[PATCH] Added documentation for rtems-tester in rtems-docs
Tanu Hari Dixit tokencolour at gmail.com
Tue May 30 10:37:42 UTC 2017
Hello Chris, all,
I have changed the tester example to erc32 from sis in the doc and
there are a few changes in the explanation of supported states for the
tests. Also the doc is in ReST now. I have included the new format for
the configuration file. Please tell if you find some corrections to be
done so that I can change the content wherever I am wrong. I plan on
changing this documentation as new things get integrated into
rtems-tester.
(That giant binary is for the image for the RTEMS logo. We can view
the changes in the rst file if we click on "View entire message")
Thank you,
Tanu Hari Dixit.
On Tue, May 30, 2017 at 3:55 PM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
> This documentation is in ReST and has been ported
> from rtems-tools.git. There are a few changes and
> it contains the format for the ini configuration
> files.
>  images/user/rtemswhitebg.jpg | Bin 0 -> 117890 bytes
>  user/tools/rtems-tester.rst  | 639 +++++++++++++++++++++++++++++++++++++++++++
>  2 files changed, 639 insertions(+)
>  create mode 100644 images/user/rtemswhitebg.jpg
>  create mode 100644 user/tools/rtems-tester.rst
> diff --git a/images/user/rtemswhitebg.jpg b/images/user/rtemswhitebg.jpg
> new file mode 100644
> index 0000000000000000000000000000000000000000..f883f2c495d4d91ef94d35e28995b9d2b7a863f7
> GIT binary patch
> literal 117890
> zcmeFZ2V4}%wm;tF43dMupyX^KNf;4HA|go?gi#OykqnY&3<L=>5)?%QB?yQx3J6FV
> za!_C-tHdE^7~%jEevP|#ckk}Ld+&Sy_ul8e&wtxb569}N?mDMVo%){Br<(kgJO&&%
> zt7oVOP*6|+2H-z{JkET{P)7%L!OTR@@SHAq0RWf{&bhdIP#ypPH+NreGyT&dmo8h2
> z&~*Zo00Te^90h=D4nCg7=6V(Yco^#Hi1>h&_UWGw at E%+J0Qd_4J at N(@L_~fr|5yL8
> zJ9v8g0szGYu)*=`jy?_`9R||3{Cz$5%U3~~%ieXLrlj7dy}=HGG~Yh$^b;-jqs~wC
> zseSsooBMUJ&VHXgue)8}ryD`~!EHZBkfu5Z(h;{^9Q{GM7o^2*`MJ4(G#;e6+#Ij@
> z001 at fez~usgEL4U0cmD$3o{*%)&Kx{W~blK_P?Qh9Rt9A0)UQ(XP~!>le4dgl!LU$
> zQ8hJH5d%m6TaLcI@)xc-xL)(VE~4Y%=6TIM5CDGSdA}9Fu`gQ at P{_(h)s&Uxk12rS
> z|K<3H7k{bskBR-U{i(*f>5nm^;A#K0?ANxxmU(0Vfa)eFn at 7Kv**^n-vTy+4`~GX0
> z*h>Il3j=^s%y0PN+1D3mUtiCYii-aJ{t7OR4hs7M{pI+l6 at IDt9}~ZMp2Gg~evzHX
> z8OIyf{BHS*><iVw<Cce?w}_ADH3vr#`QIz?f4Sjry7ilW$eB6baP)R`2Oo72)G`-$
> zCvdpkue<oVc({wWxc^5Z{9kPLn?CH5Kj}3{aAuJJE|>yv0K)}PEwuyGoJ;`Kl{D}Q
> z#V_M_j^QG(Kl7|0Ge7A)NQ2jZ{Qlh!B at +BErH_k~$bPYonT3dhpZD#38k`gRKQsU%
> zzy@#u{D3eZ3P=I+z%f7tPzO!{y1-e$1h4=u19pG|;0(9{-he+40^9{6fEeHr at EAw|
> z(t#`>4=4nRfHI&8r~{gT&%hU;4;Tc-fGJ=BSOvC#J<yQRQLs>OQt(qiD8wmbDUMO7
> zQfN`=Qk<hOqqt0QmBNX_ox+bIgyKF$3`GJ(3dJjmJc{=eA1Uf6+9<jxzENN)<|x)E
> zb}6YSnJKv_g(xK`6)9CIwJD7#Ehud%ohZF1gDAr&<0zj}W>CJRETycY{7l(LIYzla
> zxk&|3F;VeQ9ioz_Ql-+NGNH1jx<Tbl1*eLpdP0>!RY+Aq)k4)nHAb~awL?uy%}Fgn
> zEl;gZZ9r{F?Lh5C4X2K!PNB}FE~Rdy?xDs~uTqm}SZD-kWNA*)7}8v#aia03iJ*Bx
> z^P1)ZO%qKY%@oZREiEk%tt71qtpV+2+MBe&w6U}=Xi>Dav|Y3lw3~Evbo_L(beeP~
> zbl2#7=_2T!(Y>WZ({<BL(c$Tt=pppS==JEW>D}q?(LbSoLtjJRO+Q1w$8dl_oZ%#c
> z3Bz at UKn5g37DELChGB|fkCB~Gl2Mb<g7GHfUB;)3g^W#%LyYT8OiYKF)R;_}T$t`K
> zJ!N{w)XIcq+F|BkmSNUmzQXLs9LJo)T+958d7XuYMS|rNi#3ZcOB_ocO9RUY3!ase
> zRe{xz^*Sqp^*L)PYd7mM8v~m-n>L#rTM*k5wqiC6+u{L+0}=;x4qQ6`Kk)p(#{&Zg
> zHrYAZkFuMvyRpZzzhQ4<pXH$Akl at hexXuyAk;&1(F~Ld2DaxtC>A-oPGmEo{bBc?W
> zOOnfw>n2wWR{>Wi*D5y$_X+Nc+yUIrxvROyc&K<Jcno=N at gRAMc=~yEd4+hjc^!G9
> zcnf*EdAIov@}1&y<csD*@%8cT@{926^1JfK^Ox}t3s4Kl2$%}^3#17&2`nDuI;eio
> z;b8Q^qJ!TBDFtN&%>;u5GX>iPH-&_S^o2Zyo(VMwEei7ppAx<)oFrT$JO|-~XhB>c
> zNf0z-UW8jjTjZ9=Q;|lI)kA`Z3=a7ndUdGt(B5Im!<L8d9Y!4<7G)Gw6}=&vBw8=J
> zDh3fV77G!}7yB;GAg(IzES at ahBEBslDPbiMDN!adE6FEmC>bP~FF7Q|A_bN5lFE?k
> zm8O+em3EbWA^k;$QbtL}S?0M6MwU`mS=L4Ng>07`jhvdCyIh9cfIPFjw)}1Re0i(_
> zkHR^HdkSR=%Zg%(){60pEsCTgN=I%T$vQH4l;h~xqxX(h99=smbIjq`^JBfoS&r)+
> zM;tFdjyoZH!tq4fiLXkWO2$f&O7%)aWff&_<wE5-6)}~oDyb?1s$8lURAW_J)o9dC
> zt0B~?)OJoPpY%OhbaF*qUfoswjry#Hq=utLmd1qUVa;oruQbQBM6|AIz0?|m9)ezj
> zW<bYJiJrQC>h-A^ZE5YB+HbX&Paiq$efq=cZJm=kp*po^sLtr0i9XY*%b{zjo1#0S
> zcUaF!FJEs}Ur9e$zt(`pz{nupV8Bqw(7`azaP_Rp+0e6%M$AU$Mkz+)=VZ=#pQ|vY
> zG(KybXgqXY{Ji`5G84eW&?M1h_=4mGuM3r?w5AtKpPNpb9W at IvYcc0Ehnc@I-?BJu
> zfwUO3l(O`*tiQ;1 at yf-#i`!ObtP-roE-79Lz4ZCAz-5=q<<@l87p-4gZ`$bEJhqv-
> zqI4zVO24h7ZGdf?oq*jfyJ{F4>>8~2D$P}^t8cCnu9;lRxVC9;XrF4o>Y(G0?67eC
> z)b*t6bB>yh363*2G;bu_n03;0N_3iYhB`lSUUboMNpZp5G`N|5bKBL#HOG~F%jy=&
> zjo$65+edc}cUSjD4`Gi0k1kJH&j`;kuajPny;i-AykGlJ_}KcC`*ML`s at +e@FWe7%
> zTkH1o+j#$r{>1_80qz0qfii(nfippRLD|97!4ARoA%{ZlhG0XrLtnuu;P&u(geW2m
> zF?C1(PVQaCyRLUT?j5<8aBt(j)%}Vvp|Cq)6XE*d`4OxU-Vp<l>XGRWs2{jI=!`lZ
> z^(=}MeLeb9%#oNUF@#u$*iR3SK79I+9CstG6RC_$dqn%l{ZW5BG(I<hJs~JzBGEXp
> zG)W{WI%(rE>~Y(Z6Hn5U8I%2z$DW>hTK-Jz*`sHK6z7z_=ck{eQUz0^Qnz1Rf6<+G
> zDy=YGC_N^9_od6rudno9m1am}JjtZZyq!6nbup_YTQxiHwZQ9`*Tfw6oUvT9+{QeW
> zyu3GpZ;<(v`F{CxZ?C-lQgEiAyimUI6^aKH^A33D_iq0E)%X2HMn(0-s>OvR;w7mc
> zI6p*}Qj`Xku9i8Mjg?<6 at A`Q5V||5s#fM6T%ABf0RnM!rtC2N~HDNVmbP#&8*0Xl8
> z&Z%yq9#%itaH*lU(X_F%$*8HdS+BXFMY{#vs at YoAcCzi`C)H17pOrtCwkx%N=uqnT
> z(5c*6ic!Ioe^L8V(WTK<(+%ye>p9cY+-unTx$k^mSHETd*MTboV_&a-o&9#}8}9q<
> z?|XxHhG>SOhYt)t84(=G7?mDHjVX^+W6xmQ$IZtFCmbdgCVeIeQ(@CA(@$m~GkLSe
> zW~=7(=Dy6^%ug+NF6=EvEU_=8E=w(!tejeDU%j+Ch4aRd*J9WC*K;;bY}9XF*c{n%
> z+uGZX#`EKIcT{&;cCB`2_WTKSgr`JlVg<>FG(>hIlgU`1S2w`r1^^fv12P~Qpa<wE
> zH~=b;qS!|h6apYV_z73oQylz-zDXhVa~(?X;!)7&002So^rkrWgXRM1xJZ{D0AnAM
> zWPs=X0s1mOFv^d=+Sfho9YroUd-!_zID2 at C=$IcDv2t<0?&0qP96NIK$jPHePaZoa
> za_s0yr4uKQsDM!RCB?5jdrA4XyVFj+r1~38X|(?s@*toCQ0^ZTKYl4Gsi<hFslbDd
> zhK8D!o{pY=|72ifVParlW~8TQVq;=vVFeEcrUUG3tnB;r{!R9qgRN+(scBgm=o$8F
> z{O1mGEx=AsX+%3kMR6FQWT&8Fryw^15Ksy<ASeQl{qF7`6qHodG_-VJpP0Z39}WPN
> z6jW4{)Kp-9L6k-j3SI}O*=aZq9o44gG`&W5*o*7f-S}7ZqNm^2ahr9miXFH2zQ at 4G
> z!^_7nATA*(B`tG8Nm)fz?WE2bT|IpR!?WfVmKUu+_~>xm at rIML%S|6&zuW!+fkF4f
> z!XqLdL`5egCOv+V{PbB$MrKy_>zv%YH$}xIA4<#0KUUN?G&VK2w6=Zf?&<C8ANcz1
> zJ9d0xa%y^Jc5WWGw!X2swT<7|-RBD&pP$(Jg|pxB#SZdCNli^fO}Eb%1*QK!<LuNl
> zhmO*6Xq(bq^Wr>w>@Gdm>G)Ug>lj3jo2_!&dv`JNh at HTS<Mvtm!P&pY*uDP}XTLD^
> zD_`FMW-1DB at Tk}UC_p4+L`wnxV`pqPC#C?9=c*qQu1`c%Qx%J4WHK9T2&<i-2?rl~
> zz*LtD`0M<?A%kXBCELlmy)4|tcPxCuNyidxO;gq%4dufv`6|?!53Uv1=FdufMGtc;
> z--v!|_7!7u4-t;UnrDR}D|D at EH@L2v-Z+=T`{ibtkaX>&S(n9)`e><_lz*N7{xV20
> zq)ke-P{319N1P~ZaycDmY#BWKY)r}gW4Wc7&-afuL{o>T2ku7~E?K<E2nsky^=8Q-
> zFY)rF-CV+aIgUEC7w$KyLJ~I^E}G!mEOa4&ZkCu(sB6UKdoe at 1RVsA7c?Z{uXTt~B
> zpNB(U*chKN>_S-YkUlqgRYg<ZPY+r?vE+8WcKv8#cS+7eGu8J)$4 at e0HBH^Af-SIj
> z3+?-HFo at RtNK~C^^itSzVMuj|`s+oTj1-2BlO<}W|I)92d;OwSk%K=z?bN)O2IRM&
> zuMh6m9K`aamFFeBjf>S#6n);Oc*ZOJx$uVxVetXN<42KWf_{a2jlAL_i09mED{&ug
> zL`$Osf;Uhv+TXL%6Yt+!Q;N#x>cZfW&EpJ^?Q%k})l*{}H_u#>$!M=tEPkPhqe-sv
> zx?~zU3Pn+gOI^r?j41mDTg_Y=!Zin{e<R3a-A>|z*V11F at gkqNzGVKUHj%PD%8XAv
> z&pFekwYlSlHQ_zC-Suc at 9aW@3fjU7tKP|HBG-vnP{P`!hn<0u1w1my;wM&pSCyezw
> z42p(bzbxHgzMr-^2IsDJ5kbm- at kcrL2$mQaVhZ5l_uot+C(;go?h|-;Y5vP{UFS{f
> z0`{GNe9inG{U*c9;asNLhjh6vQ2cfN+sc4i0dd=vV}s-2M!~?9ytmIwT1CGXJsSwS
> z9Y1L&ZswLg2NMa=O_2(jok~%ilzmii_<n3!<8)2mz}xmmN19!6u&uFD<<So{G5pj{
> z^{dLzrTG<tEVev{WA&@Q*}!aQ^YO;?O%=(&ROetPeqHZ%@0A%BxE=(Fd8YA7;&kw}
> z$h>V->dK*{dHLj)j-h_Kaj(>g6TY3QZEY>wc#<T?n@?NsH`E|Y;!Tddp((ARihEC8
> z$$)3^w-8}|4~O==*tK(af`U@^9I(TE6`yaWyOoSAzTs-kO7H~uG!4hmN45p8rtYPo
> zU-*wQ-Z$DiAEFi`wv5wCs}4ezw6ydjHU+8KIWFF8mQktHIJYvl6g7TDSK~yHrOAuj
> z(Loj0N*LZ~0~$aOL~RAE`OJFtS5KT}nQBQtyM|<TnO42FW1u>dvL&R&@t~$}?=_{o
> zyy1A&nVT1HJL%HbrxcyEV5lX?cy(8Yzuy at e{#s(Hd+aaF at b8VAXg`=gI~F#PYB at w@
> z`tB3N`k6da*kY%OS&1V1M5@)e6M>6%baAxQBhn(4XVtF~F*!9$dc2pXp<dUD;l at Xj
> z0UE)WPsB2ULV0rt+bzV}?cEwqq;&QZm1!grXT>$ua6EE5b0;0>(&fg#BII(<!Du-<
> zh^QLwme@#K#M7*x`~C-%ra#Q1DF+Zss8ug at l{nu=@Q5{;`P%$(mt9o*Mp2;m#4L10
> ze_emWD$Awj+|h)mH<#TqzTXi*xw(}%c)(>ZJJeEf6Xnk)7?4KVj~2cyY_njMIqS^F
> zH9xB#$7QMu{B{1D%it+j$pz|j(ZN>OZ30*JY0|JT7vMmWGJ+8m(5Rs+RItd=RkIPO
> zJDPzEe2oMRV)no$?n($6E54h#KFTFd2I$RTBT+jOx?EP+$aMp&f)Hwc;ztrw-fT!<
> z<_sC2dW8~4S>tKQfMnmQ4XLFALI#Xp6;{#hbwF{79YWt6$iS^^k`&3A^!)MBC399i
> z6N$$`W&<1J(4xU|(CcmdONai=b?E1L&W#TSjgmYWNL*M=CqB51-nB)*$}Rt_l(%Jc
> zO&T$-Ka(bfXpMu7|Exbw>lZ-%p#twPhX?QDFcJ^y+n0fafj=p<qaseH<CCZ37K at 2%
> z$@t8j%w0dbq>`BKC+HkgV$xqq^M6BW_Q&b}tm5#$PQ=irOy2KNx;%At)Hh99`HKCw
> z>+fkFl3o{g)IsV;A0N3g^^s-AwB2QqKNlj}pUQgko>94HR$sV1BJ9hH_8|c|Q)5`=
> z`PZlZ3h({zhWD(nD+I1Gk_oCFv32M>8JP1U!m)o+7y^SJTC>SO6eKO+6&X0JhKQD&
> zdB|l73s3LRw)?QkMl#76D<dL<^hwD&c1FK1u?=9`PC<;rQq+qu+n-?L$Z6zUUyxb1
> z;#q6b3;nGN|N5{W_YzDz#g<9=(xorB&rpdbc4HXdTN<C`a^6N%-+6=UIqzP^JJ=PA
> z5H}&sn~Hb?(b0#Q>v>y`mfhbejea|6oY@`AcDCNw<qENGr*9VZL^~~Y<8==2dyWRn
> zxY;jrx~Gd}86R;NU%qe5n(<f2`9B$M*B5=vKdYXKJH=so1rZbCg at sWDoDKDF))MR1
> zIG)wAUFflFrqnva$R;;Z%Q-7MHu?auYNi+|3 at I-!S!E0VKn8@`BPXlNMbDRL7OBXd
> z)fbw8E!f?-mOAzh){>jC=eHL>F`cTNJoTCQ`c2GIF#6+7c)U5^iwXXgAc7)}m%!yP
> zF;XCh{(9SvVYRv#@n%meX`AECUP;lh_uJp;%1|k`@FD02mR3I~=Tx*ZiI1R}qmO*W
> zvqN;9n#V^zZu%w-J%hf8j75zX8q+y9dv6$RCO}^m>|_sxF6?xYfrw8;a1zYEnNP<n
> z6qA986Nm;!cn at U5($9pzdzlR2QW{8ywP0jGYX*;a)<Fi?ePqZ$y7^uv8EAua#Z9c}
> zO{~B={RzreOGn9ou9XEDsPjuF1N at n!gR)ys$v{T_8^l-zh781Zfvq8m`>hGkcIdeL
> z6l{GS;fvT2-90)KI{RyfUPJ#;f1u-{Q)B>a8MzZl(5=cRg_<lQ$$%I_PaRo(5Lt~-
> z8(sYdD`_Ee+nR&0r5{1KfyCcJeRm*57v_<Hdkav~aecy>5H#3ul?)sq0}sj`BQSYH
> zuzQop*%q(uOs{R!jQXE-pXKr1IYgIbA9U5$i3~J5gKd$?WB`*#f=okjJZq?(O=ty_
> z5KrV=*4l8_+9b^UL7Y%*5!wa0D^rm}VtPvk at Es5w`x+Sl8#WL?QIA-HqR!dYCj$x4
> zOre&Mhb<%M)RjN>|4+pI(=g at W5l<0~HlNTly`)((u%^G^P`=mgu3kx0N63(T$iN?-
> z|3g|(oS&baK9Op1ze`MwA?O0N-}A&T-8xfn5}hUs9lXEws`SzXEUMc`AiYvDa$}Au
> z)UXV*VD}1(#!C&f*dF$^MHsDmL@#N#N7&GoJw-Z2_3`3#Y`H>Cf0|zG&74o3{ni(W
> zvy#Z|PDl+kBZ^^$zRRv>Vn+#FK3K#9l>K|$^8JDU+UawOgQ6ZwOiG&DC!EFXg6x%r
> zv#f?k1aQcR5J#+m9~of4$LQlEVibp}dfXENq83UXOEMoj#!BB2sz;?-=U}xgBOU0s
> zSEhxL#S{^mU`&=qpHV}b1lHHl_U}bza-lDvqW#re%RyLOF7qGn0Z|R3cxewpIxLI~
> zEb4$0xO-ujSpR3G_!=!T5N|{VIG`Fh9nu+ZGQeem5s=D2GeJ}CRlANs2<awu9(%$Y
> zNTNbS)st#EtX5?X-fHV5-fjGa?PSc^E`oW^=x~LeZP<ljUC}YtoSSK~`848!y2`_k
> z2d3lNYfR&0lCl<)lBW at -nb7c~Un4|#=4wr0@#*Y{vFz_LRsAr=Do&a#$p;@`obR37
> zGY^j(1}3O^9&OGwg&@WegLGR+obJ%WK%Bl!k3%Pqys%UWj&Fm7F<-dah;s#2;t;Sc
> z|8nSBAX+?UWD%irLrZcJ at 8aDvol6EPO7@1)RJ+GG{MuxK-3848!>)5C&hv5;8iqnV
> z at jZdO$$mKhalcPa>W(<$3AWZY3pCav1hg0#={V+44SiqeR(9YqoJ8bVwiONianixp
> z0x&!W84%r#Sl2>77Iqp~Lru+)c($9;cV!^#(ABI;(EKDJ>PPUP9n#eqmn3l|BM9C(
> zq{F(9omCR3mz3aiLxb^=m*CvHtGEWu^*Fw;V>%rQ>a`u>=ZC+-agqT>BQ!}(pCG>y
> z1KqIDI*h;?`jdecDX at 9GJ}Cr>CIN^>SOXdOa-0m*ChtIcRi14Ua`(H1P=v0Q)yR>7
> zt_%1mG7v64N(KZo|Jch$1JM3yLBOj3bX*Y&T2Ov6FlIzR&L3>wC0PWf!#<&t)A2T=
> zJc!xckTYbUK4FCn#F>%-rr>c5k(=#7I^N6{G_Rka<6>ZGIvaTT4g|*wTBHqTGO#L6
> z(%)p+XH5fxnu2}C{0TGR)i at _obY!CmL0SQn&J+a40kVjR+y<Fq!^hweyR?Y^io}ul
> zC@#cI!yd>G9YL1>B~n2N42XE5&OTR2P~=u?>wm(>pA5j6Xy`hY2y#P3I!uC)?xvHd
> z(XFIcRUk|Hpv3cc0znb~o{K+||1T;)0WKj3HZpJuLk1{elZXo=pdMv{BDW+|fkOVB
> z?jZkc0N4*B33vp80Q^y#;>f^b9Z|wZd8EA;QFaFo<*kuR-+A+^c1DhmHaTq9ND#C=
> zwySh~5nI`y(4GG#bQ!H9*hDgLJNXBjDGJM_dVxYGC)4MyxW9T!f8TMvrDxY_J%S8y
> zYe}|()`Gq2_6)HAJ_#C{O{$Qy_-HbKXc;+y*#1y?p9~cDD{1KF$mgP~5%Kd_4fk3z
> z_!fr=X$0h2`($KvW_Z-GcLxopyjf4K<D=Vz6-|y4ud$?QE8(~IpoCL6X*~L^a at n|T
> zuz4A&{`oEcl(3>)59I at _{0}hJyVY>f`+=m&e9rCa1r$RguF-t!$yDWgVklP2hE=JR
> z$2IaLmRDM at V-&k#u-D(x#3U9?eP?E*vOxWk)di+arBzg<hHn`s#q at fb*3DhE2D`(Y
> zhdCvygTKmknB?^|4zX*9uW-%<+hqF+_E&j4?sUcY#^7Z1pLDu at C`*<)63`JUB$L`Q
> zp-Pa=kv)D+FxuKabv!{|=J*$Xwebozv4rReg3Sby5zkp~zEE=%ClQZ*Apx!SL3qa(
> z>Z at J|ys-tOYr|*>I^c31AELTSY--B66C#hoFJFg>FVzY7y;_R at Xl<stB0vVL*N-#L
> z(A*<w>hcbvhLDgG<IHFU*piY3%ypRf*?c4VY2ylCr}_Z6?4ZXoA;Oz3j--a7Rg>_g
> z=R~V-8#(2Vt%kGXA0unNXjX at GFKl6nx$Zi7_;fkbveg#s(n*a_dT`}~DOxpZ6e_eC
> z?uzf0gg7F&y`9zdjwffp-o_JIJUSG9!AOe#1S9qT3<tJBIMC^Vk9lTA*i9dXkPJw%
> z{*WLQND#>f{pTzA-{GAHI|#5HmUIo&GLOFi+y5e9OY|BZog3V-S_d)kAK at Yhw_mG~
> zftdU^YtUK94-9E1Iz at EB{0S0mJFl<l(nr8uCJjM8uoSfj5Y8uD>Lq^DfaVz3%p2Dr
> ztT)+M5p{Ys>T at de70b`YP~6||Khs#?ElvH`@YeHvSJ at v_e0PT;+*WvD2(;oVMJ0%P
> zoWJF5%0-LWA?BX5nZx|?4$W{r94cI7fFL?9B-)rFR~zV`;`gaT*prpv%F<Q(R#nk2
> zR=rn`$MPt_$1{?XVU<3MYgK!S?Ut(_EUGGq7+CFm?rXilq{K>;S9EBQ;m~IN9}*Md
> zexCmyp*;AB`Wouhq}`R+5W}nhCqv}QmC>Or*Z58@;mg%`B)?d6dWBudT1+;Rv4|Dz
> zP`O at F%~~H#82<6@<S^a~yB8B<0^n_6xS>|K(crxk3p#_M-X&RHBTA$XYySUyp2My9
> zo4=hG8ccsi2K->SF1TdVM3qk4k?yIjs+GMr;6gqcwfFLe-RSn{KxmY~%Gj24yoF2}
> zckCacBcN<9T@$mq-~hG#(ZN!h`rLTyqoy=w8Agc5er|f3ttoBsU-71T$v~t2XEHDY
> z5^U?df4M at x@jU;5E7VoKH?aQVKbo6==Xw4{yda(m{BO3zfj5Q#7R<|>yjHatI&Q)=
> zWKeV~8M<!y;o8Q#63CujsXW@<<a_it2VH!sxGsr5L^DTgC2vm)VVym$Y}21g0=?ii
> zZU|4≶d(oKDs*SVYZ1a7~O0@$D`Y6&C5PVjF*cK|9ee?8*AOt$?A!Bq`SgL}dD^
> zDJncov?ijZ#ag0lm9%!6>&hhT8&%v}Ty8uF$zETl7%d3;s&L}ddxcLqvZS at LiL&wF
> zXNU)vCFFDW?DWXMGaFoA=pvCb<D&-)zNJCy=xTe=Xt;(>Rshn#Q+e2Bz)&NwR^8Cd
> z(^H?0E at du0MjBHPs(JEJszt_f6|y*NLN!l!SSxcj<5hg>Im$=0nm0d7WK>Cx=PU`W
> zBF83KAP+TQPOR_Cjym`2EU9$Q<SZwOYm?R=!-DXT7Rai(`e-S}V|4;sCC!mOJc5s#
> zO81;eq*kpX1EsI4G#VbPEpkp3Si*|>h^;&A12NvI)oTN9KUT`ahEVwQg5Ks^%5+z}
> zV0TkymdL=K;e0~n9O=*(4b at oh{MUFmzcSk?Ne)Q+fKcGxEqKpB4eSL at Z%Ntr=xj=e
> z81eQg*_k&1QBQQ|7|;p(5rd at s@fuTJ=bq;~iv3p5j3X_H>u}MWIio-58SIC-|6vh+
> z8{tq&{wWx-zXTkI{P*kGUm=?R;SfzCq9gVZ{4rsM4E#QJ7J?}CUsB at we3)R-Yb4z|
> z{QB|{f_5Y=62Fhn_R>MWu?=*weiOseT>!ULq>?P=Nuj=@gP*rji$1O^g!nt;$KqH<
> zBi~v=*SHKu3xd<b5M!^kG~T7C68u56X|Uelr^xPF7B6}Z8Tn4Kf4|W3Npqo$t>v4o
> zm5YylA0p8S&fCPCP*R}a9Ml2^Ep8E$Givnk*Y<7_Sn$t-Szquz$Xbm+D^R+Oi0GEC
> z^TkCePjCvZ(vGzV$u7_&sqQ%HVNTQ0X{w>#)H}Sx=lYnYB&<0Nj`?Uv97`{0=ry-H
> zSFEdKD3X{~&34nz??v4o(zVVkTdp4O+53n}BZ<So6^putyJ~Ah3|IYd<URj)-xr6B
> zH@|o+S2WW<AOi!ZGe_Pv+UH^?Ixe1-t^6|83_kNLyt}H`>h at wNr!L$S-$P<_api6-
> zB~joV{Z6XzY*&yn-rtX%d}_}U-xIG`5VBqX#vwufz&Z3%rArb1c*BLnwSz(j+hw$h
> zt6rwVwH~kG)6_mWS4w{jQe1zJdy3)kKFMbI5uBZh>$mln_c#RhBX2KaP=hvGX;tMM
> z9k{cbf(k>rnP2tF+cY@<_3dd82mF4#*I^HKLdifRv;mCYX(W%2m?N<N`RJt4&k@)C
> zP#*fPFzNqZnDoB`8>kSzw$aU<zcMyCIkSeEISn0D-%5#gjEBqI6i=FT?~!{77iqX}
> ztNeT~5Z?2|3hs!Bd+X-~Cb+?c-dhmHqYiH7M?U!I6I71?BLtH%kujHbf_hSR^!Ee8
> zFDqnmIrY$0bBNGa3>W+)J`~##G<wL+SlH#(^wRn at LX*SN8Zv0_J{GZ*y{bO$H*_)t
> zF6u$&+KqMS2|1H@^SV79`{(k;84Zf^qb<X8c3X7OMeR0cxy?e;kT|X9auc_n3yBN(
> zB_z%%`jONL$b#Hl4r5$|6*Z)y)@#YEFi=t>EmF|xOZvr=f57kmN>Y{#|K%h?j-b=>
> z^c at a;M{ipAa*)*wYU$9PUqCRnW0MSoY4K$vV>KN4k6xLV8{8l&?a+xM1`Kl4ELG|F
> z#qP;AgE=LbK^~VCKSWqMqo2wFT~TX%Vxw}xl9Om;Y3a2=sBHN*FlIHS>^bAasJc*x
> zYFEv9=y=wI?S4?f)L<Lp8GckCAV%ic6JEuj0>QmNMWxYYbrV5?F0QOGoxcr*pJ)t1
> zMk(ppU$n_P7QYto5MUBm^Lzs=G#g4rw+*L}N;nMLrW4RI`4{~prj!RmFXO{+Zpw6Y
> zdb`!2Onut0feUNV43hksbX-XnZ)pF)4*o8cb+Bwo|Fvq1d#~yFiSmy#n((TDz}3BR
> zr#Lt-zEjhuwnn;_pp=_;@H+#OzN%o at 6Nyh}YuedL*_7%`6Ym{6r4>>5_;OD|(m`WC
> zy(HJ(Y$a90*QKsL+oD_E#E%3uobp-=h>19OO;$bPvKucBP()vvH at nI#t#+ifCCmN%
> zvT~Xi43YILmctN}+k}w3)++NA8}xWylWoj((_>4C_)c+INnR97*JONU=)__vNf0MA
> zwD%QF;U;-|a(OncMQw*+>gX<t*{e8T3X4NpWhC!_;BYUUCLjXGEgIGisoIF$uv$x=
> zC9Q9kXx%&&Fxkh~Kj9?va^?}+*>}|GO?P2A67c5nieo|2_f;3p^RJw{>$<v4VzdFX
> ziUzRIy#q^#jS3RlGyji;HHt{|q#5W0Au$>kz%@+}-Nd=x94&>a$4tL`Irhqo>;8af
> z0oMhpvQopLzy*x8yJ1E&B^c-bPbJdQd5mcqZlJkFuSgG8G(Aek3qWRN%kMWQ#?;n0
> zgszy{nP%#XC6`fZOxnCx-7PQ{`q0`7p8#W?3%0&E?nBhcKE(E2N=MaOCgBHO7{LZD
> z30<I?->Wh|QI at x!>Xb7DbH;OCcDX2WX`*Kh)rq30^Hg*YgThu(m2e?_DT4sfG%}zK
> z^Lo_(d}t5GQ&gp-q+kPa!Mo44F*~V_S6kObg?sxn1z^G-S3O;yl^s}&kz?q6fgbLF
> zXWw&co>}$a=!v~q@(^=0^4ypLINL_S+2)J)$2R>s+pa&0o-n;JoHK`PRg)!E=xSP?
> zr)V}5iN+xYWw#nqjD}%YNd3d}y7yFEVH^SXx{cqqWLgg%SxOUXDW{7j<PNXDsG?}0
> zyAPvj(r}eA3kW&b=b<oSM8HhjDdV`iQr~?H?sJ~`wq at sv9=ctlhL4%>h|)Tq2*b5J
> z*o1K0jBR{dX67h5i4y>LlqRtj6a%pdCftdYnnY)@#KaD9xYfnC^TwatN_UG_cl+io
> zpQla^hT3J!B-XDFOmT6XKNiF)E%mnj-aoNORAnBYk^~+2YM0`qrE+eoN1ylVSrvlU
> zd>9U(8;8Zg`2(7iP*edqW~-eU^a}m!5Cu=x(?<NC4AOo~xO&q*&p_db!WaAVO{~Y}
> zgo|GFS#$HS6xSPN`pdkFQ+s~+;Bn(kWSEvj%eApl0pn72*GY9>;_36W$A%gXExz>(
> zsN)An;d)II!>Q}Aws-clr}!YjRFBl*dgzN_Qk3H0;ecgdL>Pp}&kbi_HqZb+RG#cL
> z;+f~FF5Hr#romZ~%H1+Qq}W{eHZ!tW)2^Ec*-0<=bb63bpo;aO%f~yGeS&4~VFqNR
> zA6&{C^1*QJ5><(@QW?>}{wc#C^thFO at 8g`2?6LHuiCE&$z+~jovpxF`&1KYTBKG|2
> zar&(N0gmXleLLy7)!(k}H03WmCdjx}96KIiquuw0$a`^5SOSrbEsB*z+3qS7Z0Q%l
> zyCG#(ku`#&FuV>n`VzjO*));6Gou4-(gS<sZAJ8r_IYf6$1B0$Fj}a}2glny$`Rru
> zfu2CJ&ufYG at kd>D&-$d_Hhuz-b8V~7r9$zGr75cV6o(7?jdkyvS~O#4Kn(vg<Gst)
> znukkwwxKEIF)>HKRqHP~I{QX{Lp)!<_Cr-LlHoI`PtsB->Yd<dL)Erf)vTWx|C<2*
> z at OQ@jnAav)Np*rkPm@;KI{>4)Ih_#g?@*~pg`H_!5h5tys;sx~YMA8V5f`p_9B8XJ
> zc!%}25&Ngsns!!od$c3^#^@lT0mkETD+Dspx}+gAF-Muj5%~07ALRAn8`Elra|eY3
> zzMuDkg+uGL>*#Vd=g)Y*Wh|!5flAj2PYeYOe7T-#81wnYM<Hy#qDS(LP%Boi+v-xe
> z)k!GU_rW2R$9G at jpwSyp+5k2)oJzD`j1bf5cVVCXf^TEZl!P?fB=69Pjj<Y_TG+mG
> zZsBnrv71I1X2N06WYnc`%1 at P+d_`WUv0J>)f7j&J0sOp0LOyN<30EbY$3Gu~G2uO$
> z;j&fz8=;gUPdwi-ihDg0Pa5MFV>~_8Rx5ZlF<r7vEWr?C=Q=#js#*|(ENZZ0cePs~
> zQEUvEj_XMZR>!e!VBKKfJ^F4{tH{~f+1kx>+71t085%x2HI)*`)Vdh-#Gy^HHwBe=
> zhoV+E)yxz|J?J#ek?6j7QZUx3KPffMMJmhSpJmG27VS?uN(D^J8R}A%e>_xlgiTcB
> z_QtLi=tNK<T#?b~G#-nKS9 at ViH7uvu37T&@J9E>XtX(Y;^FGCYC2`H$I0U6VbxKtv
> z*y;uo<UzfqrBp}Lj?hQAV^rNmOK0O|qq5C6(Cn3aWB^h{gTvH9289pw-iFoZ6SFgi
> zuG(Ez6XMtNSIjKb-V(XH%xGvAD4N%Vkb_g>Fwt;9f=M^w+8FU-sHELH#8CUgwTkUH
> zZGvg(5sOLTAOX@{=nc$w70?-g)Nm1tzUpV=(dR9U{q^J+q8^N2BHG)tve`3&YjE*u
> z8BfDeyXLY=(@;!LJ1JtUQ$6Q7eBwZot73&+8eG4}!koQ~(kIPjb1P@|?vFK$n=7^s
> zf6J?<{|@)p!l1a56H4Py0kkt)<S1no6%jQdWSrIOM7O7|Tg<qfTrit!@~Nh<QEFR5
> z7<|`5%=Crafih?fO2)sz518vCPj!8LB<4j1<X_j(Tss}8!6PQM5KkZl%(Q69;v;d#
> zO>s`Key$H;wpF2PMv_c?GYkS7XZTea0e(;k$5nG;t|h~#AHLAv7G1A7G4Uqw>~1yF
> z+2Xy-g_)`Cblng)Vi8G!U|Un!v-H7GgKca}98q+_HR0`C;#!9)<Jx=b>nwS-I~1L8
> zefy>&f9cNUr%*fToU{_*O9_TzlLHf~?Ql_E^Y0g*C$5u9plR#OJ=}4*^Y$`oMwpGI
> zHAc+<!C2pn=&6r&x24s@(n^v{4gMkW(nnQ;DBz0&)mnBN%Ofs92NA$UD#ugnEuMGJ
> zF2n*a8|apky%*3>=W<u!{+rHrQSI*|W=v=F#iTx6Pfxm at xaYR&I)S-UqZ*<qFnZtb
> zushb0)YY{N*nE~05h}c&yWuBpk}GnTfVsZZ9MI`nyvmELvRNG*cYiTHN;_XBp!dPv
> zNAUeS#<|oIZ>mRKWqw!nulT?m8wd_jwT9+zhUT_{Q6_6pZLFPE(^P^*zKU70Q-z($
> z##d5y*K-$U?W;j?k44l_&k#<K?~v2 at omEFaqa!JZ=tWBX!a22r1w(OS=a)FWwU<65
> z=W=g^nMEKynYA@;pl{WW&)K`kl)M<n%o2DM;uOMMyOK|c7t42<Moh#>k4;(`ev#)g
> zJw@{`p6r#6uhRLzXh=iQ5(_kw)&boy4~BU*I%Jih`?my1N at L~EVj2@&gEZ!7Ry}%D
> znIF+%KjkKD(>B<u+{ReexF}(H%O7hWt#soyRF`^S{WuOeem)=Px)qI6iQ9x7J!n=b
> z at 8UiKy-{X%kuUOfFBQ_PB~OfCb<oL!Ds1ZloUpNBdwFN&L8_r#8D*Z??YxT%9SW$8
> zkJH{9oh at F6;)2%TCEbS2!OX1E$5Uii8+P(a>!YRh*!aX|(n5m(O=s#taqfal=M?mV
> z5N(g_S%LF8g*T6t_LlT4rHwmjwLX)ai{7O&AR^H&LhgNzMR?P~GY_}nqke8TNL6pU
> zMOmwB3oH1TjS*OL?+s&;zB{j6(>UVpS#vN4!DCIo<AhZ|VzmMGK~W8FgWP*|0!=am
> zv#lZoh<S+F<aC1cenBC6QSdYAE*L$!^O+Dgy6L0}W;j@<<H1+uI||XeJtRKYEwE9B
> z9bz at B8%z|EK;o~Vz9*BSz({R<BA9+MnF4+11Kp)dCs8S`v2D7l{MG({RDOvhK98+T
> zYInTdSIGno{nvts$qvX at wR9pCn3Mn{@6hdjcn;>4$eR$r426(qx}lQ!q*iDNJj(IJ
> zb~<B-_6e^v-LS3gICu<mT+1r=*vZ$CZ=HjBckMo8&kHEzus4=|e_W|8cioSMkCF|G
> zw~`R0h<Zh^_C~&OUDxN4m21KxkY_=Uhr at MU&ywpl-TOIRZ$bG>S5mxhf4_Y|znxWi
> zn=WpLWbx_bJ+{Lsx1|j;x0AO-i5X7#kE<79^Z^+=g<2x`o7^_ZkBhdqvS^G_$p9xU
> z4XoyDf}y?Za==>GRFp$nc at yF&lm;$2pH7DcGaQ)l>*o^?GR-prVeF+eP5D=i`GwZ1
> z?jWKpV%bwjNgEyqtQWKn_H5c}&8rt^Z4E2PJL!CMeAs*Jh*sDE{SWY&x at Ri`?`k?T
> zx3M{IW-)W=tUf!_<#gxWH>I5k1NyrmRh{YC+_n-!C)dp>ePB0UU}{_nTK*(&_s^4g
> zo&J{0`vU*!_sP6JR!g;0Vw8L{D38x0l`9kkdHj8xijA#GtsO^yh^2Q9r{>#B5rP}X
> z&U!}S-|eP7E&xB@^!W)x*|(b>IxH7UdZn96cg1}$v#81qBwo^gi6-xxzIfNF!o8Ul
> zT||Mp>Pq5d)8Re8rJZFqyacL6CmsKW#Dy691m at 5@TKI-!zR_)UDKNC<i_ZPyA7$U3
> zsF_&rjwXU>K9M&GzGUE4F;<_%j6(0QBJsCTEhf7Mwf@$49^H3qkaTxyo12t1gWh0L
> zEGMjIpmm_w?`R?D>@7T)I&@!lg`|^763WN*kRmYQ5d5(k&?cOO{@jpmHxYz`U*y1N
> zcK&P6oFxO6#U8tK$wQF&^TA-QP0=0_b5eHW_#dC~hi(urcA#g4VV;OQwG|@e=VhqI
> zEb0s9_gsNb_ygygHp-yg3Jk6L|1qOrN>Y42R+|izKL(Sy4qLc^aq at 5Y=}gHcC?m4R
> zY=2zOLi?`#PzV-Jy&y6$%>(n=S<ww$S0QlbOx$8TmnMO?GbzmsB)ZA+%xux&TW+xu
> zgR!3{_EN&XK?>gGCNodRkA&4s6edSrF|-=1Ya@<MhxDvg8lD`8^E-HiiMz+nxEy>1
> z7>}HH?VrFS6u(<Mjq}0SRWA%{agf at zl<;0S<-LnI%asU4xtt#BZ=B~VQuLXxKfHTr
> zT)WGrI=C0XcA%Z@(U_B(I}yKyf>AVV3UMzvIQbCI?8 at Mj)x*j;)ZCR>Q~L}*VTx}K
> zo4g1S8p}Ie8T+)g4g~dIg&Du3(T~@ssrRNp?lvB0mZ0mdE<Ux24;O6=<lee`(R>m4
> zdZGrpI}gY8;e$F7q>7YhfW)4GU90x=(&Qy7m3qXz(i*1KruFammB!U0YzOa3yl`v{
> ztbS25?!PyAHF|e$s%Jxy>E_AOe9uzr8|lv5{)uhdha;3E^d-Ogz&azF5m70~rqS=_
> zjWt^6V{hhp)!yIJNp!oFdFyB}_Z25%MoTq}=f;X+?HkYAsms;8K6qFYNijg~V7B4+
> zY at 6)ief%-C#?c}kCEqraR&_6!bfVjv?p<wG2AcO4$<Q5)KxNX!a`<4hssZ7WyRuQb
> zuFl^jP~(sTHgiF=iFpetu>~LGPwY9BKf at GB81CBF-06lotbEtE`EdDG4VP=YXy|C!
