[PATCH] Added documentation for rtems-tester in rtems-docs
Tanu Hari Dixit tokencolour at gmail.com
Tue May 30 17:10:51 UTC 2017
Hello Gedare,
I just added the image following what was already in rtems-tools.git
repo. Maybe it is not really needed there. Maybe it was added to the
previous doc because it was a stand-alone doc. I will pull that out.
What do you think? What does Chris think?
Regards,
Tanu.
On Tue, May 30, 2017 at 8:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hello Tanu,
> I'd prefer to add the jpg as a separate commit, so please pull that
> out (you can do this using `git rebase -i HEAD~1` or git commit
> --amend) Do we actually need it at all, or is there a logo already
> available for use in the docs?
> Resend the patches after you separate the jpg from the rest.
> On Tue, May 30, 2017 at 6:37 AM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
>> Hello Chris, all,
>> I have changed the tester example to erc32 from sis in the doc and
>> there are a few changes in the explanation of supported states for the
>> tests. Also the doc is in ReST now. I have included the new format for
>> the configuration file. Please tell if you find some corrections to be
>> done so that I can change the content wherever I am wrong. I plan on
>> changing this documentation as new things get integrated into
>> rtems-tester.
>> (That giant binary is for the image for the RTEMS logo. We can view
>> the changes in the rst file if we click on "View entire message")
>> Thank you,
>> Tanu Hari Dixit.
>> On Tue, May 30, 2017 at 3:55 PM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
>>> This documentation is in ReST and has been ported
>>> from rtems-tools.git. There are a few changes and
>>> it contains the format for the ini configuration
>>> files.
>>>  images/user/rtemswhitebg.jpg | Bin 0 -> 117890 bytes
>>>  user/tools/rtems-tester.rst  | 639 +++++++++++++++++++++++++++++++++++++++++++
>>>  2 files changed, 639 insertions(+)
>>>  create mode 100644 images/user/rtemswhitebg.jpg
>>>  create mode 100644 user/tools/rtems-tester.rst
>>> diff --git a/images/user/rtemswhitebg.jpg b/images/user/rtemswhitebg.jpg
>>> new file mode 100644
>>> index 0000000000000000000000000000000000000000..f883f2c495d4d91ef94d35e28995b9d2b7a863f7
>>> GIT binary patch
>>> literal 117890
>>> zcmeFZ2V4}%wm;tF43dMupyX^KNf;4HA|go?gi#OykqnY&3<L=>5)?%QB?yQx3J6FV
>>> za!_C-tHdE^7~%jEevP|#ckk}Ld+&Sy_ul8e&wtxb569}N?mDMVo%){Br<(kgJO&&%
>>> zt7oVOP*6|+2H-z{JkET{P)7%L!OTR@@SHAq0RWf{&bhdIP#ypPH+NreGyT&dmo8h2
>>> z&~*Zo00Te^90h=D4nCg7=6V(Yco^#Hi1>h&_UWGw at E%+J0Qd_4J at N(@L_~fr|5yL8
>>> zJ9v8g0szGYu)*=`jy?_`9R||3{Cz$5%U3~~%ieXLrlj7dy}=HGG~Yh$^b;-jqs~wC
>>> zseSsooBMUJ&VHXgue)8}ryD`~!EHZBkfu5Z(h;{^9Q{GM7o^2*`MJ4(G#;e6+#Ij@
>>> z001 at fez~usgEL4U0cmD$3o{*%)&Kx{W~blK_P?Qh9Rt9A0)UQ(XP~!>le4dgl!LU$
>>> zQ8hJH5d%m6TaLcI@)xc-xL)(VE~4Y%=6TIM5CDGSdA}9Fu`gQ at P{_(h)s&Uxk12rS
>>> z|K<3H7k{bskBR-U{i(*f>5nm^;A#K0?ANxxmU(0Vfa)eFn at 7Kv**^n-vTy+4`~GX0
>>> z*h>Il3j=^s%y0PN+1D3mUtiCYii-aJ{t7OR4hs7M{pI+l6 at IDt9}~ZMp2Gg~evzHX
>>> z8OIyf{BHS*><iVw<Cce?w}_ADH3vr#`QIz?f4Sjry7ilW$eB6baP)R`2Oo72)G`-$
>>> zCvdpkue<oVc({wWxc^5Z{9kPLn?CH5Kj}3{aAuJJE|>yv0K)}PEwuyGoJ;`Kl{D}Q
>>> z#V_M_j^QG(Kl7|0Ge7A)NQ2jZ{Qlh!B at +BErH_k~$bPYonT3dhpZD#38k`gRKQsU%
>>> zzy@#u{D3eZ3P=I+z%f7tPzO!{y1-e$1h4=u19pG|;0(9{-he+40^9{6fEeHr at EAw|
>>> z(t#`>4=4nRfHI&8r~{gT&%hU;4;Tc-fGJ=BSOvC#J<yQRQLs>OQt(qiD8wmbDUMO7
>>> zQfN`=Qk<hOqqt0QmBNX_ox+bIgyKF$3`GJ(3dJjmJc{=eA1Uf6+9<jxzENN)<|x)E
>>> zb}6YSnJKv_g(xK`6)9CIwJD7#Ehud%ohZF1gDAr&<0zj}W>CJRETycY{7l(LIYzla
>>> zxk&|3F;VeQ9ioz_Ql-+NGNH1jx<Tbl1*eLpdP0>!RY+Aq)k4)nHAb~awL?uy%}Fgn
>>> zEl;gZZ9r{F?Lh5C4X2K!PNB}FE~Rdy?xDs~uTqm}SZD-kWNA*)7}8v#aia03iJ*Bx
>>> z^P1)ZO%qKY%@oZREiEk%tt71qtpV+2+MBe&w6U}=Xi>Dav|Y3lw3~Evbo_L(beeP~
>>> zbl2#7=_2T!(Y>WZ({<BL(c$Tt=pppS==JEW>D}q?(LbSoLtjJRO+Q1w$8dl_oZ%#c
>>> z3Bz at UKn5g37DELChGB|fkCB~Gl2Mb<g7GHfUB;)3g^W#%LyYT8OiYKF)R;_}T$t`K
>>> zJ!N{w)XIcq+F|BkmSNUmzQXLs9LJo)T+958d7XuYMS|rNi#3ZcOB_ocO9RUY3!ase
>>> zRe{xz^*Sqp^*L)PYd7mM8v~m-n>L#rTM*k5wqiC6+u{L+0}=;x4qQ6`Kk)p(#{&Zg
>>> zHrYAZkFuMvyRpZzzhQ4<pXH$Akl at hexXuyAk;&1(F~Ld2DaxtC>A-oPGmEo{bBc?W
>>> zOOnfw>n2wWR{>Wi*D5y$_X+Nc+yUIrxvROyc&K<Jcno=N at gRAMc=~yEd4+hjc^!G9
>>> zcnf*EdAIov@}1&y<csD*@%8cT@{926^1JfK^Ox}t3s4Kl2$%}^3#17&2`nDuI;eio
>>> z;b8Q^qJ!TBDFtN&%>;u5GX>iPH-&_S^o2Zyo(VMwEei7ppAx<)oFrT$JO|-~XhB>c
>>> zNf0z-UW8jjTjZ9=Q;|lI)kA`Z3=a7ndUdGt(B5Im!<L8d9Y!4<7G)Gw6}=&vBw8=J
>>> zDh3fV77G!}7yB;GAg(IzES at ahBEBslDPbiMDN!adE6FEmC>bP~FF7Q|A_bN5lFE?k
>>> zm8O+em3EbWA^k;$QbtL}S?0M6MwU`mS=L4Ng>07`jhvdCyIh9cfIPFjw)}1Re0i(_
>>> zkHR^HdkSR=%Zg%(){60pEsCTgN=I%T$vQH4l;h~xqxX(h99=smbIjq`^JBfoS&r)+
>>> zM;tFdjyoZH!tq4fiLXkWO2$f&O7%)aWff&_<wE5-6)}~oDyb?1s$8lURAW_J)o9dC
>>> zt0B~?)OJoPpY%OhbaF*qUfoswjry#Hq=utLmd1qUVa;oruQbQBM6|AIz0?|m9)ezj
>>> zW<bYJiJrQC>h-A^ZE5YB+HbX&Paiq$efq=cZJm=kp*po^sLtr0i9XY*%b{zjo1#0S
>>> zcUaF!FJEs}Ur9e$zt(`pz{nupV8Bqw(7`azaP_Rp+0e6%M$AU$Mkz+)=VZ=#pQ|vY
>>> zG(KybXgqXY{Ji`5G84eW&?M1h_=4mGuM3r?w5AtKpPNpb9W at IvYcc0Ehnc@I-?BJu
>>> zfwUO3l(O`*tiQ;1 at yf-#i`!ObtP-roE-79Lz4ZCAz-5=q<<@l87p-4gZ`$bEJhqv-
>>> zqI4zVO24h7ZGdf?oq*jfyJ{F4>>8~2D$P}^t8cCnu9;lRxVC9;XrF4o>Y(G0?67eC
>>> z)b*t6bB>yh363*2G;bu_n03;0N_3iYhB`lSUUboMNpZp5G`N|5bKBL#HOG~F%jy=&
>>> zjo$65+edc}cUSjD4`Gi0k1kJH&j`;kuajPny;i-AykGlJ_}KcC`*ML`s at +e@FWe7%
>>> zTkH1o+j#$r{>1_80qz0qfii(nfippRLD|97!4ARoA%{ZlhG0XrLtnuu;P&u(geW2m
>>> zF?C1(PVQaCyRLUT?j5<8aBt(j)%}Vvp|Cq)6XE*d`4OxU-Vp<l>XGRWs2{jI=!`lZ
>>> z^(=}MeLeb9%#oNUF@#u$*iR3SK79I+9CstG6RC_$dqn%l{ZW5BG(I<hJs~JzBGEXp
>>> zG)W{WI%(rE>~Y(Z6Hn5U8I%2z$DW>hTK-Jz*`sHK6z7z_=ck{eQUz0^Qnz1Rf6<+G
>>> zDy=YGC_N^9_od6rudno9m1am}JjtZZyq!6nbup_YTQxiHwZQ9`*Tfw6oUvT9+{QeW
>>> zyu3GpZ;<(v`F{CxZ?C-lQgEiAyimUI6^aKH^A33D_iq0E)%X2HMn(0-s>OvR;w7mc
>>> zI6p*}Qj`Xku9i8Mjg?<6 at A`Q5V||5s#fM6T%ABf0RnM!rtC2N~HDNVmbP#&8*0Xl8
>>> z&Z%yq9#%itaH*lU(X_F%$*8HdS+BXFMY{#vs at YoAcCzi`C)H17pOrtCwkx%N=uqnT
>>> z(5c*6ic!Ioe^L8V(WTK<(+%ye>p9cY+-unTx$k^mSHETd*MTboV_&a-o&9#}8}9q<
>>> z?|XxHhG>SOhYt)t84(=G7?mDHjVX^+W6xmQ$IZtFCmbdgCVeIeQ(@CA(@$m~GkLSe
>>> zW~=7(=Dy6^%ug+NF6=EvEU_=8E=w(!tejeDU%j+Ch4aRd*J9WC*K;;bY}9XF*c{n%
>>> z+uGZX#`EKIcT{&;cCB`2_WTKSgr`JlVg<>FG(>hIlgU`1S2w`r1^^fv12P~Qpa<wE
>>> zH~=b;qS!|h6apYV_z73oQylz-zDXhVa~(?X;!)7&002So^rkrWgXRM1xJZ{D0AnAM
>>> zWPs=X0s1mOFv^d=+Sfho9YroUd-!_zID2 at C=$IcDv2t<0?&0qP96NIK$jPHePaZoa
>>> za_s0yr4uKQsDM!RCB?5jdrA4XyVFj+r1~38X|(?s@*toCQ0^ZTKYl4Gsi<hFslbDd
>>> zhK8D!o{pY=|72ifVParlW~8TQVq;=vVFeEcrUUG3tnB;r{!R9qgRN+(scBgm=o$8F
>>> z{O1mGEx=AsX+%3kMR6FQWT&8Fryw^15Ksy<ASeQl{qF7`6qHodG_-VJpP0Z39}WPN
>>> z6jW4{)Kp-9L6k-j3SI}O*=aZq9o44gG`&W5*o*7f-S}7ZqNm^2ahr9miXFH2zQ at 4G
>>> z!^_7nATA*(B`tG8Nm)fz?WE2bT|IpR!?WfVmKUu+_~>xm at rIML%S|6&zuW!+fkF4f
>>> z!XqLdL`5egCOv+V{PbB$MrKy_>zv%YH$}xIA4<#0KUUN?G&VK2w6=Zf?&<C8ANcz1
>>> zJ9d0xa%y^Jc5WWGw!X2swT<7|-RBD&pP$(Jg|pxB#SZdCNli^fO}Eb%1*QK!<LuNl
>>> zhmO*6Xq(bq^Wr>w>@Gdm>G)Ug>lj3jo2_!&dv`JNh at HTS<Mvtm!P&pY*uDP}XTLD^
>>> zD_`FMW-1DB at Tk}UC_p4+L`wnxV`pqPC#C?9=c*qQu1`c%Qx%J4WHK9T2&<i-2?rl~
>>> zz*LtD`0M<?A%kXBCELlmy)4|tcPxCuNyidxO;gq%4dufv`6|?!53Uv1=FdufMGtc;
>>> z--v!|_7!7u4-t;UnrDR}D|D at EH@L2v-Z+=T`{ibtkaX>&S(n9)`e><_lz*N7{xV20
>>> zq)ke-P{319N1P~ZaycDmY#BWKY)r}gW4Wc7&-afuL{o>T2ku7~E?K<E2nsky^=8Q-
>>> zFY)rF-CV+aIgUEC7w$KyLJ~I^E}G!mEOa4&ZkCu(sB6UKdoe at 1RVsA7c?Z{uXTt~B
>>> zpNB(U*chKN>_S-YkUlqgRYg<ZPY+r?vE+8WcKv8#cS+7eGu8J)$4 at e0HBH^Af-SIj
>>> z3+?-HFo at RtNK~C^^itSzVMuj|`s+oTj1-2BlO<}W|I)92d;OwSk%K=z?bN)O2IRM&
>>> zuMh6m9K`aamFFeBjf>S#6n);Oc*ZOJx$uVxVetXN<42KWf_{a2jlAL_i09mED{&ug
>>> zL`$Osf;Uhv+TXL%6Yt+!Q;N#x>cZfW&EpJ^?Q%k})l*{}H_u#>$!M=tEPkPhqe-sv
>>> zx?~zU3Pn+gOI^r?j41mDTg_Y=!Zin{e<R3a-A>|z*V11F at gkqNzGVKUHj%PD%8XAv
>>> z&pFekwYlSlHQ_zC-Suc at 9aW@3fjU7tKP|HBG-vnP{P`!hn<0u1w1my;wM&pSCyezw
>>> z42p(bzbxHgzMr-^2IsDJ5kbm- at kcrL2$mQaVhZ5l_uot+C(;go?h|-;Y5vP{UFS{f
>>> z0`{GNe9inG{U*c9;asNLhjh6vQ2cfN+sc4i0dd=vV}s-2M!~?9ytmIwT1CGXJsSwS
>>> z9Y1L&ZswLg2NMa=O_2(jok~%ilzmii_<n3!<8)2mz}xmmN19!6u&uFD<<So{G5pj{
>>> z^{dLzrTG<tEVev{WA&@Q*}!aQ^YO;?O%=(&ROetPeqHZ%@0A%BxE=(Fd8YA7;&kw}
>>> z$h>V->dK*{dHLj)j-h_Kaj(>g6TY3QZEY>wc#<T?n@?NsH`E|Y;!Tddp((ARihEC8
>>> z$$)3^w-8}|4~O==*tK(af`U@^9I(TE6`yaWyOoSAzTs-kO7H~uG!4hmN45p8rtYPo
