[PATCH] Add support to build riscv32 toolchain
Tue May 30 06:01:08 UTC 2017
Hello Hesham,
thanks for your RISCV support.
----- Am 30. Mai 2017 um 3:51 schrieb Hesham Almatary heshamelmatary at gmail.com:
> rtems/config/4.12/rtems-riscv32.bset               | 32 +++++++++++
> rtems/config/tools/rtems-binutils-2.28-1.cfg       | 22 ++++++++
> .../rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg    | 65 ++++++++++++++++++++++
> +# Patches for gcc and newlib
> +%patch add gcc -p1
> https://raw.githubusercontent.com/heshamelmatary/riscv-rtems-patches/master/gcc-rtems-riscv.patch
Do you have a copyright assignment with the FSF? If not and you don't want to do this, then I can try to add the RISCV support to GCC without locking at your GCC patches. We should commit the things first into GCC.
> +%patch add newlib -p1
> https://raw.githubusercontent.com/heshamelmatary/riscv-rtems-patches/master/0001-Import-risc-v-from-https-github.com-riscv.patch
Are there plans by the RISCV people to add this to upstream Newlib soon? Due to the RISCV support in FSF Binutils and GCC, there should be no problems.
