I2C_IE): */
>> #define I2C_IE_GC_IE  (1 << 5)
>> #define I2C_IE_XRDY_IE  (1 << 4) /* Transmit data ready interrupt enable */
>> @@ -65,6 +64,10 @@ extern "C" {
>> #define I2C_IE_ARDY_IE  (1 << 2) /* Register access ready interrupt enable */
>> #define I2C_IE_NACK_IE  (1 << 1) /* No acknowledgment interrupt enable */
>> #define I2C_IE_AL_IE  (1 << 0) /* Arbitration lost interrupt enable */
>> +/* I2C SYSC Register (I2C_SYSC): */
>> +#define I2C_SYSC_SRST (1 << 1)
>>  * The equation for the low and high time is
>>  * tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed
>> @@ -132,7 +135,7 @@ extern "C" {
>> #define DISP_LINE_LEN 128
>> -#define I2C_TIMEOUT 1000
>> +#define I2C_TIMEOUT 500
>> #define I2C_BUS_MAX 3
>> @@ -144,6 +147,8 @@ extern "C" {
>> #define CONFIG_SYS_I2C_SPEED    100000
>> #define CONFIG_SYS_I2C_SLAVE    1
>> +#define I2C_ALL_FLAGS 0x7FFF
>> +#define I2C_ALL_IRQ_FLAGS 0xFFFF
>> struct i2c {
>>   unsigned short rev;   /* 0x00 */
>> @@ -180,20 +185,8 @@ struct i2c {
>>   unsigned short res15;
>> -static unsigned short wait_for_pin( void );
>> -static void wait_for_bb( void );
>> -static void flush_fifo( void );
>> void i2c_init( int speed, int slaveadd );
>> -static int i2c_read_byte(
>> -  unsigned char devaddr,
>> -  unsigned char regoffset,
>> -  unsigned char *value
>> int i2c_write(
>>   unsigned char chip,
>>   unsigned int addr,
>> @@ -210,10 +203,6 @@ int i2c_read(
>>   int len
>> -static int imw ( unsigned char  chip, unsigned long addr, unsigned char byte );
>> -static int imd( unsigned char chip, unsigned int addr, unsigned int length );
>>  * @brief Initializes the I2C module @a i2c.
>> @@ -361,6 +350,139 @@ static inline rtems_status_code beagle_i2c_read(
>>   return beagle_i2c_write_and_read(i2c, addr, NULL, 0, in, in_size);
>> +#define BBB_I2C_SYSCLK 48000000
>> +#define BBB_I2C_INTERNAL_CLK 12000000
>> +#define BBB_I2C_SPEED_CLK 100000
>> +#define BBB_I2C_IRQ_ERROR \
>> +  (AM335X_I2C_IRQSTATUS_NACK \
>> +    | AM335X_I2C_IRQSTATUS_ROVR \
>> +    | AM335X_I2C_IRQSTATUS_AL \
>> +    | AM335X_I2C_IRQSTATUS_ARDY \
>> +    | AM335X_I2C_IRQSTATUS_RRDY \
>> +    | AM335X_I2C_IRQSTATUS_XRDY \
>> +    | AM335X_I2C_IRQSTATUS_XUDF )
>> +  #define BBB_I2C_IRQ_USED \
>> +  ( AM335X_I2C_IRQSTATUS_ARDY \
>> +#define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
>> +#define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
>> +#define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
>> +#define BBB_I2C0_IRQ 70
>> +#define BBB_I2C1_IRQ 71
>> +#define BBB_I2C2_IRQ 30
>> +#define MODE2 2
>> +#define MODE3 3
>> +typedef enum {
>> +  I2C0,
>> +  I2C1,
>> +  I2C2,
>> +  I2C_COUNT
>> +}bbb_i2c_id_t;
>> +typedef struct i2c_regs
>> +  uint32_t BBB_I2C_REVNB_LO;
>> +  uint32_t BBB_I2C_REVNB_HI;
>> +  uint32_t dummy1[2];
>> +  uint32_t BBB_I2C_SYSC;
>> +  uint32_t dummy2[4];
>> +  uint32_t BBB_I2C_IRQSTATUS_RAW;
>> +  uint32_t BBB_I2C_IRQSTATUS;
>> +  uint32_t BBB_I2C_IRQENABLE_SET;
>> +  uint32_t BBB_I2C_IRQENABLE_CLR;
>> +  uint32_t BBB_I2C_WE;
>> +  uint32_t BBB_I2C_DMARXENABLE_SET;
>> +  uint32_t BBB_I2C_DMATXENABLE_SET;
>> +  uint32_t BBB_I2C_DMARXENABLE_CLR;
>> +  uint32_t BBB_I2C_DMATXENABLE_CLR;
>> +  uint32_t BBB_I2C_DMARXWAKE_EN;
>> +  uint32_t BBB_I2C_DMATXWAKE_EN;
>> +  uint32_t dummy3[16];
>> +  uint32_t BBB_I2C_SYSS;
>> +  uint32_t BBB_I2C_BUF;
>> +  uint32_t BBB_I2C_CNT;
>> +  uint32_t BBB_I2C_DATA;
>> +  uint32_t dummy4;
>> +  uint32_t BBB_I2C_CON;
>> +  uint32_t BBB_I2C_OA;
>> +  uint32_t BBB_I2C_SA;
>> +  uint32_t BBB_I2C_PSC;
>> +  uint32_t BBB_I2C_SCLL;
>> +  uint32_t BBB_I2C_SCLH;
>> +  uint32_t BBB_I2C_SYSTEST;
>> +  uint32_t BBB_I2C_BUFSTAT;
>> +  uint32_t BBB_I2C_OA1;
>> +  uint32_t BBB_I2C_OA2;
>> +  uint32_t BBB_I2C_OA3;
>> +  uint32_t BBB_I2C_ACTOA;
>> +  uint32_t BBB_I2C_SBLOCK;
>> +}bbb_i2c_regs;