> zu+3#OO7_Hq29&34VFVQ?3~w=1&54K~4F7yIAbrd%3B(4^3GwU3+?(lyBLhoDop7EB
> z(zG#{ew5&Xz($~N!gj?$$ieud#1*wicWi(5fhm9BU(qt+<xc1<PY#JfaZSr8qo(Bd
> zm?iU%pkz at H^EVK4pJ)vxivQLAe@=c`;D8(?=GGmo;VosDM6%CCLUxYpZ?QUo)*8&s
> ztQ99|lL~HtsiaIG5(Oa%M8XtiI6qp%wgk!e-l4ftk2+v17`l%_+(&gI^d0bwtMWEF
> z{k}rpZi-jBKd|tcKa8$^{mT8zxiCK(!QY|~cda~Bhv22R#k}DpO=%s1A*zG_gjw3h
> zX3ad=N7$>Z^rH98^e93Ol#3Jsxw9C$(x5Nu>6MUoGfSLaIIFRZ5o(;{UdO}=OKp11
> z<GN5iO!(#E;Uq#~&|28!d!_9+92cG}B*NNx>o8G4sCwvk$p&Hd?vS?YJ%y3q3*t+O
> zufIjV#X)S_YB73WgRM4tUf$gGf1tsg?fPA}wzB(!tikf)3|*9cJXI!}eU<>R=U#DH
> zT>VKup&1rUEB#$acbbrwV6hxkw&h5+=6*@Y!yu`QnlD6V85Qrh!1B$rjRTtxp$#O?
> zKEEY9tlNnK<xfVH-$uiurTU(IC310^OG_2rSbUT%&h1~Mb(mO=aL$ACgown{j&Sx0
> zvq1t9hKt3{Q>VB+F$iqQEM?4r3&yg;!p(khM?TD@^O3~n(L88p6lcJS<vRNZ*`od@
> z%RXDKe&W|21i773-INPTFnQ{vMA&Tn*jp at kJqO|E!aX%Qjgaw*WXGtqe99)a&VdCp
> z<yncbTYQ3Mrn(`xwQIUkbraO7>loB2x`Lat|InhmIg<1uLE%VJiIKTP^sdc6^lu7A
> zf4Cc|1o;+XdkPHPXfcp2n0Pdy;uYv;xTDuJomZ#b!~?K52Jm3ca$AyBfBFxPhsXgc
> zVz@*y_=+3cQ^Er8MQ<2kNL)Ye(1*A>jo4s=5@=zQR)2?<lXXK~K(MK_2L|@L6rp%C
> z7X%?u|Az%5182Y#U+lgEwPySa-lq6H-u~+jKlvU1opL~QDXMMbgr6aa(uEF}i3w2W
> zVLFp1%iw6}M~O!qkKmy_I0MzaJB${z_$=0LkCNduB7p12VaJANZ!M=HQeb1C2~sn)
> zTG`keK7J+rT<>C`Z^2orQdgta6#h)D*n(EAzB91`>w?y|o#Lg=Ds*48H=D#QrNU1n
> znTeS-#a&7Wos-JA!zh)Lk^D%CDs?ikXLa70BFV}N%N8-Bg(G6`*V!@Q6r+aEe}fqJ
> zOr}X;_RJ_g1jQAMRDZ&3NfL7uUvdl*<SH*=f*<;rgrirUl+#w`IzIjMX=CoJT|DTj
> zXGgT*@DD~F@*4)~qT3)cT`=n(TKjAQ`@_#Z_ruTr!@`-lM|b=;3un$>E8oBQ%AcD}
> zj3fg$Rj&m?u(!ewI8EZfeZEA>p+v*U%L$`DnIy=3rw6!@et at om+aA`!xtHLw#20X7
> z{NZ|=QO=O#IJYP12PABAZwXBEwd5Nz_?d3jqIjU5Ua{MlYR`)emKjTC3W^;{J8ABc
> zbTBpr>vvvo7gWcg5>s7!A4UeqKpfh7W92@$TZo{)>NC;#a01O at U_IaUY505bxcX-w
> z<T2jOi&W6X$IM6cT-&8}4yd+FS$CmMnw#G*wmFD>ujIMuV3t}SRhcu5Fh{V3c)TPS
> z;MKrfqJ#JwlS8u=)fpIfn-$3$4<nuQm}AwCr7X$f21yJJxCmD^L01H=QgG%Li#Ejk
> z3)Q<FNnOeSD|81Rhl6Undr&dw9uvQ~q1wU-I-`jByILG0_wFJQd^a_XxU||FC^)DP
> zA?{I<>>^Jh68XisOzqk>D6T*oJp^Z=EO3^9$QC<^@;$AGncp-Uzc$a&V?|+Bw-0go
> z%gL79IDF2VR!!^i4!CI0Na54QO=t<C?<!;-@^1APJ!oKwxc<R><ND(V;CFep_;Bls
> zU5<GEf%($SU|}{+C(}=B^H0<AJ(RbgDkM3AF%Hr+8drgd(=e4-SZG6d-LeU~e41fx
> z%w+2Vhi04DWP-`_?)W>IgD8|F-C7oE#(MLOWuA1$a9JMVSyZD1>Y}C0*){j29q{8)
> zm!8sajb*=M_g7KF06{)G1J|$~kt3?Oj=jNv<8>r)+?h9D5sTF)jqaqfUQTio3Qp;M
> zA>ErS$35zpuatc{+t9ntcFVf>VMa~PJ7P52r9-d7sSIxw6c5?i?Y|{IiqkJ=h8~bv
> z*<Zm7)3kW^V}2NtAxii9<wP(f at H5`-yQ1>E`rXg^X3M>q^Ct`59~M<I at N3i$^4B6t
> z2L4^408DWax at X$J)Cz8zx-NAeD*52VfaEOCWXgIv4+#SiATZ^$1&^mkq{+YQ$(*(+
> z|JkmvJDP4DexIK-k(b{Yn at p@A1FfB<+RsdpO6N4jtFVe|8rIQf^mVFrbN5ruu78_6
> zl3A)MTCO>pap&XwC at owLA2Wt&sTOUqgA99aMLKRqCEoJyZ`Xg$w50~T(@d2On%Om8
> zg~s?QLP8|JfV(Lx;{!A1`=fkZB?2iTWg3d5KfPP59ayX2yGK9IstbRMs8g*u_Swy6
> z9CB~Bx=ne_y)Oh>y{5yG??q3S%3gGeE-R-Wtv#lJ!{Q*8xx{Zv;J&6YlGFSMA5Lr)
> zkIC(YPZ?K%;Eiq_YWq$)$kO>WbJcsbI>_To)D8vkj{cU7gU0UQ+lO=i at YT(4(l_WD
> zV5=9P!fj*V2W+$!^opN0<>GTpW6n|7Bm(U{UPIimhqe-h7FI9E&B&=yPeQDTx?twT
> zi-iuACS-UTFYBP(MsVf!sQ at COO&}4BzRzrKsu3z~xvOei2QzVD_i>%_{T)ui at rH=>
> zam4X}#JDG-C-V- at QD>l4 at b5um9ul}piF-%%Hdu(>)!FhQz91Olw#W15w#+&*@%qLA
> zqjvqLSSIhM>hkirJY}W3HHo_mJ9#?cvrG#kgWx*~F2^VgfJnC{JwZDm!*>1aM!!Mp
> zYgo!kBQ(#dU(-UJaG(t?qsX?`zal82^+0x^T<1`nV>G;HECPjT-7BQRKDdD&SVBay
> zz|ya~6BO`jtLs?aJ7Zs}*szuIGGeESZHs6tK595-ClT5WXZUM1fjPSj_EWV0+f8mu
> zZSc(<hHIYK|4_j9<tzHE<THqK*H$-j%`N7d^kg%-7)ng<8tJ+^TstCFo1GB at JmtD-
> z)}?#r9ODsb=Zsnj8a}QP)2p16v5eMI?-=gt(a3XMqOQ%P>V6U}M|}&}BrLR&WJ5&p
> zfw<s0Z|53~FY<l{jn}P5GQz4$98ymlXFhh|e9)4{q`>C0gY0Rpj9aI;5`6A>UHKY)
> zVqUx1t0I&?r+04r>RfMh5==jjun7MG?uR2)ukw!Lx>lAEA3~IZ_&01F?PZGJq&dU~
> z$$g at 46%^+4be$>w8f3LX29_kpf)%5o#VQX7M>RZO7$4fRLmp>KQ7_*)Cp`H6-EPFp
> zOH{2it++^G_sLiX;Xb?y*W{PaI74&1_?xvg=<^VxvGh&EK{^w>rRBtwTOXmY#+W%H
> zT6Wr`LtkX4<&~)97s}&=g)K6$C5VqDNf2X7mROf>gI`f%ff;5`JrK_rH?W!I-eTL9
> zUESM5FQ!Hl>4<kj48<dnguqvUk-W;KWnPk3?fox8ci3g;@#=iD)1FpEPhyEyb?r8h
> z9OexhZ?bvU&Ku#P^_S!ye|e&Gbx2r$$|m>Q1=r4v;Et}BotpU{%N`Z6`gFh-^m2|t
> zUl%ijd+7v3CVzbI>38417^7-!f<wTh03*cYE<utE*bAXZ$*_SouWdp!><v`>@3${A
> zgWH$WGUWiO+YI~~!m03*Pw(BR%dEcG*fifLPdN49&h>;w8mjq#*N=yzqustiu9Dgi
> zMN``?9)iY&u4}fS1IOYUb0;OdUCmHQO^=~8ypmOK8{&I_PEvF`vObM{b>LnViz61z
> zIGf at g{_0z<f!yLN27xhFuc5Tb$+XFoDJ_-|l^!iFQimPKs={- at n<qYV+2ol+=Xj~z
> zpO`OqUfT1d1%RMC6#Cpmnub6c!AjP*C^dN)%p{&@QZJ~eBURU8)SFP1ZW|ON^8I+K
> znHy{w`RRpjsCfM5_z(JFKCx>DROm-<!@i at 3A&(DQ?PackdM;ALd6NwI!YzK(0+sn*
> ztMPtS(+`LWsEoB#5z`@M)VBVVULR?ekmsDyD);}jeZ&%M88vmmP at o8WjAe?8T|n0O
> z)Bd<=p{7!chv;x0tM3<{i)Ex8ZSC-nyAzk%CoR988vV(_zH9!PSNH1;jVCh=4;D?5
> z(2-PVe7|>qZ3t$Qkv5o_af`0V%%^xW7v886is}C-%ppG?yip$g*1<I`)CIe#$M?`R
> zzo>`$EN!h?!R%tK+Mty~7;9gFoQ8ei*Q)Vs%X}?SVkN<Qgr0bJlSQUqNBGtFi_`KF
> znmN;#&O5$%Kg2gKg;>ajvuSBGlsy)tnx}zhg8F6rVLNeLzkZZ4;;^i(#4_m=TVR$!
> zQaqTnd2n+Z_4#&Nvp#B~4b`MN!Lx9~2WcRNW<ocT3~=g41KzG>d1P@!?-h~(9%V3#
> z4++)aeHgirpnt`x8&Zs1Tp2e(qPbxvMNixy^(S4McejcF4>7 at Usq%(%wVvuulCg|C
> z-CR#DUsSzdFm;DMQ|^2K6=8Q^<HMdth-6O<E2)jdz3Nt7a&+EwkYO`0lkfO&Ig2dE
> z$uTU&hBnN$o}bxA&U`DKS_ux<ANGVW>!>uNT?wi;345acSpPaqWIBBn9c}m+g5{fw
> z>0z3brAJDAZ4>fxIn(wgs+|<GbZ0jYM1yJ>eBsR-`U^m3K#tXNiE~dj4ZW^dh3KvW
> zTV(d>l$`T2M{Ri?7-xWnQ`Y9-ua=V%)HTYh`!<({;y*IE!b$r!*I6k4GhCV=f)B;{
> z*Ky9)sI5-DE{r%_I&k)`!qTM~7UrR2M>JNw=2?PX9J(;9=PFYo-FH81JSCL>aS+#n
> zx$nGwilQ%OhH48*OeN at pTZJv}8&{{;+WbHE-aD?TZCe{g5m78rDbge=A_5AcAR;9;
> zKtzaisZl@?Pys<YSqchDiy%c2h%^By5ouB*T|kJ^MOs2{l2FtArk--oaeMaO-}gK3
> zd++^z=MP~qldQE|nRAXYo-v+h)Wkng{&?r^i;XdQ7Yw$BN{`xY6;TQHq16X%5Ug$#
> zSH?{_uRNsc+fzbU3 at NC<w32(v%7=8 at FbaWB<!rf9F8i+4Y(NZL!;Qyk*u8akmwzu9
> zZ18sXDhba+Vg at PSlJZ3aoS$haLp-Cd23?7^HB4tJXX7OOO=;iv)luYqiSTHp4 at dY$
> zSx016G3<?i8owUe$*wt8#<euI4Ck3XG8O2$?)hzjOBTIr#CLz=$h$*5EEr~+PdLv~
> z2WI`M69HCFcvK~Lq$JKW&0^@FedN<?2as$n_|ql+6;W82yW1s=n`-cJ|J9)0sfz at u
> z>YMt<@ntg<ty!O9BG%`Qmf%|T<3d?7tAX^ZH~7gtOg>oS8!yBPtn5?HxV)pfRHsb`
> zhso%>qYC|=T(%qh(;9skvG`s1;S8TeU5YKy{y}YVi<;P1)<-b}bVL&%w8P3Qe?7Ew
> zXudNn#yDyq8xRA?u&9w7_t&Ko-u2Txa%`?trYzb at zJDxucS7KdZpJYsQL!V?vzI-K
> zpP4zUJl4nHdD^>NwGDskG&opANYB#c{-oDYiQQDS)lZeGF??J>j+1(;<@}><2YYVZ
> z%gaLwIb1~?-QnHf0y}xaWalh}jMby6FeIs_)x|3x8?&@-NOp~fT_$)8E99J;3B1q!
> ziOcu)tIRzoIh9FxUm{v0HI6u<EYs;z@}&u#u{6&`j)2S5G^CCAyfMA`75B-b<l=@G
> zmpQnLWIyR>_+MGw`v-IU7jA|0hH6oR8<qi@=O&Skcla*Bc&YVd86u$p%Z*H<ww%$%
> ztrNMaXyF{S at G-z68a=#2ue&)RNx2ohj(LYFLc-pIi`=R>MA|KP at S34|cy`0{E1j1`
> zcW{%-$U?Bw$KUV9PWh*r+<5F3c1LlMd(Mp<)In;Ty-AWemn(qUKKZyfJEfV|J>Zg2
> z!C5uGI)nRSM@~(z!G)9Bgj2(7n{yQ%BTezX?*2>+fjV*Dg%-Qx&QwF!i at f-mTNr#K
> zbLuw7x@|*sYEx1!CwXeQZo|M_9YyoSPz at 3B`-*rDq&yBz$yWMMZFJkax)F`!q^#oF
> zVV^}-js%j#LTxE>q at sjRUh1b&=RaE9uF705e=tonN2sl9-O&-{MpQH?KYV~Emw at dR
> zzJaRl6&9~z$to~A{+_W<FiJ!H9$B2gu)(K&*(77JMYy}6eNe{2!YlT`<%d_qjn^0(
> zfv#a(=-_uu6{L`qjZ=1moW=l19Ux4|L-#XB#tvTFuXNukYI4Yewl^<0#X(GrT>mmW
> z*}>z)u_ulJpoP$Jfde*{?#356;18TGZ>@<FOu^fR85skXf=#q>?86JN^T1bp^}6m|
> z>Yv%%{_ at 3#rz$rp6kg=yk&)Vb1ZJ63L|&bfVF-CilG*|@se#o#{=xUr`!<9{>fQ*D
> z(ba9xYq_s~cP?S$$$<`!lN|m{7p`};S$JM>sWTNo$kvWHoG=~%`E{6HBlg*tmt{?0
> z>cfC&)L=!&Bw<XhPIxPh2nkJFi}lRPDpWcn6LaTtCM*?pNL3p$S&NN=IgYGLU}uT)
> z6EAqvRUt(QK35d7QO?pqm}uPi{D6tC_odaFnUpB#!9@>#+Qn0Ad_=>-K+T^|+d}D8
> zYSYIjmBoulTbkj+1?{m*^rsFgU+f3e at OdPC4gS%j?O*(qDe3dI_=uz(l!hd`ohSBZ
> z at e{YRCc-U+cqf}Gkp*ybc4{G`+=(U7O>Z+!>Ly9V3K at -_coVQeeK-)+H2t{zIpQ$<
> zz$$J^YsI_=36PWFq at j&>_CIc(Ax_>DYHHd)bZkPh^n)=S3hFJDj>%NZNniZT4xUrr
> zZX2J4+PvbR^Ys(^`f4B0t1&}3?|!BO*AL at go<X&7&s`;zP#`AXQBrJ*P<T;ZPM;-5
> z at kt$H3pb3-r=!q2OfICg0OfLjw4XsWXN26*>}K!x3O4sVax6Kk-%3CY`AkL`@kklh
> zT5+!KI5D#w=`qwFN5ej*mWM>UJoVAZdCrIe5!Qw%JzWVt(^2l>WIg?;^(O}!kQ%Em
> zd%E%YsG1pM2%<zFbUp4S|4=X!!Rcgv|ER3(^JeKt&A}H<dv|06 at C9rjm64BYlk&Hv
> zZW*2R9P{FNI%}n>rZzqYV$8A9W#`#s#?~pH;2?L*Bb2avhr8 at WWIEM^Xl8rB#lR`D
> z>*?}#cTSNvw`G={wcFiWcb*E=X?JJrI*PpKamLBv*6Vs<y7U1K*cH>%3ujLe(D#?J
> zIC$Rb-<v{xr0MAfwM at QpPo1V0(98D{nPP^)MwwdHxNJ231=q#H9BY9ho4HJP{@kO#
> zhem&T4P0+?Z9Pf!*wsJL{c>NR(Zmf-?O7vR4?j7E4!VK8ftsD_C?-k18Xg?T7JsD>
> z;CppjpJUDu56j)d%93j at AN?qQnFAhtq8pRt1=Ys~J<2h&bcnAEudVjAKf&)MVQ^*-
> zcVqy9K9LLQ3&+$P+*hnDC|RX;6otW;4Bb6wLt#InoVoBo{JFmKEX#h=18-yPfYVwO
> zzRlQkvG_wHenG)+=v{&fO at 1ab6VvD`BvddtcCB}wfPf3N-CUv1blJ40te-iS5*@~+
> zdO1_P-xfF0LrKFmKVwdJJvDvdCqt?1sdesySF=?LkKFpSeCgJHqvJ=;l=Dh{N|nv%
> z?ZI~R6t8!U(gJAaOzwfM80p9aPdy;1^0L=_G1**kPldVDC}c>#md at 3k=%m1#TX#e=
> zS2XlfbXb5|e#n&g<0BDHqw}B3>yac_?+`J4seNbk^@|qGjZv*Uw1dd1i#;74aUzf1
> z2Jz{KkEfg8w;zyPO=W~!G<I2<sdrFFU(J4An<v%9ldn2aq}x~C at p17fC{KR(o67ND
> zRF*Tpdm*s^N7&Lq)F5!b^QeHn0Ez|GbmGyzgm~7L at 2`Sf*fJH#u2cCT!b=cldy;T8
> z5mTVi!Ax$zFR0c5Ng8l1+Ts{Si+U>KOb)thXtP4r$c{6<q`6~*XVrFDPb=<bxzT%;
> zw+P2PFiME*>{%2d!?0g6hKr#|zfS}<@(ilu)e^3!;+W3#GB%!x8C2a9LVvmE8;3Xg
> zG*FDD>oa~=0?&Z=p3b>}18dXjW))keBTV+XS)EN)Udl5xGU%Qk;tZL1wW at ZZNcN6f
> zE%S<pfl!s-fvHBnZyfX)3anvhgP*4p1%@ie)FzocmrYfTZC#l>Y<nc%T4^F97v1Mo
> z#(k_E^E}B5VNNY4N!-ub&l7yFaR!y(s>gFYM$GvQx&Y3-Agh`hTzl<~<7tI24jryY
> z3rX~KWQpzK{>55)QCLoiN5GEClg~tGyv!N3Lz0m-jY8MdN<vm}f>XTDn-+2|(Zg01
> zCt`i};hoo|x^{#xtBQBk_+`OyR{?@hUPGrkI~_#Je&bkPz<lF4Al|`*k;3(BdZ%oN
> z7?!Fgp3cj|kXgA%^&D|tkN&7cAFNC}miW^0`fUphr9R?gg>coa>$`3bY+DQ=q2Ug0
> zIiEz;H!h2}S4~kN`@Q>=4IAX?rd^{#mTHBLGwy^Bi?|dN7x~szBs`9k-R7Ryo-kF&
> zGIG#hwZbi^w`?eT2v at MSA<H7i_VZ6<;iSo(H(tM(5d7+9oplWs^%VE{Fz(Fa*4-h-
> z=9+ygxH|Z6g~_TeP~w at OVCd($6+bdW<3kvsg-96Y!!h;&Y?6Y$23inO<npnv4pr=g
> zobV4$_`WLZ_iDNDD5mVN)7v1}l(qdos9eS)fbON07r&n_!kCs=>WJK_jTlG8BQnkk
> zTKaZmaRZ&p1Pl1*D}U2X1KN^**hi^R`DNr2y_CCqWpsOw8h$!y878+YtNJA0wA3Y7
> z?L1Y==`gFz??9;v^6s1$0Zw5-?6r7RZAqayR5G4yFho=TN3m+!2#O$T460Q?#7;s)
> zAOFJEdWxl>|GO8^U+D~M_(I<fFDWuB{H!}t+YyfQkIF8{KTLi at u}-}yYMUZ$b?yb4
> z!*qFD?GacyB#(t7M(I_GQ15CsP%ORCMay_}7-gEm92!L<NK2+&hvylD1=V;E7Qe?-
> z*Wk}U!|@3~(OZT)g(@(LVQ$IC5u|@?F#vmMTB4S)>vXUz*?im!B8nz*aalbh02=iM
> z!c*HBcd>4ij1I%E*sKiGB^^X|4IYLcP6yFStvglUt(v?G2VVitou3hi3jXagr&xj@
> zW^WvOAKIG~{MU(fHtM#+-!$*w#Px|=^BJaohubs4w71NM7Jl*GwsglgvomlR$OF25
> zpI`s9Sy^4;OWGgr-!txUwMo@#A0Q8+ud@?I3|_x_5_KZpfA3N{ZmKJv^%STH9|qns
> zNCE%Ozo4tI?Ix3_vR+A at IQ)&{+LO<Ly=-GY3tQ)OrZMH%v+MFV?XxYbcZ?>!dU7JO
> zX>^!FInSqT2;gE(o|F<+ at H}G4w?_iiQq=WIrwd!(8{^o%45qh<Cij#nlUKcF(78{G
> zB$m3nwN6aroUO9z!8rL?<_9O5ztc+O(Xp^)TmzQ6ABhmHl8hMYHJMmQ=$U=v-^?1h
> z$N%P`Ps<|WWrczcV|`o>ekr+AU&H_2YV|*W*=zpAF?R!0QuUmFmC0*SUxE~_h!u{&
> zx{APu_kTTJKs#Sc!A+3wZspeNVr^mf;}=4)j~c7ohgc`fO&8y5ZskJDkPaGrNMTf?
> zZzGaa&9twPOPCB4-RM4uxrdQ0!D~;u&P>grJ`T+)g59u~df9tl;<*KATGA6mfRoXP
> zk3CDuj4e>}A at t5~9Q~lyT+j0kojVw{a0E+*Pw*}yHbSG$rtC^QOPage9qce4q0^6>
> zRaWbv{dJeu^t#B<Tb`8AmT;pVu}@h}3pifHxCndb8^;%99rMaJj;BZl1cH|xU|zSt
> z>T2*th~cLmGD=}=x#=xD`2j6 at 59}l#@AC~3rz`}Ip<<TlAi2D*0xs9c`;FtWGwZ!+
> zC)v`wARd8WNno9b{e~n_wQn4i-#F6Fv96!G&vfXlV?3RO0U8{T_|v(Z5+e0?GTg5$
> zx-E46LmBjVqP=kF>v(?NJ?X~2f+r^qPcIzTy*-*+?$<?jo<pWMRw=NsMZ0)4^Vyx9
> z-3yySuV2U#<H_Ir*@k=I8a&*;mb825nv2Ys+(RDrg?{_M2$`{??_Whr>dtmyy5B-U
> zE~SH8^H2|Op3bqfFe%eDpPtHI`Gm#LgKM3I9Bf%CS^`8qd)ATljickGkKFxFOZI(~
> zg=Sts6yxQ_x>K at K#X*w0AYRnLX}lxD7Cv~V9xWGMb2=<151my5OdO%Mzbz!obXTbE
> zN+O(nv3Vs)q}y3kqA33S=rBx;d(m;Oa6S;VLs3)a3h|S?w3qOMH%YF9*4=637o`k$
> z??w59Wn2+kgqFKcXdr9>cII7PLWx}ZLytrPcR2c<DCd)o+sR?|DxQgQ?IG$ZtXOw{
> z=NiNt&j+eXB$;a+%c1+r7Uw=>Nyb%8JMgX7+#Q~mf%9RgT!^l??zW6e at Y{)>{TTL`
> z;~g$p;l at K=MaC_Ce!Z~EW&1GAZV9nL#zE<UDPO`5WbU8yNQp9ibAH8q(j!ud|Azak
> z!x7xwIJp7b3kx`>zT@{a(T87shd+-o!G!qPHWGwcTYokBJKmT%l^YO}JHEF$s1*O+
> z<^b$UKBkNO|Ev=I7tf0cQrsT7YzZ2?((4R+0t99|m=C~uTY9oQ{Ch?+6>ycgyg7RP
> zoz}8<b<Z_u^M3-$e#V=guAbGDIT87Bw$^wwO4YC~-X*H*uHgQvE0nkgA4sU^D0I=v
> zU}^^Kb;<jUIN9!s<B~(s93wAfCfqi|3bkfc_tedEOI$-cQbXSzI`rZ5{YdN?OMhH#
> z at y@$XRp`Pju1 at BTH|H9gxz)QuVRs)}a*lrEI6>nnT^l`bOFy%Q)SpG9d1J7udxnF8
> z-1qN2?7zj|g1Ch%`O at oW9LBBinoXNS7uFEceFibfG>OB{=B!t&Vi+pd(b^3O9+Z;R
> z at Ybz_mI(P0Q8z1A+0Bb5OpFsVVzVFAyKjHVaeTb0IP72!q<ZZV&PgS9XMhZa^S9J*
> zZq*(T4g9R>?U(Vr;-8+n0Ov!DYROT~GAZC01BOqgOn23q?^cj0 at QovX{u~f+opfq)
> z`o$n_4SNyE)LGQ>Fk{nnnEK35tP{BN<{DEvsE$l_^Y5CP-!Vf77|>?LFZiRuCY8Un
> z2h0}S%whxn3^2359ZjTWvo*T_i5)uNieqBr5hQTgDnFX-FYXt#L5N}2|F(<5(sZQ^
> zh%`WiF^~;CLTk-iZ~MkkN<!4(_gqg2VeMmi{k$rE^|vjQ13%BUVXH$;%S_-><<En-
> zr2TU?{q_^(b)sU4GPFn3xxKm!XFt1mr5#$55sLPvy97l(KV-=)I`4o6GU at pD%)t8b
> zs*GUNAQU-f1gybH^k#m#2-vebzIT40II|wcA?Q}Ns3hZGjh?E(FC0sr_D6C-?-#eQ
> z#aFr1r|9u_6o34L&KA%sWPYmx at M~!RnctBH06j~7Ud-S7nEW*M4}DDR8Dnyk at 4a%S
> zE2SKErXPazQW*z+^$33+la at k+vW6&Gj(_=`JX?)zfq}4Nw4C~dUAu~>tIb5^l{A8S
> zMl0scZyZ+`LoBi7Cewwl;?y_G_7o2pYR3-;WIy**Ba>I0t%IwZXK;K0rPYh5H%+TR
> z3xvH9<W?klNS>^_-~>zFxX*Ts7zP0d<-Si5!!6n`^#oxT_N33qv7{ov@|Yo1{h3*<
> zuEQ$DkL`r>R+Txk6Xs-SqX=IzycwU2|MHxz?@Cdbc?rDKwsw5dnN|E6W;O-djvuv!
> zk>yy at T8o5G)PhpRHxBC_c8olDB1|T;5H-w%l5vx6D?pDk+MFo|2o7=Vgs(HS5jL!m
> zF3b)_T*1*aaKL^s9zj!WU-2i&Gi*&mK=5Uf&>2KIW`s0Q1u6kOLr&7$fV0pCn>0{X
> zfw1S<y0AfnA*$Ol5l={m_6N_yvvAE77ly!Ea0Xf63=&!%`XI@|16{C<8hoZ>!K5pw
> zoFTFfp_J0d9v)&m#x=#Wtbj2<>1Aj6-6-xq8>NwUBFy!H(mQNxcU5*kBJeI&R at qU6
> zV)E3Nhb|!ByULCfU#>p^&pq)J>%KID#0}}QP8Wm6`t-MwhW{mrvi`V)(-Gnk&>~Hf
> za6aS6j*Tm6-9bxNuX*Q{->ed#-FBLQiCmvoILh&?)!#nT{1G1|NzJKQ^;Gi4Pmcum
> z^#o&T7VEK@<OuiIT{d6QH at rq_Zogl^94e!mw#8%ay>#mNpc_6Igx6!98P1oFo+S{i
> zE!@cSeq&+E%q?i&h$iK+d{%G`T1son={Bv#BoVSv{@{Mw8(=ec7?#_j&0BNUer=hR
> z4A^MnPGDt3>88bAZZ$2pOh>E5y1HUU2U}<TRz<0g^WFQ#PYm%m%!#@(D~3%=rY=T`
> zdhg1P{N#?8KK>q+h0`p&o91*cgvH6N6$5{-s{QoUvPfyhHWA16rOZ at Ip6BU4p|-?p
> zU%{h#`G>@B5J|21Rgak at MfxsKMRw?)`_UvRGUw}23&(J5aoU-15biws#sT{4 at -I%b
> zi2c;f;fI|bm-%OXZhVIE6beUmX3tqLbrujl<X{$IJFw!Lz`U7~ocSYPeeHH^?rBOu
> z#@>uH<+QGb#4zvNg|wSFGKoqb*3Isc$-hc4&m(_DcrNFp>oF3kes;+Ps(t<&t;p{Y
> z(m7>o58~a?##4uGY;w8Vfo>)A^9R<-BvrVTWtmUxa!TD>d^(U|X?lh$E)EmT)2ZVJ
> z!4w_D-;J6)PKlf#xd{<GH25xYhP-`obLu?bn)bvn)6*uZrFz76{4Z?LD$lP*M~*Yt
> z8gk5Y%!zs!ZF>t-AEA03EZ&1`N1kQeU1-4{!G)joZAUDX2``xcJTmhRssLO34(6wU
> zSf~n=Zu3D3kY09sY~=TTPt%Au0e_&)vG!lQ4*P`|JClO at 2(W^mB-+8~1RCrTkwp*%
> z-Yg0#F~mP0so=Uetoo&&@0Xou3W9DFpj(a7(VIZjod!+0D}J~BET|S*bsQq0A{jmR
> z5nsJ96uI~2AiC8?SpV_PnR)eb>KcODIiW_X|8>sil#E9pA?7FF!?eoL9&<21mUw8n
> z!wwduAbXNva{S${CVpn|j8FPt>Bu1qbG)6?-0202?0`zuCaXlei6Y&Y;g0U4Lt%TK
> z3=h=~oR%3_FLT#V>(x7&&NJJaEzZ2|*E_??w{ENnyX!^^eC)G%v+F!6#C6b3N9a+w
> zv>xTb{PZ`D=AmcIIg<T0gGLfDI8~-0 at he?fjXhUI{vQ8fKCH!SA%^44-QS>ltd+Vt
> zBe_cMi}e{sDCv0KXriB9rhN!4y*sT3U4X*TKzONI!EdJ`wi^CWO!?V)t?cQ1hn4!c
> zI2}9L4{D)$T3x#STI-1e7X~r08DG47 at 84PMgQeXXYC?3f)b;QBAFV&}^x0>Eqd#;K
> z-f8;wPZK-;`@6Il89+N3_z{E7zx+P)IS>&G|1Z!0`VJacIsatVabx{jl&jMO(yS>Z
> zV;XFCITv6Z80vm4W*q9#(8?NM%RY_cuRi%|I)eO_X<tp^0(1GS8fu&{h1-G{J)_f&
> zq8si4dr=S84}c+m*niJ2j^PG1%c at HP9YL0IAAkeUtHX#G=nPb%#7r3>dG_dj<LF3C
> zhg5^-(VR3>5?dU4-vA#5-~eU<D}Wz$MzSk$ENL6Ch0<uW>-cKwH;yx?j}t$Tf+8yF
> z8;7eLOL?GYv5^VKEGe?KqH9qLp{NJnI97LjKl1?k9<hfRmcizx)q$!U6zw}!hXYpm
> z{JrHw&}OF){xR){y{cHhzY|TTr?AvrZkLn!u7>%-sh&mi3mZmNZ|URpQC-=Xgze!&
> zY&;wE^?-^d0wu^wOg>4H#H0HXvFZM-{A(!j)`*!SrEqOwP~CU8XS{0PmHyXDj<`2{
> zjCQaIEWmdjzMaGiGdr}m4`eq%-bs8sM9S-3H36S1fj*7qsi~p?`|rg(SxC;9i-U;%
> znnnR%>U|6?EXu`7E at F>KsMoK1=aa8LShYU)khl^4ld4X}jIeQkJUYwvcAS8xzWfdi
> z>BDv|TC0~hsXfUtw&{WO9XR+KK#l<ZOZWRlsWB at 3QfBso3bWYhD<V6SO&rENUCxpj
> zg?;v1c}WJ12 at t`r9pZCV;^peH1y6RmXGEILd2uRjgON_V#lT$xwyrTiS7`Q&M4dY>
> zzDtI##1)Ymn)0eWhD4aTP%d9Pa$U1%V;1<&qxP$Z9LOtp`?DMRkAGj_yx<yBudRJo
> zcfZ2yRpffNM#l-c!sVzVo4xaz;?$Q7E_r(7Wav#K2h}$}H&KmRt(_7-Hp(H^o9BVz
> zX=wMarkR#hzOcFdqRa5I5|j;(aUpOC_^XRNoG~=Hu%Lq4y!S0lr3ZB-CFkswHLLX=
> z8|^?WW+J_0(rayWCp+VQn8)D;S1$8x6aB)%4cQMGWNs_eETu*4PR;Nsd|^|bDgu|c
> zE`MImwVa{f9#RnfkGKAN$N!7M{FJ}o<ZBLZ5nP(m(cn1h+#ZfU at 6UHhR^gC}==fhz
> z^k4NG`8RbT`Kd2S85usW00L0Fg6CE2d^Elu-U<g9r1UiF=pxn$%<PN5-tZrS`#-&p
> z^B1w2s?(CnZvuQ(C)!X5e)J}askIOc0)+RAyzJe;K1~o}RWLzG`wGeSbDM^df<tHA
> zT<u>_LmCZ}4)6)>J0~k16Lb4y(*~{mcuP|@k1aXdUVSY!lz at x^t_a4IRHZAVM#FhZ
> zkq+Ln+NgOy%D~e{@*~|66MA&>%Y at _yQRnr(P9bD7=1iHYEkq=118O at oKL7$3u~fF$
> zRdNRVzT89n>es)VD-UWrK%mw849$$+WX^z6bFESUrYiw(2^;$Tum3kEf&c9sr~Y$_
> z|Gz(r*={hQxD=`WVlm>A-#E6a-t_k2Zs8wYS)pLFWzK1_7EuCBM^-Ug&d;h{wopc^
> zm<+q0$Cp-y#>gnFo^xAha=lxB?)c?$<Ga=7)FIb~<Bcz+Jde3OvAi at W+bVx?G*L(L
> z3-bM9ftX60YhmJvn43E*qfD2JUo?6epu%?Oxt-HK^rZXAYoUExpD6%_{O(?T4K-7j
> zu^7!$`xac6n3+3d9lDj`lM1fBoa&zU&a~=J6L_py>Mh~H^NRcSB}_B^rSm=P79thN
> zkn)my=cxa+u!Td;&ak#$`N)M+UzN(&%yOZPp=yLWXA21z+BhNrI=qu7f?rCdY?Lov
> zpav*mj2~EJvX5C$I;|9|dSBj5X;ftF45q1Oeu|Y&DM$+Kz!T{GtnaN`;IVMn!JEc8
> zKw-la^_*GJ$iV?h&qG*(EW1CA`~03H<Zm&aAN^~&{~6f*5AO3n8~4#qH^zv^GwXrR
> z_SjG2CW`18#FlmNXq6beJA&-y$+BJ1zC<&C+r<>K_BSz7;TbUmuhd$)X{hSP94{x!