>>> zU-*wQ-Z$DiAEFi`wv5wCs}4ezw6ydjHU+8KIWFF8mQktHIJYvl6g7TDSK~yHrOAuj
>>> z(Loj0N*LZ~0~$aOL~RAE`OJFtS5KT}nQBQtyM|<TnO42FW1u>dvL&R&@t~$}?=_{o
>>> zyy1A&nVT1HJL%HbrxcyEV5lX?cy(8Yzuy at e{#s(Hd+aaF at b8VAXg`=gI~F#PYB at w@
>>> z`tB3N`k6da*kY%OS&1V1M5@)e6M>6%baAxQBhn(4XVtF~F*!9$dc2pXp<dUD;l at Xj
>>> z0UE)WPsB2ULV0rt+bzV}?cEwqq;&QZm1!grXT>$ua6EE5b0;0>(&fg#BII(<!Du-<
>>> zh^QLwme@#K#M7*x`~C-%ra#Q1DF+Zss8ug at l{nu=@Q5{;`P%$(mt9o*Mp2;m#4L10
>>> ze_emWD$Awj+|h)mH<#TqzTXi*xw(}%c)(>ZJJeEf6Xnk)7?4KVj~2cyY_njMIqS^F
>>> zH9xB#$7QMu{B{1D%it+j$pz|j(ZN>OZ30*JY0|JT7vMmWGJ+8m(5Rs+RItd=RkIPO
>>> zJDPzEe2oMRV)no$?n($6E54h#KFTFd2I$RTBT+jOx?EP+$aMp&f)Hwc;ztrw-fT!<
>>> z<_sC2dW8~4S>tKQfMnmQ4XLFALI#Xp6;{#hbwF{79YWt6$iS^^k`&3A^!)MBC399i
>>> z6N$$`W&<1J(4xU|(CcmdONai=b?E1L&W#TSjgmYWNL*M=CqB51-nB)*$}Rt_l(%Jc
>>> zO&T$-Ka(bfXpMu7|Exbw>lZ-%p#twPhX?QDFcJ^y+n0fafj=p<qaseH<CCZ37K at 2%
>>> z$@t8j%w0dbq>`BKC+HkgV$xqq^M6BW_Q&b}tm5#$PQ=irOy2KNx;%At)Hh99`HKCw
>>> z>+fkFl3o{g)IsV;A0N3g^^s-AwB2QqKNlj}pUQgko>94HR$sV1BJ9hH_8|c|Q)5`=
>>> z`PZlZ3h({zhWD(nD+I1Gk_oCFv32M>8JP1U!m)o+7y^SJTC>SO6eKO+6&X0JhKQD&
>>> zdB|l73s3LRw)?QkMl#76D<dL<^hwD&c1FK1u?=9`PC<;rQq+qu+n-?L$Z6zUUyxb1
>>> z;#q6b3;nGN|N5{W_YzDz#g<9=(xorB&rpdbc4HXdTN<C`a^6N%-+6=UIqzP^JJ=PA
>>> z5H}&sn~Hb?(b0#Q>v>y`mfhbejea|6oY@`AcDCNw<qENGr*9VZL^~~Y<8==2dyWRn
>>> zxY;jrx~Gd}86R;NU%qe5n(<f2`9B$M*B5=vKdYXKJH=so1rZbCg at sWDoDKDF))MR1
>>> zIG)wAUFflFrqnva$R;;Z%Q-7MHu?auYNi+|3 at I-!S!E0VKn8@`BPXlNMbDRL7OBXd
>>> z)fbw8E!f?-mOAzh){>jC=eHL>F`cTNJoTCQ`c2GIF#6+7c)U5^iwXXgAc7)}m%!yP
>>> zF;XCh{(9SvVYRv#@n%meX`AECUP;lh_uJp;%1|k`@FD02mR3I~=Tx*ZiI1R}qmO*W
>>> zvqN;9n#V^zZu%w-J%hf8j75zX8q+y9dv6$RCO}^m>|_sxF6?xYfrw8;a1zYEnNP<n
>>> z6qA986Nm;!cn at U5($9pzdzlR2QW{8ywP0jGYX*;a)<Fi?ePqZ$y7^uv8EAua#Z9c}
>>> zO{~B={RzreOGn9ou9XEDsPjuF1N at n!gR)ys$v{T_8^l-zh781Zfvq8m`>hGkcIdeL
>>> z6l{GS;fvT2-90)KI{RyfUPJ#;f1u-{Q)B>a8MzZl(5=cRg_<lQ$$%I_PaRo(5Lt~-
>>> z8(sYdD`_Ee+nR&0r5{1KfyCcJeRm*57v_<Hdkav~aecy>5H#3ul?)sq0}sj`BQSYH
>>> zuzQop*%q(uOs{R!jQXE-pXKr1IYgIbA9U5$i3~J5gKd$?WB`*#f=okjJZq?(O=ty_
>>> z5KrV=*4l8_+9b^UL7Y%*5!wa0D^rm}VtPvk at Es5w`x+Sl8#WL?QIA-HqR!dYCj$x4
>>> zOre&Mhb<%M)RjN>|4+pI(=g at W5l<0~HlNTly`)((u%^G^P`=mgu3kx0N63(T$iN?-
>>> z|3g|(oS&baK9Op1ze`MwA?O0N-}A&T-8xfn5}hUs9lXEws`SzXEUMc`AiYvDa$}Au
>>> z)UXV*VD}1(#!C&f*dF$^MHsDmL@#N#N7&GoJw-Z2_3`3#Y`H>Cf0|zG&74o3{ni(W
>>> zvy#Z|PDl+kBZ^^$zRRv>Vn+#FK3K#9l>K|$^8JDU+UawOgQ6ZwOiG&DC!EFXg6x%r
>>> zv#f?k1aQcR5J#+m9~of4$LQlEVibp}dfXENq83UXOEMoj#!BB2sz;?-=U}xgBOU0s
>>> zSEhxL#S{^mU`&=qpHV}b1lHHl_U}bza-lDvqW#re%RyLOF7qGn0Z|R3cxewpIxLI~
>>> zEb4$0xO-ujSpR3G_!=!T5N|{VIG`Fh9nu+ZGQeem5s=D2GeJ}CRlANs2<awu9(%$Y
>>> zNTNbS)st#EtX5?X-fHV5-fjGa?PSc^E`oW^=x~LeZP<ljUC}YtoSSK~`848!y2`_k
>>> z2d3lNYfR&0lCl<)lBW at -nb7c~Un4|#=4wr0@#*Y{vFz_LRsAr=Do&a#$p;@`obR37
>>> zGY^j(1}3O^9&OGwg&@WegLGR+obJ%WK%Bl!k3%Pqys%UWj&Fm7F<-dah;s#2;t;Sc
>>> z|8nSBAX+?UWD%irLrZcJ at 8aDvol6EPO7@1)RJ+GG{MuxK-3848!>)5C&hv5;8iqnV
>>> z at jZdO$$mKhalcPa>W(<$3AWZY3pCav1hg0#={V+44SiqeR(9YqoJ8bVwiONianixp
>>> z0x&!W84%r#Sl2>77Iqp~Lru+)c($9;cV!^#(ABI;(EKDJ>PPUP9n#eqmn3l|BM9C(
>>> zq{F(9omCR3mz3aiLxb^=m*CvHtGEWu^*Fw;V>%rQ>a`u>=ZC+-agqT>BQ!}(pCG>y
>>> z1KqIDI*h;?`jdecDX at 9GJ}Cr>CIN^>SOXdOa-0m*ChtIcRi14Ua`(H1P=v0Q)yR>7
>>> zt_%1mG7v64N(KZo|Jch$1JM3yLBOj3bX*Y&T2Ov6FlIzR&L3>wC0PWf!#<&t)A2T=
>>> zJc!xckTYbUK4FCn#F>%-rr>c5k(=#7I^N6{G_Rka<6>ZGIvaTT4g|*wTBHqTGO#L6
>>> z(%)p+XH5fxnu2}C{0TGR)i at _obY!CmL0SQn&J+a40kVjR+y<Fq!^hweyR?Y^io}ul
>>> zC@#cI!yd>G9YL1>B~n2N42XE5&OTR2P~=u?>wm(>pA5j6Xy`hY2y#P3I!uC)?xvHd
>>> z(XFIcRUk|Hpv3cc0znb~o{K+||1T;)0WKj3HZpJuLk1{elZXo=pdMv{BDW+|fkOVB
>>> z?jZkc0N4*B33vp80Q^y#;>f^b9Z|wZd8EA;QFaFo<*kuR-+A+^c1DhmHaTq9ND#C=
>>> zwySh~5nI`y(4GG#bQ!H9*hDgLJNXBjDGJM_dVxYGC)4MyxW9T!f8TMvrDxY_J%S8y
>>> zYe}|()`Gq2_6)HAJ_#C{O{$Qy_-HbKXc;+y*#1y?p9~cDD{1KF$mgP~5%Kd_4fk3z
>>> z_!fr=X$0h2`($KvW_Z-GcLxopyjf4K<D=Vz6-|y4ud$?QE8(~IpoCL6X*~L^a at n|T
>>> zuz4A&{`oEcl(3>)59I at _{0}hJyVY>f`+=m&e9rCa1r$RguF-t!$yDWgVklP2hE=JR
>>> z$2IaLmRDM at V-&k#u-D(x#3U9?eP?E*vOxWk)di+arBzg<hHn`s#q at fb*3DhE2D`(Y
>>> zhdCvygTKmknB?^|4zX*9uW-%<+hqF+_E&j4?sUcY#^7Z1pLDu at C`*<)63`JUB$L`Q
>>> zp-Pa=kv)D+FxuKabv!{|=J*$Xwebozv4rReg3Sby5zkp~zEE=%ClQZ*Apx!SL3qa(
>>> z>Z at J|ys-tOYr|*>I^c31AELTSY--B66C#hoFJFg>FVzY7y;_R at Xl<stB0vVL*N-#L
>>> z(A*<w>hcbvhLDgG<IHFU*piY3%ypRf*?c4VY2ylCr}_Z6?4ZXoA;Oz3j--a7Rg>_g
>>> z=R~V-8#(2Vt%kGXA0unNXjX at GFKl6nx$Zi7_;fkbveg#s(n*a_dT`}~DOxpZ6e_eC
>>> z?uzf0gg7F&y`9zdjwffp-o_JIJUSG9!AOe#1S9qT3<tJBIMC^Vk9lTA*i9dXkPJw%
>>> z{*WLQND#>f{pTzA-{GAHI|#5HmUIo&GLOFi+y5e9OY|BZog3V-S_d)kAK at Yhw_mG~
>>> zftdU^YtUK94-9E1Iz at EB{0S0mJFl<l(nr8uCJjM8uoSfj5Y8uD>Lq^DfaVz3%p2Dr
>>> ztT)+M5p{Ys>T at de70b`YP~6||Khs#?ElvH`@YeHvSJ at v_e0PT;+*WvD2(;oVMJ0%P
>>> zoWJF5%0-LWA?BX5nZx|?4$W{r94cI7fFL?9B-)rFR~zV`;`gaT*prpv%F<Q(R#nk2
>>> zR=rn`$MPt_$1{?XVU<3MYgK!S?Ut(_EUGGq7+CFm?rXilq{K>;S9EBQ;m~IN9}*Md
>>> zexCmyp*;AB`Wouhq}`R+5W}nhCqv}QmC>Or*Z58@;mg%`B)?d6dWBudT1+;Rv4|Dz
>>> zP`O at F%~~H#82<6@<S^a~yB8B<0^n_6xS>|K(crxk3p#_M-X&RHBTA$XYySUyp2My9
>>> zo4=hG8ccsi2K->SF1TdVM3qk4k?yIjs+GMr;6gqcwfFLe-RSn{KxmY~%Gj24yoF2}
>>> zckCacBcN<9T@$mq-~hG#(ZN!h`rLTyqoy=w8Agc5er|f3ttoBsU-71T$v~t2XEHDY
>>> z5^U?df4M at x@jU;5E7VoKH?aQVKbo6==Xw4{yda(m{BO3zfj5Q#7R<|>yjHatI&Q)=
>>> zWKeV~8M<!y;o8Q#63CujsXW@<<a_it2VH!sxGsr5L^DTgC2vm)VVym$Y}21g0=?ii
>>> zZU|4≶d(oKDs*SVYZ1a7~O0@$D`Y6&C5PVjF*cK|9ee?8*AOt$?A!Bq`SgL}dD^
>>> zDJncov?ijZ#ag0lm9%!6>&hhT8&%v}Ty8uF$zETl7%d3;s&L}ddxcLqvZS at LiL&wF
>>> zXNU)vCFFDW?DWXMGaFoA=pvCb<D&-)zNJCy=xTe=Xt;(>Rshn#Q+e2Bz)&NwR^8Cd
>>> z(^H?0E at du0MjBHPs(JEJszt_f6|y*NLN!l!SSxcj<5hg>Im$=0nm0d7WK>Cx=PU`W
>>> zBF83KAP+TQPOR_Cjym`2EU9$Q<SZwOYm?R=!-DXT7Rai(`e-S}V|4;sCC!mOJc5s#
>>> zO81;eq*kpX1EsI4G#VbPEpkp3Si*|>h^;&A12NvI)oTN9KUT`ahEVwQg5Ks^%5+z}
>>> zV0TkymdL=K;e0~n9O=*(4b at oh{MUFmzcSk?Ne)Q+fKcGxEqKpB4eSL at Z%Ntr=xj=e
>>> z81eQg*_k&1QBQQ|7|;p(5rd at s@fuTJ=bq;~iv3p5j3X_H>u}MWIio-58SIC-|6vh+
>>> z8{tq&{wWx-zXTkI{P*kGUm=?R;SfzCq9gVZ{4rsM4E#QJ7J?}CUsB at we3)R-Yb4z|
>>> z{QB|{f_5Y=62Fhn_R>MWu?=*weiOseT>!ULq>?P=Nuj=@gP*rji$1O^g!nt;$KqH<
>>> zBi~v=*SHKu3xd<b5M!^kG~T7C68u56X|Uelr^xPF7B6}Z8Tn4Kf4|W3Npqo$t>v4o
>>> zm5YylA0p8S&fCPCP*R}a9Ml2^Ep8E$Givnk*Y<7_Sn$t-Szquz$Xbm+D^R+Oi0GEC
>>> z^TkCePjCvZ(vGzV$u7_&sqQ%HVNTQ0X{w>#)H}Sx=lYnYB&<0Nj`?Uv97`{0=ry-H
>>> zSFEdKD3X{~&34nz??v4o(zVVkTdp4O+53n}BZ<So6^putyJ~Ah3|IYd<URj)-xr6B
>>> zH@|o+S2WW<AOi!ZGe_Pv+UH^?Ixe1-t^6|83_kNLyt}H`>h at wNr!L$S-$P<_api6-
>>> zB~joV{Z6XzY*&yn-rtX%d}_}U-xIG`5VBqX#vwufz&Z3%rArb1c*BLnwSz(j+hw$h
>>> zt6rwVwH~kG)6_mWS4w{jQe1zJdy3)kKFMbI5uBZh>$mln_c#RhBX2KaP=hvGX;tMM
>>> z9k{cbf(k>rnP2tF+cY@<_3dd82mF4#*I^HKLdifRv;mCYX(W%2m?N<N`RJt4&k@)C
>>> zP#*fPFzNqZnDoB`8>kSzw$aU<zcMyCIkSeEISn0D-%5#gjEBqI6i=FT?~!{77iqX}
>>> ztNeT~5Z?2|3hs!Bd+X-~Cb+?c-dhmHqYiH7M?U!I6I71?BLtH%kujHbf_hSR^!Ee8
>>> zFDqnmIrY$0bBNGa3>W+)J`~##G<wL+SlH#(^wRn at LX*SN8Zv0_J{GZ*y{bO$H*_)t
>>> zF6u$&+KqMS2|1H@^SV79`{(k;84Zf^qb<X8c3X7OMeR0cxy?e;kT|X9auc_n3yBN(
>>> zB_z%%`jONL$b#Hl4r5$|6*Z)y)@#YEFi=t>EmF|xOZvr=f57kmN>Y{#|K%h?j-b=>
>>> z^c at a;M{ipAa*)*wYU$9PUqCRnW0MSoY4K$vV>KN4k6xLV8{8l&?a+xM1`Kl4ELG|F
>>> z#qP;AgE=LbK^~VCKSWqMqo2wFT~TX%Vxw}xl9Om;Y3a2=sBHN*FlIHS>^bAasJc*x
>>> zYFEv9=y=wI?S4?f)L<Lp8GckCAV%ic6JEuj0>QmNMWxYYbrV5?F0QOGoxcr*pJ)t1
>>> zMk(ppU$n_P7QYto5MUBm^Lzs=G#g4rw+*L}N;nMLrW4RI`4{~prj!RmFXO{+Zpw6Y
>>> zdb`!2Onut0feUNV43hksbX-XnZ)pF)4*o8cb+Bwo|Fvq1d#~yFiSmy#n((TDz}3BR
>>> zr#Lt-zEjhuwnn;_pp=_;@H+#OzN%o at 6Nyh}YuedL*_7%`6Ym{6r4>>5_;OD|(m`WC
>>> zy(HJ(Y$a90*QKsL+oD_E#E%3uobp-=h>19OO;$bPvKucBP()vvH at nI#t#+ifCCmN%
>>> zvT~Xi43YILmctN}+k}w3)++NA8}xWylWoj((_>4C_)c+INnR97*JONU=)__vNf0MA
>>> zwD%QF;U;-|a(OncMQw*+>gX<t*{e8T3X4NpWhC!_;BYUUCLjXGEgIGisoIF$uv$x=
>>> zC9Q9kXx%&&Fxkh~Kj9?va^?}+*>}|GO?P2A67c5nieo|2_f;3p^RJw{>$<v4VzdFX
>>> ziUzRIy#q^#jS3RlGyji;HHt{|q#5W0Au$>kz%@+}-Nd=x94&>a$4tL`Irhqo>;8af
>>> z0oMhpvQopLzy*x8yJ1E&B^c-bPbJdQd5mcqZlJkFuSgG8G(Aek3qWRN%kMWQ#?;n0
>>> zgszy{nP%#XC6`fZOxnCx-7PQ{`q0`7p8#W?3%0&E?nBhcKE(E2N=MaOCgBHO7{LZD
>>> z30<I?->Wh|QI at x!>Xb7DbH;OCcDX2WX`*Kh)rq30^Hg*YgThu(m2e?_DT4sfG%}zK
>>> z^Lo_(d}t5GQ&gp-q+kPa!Mo44F*~V_S6kObg?sxn1z^G-S3O;yl^s}&kz?q6fgbLF
>>> zXWw&co>}$a=!v~q@(^=0^4ypLINL_S+2)J)$2R>s+pa&0o-n;JoHK`PRg)!E=xSP?