>> +typedef struct bbb_i2c_bus{
>> +  i2c_bus base;
>> +  i2c_msg *msgs;
>> +  uint32_t msg_todo;
>> +  uint32_t current_msg_todo;
>> +  uint8_t *current_msg_byte;
>> +  uint32_t current_todo;
>> +  bool read;
>> +  bool hold;
>> +  rtems_id task_id;
>> +  rtems_vector_number irq;
>> +  uint32_t input_clock;
>> +  uint32_t already_transferred;
>> +} bbb_i2c_bus;
>> +static inline int bbb_register_i2c_0(void)
>> +  return am335x_i2c_bus_register(
>> +    BBB_I2C_0_BUS_PATH,
>> +    AM335X_I2C0_BASE,
>> +    I2C_BUS_CLOCK_DEFAULT,
>> +    BBB_I2C0_IRQ
>> +static inline int bbb_register_i2c_1(void)
>> +    BBB_I2C_1_BUS_PATH,
>> +    AM335X_I2C1_BASE,
>> +    BBB_I2C1_IRQ
>> +static inline int bbb_register_i2c_2(void)
>> +    BBB_I2C_2_BUS_PATH,
>> +    AM335X_I2C2_BASE,
>> +    BBB_I2C2_IRQ
>> #ifdef __cplusplus
>> diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h
>> b/c/src/lib/libcpu/arm/shared/include/am335x.h
>> index f59f896..234ed39 100644
>> --- a/c/src/lib/libcpu/arm/shared/include/am335x.h
>> +++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
>> @@ -563,3 +563,199 @@
>> +/* I2C registers */
>> +#define AM335X_I2C0_BASE 0x44e0b000
>> +    /* I2C0 base address */
>> +#define AM335X_I2C1_BASE 0x4802a000
>> +    /* I2C1 base address */
>> +#define AM335X_I2C2_BASE 0x4819c000
>> +    /* I2C2 base address */
>> +#define AM335X_I2C_REVNB_LO        0x00
>> +    /* Module Revision Register (low bytes) */
>> +#define AM335X_I2C_REVNB_HI        0x04
>> +    /* Module Revision Register (high bytes) */
>> +#define AM335X_I2C_SYSC            0x10
>> +    /* System Configuration Register */
>> +#define AM335X_I2C_IRQSTATUS_RAW   0x24
>> +    /* I2C Status Raw Register */
>> +#define AM335X_I2C_IRQSTATUS       0x28
>> +    /* I2C Status Register */
>> +#define AM335X_I2C_IRQENABLE_SET   0x2c
>> +    /* I2C Interrupt Enable Set Register */
>> +#define AM335X_I2C_IRQENABLE_CLR   0x30
>> +    /* I2C Interrupt Enable Clear Register */
>> +#define AM335X_I2C_WE              0x34
>> +    /* I2C Wakeup Enable Register */
>> +#define AM335X_I2C_DMARXENABLE_SET 0x38
>> +    /* Receive DMA Enable Set Register */
>> +#define AM335X_I2C_DMATXENABLE_SET 0x3c
>> +    /* Transmit DMA Enable Set Register */
>> +#define AM335X_I2C_DMARXENABLE_CLR 0x40
>> +    /* Receive DMA Enable Clear Register */
>> +#define AM335X_I2C_DMATXENABLE_CLR 0x44
>> +    /* Transmit DMA Enable Clear Register */
>> +#define AM335X_I2C_DMARXWAKE_EN    0x48
>> +    /* Receive DMA Wakeup Register */
>> +#define AM335X_I2C_DMATXWAKE_EN    0x4c
>> +    /* Transmit DMA Wakeup Register */
>> +#define AM335X_I2C_SYSS            0x90
>> +    /* System Status Register */
>> +#define AM335X_I2C_BUF             0x94
>> +    /* Buffer Configuration Register */
>> +#define AM335X_I2C_CNT             0x98
>> +    /* Data Counter Register */
>> +#define AM335X_I2C_DATA            0x9c
>> +    /* Data Access Register */
>> +#define AM335X_I2C_CON             0xa4
>> +    /* I2C Configuration Register */
>> +#define AM335X_I2C_OA              0xa8
>> +    /* I2C Own Address Register */
>> +#define AM335X_I2C_SA              0xac
>> +    /* I2C Slave Address Register */
>> +#define AM335X_I2C_PSC             0xb0
>> +    /* I2C Clock Prescaler Register */
>> +#define AM335X_I2C_SCLL            0xb4
>> +    /* I2C SCL Low Time Register */
>> +#define AM335X_I2C_SCLH            0xb8
>> +    /* I2C SCL High Time Register */
>> +#define AM335X_I2C_SYSTEST         0xbc
>> +    /* System Test Register */
>> +#define AM335X_I2C_BUFSTAT         0xc0
>> +    /* I2C Buffer Status Register */
>> +#define AM335X_I2C_OA1             0xc4
>> +    /* I2C Own Address 1 Register */
>> +#define AM335X_I2C_OA2             0xc8
>> +    /* I2C Own Address 2 Register */
>> +#define AM335X_I2C_OA3             0xcc
>> +    /* I2C Own Address 3 Register */