> zVv7N|;hU)Lg at MLqN?DBfOxr2ZfHnN%_Cj{@RPB#(R+T<tO55zn9~MBx)*W;8R!8h0
> zB#peQxi&(@U7>FU88Ng$5f^|eG$|O)y`<Wm$wp()QxEWk`<{-Dg!hVE+8Xw<!e#k=
> z8%$i0Ir6Z!Gu6OoT1K&y`6R5yxYi^_I=?Vw_G9$eH50B&S-Un&OBI at M%lqnf79E0H
> z6?86zGAd;*7Cre;Qc?IUId-5?OUpp$-17RW5vnKHM|h}Th+DP}=~6_|ViZ=+`L(TC
> zdqQTek36$^cPr7%?9sj`U%y?0(V}ZPE^Z`nm?qzAmG?R}z!Ra4ebu}Crhi@}u9)0q
> zDffAjWkUFhuu+u<=Tsu6Rly at Gu8@c7Jba!eJnYdZ4;o(|>PQSdXM6ceiQijsj$MuW
> zwub)JCT7|Aj4Y%gCis^QkL2{p>m(wg)KjpJyq9d^3X$D1OiUk+>K#{urEja+`;B9$
> z9LZMG`q|Xt>Mg%<B<N!oLvYKB$Jlp(2cH76`THmEixg=10P7VHih1TI1tfAdk>pqm
> zphGdz3Dth6;sc5{4=6j?tUib`%`^t4S?C+b at l=*yD?Sl?4)LEe{QI9nUMQRA3i(+&
> z3Sgt#+xNPd*%a<WuXkn6yvPTO5yRvzFPHBJMs7!8W}{hNVYWT+Z_s(W at aLKGtwN&=
> zhOri=;A+K_ZyY81X{r|q;uYYVo*SY{E_n{m_kCIMr4*8D)0w&-b8d|t*YUrsp76no
> zX4Ee&BjzKexO7nIV!wIX%3`BhVc>0Tk at cFp9*XY{oQY>67d+lj3YP_kd$O6ws9z{L
> zL`~eTo_iGzIg=k{ZaKk}S_`7d>Q0_qFpjmZ3AXEODnH=sysZxE%H&bN&d;`QznUbg
> ztB~(5TVBt`fE18Y=9btAieQFdwQA3J<GUg10ptUwzNZ6mD0IaHy|H`rittQqdBpRh
> z!)wN~TE0ZNcE&7U6~wiRIA!~mZ at 4x0QYYKYNY(Ikb(F^C4Z9;=1U}Y4hsTchTKcQ|
> z at Z#@u`J^saq^ebq8&$p(&QL;!`{doPx|Fq+(wFe8SIO4X&oKMr8#R-!yTuAC0j3=A
> zFMzSNzZn1D1(yAyj^kHRT)*_MMngyDX?%E!_#)w-vVR5tx3hn#3LN_9km`lcGuLz)
> zDha!&-oC!;K}s0L`~ZNS|4r!ipA}>L%li!9ap}2mH0?|3+#(YoWzWH-Jo2Ptuo5IL
> zJgA%`1O^ha`Q%PG(o%a&@68PT(}naxvxd4`LH484Y)Ou5<(SVyD;kuZ#w|7-m#QLW
> zY7kqiw;U@{<^E8C`r5bW8^<N2H|%}YL<p;c>Peod#&4?P at AX1dm#LmG33t5bu^e^n
> z-Fj`2Y-RC%*cX6lSVoN4o*fpS`_QtmM-M<E_r}rBs{J at o@>!yq(y|K1iDfM<9fYrn
> zOd&wxgi*zbK^UUkmZ?uuWn#~66|Z<q%NLzw)U94qwn0ifQtZ0Ref|+o*xWGh6N6j0
> zFMBrBOYqx4XKSJz>NTaCuAc}wd0Wacgy&Zi=701w3PF;-ad<Kv&Hs9E-S at ElLhT69
> zdX!}!12k{eJR9RPnw<+aEM^=e0`;O-zj0_)-Zo~IKV%=QG-FzYuoYOB08;np9^DnB
> zTi*kfrx}V0`yKc+UG+y95))L01=vANcc_V=c18qZi8-y9sgI!--{BVy1ZOipvlNLL
> z%!dv>EdZgj%}fcQFV6p&%?Ab$wOh_KjmEn9yyxFIGE~m9y<vk)?giYW^U63#_gVVs
> z(Wmfqw?f>+W7hmTNScYNbEXN_GB<$>MKTvjJ<RYakliZ+*}V(r0o0B_9NI}mz$cyP
> zqO2hNm;fHU at vFr5Q<t&5fZQF09fVIN^g6Nioyd4L2}O4+$9+^i0pQYT0Pq1f0GmbC
> z0We<(et8b0DKDxQ05D-Ckj^KSlN_wf+$!}sO%iL)LBp-Yu#yzu82oy>_O$Engq;r4
> z9oL1k15AWm+(hsCPhyjYW7>vK1Tt5sjn#wVWXZZ*(;D at I?OzoT+a21YOA8Ww+^?$b
> z61<!(dq!%VixWNdvf#oRTms at c@^b;W4|oON?k=LRR>+(<;<NSc;)e>|6WEvrt!F}C
> zGcr`pDdQfJ+W5=@Ryq|j at e9sWb^8fb=XWiNnC`=LW1TUH&$Jc$#h}`)==qPLq^Qd0
> zBd~XvhuC#~x7~5V4u at 8huYS3b-52C5L+NeYBYKScfacgz!$wLmhjKM&@S0#sdK;!@
> z&MzvhQJ)va_NXVyTzOSyY%?NJ<{J(k2j|n at L(~5Dn$+!+!|nPfw{CsMv30$CW4eDR
> z;|RJ({SZ|o&ur3sw#RxO^~%2IvI;#<j!qHt87&3_@?o^IbI#92v=5?>r*A&>e)<Ib
> z{Omj1nc*4f&Z`b`GuD$!M?Q4$#*xHPFm*Gz#->%RWh4<LFe#=;ULQlk at Jz3ijR$6a
> zd6e^Yu5B#R7h`<+6xXHo1{-#7({OJ}ES2<Bg*&n#Jdi`P85zdZUuUY3oIb;9x7b`R
> z3&=mH at L6x|!0y at 9yTf;^UCxKF7{&22q5G1A#N(wn?4pis&fD-FSmcRZG^4h3`C!ME
> zIe{p1#m^v*I0;>J$>7y*b4ltxq3a;=W9SliPDAQ1{`N5b%<o_AJpV(hjebJw{*Lbb
> zF9RMk2fC0S&K=K^It;tGWi!w13-{jIcC^1xIw_V)$=&-9x{o$WGV=cf>oh8CHA*QH
> zN}08P760rOAEpwMZn2O8UuZ?l$D<A*-lk3-C=f~T-Inug>U~z{7$kfwb5d$RI_&u=
> zP?#zHZ@@Ce)*BH$#rlN}g3Io&C{7``3cqY|TB)TXf#`w<J>m&8a!9ssq1}CpC`H?I
> z$BDygr%c2txXE+qRz$%n=!HB{TOFm{@Myyf)wFX|RL(*%L%Aa!BU4<mtlsm0Dz`nc
> zJ at LFTpSM*JeiBl6uGSr%G=plNU>-%z0(9l9Cvl#=5jfmD2x2^BKTj72IbgExPO2#=
> zjo3D{^BV`kmWoA!W6UmaJOXk(k<3rCtLDdib0Hlp`TISvwhsm4sry5j2Y~pT0}G3v
> zjQBp^s})d0E#?_N6qAJ^!6_RkLyK$#h6ZmHBiu=~FY8$XNa^Md1_JuD>w7Xk;5xnr
> zL%oLm%wRv9uN`9YY5<|sIwcU#6MEUe!T8S&{F|SE17U-mdhNYm%>^X&8s_uT1Y$jV
> zS3;QR<YO!=7DEl{#nTw at I*76%|NA%T1}rHp^?=7j@~R=GEyvu<YFaqV#6!T-vnNVa
> z%h{PzTO7M$WQTocx<uffWs&!Pw%NuMqMC2E-Ox&OI(CKnv<Y|W6H|_egP9i!a|ajd
> zZe6b|KeZzNC5yRjO|QvP#j$K?(9~o>O9QsSX;IGMk;y_R%Zy3)Q)Pvt5q_sDAEb~q
> zdLFpHtiE}s?rP3O&VJ42tGASihkfioT}Jg#uLu!eJCl9LzM);I4zuG-QM*jtwyD?e
> zmHT(Ed$s{6nLY?cMvL}L!eRqoGzt!r;v9ib)aq|-R&D07J?r>l3u9<3e^psB_?aF`
> zLitRe_MO=5uf2^ST`x)^L at td4Z0J1bs<}3W<1pWv2JZCp`Id{3gGC&oBb9=yipvQP
> z8PqO^8zBcuINbRUn;l&w<+vsxXEfKWzKnU~_V(k};~AS*)2B3!to>EZ#jh(dNYuYp
> zVl4i*Rbr$(q2dR=aR|r$?Lh2<5c4(I6xcfWaQrL+tmD+dQt25#2vna9H4Lr5D?vVc
> z-ZBP~B_TrPOrV`M_;7>?$Wz-~MkhekM-ZcBOhDs$y#>$4C^8OWZ{vlb;b-s#E3_ok
> zyM73Gv+=B0WGSkGEXNGl0}2<8LAqYRW8Euk4Wfqjr_-P)vVt-EuZ-3|jB}3uiy}3;
> z$ghjqc2Y#xnt(2_7F;I{Ql$bvRNMzzo`a?gzt^P`2rU}_qDU<X at h{5SmS9`)qgN4R
> zM4RL^dI!j8k#H<uh;9VSncDa+JvH}xm3&O!Nth%y{d7kr!W$AUE%KLAEo76hHBT-S
> zj&!yuorevcIVWpW>?WvQlsX2IyQ&=vsm-Bm?~F0S=9Y<I+xQ*@E6#ecofV%{HPWZz
> z2Qlu?Wpn0J%&tWH9C<BHnd`%=RLOwdS-D~lY18vu3!>6PSfI1uS7FUGvGI4yG=q~D
> zBH1eMMnYIh+h6Q^z=L$HU$0;r^#bd&SRnd*BPKk5o5AAD>Q}F44H|LdkH_lT4QA;$
> zty1QsSI>$HE4hOAj&dpW&MU8g2BjKnFV{E&ZLQS+EygfnFkIJ<k?rMX{ZaOV at XDi{
> z>rpxPtnO?QI at G-UzV@zLqYpbr_37%ZFN7?Gmx^kbaVJu~m<Ta#{(J%E6_SZ*rJ%Q8
> z9-lv5kvbg>n#JoDyM4aBrdCYT8=fwr){V~?;$`wvbw-eUpt<=_u=RF|K;EaEYx5U7
> zqRftMCVFoFXh-?#l=K at DWo^VfR=22b{;4DtHSTpsb#H@|y5(8(B_}3eqS8`7e=WSR
> zYR-=P$vo=+#&%_}_f*NT(Tx;w_8u`6Hq;1$GO$7Z>Cb}=mil9ZMUb|S;3t?6d;t-!
> zmNcVDxPzN=V+&=hpn=xE3K>Lr>pnpb;J-1w51m6n)-j)X=0Df}ujik#M^ov at UD)wy
> z|12J|(QRs*5{DKM)xP?}{b^*H4Fy+-VyIE|Z2os(`W|K_RG`ucoJ_<U^1z6!ZPiD6
> zU*$cB!40rzB;&o)i7L^NRFQ at pi@8^<4Oztfms7pE10h8^yp6{AEZB#h?--1#>SY0M
> z%H|t~Ad{~nufjOFzjZ_|`2A32Rm85i6W1jJT>^J!oEn$indCvihFrS5BtA1(B at U0X
> zIc#htO&PNvrzIJNw9K41{`7VW{mWZG!hVZ6?jvs**-5`chb{KuZ{mlskVu}N6Iptm
> z=z)h;Fx$NJ6mFi-v at xI1J8leD+E+Iu`KIu)iwp%Wc}vA!@hhSLQ}>L`&;FdWj^bpg
> zBbHDWVm2M<+1%|G$wyn}$=TPK<LET`7IiF^6TXoZm%0Q2l5~PllFq?asZM;kWQ&{@
> z8;Oc!9ZHrs;?|ATuRC at B@a|F0#`ZMaq#b0O at d6-PoBvD{^!+{miG&Eke<Q{HRB%xd
> zTlv$-zo7)fVV^LE!O0nYh33ksDDAu6b7o4W2Oi#ban+aVolHN~8ZQU!fIs)9^W^l^
> zmzBs!j#=umbMn{kp)}^YmLy3UNv;MW%*V1q^{4&U^9I{n*b%O>`-=zzP;*jQ#peEv
> z2x;;u()(2?cY-zD_lC0f{q(xPCo^VRaDleIehGtwTODfoayCyQBbT!`?Je<HWb86V
> z-Lk;v-Z{3qC;IYu8PV(<?SlzQ8fkc4w7v5H&ARA-GXEP-)$trO9Qs+7Y9bsR{EI<I
> z)zy?4o((wCY~%=vCT0WG0T08Ew$PaSYf=O)g!)r<_XllfhAr}qquk_sy((s~0>m6{
> zb$~YUgB-0*Cxco3y98;YtCY@;r^Cj|b~QV6CG%avdv)Aiy8!CgbHl6aXfM!fGl#4X
> zy5=A1s{n;hJ+Zs%4(~p6+o&!xb at B)^#kfz~^6NedXR2sFG?D`TD>b@%Zfv~A<nmHa
> z9oaB)?ZaJo?qytf%26m!h>+|3rgeu$>B`b^fiz-k6BT~37N;$~`2&Eu+)X|R-*Y*7
> zK$XrzE77I6>ruCg3 at J_t>lMFgcy>!WFJ5p=vUGUdPfiu_Ie*4Meb(=DHb<1xvp3~i
> zjX0}wsiRyzi}6cWWNk-W`IL8sD*md>`t2{Z#QdPYb=r95l?)s-Whg{)A{^B7J;1h}
> z`Um>3j~1X0TkHHhV&w%}jfY66c$GJV)n*h4GmZgFDuZ at 8KqpSrTDkZ~PyhSt|0&4)
> zw-;n4Ii%lJyMAL$((-vTm#w;Jf+WDzPpf`--H{TZYwWLifW5M~#E<dx%1>4)H--D>
> z=3IWvwCyf^WvZ`*3v9k>VdptvQEZ)pY<}z%TmKeDGkrKfP2NtJ=VmQmJVSc_;e~f9
> zo1W)9x1oP^q=sMAyVPtxJF8|^{;}E?bBi>a!%mF{E6%<-cX)Vl#wtB2B_eg7UHo8@
> zlup)&?Gf!y1G_T)!a`h>`Jb&LJ_$69P8yKOQb`h>TA0+;*p>O}=<k+hJ6ycPo4|7D
> zyvVibi;6|=5mNK`pwOJ`-s|H*mufYq`;WXy+Mry$Yr%=eVCAFNoFXGv;uhUS+_>-g
> zX+~LJe~<NOjVAftg38RSpwBKU!tDDY0p3EmKxjC5kiV!4py~NI!I7QTyLxWkN_ir5
> zIV!*8DxLSBH&~^nO|D61n at uc~i{?*RAzI;^NLzK0BGE>fJ$PL=$*D31rsiP48iNgu
> z7dK4cXEbDaUZsk@*$i)s!gIw=Eb^6HG1#wdxtUlhG%bC?MdIY{;Xv%ikGPN9SxQU}
> zit6AIRtQ_rD|Y-^X+<S at EUPRgKknJyOJkCvc4b9AEWcz1OlKb;yI>y>WOiPTo7~8r
> zo>n at aO6GvoRN-(_VXq3Z15)*u!%%~ftVdC%cNS*VOe>OiuGSw0$Y;e;%`Z}nYkx8J
> zpS0uu&9q}U<~`CUD*L^wP}+*LjKPDtw`ZR8y$!cvY6+>7lgfN)hr<bu3rOCfr*oF;
> z^EMk>8xeBfzgF){(Gnt|cH{tS=lyQA-b=G&q%OpPPdCiB3)<z>es+It6hh9NI$u9{
> zBueDbT{kSQ(oewY`3ZmIj2;JhMer at oW1_=}!oTIc7zF8CtptulClR%tW2yXT$NG_H
> zx|6ICd-b9@^-UD_Hv<`MK6I8$V~u^DVLlzXjcUjv=qYO*Jk=BIcXt2T4 at t|j at mACr
> zaauuStDo`k&70|$N|fnn<7K&^ugv$hO_MT9n at f1-_Cjz94wiFBGskz`4rl!~O{bG$
> znlkH~7I!QrjTet7^DkZWfk)WvX_0|HMEyz~B6;XnqXbK15U~Leh=how_WaO{0GU&i
> zx?ldxuLvP*o8PiYzY{U(Ai at NBsV;mSUVIg|0qUo~NvOw#fb<xJuK1$@{nHbp<8Nfg
> zzKGbZ<Z7eG+<Zb`hb=bxG^f5%dF?VDbv)Noe<Anje4`>@)A^mhym+jsL9KG8tHSuU
> z$)J7`m!B_%+sLc^hRSAWd1iF+hT(lP)*9m1Q=4_q4Tv^AWO|9eeJn)Zsx0>MEgv<M
> z9SL$#YAg*eWEk_*K2HOZRvReVXtJf8t@*~`5J_l7Jtw(kX{P5vH|)fOE at nT#%bi(*
> zYQ;`0X6R4YVO>!=RKq%Jch_qdeB5y@^PDs7YNM#iTX-VMnThD^J4bBcB|tB5FPq$?
> zkRE6W5^7z0jg%SO<$6iO*@s`-G(3yj1x~sRRyft}6d_`g0xBJ=+v>RAwxWX{WO-p5
> zo~`g3WPbW6HHCTz|IPQs at Cd?hNBkhpTJ!!Fop$`~GH{*FENc<j0E~Vgfg(MkjR0;0
> zF?jKu=`WnYsGeU8T640-vDCQnh}i<xLL4=fmI}Vt=)%zUSbT;)EBcSV!|$*2^I_}R
> z^VH6wzx at 8Va+xp|-1sw})8aRoT$<;0rkPIxwVa>nKz|K(TVBqkkzaB-si6M&SLs~V
> z#64(KA7)A`pgYwfY1`VD<Ji%SAOpNSG4y8&2H+Cx{-K3X%%dSIC7|ly5yM=7S5jeP
> zKnh~66-Yt6r6w+SKuZ%2D8e4b&|S7M75{K(K|YwelMNQ`L_Lr#0(XXU0y*5L(O}Y}
> z(dKghLN9^|5EAYY))qiLdHuPOxub&!vFh+k6P~CSUU$G!1l3*l*scgeavWQWADa0B
> zaJU!#7UF(I;hu+$l-08J+#aYGHBUd`yPr6ay(0bQ4I-VaP&yjfG~<Jd3Xgl&nC at l&
> zkZJN-0b4QbODY5Mq0^ejuhKAMC^&Vd&fu(l?Gv`H-%BTq`zIFXJ4-21yHt1gczoTu
> z2nUYm0A7o6plsjLwvIW{Y1(KlK`D&1{GgOnRn#_Br5uCfo)=lf1!W}_sS&2bB=5iW
> z(nA|AE!Lus=ma4L?SR<CVC76Lz5N64p)YDqi>P;1(oy!o<Ejjn%q*VEac-|htm3k_
> zp6%R at PBxmt9bg;id}c;hectb!r at dmwX_~&ZQ}TfK<N8(~u7a`ky8gLB1Mm;ZNg|(H
> zQ;poyUrJ3O^U}Po{0nK2ze|Ro_Obh$0T<YlqWG|dGvhLl>d<SiD#raLHNQ|WL=zw(
> zs^wS`Ns_$K`&53w)13f%83nXaac)5Ijf(z}qCd~RVZR{KF9m&1wnxQ%&&E5ZZ1 at dL
> zx2gd5<R|7X7 at 86dW^25K$Xeexw6&J!w}8uR1eYO#%e(+ny-N-J{9~yg at ScAMgFx-4
> zQ2PhV^MmO-1Wg?qFtnmJ1*cnW`A${DqsT+7z7lHOD0-O)V<d?K5~u*cf7_8g0l#p1
> ze&q=L)7Zbj`?moVfKTV}CEWLAg^!Mw+`HLjQE+5%Fbc6Bp6G{y%TcxCULjN|YD$sc
> zDVQn;Qj^8s?)wp3UHGnRupUu at tPbE%@$*dM#UhJqt#z#8YAbKSH~XQ<h(~#s(u<#v
> zHpxt#n-&mxIEqN=(c5}nktq2I_hIIp?ipS^q+Jha8SyAFVd1tz*Oqdb&u6ErBcu5*
> z-`>#3t*8hg_e0nE0eW-!_x3)1bJSbMR at 2AVjsjgeCFO7(b!}#LEfZCFbF9HNV7=hx
> zqyeWvxzqt(f0;(6{$-q#OumuKqJZt)7m$Fjt>V~7s#n3hm;H9(J2s<)AoSjXGD|*X
> z!Ko*WQ>aZ|UkHo~)n}g(_8rqQoU;rLQ{PK1H>AdpWI`c9uf(OPBIUk5#GH0<4%&7d
> z$F1R;^)8Du=B+KfZrP58`STJT`7B+uNc^?VnbvdxOgd36<JOtlMfZ%D&aCFSJI9 at z
> zjV^_?DRST|2Fmk+z?^9%mA8%Ir#ut|f&4``E&<)+S&nclZF9pa;u~;ZsDajnH~MDG
> zi@=*-D&4}q?}-emlQt+fRUcAerKu`M)H05bcA2v9oXaJ|&n~ZHTW%lbw0$v=xyrvH
> z_n^dk+j<7I)^rp*>zPBv)<K04IEPnGWrJB)*5BKgq}#O=)sScZz-Z1!(*?D-!p~Sk
> zY&mw0I1npdx*u;%3<1SfFJ4JpE$K)5F|}%4V@(RqD_9+9YP#L at a>=7AUhMgm$ZadR
> zlT`D at 0?dZv^A^{S^RGVcWi|@Ti&HlJg=N!4L@>6^K}%(9JfPkn**sR8Lm4h!r`?1W
> zEZ!AQhxfku>(oPgxbO2^7sB=>rGp%C7YjLReJs>$T#^a0-=+ktv`^2w-Hj_#)Wava
> zog<b4+@@A~o#^ftW+$FJLAAhZa~<JZ{QSwtN3x=6!pMgQozt##Zphnl8j`?GUt7P$
> zK}2S~!Ha;crv!05s>kA2_*1)Q77(7~pfqa{Ua=A+Spw_}OSLQ8z at q<qA;K??*A~8r
> zR&1R<f8o$lUSflddeI~A?bpAAQOt}?wa`3%1zLe#dEzT(N_KXlq9c+WcwD-l6NRVQ
> zK>&(-lCb&S$H<S1ox+Urx>!*9lolDY{bIpUm(0|t#$H!cn^LIafjiJ6ws_ag+lQPL
> zbwVF%rKsk#(6<A1IuErg;#@7BGRx`(ij*o<P92!l760<gp>jf#UCun(Y*j6zAzrt-
> z at +lvW>*K>(Zq}#c4>fh3;+XJswS0N5Z7cVSwB2Ga(8jc@=Hvui3l-}ei*Bd)o);sq
> ztnt`xh|y1vdlzr~zB24-D2MA?ckU2I9C0~S`dvA>cMfxkVBPOAkBX>VI4PMgzQ2mV
> z3cm5Oij`GyYJWSqmiX)l@|x3gfBXyQwkk|;{uJqo#u<`7Au(&I11mD#d3!b57v?zE
> zI#)WE+CA8;#P~#K5g%UKXTQ#^<I5t>D&KN1J!E)k6R)Uim|G{-e98CR$_s*J&)lWs
> zW at 6miZ1~T|DcW*g$JHTzL%C*EoeDE0!G5F6G9d<hvSfNH8P8|6 at OOMD2>u^@==b*3
> z|5JqBo>}D|(q8{X*lqa>VRs9<7W?~zU8BDfb`_XGbkm(Vc3-fLbM~UbV|UIe)%5Pl
> zUZ&GuLddIb=Tk}-ox=kQ4fd)Fy-~5_{W!9S3uf<Ch*Fq+*8A?rW%4Q9N7&A(q?`BC
> zl3hFV^h8RK4frIPw`swKNkWbDsWFk&qd^9zSf_9wj+YCP`?F)2JuFyxo1d4pXh)67
> zCApke6?9*u{VhGzSH0Eoh2ABIe^avWiMyvHRRh7!orlu4z|C#j0NhFS at lrQJE@$9J
> zd%-rDMeWY<7(!Mpy90Ig%x5UubCKTjjl&mf at 2A2mH2fvDdSYo6SI%5_RlecyySt at p
> zqDRy=PGqddZ(Hz9phP%*#r5i~2vB=SECJmh-*5 at pJ^kKw1`jTC<K~T60#)U~N9`y^
> zlW&=NJ?g@!3xci<u3DU`xasLsr{`bXzG!wQHSa7p8Oj2oB9T03U?0GJ!FGM6Y=^pm
> zeWi;zf0hPZjw0p{5s)>NJfB_e`k2mAuYOGuxTAmGN7zvwldc}0dQUHJ)bHINfug2O
> z at Di0ZAW*2JCZr8d=r-b+7v{Di&Y&!MY7yj%_-z&ra5B=V@`%A^`e6B0hqV(?2FOA&
> zHF?;KHDX(<*1<X at CXQmFDkhaBXh+SE8;xRg=uqs3^BIlP(6h!VZ7nj+wU at rw9m00;
> zEuaZ~<@*a8TpMZJZ|oM{$UzrF(3eOXKw;)T>$m`KFdDMiAW;J9eyo{t+D6G&JNI3L
> z%IM)8a+4bVR;YGmfoHei%<arbmT#@&XH9;n<1IAxU0i1wdHv7invUv9CKYafqI;l@
> z-1`Dn3-nf{t`O$Bh{(U&y&2HAn8zd?x`pLg3yN9z{?hqkA`w!d{4JYsam1M>M*6R8
> z0+SPz1Wr(az=-WQ2%gh{3f?%3pIOi3Bruh<s+}2d1&AdZgwHs<k^k2?09^`j*Z#lz
> zj-c9gI740V>7d_!O7z9pK$e_N=@U_I6^RGX_KBVu4ZmE*HNO*2NQhb3h=|JZwC5(D
> zA{DdOozxL1?r-N>w%s11Rmwk1Iku7XrnzvWGOyAk<AZC2C8bo&N8i+=Y}p*!)?us6
> zy?fzk56<VNGNpWXw$$kMeldq4<}@T(%(uMe^#+<70f$_Gq_2w7BTs64#^T}mrj6Oi
> z5PX3EmY8TjKRSZr`J!<Zx>e^LCos$vFbsL|uelTvmZ7GJ?hK1c+o3IL7iNDCxCi%C
> zJxNe7g3lcX>UxczpX(`{Qhk3lEHNh|=eC?ycp1Mk_ktqh6xnu#PPHA;UEioj4R=u&
> z^}?;W7B!{g5Vz&sfM`F>R+(nkAio-pCe-v_IbFnmhF?M`_xWesA|m;?9OiXzf~pI(
> zDbpz8QDs`0(-3|TeOKSI?Gb5yt5>LA#LQ{R)(5#3P3%0UU8ki!QMm)cPR&?txD7pW
> znjbmdWTle2EZBC$RByD<$oDy;b|KXb@<JP%YFI{vV7?z3-Ey9XHHW?^mEac}XOo$k
> z{X>KBn4PC?pO;o^Wf5umrT7Yjv~0j=^gn#w$cn4!K<28_YVermj}Mh?iqhBr`u$Ad
> zKR)EXb6;k^Uz$hSpj*o!x3ZE at rhKxwwrei+c`aS743=c^g-X<*$6nD_u9qpk at Jf?s
> z!9&h!_co<wBwWAVPlsW{H0xjsu-oVnaqB2bVX9|1KTj3czov+1nMulYN at s7&D34jn
> zWFKXNS{@$1EooK`gKH}=Bt*z(AzJ~JAS@@06zk_#TO~e_G+XIJ at g(i6LkRfkQPZIj
> znBX*MH^1}7IsfOjk5sgFEEaKJRta11#u47)Ldc!hn}fv88;gbK#!Y^vtqOWQIm7uN
> zNrX$?@r|yPnmD?oj};+RwaP6nDryU4kuj)-=jXL0_eD9#P#Pe`!>I+ft~SR<?#*k+
> zjv2Q^Wd~?0H>^L(oYc^;!ln+9k at Fjy{9pN<q?{5eIpv&jYCmjHBK<L1#8#31CH+#4
> zYw|_p(h at wzZ-OE2C;NmrF>6fJv6wmIoHPCY&dpOoF3lYe4y5_yoR&}@UTyVva=x)`
> zE#Fo*RFzAWCApW!HLAM at jWc9u1v=;)B7Tq+Fju$0o2ff at 5AE%g=hAOf^w;7Smg86S
> zKd+^$y?AuNkj>*sEajT0aTaXk6_odW+5et<O_jC{JPwO`a<d1oy4aKC&77g{XT7Ns
> zX{8)p*+TJua3AKHdwsI3Em1h{0>-&CapyqFk<8UAsJ4#B?K^}niQSeVv(>6kC_hgu
> zjK>qMK?>BwI2~BRiQ at JY<ai-8u_yxk?mBD&=A=^I*EKinmcDVQ0iHSP<IY)IN?#)h
> zKb!yZdfe(KtO(V*?-0VcsLd``am|&t at IjN4Yt)`usA)h5vyoldWmHcJZ#{Oiy3ACS
> zJo#2SD=yEh<ZEx9O(JYCL}PNYcMK8 at Z1sn4v2SmtsLol-Y2s0l%l*6R+MDvLK4sUK
> zYkPYxYb_tRAJa5Ek$$3T6ZI&=hbcqpj?9=ER4qdWu at BzabYiH4sq+#&x2y52Az{bO
> z#*^k%ZJ(G|h|o5(-0laYo7`r_ZuetbE{51SCz~iwBTle7xSn5;cQHuS*O|Z#l(G)R
> z*<TX%S5#FqmKa^8<+jC#JXBWwimHkGu?i>qmu0mzw0^8GrSFSL<KzFSW%<OLaInzQ
> zRJ69p-s-^i{N1k}G^w3h$!P@*z6CzsNGt2{(<QQm`{Wl}{UN>sc!LizBtkf<1Y1K`
> zd%Z+JY;9RESX?2|_s!n_KkU7CSX14$J_>>&prF#FM5TjN=`ErkARr*1ptLB6NS6)*
> ziGqM45b26Qq)9hQ at 1a)#si8v%y(ZK^ig)>a`|NXe-{;=nJ@@``9-s9*WGxq2%r)nj
> zW4z-X?=UqCi at EM7%)d+(6$bZx&Th3-NAh)i)vVc9Hwb}uxjnNh{mu at dGd+J#OG+K8
> z?=f4E+s?=w4k~?;gPG*c*0_ehSNmYhQuw$h at CmKav&OwUxweNhKve-fvN^eLE3)nx
> z-Lf^JmHD;CRl-NSjxjzW%IATPs}sJ#@zzA_r#}8 at oztNLu6zs20_j)d42>*Epx3*(
> zA8b<x%go*cz&?Ug{3qXvIaF;w-FtN}v#thZPPqjXUo->}2DD}3I1w1$XlN=xA5*Qn
> za%fD_!P~VpoEQ9pIP*biDq}H$8B$MAQtyR6K1J?XenEZt<EK@`E>N(+N{-Xu?80py
> z at Zz2z0-m@6i-^C_>HOEriCe6!K*HVe(Roq6f<W~6GYx9=_q)fMkmVm_)8?xz`RN_!
> zT}6c`uAay~01{lWR_N&txhlzY$~iYijk-gg=Z>rK%a`Ui at Q^CgF!<_K!^^{ojShHZ
> zEAyZB`#;CI?hiOC0S6AijIYBdbDKW^&Tr%e!07`-7#Ea&5i3VP0M_fiA^IzCodW>>
> zKwNV9ud~#Dk+=Sn5cc2ATMub_j3zkL|E>rK$VB~fdE#H!BMl=~O?Z|gL#!t)S1EGp
> z?|pQ3dH~f+fLH19lS-4=PZo)*zPKI)mBFLi0p|3l{bfpm?tdj#!lJ?Ee{`+{<$`gy
> z;YX4%mU`G%0QCDMC}f^-jK=DaSj54&dJQ2g<pnV6#~Q$S)#r!E8Gmky*13Jy2eKjt
> z`5(1Dj}uG)iYgMRvG=e2t(4Z#>mZ at ukz>RgK<MY}pCp8$f0qF~W+zuoRgy03&ckv^
> z`hS4O`oVu&^0PlbQSq1RLJ$9ox==sq0{YJgaX;rW9JwP;K0|4_4a1;8jP0-$z&Qd+
> zfygv1$RjQz67%kxW5lc39i at B#W1OWV(yY_7+U3~J+^pd*^IfX6j3wODwd+0~Nlr4Z
> zCiC9N6<5o$9Q at v?J=D(J(?x8lT!i#9x4Sc;UI9&EQJ at uOt~ajbJ>jo-eo__0-MktM
> z8}k8$!Sp$NZy5T<HNu!pz at 5l;2th=r#TR$jfnpB2SzhsxDAlTPYINy(1Vv+Rj%MYy
> zwzRshBGh at eLA@vK_QgWBBGBBP2B=+4?c4ZSmDrJiM2d+S3@&=Ks-;{JLUjq>#Y_Jg
> zjqTVeWdPd3&Yt^1VTTUzapK$RwC5Qa>ufATLp^AsOWLos&u7POQE%GV=`rz0uc<hs
> zjD|T5<X?Q}>wMSep-1A^_pfb5x`#pyfU0%)8gtY0&(ZTRsuhah4=Hn#0eMxQs*<{>
> zQ0_uc^`>Q7K22IaFPl)-Kpp<G>DqvnEtV)x8RZirFz4%L%}n;rqax53IBEyJ7nE8g
> zwcA%dA?8MHxbXArWXHiCL;0Y?AesgNM}@(skaK(D5;q>w56K6HmDFoD9^Lk|Q(8^9
> znw!c3sRINPSsvnt<2;QKclU_3S;xtjup8`Ny2`ybGG`<vA>vyomKBe|q|%LjZt<1d
> zNq!Y*kMQ;tL367)p2sZx^6nn}fS(m?;#ioqIy^LTVc@^GPo_0u|7~|GGwXN9jr*66
> zm$~w9Y%6AgdBvX`-GswA6YSHq8R+Kyk#cxgdw-Y>&Cuf-ynCw@{nO6ESk{_U*K0%p
> zJ^ktf24}JI)j_!2Lfo#eO!1o>J;{3lnaRGft2?D4oqME0T=D^)u<n4 at IS4PoIfQRx
> zhSh{I=dVh5(Ra_-RJRso``l&7N8I&Patr1 at NFdj52iajZb(%n at GKRga85YkdQuwPO
> zVrxs+-kD8n?A_8acTp6esyAA4{x);>kw?=Bln7QsJm+=9$g{rnO$~U at KA0I#7ripS
> z8mvzz`IMaR9UQkk<s7`-f>!!GF#8Fl87aPd4gVweOn_ at zEA|DQ;SpK1d=ph#+47-5
> zj50Pui+lE}H at 83UZQ9-4or&ve<0U!<O*d%P=4+%A1Z~Ph+nj}BM?#wWSzd>6idV}e
> z_ac56HNwtx&25kMW0J#{Urbt$`}+=Cx9T1_JRMmC7S at pV^ZkODD+=dSXb5)`$%;23
> zbM)j!2Xuow4m3EJFS0(;Q`Hivzwi~vX60A?tJwF~^(QH}`kzP7(xjK`IUeLMCHB1H
> zNspKZ8rXadCHnXqf%Yy>0EK`)WN3i-3LS~{IYjYb4p-`+gj4?t2nA2BkpP at y87k`6
> zTX>A<B6)D|5LpqsKo-r0dMBco1Q5gHSN|#)<aIuZAe?IhyKaXXGAR(2b=|uUE>b>V
> zs?XH%0g2Hs1h=15<Au+Wo#ex22G_Z7XJN9WXcaL*Xrhz_`6}7vUz^%Us=xj}V)e~e
> zV`WvgqZ1--$a4D8`qAaw|C~s>5cAa5QN4ee at gRpF<At+4C>fPg`t+0}lYh;L5A^=T
> zz0I`u?{{F4Lfw3Xu|Rb1!ntS9(R&_5BNFXUgBr9SeetRgqY<a$%P)1Rfufg9Tpnct
> zVY1o+jpLq at 3(q-N+H~N}ksukYgicG%7Q!QEUB#zGGtll?&Xcg=cRkyko$5{fm(X)T
> zmhXBb+Z0a{t6ditcfjun+u?$VSgQ=sw84y2rO(dl!ee6{-q(-Djt3w at LE>ht7Z~2%
> z67v+H4UK&f?4hg0!PZ8b*Bpo1!fP8He#FTonAY;P^}qlY&32ZyC9(e}Rq#bUkt*xA
> zNt9hcO+q`W@(@8emP;^xR?8tl269*p(OmA^VDcW&ivZ&*`KLQ%XJ=r<l|f^z<_)Vq
> zZm>ty0UOsqcIMl#vFhJ%c>1Sr0iJ>Jo9FL04E*U!;vywEY!{9ZUjnk!f`|F4jQdA_
> zoq8BR%cqmEdUPj1S^a6|JL at o3<Lja2!8eJ5B#vrAFVTEe!B63{5&cR`O-#)O)6m7#
> z4(3sFhAPTh^(I7};LwuN|CZ$S+25h1#;5(;mo-IEcRPEkqovpwsy!-CT{RKfI4S{{
> z7OFI&u@{i(-&nQBytWXZJ#Q^tgWhMQBMU9$(Tc9|YwqM>qbg*3f#!wEw54Y(QqfzO
> z!rcwjcj62+=FOA$izeAHAA?*eje(>69rb2L?_0y#RM$0(qo~Ao^4rC<tRzn=Ns1r7
> zg0HULb@#aYtHG=B$$(*%l9C9MY&L#nHqt6|<R{gs$AHss>8xU%R(ca-4e`yw9C7ld
> z-$bMUOZmC*R5nXmE%S3qRCo9~qH(^#ll+-NvkIta!5rQqnIkGo at ak_ApP$^zT8x=v
> z-gkR`<jI^^Gl%)=J4ZsYKZZ@*SJeu{kAe%15L_KRisa(tas%kj#g6`(BZ|W=bov=J
> zk6(5%^4y9ADvab+;O_+)S{{<GS6TejP*P=5(z^CcTjl)J`6k+Px0H))RL`}1+ebDo
> z(rc9qK7lW;B`ng*3qA=+<&24Fa4fs~Ap(a*BkLuX_J!gi{p at PbAhs2k_5br-|38={
> zi+ at b3tUpafK~^it|L*M7$X!qWee$aMaW>nbx|NRyA7eo+<eAxIJv~td%&#o4j+3}w
> ziw)0c9RwSFtwn=p=!;LZpK-N*ptuNKzg*Na^%tB1 at y##p&z;b^!DQHFoosj^HNp1F
> z_ at 2~8JkG*B>L*osc%nmqTSv16m$kmlyL_>MLS{+kqAw?oHy$uMQC>fMEpS~d%!>5M
> z`$Qf8fjfaKCy1V$x=|;?0<<6!PvWqkWPSn?xmJl(VZsOrs)?+au&;~?&=5vI|I!*t
> zZ2rJ;;Knp$Ln=>RY0%jhrok;AXxL=Q6T8->27*vBR7%(!rDw`Ht9NSWyha<c>^3R|
> zh11Lbpr0y}Ye>R>?oGQHRT at Sc4|xs4nb5zQt>g%M&x36o1rR=A_rm$AV|}9FaTZ_+
> zSRLixbwg&}91(x<KXP}a|HS`T`NLuZj|ISYap<C;Q?5YPwJB*!%?}WJb&*HE0GLp@
> zYp83r;^yrpe^RV%jIMVa(N=Du37sjvEQHEssV09ADX$g;x(&ShJNc-;$W`TKuR#%5
> zJqWLXNjlbvC4ClaD*8Y+>(m4|Y5O%Dn3v>=IA)%Kt^StSiGF|`s>LFrnZMKn_AQ6m
> zDh(#}N8J?ruezx}yZ4~q-FpNJYJ<idsJQBd_6ScQ+d%}Os2QUU at EZrEzKBz>Z8EgG
> zO~D-boILw78&&eFc<S15V2hsTPb%|Ourh4*cBPiw1p}3aR^q=*yk|Gcv4q~1r3%P+
> zx#PFlokijG!7E`?|5U#J2RDEc26IzR1OUq9S(dwex<gffm^UCJs;(aXd>#c9Q(66o
> zh$xbM=s~?IP}f=htFj;1%>X6vuQqQHzx?^Ll$PtTmf{8u1d;xC!S8hA&W>t|HY&q?