>>> zr)V}5iN+xYWw#nqjD}%YNd3d}y7yFEVH^SXx{cqqWLgg%SxOUXDW{7j<PNXDsG?}0
>>> zyAPvj(r}eA3kW&b=b<oSM8HhjDdV`iQr~?H?sJ~`wq at sv9=ctlhL4%>h|)Tq2*b5J
>>> z*o1K0jBR{dX67h5i4y>LlqRtj6a%pdCftdYnnY)@#KaD9xYfnC^TwatN_UG_cl+io
>>> zpQla^hT3J!B-XDFOmT6XKNiF)E%mnj-aoNORAnBYk^~+2YM0`qrE+eoN1ylVSrvlU
>>> zd>9U(8;8Zg`2(7iP*edqW~-eU^a}m!5Cu=x(?<NC4AOo~xO&q*&p_db!WaAVO{~Y}
>>> zgo|GFS#$HS6xSPN`pdkFQ+s~+;Bn(kWSEvj%eApl0pn72*GY9>;_36W$A%gXExz>(
>>> zsN)An;d)II!>Q}Aws-clr}!YjRFBl*dgzN_Qk3H0;ecgdL>Pp}&kbi_HqZb+RG#cL
>>> z;+f~FF5Hr#romZ~%H1+Qq}W{eHZ!tW)2^Ec*-0<=bb63bpo;aO%f~yGeS&4~VFqNR
>>> zA6&{C^1*QJ5><(@QW?>}{wc#C^thFO at 8g`2?6LHuiCE&$z+~jovpxF`&1KYTBKG|2
>>> zar&(N0gmXleLLy7)!(k}H03WmCdjx}96KIiquuw0$a`^5SOSrbEsB*z+3qS7Z0Q%l
>>> zyCG#(ku`#&FuV>n`VzjO*));6Gou4-(gS<sZAJ8r_IYf6$1B0$Fj}a}2glny$`Rru
>>> zfu2CJ&ufYG at kd>D&-$d_Hhuz-b8V~7r9$zGr75cV6o(7?jdkyvS~O#4Kn(vg<Gst)
>>> znukkwwxKEIF)>HKRqHP~I{QX{Lp)!<_Cr-LlHoI`PtsB->Yd<dL)Erf)vTWx|C<2*
>>> z at OQ@jnAav)Np*rkPm@;KI{>4)Ih_#g?@*~pg`H_!5h5tys;sx~YMA8V5f`p_9B8XJ
>>> zc!%}25&Ngsns!!od$c3^#^@lT0mkETD+Dspx}+gAF-Muj5%~07ALRAn8`Elra|eY3
>>> zzMuDkg+uGL>*#Vd=g)Y*Wh|!5flAj2PYeYOe7T-#81wnYM<Hy#qDS(LP%Boi+v-xe
>>> z)k!GU_rW2R$9G at jpwSyp+5k2)oJzD`j1bf5cVVCXf^TEZl!P?fB=69Pjj<Y_TG+mG
>>> zZsBnrv71I1X2N06WYnc`%1 at P+d_`WUv0J>)f7j&J0sOp0LOyN<30EbY$3Gu~G2uO$
>>> z;j&fz8=;gUPdwi-ihDg0Pa5MFV>~_8Rx5ZlF<r7vEWr?C=Q=#js#*|(ENZZ0cePs~
>>> zQEUvEj_XMZR>!e!VBKKfJ^F4{tH{~f+1kx>+71t085%x2HI)*`)Vdh-#Gy^HHwBe=
>>> zhoV+E)yxz|J?J#ek?6j7QZUx3KPffMMJmhSpJmG27VS?uN(D^J8R}A%e>_xlgiTcB
>>> z_QtLi=tNK<T#?b~G#-nKS9 at ViH7uvu37T&@J9E>XtX(Y;^FGCYC2`H$I0U6VbxKtv
>>> z*y;uo<UzfqrBp}Lj?hQAV^rNmOK0O|qq5C6(Cn3aWB^h{gTvH9289pw-iFoZ6SFgi
>>> zuG(Ez6XMtNSIjKb-V(XH%xGvAD4N%Vkb_g>Fwt;9f=M^w+8FU-sHELH#8CUgwTkUH
>>> zZGvg(5sOLTAOX@{=nc$w70?-g)Nm1tzUpV=(dR9U{q^J+q8^N2BHG)tve`3&YjE*u
>>> z8BfDeyXLY=(@;!LJ1JtUQ$6Q7eBwZot73&+8eG4}!koQ~(kIPjb1P@|?vFK$n=7^s
>>> zf6J?<{|@)p!l1a56H4Py0kkt)<S1no6%jQdWSrIOM7O7|Tg<qfTrit!@~Nh<QEFR5
>>> z7<|`5%=Crafih?fO2)sz518vCPj!8LB<4j1<X_j(Tss}8!6PQM5KkZl%(Q69;v;d#
>>> zO>s`Key$H;wpF2PMv_c?GYkS7XZTea0e(;k$5nG;t|h~#AHLAv7G1A7G4Uqw>~1yF
>>> z+2Xy-g_)`Cblng)Vi8G!U|Un!v-H7GgKca}98q+_HR0`C;#!9)<Jx=b>nwS-I~1L8
>>> zefy>&f9cNUr%*fToU{_*O9_TzlLHf~?Ql_E^Y0g*C$5u9plR#OJ=}4*^Y$`oMwpGI
>>> zHAc+<!C2pn=&6r&x24s@(n^v{4gMkW(nnQ;DBz0&)mnBN%Ofs92NA$UD#ugnEuMGJ
>>> zF2n*a8|apky%*3>=W<u!{+rHrQSI*|W=v=F#iTx6Pfxm at xaYR&I)S-UqZ*<qFnZtb
>>> zushb0)YY{N*nE~05h}c&yWuBpk}GnTfVsZZ9MI`nyvmELvRNG*cYiTHN;_XBp!dPv
>>> zNAUeS#<|oIZ>mRKWqw!nulT?m8wd_jwT9+zhUT_{Q6_6pZLFPE(^P^*zKU70Q-z($
>>> z##d5y*K-$U?W;j?k44l_&k#<K?~v2 at omEFaqa!JZ=tWBX!a22r1w(OS=a)FWwU<65
>>> z=W=g^nMEKynYA@;pl{WW&)K`kl)M<n%o2DM;uOMMyOK|c7t42<Moh#>k4;(`ev#)g
>>> zJw@{`p6r#6uhRLzXh=iQ5(_kw)&boy4~BU*I%Jih`?my1N at L~EVj2@&gEZ!7Ry}%D
>>> znIF+%KjkKD(>B<u+{ReexF}(H%O7hWt#soyRF`^S{WuOeem)=Px)qI6iQ9x7J!n=b
>>> z at 8UiKy-{X%kuUOfFBQ_PB~OfCb<oL!Ds1ZloUpNBdwFN&L8_r#8D*Z??YxT%9SW$8
>>> zkJH{9oh at F6;)2%TCEbS2!OX1E$5Uii8+P(a>!YRh*!aX|(n5m(O=s#taqfal=M?mV
>>> z5N(g_S%LF8g*T6t_LlT4rHwmjwLX)ai{7O&AR^H&LhgNzMR?P~GY_}nqke8TNL6pU
>>> zMOmwB3oH1TjS*OL?+s&;zB{j6(>UVpS#vN4!DCIo<AhZ|VzmMGK~W8FgWP*|0!=am
>>> zv#lZoh<S+F<aC1cenBC6QSdYAE*L$!^O+Dgy6L0}W;j@<<H1+uI||XeJtRKYEwE9B
>>> z9bz at B8%z|EK;o~Vz9*BSz({R<BA9+MnF4+11Kp)dCs8S`v2D7l{MG({RDOvhK98+T
>>> zYInTdSIGno{nvts$qvX at wR9pCn3Mn{@6hdjcn;>4$eR$r426(qx}lQ!q*iDNJj(IJ
>>> zb~<B-_6e^v-LS3gICu<mT+1r=*vZ$CZ=HjBckMo8&kHEzus4=|e_W|8cioSMkCF|G
>>> zw~`R0h<Zh^_C~&OUDxN4m21KxkY_=Uhr at MU&ywpl-TOIRZ$bG>S5mxhf4_Y|znxWi
>>> zn=WpLWbx_bJ+{Lsx1|j;x0AO-i5X7#kE<79^Z^+=g<2x`o7^_ZkBhdqvS^G_$p9xU
>>> z4XoyDf}y?Za==>GRFp$nc at yF&lm;$2pH7DcGaQ)l>*o^?GR-prVeF+eP5D=i`GwZ1
>>> z?jWKpV%bwjNgEyqtQWKn_H5c}&8rt^Z4E2PJL!CMeAs*Jh*sDE{SWY&x at Ri`?`k?T
>>> zx3M{IW-)W=tUf!_<#gxWH>I5k1NyrmRh{YC+_n-!C)dp>ePB0UU}{_nTK*(&_s^4g
>>> zo&J{0`vU*!_sP6JR!g;0Vw8L{D38x0l`9kkdHj8xijA#GtsO^yh^2Q9r{>#B5rP}X
>>> z&U!}S-|eP7E&xB@^!W)x*|(b>IxH7UdZn96cg1}$v#81qBwo^gi6-xxzIfNF!o8Ul
>>> zT||Mp>Pq5d)8Re8rJZFqyacL6CmsKW#Dy691m at 5@TKI-!zR_)UDKNC<i_ZPyA7$U3
>>> zsF_&rjwXU>K9M&GzGUE4F;<_%j6(0QBJsCTEhf7Mwf@$49^H3qkaTxyo12t1gWh0L
>>> zEGMjIpmm_w?`R?D>@7T)I&@!lg`|^763WN*kRmYQ5d5(k&?cOO{@jpmHxYz`U*y1N
>>> zcK&P6oFxO6#U8tK$wQF&^TA-QP0=0_b5eHW_#dC~hi(urcA#g4VV;OQwG|@e=VhqI
>>> zEb0s9_gsNb_ygygHp-yg3Jk6L|1qOrN>Y42R+|izKL(Sy4qLc^aq at 5Y=}gHcC?m4R
>>> zY=2zOLi?`#PzV-Jy&y6$%>(n=S<ww$S0QlbOx$8TmnMO?GbzmsB)ZA+%xux&TW+xu
>>> zgR!3{_EN&XK?>gGCNodRkA&4s6edSrF|-=1Ya@<MhxDvg8lD`8^E-HiiMz+nxEy>1
>>> z7>}HH?VrFS6u(<Mjq}0SRWA%{agf at zl<;0S<-LnI%asU4xtt#BZ=B~VQuLXxKfHTr
>>> zT)WGrI=C0XcA%Z@(U_B(I}yKyf>AVV3UMzvIQbCI?8 at Mj)x*j;)ZCR>Q~L}*VTx}K
>>> zo4g1S8p}Ie8T+)g4g~dIg&Du3(T~@ssrRNp?lvB0mZ0mdE<Ux24;O6=<lee`(R>m4
>>> zdZGrpI}gY8;e$F7q>7YhfW)4GU90x=(&Qy7m3qXz(i*1KruFammB!U0YzOa3yl`v{
>>> ztbS25?!PyAHF|e$s%Jxy>E_AOe9uzr8|lv5{)uhdha;3E^d-Ogz&azF5m70~rqS=_
>>> zjWt^6V{hhp)!yIJNp!oFdFyB}_Z25%MoTq}=f;X+?HkYAsms;8K6qFYNijg~V7B4+
>>> zY at 6)ief%-C#?c}kCEqraR&_6!bfVjv?p<wG2AcO4$<Q5)KxNX!a`<4hssZ7WyRuQb
>>> zuFl^jP~(sTHgiF=iFpetu>~LGPwY9BKf at GB81CBF-06lotbEtE`EdDG4VP=YXy|C!
>>> zu+3#OO7_Hq29&34VFVQ?3~w=1&54K~4F7yIAbrd%3B(4^3GwU3+?(lyBLhoDop7EB
>>> z(zG#{ew5&Xz($~N!gj?$$ieud#1*wicWi(5fhm9BU(qt+<xc1<PY#JfaZSr8qo(Bd
>>> zm?iU%pkz at H^EVK4pJ)vxivQLAe@=c`;D8(?=GGmo;VosDM6%CCLUxYpZ?QUo)*8&s
>>> ztQ99|lL~HtsiaIG5(Oa%M8XtiI6qp%wgk!e-l4ftk2+v17`l%_+(&gI^d0bwtMWEF
>>> z{k}rpZi-jBKd|tcKa8$^{mT8zxiCK(!QY|~cda~Bhv22R#k}DpO=%s1A*zG_gjw3h
>>> zX3ad=N7$>Z^rH98^e93Ol#3Jsxw9C$(x5Nu>6MUoGfSLaIIFRZ5o(;{UdO}=OKp11
>>> z<GN5iO!(#E;Uq#~&|28!d!_9+92cG}B*NNx>o8G4sCwvk$p&Hd?vS?YJ%y3q3*t+O
>>> zufIjV#X)S_YB73WgRM4tUf$gGf1tsg?fPA}wzB(!tikf)3|*9cJXI!}eU<>R=U#DH
>>> zT>VKup&1rUEB#$acbbrwV6hxkw&h5+=6*@Y!yu`QnlD6V85Qrh!1B$rjRTtxp$#O?
