Building RISC-V BSP
Denis Obrezkov
denisobrezkov at gmail.com
Tue May 30 16:09:49 UTC 2017
2017-05-30 18:31 GMT+03:00 Gedare Bloom <gedare at rtems.org>:
> On Tue, May 30, 2017 at 7:49 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
> > Hello,
> > I am trying to build RTEMS for RISC-V BSP. I applied Hesham's patch for
> RSB
> > and built RSB. But when I am trying to build rtems-generic target I get
> the
> > mistake.
> > This is my sequence of steps:
> > git clone git://git.rtems.org/rtems-source-builder.git
> > #patch applied here
> > mkdir -p ./development/rtems/kernel
> > cd ./development/rtems/kernel
> > export RTEMS_DEV=~Projects/riscv/rtems/development
> > git clone https://github.com/heshamelmatary/rtems-riscv.git
> > cd ..
> > mkdir rsb
> > mv ../../rtems-source-builder/ ./rsb/
> > cd rsb/rtems-source-builder/rtems/
> > ../source-builder/sb-set-builder --prefix=$RTEMS_DEV/rtems/4.12
> > 4.12/rtems-riscv32
> is $RTEMS_DEV/rtems/4.12/bin in your $PATH?
> You are right, somehow it wasn't there.
Now I have another issue during make:
checking for RTEMS_CPU_MODEL...
checking for RTEMS_BSP_FAMILY... riscv_generic
checking for CPU_CFLAGS... (cached) -m32 -march=I
checking for CFLAGS_OPTIMIZE_V... (cached) -O0 -g
checking for style of include used by make... GNU
checking for riscv32-rtems4.12-gcc... riscv32-rtems4.12-gcc
checking for riscv32-rtems4.12-gcc... (cached) riscv32-rtems4.12-gcc
checking whether the C compiler works... no
configure: error: in
`/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/riscv32/riscv32-rtems4.12/c/riscv_generic':
configure: error: C compiler cannot create executables
Now I can see the error - there is no such an option "-m32" in 32-bit gcc.
But what does "(cached)" mean?
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170530/fe424ede/attachment.html>