> z%<Ucsr;iN7Qks7+?MLA at C;!}S#HUZ}&qCm{CsJC<sdv;JrvNE~_+xI{thTBc6;JU-
> z)YJaZfuP6aM3OFsmLX;SHz{w?*=+OJg?475RJX$OQ^I+)!Av at 8cipl};0dvP*LuBd
> zzkY2sNfe7*(`&!q&5FM(e50W5aS at q|^l6P<F~z1n at Us(p$=Diuyc~zwpd=p`D<(GL
> z at Fl0ld_H<@c5{~~*H=^C-yuc2x?|)l_Huqw|LM+;*yfp&Tg;3?blms)&7DX&E)G#p
> zx=ZNY3ZDeCo^K{urVB)%H2>E8)yRf>(dm4jdmN^{VawxhfO#C}e`8^@QGnU)EbZcT
> zur#miHC-)g4^O|xJRm38aUwv_0X9R?DL>o)17_#{#HQ){PXFBVkmrNRw&MazAGL(@
> z6vnDoe_%grduR%z8#;=7G6-We9boLFYU*m at YU10Y5;^k>nhlgO?e;=}oxMq|fx!p^
> z4?T`(oA#XT9tkqw4As)6lUZH6$rT*cM-AF&e`V*<51=0<$s3z6{46%rAeaXqq&~3p
> zpnMXOcwuhQ)z$+(1NPKd+nqAslgS;Ma6A?)4@)dFOEMcMGQ<6rVIp_uL_yx12o;rj
> z;ocT?r&R&jH*+9J!@ckbRN`;fav=?}d9i0YCU!R%(qlVi=VXfjnxzebz5gk<_&-8^
> zXCBi6A?2It24|c-i~3&)pcV6MUeDWF@|e{Rf4s9hQMYVUKTcy`_2ssf&E3EwL*|KI
> ze*89t;jE`5%4Pd(CzHoq50Jd->Y2qO!<;wZlOgMyu=0jTV&zF(83Pz6w(*n7f-r+h
> zCxly#Cps*_F8in59K#zb at a7(00+Q$L8s`9rFvMt)G7hE}=u;pJ=>fn;WoO~B&X9X+
> zBtk(Gxm1Z^O^0kgz;*2&sy)b6I)0niiCpn(K`-66J=$S56yG;ucG?*zs6#Kn3<=yJ
> z2i4k=!Jkok at n}rE-_3R>oLZFG$%LE)uXbk-BYwWb<5z-Sdum!5y7!YJRgEope&3(|
> z6;tW2uG8oh^2Dagj5dgqfm(>io8s8y2q0N at 1&10dGkTLG4KKCoRM5=J41MjupJf*o
> zAE!jiM&mv)JQ&$}K~|^U!*1u8vs*Iy>5SBI&8`}$U%cfBXTY6SZ9HrQ4GfZ)jS#N#
> zwHg<;cKeKfp>F*T`E{-{e(Z|hTzmi+vX1#q<2&usN?(F-W6LoM`^Z%XtkK3H4vmF}
> zYqVg`^1J1;`hOjDne3 at 8Q=2P<o$CUNht#FNT0-$qWTCAfPAKP$_3Vm85aNQGICos-
> z#MP^4V`1UL(b;PubS57=F5!PbrP6UvuALMX)9vFOT_2|S&l at r0kGxY?kd8(*)6a`3
> zfgsKSQx(@L|MA}>i!^na9^9G>QBv+yFA(BXN6|noj=*1dJOyyM*vo%4a at 2qGS@P5m
> zPtAU{#|)K at c3yc-cOE$6`e6arHo_V2%IfmNeC~PPC!Rq#IVx;KMp>oY%AKf at VgQJp
> z8VdLs1O~zA$Wb#>8!Qqz+TE+D%g?v0CKi+PK8)(ZEgtk3>@@0O|62f<knjO<0Q|h>
> zQe548&*OwZ<O1ZkicYba9oCKvB)UHoMAg6 at bO9HX0t@wiC@*?fD5J<4l@{QC9Tb35
> zK;HazBTreWOMslN)%5<mOTyZhTYk>wD~L5{XbY5giR)FudafbDuXfL9_c@<9QH0W!
> z;@*g25`GhO`>H(RP32dYn(DU_Odq+aYfkI78-e8B1Hn%kbX2qaR+rij{_CEs4xGIj
> zsHcq&MINpc$lc3?uUM6ex7ZW>f3&m at Kt^Ui0&BUJ`TDQGN;KzQ%&mUTb)XrYhA6oR
> z_LwY;g@;YHrgN~TD7KO{&bhjAZoIvFukTVSHZ+FaaOza|%Sv2wYdRM?=rXqWW{ZZ<
> z;Fmq#=gp>UqX_?x0 at 0|0M}0TXgadx)6;#1|WQQ;~&0ng0dwdep(P4Ck9N(5=Iq59j
> z5e>Hbc3E=MNU4P<;*PE==lQO7`raU67MzO=8W~aM<YNsYfv)Wu%Hk;LPiFWTpN_26
> z=%Y(_iTz7oUvR$A?VuerAA at kAY=QT|@MUZNEZFelJl(4waW!9}-TDPYWWCg at rtot<
> z{GNVO;tT9iZ at BKivRAU_4OU@EA;Gwl=cN;s#hcoW5HFXw%%o_{$LAfZ!170a{6NP}
> zyO%Lj`^SUk=a+%l_xe9SOkUhldz{Wem-^#`u}RSr9r}w&zODtV;Vr&AKwAzX|6KpZ
> zO(3BZ-S#E-%NVK!bz0-1!A*<G$JMb+%v-L8yl?2jJ>OCe^){RA$5O3^MKrsPVCfxM
> z$@ZMzgYW4x8+6-13de)`6V=2qM(6w|JD$VBgT%8T>l6EXnW~oDB8Qy|hw6zsCf{%5
> z(Z-#Gu2Z at pCBBKcYb~*a<klNK4+tLuPxTb$^%1;>UEIPiJWtnfl%`+sUf+Px{-kn1
> z0o3giB=%!iXxZoZyJ^>leQMFWQc{L=Gj1nxX%?;*Fay(+nACPQElX(~@)g%XXWBT?
> zz(12eR2B at FnOP;(mbC!8`%$JQg}@nA6u7qPwL(6Za7r+%`7|ge+AcCn?S-gvq2cW1
> zUOVefHs--h!wzjeo<Z4i#sQw&`VVbUEa16Ml~>je`fyV(mif+9LP)6q2kjymhTdlu
> z8;K#A&u?$m`yKR84E+}GJJ-Pe61L;?YZD+H#yCTyJa%=$=9jFynpq0nE1AC&0NH3{
> z2Q#)2X+q$e1iOM>F+G=xF3SRti+AWGbaoIgOzNP5 at ZgftB=)S_@~YqYFGVaBR}clH
> zej@?6!Xr(;RG?vlzAs0}J=5AtyVk5GkA1dnAQ_N=ckMSlDkJw8brrR<Qz!`;CU|gF
> zsT!yxEjnW;#lkjq9$|e8_p3+hKdhNEy+3DKzyTJPlPT`r>3SuQvMkRy62r3VbE^Cg
> z20T&;T~5tg^s4eZ^`zDN$O6&Q+3v3zqmH27<rqV#JfSJ#<`-)ODQ3UNTpuemi+68h
> zUM~WcNz8t)`L4R(^Ae~F<$Q;@t(cVJFI at ZqPwone#FD;Z8RS8DrQ1$s2bdADg$LU0
> zI6aP~e&HkZyv_!9zyUalBClGpHHZNnT}0V>>u<{{y$*^`rT7pbG$R$3r;kwIDJ{5K
> zNly%qy3H2s)rZw at oecZS@(+0;J1gFm(4_Ad<mLoVS@*jYDc?U9$;@m0Yry6|Kd0!P
> zdcp5*ktNq;9&cuE%X)0Co at YgCwOlEmuxwY#sFQA{ahF^v*#c{lhYDyj3lqU$f^0dm
> z(Gy^SKo_9n$H^avR6#c?XVaD%fxpIs(TjW%%A?%FeA|4!E?C2*S&CS=8%yAbQF6Gc
> z`l)vCE#OKlDFAaK9L&jwfbrFX`5`FSx3fQt2ts}>x4MYA#-Jn9T4dvIO7B1(@KKaE
> z%y#;^Fo|Wk at thmRfI^p{64pg|(y;!*zUO_{PbwdPpKXUTVp at 0biL*2TViDn&hu$Wq
> zjLp!KIbIct+?boGDKpUxHg)LDJBj_X-&m~#ZJ*zuz7*TJdR>{dJmb4*T}8-Rx3lwm
> z{_4u4D{(DX!XL1PFue1>6r!!ZjyF2^N`C7DriQG+&QaLMj0y-`@B3j{lc9p`@0j#u
> zrG##&9*XvPR!tJ!uB!)pE_>P-en)eS`8nRJ?(NwR0}BO3qx}UMu-8 at Y^r?@?iS|z_
> zk^$;cPYpQ!+Tm*~|4 at z~bRN)L_zDSyUV+RI5SY{?phnvJMVESVQilP`^M2gDfR`}=
> zA__RB?{P*8?yay;(1ivTXQUk#MemeyX|_Uq^mUH|xXzDpM{!7*w^7Y}Ub+9Qo#!fa
> zM-i?oftm~IUuL?5InyEf@!)Hnimof5{J#|7%DO~#PCJ0BiL*@sXzBIvUqz6=Ur+xO
> z8^+K(>oLa+RKiJx)$z{5x&2EdSep5`M}v$Dbq`(T*3CYkW^Ah&P at 5O%2EVW_DrB+w
> z9{b4U>iG!#{*!Xfjb$p(7o7!l=M?~k+&*x`qdHKaB8wpAOoHT$COLneD@#ZOUFYGO
> zWUE5m*mr-AZUgpm7H8PgQCo_pD9vi}7SvSX+LNC>SllvMvd3uqi*qT{Z1282F2!s!
> zuW0b#g44q=n_?|G11>*woE;p_#fS`hPjJxS*VD=CK(1p>ZzQ__%W)N!T)4jhA0e2x
> z=<P2Q+MxwhbT+{@J$PviZjuTP-n{*)#ywPxE2rc0(<J>cL*%u&Q*qi9VHZ!MuRK)Z
> zbyR1tC=0e5QOwKw5aduUgNJcQiO#lM{*46IOGQatz!qip^q+C+{^J^(jnV#-qI&_<
> zB97{jF-vE6L4q*>ZGf0ur2UogcCWU;vpX!@)Z~dBFpK4_A4+_QOLnG<4pYy*e=5{o
> zUNYKb#K9>n{cmuDw7TECTU<Zqysx12UvrzhimdhB?>PQ$$6LQXzv+j;4dmFXR3jW0
> z$WdQlcr0msUuXVQ(x8rlW at i_uI0%e|Gj$0r<n{=IH;5^u2=yLEqV8Sekt4*9DZ#zx
> zxQ;j9yxNz!U}c5IGe#4m(X-i3T2gU3-6oc_HKHibWv&VHy<T4xP>AV+G&`02a)}`_
> z517&?HkHo)k*EnznhpGc{z4FMi7VcFTzCegcNC>?!89!!KI}D{vHWr at NIdOoX5TCT
> zny>(?BPI)zyK#Jp5Q{-xfHhlJmlc~$5H!j0aMkYE$KthpSXGaqdT0ef+br-Fy_-iT
> z4JR at dXn8Ef`6 at w}mIu+?(1<H8J$-pDW(vJFr5utQ5xQVjP3ld<ah%0vJ7IP#__|sA
> zoKrkU#DlAKDZ(X=xiZKMt}k)dVy(8)!|W_p-aUk}9hN0U%#R&Z_t1RGeEGxJlIL&z
> zS^)L>8(;Tt&jFEy4=byQv<}F^hm{(OI at dr=;w7Z97GvG1{9$IbFjUYt?m(2?a;w=*
> z_>D2-I}%WyKs!aaSzy&86%k~Lbw6{fW8qD9_|{1h?@dJ8`rfmGI9(nrSC-SU!@7;3
> z;*}n}+kW0>;s#|uf8LJZF5cd~zoKnaUqsn=ARywUezEVOm%Tvkt5 at J)vC7b$>xW>M
> z<sH^pg3k{?&|_hipu<eLjU0_GToD;VO|vcjq{@FFMLGg3bq>V=Fxcm|BTy@#pHxDK
> zpHu=+eV`%lmk2V45a4Yq!FKFHxb=*mR9amqTnvcx0aDD(LClPPOCHcUjt8nd`VpiQ
> z$Px(8L<pq31j>&bfkS5jMN(OT4S2ef_<^8G$QY2HuL12 at ef&vv8UuW5;_<*YSk13z
> zVTI)@|HqR&`rilnpC1v^IUsg_XxUL<Nk(Gt9x8-rUCXv%Ip5ipe&bv1!|db4N1KqM
> z+TY*!yJxa0rdDimxiCAxxzi^#`TMo3&H|X<ksNUFV~m(!O&TzV=!^40!!C8!^Yx)i
> z2A227z69T at ypNJh+&2$tU=5Nd1h_5|gc~UraYGxYhsN(;F<euXtD0$9Yp<uXCBidu
> z&A+|smcH+fF^PhBC-%cmzFQnqe9p?xF)au~dDL?Fdh|n|55Az9Pm0_#y8oYk&L2rD
> z(Hyq-7pVC&a*eN_8T$Yhk)H>hhdD at v%(4omVB0~=W#ZG?nn}YFvBi>I%kgr84{G*o
> zou~2{LOiec7u!M3YS#rgwdn>FrjDiZp3&0K`(a|8QUg{{(*)MoD8U@&akYULpBuf$
> z?v)rhr|EYgkU5bPUdXa-^BgvpT(F}IiC&WH??&Mw7G7>a$Gb>{`-pCX at ri5tz<d{9
> zUVG+ir0Ay^^br!T(=#&16P}H{Dr*y?zvJ+4FBmq&e_3 at 7|GQ%T=U2 at ChsLZM)+A-8
> ztC@`TQnSWm&Sq1<E|;M9R%U=~ScprI;Lu_W<br=~dxMa at OW7SY_GeYtkQ1fHJ3P=-
> z3jF<#)Wn?Ag{fx(pOoh`9jPn&Xa-HfKFVh`DxVbfx+;5A4Q?uJZ{Vf$&z_=ilz9=P
> zFozL)Y1)^|<vF6Jrt{jFgcC~h)Eh4anwPj(ErW`cs8py#oo6$`vu>!BWoFh2+O0h!
> zSSa~>nuJ7d#OdSCi5R~`v at Rt@irYN{+{+VXD9`G8t=I5k at 3@dVXyv at mkKB|`d at KC6
> zGAGdoXU9KYlvw0aLVoX`V8M72mgj>s1YzgWq$gMNpGr{LmfR)<0EY(;-+$k(YQCBr
> zIp<puAL0e!A>9~C8}tZaRsw3+gwH?1T6~O393XZuJ%ehsR>>zX4F~6N$xQ|1 at S06D
> zwNZqZ49n-d2NwV2DShN3y+>cFh%Fz8nquSr%H0XZLT(Vynz2Y>RbAo9DRi80#1rB(
> zRc`LmL6lG{CRO+`eC2!mit}7_kZhvW=WPmV-hA=?@DC_oTk-e2nt>Pb!xO*K?`^^2
> zxQ+vN1r)2A)Vv2)8dg&7?7Uw|>FoHp&|R`Qz3h=zwQA+?QcgE%=UO-~ob6D!g)INh
> zl9au9DJ1wCL?_NZp+HYI)dzeDyPYK!_CejqIoW<HE+(JowAJg>AQla!Lqpj=MAw{{
> zdKn@!Snp?KYpXfQwqV2YqUij?^XcX572 at Tr<{MS|JBSw^Qc at MZitkbo<u^iKnwn=;
> zXb4#X(duo at f8^ZU%ONH{Db%CC`FojNz1Em^0Jh#A^;Yu1rGzbN9SEAVk9<0u at ZNIO
> zMsU80tJoeB6TIHt0ro+BdRBI2t$lgHFZw6dlh#taLSbHIbX|*w&(%fnH+Z-8I6hW^
> z+2Ux|5_i=??K^5xXc=%=;qI$ICP#%VPKbE8CEUyhpz|sO_x9u8+7C?bh8R8Ca>hq3
> zOJwO8jknKUJO0JA&+G`}LT$^8yUV2`4 at X7;+%^wRZ^@am((dL<8tZ=tYp<QA!wg at X
> z>PAd{9s?BF9#0>0oT at GxaG(qli=$@}w{2(!9W1N*hF1KK%_BlHHiZ&mj~y-qpCPd|
> zV^UWZ6=3^-Z3UjA<Hu|%vIRsihe{0l_yZ?5jq|R*OQ7^WZGB|v>*wx77Q(eP#R;gs
> zG3}0DjU+5%7Na7+E?QQqEtdzs#Jo02W;xmZe9nA*N?lv-X`bc-P%n>8^8+x`BQr>n
> z>4Ep7K<%AG08ERIpZ$KoO{aQ}4=Z04{`IQ)>4waj(~T42oB4=0b{utGwZAASzeI=r
> ze*3-ARm0DUdl}KJ!tU=D4!&?(REfHIj!alBT;?a1FFz+dsq{)&XjNy<>{`vgXRdJ@
> z5LEmG;v=0y2VL<w|G5|+7Tp!vJ7$}%4BcAnpX#vLKLQk0U$RfI#^vKfrjA at R!Q(Hz
> z`pLfX#~-m at i9%{|)E!vJX_EG?hcq?39{Qkl%t_v%Up at dDvBz<iz|~Y|ADIhLX%2iK
> zkcm*g<><Tl)KI*T*dON}B;n}j+38a}$A@|h;JKwKrJo5Z=sVTtqn~Os!@h0(q?!mR
> za1NQ9slHq at 3J-4>l)Ce%u{Vg;j>BXscRR5mbmnXa{U*C<F>0B at 544Qs`-a&bUpwoQ
> zX^a)Dux%<OC!%Qh!8>EVy--9D6|RX8fRnm`dpeB1r++Fn=SOJwj9|KM!`4!}+IOE#
> z2v?Bu1B+YKXXv>2$`6fRjv5JRWTlWn;m^t(_0!LnRjgOez?AWz5Gzm<p?b9IYeTnz
> z5(=7KKRQ&2Qufi`(nuS8BH;?^wNALoz%VCwede}Zxt}j~fomT*Bm(v(aVvyG>)2ff
> z>Zy^_x#lKn(pe2pGhdv0(L#4LB2Jbv81a6a2EO~Xbht>8HK(n7_{#kp)A7WYw82_7
> znen=X(oSpN3B(S>*X at l>tYvjBy!o2H>Ye0x4@^%*IZd4ZtMFGoo1DnheI!9hG0dR~
> zM$l=vx_)d0Yn12Z<8Ic-5qJxJha7IEUc09IO~(oMO-&}z+%N4UOajcm<dMo9XPeV&
> zdY1dh27GJ)?*bff+FC(P_n4dD4S!WQSt18$fnv>kENSqQ>J>nzTj(Y~9cu{r<@;N~
> z*35vj8n7Kl*oS4Hg_{ay`<M=J?Q?+x1cU{D5i{ugMKoZ(uH8mi$pQrIyp1W at 3#eV-
> zexc+eIOXyzGwcVLVgRPxA|?OzSA#L=o0PZlFbog)NET(GAa$tqD-eP23j?G~1o%h}
> z^&LFVi#sIK01r9 at 9PlpKU&KE^M%f#@Qmsfi4;YYm@%=v@;8z^-lgh*sas<StfK%J@
> zzfbY+js*&M*G<yi?~$;1SA4v2L*<&;P>VjW{T&WjDFLk|o%bDnf5(8n=oiMW_?j$2
> z52*vhtQ4$D1_}ayk2Qm&Fw6wu?F}-fFz at rorkXzXjVY7){Sk&6%*3R5wHOrz4CIl&
> zT~h-K4i=Go8<!j5ZN#*S1yv8Z3{G3VkoASXpJOsK at NQ#0rg(p{tuNv;4{e5>NP%af
> zx2KMIP{NIK_rC7gG0T+`4 at tjGRP%VR>QT`|T8KAveEx@~^zWEhHg0&re0H{5!h0?b
> znJv1QktSy|KKnX^q(4$OQI?)0&TxSK9`&NU*9;-Exmbm=m+Maqx`&xnQ9M%C7)Pem
> z8O)hpMG}h^j?Gsj3p0!I#_uqxn5V4STzHUedk56qV9A?EG>q6*6Yhv>7Tms1I&_aX
> z<8G<2%w2!hZ-yIpK756RNoK=&&2BDdw=&?m*Q(_)?3J1F-3_W>@t&+$ZP|J_>O09S
> z-wZAu+fFcQ(Wbq at PjX(7U^J9zV>drl;AnB~ts6(=_C`@%IV3qJ*oKidKMMc=-c-fh
> z&sP}Fa%3Oj;$64DK3~|zch18s;f#6d$;VI!o1i{yUS?$JU$9O7EiCb$S5yB_{k{_%
> zTv4ME3xToqGM2 at wcR#-s@!vESnObe>Pt5A_S*MXGd{NznOeH}u at zM#LM;apsY~*)w
> zR}>b|Y0ej!Q;Qxv^H{avQ>E*J4-?Ga2);^jM5Hzd;?5 at ppuAFv<_IkureRo7Gq&~z
> zdc`JpZZUB>>S6q*)v-U98tHw+f-~?>%(Nc9QdHWOl91=Qi;(j-Z*1od6T15F_~LPB
> zvj(4Z_G4kg{U46dbN93Rljtxu8Cfgh7lb(QNK47?5!DBvRD1+q4_9F4$d8TN9$Gut
> z$UX5}xKRGoQTxRAZ%k=&yk#yiFexL8GK`XM9_?Oh4}6fs5hA+x;`x5gm(u2c${+~)
> zRmUzb6XA5*+3VEKm4QmG`MQ=?_EY*gN1nP!NV at bL{6w|2cB}6Bqd;@MD+pPK!N-Jc
> zJGuU7HG5#dk{6W07DtdaJ{m{2obSI;=w?v5`$*<Dp>b78dq|;?Aoh}4#Y6zDQ<Uyj
> z&#H&78lJ^7-B&{TleXZPA#$k%^?G`EJ)}AP)YC6N-oK_IqKD|`Sc$iU&L3S|FGHLX
> z0H{%gG<+kAm=Zy*nT}}(=+*9WIzBs&rWw9-I-qWC at bSo=Td3V)2m4fPWb1(U<ue}h
> z(!qF}#79r;=z;#Oo6?*{PvA?2;`4Nod6Q4-vjguqd~vouC37zePUX>SY22aiJQebT
> zR8x19tr96xDE$vd%Wi13Na at p=^+fV`N6xc}-fCyN4vRf{b5Dd`BdTKdJXXzI-QSw8
> z&+_#`ibIcv%%IJE2kvVrgvkyY);LpXne>MJV|C=px~#HzpLlbf*4%!Yz!i<m1}TM}
> z`rMnxrZ1FwA5QszrF`Ht-`!^q4Wf=O)_x*fxr>5KD`<o_j5QDf8$5&F!59z*gdn?W
> z(?#n33}jr4rsGV<p1l$KJg%;8nn}D7%9$kku+ at Qzfymr^(OHZ2A at Y$GGNO)uK`+<Q
> zidpYao%z<ew)2efQ|R$U<-pIt&}hsrM#T?r$oVsL at M-zp$)_ib8bmjACe!4&Y1e9t
> zZ-}&aQhdIP at Aj71_suvChknW_hF|?_(B=P?&+9-BBW~)!LS6Q|a~|f>XD{=miON|y
> z*qsQJxspnKe`i(m<q<3T at j%pG!P40dekwDQ><_a#yh<B={6sFVZiY&x1h$AyI*hgX
> zctAhvVkli~O4tqI+q=5ug|fEaPPZ(A!kjzUe at IJ<*+)s0>t)3R6lXE=xmx}9d7qU!
> z(oat&QmoIn8IWK3hf&f$ik|*|a{k1_i*_+GCMFMAt`B`nyQ*y3As_8ww?y+!JkP!}
> z at 8Y=@rJ`lVG;a^XGjq8E1Ep2en~`~PN{0^c?%IRU)RUZ_- at 14kADJ<Qs4G3$zc95>
> zToz_}sM#N6w!nT_;YFQU$#vDpG&{x at C#@U>zx6<*6Am96x0Ib>5}SBgnIppEW!Nt6
> zT at +A~28`k7>;EiEYx3}-g~$nZE{hB`?gUbGv1}dww*7uyf}1l#%+-Z0 at 1IoCpagSu
> zk4%1+L>e4Y%ij-FdoN{j3FA!v<Mux8C`~W$TCce#9D0lE*etCgvS3OC9OjF%=jv-R
> z5k!IgQeI;+KLAvhLc!`-*WB05FA^(RRj<!~zI70zWk|<1aQZ%eecoQtx0T9m)x?Av
> zUM%6{srU=BIQI{qdKADjg!$6MqVR4vsEV)B+_vXSlr`6Wm-eA!dd%H)ho;S=Cj3=g
> zd;*o-XYo<N*NRU4aYF*6PiP4X2FvsVI)!}wC;qP**xzI?Qs+yMq%L-9TvtXyoT+Qc
> z_j3h9LMcU0s?AO**26vU>JHpi^H;s)qnpM~f9W1<yCZU%if=!c?JMJ<wwHO<YwFHz
> zYwtXfVrE49QhdR_oh{sn>ZIj8&gJ4u7XF-U!-?<<CRJs|KpTMnJ5oab_C4Yl)TH=9
> z0)BgAHvqRlkTS%5&f;sRoOQN#8hvns+sn1mAzAJ*%W{QRY~!lcgK&)`MrN^nD4R2B
> z8m=neD`G$Pz}6X(q)=ZzopX%vG={vUqcE7_G578hj4;xs<V}UW$3$4p5E!$F;4P8C
> zxW9VLr+Lx-5O5^Tzr&E at I=kR1!ZzW}IA|BhUr>Xe<sktOhQa{B+lUUYLum=HJgus@
> z3VI(GJ$(C8k`-Uw99bL)Hi4dFRXFz!A~BkYk-MLs&^I%=d0~~qP4EHs<V{`LPm(ys
> zhanjeR(3-5JhhQKQ?6QuspRE>&v0`wY*3bTQQkoQwtBn)WGHt&*h@=>k?p8vXnm!>
> z_{@`!WzS9XKG9A9#j`5XCnf%qrC_c;k6?L9Ig8`_Hjg+r!wc3NESg!P%>6bPV0@`Z
> zVfbVW)e7~O at H+8>4^)&!6sOm0vm)wPv=G5 at Z!kmUZKnH{&bOBFU^S?7c=KIX?Q9H(
> z>!zr{ruRPj+uJ$hMD3h;tNWW2htN7U?B~%s{k$W at qmqjfdwlN6+}*QkU&YQ`ky)%Y
> zAIQ_C6IMg-4iTAxW^s36;g_qshD#B|Q`YD`F@!hSd6{6OTKoYcXjY(`FP}pc9%)!!
> zN8JLSk?o_M7gP3yn0UQfY0vWEv8+wIH8~x{R?IfkkhKCd?+V3z%8ZO2Ln=4Y2w!<2
> zkckq8YCxwE92#s;bh;w$)Jq@*6k$H00r%rE8*;iBJlWU%qkTC*Kf%PaBNGi*1Vml1
> zpQ2EtE3@=C)w7aBbse%sAiB#O>rxW^z$D(!aMD+Ug=JpB;6_<qpGlpi(exU8N<|z`
> zN8vNTuPAHdlAAw`1BA^t1}o|w>F(+t0AkzH162vR>2Hcr2rlaZqQlC>5bRVAIrk8N
> zPVp=|;H6~B2`J{SVIQX}EfHox(t;2~%{$Bh{=q9#j3EaX at Y}3$YuDEgN at L22@|b#)
> zU<b at rSdq<Xlcj at Z#y4gHVg>ydtAA0}(m&Uy=DwB=h>!a;TkAY+>9ry&DcZQS<;*a-
> zII}jHPV)ueNtWh@*Lf5X+^q<a-eh;(`jnnK<r<)20qI_r_X{RnZr#tiwKe%?>ak54
> za=61*sqp6xQEI|a9|+T$h)w(M#?H-U5!>v|*n1I|Vy>@3B4O+(yZ#B)HgGw(70L1x
> z!j#=GAP- at 8;y4a&@eehG_l8^M3q)6_H<v8l=Q)pXB0nU5sN<iPqK3AlQ{(*JdM^zI
> zY2{4xu<hrkD+g6LF1(|{mx at 2bzB34@=5zfp?@=yl`*f$tra!T8eB5ce0$dPeiaUHM
> zYk0BAuH<(AI%i6Z*t3J--0oDK?4w6)f{p^^Zs^kC!{<O*Zy6=vANp0lIIQ9?2|4qw
> zI!%bu2!Pn=sOv77li}|~G%b(8F#fiq=`K+4g_<^BG&F>{9;yNQ^;+%#XyGeM%yqjL
> z*K#0yFx)l3>r|NM5wccluiqkyBjnRPo<I_Yqhusz^wzqUx6ZN=fb>ibg0~4^<CtSa
> z>2gVW+o&VicnY5-ewGqu^a at 1~Z}^38-~opBMs8gL7LccWofi9(N)Cl%Ib at 0?0ZIZ9
> zi6r00!j$unS6CV~NAvn`KdFq;0+5qqZ#gw>b+=<<Mm83CG+%u`st<*3B7I!9DLOwE
> z)Qn&DsppP-3`(jWsjNp`(G$t6FI~CuZ<*CaHP?A1(q-JoHa^j`k%t3&Z{HryXjo~n
> zbb9 at y3OYtNp-PN4J@D7C%bUDK{`ze-I-zB~lKm}SYaSYK2Q|;yoVGH(qCtZzv2Wg!
> zK6#4wwk?eXX$YnBWgX^LL`*EGQKvpRQczTE(Ny95Elqnmy*?RoZO=E;_gTwR;mP9x
> z7WTJ-m4U}Y_Lr0-+CBO-%2%(=!{6`EP6{7*<Ipkkh_ma6^M;7xRmIW=PVBiY$FIV<
> zGQD^rA4rTFa^30_2t?QU3%9595yEi&xA76Lw)+Y((^`yUGr{S%f)>x*O)C-mx^TXe
> zR~&CNkKPC%>iFj#<N|_gu8f%B<O!j|`Q97A5LdaMa~wGO+T$Y-ThUQvW>rWNat%mH
> zf=U%%1!>Jmjd?X{FyY-&CyZW~)jqIoD8JSrmDH;iN5!XL at 5bXvkBsZwb?Ik`&evzr
> zNn$t%Dz at qCG28q`K0A+ysH2a2Hp<8w_XKvob=bo+q9RA*?%bkq&*^+|UBN=%`t;n|
> z0YKF<cenHJI|9FL-D~VOp3R~53@<JO+D67I<P<rXsTii6*h*j9 at re}aC{#U1b&P&n
> zxv7pj<1G3J)P_1aZC#hCG&o9ra;9~TswYv6h{nP;6Y(EgAuM1Q5ZhBa<62;LgIg|s
> zT&?j<EwyEq<&f!8z9anr;rHFs<7Fx}{Bxb?uWaOq*^uU_JSuYZ;9|BbTiXnRBmDbH
> z3`4DOiW at 89_9ikk$T+6WHdmioQ%~C06$QQvGizx~XYG`|D)gvryzJ|~jPcT|%XCsD
> zX&;S0)|goJ4d~WdBZ>!Po>pG4R400Gn%rf_gnebwbR%$rlAY2Uwj|2)N!b8w^0#r)
> ze`gJY;RI2m4$pfW%@Bs{*eV9O+NlK}>}Gm<-PPIGUjtmSE^baAm}@wz&3{LU<}>&w
> zZ43I?dmS7{lDf#rU{@3`P+n2sT1SKJ<!`dMm!9+4 at YpIvqPW$weE7QVx2V!v3h!U#
> zzDzBKe$dvxEU>UVG*K&Chh~0nd@#&Avbn3eW3^46@`&8PHKSNjqnfFAo5A8J{-Bt!