>>> zKEEY9tlNnK<xfVH-$uiurTU(IC310^OG_2rSbUT%&h1~Mb(mO=aL$ACgown{j&Sx0
>>> zvq1t9hKt3{Q>VB+F$iqQEM?4r3&yg;!p(khM?TD@^O3~n(L88p6lcJS<vRNZ*`od@
>>> z%RXDKe&W|21i773-INPTFnQ{vMA&Tn*jp at kJqO|E!aX%Qjgaw*WXGtqe99)a&VdCp
>>> z<yncbTYQ3Mrn(`xwQIUkbraO7>loB2x`Lat|InhmIg<1uLE%VJiIKTP^sdc6^lu7A
>>> zf4Cc|1o;+XdkPHPXfcp2n0Pdy;uYv;xTDuJomZ#b!~?K52Jm3ca$AyBfBFxPhsXgc
>>> zVz@*y_=+3cQ^Er8MQ<2kNL)Ye(1*A>jo4s=5@=zQR)2?<lXXK~K(MK_2L|@L6rp%C
>>> z7X%?u|Az%5182Y#U+lgEwPySa-lq6H-u~+jKlvU1opL~QDXMMbgr6aa(uEF}i3w2W
>>> zVLFp1%iw6}M~O!qkKmy_I0MzaJB${z_$=0LkCNduB7p12VaJANZ!M=HQeb1C2~sn)
>>> zTG`keK7J+rT<>C`Z^2orQdgta6#h)D*n(EAzB91`>w?y|o#Lg=Ds*48H=D#QrNU1n
>>> znTeS-#a&7Wos-JA!zh)Lk^D%CDs?ikXLa70BFV}N%N8-Bg(G6`*V!@Q6r+aEe}fqJ
>>> zOr}X;_RJ_g1jQAMRDZ&3NfL7uUvdl*<SH*=f*<;rgrirUl+#w`IzIjMX=CoJT|DTj
>>> zXGgT*@DD~F@*4)~qT3)cT`=n(TKjAQ`@_#Z_ruTr!@`-lM|b=;3un$>E8oBQ%AcD}
>>> zj3fg$Rj&m?u(!ewI8EZfeZEA>p+v*U%L$`DnIy=3rw6!@et at om+aA`!xtHLw#20X7
>>> z{NZ|=QO=O#IJYP12PABAZwXBEwd5Nz_?d3jqIjU5Ua{MlYR`)emKjTC3W^;{J8ABc
>>> zbTBpr>vvvo7gWcg5>s7!A4UeqKpfh7W92@$TZo{)>NC;#a01O at U_IaUY505bxcX-w
>>> z<T2jOi&W6X$IM6cT-&8}4yd+FS$CmMnw#G*wmFD>ujIMuV3t}SRhcu5Fh{V3c)TPS
>>> z;MKrfqJ#JwlS8u=)fpIfn-$3$4<nuQm}AwCr7X$f21yJJxCmD^L01H=QgG%Li#Ejk
>>> z3)Q<FNnOeSD|81Rhl6Undr&dw9uvQ~q1wU-I-`jByILG0_wFJQd^a_XxU||FC^)DP
>>> zA?{I<>>^Jh68XisOzqk>D6T*oJp^Z=EO3^9$QC<^@;$AGncp-Uzc$a&V?|+Bw-0go
>>> z%gL79IDF2VR!!^i4!CI0Na54QO=t<C?<!;-@^1APJ!oKwxc<R><ND(V;CFep_;Bls
>>> zU5<GEf%($SU|}{+C(}=B^H0<AJ(RbgDkM3AF%Hr+8drgd(=e4-SZG6d-LeU~e41fx
>>> z%w+2Vhi04DWP-`_?)W>IgD8|F-C7oE#(MLOWuA1$a9JMVSyZD1>Y}C0*){j29q{8)
>>> zm!8sajb*=M_g7KF06{)G1J|$~kt3?Oj=jNv<8>r)+?h9D5sTF)jqaqfUQTio3Qp;M
>>> zA>ErS$35zpuatc{+t9ntcFVf>VMa~PJ7P52r9-d7sSIxw6c5?i?Y|{IiqkJ=h8~bv
>>> z*<Zm7)3kW^V}2NtAxii9<wP(f at H5`-yQ1>E`rXg^X3M>q^Ct`59~M<I at N3i$^4B6t
>>> z2L4^408DWax at X$J)Cz8zx-NAeD*52VfaEOCWXgIv4+#SiATZ^$1&^mkq{+YQ$(*(+
>>> z|JkmvJDP4DexIK-k(b{Yn at p@A1FfB<+RsdpO6N4jtFVe|8rIQf^mVFrbN5ruu78_6
>>> zl3A)MTCO>pap&XwC at owLA2Wt&sTOUqgA99aMLKRqCEoJyZ`Xg$w50~T(@d2On%Om8
>>> zg~s?QLP8|JfV(Lx;{!A1`=fkZB?2iTWg3d5KfPP59ayX2yGK9IstbRMs8g*u_Swy6
>>> z9CB~Bx=ne_y)Oh>y{5yG??q3S%3gGeE-R-Wtv#lJ!{Q*8xx{Zv;J&6YlGFSMA5Lr)
>>> zkIC(YPZ?K%;Eiq_YWq$)$kO>WbJcsbI>_To)D8vkj{cU7gU0UQ+lO=i at YT(4(l_WD
>>> zV5=9P!fj*V2W+$!^opN0<>GTpW6n|7Bm(U{UPIimhqe-h7FI9E&B&=yPeQDTx?twT
>>> zi-iuACS-UTFYBP(MsVf!sQ at COO&}4BzRzrKsu3z~xvOei2QzVD_i>%_{T)ui at rH=>
>>> zam4X}#JDG-C-V- at QD>l4 at b5um9ul}piF-%%Hdu(>)!FhQz91Olw#W15w#+&*@%qLA
>>> zqjvqLSSIhM>hkirJY}W3HHo_mJ9#?cvrG#kgWx*~F2^VgfJnC{JwZDm!*>1aM!!Mp
>>> zYgo!kBQ(#dU(-UJaG(t?qsX?`zal82^+0x^T<1`nV>G;HECPjT-7BQRKDdD&SVBay
>>> zz|ya~6BO`jtLs?aJ7Zs}*szuIGGeESZHs6tK595-ClT5WXZUM1fjPSj_EWV0+f8mu
>>> zZSc(<hHIYK|4_j9<tzHE<THqK*H$-j%`N7d^kg%-7)ng<8tJ+^TstCFo1GB at JmtD-
>>> z)}?#r9ODsb=Zsnj8a}QP)2p16v5eMI?-=gt(a3XMqOQ%P>V6U}M|}&}BrLR&WJ5&p
>>> zfw<s0Z|53~FY<l{jn}P5GQz4$98ymlXFhh|e9)4{q`>C0gY0Rpj9aI;5`6A>UHKY)
>>> zVqUx1t0I&?r+04r>RfMh5==jjun7MG?uR2)ukw!Lx>lAEA3~IZ_&01F?PZGJq&dU~
>>> z$$g at 46%^+4be$>w8f3LX29_kpf)%5o#VQX7M>RZO7$4fRLmp>KQ7_*)Cp`H6-EPFp
>>> zOH{2it++^G_sLiX;Xb?y*W{PaI74&1_?xvg=<^VxvGh&EK{^w>rRBtwTOXmY#+W%H
>>> zT6Wr`LtkX4<&~)97s}&=g)K6$C5VqDNf2X7mROf>gI`f%ff;5`JrK_rH?W!I-eTL9
>>> zUESM5FQ!Hl>4<kj48<dnguqvUk-W;KWnPk3?fox8ci3g;@#=iD)1FpEPhyEyb?r8h
>>> z9OexhZ?bvU&Ku#P^_S!ye|e&Gbx2r$$|m>Q1=r4v;Et}BotpU{%N`Z6`gFh-^m2|t
>>> zUl%ijd+7v3CVzbI>38417^7-!f<wTh03*cYE<utE*bAXZ$*_SouWdp!><v`>@3${A
>>> zgWH$WGUWiO+YI~~!m03*Pw(BR%dEcG*fifLPdN49&h>;w8mjq#*N=yzqustiu9Dgi
>>> zMN``?9)iY&u4}fS1IOYUb0;OdUCmHQO^=~8ypmOK8{&I_PEvF`vObM{b>LnViz61z
>>> zIGf at g{_0z<f!yLN27xhFuc5Tb$+XFoDJ_-|l^!iFQimPKs={- at n<qYV+2ol+=Xj~z
>>> zpO`OqUfT1d1%RMC6#Cpmnub6c!AjP*C^dN)%p{&@QZJ~eBURU8)SFP1ZW|ON^8I+K
>>> znHy{w`RRpjsCfM5_z(JFKCx>DROm-<!@i at 3A&(DQ?PackdM;ALd6NwI!YzK(0+sn*
>>> ztMPtS(+`LWsEoB#5z`@M)VBVVULR?ekmsDyD);}jeZ&%M88vmmP at o8WjAe?8T|n0O
>>> z)Bd<=p{7!chv;x0tM3<{i)Ex8ZSC-nyAzk%CoR988vV(_zH9!PSNH1;jVCh=4;D?5
>>> z(2-PVe7|>qZ3t$Qkv5o_af`0V%%^xW7v886is}C-%ppG?yip$g*1<I`)CIe#$M?`R
>>> zzo>`$EN!h?!R%tK+Mty~7;9gFoQ8ei*Q)Vs%X}?SVkN<Qgr0bJlSQUqNBGtFi_`KF
>>> znmN;#&O5$%Kg2gKg;>ajvuSBGlsy)tnx}zhg8F6rVLNeLzkZZ4;;^i(#4_m=TVR$!
>>> zQaqTnd2n+Z_4#&Nvp#B~4b`MN!Lx9~2WcRNW<ocT3~=g41KzG>d1P@!?-h~(9%V3#
>>> z4++)aeHgirpnt`x8&Zs1Tp2e(qPbxvMNixy^(S4McejcF4>7 at Usq%(%wVvuulCg|C
>>> z-CR#DUsSzdFm;DMQ|^2K6=8Q^<HMdth-6O<E2)jdz3Nt7a&+EwkYO`0lkfO&Ig2dE
>>> z$uTU&hBnN$o}bxA&U`DKS_ux<ANGVW>!>uNT?wi;345acSpPaqWIBBn9c}m+g5{fw
>>> z>0z3brAJDAZ4>fxIn(wgs+|<GbZ0jYM1yJ>eBsR-`U^m3K#tXNiE~dj4ZW^dh3KvW
>>> zTV(d>l$`T2M{Ri?7-xWnQ`Y9-ua=V%)HTYh`!<({;y*IE!b$r!*I6k4GhCV=f)B;{
>>> z*Ky9)sI5-DE{r%_I&k)`!qTM~7UrR2M>JNw=2?PX9J(;9=PFYo-FH81JSCL>aS+#n
>>> zx$nGwilQ%OhH48*OeN at pTZJv}8&{{;+WbHE-aD?TZCe{g5m78rDbge=A_5AcAR;9;
>>> zKtzaisZl@?Pys<YSqchDiy%c2h%^By5ouB*T|kJ^MOs2{l2FtArk--oaeMaO-}gK3
>>> zd++^z=MP~qldQE|nRAXYo-v+h)Wkng{&?r^i;XdQ7Yw$BN{`xY6;TQHq16X%5Ug$#
>>> zSH?{_uRNsc+fzbU3 at NC<w32(v%7=8 at FbaWB<!rf9F8i+4Y(NZL!;Qyk*u8akmwzu9
>>> zZ18sXDhba+Vg at PSlJZ3aoS$haLp-Cd23?7^HB4tJXX7OOO=;iv)luYqiSTHp4 at dY$
>>> zSx016G3<?i8owUe$*wt8#<euI4Ck3XG8O2$?)hzjOBTIr#CLz=$h$*5EEr~+PdLv~
>>> z2WI`M69HCFcvK~Lq$JKW&0^@FedN<?2as$n_|ql+6;W82yW1s=n`-cJ|J9)0sfz at u
>>> z>YMt<@ntg<ty!O9BG%`Qmf%|T<3d?7tAX^ZH~7gtOg>oS8!yBPtn5?HxV)pfRHsb`
>>> zhso%>qYC|=T(%qh(;9skvG`s1;S8TeU5YKy{y}YVi<;P1)<-b}bVL&%w8P3Qe?7Ew
>>> zXudNn#yDyq8xRA?u&9w7_t&Ko-u2Txa%`?trYzb at zJDxucS7KdZpJYsQL!V?vzI-K
>>> zpP4zUJl4nHdD^>NwGDskG&opANYB#c{-oDYiQQDS)lZeGF??J>j+1(;<@}><2YYVZ
>>> z%gaLwIb1~?-QnHf0y}xaWalh}jMby6FeIs_)x|3x8?&@-NOp~fT_$)8E99J;3B1q!
>>> ziOcu)tIRzoIh9FxUm{v0HI6u<EYs;z@}&u#u{6&`j)2S5G^CCAyfMA`75B-b<l=@G
>>> zmpQnLWIyR>_+MGw`v-IU7jA|0hH6oR8<qi@=O&Skcla*Bc&YVd86u$p%Z*H<ww%$%
>>> ztrNMaXyF{S at G-z68a=#2ue&)RNx2ohj(LYFLc-pIi`=R>MA|KP at S34|cy`0{E1j1`
>>> zcW{%-$U?Bw$KUV9PWh*r+<5F3c1LlMd(Mp<)In;Ty-AWemn(qUKKZyfJEfV|J>Zg2
>>> z!C5uGI)nRSM@~(z!G)9Bgj2(7n{yQ%BTezX?*2>+fjV*Dg%-Qx&QwF!i at f-mTNr#K
>>> zbLuw7x@|*sYEx1!CwXeQZo|M_9YyoSPz at 3B`-*rDq&yBz$yWMMZFJkax)F`!q^#oF
>>> zVV^}-js%j#LTxE>q at sjRUh1b&=RaE9uF705e=tonN2sl9-O&-{MpQH?KYV~Emw at dR
>>> zzJaRl6&9~z$to~A{+_W<FiJ!H9$B2gu)(K&*(77JMYy}6eNe{2!YlT`<%d_qjn^0(
>>> zfv#a(=-_uu6{L`qjZ=1moW=l19Ux4|L-#XB#tvTFuXNukYI4Yewl^<0#X(GrT>mmW
>>> z*}>z)u_ulJpoP$Jfde*{?#356;18TGZ>@<FOu^fR85skXf=#q>?86JN^T1bp^}6m|
>>> z>Yv%%{_ at 3#rz$rp6kg=yk&)Vb1ZJ63L|&bfVF-CilG*|@se#o#{=xUr`!<9{>fQ*D
>>> z(ba9xYq_s~cP?S$$$<`!lN|m{7p`};S$JM>sWTNo$kvWHoG=~%`E{6HBlg*tmt{?0
>>> z>cfC&)L=!&Bw<XhPIxPh2nkJFi}lRPDpWcn6LaTtCM*?pNL3p$S&NN=IgYGLU}uT)
>>> z6EAqvRUt(QK35d7QO?pqm}uPi{D6tC_odaFnUpB#!9@>#+Qn0Ad_=>-K+T^|+d}D8
>>> zYSYIjmBoulTbkj+1?{m*^rsFgU+f3e at OdPC4gS%j?O*(qDe3dI_=uz(l!hd`ohSBZ
>>> z at e{YRCc-U+cqf}Gkp*ybc4{G`+=(U7O>Z+!>Ly9V3K at -_coVQeeK-)+H2t{zIpQ$<
>>> zz$$J^YsI_=36PWFq at j&>_CIc(Ax_>DYHHd)bZkPh^n)=S3hFJDj>%NZNniZT4xUrr
>>> zZX2J4+PvbR^Ys(^`f4B0t1&}3?|!BO*AL at go<X&7&s`;zP#`AXQBrJ*P<T;ZPM;-5
>>> z at kt$H3pb3-r=!q2OfICg0OfLjw4XsWXN26*>}K!x3O4sVax6Kk-%3CY`AkL`@kklh
>>> zT5+!KI5D#w=`qwFN5ej*mWM>UJoVAZdCrIe5!Qw%JzWVt(^2l>WIg?;^(O}!kQ%Em
>>> zd%E%YsG1pM2%<zFbUp4S|4=X!!Rcgv|ER3(^JeKt&A}H<dv|06 at C9rjm64BYlk&Hv
>>> zZW*2R9P{FNI%}n>rZzqYV$8A9W#`#s#?~pH;2?L*Bb2avhr8 at WWIEM^Xl8rB#lR`D
>>> z>*?}#cTSNvw`G={wcFiWcb*E=X?JJrI*PpKamLBv*6Vs<y7U1K*cH>%3ujLe(D#?J
>>> zIC$Rb-<v{xr0MAfwM at QpPo1V0(98D{nPP^)MwwdHxNJ231=q#H9BY9ho4HJP{@kO#
>>> zhem&T4P0+?Z9Pf!*wsJL{c>NR(Zmf-?O7vR4?j7E4!VK8ftsD_C?-k18Xg?T7JsD>
>>> z;CppjpJUDu56j)d%93j at AN?qQnFAhtq8pRt1=Ys~J<2h&bcnAEudVjAKf&)MVQ^*-
>>> zcVqy9K9LLQ3&+$P+*hnDC|RX;6otW;4Bb6wLt#InoVoBo{JFmKEX#h=18-yPfYVwO
>>> zzRlQkvG_wHenG)+=v{&fO at 1ab6VvD`BvddtcCB}wfPf3N-CUv1blJ40te-iS5*@~+
>>> zdO1_P-xfF0LrKFmKVwdJJvDvdCqt?1sdesySF=?LkKFpSeCgJHqvJ=;l=Dh{N|nv%
>>> z?ZI~R6t8!U(gJAaOzwfM80p9aPdy;1^0L=_G1**kPldVDC}c>#md at 3k=%m1#TX#e=
>>> zS2XlfbXb5|e#n&g<0BDHqw}B3>yac_?+`J4seNbk^@|qGjZv*Uw1dd1i#;74aUzf1
>>> z2Jz{KkEfg8w;zyPO=W~!G<I2<sdrFFU(J4An<v%9ldn2aq}x~C at p17fC{KR(o67ND
>>> zRF*Tpdm*s^N7&Lq)F5!b^QeHn0Ez|GbmGyzgm~7L at 2`Sf*fJH#u2cCT!b=cldy;T8
>>> z5mTVi!Ax$zFR0c5Ng8l1+Ts{Si+U>KOb)thXtP4r$c{6<q`6~*XVrFDPb=<bxzT%;
>>> zw+P2PFiME*>{%2d!?0g6hKr#|zfS}<@(ilu)e^3!;+W3#GB%!x8C2a9LVvmE8;3Xg
>>> zG*FDD>oa~=0?&Z=p3b>}18dXjW))keBTV+XS)EN)Udl5xGU%Qk;tZL1wW at ZZNcN6f
>>> zE%S<pfl!s-fvHBnZyfX)3anvhgP*4p1%@ie)FzocmrYfTZC#l>Y<nc%T4^F97v1Mo
>>> z#(k_E^E}B5VNNY4N!-ub&l7yFaR!y(s>gFYM$GvQx&Y3-Agh`hTzl<~<7tI24jryY
>>> z3rX~KWQpzK{>55)QCLoiN5GEClg~tGyv!N3Lz0m-jY8MdN<vm}f>XTDn-+2|(Zg01
>>> zCt`i};hoo|x^{#xtBQBk_+`OyR{?@hUPGrkI~_#Je&bkPz<lF4Al|`*k;3(BdZ%oN
>>> z7?!Fgp3cj|kXgA%^&D|tkN&7cAFNC}miW^0`fUphr9R?gg>coa>$`3bY+DQ=q2Ug0
>>> zIiEz;H!h2}S4~kN`@Q>=4IAX?rd^{#mTHBLGwy^Bi?|dN7x~szBs`9k-R7Ryo-kF&
>>> zGIG#hwZbi^w`?eT2v at MSA<H7i_VZ6<;iSo(H(tM(5d7+9oplWs^%VE{Fz(Fa*4-h-
>>> z=9+ygxH|Z6g~_TeP~w at OVCd($6+bdW<3kvsg-96Y!!h;&Y?6Y$23inO<npnv4pr=g
>>> zobV4$_`WLZ_iDNDD5mVN)7v1}l(qdos9eS)fbON07r&n_!kCs=>WJK_jTlG8BQnkk
>>> zTKaZmaRZ&p1Pl1*D}U2X1KN^**hi^R`DNr2y_CCqWpsOw8h$!y878+YtNJA0wA3Y7
>>> z?L1Y==`gFz??9;v^6s1$0Zw5-?6r7RZAqayR5G4yFho=TN3m+!2#O$T460Q?#7;s)
>>> zAOFJEdWxl>|GO8^U+D~M_(I<fFDWuB{H!}t+YyfQkIF8{KTLi at u}-}yYMUZ$b?yb4
>>> z!*qFD?GacyB#(t7M(I_GQ15CsP%ORCMay_}7-gEm92!L<NK2+&hvylD1=V;E7Qe?-
>>> z*Wk}U!|@3~(OZT)g(@(LVQ$IC5u|@?F#vmMTB4S)>vXUz*?im!B8nz*aalbh02=iM
>>> z!c*HBcd>4ij1I%E*sKiGB^^X|4IYLcP6yFStvglUt(v?G2VVitou3hi3jXagr&xj@
>>> zW^WvOAKIG~{MU(fHtM#+-!$*w#Px|=^BJaohubs4w71NM7Jl*GwsglgvomlR$OF25
>>> zpI`s9Sy^4;OWGgr-!txUwMo@#A0Q8+ud@?I3|_x_5_KZpfA3N{ZmKJv^%STH9|qns
>>> zNCE%Ozo4tI?Ix3_vR+A at IQ)&{+LO<Ly=-GY3tQ)OrZMH%v+MFV?XxYbcZ?>!dU7JO
>>> zX>^!FInSqT2;gE(o|F<+ at H}G4w?_iiQq=WIrwd!(8{^o%45qh<Cij#nlUKcF(78{G
>>> zB$m3nwN6aroUO9z!8rL?<_9O5ztc+O(Xp^)TmzQ6ABhmHl8hMYHJMmQ=$U=v-^?1h
>>> z$N%P`Ps<|WWrczcV|`o>ekr+AU&H_2YV|*W*=zpAF?R!0QuUmFmC0*SUxE~_h!u{&
>>> zx{APu_kTTJKs#Sc!A+3wZspeNVr^mf;}=4)j~c7ohgc`fO&8y5ZskJDkPaGrNMTf?