>> +#define AM335X_I2C_ACTOA           0xd0
>> +    /* Active Own Address Register */
>> +#define AM335X_I2C_SBLOCK          0xd4
>> +    /* I2C Clock Blocking Enable Register */
>> +#define AM335X_CM_PER_L4LS_CLKSTCTRL  (0x0)
>> +#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP  (0x2u)
>> +#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL  (0x00000003u)
>> +#define AM335X_CM_PER_L4LS_CLKCTRL  (0x60)
>> +#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
>> +#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE  (0x00000003u)
>> +#define AM335X_CM_PER_I2C1_CLKCTRL  (0x48)
>> +#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
>> +#define AM335X_ CM_PER_I2C1_CLKCTRL_MODULEMODE  (0x00000003u)
>> +#define AM335X_CM_PER_I2C2_CLKCTRL (0x44)
>> +#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
>> +#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE  (0x00000003u)
>> +#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK (0x00000100u)
>> +#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK (0x01000000u)
>> +#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE   (0x00000003u)
>> +#define AM335X_I2C_CON_XSA  (0x00000100u)
>> +#define AM335X_I2C_CFG_10BIT_SLAVE_ADDR  AM335X_I2C_CON_XSA
>> +#define AM335X_I2C_CON_XSA_SHIFT  (0x00000008u)
>> +#define AM335X_I2C_CFG_7BIT_SLAVE_ADDR  (0 << AM335X_I2C_CON_XSA_SHIFT)
>> +#define AM335X_I2C_CON_I2C_EN   (0x00008000u)
>> +#define AM335X_I2C_CON_TRX   (0x00000200u)
>> +#define AM335X_I2C_CON_MST   (0x00000400u)
>> +#define AM335X_I2C_CON_STB   (0x00000800u)
>> +#define AM335X_I2C_SYSC_AUTOIDLE   (0x00000001u)
>> +/*I2C0 module clock registers*/
>> +#define CM_PER_L3_CLKCTRL   (0xe0)
>> +#define CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
>> +#define CM_PER_L3_CLKCTRL_MODULEMODE   (0x00000003u)
>> +#define CM_PER_L3_INSTR_CLKCTRL   (0xdc)
>> +#define CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
>> +#define CM_PER_L3_INSTR_CLKCTRL_MODULEMODE   (0x00000003u)
>> +#define CM_PER_L3_CLKSTCTRL   (0xc)
>> +#define CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
>> +#define CM_PER_L3_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
>> +#define CM_PER_OCPWP_L3_CLKSTCTRL   (0x12c)
>> +#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
>> +#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
>> +#define CM_PER_L3S_CLKSTCTRL   (0x4)
>> +#define CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
>> +#define CM_PER_L3S_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
>> +#define CM_PER_L3_CLKCTRL_IDLEST_FUNC   (0x0u)
>> +#define CM_PER_L3_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
>> +#define CM_PER_L3_CLKCTRL_IDLEST   (0x00030000u)
>> +#define CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC   (0x0u)
>> +#define CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
>> +#define CM_PER_L3_INSTR_CLKCTRL_IDLEST   (0x00030000u)
>> +#define CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK   (0x00000010u)
>> +#define CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK   (0x00000010u)
>> +#define CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK   (0x00000008u)
>> +#define CM_WKUP_CONTROL_CLKCTRL   (0x4)
>> +#define CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
>> +#define CM_WKUP_CONTROL_CLKCTRL_MODULEMODE   (0x00000003u)
>> +#define CM_WKUP_CLKSTCTRL   (0x0)
>> +#define CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
>> +#define CM_WKUP_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
>> +#define CM_WKUP_CM_L3_AON_CLKSTCTRL   (0x18)
>> +#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
>> +#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
>> +#define CM_WKUP_I2C0_CLKCTRL   (0xb8)
>> +#define CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
>> +#define CM_WKUP_I2C0_CLKCTRL_MODULEMODE   (0x00000003u)