> zSP(=@PQl_0UpnVN2r-BELRxND4BG}=_I2Inm(9w0WEb7%=hNnGC*%Ef*xsVB%&t%c
> zPguLJriN#;2FOpr*WkB}LpLF>!MGhboRL!k0|^7kU}6%VXGH;^SaM7MCCZhCRWcm>
> zw4WFHBb^W5b{Mrc%dqO6IX&6tQX^3}Q22)3YWsq|u(IY4crG$5*~11BgS^Q4amjDm
> z(%x&SBweX{m&c^#hx><FAN$Peg9`Ph9dePL)oZGzg{#H~09nP9DlhH5ZWESQRyp5^
> zi<N_pC!KjH<u-F_kR8!7hz3X3nr7L|CyC!a(0RSrl_WlCw4uLRS0VOA!+*|RO?t(7
> zhNOygOc%wmN6)*mFU&lhD33C);5emVq`-AY&At2uzgXkkivZ;E$AeBRpy`K)aLrTB
> zz~-*95sPuO)I`Q0u0xzcEP_NG-f;8s{24<<>DEVU0*R^<=!OHd>9J}Xf^G-Of#Lb6
> z)O;^r?0r>RuWnnLmub|j*qyf)4aF<Z7ujqAE~-`R|8}p3eRDg7)Iks?x{$O9NFwwp
> z;%x4q8k^%>uigRqVNH2ystxC*imDVL$syLB0R2>9sQ66Bld&K{y}N7mPO1`8Ul2=B
> zgXSsfk9a0VP*jtaiocRdBDZguNkZAyCYR#^^wV9#Rwe3hDfi!UcG<-vZr}A1b+EaG
> z)Y=F#=uZ!FCYlG)6TI*@@8KMx>- at -X=B<@J)s?D9>`@>eF6trF?#QNQNBXO;4>epQ
> z-NEU!p&|wexs4ac(R(7>d;?z^+SDtzjqiQ%{r-B2&c-9=InH?pagaq$(oiGmlIutT
> zSO_hFh3MR3 at v@ZN4>oBgO&?Ut{S>i~WdA5!n<r-E;Bdnf*WUr62h^Yn;S8kf1Kiiq
> zFwEuZYD>GolYO at S7>3CVKbwLUu6|w>^Dg`G21m<lX$-^4j>6*lNqPs9W}C<iGIKkW
> z4<}^ZIHrb{{7(L&lI^HGcu<zpy-2%MpKANL+Ws at rFc*E-SS#3rwDT9J==)PikyL>6
> z^5 at NC)0NC7kB`s<*FS!eS?`t76Z!OS#T4;Wg9F#kiW`@l9g$~cS~w+bB$s|aA9t3M
> zmHGWc8&%WBeV|L(2^ST>$etF-{FHL at V$$46lh!yYlI|vjm0F$c2!)4H7%l@$l~ewi
> zhX8ud<V}M=MH#)x)}AXdJ6>d>`L5}-nd3A6&PMh3`^XQ#YMaZM<u({sfHD&-Y3UMm
> zi=+e|?O$1iy+bCp;nVL$<jt*Ff9YOs#n#>Ek}kJaH2+Y1WD1Mv*c at Ra1OVNDB?#L;
> zscz&pLr84100Roh5QHQJ`KqGk6A8Bz@`Y9G55Y&uR;cv at Q&RsHfOXFUJqvoJNVMeU
> z%&&Da`BTmirZNeeRa^a!(;D1w%r4y!S95Bm(!KQfP^i**BSTOmUov;)TuQ>-<U5&>
> zVv&F8A0hb&`*^-(jMT<QEDSW3lUfrVZ(D4~HkcHtyAW&p=Kcx#lc^50JWooH7Oall
> z*$29nJL+e0ueLt9KcS?iQm<DMb)~l3K#)*6_7q^@+94;*J7&wS&YtU!D%)msEX3d+
> z9mr%%^m2aO1UXGXdXsK=EJ#Z0K*hI|COuiI6g3jVA at H2&miBt7aEL at 2>gEWRiRHVJ
> zgHmzg6MC`X>VP;uo4vb<i0oKFR%7dkUVsYuFBtoO=Q{K at kUTJ^r<-$A_kl0xqSxjB
> zI0IV>C;Pz39q4X6lJuq!Hi<em(GYHh90`8|9c)vQS(qvGBRFECjRMZ7O_XFmhoJYb
> zaCV+N?{eH1dvg4h?Ctx)?{l9DYBnMVAK at 71bQgZL>_QM(ufhl;LFa*u6PQ17!FVqU
> zs_Z8fnL{0#FQpfAzWGkNv9?KwTfbSd at 1w@|Jo2~U%%VdEW&4hb_-hM4siJ`_a3c{p
> zZr3q5K@!JFzJWPlh&{F9)1co%`uv|n((`hviDhG6%%$?pq38QIT9DKJffNQhobT~y
> zK*lxy%+dB65svmX9xj-AP3B&hCeXbJwlLfvlpaAjZ=jP)e%=G=Oa5INIF#laeg?3h
> zOyLc7Q7c0kA07$niAj>#YO;XYnxTL8<3oF(e>It{B5ng_u=*}5Hs)x}`89sK6?rm9
> z24_i#=zt0ilH{|a!s6C$*L_#X_Q;ds4-^res5NWO<>bMqQ2c&UxiG&zM#E9=Qrwf%
> zv-(0GFw-X19QtK5W=bb(-{)L{1>{_iv5OBm_3RV#w|SSNMgMyyGD`_*$<9ZJi3U1<
> zBTB<^N%P%;)qxzofG&%J8a<i%k;%ZaLEV)Du$~WyAhO)(s&cIF?>+nactUi3tzWP5
> z{_KiimG<gd`7KzJ9`w|^)40mEAeInV=~aIqXW0D>5N)8D`whXkCn~=ZWL&U*;en3e
> z^pBC0%lswbO7}Q9g+XE7K+2JpLQaj~zlGP{8b?1~w^6Y&1qbM*pl<FtCDzfjbPXn6
> zwMzA_AFUV!dhE;&Jm-yQK~CPBGipV$X=bc82v^~@N}n~k7OQDG9vG>^aYY}V9zK4-
> zS|$8de&6M4?|Dg0W&TLgS#l{*ssXSSgH99DFtoVeYO<dz)IL%xb`Dfd%!uQ--l{>}
> z#FXag$*eBEhd#JSfENYbB8PgfM?<%)Z<_rmf3W9>6jTlvm5;gK!?&O#=a^1ZUaBck
> z`$@%S&aK8ID|$Dw9$Pv|>Ibz+o%ZD6V0`3X8oq9LU#~y0Ij1^vGOosH!bVa;wQTdr
> z=<IF6P at 6(JJ;8k5ozqEr+G at 3iJ>DaKM$4&Su<p)pgH?B0Pqf{^3Oq))+ at vtv!(AiP
> ziR10Y00PGSUpY;mL-)u!)m%a)W($RJwSF9bYgDdlLn=;DWc$oOnOjE0rNk#(JW+T+
> z0h+{ec;M}_J*ak<xuW(`|DsKd56^TT*u=wly?2U$I4e%@Fk-eOJLX#4ldM)xEbei2
> z50G&4MBsLiFCzql#PN^kyeZ#-z-Xan4 at 3){MggN3T~3f|NAJ7SP4_hdv!0&!b>$m)
> zMj{v1h`=pj4 at BlDumcaQQ@9O6P>*X6CIhST33CLPR^y`o%~lGvt8JHi`As_?=fHsF
> zta$EDo(r-}tWn<byH!Pg7al(Cu7@~?ba+>S?K+j*n+(OiJKA$OwV5C-)?|Y!413p$
> zYJHE2`zIM6U~5YBU)x9eKfW{2#eK at mgqjv8+~--UGdg$=jL}H~U=?f=w<&L&j?5|a
> zJ$R4>UT0%>ew%jfu+qE>W4Z1-w2)TG>H5X^;3h)L|1tlNulO2#;%*Z8MT0a8uva7=
> zQX-v>^#Y<~#((>E-fZbD*^~rt^RVK54HOaOKi*&L6_Z~TFP2Qr5UKU9v+xCTz#gHF
> z^o&}VzW`bG&pkDiu=p)RK5{wtfE(yso=uWIUV|LF)FM|NXsjNm9Q8AS7c9Ye6j?}k
> z17%=zBq at zLILk~{z3&6)NPR+dY8r at f=K-uo9>Xl$5M~tl#cJ(2>O~z_!J7G*i}PE%
> zT9qk|x2R6^b?Pcnc?O!fAm}w%BRUE8IO1hP at O&CjCyj-Utg at X!1X4~og9?7QZ81<@
> zFDEgD`aLt>)7e!fYK at IMA}WR3qQM5G<wF~;b^1QM_4Q>pl(5$qPTspi#mPp@$0=eW
> zTC8;r#0fWHc|qzpb at G0HNLjv{q@<j<qd?+BAN!LhBDw-`&bY~g55TY!32lI9b8nUs
> z<wSYWKn3fHByj?r7C3GJI{ci at I~4jH`lb8j0x9OeXLv`DMwVefpR%54_6)G&KItN8
> z;XdsX>~I7?bH3L3Csq4;)vYTPAxaXqF{kaW=U+Tq at aY*9%?l+qw~WM_52ZWR&aaQ6
> zjKeN^Q#f;0Gl+s}>SAuVNSikxR+1jMx`CA>Ntm6NI^iGD0y{6cpT?&Zxn!-;J}?(N
> zQ1qfuy;%km;RFQTHbSNN+-9S*{w)R}Ym)|Ox!PduKJj;%_agn1?lQ5y<93dEVKj<D
> z7)|n={N*-~%&5*V5 at b4z_U?-xTFx<(-d8rkiRZoH<jdg=;E2-iX4hm|e-w;l1UfF;
> z9Y?f-7(6Ap=j!0{jqQ40#H79IKAL-H3EK~uSrA(A5KV#<PX7*m`%TgQ+fBZ{r<qB-
> zvLXwqA9yY`#tuA>CEc5YF at fErLIL9k)byU4nADj^Fg#dExtdaukw*w0o#1}_QYici
> zbz}f%wc`+DWqRP831tQg!WkggzjnG;-uGl;CIz=a62T?RP1DR+zfG+Gj1h~ClUW0(
> z{Kw~E_so*_t!StC$@a at v=?r$VV2vm3(w4`=xfOH5TC#`Z1`hq!chn(_L4ug8%PmE|
> zu#er(61lp(G-n2)9P2NaCf5y)qRaaS>&+<)QaBca;pp<><W}`yS>I{L<KM)&Ury04
> zMWf`|iZNh<2xx;m9}Q*X1_ELhf7M>Ge1+Q2nQc|6kJ7mW7{C)Q)Kiha0YeOh_G#(5
> z^0#sIyLuYokkKd?0M at m`EH_Do+Hm4?TMkAg*s+!d3OnsP8+~yc;Q?mXZ*}r_J&H*k
> z<(zWA at NlK)yy<vVhgq`S4-AwCr~k%dST=}b6k}6a%cY+fI9gL*oouvNP6QP<2ojR#
> zV01yseA0NSw{j9vEke at xHD=#p)~1G)*HK5=`_!^Vk0AU`vp8ee3kz4$Hw#Vd_PO?=
> z8$G!z16RQ6=Kbl{;CaZ`03i(${*5wFI!m}VZ~i(+E6<;~i5>NHP|n$T`lWr1XKoz*
> z1nuJ}K6<5g=WQbbuw!qmEPNXznHgP&Robsw%ayvU%Vb<6h}<{_`@XeRdE~3+0;3{0
> zG(9MGLB3g^7oWef?PMJFFiYZ5V1t7&duq|qy$z%@9GAR#h@)w<xe{trJ))*FSCJT!
> zoql=9OyrGlU94JU=<qk1Df0<4#iWVw4{VERBlVlv-F#eg at 6<d+slv^8&S~~(L4_z2
> zpc24v|LUDVje|!9(MW!CK1s=Rk^H|Xd((I*!@qBML}_Cx`#RZDmSl@;lO##Vo^>io
> zO!h2k7)!`HArvx|grv#7&)5}7*0GN<_I1WGhFQAL{@3$7*Zo|d`^EFT at d9H`=W)()
> z{C?l<w}$a%ko)Ev6D8ABG%b(nxQeYV!)Snypj`~!4g(=vXOb<cD_h``u!*L~w|o1S
> z_l(btTIU7D#ol1AK6qw+$~FH@;}I?SY`mGaR{-=BLy8!h%U_F&`7(4+pQS*w#k=gu
> z3_3pVeLP{R{khb2Cun6w{-#XcY=~FsY|>AKv|4LJA(?nxkeDgrImu_DVFnzvJ5j2x
> zJ_YL($n34QAWoe2<Da=H;TC*zqR{5SmDQ2P3fA!}6cI-<t{Kcp(=fv2n8Wy7CUX|z
> z6DmhWe&ozbBTuOHiv~|DXYXfGm6&hz#29dz-z<TLMyEg6&=$MnLCqY=%DeXA^w*f5
> z?0&z=%DH|vIg7NeH(!q&k<Y_>J9-5ufe})~B41Y$_k~icmETU^W8?#%$h7sQP3eJK
> z<MK6s4!#355%x$#FmT3q26QoQtpV_4^^Q61JgQmD-7aN%Eo8NoTyg)Kx~Y)ZDP#yU
> z&)5;jwtc$k0FWIV3}&t`a at J}V)8_o at Q6rLsU(+SKw?fL1$q2_8TBG4-c((Xk8O9m&
> zFG2(63U2vszBi7F!H*5ihF%JkUasN`Y68R9V#yG-4$J2L!o(LVKlN{|8p%FnT?h<A
> ze>hMiq69;pcVbUf;~6rTWfzHl?@RX^%ifrX_;Mc;6Uoz`3uZ3}JZfx}o({yR096ym
> z9xcA)F{C=l1teg{MFav)MxCPF8kE}tPAdAAM}%Jf at lHi6N;UUn_<~V8LNukbi6!=X
> z#3S0K?#bq(#^GvuUst0m`FA0^pJ;g>d|l#vajU6)?awMqwx{ug5qwDxa2JL!zHTX@
> znvrcM5gq`;LS!HQ3)+eGWFe65P1@!oNH0Q6y&lHZ{mZfjR;DU;<M#$%=7s)GY#GCm
> zCy(l`9)M{~fI3p56tdcN0X5RiN0`M1Dq`q~n$JWq(HrxHFy at i%Rv2F at Q{T|=PBMYl
> zo=xF*J4h4L6EaH}4{==o3!0Fkz|K5FR{QEqcmOFQQU_qv47eGs#JY)Tbpe{l)N5Tp
> z^<xEG+f at e8z<-n{X94BU2?$I5P8Wqf^Qe`x6ZPU3TPKou5vZ6*Rk94F%}BzIJqsu&
> zh>ouR1XP<3w}#d?kaLC0n{>$oI+XF+kH$upPC~Y3(r)YJoi2yaZ#7+BFjg#mc<K7q
> z>!kAQFT5XUbG3uLo9Kbx1g_B<fEwFHF3y15)sADMq3knEx?Df4QfsX0ixk?Wz1t($
> zdP70&5p%J+M|C at b?&rr<Efu(r6Fw~6BgL3xM<t`TCJH~0ZTc9zMl%~ZB*$dVyJSp<
> zvoLF%Jnm9T&3g24+%OE)sMvo`fK!u$GL0n<VoIxY&kS0W*TrsiukdD1hur1O)VR~#
> zZFEPU<GC;+2H3Ep8Ar5?5+rB at Vxo*Q^p0CKMeEv|)8+&6vEpf<(<z+4ibBg|hoLiQ
> zn79lD(w2yhc9FvRtT!E3)r;D$RrGU1=bbf|Zf(E!kdXu;UeYsA>??a(VL#*73ny2W
> zB56;Nc7BB~#*S!5Tw>U_old(m&?s6r8Dt4Jp{LP_GP-A=CJ!HhTbeuJvzV8Jnz$B1
> zEI~Msz~OmWTpb at MCW(~XSTwAt&K$kTD}Z{M{z2hWhNj?TZJ$#ht}3hRF6$WUmj(ce
> zokk18J*iq8f<02H+mol6qpuh9PN*Db<N!&eoX(7=%rE?OSS(PO9C at 71Wzepnx}YB{
> z@!%($>t41UM-9~X at -s=y%aCXu69E(UDC40_AiZIP6)Vn7Gfa1_eJ<7^YBn#*$2)We
> z at y*|{@?iC`VOVi>J*1umqI_ZK)AaL0e&Y at C2yNFdj)^%YrjO2(>b7!Tr>1H6eux$1
> z8fy_^FSy6JMH?iOh~h7 at rlFLecklO0Sjq6%%$1pK);He6qrT53DuX4P&IzWS(ERX{
> zBSn2YG3hY-dqEQDIO_?*ezw$(L|Ct27M6PQ;26?*QVHFEHu^@r3TnrM&q{&hYHkPq
> zTrvLkO=|Y|TW4XvB<nAxV?oQMSoi3enisWtI=y98a5L*mA%VRzVvk<u*4_KGfqC4$
> z<*{B}xY7$eQ;9Q%rKD at wvh7obM#iO;Ic^3tWB=04!6rLk8W$?ES1yu>Oz19*a=caE
> zyf?d1?`Tew?OWRv&*88WMkZ`LN<P#`nDG95O{<JOGJT at zHgX1yt9S{V{y>m?%A(UN
> zJUfb)F#9>op at Vjq&&M?}Xcef5eul>tAucjY^iD7w at m5CUuEaBguve_rTO$&egU{^D
> z>Jk*<(p!~v#Fe9AM%O!DrTOc3Ahm$-DoE=)*%_ntOsqKBkXq<fm?IKqW$y7!!_ at QF
> z+Ivor_;DaKQWs7oP`xO??$C}N4IuU<?HbFVt(pc;+714U8Z`HjpXia;dla8T`SwkG
> z_Bbuq(CM7qG3z+5ccm=%NRq&dE4GGdGny!=(knA%w#L>qI!+(w#ca||WedJ#Pff4>
> zVfc{xjw7_lhJ<*8`z#l<ZCs{4d3(w at sq8nO9Y=$B_xtn|HcWCLaBvWsO*O1Crzgy5
> zahTS^`Nr=9_wIf=I98ba7o^TdfiQSQX8EfytO-?``14iN8uWw*mD2IRanICGM>06)
> z at l0A;XPr)R;{$9K?HC=*5TV4aWzC=kXw4xgTRf10roI0#+VZiKVXA?g9Oj<#&pG at N
> zDd;cCn}b at XLkZS<{#!wMxbx(!NE-Zw at 0GtGf!~$W7k{5BfXkfUzCm~1S|O-7jLFuG
> zBip)Jhe<3$pG3~(&v*ZgFMB$Df{6=1McbQQj6;Zg4Dp$@!4`fcbh&xRETA8MkC)cI
> zu~nmRZBaDB6G;nRTqFGjT}AUDXQ;ObWb~RbS-u6vv!lcxg1k+U*7}|LOl<yj1sp8-
> z_2tCt44qTln(Bi$&^%hHi|@3ZU8d at HbaV!VW*l3F?>Y!p*=1}^l>|6W;hL(}114GW
> z2(y9kQ;5TOJqcRcpv{n)^Vt?^QRNR(8j&%U9~o3qexdE=r{uOId;&uVnBOUi at TXx}
> zC&-z}q(m-Lg@;Y5o+Cm12J;{8+;9a#>)r%09y4pL!892{hX6~Nnad`63R=0YiRs;>
> z$=>9o{slD(0`1QW%k4tQ*1&X$MxU~^YQ5ksFMm_{<*BLz9^z(<J-;6 at +^b!)sApC4
> zne`n{+vI$++zb+2_hH}E-5%ck?c8BqGdf-4dIR?HT&8x2gWYvd#bJ(DDp&i&s{)Vk
> zMgr5tP_tK|L^iyLXtJK`z69ob at wxZo&}?6_Rf!<BG~B&I4>*9Lq8Mi>s17Br5a?|(
> zq5aLSbAWC2prUl`;5z@|>}R$z3Wh)Ly|0yykrgZ1u+4PFT{Hoi>+eHuu^zG5f!A~O
> zk?*;qXl6T+K%4gmunx<4Cuf9o1JwFHH+P at 1ea7*$Qh3Lw(n1sT0L0kmgumX=Uu0{Q
> z0vX{~uM2uFdRdo#j+^W2LQeD$``VFX8l5hj<k%Qe1NhYH<>JTbE4G)HpGc|5=AMvg
> zyY%aM^Zs)xCJpxxnT+M7ouJ=@yIi7#znkT{)w$i4w(Q%HKheH at Oni3SDI=A{7S#Hz
> zFZ5u7TFgviaWl>{lN*glsAJ0qm0DA!^Ixuct6z~xwly9W3MxCx_-drSwYcU+Mz+9&
> zaUN61Ru`QbY~6qtLQ$O|IY4=jyyETUYLz<VmC>nt;LC+Da}%9%f6C`!G+yFQUB%`Z
> z?Euvfvi*vS(4&m41NBUoc_q&RAJ6eSIC<>Ie038G`JSD1+?=d$Y)Hm+SPY8n^oXmj
> zva$xStg<F&Bg4ue344C+muIZ)K_~el&WfH<?E^;bC;<~SHplRO7e3M6q;?*ulNHZT
> z3KZX^CKu$|h8i}#_ME<cv+R9%!L=E8d?c)3uD|!={O%%uy+2E%AJXn}4o^P#<V#p7
> z)#``mj6Zio24`j2F;^L=WUNg1B;k0t0K$hN5UFE8#J$W4{f(0B2)KxLeN5I{8o6qd
> zM-(KtRfRbNU_9?Qt%nGWZM^?kKhWp%YPJowz at 4l6OSfd6Oa}YCS0dbOLQn@*H~=>K
> z3IH>qD0e}ZlxDibp#AqSQ{adq5vm|f<=GSfvWcg$$&Pe`$$TU-^;tsaBh73+he{>5
> z(&k-&yHNVy`r&H1)BoKMBS^C_z(7KTzQD?@hI8Q&%9P7}b^}!x6fVBonb7B_&5hoL
> zRBnv=y$ae<-&0H;va5fnVY}TGz)^(ZE&J{kc=nXOm_8>oIa~tSa$QeEBL)X|R_(I&
> zT^mHe?&ri!L{b}krCx=e?7XKpS2j0?UqY|hQv?zE%t#%H#i?UeKH%a%o1Oai{;<sh
> zBTpTq(udNA7BDiuDK at GOGzAlvjj{n?dsB0pg~bZ-i$s)vyYN#=MtFMNdj8kz?CR{t
> z`I=^W!FG6qRfjED5`YIIl*rJTwLA at q=Suo=Nig3RM~{B#ES{edn%3Oig>3ey-ao>-
> z1`;P4(p2~DNEilh)~xanOCdy-`0i8lxCg)27f;8VQhm9v<IU;DqTU4Rc$2q8FRp^j
> zgMlQvt at QOF1ZU1u;`oXF-8EFRt)h|SYjT?|$qj~jYjoTUa@}eMgPK+zsYD(LL3U{&
> zsWu-con7FUgZlMjy<SFiX}??ZzuIM}zH_nQ>)2BL;gQm>E0?v*vfw->fx*ElUA#B7
> zDpXH_#6M#JLwXdFp(@VBeEET*yIza3r37xToNT|}Q69cBWnRtx1G<VCgaC&s(DX>c
> zFVQAiV8_3Ho3HG58$420Y#?;jS+!64PVDZ{d#Mq-KKES^0rj-onVP?BD?F(V-aC4&
> zF8uQdgV{hAksou*#19t?yUpJgn1)k!aE;jsJIevfN at sw-t&eoy<X+XdY at 3CZqxi*C
> zzpXSqFPNLs;P6cH$DXM8`|SCge{iY#)xMZ;`Kae&DnPxSF5iZGxH(EEx_6k5Y4y!=
> zrT|)@Kt&UaraVo_swQ~IIw_t}u4j?fkr6LVO6_tu2tl?$k?uS{26XOlK7p6py*1!z
> zAN^v1;WSfDt9Q9g|GIdAtP!_;eBVVyv%c!FajT`-W&gyAs@%|hN$AOcmk9-0rqiq6
> z$6Z`#6)oLsryt?fK5fP89(ydE^>|NHyfFagzO2>xu9Ox&Xgd&iLd?#j9`&obvErRu
> z>_c54dt;6;u5c692)Z2Hx)}p4f47K2urr$qSG2t5j_GJPMCNI~oPTvAAT_n}Rmf_d
> zC(w}Bw1>Hv3xrG%z1HVDrc=e=GAlkCN^LkkGIou<S2riWUnbVXW_eX4M|*ysr5Ece
> z%B`pD4L5?I_r=}$X at GqVbHr};+nEv at s}C3L2TS0~-8qSlj&DtD2c7d!yJNv#`!8jO
> ztcr{GGz;w}(cMMz^GYeWDqI^X0>}S!^9ZfYkn%0Rc-ljG#m^*v+_C3O`?kp`TNQI5
> zt~apvQXB!JVUDmX3>Rh=ix+6N)7 at q<Vjc$_)1 at AtWnL(G6g8fh`;_*B&0=Wd?fxDR
> zn6c2`S<l~6Sr~}z8u#UL5iHEP;K%D}!qvS|%y630fSVnl`(Vkt4N5!+4~kE`g5|8X
> zn4M!iF5-5Abh6Cb$s=qpr?#K=c~{ZxhyZl~ZXpOF?vU}(m3=1}w-Rme>ToZW-;RkV
> z3}2Y&l$^=D?|=8a!ZGcDlwn#Gh25y)kDgY at MB72Au{ioOJS!-u?5D&7sTB9?hf$Wi
> z+|ThFs959!aHJkTE%iOE#Ar}QU%d2_=baUPmCI#PpZq({ra?1MXH|+ at W=Of)ungZA
> zo#9z{m`&G>y3G|T{Vj8UC%LrQx7)vOebhGn=}H(ZZNxki-SvgF7>4d!rAQrRk)8aF
> z7a9d-Yu2^N$eEEcW)=y`TZDH|mJYpv_Qq=%-qchOm`7<s!?J2hLxWKW17On)ZUGC0
> z)D~u|DROUHjOG_bab`hi^ZzQ{6FOG{D2r4Ac_Er4=3|kz*nUu<S5oB7<=ZUvW9H0J
> zju*`&_N1qn`q}WaB at yrB)Fg9PyuxbA7=<&zFNA{m?sPq>Yx1yaAxb^-M_78?G8@;H
> z5nOc(4)p%Yw1ko^(UA%5kP{4B0LFXTpm1qdsG)E1DzIg|Mw|?4CU<q*jSCJ_>0t-j
> z^X+{*b1;KvoBDLi=xqV5IM>&lx|+oFRsM$v|HJ+6-m8Zt3 at 4BQ;G>+rrM!<9sF=kp
> zehyQ at H?q}`m64$U710NynbXY>XK8(3etr&7?ciAT5P0*n^xEizGv9`VV?1c{d$l$x
> zVQ=1DL8be~)n+DqznE4??7>AsssR<)4)`eC;f02az=%|slm$33Muy*7I^xLHd)!BW
> z=-~t%w%OApaKtn>#W!w^<ost{T}g?KMI5^br5vmgQ_hyAymQhGDX`2Lnb3>tr4flo
> zoLeh>g+5z2*jx&!odyUYUgvz7pfuB4D)j>^y?UFAo5_%B*)~)pQoxn$p7<0d>gkZb
> z+&}#(+c2Z@)mrdVP-S|jftyIRa>}!_mwhITW~$<vmADXBM*>Y9Z&p(d{W`EsR{!|3
> zxJT5ghb=Wfe$2w8?d;(<>?w6K;Xr&+%k?d&Pmj(SRicTL=r*gK#4vmgTdSgrGn8lr
> zbP-y>EGJ5u!d+bKndW at rrdJhzl!)eox=h6gwlovzq-R~dgICn&44}Ow3xVX?K!Kj;
> zu<Kv(UVG3R?I9+_1-s at eMyD3GOTkZweQV?CIj_&{TV|$?udjY`aLmI2($1V2L_m2L
> zaWg^SxTcZm#b5ID?ZDi?HE>n<i`HM{Lo?Bv_yWXLp!Wx?q3_>1=t{M}5tP!JEX3&^
> z)r30GLphEe=}%v|2|@>??CxGs3$W?iT@<LQL-LS)&aC>LWPPo*<;(Z>@mTl5wEgUP
> z1Wd_A+H7S5fRQhw^8W}JJ;%8-RR$fHReHjY>yzaD3Ri>~{52LD#;&Q=T8l;9WkLWz
> zh5Mj{B5VO}HeuwN!T*IcA#smVpui1{{u&DAA7hmtXH=v}=DEKx#{eNJsE)>)37G+r
> zN!6jqxgXI+^+Vxo;nUS=Q_nurTl5q!1Z+ikOGf!)Q2NqWx3qPUCbj`>0iO*5yyVP%
> zRE|leni*UW;(+)Dz+xffJ7_k5#`ls(@;Nq3eW!T8%2JpU6?x;wQL=mVtWQ|iG|mj^
> zN)SgwfW_5oWDisCdROdWTX+Mz6!g>U<)GiL at -x#sdfm6*r(S=5mMPDsnC^viNfw(t
> zESt43`s<rBL}ee at 4Bybp4IZC*ZbuSe at RoFyeqlT(+qJEF)Hpm2H6cuc^bbAHny5tC
> zq{v8(8?3;oE?ytR<{rF1iN2=_XeKcWeY3GONXi83ICxgO^g{Lmk~ieT6SX9NoqV~8
> z@!Y2n$xibjz<1&Uag{mA`&fU~(stK`b!>_D4wa!(FL>9-))<k2UUW5?)rc^P#@$1W
> z(Vc4Jeh%x{6s;b-9^+7H<wl=8A66~l_b=-?V-LmP;X#8K&JT<MblF at NIht47M>{_q
> z=}I(@B~&0|pSGV~KCp=`aQA*IdyF^KQ%O24#ATrYN;?N(q;DpocbSEMK}&V33+1`O
> ztrWHMnDVrJx;nCRjkbnj6BQ6_<Hr87+^5SRo2JkKK$sheh>n1rd`b`qsWGJ-DJYm;
> zDO)b<`eeYHe$3^{LymZ9{hB9=44ZDoab}UuY5LVw7s+z6H)?kM%Fg5anaforcO^M)
> zIh}{ed8qDz9mqa_j1`C;h|y&PdV*POFnlbqcFGx!T{wZg^JnjR%=r!OW%2EX<nHmA
> zzq}u1>aQMFHP+O(V<$^4k!+{wCd at wTggF$-%l_K;T9<&td41}`??@N-Nej;*o{>Z#
> zAOrxMB~{(^-caimFw3N_XxrFkq^T=hi*@55P1-p_4nFK)xS5}!b1mVQ{(?peo&x}-
> z0~RA-YyEvYd-?*d4${X^k1R;;CD(cqxNf~l+<BdbjMj-Gy05p8+h+H=-mw!2v1;I#
> z{0<|S#jw0E+s+Y9UPF#_WmmDb>Y(<~)?G}wO`=@p)T`0C2RJl%G<X5nvOh8|*~(;T
> zp at 1O7A(ai>2MD0RZ-S|}?03qlv~-sS<ygWEz2jMhYXoC3w at Uc&SqGtT+fT*aNssmm
> ze(mS37_Klr;yxp_(A7qaPYttOOk at j?2>u<v5!Y<z#*Ag1i2OqnxY>nYy93N|Sx@~7
> zx^R&OfU7Vva#=y0{(&sOx(%PHB|*ti%Yr?w(4{;0NZ=1_UFkf)G0!v8m!*J1rw at QA
> zSEry%RrWb#60`=Gam?Q~i)!o9<(%cvyF5r5dV2RFtHblj$cD1QA=Byb^~lbE3cca|
> zNct6q(I4z7U~a`}TFk78uEU<ufGJ^IVqn(T9jWy at g!gQ);aMTxt*OJ|A6Wgca%f9~
> zc{ExuT>kUBQXp!{WyEg0KZ|bKh_2FGzPlfG$tiPUFxOSoZb50SYX;2Cuw>RE1ZI5r
> z+5#`ed^yqLn>navrc)vkZ*`K}s8={oizFuBIV+ok^aN5cEEaHeUKw+xVY=Y{Mqwuq
> zjZ?EU%koRn^D7GG>UHmmYSg)q89kZno(GV^{C^#&t__vuI9uUYoBDb5FUS!K-vG0R
> z)VIxYwnDjRc;kdEE_sKtgslPjDx0^ifs-1CrP&8RsBZy?O;kAR_X|-EJsA%1L#wDQ
> z7T at mX3my4SG$~?GGEw*Vl?VNmCD$v<j2~WHJ#*IPFiJW?E6=<%JU*>W(?(`@*|5X|
> z&}#*CQEK7^QCurTKx_47XSEZffn8be at y^>GVL3uH5$??Idcuqov?hTlhW$qx!D3i?
> zkc8#&;13#TFKf_Bdh0FaHI`fpN^;F>o76jlFz&}HAvpT66131h>#}}zJM`MC6$|NL
> zkfF{i<-i+m9F<=EC_zjoFtqXfo4=qWR;3u~#d^SB5YijIlTH;}WF7M&x1bcdET!`n
> z>1G>^lZCqNvjJad_EkT5*FV>*)$F5zlM=vV%!%Pv?V68!Rt4krP3ta~$^}ZV)x-Ii
> zs!QhLA)Q^#kYflVlA^6hL$a#jU_n!T%CJqr!(@|FAKvO~?(uEm+Rzg<M1gi(qJw+%
> zPLopS0blQ&1`qP_YG&pu`xa6DfytX&T25tm&YW8m{3+DsK!uIFvTh5Iz{~_Y+<{C9
> z*@XIx%mLvA+HCV9A>7+{ng$iB><djAax}&?W3 at dBQu!KuZjON~Y at JNdq)YZO$9WZo
> z_RLGCGMl(J4+A`Hp3KY|LA|#?(}b(nqXQQxhhY4MdQMDy>srOfLuWofKswrAr|wRe
> zlED0G+!o)|OfQ_g*gUi5F^}^7L2rv5;<?KY1m!~`H5`(BO+GM82lJ6legOsJyr{{w
> zx<`!2Zz)PN*}b*Jd9HEugka2JT#YEtZu3|4DIhLNkHeW}%feqz>~OICN`{nASAQEk
> z`iXVMCiZBr7AoQ5+&k?cm6jp$=^JWaj07k8e{M0U=8K<TA9gj`%#)B{tWt=BscW;i
> zOy$V>M>ms~t!e?y?e1U^P#ea{_3U;F=H|A{xS5%1gxQf${B|N;k)c0~g at jLH*_sA1
> z7Zuk6bsuo4+9s&RWRK4pzT6a}W^wBtr@;D`u3CFfnsM5yFOjiGg~8*Cn&TEhK@&r?
> zK5-qXIMCv2@@VL{g5&)Q(OK<Z*U$G{&vDTHR0%ghAE8CFj*F3f+QOkD3=Jf)FMbnQ
> zKrnIlC3{qRiRgG+B&7Qv6XGm_m}M*hBt4M89R<|F9)ZLrnB&lHZ_rrv<k(W?gPG>3
> z{&xwTqT(eusits#guQh5Fp}rlI5<&VJRs?Gppw)y&h04*@Xj~q6IWrhn|2+c3w7Va
> za28rUAL_D7u%L}GOiuUq+UBK<#};#q!o$m6cvC9Wm%`cVb0XwgihV+_%*!Nrr+H?M
> zrN4(&u(z#6(z8;xk_AWq)jt3}UaKd-aG~wJXK0hL(WD7oxUFhfo|jqYi1yRd`U<^u
> z`L#j6M^i2}rpd3;b7%@r$2NVw<yTbJT-)x|mXr3>s^Dn`9SX?aM-eyI!pJb9Pp7j~
> zm-wl{-5=^xYPY-`R&Ac$5t0na&Cr3Qj{0l<4xPbAAzN-Do`0bQ%z&eH1U@@E0mBBL
> zPh<|AG>z14DmSV>2LSt(OE)*Gv8k?<{cvZi(<zk&Vs$~m<*;~KjM*7txDx3Jw|T3}
> zK!)&_fxy7Dw8htRU#AA5Z0)9WYjov1kTn2}4j at Kep3hH&8MIF;XUd-6daQN#am^w9
> z<J*n;Wh=)x%hZ1W)OI)a$RUFeyV>9RKun4o>MuwJ{}Wk;TmuN at Wb82tECCUAt|HK<
> z&=X!bJ~le_k~j6tk6&{ap4=ZgdHN52lAU#oPQP;M*Z{&>FMBPjQ9)cgUU|s%<)`IN
> zm0?+?>aL445yuf?r&{v*(diDG(i`2DrVi_}{arX$fm^_inv7r{s(M<}P)>_`fAuC;
> zAo5ddKc-kxXbus^iyy_FpzOV1Nrdnd+NV!axZ++`%16K4Sa;mW<HlREOPx$A0r?t<
> z;uld}eWTB37Nh at y+{}eSa4lW!4mavPc$9md((U~0o&ZxioZ5EC_o_~kT`!t!j)HjB
> zbFNqU%mmiehk at J2!&-YD_q`bjxet$d#ob#i>y-5Hbnc9+gAmI-x@(}7L=sq6bcblT
> zCTft=BWYPLlqdCD)#dex7Z;CLdlYrtvaK3N)Oc*G7i2r4>kp5*pFFm!E587Z2bdI~
> z)`7g3K3D$-pkvNBd$J^|HPNR1PqG*8_U+mK9*y?v&f at S(b=FwFKyo$!`Uq8uNXLQo
> zz{E;*wtMP*KXDCx_4au0H109m*Qa+d?dUNd;*C at ap4wv09n!jIA#6A5t!{dC;)h{J
> zza>uTO+b{x9TV}8ZyS=cqBlfNn;eTt2$UUOt14%pG60 at jG)L!W0Jl_MiJ7L3;$X6N
> zfN`gs<#6FgO9w^A=bummz at c#X0!{EM;2xXpaydGvPzR7m^{)RR?B_B7g4HjQaJy^~
> zeL(+K2J|iHiae2^^x0Q{Nfl$9kj at g@r)&NN{gLf3$~#!g=>6HDL0irv;1P%5OoG53
> zhIRXZeFoj>bCMBA)741Ux#0F~blGo3<?fr^#}85-ETz_+HIhoMeFbjHjqbt(%;NZI
> z&s$thHBi6_RZ|*m^)g?gb=P-#MB%wJ54Vihju`KKvm%<eA~_j?G*`eP1LpqV_3>wz
> z%&N at P&v)%9MWx%PbMJFP92gP6bM}H^G{VrQyPM4LV{1`uEdH{ZWA3>(@T#p9mF?W0
> zKBX4zOaMOjZKs85yUZI^PYbLJKjVWLYI;%;jcPq1+bMGMb+_kDj?@)CgR2{>HC at R`
> zb6CQJdAU=mz)d>LLu1Qd*%}{{O<`CF>kZcp?1YSH?1>}FF6(_!y$h%Y(UEmefKOT5
> z=~0hrfFl~{CWRjgZzCLTyib=7k?NSf2s^!UFkSVz3n~45MbSI;Ys4i(8!^t}xrL_a
> z|J+y-OJDo~@How7%ng)u at V)<HIA~llF~mFpi6cuXbl9}m7AEE{8+Y`WIyvV!0GNr*
> zl1GRvb%Tj+gkuap<6f%!a5~?<*7i at A7!f5aTb6nG=|5d!SRz~}__BwNN|%lbsQ*Wj
> zkn>HBQ$`%80<syV%u1Xa;0A+n=!u0GbcnO1+m)x#E#W6}v?ua?lWzN*^=*GBdQo`*
> zn*-coe}vIUqXk`?R?{NfwBEZ#vptv`HCCRyUtMP>&uy-07kf=t!?nuiHRXu<BPF(!