>>> zZzGaa&9twPOPCB4-RM4uxrdQ0!D~;u&P>grJ`T+)g59u~df9tl;<*KATGA6mfRoXP
>>> zk3CDuj4e>}A at t5~9Q~lyT+j0kojVw{a0E+*Pw*}yHbSG$rtC^QOPage9qce4q0^6>
>>> zRaWbv{dJeu^t#B<Tb`8AmT;pVu}@h}3pifHxCndb8^;%99rMaJj;BZl1cH|xU|zSt
>>> z>T2*th~cLmGD=}=x#=xD`2j6 at 59}l#@AC~3rz`}Ip<<TlAi2D*0xs9c`;FtWGwZ!+
>>> zC)v`wARd8WNno9b{e~n_wQn4i-#F6Fv96!G&vfXlV?3RO0U8{T_|v(Z5+e0?GTg5$
>>> zx-E46LmBjVqP=kF>v(?NJ?X~2f+r^qPcIzTy*-*+?$<?jo<pWMRw=NsMZ0)4^Vyx9
>>> z-3yySuV2U#<H_Ir*@k=I8a&*;mb825nv2Ys+(RDrg?{_M2$`{??_Whr>dtmyy5B-U
>>> zE~SH8^H2|Op3bqfFe%eDpPtHI`Gm#LgKM3I9Bf%CS^`8qd)ATljickGkKFxFOZI(~
>>> zg=Sts6yxQ_x>K at K#X*w0AYRnLX}lxD7Cv~V9xWGMb2=<151my5OdO%Mzbz!obXTbE
>>> zN+O(nv3Vs)q}y3kqA33S=rBx;d(m;Oa6S;VLs3)a3h|S?w3qOMH%YF9*4=637o`k$
>>> z??w59Wn2+kgqFKcXdr9>cII7PLWx}ZLytrPcR2c<DCd)o+sR?|DxQgQ?IG$ZtXOw{
>>> z=NiNt&j+eXB$;a+%c1+r7Uw=>Nyb%8JMgX7+#Q~mf%9RgT!^l??zW6e at Y{)>{TTL`
>>> z;~g$p;l at K=MaC_Ce!Z~EW&1GAZV9nL#zE<UDPO`5WbU8yNQp9ibAH8q(j!ud|Azak
>>> z!x7xwIJp7b3kx`>zT@{a(T87shd+-o!G!qPHWGwcTYokBJKmT%l^YO}JHEF$s1*O+
>>> z<^b$UKBkNO|Ev=I7tf0cQrsT7YzZ2?((4R+0t99|m=C~uTY9oQ{Ch?+6>ycgyg7RP
>>> zoz}8<b<Z_u^M3-$e#V=guAbGDIT87Bw$^wwO4YC~-X*H*uHgQvE0nkgA4sU^D0I=v
>>> zU}^^Kb;<jUIN9!s<B~(s93wAfCfqi|3bkfc_tedEOI$-cQbXSzI`rZ5{YdN?OMhH#
>>> z at y@$XRp`Pju1 at BTH|H9gxz)QuVRs)}a*lrEI6>nnT^l`bOFy%Q)SpG9d1J7udxnF8
>>> z-1qN2?7zj|g1Ch%`O at oW9LBBinoXNS7uFEceFibfG>OB{=B!t&Vi+pd(b^3O9+Z;R
>>> z at Ybz_mI(P0Q8z1A+0Bb5OpFsVVzVFAyKjHVaeTb0IP72!q<ZZV&PgS9XMhZa^S9J*
>>> zZq*(T4g9R>?U(Vr;-8+n0Ov!DYROT~GAZC01BOqgOn23q?^cj0 at QovX{u~f+opfq)
>>> z`o$n_4SNyE)LGQ>Fk{nnnEK35tP{BN<{DEvsE$l_^Y5CP-!Vf77|>?LFZiRuCY8Un
>>> z2h0}S%whxn3^2359ZjTWvo*T_i5)uNieqBr5hQTgDnFX-FYXt#L5N}2|F(<5(sZQ^
>>> zh%`WiF^~;CLTk-iZ~MkkN<!4(_gqg2VeMmi{k$rE^|vjQ13%BUVXH$;%S_-><<En-
>>> zr2TU?{q_^(b)sU4GPFn3xxKm!XFt1mr5#$55sLPvy97l(KV-=)I`4o6GU at pD%)t8b
>>> zs*GUNAQU-f1gybH^k#m#2-vebzIT40II|wcA?Q}Ns3hZGjh?E(FC0sr_D6C-?-#eQ
>>> z#aFr1r|9u_6o34L&KA%sWPYmx at M~!RnctBH06j~7Ud-S7nEW*M4}DDR8Dnyk at 4a%S
>>> zE2SKErXPazQW*z+^$33+la at k+vW6&Gj(_=`JX?)zfq}4Nw4C~dUAu~>tIb5^l{A8S
>>> zMl0scZyZ+`LoBi7Cewwl;?y_G_7o2pYR3-;WIy**Ba>I0t%IwZXK;K0rPYh5H%+TR
>>> z3xvH9<W?klNS>^_-~>zFxX*Ts7zP0d<-Si5!!6n`^#oxT_N33qv7{ov@|Yo1{h3*<
>>> zuEQ$DkL`r>R+Txk6Xs-SqX=IzycwU2|MHxz?@Cdbc?rDKwsw5dnN|E6W;O-djvuv!
>>> zk>yy at T8o5G)PhpRHxBC_c8olDB1|T;5H-w%l5vx6D?pDk+MFo|2o7=Vgs(HS5jL!m
>>> zF3b)_T*1*aaKL^s9zj!WU-2i&Gi*&mK=5Uf&>2KIW`s0Q1u6kOLr&7$fV0pCn>0{X
>>> zfw1S<y0AfnA*$Ol5l={m_6N_yvvAE77ly!Ea0Xf63=&!%`XI@|16{C<8hoZ>!K5pw
>>> zoFTFfp_J0d9v)&m#x=#Wtbj2<>1Aj6-6-xq8>NwUBFy!H(mQNxcU5*kBJeI&R at qU6
>>> zV)E3Nhb|!ByULCfU#>p^&pq)J>%KID#0}}QP8Wm6`t-MwhW{mrvi`V)(-Gnk&>~Hf
>>> za6aS6j*Tm6-9bxNuX*Q{->ed#-FBLQiCmvoILh&?)!#nT{1G1|NzJKQ^;Gi4Pmcum
>>> z^#o&T7VEK@<OuiIT{d6QH at rq_Zogl^94e!mw#8%ay>#mNpc_6Igx6!98P1oFo+S{i
>>> zE!@cSeq&+E%q?i&h$iK+d{%G`T1son={Bv#BoVSv{@{Mw8(=ec7?#_j&0BNUer=hR
>>> z4A^MnPGDt3>88bAZZ$2pOh>E5y1HUU2U}<TRz<0g^WFQ#PYm%m%!#@(D~3%=rY=T`
>>> zdhg1P{N#?8KK>q+h0`p&o91*cgvH6N6$5{-s{QoUvPfyhHWA16rOZ at Ip6BU4p|-?p
>>> zU%{h#`G>@B5J|21Rgak at MfxsKMRw?)`_UvRGUw}23&(J5aoU-15biws#sT{4 at -I%b
>>> zi2c;f;fI|bm-%OXZhVIE6beUmX3tqLbrujl<X{$IJFw!Lz`U7~ocSYPeeHH^?rBOu
>>> z#@>uH<+QGb#4zvNg|wSFGKoqb*3Isc$-hc4&m(_DcrNFp>oF3kes;+Ps(t<&t;p{Y
>>> z(m7>o58~a?##4uGY;w8Vfo>)A^9R<-BvrVTWtmUxa!TD>d^(U|X?lh$E)EmT)2ZVJ
>>> z!4w_D-;J6)PKlf#xd{<GH25xYhP-`obLu?bn)bvn)6*uZrFz76{4Z?LD$lP*M~*Yt
>>> z8gk5Y%!zs!ZF>t-AEA03EZ&1`N1kQeU1-4{!G)joZAUDX2``xcJTmhRssLO34(6wU
>>> zSf~n=Zu3D3kY09sY~=TTPt%Au0e_&)vG!lQ4*P`|JClO at 2(W^mB-+8~1RCrTkwp*%
>>> z-Yg0#F~mP0so=Uetoo&&@0Xou3W9DFpj(a7(VIZjod!+0D}J~BET|S*bsQq0A{jmR
>>> z5nsJ96uI~2AiC8?SpV_PnR)eb>KcODIiW_X|8>sil#E9pA?7FF!?eoL9&<21mUw8n
>>> z!wwduAbXNva{S${CVpn|j8FPt>Bu1qbG)6?-0202?0`zuCaXlei6Y&Y;g0U4Lt%TK
>>> z3=h=~oR%3_FLT#V>(x7&&NJJaEzZ2|*E_??w{ENnyX!^^eC)G%v+F!6#C6b3N9a+w
>>> zv>xTb{PZ`D=AmcIIg<T0gGLfDI8~-0 at he?fjXhUI{vQ8fKCH!SA%^44-QS>ltd+Vt
>>> zBe_cMi}e{sDCv0KXriB9rhN!4y*sT3U4X*TKzONI!EdJ`wi^CWO!?V)t?cQ1hn4!c
>>> zI2}9L4{D)$T3x#STI-1e7X~r08DG47 at 84PMgQeXXYC?3f)b;QBAFV&}^x0>Eqd#;K
>>> z-f8;wPZK-;`@6Il89+N3_z{E7zx+P)IS>&G|1Z!0`VJacIsatVabx{jl&jMO(yS>Z
>>> zV;XFCITv6Z80vm4W*q9#(8?NM%RY_cuRi%|I)eO_X<tp^0(1GS8fu&{h1-G{J)_f&
>>> zq8si4dr=S84}c+m*niJ2j^PG1%c at HP9YL0IAAkeUtHX#G=nPb%#7r3>dG_dj<LF3C
>>> zhg5^-(VR3>5?dU4-vA#5-~eU<D}Wz$MzSk$ENL6Ch0<uW>-cKwH;yx?j}t$Tf+8yF
>>> z8;7eLOL?GYv5^VKEGe?KqH9qLp{NJnI97LjKl1?k9<hfRmcizx)q$!U6zw}!hXYpm
>>> z{JrHw&}OF){xR){y{cHhzY|TTr?AvrZkLn!u7>%-sh&mi3mZmNZ|URpQC-=Xgze!&
>>> zY&;wE^?-^d0wu^wOg>4H#H0HXvFZM-{A(!j)`*!SrEqOwP~CU8XS{0PmHyXDj<`2{
>>> zjCQaIEWmdjzMaGiGdr}m4`eq%-bs8sM9S-3H36S1fj*7qsi~p?`|rg(SxC;9i-U;%
>>> znnnR%>U|6?EXu`7E at F>KsMoK1=aa8LShYU)khl^4ld4X}jIeQkJUYwvcAS8xzWfdi
>>> z>BDv|TC0~hsXfUtw&{WO9XR+KK#l<ZOZWRlsWB at 3QfBso3bWYhD<V6SO&rENUCxpj
>>> zg?;v1c}WJ12 at t`r9pZCV;^peH1y6RmXGEILd2uRjgON_V#lT$xwyrTiS7`Q&M4dY>
>>> zzDtI##1)Ymn)0eWhD4aTP%d9Pa$U1%V;1<&qxP$Z9LOtp`?DMRkAGj_yx<yBudRJo
>>> zcfZ2yRpffNM#l-c!sVzVo4xaz;?$Q7E_r(7Wav#K2h}$}H&KmRt(_7-Hp(H^o9BVz
>>> zX=wMarkR#hzOcFdqRa5I5|j;(aUpOC_^XRNoG~=Hu%Lq4y!S0lr3ZB-CFkswHLLX=
>>> z8|^?WW+J_0(rayWCp+VQn8)D;S1$8x6aB)%4cQMGWNs_eETu*4PR;Nsd|^|bDgu|c
>>> zE`MImwVa{f9#RnfkGKAN$N!7M{FJ}o<ZBLZ5nP(m(cn1h+#ZfU at 6UHhR^gC}==fhz
>>> z^k4NG`8RbT`Kd2S85usW00L0Fg6CE2d^Elu-U<g9r1UiF=pxn$%<PN5-tZrS`#-&p
>>> z^B1w2s?(CnZvuQ(C)!X5e)J}askIOc0)+RAyzJe;K1~o}RWLzG`wGeSbDM^df<tHA
>>> zT<u>_LmCZ}4)6)>J0~k16Lb4y(*~{mcuP|@k1aXdUVSY!lz at x^t_a4IRHZAVM#FhZ
>>> zkq+Ln+NgOy%D~e{@*~|66MA&>%Y at _yQRnr(P9bD7=1iHYEkq=118O at oKL7$3u~fF$
>>> zRdNRVzT89n>es)VD-UWrK%mw849$$+WX^z6bFESUrYiw(2^;$Tum3kEf&c9sr~Y$_
>>> z|Gz(r*={hQxD=`WVlm>A-#E6a-t_k2Zs8wYS)pLFWzK1_7EuCBM^-Ug&d;h{wopc^
>>> zm<+q0$Cp-y#>gnFo^xAha=lxB?)c?$<Ga=7)FIb~<Bcz+Jde3OvAi at W+bVx?G*L(L
>>> z3-bM9ftX60YhmJvn43E*qfD2JUo?6epu%?Oxt-HK^rZXAYoUExpD6%_{O(?T4K-7j
>>> zu^7!$`xac6n3+3d9lDj`lM1fBoa&zU&a~=J6L_py>Mh~H^NRcSB}_B^rSm=P79thN
>>> zkn)my=cxa+u!Td;&ak#$`N)M+UzN(&%yOZPp=yLWXA21z+BhNrI=qu7f?rCdY?Lov
>>> zpav*mj2~EJvX5C$I;|9|dSBj5X;ftF45q1Oeu|Y&DM$+Kz!T{GtnaN`;IVMn!JEc8
>>> zKw-la^_*GJ$iV?h&qG*(EW1CA`~03H<Zm&aAN^~&{~6f*5AO3n8~4#qH^zv^GwXrR
>>> z_SjG2CW`18#FlmNXq6beJA&-y$+BJ1zC<&C+r<>K_BSz7;TbUmuhd$)X{hSP94{x!
