make install problems
Fri May 26 00:37:46 UTC 2017
On 26/05/2017 09:53, Chris Johns wrote:
> On 26/05/2017 06:46, Kirspel, Kevin wrote:
>> I am having trouble with make install today.  Nothing gets copied to
>> the installation directory when invoking make install.  Did the recent
>> parallel build on all sub directories changes affect the way make
>> install works?
> Hmm I did not test this. Bad me. Looking at it now...
I have pushed a fix for this and I have tested installing a bsp, clean
and then make again.
I have a `everything` tests build running now which takes a couple of hours.
I am sorry about the breakage.