> zgvF}ClnJLT#5Hna>=)lBA-I at T>w|JY`(h)Hd3J3Xv#I`c^4q(?fvzR*!lDU}P`BRQ
> z^{J-h<VG&_j`odW(VLAGs>-1AqG|BiK3-&tJ`MmExmH!}?WbrZoi}7h2bV$}-rU_A
> zAN+ah{)Xnxxkdm3wIHoK8qw@$l-ND8f^9R$cRPAVzDT?($`(N?7>T%kspxiutewOs
> zhj${&``W<C=nBG1gd3?6ujIXsFg*7bez<@VrIxI?zA)AN+c-C+wpmcjGr;LDNKB!J
> z4n35mV(0A=KNhwy$w^c?POO#j3+A)_vh*Jrj7ztfK=ANX;YSad>4Pu at V00#oolT-q
> zk>UzG5AU6`Ap2Kt|7(_-8JVb79RE at FROVaP4dmkHcs&K6R+!9O`v7L at Y-;+1OL{i^
> zKTxa!i7wwx5}jKuKO=WVvv7YIsQ;yav1o^V_7JdX+`j56;V><4u#<2Mp-vLh5-ADO
> zb{bgU717+d7H at lD*8YyB<yEh5Dr``PJ_?~7d=zn+e48arsd>4x$+c8=PiO<3<sELV
> zpPBkw(}sf{SPD6@#P4#N=JSE(c*EZ6=756a_rVc+jq<jWaM4?Lw|u`GF_#rhhs6Rw
> zGOk_By#reFsEQbm at y2~eD0%sKxO(=zY3z!5lzBBjx#QEg@#0ZzR8taNE7LB*#$h3+
> ze5(nk2>#8GBzMM%`#sz`uo2VIvHqe#ZOTqFR>Z3=+}c?7+#O?16d_xTu<Um|&$J!M
> zph!8y+>NO(AMhH{5LyFN*L(BNhoQ7*u;xZEtsq<h at JEybV0YRocxG=+nXKIoOgAC4
> zZSsbsK=?ehMyiObx at IdDC2A55v(r}+4!c|e5&`gsnxt4_z_A9|j|l-F4$c9)L^CG~
> zOF2*Lfl%h+^5_p5S7f_&>u`SJ>*5;zjViw&q(`{PpASS}WTi$6K?rb+;$NttPBL!C
> zS>e?ky)Ji~H0kv|uy at aRU^(yoCgyO9^aV`ai^3k6+>?RJu(LEDsu&GSREihoOi(jb
> zYA^E~*ULZ5e4VzcB>Cyj59w>xyKEU|U{0|EJABMdS)G&!wn&(9x<a?wKeB7HP|1~I
> zerAPicpGq<{V5SfV9?{6y<v)vcFN{pyewVDC7Swu4#FuN8?ORqCkeQzmSFbmieI0k
> z8b{1bL~qOw9STedP*)v3N8{rfO8wV=)!S&E=_nXm_wlP=f(+o!H(Jf=+K~#^OV8z(
> ztk_*MKSRq<RGc>YQCXAioBA>7-eFr1NNX-P%{07e6sUEf?k_9fNYqtOyw;W)T!>Yl
> z4K6_1uSIaq$j^NrWBFwd6_MqXUpP0B4n(eybJ~z#@?A~J!`0z-d}6xw*L)F&WkvDi
> z at eR`k-7{ARv}bnB17<q%6nAzE!$bkOf3XQoj9ZT;o6O=8N-GsP+k+i$H2L1F9t><y
> z^-@?AYSnYN>^%`YN9Aipw&8H at GCCgO7og7m2CxiR6=$odJfLlOE*p!GLKauQrHXi2
> znLjUXbGqt039`S&=<ZMBR*kyg8i4o<l8?f~&%M5wZW3nHIxS8!=z3E;Z_it%rmU0p
> z+G&kcP-B;|H~hT*Nk3EQhOt4~-Nj-|uAVk)kadKK1~|nDu+U at H#UW(1*L?PfDgXGf
> zsAmt4a4p<^5k?%;h5JxlDOG#zuu&6YU*fK at TkY`0orTz~XW=^o6W!E}#i?vbr0~Dw
> z;;6hdy|W03E(k?wNEIMy8l$jry1(Tty2EP>ZVWl#a$pPLx&Rn7>V$8<NnY^INpf at G
> znGXss6ap&14oEE>e4SYpe%up)8K*YebC?Fs<j;xxm~$CE?j>V|6ByZ)^Phd>&bv7O
> ztbQmGFL>p*rtB}EPo4P$V=w(SCGjU**7K-<q)C|Eki;r5Ap4?CLonYq=b9V+B8{Eo
> z-i$m&tLYkC#ecUCiE`FzGq1v3>Ns&!aX!uENbsdp>+OEdg0KWYuL8V%j{j3MPw~w5
> zw=0s3PUkdUQffT|i~S9a1E=<P%MM_t$b at K7)w~B=lU=Jea#lIEF?Et(vlD_Xy#jqq
> z)>3yjqZsBMB%c>pVM at w7u3_xEZyrGh$+^K2*GqUQ3Pqw9&R)g~fzYK-hx<aT+QyMD
> zup&$0`~&>ffS>s2lczgrrW>yegu8?@b;^#vf4JrMQ~eKq+S2k4>N3 at C7n)A#<EE&K
> zi?jOPZV|#Amyz0s5h%J($iy8o6o~Ba2-Y%e&#ceGC}>?*y)o)$|7O2dw?g=b%9X|F
> zRG5=pJE3MTPH7j=H>6ZOa}~L*rfY_`e8>4X^6@)tLIuBGr184Tqwt0Dl?{=tiiMEu
> zK&jWW&d|hEmeHcd8XuY7LO2ce(sehb;NmKAJj>a^F|tk76*yFH%p=E=>nDGNAT#Zc
> zjBp^vI-g<2?vpuZ%%*VUf^eSuAr=6|k&I$zG3@|vu{H(TOgM&wI|sDu>Ee0X4%8Q8
> z3I}KE;U169nC%6nB)&|2+1<G)9kdFo&;kRI>)P$wJhy0dGbiF7LK~t?y^lW9;Vx at 9
> z!h~iZve<P_^jLfPZ#!?oSz2gL;;(Z2>!K0g#f4C97-gsd7<bP(W6lI@;yBt(03M-y
> zf&LQ!l2{6uR&On2hlDGjR4*BLqV5H?F4xfVTK}BymHTX at LZQfvt<yR+_w at cSS~K(P
> z2I@~LEI^c>|JF(_>?fqa=weG%;4P at X)Xk6Om9Zng&wG`Ad?|hBdZZ0#<}iB%NU-Y`
> zEubAoz5{+SeTG(AN`pEAqQ41Kt6M{#zBdF7Dso)AIXC(XJRZzD^D1adej`mo;}_dm
> zSKSiw_P>U8Gz3Pi9c=XT at a8e4grn=-FGO5ir-(*RD8B*MDLj+TCWl}yb<AAytQH<u
> z4^zq?oI~m}#c9x3T4B7*Yj@?W&9hS)LjLsr;nJ!`Z${}t_{`X(QSj%MK;C#Ym5+`7
> z5{Lg&Ls>-I!spPVm{|#0G at UKvYG1&@$~464BdqxB_e=kX^o5v at S9Fba&EP9Use2kS
> z=9XH=_r43(KJXn{HS&<|>((rcTb+CMTVA1*Vv+lvvF~WNUuu`GQ$vDw0*y47rY)Py
> zaH#)u;5pUdnK}N{Sf+jJrWqf5d2zF?>-N(ljimqYOgB01zc_ZRe25gW;A=~%+VgY6
> zfr_~(y$6;u&~@p at fX>Scz5*USK?E{H){F$=y-R<Eb|qq9cOFT>6)T at 5OqrJ*-vS at 3
> z?qISC@*YrxR$KdPDx&r(@!qU&T^qHVCsh>CtqD2?D9eM5a~_sXy at rN0@GeZ9kQvL*
> zXe3Xa7Dt4}>9M2Ru~#VkIm9M$Nw&QC{h-CUWRQ|ns9dqPRv;#27fd_9*9_;ncK6-@
> zRvLb%<W!BVgK2#yN%uv~(P;)Ilx9Sw(jvcx<WpBh8kH31yQl&&>+dVetCZd}j!D>m
> zdUc-UrxGJgHQeE&YP4*Qy3PaxZJHY{Zu&e$R8MXwuoT`l68df^-}dpfs*c70-s6q;
> zgV#B~9rhdPtI+Y*`UU}g%+Q^z9~(VDRJ4X4CVKNWyCYz7!?H=noxERPTYvnV-jstV
> zb>8;*=<Kq{(80{Oa55}$0BmFrd>VcRHvIpo5lVn?$xXr-(5C+aT6&sZS~Wt0&duNi
> zCL|@ZcL<-$n!Q`)1+j=?bsGm}rCL6Ict%1lG@`qZGdhJS|1n7uou at Nc2wz>sf0$hm
> zBph<#|Je4Y<4Z0kbKNm}97Y(YqfJ9_9YNR=H1mIct2=<-YW$zy%Ei!=?{moe_yXS#
> zFGUhQG)udW;3R;_-IxjOW`YRvkvZ*Z<LUg6!P~WU!}s#2&JPC0&rct1tN!DfZP4&*
> zG!$G9r?R(WMZZ(r+i<5s9Pirwb7Cz6PONk1dr$u8ua6atvU&5+U$s*nU|;_*v-JcK
> zr)dI2*r^cVHoGbu79al8cP}*Y_VH(DprD=o*H493M at Mqq6*@JIyQ6QRm6{07YL^aF
> z4Wd{4_{H<wkEeCg at 78le56veA=QRzFByAH$SE*@ajWrtj)Ewn=#_YSBw1~T5Nsp_2
> zZ{BI4zMJ@!Zj`j&lVmp?E(RR1F$fU~1hoU<^1uqyat>2Vidx*f at mgVN?d7*t5*teg
> zPwCzBXZz=6cwjyTpepz-Wr`|`hpub3N<XzsxOdsE*Bco|ZJLRpw<*iIyjlN^)Zc-Q
> z!e+p6h`{{SgGX7jhC^x-qZmc|-7NWq_Lf%}n^F1EEt}c<EWy}NvRXLiyqsOA?)tCI
> z1N7IB#dz{ZQM)%rnguUIR<CVv`NPHx(x$ftvoa5S!VZ`(&!u~ZLJa<bMlgBd=fj6_
> zhgqjr?SzdI5LVQ8;i5unr7Bb3+;1<&c6Aq~BsK47w(ynFjYEL+dSDcV0Y#uQ^mZqg
> zZI9_Gdy{DT+i%h)A(PxMO1eu2tHRHP_u!82pi!{utABL7!ir7rQ$>=kEHZ^C>J#$k
> z?)(_ at cF@mU1*9NmlC#1zCqspE!WV|ncICsEKMdCv!cmo6`nfI&|8oc5mirg83%#Fd
> zb{MY=_FqusFKrsGVoD%s7mS)KGqPBxQ3+e15VwJ~2tAU<y&)=^Y^fBnrxA7KDKx(R
> zsnJ)wmQ9)d?$(Aq?kxO+`9Dl`w)>y%KPfu8#yRbMJ+Np1C%y?+yG#|oQ2lOJ@(Ql{
> z-LHpaLH3rGMX}YatOP5ZI<$RnTD4h7{<)~b_8`y$AX9g;+I*6s+~F6O0tg5w#W1Cg
> z>Z>>C&6l5d=qgmro82|{;YprX;3G{s#uAqLoZ?gP{Sq=VVHXyGtlp%iBo;ZpAQR%H
> zE1HzQA2}G2j}|SO at ogCf3(n*wiNg=9&tvae9^=?LCi at NE4-n#+Znr$YdTDBFd*K;x
> zDdAc)eWS>-QTv%ytv63 at JH4N$$U7{LNv{>~zssb;O>l`UneZv(aV$UL357GF(TGTR
> z8LZWrs?wn|!hadXo|!D_rR4vDOsaZ{y}+!*a?-S0utLM?rS8 at m;|nOSFB3~6nJ!`T
> zjT)zqx$=1VC_>;TixFGkYsVPT%(8ME*^-bz1WizBNB;Qz1zr3eo^f!P>`E1(Y0MJF
> z+?!n#D8-b^HM3$q*D8nH^K>mf+#Gl;m8O|t9X52s2AFa(c`ht>mhvV^mmB8S0K1+R
> zv|LB$JVi4mV!*z?O>-Y at VfbFY5Y4#!Y4L(p(!08^`MeW2yN^aD0Lhv at 1D}%iA@(KQ
> z>0FE_+^QVqEbi#nWB}nN<_tL+lZ+$jCJoTQ?bN-!%%#%6&%a|&6zP-BX at JTXlY27y
> zgfO5wV8O$}fA?_|bLY$^20#8`f24Bl&J1HzDp%AGmZFv1^%8rOHIjF(iW~%t5ru~f
> zP!4arg%@9Mac;LXVSAvQq*CIZ6fipcV0&#*E>||$B3F8SW5c~|nkU3#mLI|wM|8+o
> zdhocz__?E|cGJbCMflRVN6B=b>z>`L-8z!2O>|GVxC1#A^3Bw!oxikt(X4;nbm+Ur
> z(;(PX$w~i$a&3IF5zs<O(RdHuMDBp&Dc8;P{v4PVCp~A>$du9C$I(RaD9=n7p)E{!
> zyM1-G)Tdp5KeZQ$WPa=4AE at W_=eq&w5gu&<{!s+0Pi54}0PZ^5b7flc%+ry#Nx+kR
> z=#n3vGht_CXx0IhhptEnEhuqsciYk7Zn2~a{+wO4PD#tQNOE-05G;IJ|7l}=@&H0~
> z??T3+g(~B{8`%M&&8-k#ksP6qAs6re*4y!BlmD%8 at y2sJhST-;4Q=o?4Zm$bG(YW$
> zJB0Hp+U0^+)Y|K)&e|(%e17Sr5kzs~%@A~bwUl&p`L~fLD>Fipo1HB$rzsTge!_kG
> zSFx#0av`U?R~2p_qD$&~AsBwNi|8I%D);7zwNvr7<6Hl&smp2R#^-=X{khXNG9D(V
> z2VqE&zre+z6y3}i_+`UNLt&G|Oh_B=trJ&vo100}c0X&N|HzihHK^l{kvvtrVzSi(
> zUN$02(sj0sj&NA`ke=?a&U3my!eB^Uq at j4Na>|o*dr;z;-d(TtxsWXP`)LKNZ$LD!
> z*}r=l-uG&$`VYY&q at 1;-IqY7iH7J`sbF!Kjqyq1Z4a<3SH{pA8QK#Be)B5!44)k_=
> zh&geO<Kf$I`NRU3QiPM!YY+Pymo2=W20JZl1P7NJ3qr_SxJcxV9K#+!<^Bsee at 1Sg
> z5^2s9Bxxa<yxCgMiCU{Fb^N_`Zdk#~wZ>fTn5<W?SX<3h5@~*J1j*3erUIYD_vQ(}
> zF&`!q1Op>oH=`jZ!c~@7n&jlzI_`$g@!{Qghp*|9Zvp;b{lEEx at H3*u>mSzLI7Lb(
> zo(Jkdp`9U;TfeUL6g|k4N^|M$p8OJo$erFE%*OXGh1u}%CjsQN-;WOC+o%{RjIPHn
> z)qVRGki-xPMC1Q=p27b}CHOzY6x94bF$MDfTTH<`Y%Gpi{1+7KPu@)UiX$HJ5kz`V
> zI{t8^!`H5{ovB@(GtS-Ig_td_z-XaTUoM7o&ZVOFMI!-Uk=!<V)M!Sd6_u37MN15%
> zNVVd~sePZF?YkZj#)ECAEq|nC2}W6SrIp}y<u_xQ0J7xP++am~1}ltL*Mn|7!djhe
> zp>W;C=6<hz*$I9)(tz90!@9SUv9Jys|8A9*+55-6siyL!&aAf8 at UH;v3+Qru>?t)Z
> zN<1{X8#G5ZVo9l^S!T!PM&mUf4(0Bo6k7=&@rCg&$YnM$`9;*|9`Rcp3AoaR<}Cip
> zR(h$#bxTEeE9`MZE&o*GXp47FwoUT2MV-a>lJ&?5=nQu{8A at WM2N1dRytJFOn6J{!
> zB0s13lsg&5WQ%R7D$5=_tI*D(M9kPN5!N6i+zDC(^-|S9WwOY%KaJ+Z{gEE$=-X8(
> zlg?tex_aLTZ<VtxuIY6Swd9Z|F8AMc#=6>W6_$Sey8bQ4XUTWw(%m)u%lz10`175>
> zTR#IF9p&xe*zx=g4xzTo#$v|=F$<2QF)8XYt$$mE)a8IX>kl0)Sb`sTCV at VIUEuq#
> zX?rM|cV99`#8t{d=_|j!gD2A;n^0$<Q$^5CC{T9VgvSUkUO_XTqgb!Qi<e<!3qsUo
> zagpz3^?-QoinroADZvPJyF%_)5u238J<{3TLjYXX)~&~Z{8LN;>fOVcFveTQP^C34
> zx(+PF<aT52K;!L4*#j3KJtOlrJ(6Y3i*==d=kx!zHUOx@!L79zz4I2vX6W55Jr}G-
> zGZcOip?7gFco at 0mzNoYwN528U+EEnqNDM;YGp*1x&akpRVP3sRGX9fF<&(>R0QB at 0
> z_da!(j$<7Ip2~Cbvsiy5QK!BSx-);@*`1-iNA>T7mLqIXVL`VJfK=`lfE(tad4&;S
> zY!k5YWr5I~6&}T at v3I}vL at mlrhH{n3LSPO_SrWgB7y3jJ{DMujp%+KA7{-)<NJ<{W
> zAZF{RZ9<`DE&X~m5F0W7YkDi_&p0g(U?0&Zu_B&80?}s-cj5>8_eyHH6?IUB$N5=7
> zOT6I`Jg_|BzaR!LzKuV$F*U at U=u%ZWhHB6&C^fpb{&Vp`*JaMaUi5tz58yUlqS!G0
> zf+`_x1de9|7vH)Qx4%5IZ&j=4Q`1Hj+tiQ-{kp8sHp~Q^J0u#b#!OJ#6ry#tga#)B
> zPFdZlvv<dBA5GExw3VrTwZ-=`Pp<pI9QhJu?6+G|uWV%VPlHs?ah#9rBoI+v$U$CY
> zBi5EAJhtx8xn3&lo1Tz>n5?OMKjFz$J at 5APb+Atcglx@yg$6;>bAjEf+Gaa$U5V}j
> zEc<nY{GUb*02J6qh}U};QwMzm3Ds|LPbq5?)DTJ=PcDA7jQJV}o4D4Fe&GWC`4?39
> z2ynNT%xq3<&fr at KvFM7z=qeZ+P0E0b%@3SalAL{hKA|#|nP)rhZ!QGFqw{7|Y4_y1
> zvFB8x97+_CTh?K5F*;U6e)&XSHGf2Asi;Z%T<#a+BCK6~;KRHuM- at DShwTO-MTh%H
> zil!`j|7akl3F>i=bL}uCf*VbK37G4bGBMH68NjX>KteGAfy|x+EHoSl)Y!U*7KE-@
> z0LO8^q6>}-Xx-FsZP4FF3)AX1rZxIlSR!&~iihI!KOzhWU?7Rm!4AmOJL7rT?u1t`
> zykOFlBkBEGU~+fvDgFJ3nJ55;fc}qHEt&Kf!QQxYj at 0RBo6ZNG3ED%m(s>96kA|#i
> z+ngFA1#!_e$mx;6#qAwv-XgOWXvN(8fpW=U64|Q$8CZq1Ap*@CHlD>wNJJ9V3xLa4
> zM_y}HV`sa{{=Q%on~_gE*^Ap3?4tl8(O+2u8d1=tq&DQd66+B(57+_z->(cW0*EQT
> z#xP1W^$rCbA1=8H(5X{3iSA`lbE7R@)rYGpQ>~tyPw*Y6`zf?vKXWn+RTg&PD#%ya
> zCC|K#HYqM)Q<9Wn=$_w%6N3JrnV)XFPt240SrFOm3%LA@&f`3|%^qg1PUUmD<EQtP
> zJ%#l47#u^x|CPtEYQZ=_ssYb>9|KM3RH6%i1I(_jb~}g3?5x{%GhNJ=^+v2$ZLq%0
> zbwG_LyGKc6b(Y|mg2PNU1PBnd^U;)nF709}pq09WpU(vrPD%&X_ZM^vDntfi3IUV~
> z(9;&E;^j2xJ-fyK`HC5`rz<m-SYwc_w9Q1wE&%wm(%N7^j{!o?bzn~-M-x9GmrttG
> zEa(rB-6mKCB%T2|FyRVcWv~J7$p62;;{pPZCQ9Y{0G;~)Y6JEuj*(*~@E3%63j7zp
> zz}!qMbY2*%2z-MMX38gEj{}v7X9S at JnotAsn{oW=H^|iL#P0sjUpw*d*N{JVLNKg$
> z6EyQ;*_YqILKd|iC^2i%zz^qI-O(gqulv*w^|84D7GuJ<dsxS9LCiRv^H+hp(i#Zw
> zW7fg&OQAcMJ|I`po$-bc16>OR=;;CZl>@9CVBs}H8tkt&tN#Uwa9#keFLBEqIBZ*#
> zZy=siLd2uZzjs1c3p&EFk|+i7fAeu)0GIRt`GZM`W;H56cdo4NQlYyB%T7ArzaYs_
> z7_=8{u~P)2lv7x*aXUlcUL5U0rU2E3EDrifv6D_h)2KNNcpq-&4Ld4Dc91Um7qr~k
> z1mxfXyWP2x8DQO!)N#*kK(lm?bBZ?q7vzg%{;-RV2OjlSbRlcB4`1Gnn|1U<l3)iJ
> zx1lpd>|nC`4PU|pC<)N`=`}`E4VWcZF~%X9A}|a*q|2C+myax3jXk*BzqUUAQX=;J
> zKA^#$dhHGBJi1sU4t($r>jQF2veN2TVD3%KGs2o9U6mnEn<7hfIP9Sms!B?4b-B>R
> z8XP<o4=K1 at H~$lOC7^GhaT4K&N{~~Kx)tQOPVQVB^Zi77B!1`~?DP%)*6mv>=nmvp
> z>-p*ulg;8CU{h(irFR&l57>&MfBpr%aRYXpb9V0#&P*(poAwt(b*J=2?Vz|3CRMnR
> zO8d3a`3As(c6Lj`qPDc>)D<x{3?L$i1KM848&A=EJ3!^Q^E#h(3?SX3(Q7E)^v!QK
> z;e^t-+0a+Mub0P`nUBMvS&QN9_bAq7YL6cbE&nw3YIMd=Y at mMmjQYB>jwg~^L?GLz
> zr(*l0ZZ~Yw{$=3?P%s&KVyrI05j{S}<Nn6L879=R2EWsyG$y`i{mce2nkS%b&Ut?A
> zir6;(2)5+*`jsn-rJ;=yX|pQ7M2l^!CUg1;CNc+*!#gi2^5;q6(jVTqC3xnZ at 61_D
> zNL;WgmW5v~^|;uy12N>a8-_%S8&T-2+c1(j^JOTG^{N-v+ZEX;RTQ#K0>?Ire44a(
> zSPA`I$oKARjbXd~WQIt0$*C(lm}LlQkMRcAiKd_0MKUF_acJCF5j(JiY&88>+z2~2
> zG at VhkZzpb<?9|3}?8y#&4%OahnlD^e&7E7FiCUCKeFm_Qae%ZHv(vjkyIpW&lIs>7
> za$sb{(6%C>nOw+YKt=8v_80UckRB<Fd9BI0YUu^rKy_nd$lO+8Qc8>yEVf-3<)jL9
> zK8tl2*eDpa%(uY4)0cog0)^wiw9O9T&4|q%xXAOOxx`!8x at T_-Vp4s}9p5)=_VvPw
> z{7%0AF((ctnvd3P=*98A2VIh1D*svt&a$9d^Hgn?U<-%m-iiyzwb4&%A!>Z=!tA?g
> zgRS*S$ynjla2^U*HsSGj>FdlI-?C1NP8D52(M!7epafPh!;uIGw^=>V8ll($JCp-?
> z>R{SKBSl$kw at lMW2l0cFX~dos$HzQLqj$PMXwS*{&XmIVjhMW|0tfYuUvGLY>#dyM
> zSZkL{nU6v0jI+u}o8v%BWA9bk+XX~-gj62{zJK-R>4Xhbj&3A;BnY~xVFlyq+DKlK
> zLw4aBya1FKT*jQ*F-UP0d{oh4 at 0N=i-)87gmj`LV)OS~&`TVJ%<j-Of|AIVl<JIHT
> zF7t-o34;QfkAcy}2exN91XniJez)&6FTDp(ZjP<a{7wZle~<bb#U7WLe#xNUsCh0Z
> zPc5lo{{`Lnc1VdX2eu5L*-;XS$VB8L<an!?7Qw34cuf{%MILE5^9DN*xhIv<(w~tL
> zF>`vU73UAs9_Zvy_b#Qenwu22&po=Hs#ItH7C|1br;)+P=DVj>*G5;k0(>3KRocVg
> zG!`-$SBi37Ru at i;Do3rIKtBA0g)G!;>|;txd$Ems3wvLmmnGk at cIWWd5N6pkxW3ub
> z+yQ<{$GE7=PcbF6)Pdk6Q)?wJZCUc_{i|d9&$C&d`4Z2Vf9UvMl)ZOUlV8^@3Zi16
> zSSTV$R6wLFf^=e~h=A14qaq+6AR;{^0 at 6zaM3fc<0TCh6JE0 at eq$4c_q$3F>1W4l9
> z{@!!$cfR+%<D7f{U@%7VjO59F_FikQxz?HsC4*!ckVagm%rvDQ{DhXx$X~9gNYN8?
> z^N`gYhOk%M6b^_+p7#oTA}+g~Tpu(j_aQZVi|ZV9boN(vpoc50zQGz&3{2&Li?mZG
> zPk_3TCJi*zAqBdlq=Wz4PaYT#(xo;J3|I%Hi!pSLqWXXO#gq0KB#?6Ef!<XQ^lyG!
> z`JZAP6cD4ThdZ=MSoZ#f+^qHp*2=vGxix^?cg*(85%y$U2Xq`c(T+S>I{M{#*$-mz
> zV^FXY?Y1b|t8={b>_mi}uhUt|^6uV0^4fava4!Fc-oT&}dVg1&fXW4+Vip<-Di<=@
> z4OgpG7*b1e;dt&k4KkKcgeE|bh;`cu51uwG?oe-s!R5`9*E^C at 68b7Uf3TXg{N#HO
> z-u?L@#XzP<17nR{SE8h~^>X#nMA%w>a!9s4SklrPzb*IdQof+AZpE6I+tnrH3FKro
> zK&a3tnmBr85=E#Oz&Ya_z1f+6&-9C#B%-zY472(owhc3p#x#zg++-4QyHCon<LIAh
> zOrt$AirHpu$l#L-eTkb5jNeLOz6rt%92O%g9Yuwpnc3NsSFt&QJejYTq&8b<Pj;?Q
> zXMu*5HT~YMGj7+b3=15cI4IaYvcYWA!!ZOr;2(jK6g>-1LJ#WyVHwQGLAn7ypbGtU
> z7KWip+5!OD6+j<^0>6eiyns`IOf~=q+8IUS-rWH}Mc)YO4g0V=0tM9bEM^%;<pOEc
> z+o at xA5z7{TM}j4y06ZE~MKSnXH(hWoP82?F8hH!;jy{Aq2%yR0Uua at K2f$DcXiUbx
> z at YitNc}3#{xM`4V&+O;{pP=_1yV&>~+xr)|`xG+8b|B*zecX<)18(a#YS)sIvikcy
> zn3rB>8 at qvekcnDcy3BAT;At1~pp{C|O`;&deAsIU{IIRKpv64|>boMs8Wf>WA-gbM
> z1OPt!!Fx#y6gVR?1-ff%ucrp?Is51Wjyi+-ciaLKox#`)TCjAzIA|@-dww$)It?#G
> zzV0Ko75~40GaSon2*}<viC}2gfxy)HaNH5x6ZDR*ZyS0SG^+ez(S3lOLcM^lKg1t|
> zuG}7gZib(x_kq`Ez2de|yGD$z%~#;ooB>kb`i)_}3noD-<yufQL(~He_ubyHz5<$^
> z*@)Yr18H68^G`Jsu4t;B2x&MAP|s8P_0!PR<3LmyHt6pI6otZmMLRL=3ZuldtHVA*
> zso!8L(;uAOP`Nfg?QW&;RUTI`Zk>@_YAleTo=t%Fo|(16tPF#rdn)0$gS?+o+diGj
> zM;cS_gF0z??laJ})QRY|7d at ALzVxZjVFVzxQwW?E6yJSLh%+$DPkVRlY76|eK0d_L
> zelmn6C$Br at _IP{CTaUL0>WUUMo<AR=E4s^pX~w0koq)UG%HVXK3smc4q?vX*3BAA*
> zT8J2*SK0z11IlK)RCDoa>=<A+PLkp<FHwXH;d4V}U8|#-k|7%6I;mG$^Ph)(^jxKS
> zO7z|H9BAMIzub$i<Z%o+D14R{6}T at brg_{i<i}TKFy%EtXT_(r#0iTx89kW7XSjD$
> zzUBVe-)Y9E(Y(3nUG)L<p{I_%?WZEgJ?*|H57+;4(-1ShXILo(byA0BTlo1lsTu_5
> zG|OyGUF}uVvuF|(_55Tew8ynY0|51aWCvXdWSC<#50rlgXRUAR4-2#qIeDA;WnMfp
> zuO2A^$`f(3yL9o;aLxVY9UuO%7~n|tvg$9*4M-JrhB3QhLmBYn=TvGt2R}^&Rt!w8
> zpd39WOo;F%?9Y?8$lTFoa*!p}`i$Z368)T?6P;|*r3#@3^<Jv%;A+vx at -<*K*3rQ#
> zP|6(yh#s2$h1wF3-*KR;0ULuU_Km3XoH+w+J?UEM>+5-EWc=f+3uE)ojmkWKaA{lZ
> z%KcYa<lhWlU0soo_LizaZ2qV90(hYH&EHjf0)$kOO+fd;!%UI!zH#O9uD<S_>Y!ga
> zYi?IHjTyNpH^Z<$ECQe;*bUWa$J38M<+^NF@|9>`&9`?GQnSx^bl*xX!W}4x`&5CG
> z`IVizL~%qd+^$(g?;wk at l>qDDf#Q6SNSn;c_-w?^XdYdRkpe{EKoJj$gk>39qSn+;
> zr;nUeoX#4QOB at i5Wl`rSGfJO<%Gv3g2}LLsrW&_D%wg|x!x&cm>PFa+ at iGMUmWXFZ
> z%w|>xT{CVMIejljjNa+D71#`5Imwncl5scomzr=us3CTMo3zQ(F5vD@!rb-1(ToE*
> zn05^^sLoNu-HuZf#}9+dh8*k?&-r!#`N`4sEs87CpqAvph)a!NChNh6lo#Qt<b8iw
> z9=8Wzd$qU42Tw9 at +bA)Q;CA)dzA-g}|FCe#P~LBJyx0Q0_nR|{NIql- at H|a=4Sd3@
> zp9~X$hfA?s-iH0fi`f6di$`$wz*KlNWA_dLqx`XShyn~lSUUe_5D&cy5(G#+(zOjj
> z$OmeLqNv+VTB at e*ED1Vb<DGtM>am@&4A0qwhWE|uQ9Hzd*gl at Of)Yc!yvmH>L at pxs
> z1FLf4e-8;k9}zIX|E)VGpL~*e*YKZU*6?pIn at aYj#}{W}|Awj6$b>~yt0K{Z41DL{
> zCFnU6Aq%zsN=j~zXBD;S-GfX(wwzU>pBN+}iRp3LP}-GRY!9Ax5kvoYu#4HI24 at I*
> z0jKk|gPzq#L@`=XoAbVU5vbXmwg70aD6IiEbBnx9TSP5>?ijJ=*8mecp0XI-My8^;
> z{)*fF2O#g8Ul{~<&q}+7T5>Ig?C`qovi+x?)CLuRk=HN&2EWBcU4K}#WstV*xOIhQ
> z6x<mSLyH43 at fU9J`W@|MkPf=ic(WB>%poilGN~6t)Hjeyyw)Y?|1HF9*Zpz&AC~GZ
> zEO1^Sj<mI|5#)J<LTv^`;j(K0;!)hk{9}_s0k7O}a)rnbe)G*0nJP3n5}MuR$muSt
> z0jJ{E3EQ`dUr%Z at okc&D+5wuksda{dWYDFcOKAC`G-h|kNB^jGT+@*db64%Y5}hW1
> zQTEl)LK&f&Ei;<kjL{v}byP6E4MKj`T6H&IKvCl-(va*-M^DI&2X<%^M_1%1{H?_X
> z4~9 at BcI{2cFCKV$MT$7|8RvpsL_P^mgnWg(FlmQY#$yU?Zio)h#q&Dzzge6qyexc|
> zO{B_67P_1f1U%pY849U|fQ`U$%3Kg!lYKOT9aNSQa(NJ{L2lQjZJ{*^en1K7(=2XB
> zsrn-be^2gYe^Q|(vsY)?`N>^95UcBV4B2B(rK9K<J!Mp_+oNl@@EecQ2YzDt`#;oO
> z6vboPcFNEaU=81gus5!3O?`O;eBw7%U`+{cQR{{cvZzri01{dAU(hs3?n#=E-`R?i
> z>kwPb|Gc8;F{;yEZkcJD9SvE3Dz^BCr7B?oMK;FnT*e$hjcvJt^8*_OQ3v_1;SQwX
> z5^6Lof*GL^2<k}+n0K9;F;opJ5Zi+WKNRR=WNNR)Lbiwx{;+)Lv$Ds{V)MWUR+KXC
> z68m<vg-|rWzbRh%7n5LjX74VlGlUMVExxn;hvimzU at U4WVxUg#-(^f0Z1P~fW+77m
> zd6#*EfZ4hD6tYE40s6`R!Okt*0`bWneg at v>y8`fzgf8vD)(~#<r!V|R6ce(IYj2Qh
> z!R+w$(LDfuh+ at cW0`!uIKl+E|{ts{#%hB^DR6vTqPWkHyur%oAo70RD+CJ#afd&q5
> z at L2eDfU_{TG)gr5j}wn2vor5n|3CDVO*%L!|BEL2w5x;aEF+?Jw+;WW+-+=Q<h0|*
> z1ZP;!pok~xp|ADfF{rO&5b`D}oDFXb?!#dUIlvr*tl!6-LaiA8!%+Uc1W(TqCq|6^
> z>k3&Ja6i<eBhX!A?(8*ssym=~u->?>GngM)pQL&Nb_a0B2lA$%COUsup5YAQ7nrB5
> zv&jX_BjSG#dkI)`gV8 at MT9c!T;wu0{UM!`-|FC#M7%Eevb9g$BA=8-60mQo*SY})`
> zcEE7Vo at wMn#xY6IU9Vbfca<;mjtwlEPC`BN!vT^*JObAN_N~6T2HU?sJi0X_9GujU
> zkBI-J0y}Q_- at Cs4{V8V0pk{+Ywm?QAbYTyCcv>{B31Cj6pNu0H4+Qvrysu<GHaG|b
> zW<Pp>?`BopwH{-hhNfU&eioz_(H?z#gle|TV*~oyXHfSfwq19?AXxy2?a3X?_9<{U
> z?~t%dteUGxCt_*+5oW<UFvw~7(i33)4j3{d#n%~>#|c0z|1K!UG<Ok-$5FOqQ1?DZ
> z^RsxuyGGlvJF06 at IO<gw$gUZ9eI^Iaf~vFEfX$!X1snNW!Cy`d1~%9G3;nek%<>&Y
> z at Ub`8x at o8CqelF|dqK$3(b-Wt?@<P-5m!_S4hQe1IyhtJUGP8>{585=GX{{mUeEgW
> z!2evyGkE$*y*WlQ!iO75F~cy#LU6jnu*W3aRVX19vhFgi3Z5ijv=(LRk+0EJn#s7s
> zsBc*jA7+EjfqfDgl?ob~`xqtS;m83xvJrF2vmGH8__se6$M=WjK`)As58+^4%m53d
> zpW?lz`|l?bDZ^|*t-r>ELu~&(-W2ckI`AY!R=B^QHa{X6n?ZWab4t9Z(Hi`2eBTIU
> zB9fctUD<ZB*DKHW518JNgY-Z(slGtbE^;ooUnl2GYct9!u>;VF7^aacMVm>){}WN+
> z|9eDbsQFK at v<T_FP5^E_6JT;|GHP at 9<hH))eabYZEWlXq=2jkTF_L+ at Sn%`e;%Iz1
> zeTzAH6GVlms2NWizyjEd1Dep$>NGP9^P71dmx-B(odJXx<=U&O3AynZD3Yaf8xjSQ
> zg)tA9iaR>Y+FgDut*01H<%BZSZtZas*;hBnzKxJl{@^;^LO&;xS$lrg!VgQEE~mVo
> zb+Y~MjZMo366Mu`?a;vDNYGCHmDq1X)A at kmShw{84;>sHk6=4x1{lmk!?mh9MdGbS
> z6x0H{+Cwc8735V9KID0-A|Bip;QMb`VuKUv`YY!;Reee-bIMfxA_NFlJ)U~}5p6XM
> z0|=_i<YZs!G;_4R4h?piYu`8y)GC2+$WD+vA6f<%SWF2(ewDkBVp(1pEuVQe^2Xcw
> zSM&2{3cy%#!dsS0G}2E|$O_^_AgZ;wA^I=b$n1q~9;O)WE|)+I$-JvjcCdJB5vYB?
> zC<3$~=lpTminGigdk)KnRV{NXXEWb!!1HW2CXUK}yJG2dtm9!0zw2~gXU<?Z!k)Ai
> zK_<`eHvc at J+CT5<NsUsZTbL%}ub><zwDZ?J=saqKKP)kHFM`Jb+Gz9X+tfOBl`}(D
> zIdSQZx-YNzJ2;ra--W!L at VOEj8hcQYBDeBu5AGKO8bZ0U2{bx?jvuCFyQVJnb(VFt
> zjQa>I{^Glv#FWPtu#gPhoq8zB=P-Nk;ij2SSZNBjiTfq|m{_XeDY_~-v)ua<<JasP
> zsWXFHe^}mhRv6L)>Ny6(FY{jR6AUfvG+OiaF2_M`&Q`H^+|54ROeV&Qbs<Y%hPunj
> zdnVSUSJb%=y7%1C$k^6|lb!zl3a3cKr#gN1X!XO-P$P<~5#xnJgr~y$dbO)#VIxQm
> zS{`|sBvY$TfS;zhwz1y3(qfN9E7%W{dbgG|*Q04`?GUm7I;3VoUnyJ>!bcOHhg64;
> zuh>p-8JfMlf@!|qxVXIYj<P}cUAiaF98iTuJW+SPS{QU8g%1nrxhLvh{|L|Y3z-Q#
> z)7Wfq^ZtCE)dodi&Of;YBVceP!mkzyA#)dY*2$0y(4O2!TP()Mo|qWi$<Wzo at 9NuN
> zEC(e)vt?ReH5Shc1xb-Rs4Fz+43vvGnt7InW}s0h!rC$ED;M(J-0h^C&G&~9U&S9U
> z2 at YRjtBrl-x&@)?Q+}6H)TqbEuxPsem8s?R!>iaL%aXyeE9wt##;<(-xHs1joj86t
> z>v^hZve1L%@SEH>cT%@E?v}*+r?gCa8Vnc?d&94+%d*Wp>1u9}YpuMa=%C*lr!$o!