>>> zVv7N|;hU)Lg at MLqN?DBfOxr2ZfHnN%_Cj{@RPB#(R+T<tO55zn9~MBx)*W;8R!8h0
>>> zB#peQxi&(@U7>FU88Ng$5f^|eG$|O)y`<Wm$wp()QxEWk`<{-Dg!hVE+8Xw<!e#k=
>>> z8%$i0Ir6Z!Gu6OoT1K&y`6R5yxYi^_I=?Vw_G9$eH50B&S-Un&OBI at M%lqnf79E0H
>>> z6?86zGAd;*7Cre;Qc?IUId-5?OUpp$-17RW5vnKHM|h}Th+DP}=~6_|ViZ=+`L(TC
>>> zdqQTek36$^cPr7%?9sj`U%y?0(V}ZPE^Z`nm?qzAmG?R}z!Ra4ebu}Crhi@}u9)0q
>>> zDffAjWkUFhuu+u<=Tsu6Rly at Gu8@c7Jba!eJnYdZ4;o(|>PQSdXM6ceiQijsj$MuW
>>> zwub)JCT7|Aj4Y%gCis^QkL2{p>m(wg)KjpJyq9d^3X$D1OiUk+>K#{urEja+`;B9$
>>> z9LZMG`q|Xt>Mg%<B<N!oLvYKB$Jlp(2cH76`THmEixg=10P7VHih1TI1tfAdk>pqm
>>> zphGdz3Dth6;sc5{4=6j?tUib`%`^t4S?C+b at l=*yD?Sl?4)LEe{QI9nUMQRA3i(+&
>>> z3Sgt#+xNPd*%a<WuXkn6yvPTO5yRvzFPHBJMs7!8W}{hNVYWT+Z_s(W at aLKGtwN&=
>>> zhOri=;A+K_ZyY81X{r|q;uYYVo*SY{E_n{m_kCIMr4*8D)0w&-b8d|t*YUrsp76no
>>> zX4Ee&BjzKexO7nIV!wIX%3`BhVc>0Tk at cFp9*XY{oQY>67d+lj3YP_kd$O6ws9z{L
>>> zL`~eTo_iGzIg=k{ZaKk}S_`7d>Q0_qFpjmZ3AXEODnH=sysZxE%H&bN&d;`QznUbg
>>> ztB~(5TVBt`fE18Y=9btAieQFdwQA3J<GUg10ptUwzNZ6mD0IaHy|H`rittQqdBpRh
>>> z!)wN~TE0ZNcE&7U6~wiRIA!~mZ at 4x0QYYKYNY(Ikb(F^C4Z9;=1U}Y4hsTchTKcQ|
>>> z at Z#@u`J^saq^ebq8&$p(&QL;!`{doPx|Fq+(wFe8SIO4X&oKMr8#R-!yTuAC0j3=A
>>> zFMzSNzZn1D1(yAyj^kHRT)*_MMngyDX?%E!_#)w-vVR5tx3hn#3LN_9km`lcGuLz)
>>> zDha!&-oC!;K}s0L`~ZNS|4r!ipA}>L%li!9ap}2mH0?|3+#(YoWzWH-Jo2Ptuo5IL
>>> zJgA%`1O^ha`Q%PG(o%a&@68PT(}naxvxd4`LH484Y)Ou5<(SVyD;kuZ#w|7-m#QLW
>>> zY7kqiw;U@{<^E8C`r5bW8^<N2H|%}YL<p;c>Peod#&4?P at AX1dm#LmG33t5bu^e^n
>>> z-Fj`2Y-RC%*cX6lSVoN4o*fpS`_QtmM-M<E_r}rBs{J at o@>!yq(y|K1iDfM<9fYrn
>>> zOd&wxgi*zbK^UUkmZ?uuWn#~66|Z<q%NLzw)U94qwn0ifQtZ0Ref|+o*xWGh6N6j0
>>> zFMBrBOYqx4XKSJz>NTaCuAc}wd0Wacgy&Zi=701w3PF;-ad<Kv&Hs9E-S at ElLhT69
>>> zdX!}!12k{eJR9RPnw<+aEM^=e0`;O-zj0_)-Zo~IKV%=QG-FzYuoYOB08;np9^DnB
>>> zTi*kfrx}V0`yKc+UG+y95))L01=vANcc_V=c18qZi8-y9sgI!--{BVy1ZOipvlNLL
>>> z%!dv>EdZgj%}fcQFV6p&%?Ab$wOh_KjmEn9yyxFIGE~m9y<vk)?giYW^U63#_gVVs
>>> z(Wmfqw?f>+W7hmTNScYNbEXN_GB<$>MKTvjJ<RYakliZ+*}V(r0o0B_9NI}mz$cyP
>>> zqO2hNm;fHU at vFr5Q<t&5fZQF09fVIN^g6Nioyd4L2}O4+$9+^i0pQYT0Pq1f0GmbC
>>> z0We<(et8b0DKDxQ05D-Ckj^KSlN_wf+$!}sO%iL)LBp-Yu#yzu82oy>_O$Engq;r4
>>> z9oL1k15AWm+(hsCPhyjYW7>vK1Tt5sjn#wVWXZZ*(;D at I?OzoT+a21YOA8Ww+^?$b
>>> z61<!(dq!%VixWNdvf#oRTms at c@^b;W4|oON?k=LRR>+(<;<NSc;)e>|6WEvrt!F}C
>>> zGcr`pDdQfJ+W5=@Ryq|j at e9sWb^8fb=XWiNnC`=LW1TUH&$Jc$#h}`)==qPLq^Qd0
>>> zBd~XvhuC#~x7~5V4u at 8huYS3b-52C5L+NeYBYKScfacgz!$wLmhjKM&@S0#sdK;!@
>>> z&MzvhQJ)va_NXVyTzOSyY%?NJ<{J(k2j|n at L(~5Dn$+!+!|nPfw{CsMv30$CW4eDR
>>> z;|RJ({SZ|o&ur3sw#RxO^~%2IvI;#<j!qHt87&3_@?o^IbI#92v=5?>r*A&>e)<Ib
>>> z{Omj1nc*4f&Z`b`GuD$!M?Q4$#*xHPFm*Gz#->%RWh4<LFe#=;ULQlk at Jz3ijR$6a
>>> zd6e^Yu5B#R7h`<+6xXHo1{-#7({OJ}ES2<Bg*&n#Jdi`P85zdZUuUY3oIb;9x7b`R
>>> z3&=mH at L6x|!0y at 9yTf;^UCxKF7{&22q5G1A#N(wn?4pis&fD-FSmcRZG^4h3`C!ME
>>> zIe{p1#m^v*I0;>J$>7y*b4ltxq3a;=W9SliPDAQ1{`N5b%<o_AJpV(hjebJw{*Lbb
>>> zF9RMk2fC0S&K=K^It;tGWi!w13-{jIcC^1xIw_V)$=&-9x{o$WGV=cf>oh8CHA*QH
>>> zN}08P760rOAEpwMZn2O8UuZ?l$D<A*-lk3-C=f~T-Inug>U~z{7$kfwb5d$RI_&u=
>>> zP?#zHZ@@Ce)*BH$#rlN}g3Io&C{7``3cqY|TB)TXf#`w<J>m&8a!9ssq1}CpC`H?I
>>> z$BDygr%c2txXE+qRz$%n=!HB{TOFm{@Myyf)wFX|RL(*%L%Aa!BU4<mtlsm0Dz`nc
>>> zJ at LFTpSM*JeiBl6uGSr%G=plNU>-%z0(9l9Cvl#=5jfmD2x2^BKTj72IbgExPO2#=
>>> zjo3D{^BV`kmWoA!W6UmaJOXk(k<3rCtLDdib0Hlp`TISvwhsm4sry5j2Y~pT0}G3v
>>> zjQBp^s})d0E#?_N6qAJ^!6_RkLyK$#h6ZmHBiu=~FY8$XNa^Md1_JuD>w7Xk;5xnr
>>> zL%oLm%wRv9uN`9YY5<|sIwcU#6MEUe!T8S&{F|SE17U-mdhNYm%>^X&8s_uT1Y$jV
>>> zS3;QR<YO!=7DEl{#nTw at I*76%|NA%T1}rHp^?=7j@~R=GEyvu<YFaqV#6!T-vnNVa
>>> z%h{PzTO7M$WQTocx<uffWs&!Pw%NuMqMC2E-Ox&OI(CKnv<Y|W6H|_egP9i!a|ajd
>>> zZe6b|KeZzNC5yRjO|QvP#j$K?(9~o>O9QsSX;IGMk;y_R%Zy3)Q)Pvt5q_sDAEb~q
>>> zdLFpHtiE}s?rP3O&VJ42tGASihkfioT}Jg#uLu!eJCl9LzM);I4zuG-QM*jtwyD?e
>>> zmHT(Ed$s{6nLY?cMvL}L!eRqoGzt!r;v9ib)aq|-R&D07J?r>l3u9<3e^psB_?aF`
>>> zLitRe_MO=5uf2^ST`x)^L at td4Z0J1bs<}3W<1pWv2JZCp`Id{3gGC&oBb9=yipvQP
>>> z8PqO^8zBcuINbRUn;l&w<+vsxXEfKWzKnU~_V(k};~AS*)2B3!to>EZ#jh(dNYuYp
>>> zVl4i*Rbr$(q2dR=aR|r$?Lh2<5c4(I6xcfWaQrL+tmD+dQt25#2vna9H4Lr5D?vVc
>>> z-ZBP~B_TrPOrV`M_;7>?$Wz-~MkhekM-ZcBOhDs$y#>$4C^8OWZ{vlb;b-s#E3_ok
>>> zyM73Gv+=B0WGSkGEXNGl0}2<8LAqYRW8Euk4Wfqjr_-P)vVt-EuZ-3|jB}3uiy}3;
>>> z$ghjqc2Y#xnt(2_7F;I{Ql$bvRNMzzo`a?gzt^P`2rU}_qDU<X at h{5SmS9`)qgN4R
>>> zM4RL^dI!j8k#H<uh;9VSncDa+JvH}xm3&O!Nth%y{d7kr!W$AUE%KLAEo76hHBT-S
>>> zj&!yuorevcIVWpW>?WvQlsX2IyQ&=vsm-Bm?~F0S=9Y<I+xQ*@E6#ecofV%{HPWZz
>>> z2Qlu?Wpn0J%&tWH9C<BHnd`%=RLOwdS-D~lY18vu3!>6PSfI1uS7FUGvGI4yG=q~D
>>> zBH1eMMnYIh+h6Q^z=L$HU$0;r^#bd&SRnd*BPKk5o5AAD>Q}F44H|LdkH_lT4QA;$
>>> zty1QsSI>$HE4hOAj&dpW&MU8g2BjKnFV{E&ZLQS+EygfnFkIJ<k?rMX{ZaOV at XDi{
>>> z>rpxPtnO?QI at G-UzV@zLqYpbr_37%ZFN7?Gmx^kbaVJu~m<Ta#{(J%E6_SZ*rJ%Q8
>>> z9-lv5kvbg>n#JoDyM4aBrdCYT8=fwr){V~?;$`wvbw-eUpt<=_u=RF|K;EaEYx5U7
>>> zqRftMCVFoFXh-?#l=K at DWo^VfR=22b{;4DtHSTpsb#H@|y5(8(B_}3eqS8`7e=WSR
>>> zYR-=P$vo=+#&%_}_f*NT(Tx;w_8u`6Hq;1$GO$7Z>Cb}=mil9ZMUb|S;3t?6d;t-!
>>> zmNcVDxPzN=V+&=hpn=xE3K>Lr>pnpb;J-1w51m6n)-j)X=0Df}ujik#M^ov at UD)wy
>>> z|12J|(QRs*5{DKM)xP?}{b^*H4Fy+-VyIE|Z2os(`W|K_RG`ucoJ_<U^1z6!ZPiD6
>>> zU*$cB!40rzB;&o)i7L^NRFQ at pi@8^<4Oztfms7pE10h8^yp6{AEZB#h?--1#>SY0M
>>> z%H|t~Ad{~nufjOFzjZ_|`2A32Rm85i6W1jJT>^J!oEn$indCvihFrS5BtA1(B at U0X
>>> zIc#htO&PNvrzIJNw9K41{`7VW{mWZG!hVZ6?jvs**-5`chb{KuZ{mlskVu}N6Iptm
>>> z=z)h;Fx$NJ6mFi-v at xI1J8leD+E+Iu`KIu)iwp%Wc}vA!@hhSLQ}>L`&;FdWj^bpg
>>> zBbHDWVm2M<+1%|G$wyn}$=TPK<LET`7IiF^6TXoZm%0Q2l5~PllFq?asZM;kWQ&{@
>>> z8;Oc!9ZHrs;?|ATuRC at B@a|F0#`ZMaq#b0O at d6-PoBvD{^!+{miG&Eke<Q{HRB%xd
>>> zTlv$-zo7)fVV^LE!O0nYh33ksDDAu6b7o4W2Oi#ban+aVolHN~8ZQU!fIs)9^W^l^
>>> zmzBs!j#=umbMn{kp)}^YmLy3UNv;MW%*V1q^{4&U^9I{n*b%O>`-=zzP;*jQ#peEv
>>> z2x;;u()(2?cY-zD_lC0f{q(xPCo^VRaDleIehGtwTODfoayCyQBbT!`?Je<HWb86V
>>> z-Lk;v-Z{3qC;IYu8PV(<?SlzQ8fkc4w7v5H&ARA-GXEP-)$trO9Qs+7Y9bsR{EI<I
>>> z)zy?4o((wCY~%=vCT0WG0T08Ew$PaSYf=O)g!)r<_XllfhAr}qquk_sy((s~0>m6{
>>> zb$~YUgB-0*Cxco3y98;YtCY@;r^Cj|b~QV6CG%avdv)Aiy8!CgbHl6aXfM!fGl#4X
>>> zy5=A1s{n;hJ+Zs%4(~p6+o&!xb at B)^#kfz~^6NedXR2sFG?D`TD>b@%Zfv~A<nmHa
>>> z9oaB)?ZaJo?qytf%26m!h>+|3rgeu$>B`b^fiz-k6BT~37N;$~`2&Eu+)X|R-*Y*7
>>> zK$XrzE77I6>ruCg3 at J_t>lMFgcy>!WFJ5p=vUGUdPfiu_Ie*4Meb(=DHb<1xvp3~i
>>> zjX0}wsiRyzi}6cWWNk-W`IL8sD*md>`t2{Z#QdPYb=r95l?)s-Whg{)A{^B7J;1h}
>>> z`Um>3j~1X0TkHHhV&w%}jfY66c$GJV)n*h4GmZgFDuZ at 8KqpSrTDkZ~PyhSt|0&4)
>>> zw-;n4Ii%lJyMAL$((-vTm#w;Jf+WDzPpf`--H{TZYwWLifW5M~#E<dx%1>4)H--D>
>>> z=3IWvwCyf^WvZ`*3v9k>VdptvQEZ)pY<}z%TmKeDGkrKfP2NtJ=VmQmJVSc_;e~f9
>>> zo1W)9x1oP^q=sMAyVPtxJF8|^{;}E?bBi>a!%mF{E6%<-cX)Vl#wtB2B_eg7UHo8@
>>> zlup)&?Gf!y1G_T)!a`h>`Jb&LJ_$69P8yKOQb`h>TA0+;*p>O}=<k+hJ6ycPo4|7D
>>> zyvVibi;6|=5mNK`pwOJ`-s|H*mufYq`;WXy+Mry$Yr%=eVCAFNoFXGv;uhUS+_>-g
>>> zX+~LJe~<NOjVAftg38RSpwBKU!tDDY0p3EmKxjC5kiV!4py~NI!I7QTyLxWkN_ir5
>>> zIV!*8DxLSBH&~^nO|D61n at uc~i{?*RAzI;^NLzK0BGE>fJ$PL=$*D31rsiP48iNgu
>>> z7dK4cXEbDaUZsk@*$i)s!gIw=Eb^6HG1#wdxtUlhG%bC?MdIY{;Xv%ikGPN9SxQU}
>>> zit6AIRtQ_rD|Y-^X+<S at EUPRgKknJyOJkCvc4b9AEWcz1OlKb;yI>y>WOiPTo7~8r
>>> zo>n at aO6GvoRN-(_VXq3Z15)*u!%%~ftVdC%cNS*VOe>OiuGSw0$Y;e;%`Z}nYkx8J
>>> zpS0uu&9q}U<~`CUD*L^wP}+*LjKPDtw`ZR8y$!cvY6+>7lgfN)hr<bu3rOCfr*oF;
>>> z^EMk>8xeBfzgF){(Gnt|cH{tS=lyQA-b=G&q%OpPPdCiB3)<z>es+It6hh9NI$u9{
>>> zBueDbT{kSQ(oewY`3ZmIj2;JhMer at oW1_=}!oTIc7zF8CtptulClR%tW2yXT$NG_H
>>> zx|6ICd-b9@^-UD_Hv<`MK6I8$V~u^DVLlzXjcUjv=qYO*Jk=BIcXt2T4 at t|j at mACr
>>> zaauuStDo`k&70|$N|fnn<7K&^ugv$hO_MT9n at f1-_Cjz94wiFBGskz`4rl!~O{bG$
>>> znlkH~7I!QrjTet7^DkZWfk)WvX_0|HMEyz~B6;XnqXbK15U~Leh=how_WaO{0GU&i
>>> zx?ldxuLvP*o8PiYzY{U(Ai at NBsV;mSUVIg|0qUo~NvOw#fb<xJuK1$@{nHbp<8Nfg
>>> zzKGbZ<Z7eG+<Zb`hb=bxG^f5%dF?VDbv)Noe<Anje4`>@)A^mhym+jsL9KG8tHSuU
>>> z$)J7`m!B_%+sLc^hRSAWd1iF+hT(lP)*9m1Q=4_q4Tv^AWO|9eeJn)Zsx0>MEgv<M
>>> z9SL$#YAg*eWEk_*K2HOZRvReVXtJf8t@*~`5J_l7Jtw(kX{P5vH|)fOE at nT#%bi(*
>>> zYQ;`0X6R4YVO>!=RKq%Jch_qdeB5y@^PDs7YNM#iTX-VMnThD^J4bBcB|tB5FPq$?