>> +#define CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC   (0x0u)
>> +#define CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
>> +#define CM_WKUP_CONTROL_CLKCTRL_IDLEST   (0x00030000u)
>> +#define CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK   (0x00000008u)
>> +#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC   (0x0u)
>> +#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
>> +#define CM_WKUP_L4WKUP_CLKCTRL   (0xc)
>> +#define CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK   (0x00000004u)
>> +#define CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK
>> (0x00000004u)
>> +#define CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL   (0xcc)
>> +#define CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK   (0x00000800u)
>> +#define CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC   (0x0u)
>> +#define CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
>> +#define CM_WKUP_I2C0_CLKCTRL_IDLEST   (0x00030000u)
>> +#define CM_WKUP_L4WKUP_CLKCTRL_IDLEST   (0x00030000u)
>> +#define SOC_CM_WKUP_REGS                     (AM335X_CM_PER_ADDR + 0x400)
>> +/* I2C status Register */
>> +#define AM335X_I2C_IRQSTATUS_NACK (1 << 1)
>> +#define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
>> +#define AM335X_I2C_IRQSTATUS_AL   ( 1<<0 )
>> +#define AM335X_I2C_IRQSTATUS_ARDY (1 << 2)
>> +#define AM335X_I2C_IRQSTATUS_RRDY (1 << 3)
>> +#define AM335X_I2C_IRQSTATUS_XRDY (1 << 4)
>> +#define AM335X_I2C_IRQSTATUS_XUDF (1 << 10)
>> +#define AM335X_I2C_BUF_TXFIFO_CLR   (0x00000040u)
>> +#define AM335X_I2C_BUF_RXFIFO_CLR   (0x00004000u)
>> +#define AM335X_I2C_IRQSTATUS_AAS  (1 << 9)
>> +#define AM335X_I2C_IRQSTATUS_BF  (1 << 8)
>> +#define AM335X_I2C_IRQSTATUS_STC  (1 << 6)
>> +#define AM335X_I2C_IRQSTATUS_GC (1 << 5)
>> +#define AM335X_I2C_IRQSTATUS_XDR (1 << 14)
>> +#define AM335X_I2C_IRQSTATUS_RDR (1 << 13)
>> +#define AM335X_I2C_INT_RECV_READY AM335X_I2C_IRQSTATUS_RRDY
>> +#define AM335X_I2C_CON_STOP  (0x00000002u)
>> +#define AM335X_I2C_CON_START (0x00000001u)
>> +#define AM335X_I2C_CFG_MST_RX AM335X_I2C_CON_MST
>> +#define AM335X_I2C_CFG_MST_TX  AM335X_I2C_CON_TRX | AM335X_I2C_CON_MST
>> +#define AM335X_I2C_IRQSTATUS_RAW_BB   (0x00001000u)
>> +#define AM335X_I2C_IRQSTATUS_BF (0x00000100u)
>> +#define AM335X_CM_PER_L3S_CLKSTCTRL   (0x4)
>> +#define AM335X_CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
>> +#define AM335X_CM_PER_L3S_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
>> +#define AM335X_CM_PER_L3_CLKSTCTRL   (0xc)
>> +#define AM335X_CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
>> +#define AM335X_CM_PER_L3_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
>> +#define AM335X_CM_PER_L3_INSTR_CLKCTRL   (0xdc)
>> +#define AM335X_CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
>> +#define AM335X_CM_PER_L3_CLKCTRL   (0xe0)
>> +#define AM335X_CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
>> +#define AM335X_CM_PER_L3_CLKCTRL_MODULEMODE   (0x00000003u)
>> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL   (0x12c)
>> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP   (0x2u)
>> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL   (0x00000003u)
>> +#define AM335X_CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK   (0x00000010u)
>> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK
>> (0x00000010u)
>> +#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK
>> (0x00000020u)
>> +#define AM335X_CM_PER_L3_INSTR_CLKCTRL_MODULEMODE   (0x00000003u)
>> +#define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
>> 2.7.4
>> devel mailing list
>> devel at rtems.org
> embedded brains GmbH
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
> devel mailing list
> devel at rtems.org
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