> znp-p at WvkYtFdp!@pVmo^U>*_7r$LB$Vd}i3z6f)x3Un5z2Y;eeqrcqr?0kq=l%DoQ
> z2jB5*sC-C})T+lp<`k;5FXonn7b&oh-S(T-S;~RXTkIni+wD+3-bG;r#v3LJZO(Fb
> z6v<C}rk1Z|wR|`3%LT{zIT`nF;M~?@+8c~1K#c*6L(6g(CBx$pM#Ox~>rmrxwS{9F
> z&8zE^Tp1RaLcbr)l&c3W4yL=bJ;_9G()$J|miS=0iHd344{XXvlDl!te2m)^ZpVK#
> z at P_z;Rxk;}O)I#iZ_=XrJC1ZlB|^!{d(*2W)@kjW`sg*yXFnH1RH=>FxfFehcpT0N
> zK0aYnNzRM>&2LKXh!h_znhn<q=hStZf1Dv|a9w-MPo<rttv<S$oo7?{JIu*1IK<Gs
> z<dX&vae-QGRRu<(%Ce2+Bcusiu$pC1dv2%Tca<hwbfR474mP4SmnikD%fNgnd3;<q
> zw{m0=(hY0Afg*lE3ZTX&a)BSQF=JfUV!fMb;JOp^pMH}|ZVL$U_Jv~_u}e6SZB*_$
> z2&-(c%zA*M2C_sWYq=qXNM7LPZXZN>EGw>p!u5<i2z6u*=Z*OdBf|b2SioAjcfjQn
> z-)P()cHzqa#A3~$)Ird-E}#N1gB4v)JfGPQAW_B?0yxP7Aeu=G1{<Sk`wz>m{E<B=
> z>L~!%Ea`FpwW68nzn5p=G>J9(Ywnj&DmMTJ{jXqGy at 7<u7ibHBUT&J9&1*Y495BX9
> zd+4^rZzx&c!JHAUZkd3g75&C-hBxDGP>TYP<vZZU_YZ?OkDubiK&QZWZ$5y3 at ZMAh
> zi2HmjlxEnj4jkWkVK+d8!DmB&Aj^B`xg%Y}Wy@#mZ`TcYtLey<EqD2ZEKNV>7Ameu
> zcDNsSOoy)TVtkC-%2>DHvO;PpR76u0)pS+yFdgO%Nc#2wjfM=VHMAb(STbjW?vA-%
> zLYG|bY at eO$e4!Wh0OO+q=91-OO<~F at ljg<LS&7<7|2eruc*C?6SM&ijHeSkD(f;oR
> zdhf&`+Du<fHbG*pZe&toOlS~hVNiR+BXCa at Ibe6RRtZHe)I4utqgAbR+AM8So-073
> z6uM|7EWmgVLU7<lrd5ia>6SC5$%pK-{R)dNggj>#<nU!F3DJ^IGyHH6mmO4)PH+Up
> z&V<~%?5l7B$P`j^2<XBgJP|IFNpAUmsgE}TE0tRY9v(WHWWd2}YEpMRc~W7}$_<xV
> zyqirnAtAwlFschE=+}^+T1hf~5tF9$B+c^2>o at A#tV4ut<Ggx5r_~<vByEk#Ju0_S
> zNN2#C2QQRAVVP`KUYBK|9>3C{_O|UQj;x;+HOB}kr{%oSeNaiMpEaMrg=zLUwsIR)
> zr!#c1bz5qJwuahugKI?VG{H2VaMDT4v{qw*+>a3L8MuFVgY)a#rhq<37#+po^Y_3;
> zraMJ-d8+vMLgLf2uh#zD>tasB3_CFZNstX7ks{iR_jEHdiAqcyY*qEEExt>ZEiBQ2
> z`$VN<c4rSDdu$9jb6$_aPPB2>9eR|254(L2aCNLnG}uPivsCN~fZGR7J>tBW)-)|S
> zohLLoeprbmC?}Y*+JJkAdcqye*KiE1+Oy@|+~iLOF>OAS#eiEsD)D+BrPl#BNBJ%K
> zgbLUaxn`Bh;gav01!}7N%m#+$%-+dG0pc2URLH?^veL>wE5z8^OV;$);>x7h`V+bb
> z<-&*0$bJ<0UO}gfoss7ZH&0G^ycV+0{n7DOolTvPq?M1E&s=vEew4XFIBDWqWM(pd
> zLhfQk!q4&6y0CbKL)qfu?|Erm;6N<Uo*}O98M<PQVIOQr*Ij-v`?EF_T|OCZruj1R
> zWxZD%VXFx{aqn|irs0gO`hk}z!%Oy(2s1&H7}E_`EestPjQk4Dx`n1t)1o$;fn=A1
> zgcyi1+z0Pfx;r9ykyD`2*MZnKzR?Oj4p1!?TX%-U%F&fSVVx2^ZWeqFOsaVK<o$zM
> zmfthViWBs6V70=RknA*PqTvC*QsVHN!t8}q+lDmG-$?;vo5=T34~_f33)oUW^>x3;
> z++n2shgTxYokn({SP)*)>#n$?bbv;(WxR8>MowPw+Tg2vB#oNxn}J0VZQM9)?;5~u
> zZ+Dre4mMDO5b;maI^y|z`~uk%DB&>4O>)1{%f+62(X1?toPx$Lo}!%<V3jsd|7VA^
> zCH#MM4D+~H6d?`D?S0ZyJcRB=LUZ1we?0yAGX7dbCcnoU!t<q8Pz9j$|Ho&H at Kz-$
> zc8T%6?KhAar})sJ1d-t`_2UFtl^i>pGjE6D0zBuQ7u+r{>Uwwar&7)!<{d*$dqbkn
> zz5__Y)Pn5`#FZT2tTW8;BKjYeuCn3X%egj%YY{7J$1dp-Elq{rUt$OLAE4hRedz2k
> z0$^Z!L*|4&{Cb=Fj)w2A-RyP4>>(j_t?x-w`oPzmP~T%7esNG!#pe&ptIIR!-9xZt
> z$*j-h%b5YAvmo$c`%Qla3_FxLE47vWoVTY5x_%-14~qwC(O3hO!<Q-Uh}u31B5Gqz
> zJw`PPgsg{&X0JN!%S>ODqU=#kX`Mt=Fs^K>BTn7gp~ywmb)od9sH*94y-U82$Aomx
> zb0Bcj*fF_ at B&LxEMSJnD_v;<Ni9+qy!ZeT3I`?3cw43b}qoV=xkG-b%m)AVD(1|-z
> z at F-Bta}6%lmQX|s<@&lR0Z3lgX=}_6sCKo(Wpbd(8<&sd>G8a>d$jbRWWn)O*A3{c
> z6wsGUmSWfBr4>CxEeJe9QGdS$M#b18_{kWUF98$iptn4!M=h`A_ at MswgLE@iMcU5B
> zD~~=B$N~DOph1KU)Ei-Vk*X`<^+g5}%mCErH+sQx1FQA_Y`mvyP%0{&N$|K#S;~d<
> zq}%qNmtjg at wdD_Z>pJ?fh9t7izZZpVUA-pAvW1Q8qo3TPdT%t at inkWNsMD;LSlsM5
> zQ?U9WBU0d9q;eO_;h6?0_Y>bd{ht@;9UGjl=-u;z=e=v%jG}l%`1Nro_jk at 1Ny~r2
> zs2dO1b!v?y;TqQ}Z|;mRN)CgFA_W1X;vyilqX&>n2v##tHOfzue+r$wJ)njfj8&wW
> z{oiYB&`ltSQvH{Xk@(`-6#C8oDzPzyN!Hf*EW*1}I<P6!CE5=j7AR3|n8wD$<SH_h
> zF!jLPo};WW4NGUV8E8;*@TSL#hGwqaq#LfQAYXQ>ugL?D;rX|EXVJRF1xkcJ4gy)y
> z^Gm2P-p`cms{+?gtyv-k0nP~e0AlBt at LiTdpTEul8D)6KrGw%w#~>lG8-Q+z0bEmy
> zIb9!M1zx*<@!X5MHlJ7nC}<BacsKXIQw2G^Omg20JpCyf%Hkikn~ERgg-Z}|WUxpB
> zk0HG&tJ-8#JA at PJvL;~Xva3kX6d2yBjk~Emd{=s8^mvzqr@*TRH?ePdQ_jZMw*^HJ
> zur!I-=<^k{DDoI|8(XIq7=qWiFr$I`g(bqj at LL7NQ89`+TOaw~BuQA_&tPjOY#lJ%
> zkL2A*iGw~e{5jvA*d+sgg00}4TF(TpES+61w&jWwpA2gyimIPhJP5(6{`7ucoiU!s
> zc=Ctk=C21ceTO_X&B7WzGtDGRS~}h+O6X5LPD+tekj6{m>P1&8Z?ZSxD=Jr(XHE*)
> zcf6umt>5gaj4Vv;>)QQ(JrafQoqmhWQ|Ph3GqU-~Tjr$s;Fg=J87J>>a<d^%Ozf=c
> zi7IRl7$wxCK$mzv&_nQu%skg`vtBV?pAIYD-nn@$Hh%IIJ`Qnw?-Jb<^c{JO&omu>
> zoSHlvz=tiewp`kE`F^{;^~$#dwI?cqjVhd at k_R6n^xxfg9n5|^5SP1>4$rNqU7M9e
> zvOk6MJG|{i9duL_B2(s)CBFulrrJyvm+w4E+TOBi$lLV6cukaRX2<*%+UkQ^CE~6@
> z6W%o4=DBw%EBYeK|N6srVrY_b^dI=5Vqm0p8IIU=q$aZmd5H0$NF6Nf;an`K{_^t!
> zRabA`t_hKuoB58%^@QJ@>AZ0{ev9ZS3%3?bG5w%N@~Q01+l45$?KmJhE*6GoyE{J{
> z-<1)?EFb`K{f`N6pAPI7n$J{L#%4C`NA_lNGB65#$1VM?z$lt|9$$JmQnW3r!p+Si
> zmG9*$XLoP~gu-vi`fRkpx$b`^tS>#6#0DtgrhnRqzZq$CFnv1Qa4|2?rQD5~*NrL1
> zHp|g$AjN%=3T~Q{J)|IMPLmr=vy(SY?btImrK`527NjUZY?t;8d6YSts#WmG;0Mjb
> z++$@b$k)x{eL{n7WQPUbH6UzSZFJK_ayGOql_u2+%$%V|h at B)2jrB{l^&oMfujZj-
> zCM!}M80kL!WwDm6F4XQDvxz*#Y|1PwQq3d-;Wk*?K>PjGzB6kh6UcmwQd`~SxK{fG
> z$5TfGbv%4sCp?CsBEM;~+(&d09j~&4pE^4anWtdqQ>ZwaR{@QUN~N at JQ&Xfq`bC(f
> zSPi;=JFgb}l=&q36eT%fN at s;dqYcUM6K|&YsSzC`h!)=ZaI5lxCo^Rgbwj_js}q%f
> zNczV{MtAeDW>jk!80b6FKza=u+;D-Ws?Xkm6dbJ6&JijR8^|CRpPCX3IeoQ*B5|-@
> z_WZYBX%9q>uJ^dq6ik>cpv?SuN!?W^RsFsX*({nxi0QQLb(s#LwFa$iZIwQ2YLN5j
> zJZuDMILGFp@^^HT9GCt at irCbLfmFEU?Q37y*un*bAO_8q;JXQ^(iFx4x)FdofTlY=
> z4_YL}<r;0ZjZ;YzrnICF?LF%g7E3=A9&5x_tSik8>oLz1lP{sVM=7pQ>d6w25LaCv
> zqU9dGt;IE+w|FIo!0WGCQV<i9<UV2rw?@cqAoHvNhsDN7$1Q+d3;hI?HrkInguFzP
> zn(=6HUE}pTF~?liDI3BYzAIY2%XLAA^y&rB>yY%?+QcTHh!YSt=z{CtOm3)}9P=jj
> zGm;%~oSfHa_;NQQln(ji7h^mqr|7RJ;V|M9ZTS+*bD8&`@{FJl7~m%^y77ZsPclFA
> zdyU1nwi{DQxSJ$ppz%SxCI3!SsKCx5tw8e4FTevixQ@|5A|WIN0Ue$o at dr1ETaW8{
> zW`T at p#_3%LcDLFNg~Yb1O+orLOQxpDsu8mjS0M)!gdrsvl`WtQOfFJkk8zbrvXFI?
> zZs_NseBWz->MM27 at l^XI*1iikOK-+eEs9*Y+;hWY&OWNWX#eBUOTFv7i4w1=4jMs0
> zXhjM%5=zK~vnbZv1*So1`gKx*6-2j>E}#12y&9|H?RR%Q?aUv%a#Xk?VgHm<N$hjN
> zwz?Q;{*dD&uXdPUMTXgt69y-9+>GbS*FHPzcH9;n&Ws%Z-ZBK)o8`!ELD69={_(N1
> zFYgbFU4tx8WpPGF;DwmSX(lbqeKGL5%E59kUlhvw{)6ZXm%b&m^_f2bM&|`=*auEF
> zkb5zb8f&6oh%g*70tEmW#$zHuh}uUUL$Hs2DO4GnI2OS%s3~kQww!tFhxFFDPw&cH
> zhxhbbnbz9x#Hw`lI6qQ;oG_4*c03w&xytIb>od_&ef-XubhS23j;9TQFS|?dg{B!Q
> zcI&@>MLXw?>)tWwyH(b(_F)}MKS7_9i)XJs{THIG8IHr5cTdi+GoqFLin*~7v{yz6
> zeLv at x+u-D|Wnt-|2cuzM>ug=-4*R at SU#(TIG7;EFQ^CS19bpP<5c+uvf2eoVn#^W~
> zt6}2zCB3Ug7j=0Go`~tN3oLO4`fHlOIg_NNM{&+_^%dnin0K^<j-Te<B%4yYR8mXL
> zYcZcMs|GwnWm}<@UgUqT+WyzzIU1Jew4z6 at B(iq|v6JM&)o)YwEn5#*d6eG%JZ)89
> zyYoYr&E2#@Yf+-32kxxB%`Lit-}s`eB;M*UCSi<qtyaozc%!$e0sR;exubNNqR7!A
> z`RqAS>k^{>7vj6O=;o at kjPAv(=-t5`8u-T|`9BMvd0x!txjg2cOZ)#YC~gifglxng
> zLY_rfQ{-Z|Fem7DDu>JKZ|HSJuB@#L99v7AV6(o=CYsKtp&_+`I^gFr*n~NZP$Do?
> zT?^urZVt+9PN>M<d1rO;yw0oYd#q0`cCx^l$?Z2|8tsdDUB#SNo#wqZGLI3z_}IRC
> zSTL%ql{@0Q^mB0NZ`#|~%s&eM;+pb|2HIsW92rZ6X22&zn8vmgdnOLBw*wZg+o0$5
> zzm0thq9yEc&@a;RD7CGbniTO!<ax_wtJY<iR#k6C*0nHuQ&zT#%k4bg5B;!(b^OEv
> z=s|=i5TxE*Ec&gmdQ`7+&`qpH(g8Fh+uvxrcA(-DxZk#?RPE at dIg8XS<6jx8SYNMQ
> zuXZ`!5 at At7camh|cY_MP%O-VCu%|skOP4=uTK!+Esj(yYSm=>W2#DklcyqJRGXJnx
> z4sKd^K6qpKyjn!JDgN4W=y~OKQxvz$I(G=XM7st10>!t*%}-Oar4;_o@&DMFrzec{
> zbyKi2>Ed}AEOfkLwO>5oOP@#^tncDOLW-zcP*4D(B}Coq+cVse4b3yHci@&-iK-mI
> z_5ss at x*CM^Zd(9s9!=*dW#0Apube3|tPLamTQq$e%THS*-)zPUGfyox9HSt!NoUmV
> zlnjduC2aa<#hWLKyg7SRS1_*D!Tqw`@1U3Y(OpaZc@*8pNNu9wiTmqZGL4QF?Zc8L
> z#>vT3Uv?oGsQ;d=MK*LWKLtt6p at QM1kYJos531F-;mC-(b^aNbL+5Kx4-eOUxOMxR
> z#IF{C{c9S}RIoW&DzSTzJ9EVJnhJK=yc?CR*qzGV%=vhP(;Es*fV5##U8$87R-KHg
> zJ=C_i^zNVVPysMzW at LUw9CXi3(I2$F{O=Lm8Z;iqN*AH*HI5sG(;Yt1V)O^g_V5)q
> zFQ7enj0LXBKYJ8?J@)eI^jFRO%$`gRMrIM+6v6++4{H<y=WC{T7etDUyU|zE)IZs`
> zBj$R&?96P?yqf3YRm4^XDt75I$R~SrNc7GDxq}oT8411RXNk_w_A03T`4m(b^xZ}!
> zoyUvVUQELN+-??D>R)we5I$L#4sSaq-ETd0C{#aq*zA2Q<l0ZdKG!+u7><ged6V^s
> z9x>`NGkvRRiVedcZ9A3mu1foYXk0d7_V`yw2N^p)A2Pk(t5ftKnj~;6yW=cJ{Kxwt
> z-1~(R*5JZ^Yt)kr3>a;5wD6A1Q46x$a7T|6E%4sD$W&5du}+B==9ZbAs&`K6?5W{*
> z(k*OaeXfd9yU5$LK+-(t5a^c?GP#pC{JQ#ss`;GVwnl2u$BCNy!BX41ATBuoyfu|$
> zY5F2NWOF}?k^?+RFtZoF$q$lhhaq%VG at N#!udx}#V=u8l=xsbFq3 at RyU_c|DAUHs3
> z9!nZ!a)7aHT-g(zu=Q&z7IG}m1rh#jIp(!3a1o{g(u9eI3v8nI`9Y0F9VrKMOBe~V
> zWtGuae%)HHu!c@)DQ?-Io)QwTMAKS`=oM`;_Fpy?0&MEcUcKubc}Av;Idwz_(i5U{
> z>XP0gk6MX^7L3)Nrd(A3z|<K*!gnd_S<{MQYMZMcXqd>Msv837{2T@!ztW?BW83=t
> z?Z#zP{N3iC-MN at mZ%;53`OlIRJtBWh*%}LTaC$!_w~%wHJuPebsoj*e%kdlu!EiOR
> zch}W at 6&aUkeJ$ol1)3QN#qMG<IpJLMJHaz|s_TiFgHB!)=~-AX>sR_CVOJu^lM_<$
> zY=}B&3{tANZ at -HVoE`yZZ}aC<5{%A<ae8=q2YGmH$f^)yyDqoi!@ksAmn|BfUa-LZ
> z)%kiOFW8LX?Nf)WObBZ;51Il&xV~V_rX&Ie$PhO)$YL8qXcuse%>WQLTT)!bv2=ZD
> z at Bq*>pUTF*T|rF{Fc1a+%a$O4YPV!GLw3n{dM$lF&<le%aU6snp_{fp<yow-6eriJ
> z!xrSft$g-+acz0 at mFvbN_=c;<L!#0BG%V?p)HlbWFHyUwj=Y;&*xIc^u`Sd=mjG3l
> zfbe+tRl7;MF&_S7zm1hXI5=>}uA34 at s}q6Ps+dx|?jII8nY!OWPDiDej9+`fc*;s`
> zm1=!f3g at e7eS7}QA3ZaD(XM1{^ET7zC0zq>JSQ#RzkX8RAaLNB>PK7F1)J(wR&)XC
> z0rV%4c?Ka4BIXQI?Q!<lI_)Q%=_fCU4z5^p6!cB`U;3hbulD+yRRaXzxj at 9Re)XW-
> z<qa1wHUe>j3e)of<s{7E)!(PiwDg!(m^<`|x;HI6JIuTN+9+7~@_Oj{M!QCR!MDzJ
> zA=8b+GsPowdlG6BOaaJP<~dsBtA0Ya(qVFT>W6yg at 9IS!+HTCr`b8hz+m8`xd$x$f
> z5J9M;Uim<w5#8fGd&7 at 0xjvO~jtZPE4~J9sXP_e(&v?_IGEHY^<Py?MoB{Uc9)4sE
> zIX+&J at Jsf$_|ehss1iej`x#I4LijDSdu(nq`R>{{MT!y{dcQ9eattZE+ at OFPs`Ji*
> zyQFB%1?uyyk4PDvWAl=%ul*|htmBn at fKjWBT2w)7UR;x!sWtxAD#LPzm(UmMe*xYy
> z*2_-{lOQbReIr$;+hi8hj10!?$=5FDjbGiqXSZm+T>-m1IX-zyEX41vs!pu at Dd8}k
> zv!QrJ`nX?Za}Bl;G7(j_>Z_kF7hb2$yY=3y%+5+%*>CFba{ay;b+#t#0*vU<k_HLG
> z9Z<mTTdbLnth at ek@k3&Jkc;1JRkX;rnCG7DNAi1F_rG|`#logW@@;~Lqxj1d2I(lG
> z8t2nn(Eg(Mg(A1k<&sC|hJ at v-$34F({%ln_U^B>Vp!;bk{PP}M58JqdXIHmuB=dR1
> zgDey_q*Yc|xyW){)+Wiw&DB}0BdsWL5T5>bv%klc){cuNxoApNCO0}pZJNsnbWABf
> zdGwr+V1jCC1Zilw-J>)>_w7eB6}zWUP0B!D7v3ptwcW<4Dvy_`Z^(BsQX_a&IIc|&
> zLCC9UaNHE>pcJVoBjpdvxl#UdQcj*IcYgdyAP`YQEB^(s_4(c};QebjCwW4gb(`o6
> z+i58<)-dQcd7i`{!IVVs57c=R1%Bs|nYj*oLMeQ665J^wtv^i`D3!n9{80KySHgXF
> zbxR67IFT#Q0mBg49sLP8j6D4qcc_8wF`gR%_5BQAs4+35T5bs(|9wjDO7GtH^Ac*a
> zPabHW!on|PK3|4nwIullCh&$o=zFaQXt=`ql1JDQEE(zDv+CB>=?q^f^sh$3ph7sp
> zdpx&y1{-w@({aVprXrY>Cg>9niZ(7EjXY;@T6&(fxiv0c{?KwykQ|wtI!jX`to;;h
> zWFDu)W}X|^TIDye7Ras~jHT!l(?2Z{Hl^aZ&(7g)(%lFihw0bJGWamM^9N_<xgWA$
> z9m;BNXc5!pzp5pK`#Ch7i9<N#gLP72?pw0 at ILeor(yD*(D(cNh3oL9VHh at jx1c)+;
> zqu;#L`5wS{UwFFYF4<0FDNv*D>NW(VD3ODkn}Pu9sVb)8cY1WSWG~nM9{lCw(xY}E
> zbqo*OODM7z1w57EKb|VE8B?*=h(Ap?{DBaE?~*B!W-+{WVxZ^3z-a|}mBy}<jdOJ!
> z%rm8AB~TzNjoFL(iCRDNJo6|cn91#TbcQ=Z-6 at NfLUL#?%))C2K2GtadK^#Sg8A`%
> zzB3yTy_f at wVtn)`?#E(35a;|1_l<BBG>^8a)?wdJD;4V}_G;}$HE`4vvSvO-gepWs
> z6IRbl$a%ZgUv?}jHz at 7dpYM5^+vo8MU>kHm_E=^S&Wdwgs52t1LXA!v6;};<^M=R_
> zPVh^5{YvCA%LWzH at O~T5e4EN%uO{j$Tmf;9kpRMBQ;J(Vu88J1bBD5 at u(O*P<1<q7
> z-O$`yAnxt9;|)VED+)h1$x}JiqFXvKp9}3Yv_Ti31d4xKzw688G?XVTEV)|aGZ&k~
> zEAV){|5JzAXICe$J{a at J;XT!`opKb96AL8^nm1Anm`ElbzrUzKcxfaPWJX_N;iJD-
> zA5{*n989!7d3U*(_iZLmsjO$x!j-082w5K&+~6$UhT?6YK2_8^&s|9maIE(tZm&3z
> zp~Qw7?;w#|LyG#&MsM&&BXXSGZ$2cvE^{us1xXLTsG}Zg(d4OU-JVw(4Z1Er#9 at Np
> zO5Um9U-teiV`?31;_B{5O0^xYt at u7q5^prYOkfDb-&82m at qU1PU69&+dPa)ScLdo8
> zVW*!1T%O&fL3I;~tef?%;leGoTeU;d)8cOqn>%pvjh)Cz!K5j#!ToO6cB#c11WD4A
> z#9Dt1xwO|8O$}%43V~WHL!J`NtKDDC*7J4SUyBKNX{W%XwkCHvsAXi?0t!Esi?SWQ
> zsUy4$v({PrLX36D3G`32KXs<-ynOJ|ZKM*i6C&^&5)3I1!bjD?T!R=fL0LA=Fsw`3
> zY?+L-ari}l<;PcNus!hpqvwl7V-qirG?>%g?FrHk(b7n at g<dA)wvn)+$=FHwf|BFV
> zH~*bf`P1j83roeT6=)F=6y;c3X~z?~rV-ku%yN+?Jb#HzS_EbC3Z_5(>)SVYMK!P6
> zomz5QBbiIixhsSHd3ncx@|oe!v3N!FNr)jWvFeQH<mkA0iV at z~JmqVx`pK+L0f(mX
> z77_FZY~Kv9j}x>rbqS=t=$?3_n{n6rSu3xdQM~!pP{V$==d_$eoz)K(+5VnYVfR=c
> zvIxwib2r!D&9p2_XVzt<=pn_M{8DbV?A`+`$>(w@{k`eIagd{{tE&P1L9;0J{}@hy
> zYlQ4v_6UVg&o4rDZ*n5`z_}5i8Bq*pe52HZNQTGgw at OFKqeiSFpD*v-3O>^QX&-xq
> zeeA`hRtntOPYz%)j=zdB?2Ci8lg{IODIU4wde2S2Q?8$A4~u?r)XgZ71q+ENQ8(w7
> zZyo)dBE9AoSc}P~wUH`rwx$atI#>wkjx at JR`o<;C7+mrR^47ld{g4W_Lyjh))MAng
> z^0OXof=9hA6axXJ_E+5)9r>*P^7i9S_(!unh at CDajmRFxR6?9hYtocUF{v0xos;@h
> zr0~;7_Q4zZu}4nYY~g3=c_FUjB=wv*<-`4OzU5(*IrJ*o9-ZApw+`=Ks$5B)F_N)<
> znVgyNWL32GBXS?&4(;b>#0^G<CKm!)w|70Jsm86RZbRoMzrp%yR57!y=2o@(EUpmw
> zgV~1Sgc0XgjuRjFy7#-<ofWqpI=WBr%IBSHjB^&W72UPebypPa!dl~)x3WW0E1X9*
> zQHg`x_1Wr4QhKtQ8xLXcm_G at 3?TgGz>A;7wmy#{}q&>3|!obLS0*ms>0mSxEGE<2=
> zCR0klN!E<FkZMj(g!}KY$7fz9_j<RCA(FzgFZNSQ3ydkAu%y>tur*%kIc~{WDal{K
> z%=;aX^*A5}IMmJ=_<n?WS$X38ZGGv5n%AE{#=vwxrk<D%rZ2LnKdZ}3-krA$Xiv^v
> z4&a<lE*KkkNp+jll8Vu*dikn5;&Vwt2zPzZRsYu=mz%n{rm&?eBOSzPJ_-ZLLAoPQ
> zFNs*<H;!BF5s*^AXb=161aWs_f2vWNXeQ(W>aAijBpz;CGOW<G{O*LS>q$=@O4qqp
> zm(I=}vwV%FdQCUH{a37G9myP{sC0N{X+kq at l2AZA9t>F5cMt56GUTOQ)7eYq6f|jd
> z(N$@l6n)SA-~|f{t4$REoKNT+Dt$4UGM<CX3jp9p!Q~=aC|9{&KQ_7d`r((%S|t0L
> zWxE@}9fdATwHJ at cGp|ek#gpwIp;l|Dr?->gOIPQnJ_C)pxM(ODL<}=_AIK at xESd?W
> zl%zi&hB$!wVzV?-<Av|84Dh;<CFVCHdg3Y4nLnB=NAu|bK>svT21V!vIRDl1DDnvN
> z+aDG#BpbrAf#MOmwI+yP;t#l+`n-5q$!ERoS6zaR&haLJZ;wqHr1~3&N#c<qtvA$D
> zMkdB+z0%EoSA?=^JC`5YU6>|iRNK at shV#02>#tNMVSuWKYF3OUOl27l8OXsFK{K#V
> zbCvLPiLL!Pb&b5y+sZbH7t34n={N*{OG!nvG?1rt1W{#<@#q$pDy$KC?jL9_NKtC#
> z^lJ5GiqYP2Wq)=#X*a3OmF*~ULg&}Fdv3aH(tcC$z^2-7g6ZG11>@zBRcmnmW`AKR
> zR at iaXPO+<nPC?bUZf5%KO}~OylyLS7*>CRX6SEaHAFnTq=}P(1M4zFKA=IZY(L`pT
> zht_mPt$(<0lDZApF>GzUDr|GB at ZQSizGKsf{a{vz8rBb|HFU0qT=8YOV6j=<=InTX
> z70au`M_S{bYDw){J~CfY>A3gQb$%@dUMk*%i>)bfLCTXqsjhc?bs2x&<MzC3Oik{D
> zeFb at Jb!dcc*s at hTkOSuy{cI8dcPjkDa^)LYsf}Lya$#n at Zu<4-`xMWzYMCDX at 1#vP
> z+dJ~5!-|iFsp?^<zo_-A5zd at qe3kX=0vbr}EDs5*ZRUdL354Vsv5#^KNgWURO>RDH
> z-Fq}D2@?45edF2>Na&c$`&wU~&d6l{+VepHLte!M2Zy4XjVR{VRHc^8Ei~(8Sc{;p
> zZSYR+<+&j7VRg`<*)B&0+`VBJB)Z{z4UMwr<%h8)zlr$N<3$RxJgGbQm1CVVis$~P
> z1s&UtuYKxAn9&GUVmlet=)vx%oAF5XLX>NsyUD9t$3!jJnXH+v-N at t2ZXA09r;EHx
> zCMUUFaobR)-0cSOx9p8q^2drNgacR1`fk2r!6MIczqVh at bS({|A&U;0Ns&Y|?x3yR
> z at Ee*Q?O^!rI#cSyi|^~v^5NX<!WJ77sa9H&i&qn)<K7h3R;-rL0i+Iz`or at 5+7sN0
> z3CIfcS1Ru6?s1^LOEdZZuuOs+hJmj)e>-{%#8-J8a<P~FM%!xE;x-xPGOB9lxDxz5
> zc(fFJ9Yl5aNBGzVpACMYykuB~5TUtdgSltySqL at q>Rf(Mmb1*IvNWRvVdBeD^`82K
> z<GOf}nIp<=UcUsm<Tx{6ZKisOx)XM*sDx#|FjCRYbU*lOGL_HRFJ1lpyx;iMIMoE;
> zJrZ|>lR%^TIHo%or1#hp=%C9eiJvwIig$&vpz+}fY-48+&|2TGX>x-;%u!ITlKlpk
> zjS`@_^tEG-)EN?1?*yi~DcKIlDoj+nMSscXp{N_&`+D{&BsR1M;Ysiq<0nF1AmwOY
> z?E%mzrl_q;jSStlBHtJFxSwBZvbK3VU*zo5L)ZwCO$={b2XSej{6qazO)k=-UHwXY
> zx0kd`z+vUV^53h}B+c1#6(NV4*mfYyawIErGIM`gBZhnrer(A+L`S+#d%x9G!rf1>
> zS8so@?CvC7!RRxpunV00N1l20o!VT5s~`dy?+|Qz*X?NTs8e`aiXP^+?wbKOzPVEw
> ztvPzq;T9hcJd4)46tJ7VYXeI%ly6!$p$+OIaly+J9QRO9$(obiOpHF<P at Dz<rN=@I
> zk}f!5)Z;+8V=>OtOSU401FNg(Zp2We|M%?vBGI?#hf=#jv<HMPj|hC}Xei>OTXE9u
> zf%|3tJooj^pWP7cc-U8su7!0XIl+EGA%w`VHXIkN)^N1p{1R+jW)t>iWH*eFeO<Kp
> z>vP!?KXqAO3mu$q(B|EK?mzZScRrdxv_bQ~EVMozQ>nhEw%||aZSkArL}*E!@o+Yt
> zP+P2}yKO^~P-N3<?DUJ10n3m*G!P>Cw~<*Za5SzI9s+&riav^Jb}pb{@7l7ubH3_#
> ze;?ytwO+Zl at gPZg{a&nny*^ol`Wy(O?&SJKcQvKrqPEn693MZbQSE7!FDbj;9Co=)
> zSlMgnbl5A>=y7%Ll+vwHqMnDzffkG5w#4o)^+~o{G#;NVI=2#|hR#|*zs7i3uDq$I
> zTQ108GYYlh`x^4-d7MM^jn67>#oa5~S(F~63$h&wp^KA6NWQTSl#GU==Wfs1PlXMK
> zRi)~PMoqnzcgkiLLEm9)j|o@@gjU at TU0j5pL)>IUB3WplZC7c$yFqxUPVTeanT@{p
> zc8m<mPSLMX!zAOt)oW^7;;K$N2PJb=Ptk=E^Up|AQ6nAO>|u7Yv!^t9+MZ%g416M&
> z=XB>8O!m9A{mdPSYSUE=a!<Dk at LC3@Za*V~$9~Vg?bIqLO92P^^tv2~Oe at x!p at PWo
> zn#yF~;2Fx*YV5Mr-4UI{#W;?8T1&SQYfq+2y1TQxyJFGI!(gDHqyDrw?F-R=+*|Lg
> z;Bw4erdGXE3#J&`xON1gNzsbPT1b7Z6fl=2o8et(=s%Bd<M_<`Qkw8ln}z=U#kzk7
> zZ+bpO_WX%FlSGN!I;Isf?*j)aL_q6&{FQyh-k(j<A0;_!Q4)QVN_@=g-(cO8pyId(
> zb*PpBP5xJh`lu=FSbC`J^6oKc3v-(`3iNiN58+|BLz-#}(BtZtNzh3CfRR^&L8&rU
> z)ZtZpZ-|cdvz!_wT?=$tVbE*c*@I0>N?b2DiyF8(DFQxRrUgHhE^PV^fQjr~3{iEh
> zPTFA9V at Cm#*ZIw{_jj_Ly7P<;4Mq}&m_DfgTNCrnHc5Ns3OSpEX<s|xx7P}Ytth8L
> z*OOl=k1dW;qxSK}-P_Ooq~ny)a1^Pbf(#G;LKh$>wb*eF=GImXmdVKC^~>HY<R_Ct
> z#Nv+fvha;(i?Z5GY9x at rz`P6frqxb?u2YlS>JKT_=RkpGr~DU=kIN72dDYs#Q}Rx!
> zY1U-3kw(MZ)jju=Xv<9_ at d;DQNJwpQrN5wyXyUE!FEQKEV5%gUc4j7$xgR+te2U@`
> z{k%upDFXZ3t=w86@@Qn;H^+*kUk^1MHjcXWJ at JAMq)8SFhJzMkKN at yV7IBK!RG0y8
> z%j8?HyJq6*vTL*E_G|{z0Q>bScFWrZA612HP|cCn64o`%E2jp*dgoIJ=$IWRj{Bt?