>>> zkRE6W5^7z0jg%SO<$6iO*@s`-G(3yj1x~sRRyft}6d_`g0xBJ=+v>RAwxWX{WO-p5
>>> zo~`g3WPbW6HHCTz|IPQs at Cd?hNBkhpTJ!!Fop$`~GH{*FENc<j0E~Vgfg(MkjR0;0
>>> zF?jKu=`WnYsGeU8T640-vDCQnh}i<xLL4=fmI}Vt=)%zUSbT;)EBcSV!|$*2^I_}R
>>> z^VH6wzx at 8Va+xp|-1sw})8aRoT$<;0rkPIxwVa>nKz|K(TVBqkkzaB-si6M&SLs~V
>>> z#64(KA7)A`pgYwfY1`VD<Ji%SAOpNSG4y8&2H+Cx{-K3X%%dSIC7|ly5yM=7S5jeP
>>> zKnh~66-Yt6r6w+SKuZ%2D8e4b&|S7M75{K(K|YwelMNQ`L_Lr#0(XXU0y*5L(O}Y}
>>> z(dKghLN9^|5EAYY))qiLdHuPOxub&!vFh+k6P~CSUU$G!1l3*l*scgeavWQWADa0B
>>> zaJU!#7UF(I;hu+$l-08J+#aYGHBUd`yPr6ay(0bQ4I-VaP&yjfG~<Jd3Xgl&nC at l&
>>> zkZJN-0b4QbODY5Mq0^ejuhKAMC^&Vd&fu(l?Gv`H-%BTq`zIFXJ4-21yHt1gczoTu
>>> z2nUYm0A7o6plsjLwvIW{Y1(KlK`D&1{GgOnRn#_Br5uCfo)=lf1!W}_sS&2bB=5iW
>>> z(nA|AE!Lus=ma4L?SR<CVC76Lz5N64p)YDqi>P;1(oy!o<Ejjn%q*VEac-|htm3k_
>>> zp6%R at PBxmt9bg;id}c;hectb!r at dmwX_~&ZQ}TfK<N8(~u7a`ky8gLB1Mm;ZNg|(H
>>> zQ;poyUrJ3O^U}Po{0nK2ze|Ro_Obh$0T<YlqWG|dGvhLl>d<SiD#raLHNQ|WL=zw(
>>> zs^wS`Ns_$K`&53w)13f%83nXaac)5Ijf(z}qCd~RVZR{KF9m&1wnxQ%&&E5ZZ1 at dL
>>> zx2gd5<R|7X7 at 86dW^25K$Xeexw6&J!w}8uR1eYO#%e(+ny-N-J{9~yg at ScAMgFx-4
>>> zQ2PhV^MmO-1Wg?qFtnmJ1*cnW`A${DqsT+7z7lHOD0-O)V<d?K5~u*cf7_8g0l#p1
>>> ze&q=L)7Zbj`?moVfKTV}CEWLAg^!Mw+`HLjQE+5%Fbc6Bp6G{y%TcxCULjN|YD$sc
>>> zDVQn;Qj^8s?)wp3UHGnRupUu at tPbE%@$*dM#UhJqt#z#8YAbKSH~XQ<h(~#s(u<#v
>>> zHpxt#n-&mxIEqN=(c5}nktq2I_hIIp?ipS^q+Jha8SyAFVd1tz*Oqdb&u6ErBcu5*
>>> z-`>#3t*8hg_e0nE0eW-!_x3)1bJSbMR at 2AVjsjgeCFO7(b!}#LEfZCFbF9HNV7=hx
>>> zqyeWvxzqt(f0;(6{$-q#OumuKqJZt)7m$Fjt>V~7s#n3hm;H9(J2s<)AoSjXGD|*X
>>> z!Ko*WQ>aZ|UkHo~)n}g(_8rqQoU;rLQ{PK1H>AdpWI`c9uf(OPBIUk5#GH0<4%&7d
>>> z$F1R;^)8Du=B+KfZrP58`STJT`7B+uNc^?VnbvdxOgd36<JOtlMfZ%D&aCFSJI9 at z
>>> zjV^_?DRST|2Fmk+z?^9%mA8%Ir#ut|f&4``E&<)+S&nclZF9pa;u~;ZsDajnH~MDG
>>> zi@=*-D&4}q?}-emlQt+fRUcAerKu`M)H05bcA2v9oXaJ|&n~ZHTW%lbw0$v=xyrvH
>>> z_n^dk+j<7I)^rp*>zPBv)<K04IEPnGWrJB)*5BKgq}#O=)sScZz-Z1!(*?D-!p~Sk
>>> zY&mw0I1npdx*u;%3<1SfFJ4JpE$K)5F|}%4V@(RqD_9+9YP#L at a>=7AUhMgm$ZadR
>>> zlT`D at 0?dZv^A^{S^RGVcWi|@Ti&HlJg=N!4L@>6^K}%(9JfPkn**sR8Lm4h!r`?1W
>>> zEZ!AQhxfku>(oPgxbO2^7sB=>rGp%C7YjLReJs>$T#^a0-=+ktv`^2w-Hj_#)Wava
>>> zog<b4+@@A~o#^ftW+$FJLAAhZa~<JZ{QSwtN3x=6!pMgQozt##Zphnl8j`?GUt7P$
>>> zK}2S~!Ha;crv!05s>kA2_*1)Q77(7~pfqa{Ua=A+Spw_}OSLQ8z at q<qA;K??*A~8r
>>> zR&1R<f8o$lUSflddeI~A?bpAAQOt}?wa`3%1zLe#dEzT(N_KXlq9c+WcwD-l6NRVQ
>>> zK>&(-lCb&S$H<S1ox+Urx>!*9lolDY{bIpUm(0|t#$H!cn^LIafjiJ6ws_ag+lQPL
>>> zbwVF%rKsk#(6<A1IuErg;#@7BGRx`(ij*o<P92!l760<gp>jf#UCun(Y*j6zAzrt-
>>> z at +lvW>*K>(Zq}#c4>fh3;+XJswS0N5Z7cVSwB2Ga(8jc@=Hvui3l-}ei*Bd)o);sq
>>> ztnt`xh|y1vdlzr~zB24-D2MA?ckU2I9C0~S`dvA>cMfxkVBPOAkBX>VI4PMgzQ2mV
>>> z3cm5Oij`GyYJWSqmiX)l@|x3gfBXyQwkk|;{uJqo#u<`7Au(&I11mD#d3!b57v?zE
>>> zI#)WE+CA8;#P~#K5g%UKXTQ#^<I5t>D&KN1J!E)k6R)Uim|G{-e98CR$_s*J&)lWs
>>> zW at 6miZ1~T|DcW*g$JHTzL%C*EoeDE0!G5F6G9d<hvSfNH8P8|6 at OOMD2>u^@==b*3
>>> z|5JqBo>}D|(q8{X*lqa>VRs9<7W?~zU8BDfb`_XGbkm(Vc3-fLbM~UbV|UIe)%5Pl
>>> zUZ&GuLddIb=Tk}-ox=kQ4fd)Fy-~5_{W!9S3uf<Ch*Fq+*8A?rW%4Q9N7&A(q?`BC
>>> zl3hFV^h8RK4frIPw`swKNkWbDsWFk&qd^9zSf_9wj+YCP`?F)2JuFyxo1d4pXh)67
>>> zCApke6?9*u{VhGzSH0Eoh2ABIe^avWiMyvHRRh7!orlu4z|C#j0NhFS at lrQJE@$9J
>>> zd%-rDMeWY<7(!Mpy90Ig%x5UubCKTjjl&mf at 2A2mH2fvDdSYo6SI%5_RlecyySt at p
>>> zqDRy=PGqddZ(Hz9phP%*#r5i~2vB=SECJmh-*5 at pJ^kKw1`jTC<K~T60#)U~N9`y^
>>> zlW&=NJ?g@!3xci<u3DU`xasLsr{`bXzG!wQHSa7p8Oj2oB9T03U?0GJ!FGM6Y=^pm
>>> zeWi;zf0hPZjw0p{5s)>NJfB_e`k2mAuYOGuxTAmGN7zvwldc}0dQUHJ)bHINfug2O
>>> z at Di0ZAW*2JCZr8d=r-b+7v{Di&Y&!MY7yj%_-z&ra5B=V@`%A^`e6B0hqV(?2FOA&
>>> zHF?;KHDX(<*1<X at CXQmFDkhaBXh+SE8;xRg=uqs3^BIlP(6h!VZ7nj+wU at rw9m00;
>>> zEuaZ~<@*a8TpMZJZ|oM{$UzrF(3eOXKw;)T>$m`KFdDMiAW;J9eyo{t+D6G&JNI3L
>>> z%IM)8a+4bVR;YGmfoHei%<arbmT#@&XH9;n<1IAxU0i1wdHv7invUv9CKYafqI;l@
>>> z-1`Dn3-nf{t`O$Bh{(U&y&2HAn8zd?x`pLg3yN9z{?hqkA`w!d{4JYsam1M>M*6R8
>>> z0+SPz1Wr(az=-WQ2%gh{3f?%3pIOi3Bruh<s+}2d1&AdZgwHs<k^k2?09^`j*Z#lz
>>> zj-c9gI740V>7d_!O7z9pK$e_N=@U_I6^RGX_KBVu4ZmE*HNO*2NQhb3h=|JZwC5(D
>>> zA{DdOozxL1?r-N>w%s11Rmwk1Iku7XrnzvWGOyAk<AZC2C8bo&N8i+=Y}p*!)?us6
>>> zy?fzk56<VNGNpWXw$$kMeldq4<}@T(%(uMe^#+<70f$_Gq_2w7BTs64#^T}mrj6Oi
>>> z5PX3EmY8TjKRSZr`J!<Zx>e^LCos$vFbsL|uelTvmZ7GJ?hK1c+o3IL7iNDCxCi%C
>>> zJxNe7g3lcX>UxczpX(`{Qhk3lEHNh|=eC?ycp1Mk_ktqh6xnu#PPHA;UEioj4R=u&
>>> z^}?;W7B!{g5Vz&sfM`F>R+(nkAio-pCe-v_IbFnmhF?M`_xWesA|m;?9OiXzf~pI(
>>> zDbpz8QDs`0(-3|TeOKSI?Gb5yt5>LA#LQ{R)(5#3P3%0UU8ki!QMm)cPR&?txD7pW
>>> znjbmdWTle2EZBC$RByD<$oDy;b|KXb@<JP%YFI{vV7?z3-Ey9XHHW?^mEac}XOo$k
>>> z{X>KBn4PC?pO;o^Wf5umrT7Yjv~0j=^gn#w$cn4!K<28_YVermj}Mh?iqhBr`u$Ad
>>> zKR)EXb6;k^Uz$hSpj*o!x3ZE at rhKxwwrei+c`aS743=c^g-X<*$6nD_u9qpk at Jf?s
>>> z!9&h!_co<wBwWAVPlsW{H0xjsu-oVnaqB2bVX9|1KTj3czov+1nMulYN at s7&D34jn
>>> zWFKXNS{@$1EooK`gKH}=Bt*z(AzJ~JAS@@06zk_#TO~e_G+XIJ at g(i6LkRfkQPZIj
>>> znBX*MH^1}7IsfOjk5sgFEEaKJRta11#u47)Ldc!hn}fv88;gbK#!Y^vtqOWQIm7uN
>>> zNrX$?@r|yPnmD?oj};+RwaP6nDryU4kuj)-=jXL0_eD9#P#Pe`!>I+ft~SR<?#*k+
>>> zjv2Q^Wd~?0H>^L(oYc^;!ln+9k at Fjy{9pN<q?{5eIpv&jYCmjHBK<L1#8#31CH+#4
>>> zYw|_p(h at wzZ-OE2C;NmrF>6fJv6wmIoHPCY&dpOoF3lYe4y5_yoR&}@UTyVva=x)`
>>> zE#Fo*RFzAWCApW!HLAM at jWc9u1v=;)B7Tq+Fju$0o2ff at 5AE%g=hAOf^w;7Smg86S
>>> zKd+^$y?AuNkj>*sEajT0aTaXk6_odW+5et<O_jC{JPwO`a<d1oy4aKC&77g{XT7Ns
>>> zX{8)p*+TJua3AKHdwsI3Em1h{0>-&CapyqFk<8UAsJ4#B?K^}niQSeVv(>6kC_hgu
>>> zjK>qMK?>BwI2~BRiQ at JY<ai-8u_yxk?mBD&=A=^I*EKinmcDVQ0iHSP<IY)IN?#)h
>>> zKb!yZdfe(KtO(V*?-0VcsLd``am|&t at IjN4Yt)`usA)h5vyoldWmHcJZ#{Oiy3ACS
>>> zJo#2SD=yEh<ZEx9O(JYCL}PNYcMK8 at Z1sn4v2SmtsLol-Y2s0l%l*6R+MDvLK4sUK
>>> zYkPYxYb_tRAJa5Ek$$3T6ZI&=hbcqpj?9=ER4qdWu at BzabYiH4sq+#&x2y52Az{bO
>>> z#*^k%ZJ(G|h|o5(-0laYo7`r_ZuetbE{51SCz~iwBTle7xSn5;cQHuS*O|Z#l(G)R
>>> z*<TX%S5#FqmKa^8<+jC#JXBWwimHkGu?i>qmu0mzw0^8GrSFSL<KzFSW%<OLaInzQ
>>> zRJ69p-s-^i{N1k}G^w3h$!P@*z6CzsNGt2{(<QQm`{Wl}{UN>sc!LizBtkf<1Y1K`
>>> zd%Z+JY;9RESX?2|_s!n_KkU7CSX14$J_>>&prF#FM5TjN=`ErkARr*1ptLB6NS6)*
>>> ziGqM45b26Qq)9hQ at 1a)#si8v%y(ZK^ig)>a`|NXe-{;=nJ@@``9-s9*WGxq2%r)nj
>>> zW4z-X?=UqCi at EM7%)d+(6$bZx&Th3-NAh)i)vVc9Hwb}uxjnNh{mu at dGd+J#OG+K8
>>> z?=f4E+s?=w4k~?;gPG*c*0_ehSNmYhQuw$h at CmKav&OwUxweNhKve-fvN^eLE3)nx
>>> z-Lf^JmHD;CRl-NSjxjzW%IATPs}sJ#@zzA_r#}8 at oztNLu6zs20_j)d42>*Epx3*(
>>> zA8b<x%go*cz&?Ug{3qXvIaF;w-FtN}v#thZPPqjXUo->}2DD}3I1w1$XlN=xA5*Qn
>>> za%fD_!P~VpoEQ9pIP*biDq}H$8B$MAQtyR6K1J?XenEZt<EK@`E>N(+N{-Xu?80py
>>> z at Zz2z0-m@6i-^C_>HOEriCe6!K*HVe(Roq6f<W~6GYx9=_q)fMkmVm_)8?xz`RN_!