> zX{tFA1WJO70pDC4i6|ooGmcq%K9VxFZU$@!NToJ<eeugH7TM!m*FY=tZjHWFhvm at b
> ziFOer2A6J5|5o6w+7kbVmrJ#lt99AOMw`K8tV*(Cj*qY;t at K3FD`?pYS#`4~*Kj6v
> z57n4?e6a2SIk2VSaQ|E_=1%_;`_j_DO7nMFaW{%cpWmnZvcP=w)rrF>yI51VJUOpl
> zb=uj)dUYB8<}KGdVC2{5@$Xj`9~Zj+9Z}E(YK4BCy$YvFfaq#rB9$S^2#5aSLmmCY
> z@>>MRWU1A}%xJHm$b&N}?WgKoNmIV<yT}5*j5Dtybm}UjMNX at gB#MUItd(tib*)jz
> zTYOUUI9;*7;TVFgU-JyjXT!9iU*XMLEB#O3&`+B!GaaYDMSfgMpo9rMtgFjD*G4S;
> zO#2-5Ojpfy3cIek(JIILOlYQ=o)_`8B&n77i(Rd~zsz|krgZsB%C}!oXY|e`cr27E
> zVfT-E7U-g`C2^)S_f6<EWois<GPI2c74oWGtG+zMOSXx9r0AZtBPl+c|EZ5$|M#x7
> zD15Oa#{M%{06pZH#hQ%diVt~HxAWUH>RYeRyfaAgIr3Fx|FMA6<f<P1c?(5$$5p4F
> z8;|>jk#WgSH|g>uUDEw|eaUzugI*(3h`eF8%c5q)(rNH<*P%}L>XxP at jh{Y!uD!WC
> zVh2LK0~|DNXQJ(mH7!ir>4y9>wSv~rm261H1<iYwkw>cA4NylaNkD3Lw2}Lmt1qnL
> zm0wG<>y;F~-K(D(Y#ya&6ev6+IH|J*j~!_$1N-SI;&AzpeX3g^>CJ}|nGY~#<%gIZ
> z4keYdw*$T5Jj(}8yZMf84bi*Uxmj(Mhx4T$y2ALowr!<Qvt7fGxA2nr76zQezuH7N
> zs&RF|a%HpUAt%ffvtQf8!{hvSy~^uVpRP~7IfY$dUP&e#- at +=>9LRyhzGgXg{VW<=
> z%hgogFTaJC?yt(U4YIy)NbdA)H(*s3P-atH=si+p`Y=1>n!wC1EW4QwmBw-qFQfxO
> z(8@&ZcE1hMir=1kUepKO!4F#MUyW%QQ<FK410J^@O~?53{Q`Pyqx1~lR{WlzA~!?w
> z4ek>-m~0d<nRbGJk7_vUnkj;#$hCg+K4Wq(l}b|f7QB2aQCs##sEdw(ef!ehH0SiS
> z$+;WKlb%Ui9RWn5I-2)IL1f0G#5D8LhDrQfkkf!*n at vRQB^5=X5 at Qcef&2~a6iZ26
> zYh2TL7y1-f*91_*QKw60Z$e%jlo79sY2F?^jGF!6wVz+=nEY2rW8uDif$nEYLBMYQ
> zyLW`y?y5KOSa$V7Y=^>?v(FQBn#@g__WLMq`d8Qr`JC|cSMvgFGA|7i;}_U&Ml*^0
> zTHSWaOI5zUqQ<%X4nvM_coz}{FZNx%NstTCWT9w>)%hPRc60mW5)<U)`{0SJ*360a
> z{)SWb42!eDy{@Yiu#XNf(kbXw3=d{6_#5<H4#junz at 8>88=kq_+tQlJnfTD|)(>xu
> z;zV81ml<Ma%dr<(ST3<6l|el}@*v=&+F%r?iGRY&2)JNq6Gir5?9<KHVy9La&O49+
> zgl=o*VNY`>m~yvRbdFVFdRAijfL@;bB7QbrZf0$@jU3nxDM7~}L<m4=xv<DJ)pd~~
> zy6YKo at r_~ftfPJ75$ikztOp0CTt$qx*YCMqpLt!DslnYmq9h|TBYSL8|K!BSYnzki
> zx~Jlw@(6EH+W{TEf01?|&-HSj|0nwG(GPa|MIQ>96O at WCH3|Bx3{&AD>TDppAAw{m
> zCy$0~3UadDssu7>9xi!v>WJP}Fdat4Q50h}$o*>0VlqhG{648Z^Sh?OJf8<?bpKO4
> z`%DSf at i6B)+o5^$PO*#Y-$zP4Qf^fn4_E9$uQGBFocVw}4M&Rjsp*7U*PE~DTYgy`
> ziW@!ABx!RVkgFl+LZm2AG~#=X`XB9mXH-*Lv~EHX>7rC=DoQURNQZz52poD-S`bu-
> z^d`kX00l8rLGeg0(mMoDI?_Z1q)UeY(j}or2=T6*bKZFOzBk4l_x*Z*&X4^o*?X at w
> z*SFSQ>zm)4GYnS8!zYLj&d+8~9+Ovce^=Sn;9|Rc+e3UeVX*MRE_~4I1??(I27Z-j
> zdXk_<gS5o!k2RMExUXpA+4>od@&U0rbbD_0{trRN8T8pFNw!4I1PAFmDR-LwB32*P
> ztC_ZEa#SPZFZbYn1nYXYW6P(Drcxx0jgw=`&d0cp6_us$?e3AkCZztxYm=>L4VC%T
> z_#S>M)4y<$j#`z*CP at E=sB0e_mTQxF>8my80QYthFjah)|D-0DEWVO~?OZ3`UF-HE
> z>!Hd$$j3U$>7zHHa=#$~T_k>D*#6wdifFsDgkjuA4~_snEGd{zc|!b)?c|^EubLJx
> zk*();AP5D>r>SWPUZt!2b-o#Da+c?u?L?|W%W!{mzd3WOQdWB~T>Bif+o#*p>u4Eg
> zI^PqiMor{SYFA at z9k1mT*{7BIBc-;}`z!AtTc~so=hShfSIkm|SEzD48$qwbP7W6_
> z{#?a6doAPQx1VN#2bMTm<9LM&{0$w2_rjTPhz<2!do+=6Q8 at nSy8N(9CS#l3mE~!g
> z9yTBG;<F`Bk>4=s`D?ue&51t at MAl2U+~ncua0-+=fB5W~lSCxr0*oCNwU_RrIefM|
> zAbYrpFs;2)Qc~i5nzH<~;>O6)-2X|W+_eIN at 0xk`ic&qF2e3Gz^f@`rx;G_SgYm at E
> zXbYh^|2#)jN1fWK`~PKr*_mJIVzn>ozKTEu8xBenGNHRF<~D9Yf4(;;O`CSbc>5y|
> zlE4kBv`q-$-vo=F28tCm{}NQKXfByQ+ at is)ET&}$s6iV?C5LaZV~@9zA2PNCzIh1U
> zAQiQW{`z|~Ns+D5aDvQVO1i_=u*@36aFkPHD=R-WS=5v>p8Va85r~>}fv71}<-KFi
> z5m}rNXKe}#__Nf^p=iJE81)v<<MkXDnW1NOm)iAKRmk?G%nrPy%cR(*k9B{KCEkDW
> zO<2n*f{)%PGSIK6-KlUo^@&AIHKNz^nnsTX8s`Y0Ky{KfVC&SmwKvG)xL at HwSj5q{
> z|Az1rrE(BzS4W!k at +a0Twbm#0T>f<Q-fT2j6gQ!eUKRT>0>JEsWN_{wnrE`#-b7(G
> z<FrW><`4a3mZMN+F*dTbhr8G2Rpg%y^{%yCEQ^X0-F|DTmpqQFJG85--JjkVAhOaQ
> zcu&H~`+Z*R1A*P6 at gIg;Pw>$n=Xg<%`nbVzRyUfeQ-dR(H-kIZ(_Z;n;^if23>6|-
> z7l(~25>Yq6$Hj5}o&uj3p(@Q2g(+?Q#e98}p8 at 3P2y3NBT6<I=)ObFOH)*)Gm-#V1
> zo}ani2<<4o=fI#8Igt=Z^%z$*VR`1^tCL8f#H-CS^}qOwJzMz#U~S)fQtwBfvp$n6
> z+<mP&u6as#w&6%7>*N)Zz6dFQ5*ETo at URNo+|S1(9vsYSPU3sL#QIsD<El%FUw$tt
> zMzO+N;LrF^tBHJ>-#-6HX{H5}-0NvFu8&A^T=DqIY{$&D_tLzBjU?^^ze0qc#Hw);
> zT?sw%aVmE!0uBvFGlrDmVmeKAXx^7Ah|c7n{>Yy6*|eaOhmw&pjNuU~bOy%N<JB;V
> zg|AbQyX7LCi|?yVV at 3OYLcW9q>b;dPJ at i9`_5b7Ol<_~PN6R~MkvdWMLJ)@#9v0Hy
> zq6Zi((bwUL9LH>ti*av-xXR&wEiV5Vj=m_Ienps$ZyZUGP~=(c?eNC5W^%TNJ(P6I
> zGPD?PKK_Anzv!L{h3*DRG|C at 1Kts%@5tgldF!wEQsng#dG0a}WNAxY1np}|b at bL29
> z;kw-Y_?bno>Q&~&6TykLx&|}$N=lxqS_1JuXqG7{6$k89H+o6uNCR_pAq-ZwnG^w5
> zyvjxm5Sw-RbE;h<S&w&l(u;#$>lfeV at f4dN7UHx92duUiLijUm>5|IC`rUs{Nv*H+
> z5Z16iIbx+bRpj8hX1Mov-gjh7 at 3e}#y_>Ysyi)R{v19 at zGb@T4tHB8!j3gP3`u28`
> zxbSD~tOR1{3ooVV&=;wikBHD@=<t^8?|?*@EXS%k`8OrHv$0=vW^Sr5=gM%#`(5VY
> zvHS*OYoS1j5qcdx_~V<T-HL3ji`eV&e;gcouBgx&g<GaYxE88lTdb2vw9PnCm*>8C
> zsV-|jaW9^rylnIBu!fPeV4VtP#+Oc9=2p>=MPZ#e+rgu99}tepg9>XmjCQn37JO!7
> zUEsuJH;!1}e{_Jj{<!>533yY;hh%P0sN`KnBdT&~<>{QliOWs};EHSWhyf?%Q=O!<
> z!~3w!fz4If8AZv9Q$9Ym=}!agladi~p^9rD!3&ur%y<Y}0JCOYrU<w_`E?KGB2d-L
> z?aUE;VjyQDjA{B2=~A78+rH|ft?~y^^WG&po$nkkhP!hqs6wPC48f!s<*~ec at 5zkE
> z(Q`V&(*+I+hvJ8C&vuS=D!lJ9_^dSbc*HgR^`yz;310urfq54YtnnLCS>KUKvtC(S
> zSAZyx9ru*}m6MFMeDCYwhq$eVZB=cZFKFE{QUkGS-_?FYKne*BctsRNJ~eV2RQj;T
> zNo~<!`I+Vd2JYY=r}?@BI$-qK*H1qUe8w*IqeC!ceNUiZ9CkC~{=V3<6z%gF;k=OE
> zib4K(f-%<MoGAV*k9KNZu84WsFY~$Uw+9|frNF%w;5dEwFKHAz>iaK0z{$z69dX#n
> z;N<6 at N2o!Gf+I-&`IDQSR>^Oll=K$$O4g{De7zEo9Tn;jCtc$z)^4+u5d_^Fok>^_
> zz2|*o_6TWg;q-}6(ixxvqS32<B{SCRmQLsTIk`xTtLLD_#$jr7yT2iTz&x{;83Cu-
> z-{yB2n at s-^`|d`y?ahMDc$rgv8W<U2A#tUbc42nGc-X?vmw40p^2T|IpbfL?!F^{7
> z<+qq$EJ8-*<#KPd_ye`gRmB(#YY$8g;B4v5K|J3F+%|<aLzI=_E>nh`gm#c%D3dbs
> zCczY2=QE`bWW7tDft#Ub-syxclMTq{t-<2o`>G493NAz at hc2Qe{;m$Jy=VdoY~j28
> zf9Z$BupCDd9#sVXG*q`2;95b33~mygB~GPsVgZI;;y-$RCkC}N6A}<IGRL#GJ*ju_
> z0(VfhV94ZR!9J#BvIf!=>Q?wa{(<24jJxJ_I0B(vQ5!wF!a+ReG5?1=zE>!!McD3E
> zYY5lAn102k?qp=oH}sJV5Y~3#tQXj`Qr<jM;dO0TXDlh6>p%1t8CK@%W%&(hqZs2%
> z%Z!o{e!^q3c;0QpZ4XdKOg;`fOd@@2CvaX9mi)<PpmJ{QV<ne(eReo^3UIJ<i~**1
> zxK%Wj)pAR3omSKD{4OXSN2_`ISsbm2_NkWW2aHK`ygs_D!fl+awTJKjkiEL+sLQQ+
> z=LAOiwBT9C#|T)Y=$EAsS#V&~Y2i+nT9kU)B6z2xZqByKO~zO(EjXXDL0;&1fP3rc
> z=0+bf0uNh!Om-MQCMeG<FTZCAkkZMRy-Sa*m+U{w4*NOvPA}5}WeTr{)y{QP5bnY&
> zGh;D at 7kB+^<;IWU`gCfJ5|!83;Qs2Xu(^tl%uo553kccA#ss0Zgxo)`tLm`-ywh{k
> z==*CW1lEA=S*H$xbrH at Jko`uv at 4RS{Go#=f<8z{Rq=eV9OvPPiFnHi(D)MSesOes>
> znBMTjXJftN`qlVp=I at yc)kxS$Sd)arXhT<7K)line$`8XPyL{iLQ?sx%ZApaYZPft
> z3ViuF)phkXLs_-8FC at 0IW3*Xy4vozqtW0gt7_&rS@!;ERM+cNN43d1T7cu7XyA{z2
> zaV?+(NR2LN2;#Fxue@*b*=oDnzY4I=w_I>f7ihW^k-Urg+Sc`Bi4&4^R%>O~T#;M9
> z!ZzBmO&cUWnq$Sl)YjT2<3`Sb1Hfv;`l0~g?`Rka<5rXITa0ISnN=O$cf!Pte;)FX
> z$a#K0aMJ5aWBQ!*ihluL3mo9#JAn&C8o|3Nh+Jfu2eSWK0ZZ|Y**zNiwcyQ=xef(5
> z^@G><W)bkSRVpQu!c%WjE2J9sHvP__$f6$jm5J*xHr;j|`V(}ASI-|wG2=@T-LIeE
> z7Y}}pUjp?OvicUKIBjOFx-L;192{~;T}=GL$yw7iX&6F+6 at yJ-yIc$Pl_6!|)zAA_
> z)Qh$?7;piVWhj5Kz>SDPCz&9j8YiYvjS7cRdYtVG`7q)x_$0bWed~v!ve~|9s#$`<
> zyyfc`pLWy6%ogL8V=isyZys+(cX==(VI9~F+&h=C&arsWgE}LNQMtV!RoA5EGQSTS
> zlSr1ywKG;9<vQq2FLDih&ZW%EssOdhvqC6Fk%(jFSZ(dP<ekM1t0t at TPU+x9x8*Oa
> zr8L1U4)VMdRZEuBpNn(pu8JgSP<Kl4;I(DlBY1hexeSdo*2R9xFfd35++A4OOROT+
> zwl|qZEleNNr<&Ld<z5$qVH!&I8X8*lrit7qAQOl)>J*U%?-cJwbWbT>C0&U8*7L;C
> zT~NB$)u~M^ZQ<F<T3xG_ENrS~UOr02EqC?2dlgo(mREO2Oxaj4YBlz9T=55ofaT)x
> zc+|c4iQkYOKEamJarMzAp+ejA-PY&Z#HcT4y)8u877cR>f$VjFZ2?r$t8dR_Al~}c
> zq<IgELd)2#$>V0Hw7m-NHfh~XQ;MX2#B?n;n+<>0oifUM-K%40>D8sfjfX!Et4^f5
> zryb|FIk6in3M()2qKnu9O1yWq=%lAo_0P`OjaR!KF at y3@a at lzK13;h7_X!6c<sGD4
> zu6mlC5^zN?DoL#rFG{)&W~VsPWROG&@=arzx$itmSeu(TJa2pW(yir*{KK0c5)!n|
> ztFXWa>4cqIT<cqFk=uC719O59-rwqtCEybD%UdtK6fApZbG at wd?K<3}SHM%v$wGm%
> zUu+o5#NX-Q#ab0`_lgPcL9k&I?n&2X$)#RtqGE<g8tzU>-CFGcJ2q#}O)$lH>`>oL
> z?E4Pb&;O<D-7Wb?_$J$m!@(xLkitpA0G{MI<qgAaRfLs(HAIJqXARI at SC*t9QJ8=*
> zK5#ZdeFHH+zagi{%2k_|DRgTh&9 at W7Hk#iMY0g%#C3&fo3tm8Rk{*o&4vgJ4$Z9`S
> zNOiX>xUQ^4VJgGW>*;WF$P;<8%+1rD1L%TY0AZ#D{0%Y4m*}#`C@&6G>04srYQ5ny
> z)obS>=^tloTejOg at ENI}+a^n at AQc;6TBHzLsI6H8TTl*q2bMnY|08-JzGH$<jOML_
> z%cx$me_iv;z|em~cIUyK;3|IHT%03jI(5e%^MQQR5-F|uMS8TB3}*gq{iuQcif2uh
> zfI=Y=R2O0B3?Y168P?;4^m at u{nOBi*SzY$S$`=n`=Xn;py`WDPpsum<iqk=VEi#Fv
> zO4XnJIl~YVt0r>a=G<FHmmk%MvA4CPm*eG%E!8H0z&B}&nbdR%gr8Eo)Xxz`^HZJc
> z&hwUm6rWYrx2gnsW52SgQ_Vv&l%b}dt-nI=RQN>nUTXO$jV$8t`~IS6^i^^naInMw
> zPPeEJLgs6XK#WF_%h6MDjkXJXO5<&$|G6hWKyZ=o{LPEq^k-z^O=E&AyKx!X=r;3C
> z-D(~E{L<|j)DM(i at I|7<r+^M<(%=`Kw93JhOxZy5rJ^hDM<3x~I|Z>YH;=GcD50Q?
> zpxkLy5Orw`Qxbn^&3?%07Gr3D>+aYG$G?xU(N4$kF0Os at X(tbVxG98tgLUfmU<ugn
> z<P#*k^eEZjunX>dd_E%QW5J_x*6THAt|}+l#1oYr!Jdc_#omf at dH_;w`Qq6E-kK*C
> zoc5kGGzkBEHRDthBS&ln+Wdp#fQxm;mz3F`AWc$S_%Vr&{#fm1zKx;N6Kvx~6jo5o
> zE4TWsb>*}nzbX7RtopFy#2U-I)r&j&_;Coaxi{m$Xlnjv5v_-ZJJ$65%Cfkn{Yued
> zMrJ`>CddO3#@>L|mutk|G=3JmDtTScn0xozW}O8ws-irE3&}_D!98!^ac*TM$~a|P
> zeO~zafMICByCXZ%@=7X~0 at eKed4_SS9q}od&Y`0C<rw?z2aTlCU<>Z9Oy&TA%U`cH
> zU8LK0!D4fkEj~+ECmQAsr(+UFC$}yKncdydP&qdeWcF&*s3dH7!=U0@{9<0Eu_h}6
> zIo9ZZT_UB$J(qp<3yjqnPiHMLg<!HE3Y>X4q36xyd<GVEs`Q+G3><f7YKn<XQ$d*C
> z64&U$y?rvvl+gC_&MR at 4O$W3vJ-KMmX?0Zug|H1YY|8-L%%ZJMqxep`=<>_njXpIr
> z<YCvI06t4AtePXULN}Pzl~M)sNkNGBn!aeEd0W3~uk8B&j+1>S$|N&2n~a9&=W?#(
> zD}94-bxE*Nho_iHFFj1xgvfmP!;yyH)BwVO1^>ALRYB`V$2i98`mx at jf<W84E*i~f
> zAx4ZS<)pHSYi-n=ydut7;<7nam*Z~tSm{TvYJ(3-G-TB1!&J9H&`<*H3M?Hw{uu<?
> z!- at e$5H3BA>OJ~a%;qT*@2#)&x1kW`5{Zi4GFqd1z)pAENB43c9hny9-Dl@?G|gaE
> z4b1(bKGCCwIT8u~X0ORB^DD&@ss#b9wmJ2hx>_4%B_}!W^@)cM3z~m{^POm3wb{81
> zv>z)Z6grfQ7KWChztVCE6v$>#b5ipBNJfiOoME;h`KEFR#Wf>FOdic&fG|MAZhtEE
> z2G8<iZBvKzpOP61&)NqWM>QdWgKPRbBb5p(8-_WdT+3OCQ+)~$nXs6BFp8BXY&43z
> zT8t8`keQN<SFENZriD4}_cE*;ITemlJRwf37$c~@D0fA^(r{tcsVy7dJP6Y(j1fEC
> z4XC0l#)$H9%u4H6`Va_XekaOohj7kmy8vN2CE}bDN_Qg*R5>D#)4f>EGa5wj(p*Ya
> zpRr^#Mf+{DbBT)J^=BA-b0KL%gX*VGoua0q&=7bD`U|<IDNaiRx;sx11C8?mJzzEd
> z`;skA?&VqJ%F1~;w at WrO=qHUGCgP^wzzP5rCyT~_BDv8FOw^!1W9E*DibvmAG(Pd1
> zfbph)K;|7{d@@i<R>IImj^Q0ySKH%CnGJ9w*K)o_yTV$cGfN at FJ}sz9_DGm5VL(DU
> zh9_7bSPE?=%xPlpJ`e<M%wx^a-cZ-1x!{vVwg;<8TY|Tej{yW67*>EeXd*&}Y4|H)
> z-ONq?0Va4eXj;-a2+SBB4X-*aK%xu7eSy60&P@!mU#q{FcANkM>Evc*Uvk;r6ydyZ
> z$l5_AQSVJ*wyd*W at cp3T&%XCQ8y_MVEHU*pb;-?}+tVi<;G4^p$>5oRNH{T^4EC0>
> zAq~Gt%1C|Q(JSc!oNH${SwaWXzdZdGGm^@oI7!=m4RIrahLTHBws!9mQFZ<21)~pb
> z-3HF0Og{a=YtH%m&`4Q(4VqoDr5W}ItgM9TsRd7M9)gkK#yBYy0JC2-vQ}M%Ff2Bc
> zr&vO$K_GF>Ig66>-6ZYhm?ei~v;`P<`ulMR=X}b?QarwS-7?#Hn(SmS0DxkQ?KuV1
> z4QP=21=Mt8RAfgyyTFG@)h-~Lof~t1e`WR+gocbUfQV0hVAMh(2FhtER>E0SZ8I65
> zYzTxhi#)rZa=oLYF(jk;0>C62)e;yKD1=fW at 1K=Q<TO=yP#hUajFT;yW!#oS>6&5}
> zDra)zTGNFgPGl2cOv#b<lt1_<kFgv?vH0)WJ?Gz@<MgxD9YH90S#;34`*6$GeJA$t
> zt-%?{t{0xvIc~xfHhtvQ6yjhb7vY*KI at DXI^WCW-D=PTP^<%2R+=d!q at n+^cJ}Y|$
> zKGi-XNlf6V+ewd0aZMk=?YI4e^n4?b2JIm<pXSfBP+6BDsncJt)`Xs25t1C!ho^4o
> zsmK3xtW?-A5GAiN5HQ(WLWv3L5FV33vgHj0WFb(6pWX=PEDAKRh$w9 at mn<0A9<udV
> z%!EJ2(A_AuzI=a?bzK-r5z!CfQvAyxj+a{e8CGWFC4!l4_6r8pOCtjjG4_k=h&E`N
> z$)I}oYZGsE!Pt^%C-QU7K$MKkcvjMmhXyr6|Cy<LR{mT^X~U~v0RumS##}v9oII^A
> j#OtO07l8h05V=wRUjN$QUkv<<fqyaZ|AqnP-xL1<ly<Oc
> literal 0
> HcmV?d00001
> diff --git a/user/tools/rtems-tester.rst b/user/tools/rtems-tester.rst
> new file mode 100644
> index 0000000..24c62dd
> --- /dev/null
> +++ b/user/tools/rtems-tester.rst
> @@ -0,0 +1,639 @@
> +RTEMS Tester
> +.. image:: ../../images/user/rtemswhitebg.jpg
> +   :width: 400
> +   :align: center
> +Chris Johns <chrisj at rtems.org>
> +1.0, June 2014
> +RTEMS Tester
> +The RTEMS Tester is a test framework. It includes a command line interface to
> +run tests on supported targets. The framework provides back-end support for
> +common simulators and debuggers. The board support package (BSP) configurations
> +for RTEMS are provided and can be used to run all the tests provided with
> +RTEMS. The framework is not specific to RTEMS and can be configured to run any
> +suitable application.
> +RTEMS is an embedded operating system and is cross-compiled on a range of host
> +machines. The executables run on the target hardware and this can vary widely
> +from open source simulators, commercial simulators, debuggers with simulators,
> +to debuggers with hardware specific pods and devices. Testing RTEMS requires
> +the cross-compiled test executable is transferred to the target hardware,
> +executed and the output returned to the host where it is analyzed to determine
> +the test result. The RTEMS Tester provides a framework to do this.
> +Running all the RTEMS tests on your target is very important. It provides you
> +with a traceable record showing that your RTEMS version and its tools are
> +working at the level the RTEMS development team expect when releasing
> +RTEMS. Being able to easily run the tests and verify the results is critical in
> +maintaining a high standard.
> +The RTEMS Tester contains:
> +* Command line tool (``rtems-test``)
> +* BSP Configuration scripts
> +* Back-end Configuration scripts
> +* Back-end Python classes
> +* Python based framework
> +This document is for users of the RTEMS Tester as well as those wanting to
> +develop, extend and investigate the RTEMS Tester.
> +License
> +The RTEMS Tester is part of the RTEMS Tools Project. The code is released under
> +the OSI approved "The BSD 2-Clause License". It is free to use and we encourage
> +this, including on operating systems other than RTEMS.
> +The code and command line tools must retain the same names and always reference
> +the RTEMS Tools Project.
> +Quick Start
> +The quick start will show you how to run the test suite for a BSP. It will
> +explain how to get the RTEMS Tester, set it up and run the tests for the erc32
> +BSP. It assumes you have a valid SPARC tool chain and have built the erc32 BSP
> +version of RTEMS 4.12.
> +Setup
> +Set up a development work space:
> +.. code-block:: shell
> +    $ cd
> +    $ mkdir -p development/rtems/test
> +    $ cd development/rtems/test
> +First fetch the RTEMS tester from the RTEMS Tools repository:
> +    $ git clone git://git.rtems.org/rtems-tools.git rtems-tools.git
> +    $ cd rtems-tools.git/tester
> +Available BSP testers
> +You can list the available BSP testers with:
> +    $ ./rtems-test --list-bsps
> +    arm920
> +    beagleboardxm
> +    jmr3904-run
> +    jmr3904
> +    mcf5235
> +    psim-run
> +    psim
> +    realview_pbx_a9_qemu
> +    sis-run
> +    sis
> +    xilinx_zynq_a9_qemu
> +    xilinx_zynq_a9_qemu_smp
> +    xilinx_zynq_zc706
> +    xilinx_zynq_zc706_qemu
> +.. note:: The list is growing all the time and if your BSP is not supported we
> +          encourage you to add it and submit the configuration back to the project.
> +Some of the BSPs may appear more than once in the list. These are aliased BSP
> +configurations that may use a different back-end. An example is the SPARC
> +Instruction Simulator (SIS) BSP. There is the 'sis' tester which uses the GDB
> +back-end and the 'sis-run' tester which uses the command line version of the SIS
> +simulator. We will show how to use ``rtems-test`` command with the SIS BSP
> +because it is easy to build an use.
> +Adding support for a BSP to the tester
> +To add support for a BSP, one should add a configuration file in
> +``rtems-tools.git/tester/rtems/testing/bsps``. The configuration files
> +should be specified in an INI file. The configuration files provide a
> +means to the backend of `rtems-tester` to automate the running of tests.
> +There is the ``<bsp>`` tester which uses the GDB back-end and the ``<bsp>-run``
> +tester which uses the command line version of the respective simulator.
> +The general format for specifying an INI configuration file is as follows:
> +<bsp>.ini:
> +    [<bsp_name>]
> +    bsp = '<bsp_name>'
> +    gdb = '%{_rtscripts}/gdb.cfg'
> +    arch = '<arch_name>'
> +    [gdb_script]
> +    gdb_script ='<bsp>_gdb_script'
> +    <bsp>_gdb_script =   '<Instructions for gdb
> +<bsp>-run.ini:
> +    [<bsp_name>]
> +    [run]
> +    run = '%{_rtscripts}/run.cfg'
> +    bsp_run_cmd = '%{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run'
> +    bsp_run_opts = '<options>'
> +Here is an example:
> +arm7tdmi.ini:
> +    [arm7tdmi]
> +    bsp = 'arm7tdmi'
> +    arch = 'arm'
> +    [gdb_script]
> +    gdb_script ='arm7tdmi_gdb_script'
> +    arm7tdmi_gdb_script =   'target sim
> +        load
> +        run'
> +arm7tdmi-run.ini:
> +    [arm7tdmi]
> +    bsp = 'arm7tdmi'
> +    [run]
> +    arch = 'arm'
> +    bsp_run_opts = '-a -nouartrx'
> +If the tester should run the tests on qemu for a bsp, the given pattern can
> +be followed:
> +    [<bsp_name>]
> +    [qemu-script]
> +    run = '%{_rtscripts}/qemu.cfg'
> +    opts = '%{qemu_opts_base} %{qemu_opts_no_net} -m 32M'
> +For instance,
> +generic_or1k.ini:
> +    [generic_or1k]
> +    bsp = 'generic_or1k'
> +    [qemu-script]
> +    arch = 'or32'
> +User can also provide a "settings.ini" file in case a configuration file needs
> +a path to, for instance, a first stage bootloader (fsbl) that is placed
> +somewhere in the host machine. The settings.ini file can be passed with
> +``rtems-test --with-settings = /path/to/settings/file`` option. The
> +<bsp_name>.ini can contain defaults and the settings file can contain the
> +user-specified configuration.
> +xilinx_zynq_zc706.ini:
> +    [<xilinx_zynq_zc706>]
> +    bsp =  'xilinx_zynq_zc706'
> +    jobs = '1'
> +    [gdb-script]
> +    arch =  'arm'
> +    bsp_tty_dev =  ${settings:bsp_tty_dev}
> +    gdb_script =  'xilinx_zynq_zc706_gdb_script'
> +    xilinx_zynq_zc706_gdb_script =  'target remote kaka:3333
> +    mon load_image ${settings:path_to_fsbl} 0 elf
> +        mon resume 0
> +        mon sleep 4000
> +        mon halt
> +        load
> +        b bsp_reset
> +        continue'
> +settings.ini:
> +    [settings]
> +    bsp_tty_dev = '/dev/cu.SLAB_USBtoUART'
> +    path_to_fsbl = '/home/chris/development/si/work/hydra/boot/xilinx-zynq-fsbl/build/arm-rtems4.11-xilinx_zynq_zc706/hydra-fsbl.elf'
> +Building RTEMS Tests
> +Build RTEMS with a configuration command line something similar to:
> +.. note:: The following assumes a Unix-type host and that the tools have been
> +          built with a prefix of ``$HOME/development/rtems/4.12``.
> +    $ cd
> +    $ export PATH=$HOME/development/rtems/4.12/bin:$PATH
> +    $ mkdir -p development/rtems/kernel
> +    $ cd development/rtems/kernel
> +    $ git clone git://git.rtems.org/rtems.git rtems.git
> +    $ cd rtems.git
> +    $ ./bootstrap -c && ./bootstrap -p && ./bootstrap
> +    $ cd ..
> +    $ mkdir -p builds/erc32
> +    $ cd builds/erc32
> +    $ ../../rtems.git/configure --target=sparc-rtems4.12 \
> +                        --enable-tests --enable-rtemsbsp=erc32
> +    $ make
> +Add the -j option to the make command with the number of cores to run the
> +build parallel where it can.
> +Building all the tests takes time and it uses more disk so be patient. When
> +finished all the tests will be built and ready to run. Before running all the
> +tests it is a good idea to run the ``hello`` test. The ``hello`` test is an
> +RTEMS version of the classic "Hello World" example and running it shows you
> +have a working tool chain and build of RTEMS ready to run the tests. Using the
> +run command:
> +    $ sparc-rtems4.12-run sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
> +    *** BEGIN OF TEST HELLO WORLD ***
> +    Hello World
> +    *** END OF TEST HELLO WORLD ***
> +The run command is the GDB simulator without the GDB part.
> +Running the example using GDB:
> +    $ sparc-rtems4.12-gdb sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
> +    GNU gdb (GDB) 7.12
> +    Copyright (C) 2016 Free Software Foundation, Inc.
> +    License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> +    This is free software: you are free to change and redistribute it.
> +    There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> +    and "show warranty" for details.
> +    This GDB was configured as "--host=x86_64-linux-gnu --target=sparc-rtems4.12".
> +    Type "show configuration" for configuration details.
> +    For bug reporting instructions, please see:
> +    <http://www.gnu.org/software/gdb/bugs/>.
> +    Find the GDB manual and other documentation resources online at:
> +    <http://www.gnu.org/software/gdb/documentation/>.
> +    For help, type "help".
> +    Type "apropos word" to search for commands related to "word"...
> +    Reading symbols from
> +    sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe...done.
> +    (gdb) target sim
> +    Connected to the simulator.
> +    (gdb) load
> +    (gdb) r
> +    Starting program: sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
> +    Hello World
> +    [Inferior 1 (process 42000) exited normally]
> +    (gdb) q
> +The command r is used to debug set break points before issuing the GDB run
> +command.
> +There are currently close to 500 separate tests and you can run them all with a
> +single RTEMS Tester command.
> +.. note:: Use a recent RSB version to build a SPARC tool chain. A recent patch
> +          fixes issues with the GDB simulator and it improves the test results.
> +          It is also recommended you use a recent RTEMS 4.11 version as the
> +          tests have been cleaned up to improve the results.
> +Running the Tests
> +The ``rtems-test`` command line accepts a range of options. These are discussed
> +later in the manual. Any command line argument without a `--` prefix is a test
> +executable. You can pass more than one executable on the command line. If the
> +executable is a path to a directory the directories under that path are
> +searched for any file with a ``.exe`` extension. This is the default extension
> +for RTEMS executables built within RTEMS.
> +To run the erc32 tests enter the following command from the top of the erc32 BSP
> +build tree:
> +    $ ~/development/rtems/test/rtems-tools.git/tester/rtems-test \
> +             --log=log_erc32_run \
> +             --rtems-bsp=erc32-run \
> +             --rtems-tools=$HOME/development/rtems/4.12 \
> +    RTEMS Testing - Tester, 4.12.not_released
> +    [ 1/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: base_sp.exe
> +    [ 2/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: capture.exe
> +    [ 3/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: cdtest.exe
> +    [ 4/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: fileio.exe
> +    [ 5/13] p:2  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: hello.exe
> +    [ 6/13] p:2  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: cxx_iostream.exe
> +    [ 8/13] p:2  f:0  u:0  e:0  I:0  B:0  t:2  i:0  | sparc/erc32: minimum.exe
> +    [ 7/13] p:2  f:0  u:0  e:0  I:0  B:0  t:2  i:0  | sparc/erc32: loopback.exe
> +    [ 9/13] p:3  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: nsecs.exe
> +    [10/13] p:3  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: paranoia.exe
> +    [11/13] p:4  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: pppd.exe
> +    [12/13] p:6  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: ticker.exe
> +    [13/13] p:6  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: unlimited.exe
> +    Passed:         7
> +    Failed:         0
> +    User Input:     0
> +    Expected Fail:  0
> +    Indeterminate:  0
> +    Benchmark:      0
> +    Timeout:        5
> +    Invalid:        1
> +    Total:         13
> +    Average test time: 0:00:27.963000
> +    Testing time     : 0:06:03.519012
> +* The RTEMS Tester's test command. In this example we are using an absolute
> +  path.
> +* The ``--log`` option sends the output to a log file. By default only failed
> +  tests log the complete output.
> +* Select the erc32 BSP and use GDB.
> +* Path to the RTEMS tools so GDB can be found.
> +* Path to the erc32 BSP built with all tests to run. If you add subdirectories
> +  to the path specific tests can be run.
> +* The output has been shortened so it fits nicely here.
> +* The test results shows passes, fails, timeouts, and invalid results. In
> +  this run 13 tests passed and 5 tests timed out and 1 is invalid. The
> +  timeouts are probably due to the tests not having enough execute time to
> +  complete. The default timeout is 180 seconds and some of the interrupt tests
> +  need longer. The amount of time depends on the performance of your host CPU
> +  running the simulations.
> +* The output shows the average time per test and the total time taken to run
> +  all the tests.
> +* If the path to the testsuites was put to
> +  ``sparc-rtems4.12/c/erc32/testsuites`` instead of
> +  ``sparc-rtems4.12/c/erc32/testsuites/samples`` then all the executables
> +  would have been tested and not just those in samples.
> +This BSP requires the ``--rtems-tools`` option because the SPARC GDB is the
> +``sparc-rtems4.11-gdb`` command that is part of the RTEMS tools. Not every BSP
> +will require this option so you will need to check the specifics of the BSP
> +configuration to determine if it is needed.
> +The output you see is each test starting to run. The ``rtems-test`` command by
> +default runs multiple tests in parallel so you will see a number start quickly
> +and then new tests start as others finish. The output shown here is from an
> +8 core processor so the first 8 are started in parallel and the status shows
> +the order in which they actually started, which is not 1 to 8.
> +The test start line shows the current status of the tests. The status reported
> +is when the test starts and not the result of that test. A fail, timeout or
> +invalid count changing means a test running before this test started failed,
> +not the starting test. The status here has 7 tests passed, no failures, 5
> +timeouts and 1 invalid test.
> +* [ 5/13] indicates the test number, in this case test 5 of 13 tests.
> +* p is the passed test count (2 in this case)
> +* f is the failed test count (0 in this case)
> +* u is the count for test marked as "user-input" as they expect input from user
> +* e is the expected-fail count (tests that are expected to fail)
> +* I is the count for tests the results of which are indeterminate
> +* B is the count for benchmarked tests
> +* t is the timeout test count
> +* i is the invalid test count.
> +* sparc/erc32 is the architecture and BSP names.
> +* hello.exe is the executable name.
> +The test log records all the tests and results. The reporting mode by default
> +only provides the output history if a test fails, times out, or is invalid. The
> +time taken by each test is also recorded.
> +The tests must complete in a specified time or the test is marked as timed
> +out. The default timeout is 3 minutes and can be globally changed using the
> +``--timeout`` command line option. The time required to complete a test can
> +vary. When simulators are run in parallel the time taken depends on the
> +specifics of the host machine being used. A test per core is the most stable
> +method even though more tests can be run than available cores. If your machine
> +needs longer or you are using a VM you may need to lengthen the timeout.
> +Test Status
> +Tests can be marked with one of the following:
> +* Pass
> +* Fail
> +* Timeout
> +* Invalid
> +The RTEMS console or stdout output from the test is needed to determine the
> +result of the test.
> +Pass
> +A test passes if the start and end markers are seen in the test output. The
> +start marker is ``***`` and the end mark is ``*** END OF TEST``. All tests in
> +the RTEMS test suite have these markers.
> +Fail
> +A test fails if the start marker is seen and there is no end marker.
> +Timeout
> +If the test does not complete within the timeout setting the test is marked as
> +having timed out.
> +Invalid
> +If no start marker is seen the test is marked as invalid. If you are testing on
> +real target hardware things can sometimes go wrong and the target may not
> +initialize or respond to the debugger in an expected way.
> +Reporting
> +The report written to the log has the following modes:
> +* All (``all``)
> +* Failures (``failures``)
> +* None (``none``)
> +The mode is controlled using the command line option ``--report-mode`` using
> +the values listed above.
> +All
> +The output of all tests is written to the log.
> +Failures
> +The output of the all tests that do not pass is written to the log.
> +None
> +No output is written to the log.
> +The output is tagged so you can determine where it comes from. The following is
> +the complete output for the In Memory File System test ``imfs_fslink.exe``
> +running on a Coldfire MCF5235 using GDB and a BDM pod:
> +    [ 11/472] p:9   f:0   t:0   i:1   | m68k/mcf5235: imfs_fslink.exe
> +    > gdb: ..../bin/m68k-rtems4.11-gdb -i=mi --nx --quiet ..../imfs_fslink.exe
> +    > Reading symbols from ..../fstests/imfs_fslink/imfs_fslink.exe...
> +    > done.
> +    > target remote | m68k-bdm-gdbserver pipe 003-005
> +    > Remote debugging using | m68k-bdm-gdbserver pipe 003-005
> +    > m68k-bdm: debug module version 0
> +    > m68k-bdm: detected MCF5235
> +    > m68k-bdm: architecture CF5235 connected to 003-005
> +    > m68k-bdm: Coldfire debug module version is 0 (5206(e)/5235/5272/5282)
> +    > Process 003-005 created; pid = 0
> +    > 0x00006200 in ?? ()
> +    > thb *0xffe254c0
> +    > Hardware assisted breakpoint 1 at 0xffe254c0
> +    > continue
> +    > Continuing.
> +    ] External Reset
> +    ] ColdFire MCF5235 on the BCC
> +    ] Firmware v3b.1a.1a (Built on Jul 21 2004 17:31:28)
> +    ] Copyright 1995-2004 Freescale Semiconductor, Inc.  All Rights Reserved.
> +    ] Enter 'help' for help.
> +    > Temporary breakpoint
> +    > 1, 0xffe254c0 in ?? ()
> +    > load
> +    > Loading section .text, size 0x147e0 lma 0x40000
> +    > Loading section .data, size 0x5d0 lma 0x547e0
> +    > Start address 0x40414, load size 85424
> +    > Transfer rate: 10 KB/sec, 1898 bytes/write.
> +    > b bsp_reset
> +    > Breakpoint 2 at 0x41274: file ..../shared/bspreset_loop.c, line 14.
> +    > continue
> +    > Continuing.
> +    ] dBUG>
> +    ] *** FILE SYSTEM TEST ( IMFS ) ***
> +    ] Initializing filesystem IMFS
> +    ] *** LINK TEST ***
> +    ] link creates hardlinks
> +    ] test if the stat is the same
> +    ] chmod and chown
> +    ] unlink then stat the file
> +    ] *** END OF LINK TEST ***
> +    ] Shutting down filesystem IMFS
> +    ] *** END OF FILE SYSTEM TEST ( IMFS ) ***
> +    > Breakpoint
> +    > 2, bsp_reset () at ..../m68k/mcf5235/../../shared/bspreset_loop.c:14
> +    > 14    {
> +    Result: passed     Time: 0:00:10.045447
> +* GDB command line (Note: paths with \'....' have been shortened)
> +* Lines starting with ``>`` are from GDB's console.
> +* Line starting with ``]`` are from the target's console.
> +* The result with the test time.
> +Running Tests in Parallel
> +The RTEMS Tester supports parallel execution of tests by default. This only
> +makes sense if the test back-end can run in parallel without resulting in
> +resource contention. Simulators are an example of back-ends that can run in
> +parallel. A hardware debug tool like a BDM or JTAG pod can manage only a
> +single test at once so the tests need to be run one at a time.
> +The test framework manages the test jobs and orders the output in the report
> +log in test order. Output is held for completed tests until the next test to be
> +reported has finished.
> +Command Line Help
> +The ``rtems-test`` command line accepts a range of options. You can review the
> +available option by the ``--help`` option:
> +    RTEMS Tools Project (c) 2012-2014 Chris Johns
> +    Options and arguments:
> +    --always-clean               : Always clean the build tree, even with an error
> +    --debug-trace                : Debug trace based on specific flags
> +    --dry-run                    : Do everything but actually run the build
> +    --force                      : Force the build to proceed
> +    --jobs=[0..n,none,half,full] : Run with specified number of jobs, default: num CPUs.
> +    --keep-going                 : Do not stop on an error.
> +    --list-bsps                  : List the supported BSPs
> +    --log file                   : Log file where all build output is written to
> +    --macros file[,file]         : Macro format files to load after the defaults
> +    --no-clean                   : Do not clean up the build tree
> +    --quiet                      : Quiet output (not used)
> +    --report-mode                : Reporting modes, failures (default),all,none
> +    --rtems-bsp                  : The RTEMS BSP to run the test on
> +    --rtems-tools                : The path to the RTEMS tools
> +    --target                     : Set the target triplet
> +    --timeout                    : Set the test timeout in seconds (default 180 seconds)
> +    --trace                      : Trace the execution
> +    --warn-all                   : Generate warnings
> +Development
> +The RTEMS Tester framework and command line tool is under active
> +development. These are changing, being fixed, broken and generally improved. If
> +you want to help please see the Wiki page for open items.
> +History
> +The RTEMS Tester is based on a refactored base of Python code used in the RTEMS
> +Source Builder. This code provided a working tested base that has been extended
> +and expanded to meet the requirements for the RTEMS Tester. The tester uses the
> +specifics found in the various scripts and configurations in the
> +rtems-testing.git repo that has been accumulated over many years. The shell
> +script implementation is restricted in what it can do and, per BSP script, is a
> +maintenance burden. For example the command lines and options vary between each
> +script.
> 2.1.4