>>> zT}6c`uAay~01{lWR_N&txhlzY$~iYijk-gg=Z>rK%a`Ui at Q^CgF!<_K!^^{ojShHZ
>>> zEAyZB`#;CI?hiOC0S6AijIYBdbDKW^&Tr%e!07`-7#Ea&5i3VP0M_fiA^IzCodW>>
>>> zKwNV9ud~#Dk+=Sn5cc2ATMub_j3zkL|E>rK$VB~fdE#H!BMl=~O?Z|gL#!t)S1EGp
>>> z?|pQ3dH~f+fLH19lS-4=PZo)*zPKI)mBFLi0p|3l{bfpm?tdj#!lJ?Ee{`+{<$`gy
>>> z;YX4%mU`G%0QCDMC}f^-jK=DaSj54&dJQ2g<pnV6#~Q$S)#r!E8Gmky*13Jy2eKjt
>>> z`5(1Dj}uG)iYgMRvG=e2t(4Z#>mZ at ukz>RgK<MY}pCp8$f0qF~W+zuoRgy03&ckv^
>>> z`hS4O`oVu&^0PlbQSq1RLJ$9ox==sq0{YJgaX;rW9JwP;K0|4_4a1;8jP0-$z&Qd+
>>> zfygv1$RjQz67%kxW5lc39i at B#W1OWV(yY_7+U3~J+^pd*^IfX6j3wODwd+0~Nlr4Z
>>> zCiC9N6<5o$9Q at v?J=D(J(?x8lT!i#9x4Sc;UI9&EQJ at uOt~ajbJ>jo-eo__0-MktM
>>> z8}k8$!Sp$NZy5T<HNu!pz at 5l;2th=r#TR$jfnpB2SzhsxDAlTPYINy(1Vv+Rj%MYy
>>> zwzRshBGh at eLA@vK_QgWBBGBBP2B=+4?c4ZSmDrJiM2d+S3@&=Ks-;{JLUjq>#Y_Jg
>>> zjqTVeWdPd3&Yt^1VTTUzapK$RwC5Qa>ufATLp^AsOWLos&u7POQE%GV=`rz0uc<hs
>>> zjD|T5<X?Q}>wMSep-1A^_pfb5x`#pyfU0%)8gtY0&(ZTRsuhah4=Hn#0eMxQs*<{>
>>> zQ0_uc^`>Q7K22IaFPl)-Kpp<G>DqvnEtV)x8RZirFz4%L%}n;rqax53IBEyJ7nE8g
>>> zwcA%dA?8MHxbXArWXHiCL;0Y?AesgNM}@(skaK(D5;q>w56K6HmDFoD9^Lk|Q(8^9
>>> znw!c3sRINPSsvnt<2;QKclU_3S;xtjup8`Ny2`ybGG`<vA>vyomKBe|q|%LjZt<1d
>>> zNq!Y*kMQ;tL367)p2sZx^6nn}fS(m?;#ioqIy^LTVc@^GPo_0u|7~|GGwXN9jr*66
>>> zm$~w9Y%6AgdBvX`-GswA6YSHq8R+Kyk#cxgdw-Y>&Cuf-ynCw@{nO6ESk{_U*K0%p
>>> zJ^ktf24}JI)j_!2Lfo#eO!1o>J;{3lnaRGft2?D4oqME0T=D^)u<n4 at IS4PoIfQRx
>>> zhSh{I=dVh5(Ra_-RJRso``l&7N8I&Patr1 at NFdj52iajZb(%n at GKRga85YkdQuwPO
>>> zVrxs+-kD8n?A_8acTp6esyAA4{x);>kw?=Bln7QsJm+=9$g{rnO$~U at KA0I#7ripS
>>> z8mvzz`IMaR9UQkk<s7`-f>!!GF#8Fl87aPd4gVweOn_ at zEA|DQ;SpK1d=ph#+47-5
>>> zj50Pui+lE}H at 83UZQ9-4or&ve<0U!<O*d%P=4+%A1Z~Ph+nj}BM?#wWSzd>6idV}e
>>> z_ac56HNwtx&25kMW0J#{Urbt$`}+=Cx9T1_JRMmC7S at pV^ZkODD+=dSXb5)`$%;23
>>> zbM)j!2Xuow4m3EJFS0(;Q`Hivzwi~vX60A?tJwF~^(QH}`kzP7(xjK`IUeLMCHB1H
>>> zNspKZ8rXadCHnXqf%Yy>0EK`)WN3i-3LS~{IYjYb4p-`+gj4?t2nA2BkpP at y87k`6
>>> zTX>A<B6)D|5LpqsKo-r0dMBco1Q5gHSN|#)<aIuZAe?IhyKaXXGAR(2b=|uUE>b>V
>>> zs?XH%0g2Hs1h=15<Au+Wo#ex22G_Z7XJN9WXcaL*Xrhz_`6}7vUz^%Us=xj}V)e~e
>>> zV`WvgqZ1--$a4D8`qAaw|C~s>5cAa5QN4ee at gRpF<At+4C>fPg`t+0}lYh;L5A^=T
>>> zz0I`u?{{F4Lfw3Xu|Rb1!ntS9(R&_5BNFXUgBr9SeetRgqY<a$%P)1Rfufg9Tpnct
>>> zVY1o+jpLq at 3(q-N+H~N}ksukYgicG%7Q!QEUB#zGGtll?&Xcg=cRkyko$5{fm(X)T
>>> zmhXBb+Z0a{t6ditcfjun+u?$VSgQ=sw84y2rO(dl!ee6{-q(-Djt3w at LE>ht7Z~2%
>>> z67v+H4UK&f?4hg0!PZ8b*Bpo1!fP8He#FTonAY;P^}qlY&32ZyC9(e}Rq#bUkt*xA
>>> zNt9hcO+q`W@(@8emP;^xR?8tl269*p(OmA^VDcW&ivZ&*`KLQ%XJ=r<l|f^z<_)Vq
>>> zZm>ty0UOsqcIMl#vFhJ%c>1Sr0iJ>Jo9FL04E*U!;vywEY!{9ZUjnk!f`|F4jQdA_
>>> zoq8BR%cqmEdUPj1S^a6|JL at o3<Lja2!8eJ5B#vrAFVTEe!B63{5&cR`O-#)O)6m7#
>>> z4(3sFhAPTh^(I7};LwuN|CZ$S+25h1#;5(;mo-IEcRPEkqovpwsy!-CT{RKfI4S{{
>>> z7OFI&u@{i(-&nQBytWXZJ#Q^tgWhMQBMU9$(Tc9|YwqM>qbg*3f#!wEw54Y(QqfzO
>>> z!rcwjcj62+=FOA$izeAHAA?*eje(>69rb2L?_0y#RM$0(qo~Ao^4rC<tRzn=Ns1r7
>>> zg0HULb@#aYtHG=B$$(*%l9C9MY&L#nHqt6|<R{gs$AHss>8xU%R(ca-4e`yw9C7ld
>>> z-$bMUOZmC*R5nXmE%S3qRCo9~qH(^#ll+-NvkIta!5rQqnIkGo at ak_ApP$^zT8x=v
>>> z-gkR`<jI^^Gl%)=J4ZsYKZZ@*SJeu{kAe%15L_KRisa(tas%kj#g6`(BZ|W=bov=J
>>> zk6(5%^4y9ADvab+;O_+)S{{<GS6TejP*P=5(z^CcTjl)J`6k+Px0H))RL`}1+ebDo
>>> z(rc9qK7lW;B`ng*3qA=+<&24Fa4fs~Ap(a*BkLuX_J!gi{p at PbAhs2k_5br-|38={
>>> zi+ at b3tUpafK~^it|L*M7$X!qWee$aMaW>nbx|NRyA7eo+<eAxIJv~td%&#o4j+3}w
>>> ziw)0c9RwSFtwn=p=!;LZpK-N*ptuNKzg*Na^%tB1 at y##p&z;b^!DQHFoosj^HNp1F
>>> z_ at 2~8JkG*B>L*osc%nmqTSv16m$kmlyL_>MLS{+kqAw?oHy$uMQC>fMEpS~d%!>5M
>>> z`$Qf8fjfaKCy1V$x=|;?0<<6!PvWqkWPSn?xmJl(VZsOrs)?+au&;~?&=5vI|I!*t
>>> zZ2rJ;;Knp$Ln=>RY0%jhrok;AXxL=Q6T8->27*vBR7%(!rDw`Ht9NSWyha<c>^3R|
>>> zh11Lbpr0y}Ye>R>?oGQHRT at Sc4|xs4nb5zQt>g%M&x36o1rR=A_rm$AV|}9FaTZ_+
>>> zSRLixbwg&}91(x<KXP}a|HS`T`NLuZj|ISYap<C;Q?5YPwJB*!%?}WJb&*HE0GLp@
>>> zYp83r;^yrpe^RV%jIMVa(N=Du37sjvEQHEssV09ADX$g;x(&ShJNc-;$W`TKuR#%5
>>> zJqWLXNjlbvC4ClaD*8Y+>(m4|Y5O%Dn3v>=IA)%Kt^StSiGF|`s>LFrnZMKn_AQ6m
>>> zDh(#}N8J?ruezx}yZ4~q-FpNJYJ<idsJQBd_6ScQ+d%}Os2QUU at EZrEzKBz>Z8EgG
>>> zO~D-boILw78&&eFc<S15V2hsTPb%|Ourh4*cBPiw1p}3aR^q=*yk|Gcv4q~1r3%P+
>>> zx#PFlokijG!7E`?|5U#J2RDEc26IzR1OUq9S(dwex<gffm^UCJs;(aXd>#c9Q(66o
>>> zh$xbM=s~?IP}f=htFj;1%>X6vuQqQHzx?^Ll$PtTmf{8u1d;xC!S8hA&W>t|HY&q?
>>> z%<Ucsr;iN7Qks7+?MLA at C;!}S#HUZ}&qCm{CsJC<sdv;JrvNE~_+xI{thTBc6;JU-
>>> z)YJaZfuP6aM3OFsmLX;SHz{w?*=+OJg?475RJX$OQ^I+)!Av at 8cipl};0dvP*LuBd
>>> zzkY2sNfe7*(`&!q&5FM(e50W5aS at q|^l6P<F~z1n at Us(p$=Diuyc~zwpd=p`D<(GL
>>> z at Fl0ld_H<@c5{~~*H=^C-yuc2x?|)l_Huqw|LM+;*yfp&Tg;3?blms)&7DX&E)G#p
>>> zx=ZNY3ZDeCo^K{urVB)%H2>E8)yRf>(dm4jdmN^{VawxhfO#C}e`8^@QGnU)EbZcT
>>> zur#miHC-)g4^O|xJRm38aUwv_0X9R?DL>o)17_#{#HQ){PXFBVkmrNRw&MazAGL(@
>>> z6vnDoe_%grduR%z8#;=7G6-We9boLFYU*m at YU10Y5;^k>nhlgO?e;=}oxMq|fx!p^
>>> z4?T`(oA#XT9tkqw4As)6lUZH6$rT*cM-AF&e`V*<51=0<$s3z6{46%rAeaXqq&~3p
>>> zpnMXOcwuhQ)z$+(1NPKd+nqAslgS;Ma6A?)4@)dFOEMcMGQ<6rVIp_uL_yx12o;rj
>>> z;ocT?r&R&jH*+9J!@ckbRN`;fav=?}d9i0YCU!R%(qlVi=VXfjnxzebz5gk<_&-8^
>>> zXCBi6A?2It24|c-i~3&)pcV6MUeDWF@|e{Rf4s9hQMYVUKTcy`_2ssf&E3EwL*|KI
>>> ze*89t;jE`5%4Pd(CzHoq50Jd->Y2qO!<;wZlOgMyu=0jTV&zF(83Pz6w(*n7f-r+h
>>> zCxly#Cps*_F8in59K#zb at a7(00+Q$L8s`9rFvMt)G7hE}=u;pJ=>fn;WoO~B&X9X+
>>> zBtk(Gxm1Z^O^0kgz;*2&sy)b6I)0niiCpn(K`-66J=$S56yG;ucG?*zs6#Kn3<=yJ
>>> z2i4k=!Jkok at n}rE-_3R>oLZFG$%LE)uXbk-BYwWb<5z-Sdum!5y7!YJRgEope&3(|
>>> z6;tW2uG8oh^2Dagj5dgqfm(>io8s8y2q0N at 1&10dGkTLG4KKCoRM5=J41MjupJf*o
>>> zAE!jiM&mv)JQ&$}K~|^U!*1u8vs*Iy>5SBI&8`}$U%cfBXTY6SZ9HrQ4GfZ)jS#N#
>>> zwHg<;cKeKfp>F*T`E{-{e(Z|hTzmi+vX1#q<2&usN?(F-W6LoM`^Z%XtkK3H4vmF}
>>> zYqVg`^1J1;`hOjDne3 at 8Q=2P<o$CUNht#FNT0-$qWTCAfPAKP$_3Vm85aNQGICos-
>>> z#MP^4V`1UL(b;PubS57=F5!PbrP6UvuALMX)9vFOT_2|S&l at r0kGxY?kd8(*)6a`3
>>> zfgsKSQx(@L|MA}>i!^na9^9G>QBv+yFA(BXN6|noj=*1dJOyyM*vo%4a at 2qGS@P5m
>>> zPtAU{#|)K at c3yc-cOE$6`e6arHo_V2%IfmNeC~PPC!Rq#IVx;KMp>oY%AKf at VgQJp
>>> z8VdLs1O~zA$Wb#>8!Qqz+TE+D%g?v0CKi+PK8)(ZEgtk3>@@0O|62f<knjO<0Q|h>
>>> zQe548&*OwZ<O1ZkicYba9oCKvB)UHoMAg6 at bO9HX0t@wiC@*?fD5J<4l@{QC9Tb35
>>> zK;HazBTreWOMslN)%5<mOTyZhTYk>wD~L5{XbY5giR)FudafbDuXfL9_c@<9QH0W!
>>> z;@*g25`GhO`>H(RP32dYn(DU_Odq+aYfkI78-e8B1Hn%kbX2qaR+rij{_CEs4xGIj
>>> zsHcq&MINpc$lc3?uUM6ex7ZW>f3&m at Kt^Ui0&BUJ`TDQGN;KzQ%&mUTb)XrYhA6oR
>>> z_LwY;g@;YHrgN~TD7KO{&bhjAZoIvFukTVSHZ+FaaOza|%Sv2wYdRM?=rXqWW{ZZ<
>>> z;Fmq#=gp>UqX_?x0 at 0|0M}0TXgadx)6;#1|WQQ;~&0ng0dwdep(P4Ck9N(5=Iq59j
>>> z5e>Hbc3E=MNU4P<;*PE==lQO7`raU67MzO=8W~aM<YNsYfv)Wu%Hk;LPiFWTpN_26
>>> z=%Y(_iTz7oUvR$A?VuerAA at kAY=QT|@MUZNEZFelJl(4waW!9}-TDPYWWCg at rtot<
>>> z{GNVO;tT9iZ at BKivRAU_4OU@EA;Gwl=cN;s#hcoW5HFXw%%o_{$LAfZ!170a{6NP}
>>> zyO%Lj`^SUk=a+%l_xe9SOkUhldz{Wem-^#`u}RSr9r}w&zODtV;Vr&AKwAzX|6KpZ
>>> zO(3BZ-S#E-%NVK!bz0-1!A*<G$JMb+%v-L8yl?2jJ>OCe^){RA$5O3^MKrsPVCfxM
>>> z$@ZMzgYW4x8+6-13de)`6V=2qM(6w|JD$VBgT%8T>l6EXnW~oDB8Qy|hw6zsCf{%5
>>> z(Z-#Gu2Z at pCBBKcYb~*a<klNK4+tLuPxTb$^%1;>UEIPiJWtnfl%`+sUf+Px{-kn1
>>> z0o3giB=%!iXxZoZyJ^>leQMFWQc{L=Gj1nxX%?;*Fay(+nACPQElX(~@)g%XXWBT?
>>> zz(12eR2B at FnOP;(mbC!8`%$JQg}@nA6u7qPwL(6Za7r+%`7|ge+AcCn?S-gvq2cW1
>>> zUOVefHs--h!wzjeo<Z4i#sQw&`VVbUEa16Ml~>je`fyV(mif+9LP)6q2kjymhTdlu
>>> z8;K#A&u?$m`yKR84E+}GJJ-Pe61L;?YZD+H#yCTyJa%=$=9jFynpq0nE1AC&0NH3{
>>> z2Q#)2X+q$e1iOM>F+G=xF3SRti+AWGbaoIgOzNP5 at ZgftB=)S_@~YqYFGVaBR}clH
>>> zej@?6!Xr(;RG?vlzAs0}J=5AtyVk5GkA1dnAQ_N=ckMSlDkJw8brrR<Qz!`;CU|gF
>>> zsT!yxEjnW;#lkjq9$|e8_p3+hKdhNEy+3DKzyTJPlPT`r>3SuQvMkRy62r3VbE^Cg
>>> z20T&;T~5tg^s4eZ^`zDN$O6&Q+3v3zqmH27<rqV#JfSJ#<`-)ODQ3UNTpuemi+68h
>>> zUM~WcNz8t)`L4R(^Ae~F<$Q;@t(cVJFI at ZqPwone#FD;Z8RS8DrQ1$s2bdADg$LU0
>>> zI6aP~e&HkZyv_!9zyUalBClGpHHZNnT}0V>>u<{{y$*^`rT7pbG$R$3r;kwIDJ{5K
>>> zNly%qy3H2s)rZw at oecZS@(+0;J1gFm(4_Ad<mLoVS@*jYDc?U9$;@m0Yry6|Kd0!P
>>> zdcp5*ktNq;9&cuE%X)0Co at YgCwOlEmuxwY#sFQA{ahF^v*#c{lhYDyj3lqU$f^0dm
>>> z(Gy^SKo_9n$H^avR6#c?XVaD%fxpIs(TjW%%A?%FeA|4!E?C2*S&CS=8%yAbQF6Gc
>>> z`l)vCE#OKlDFAaK9L&jwfbrFX`5`FSx3fQt2ts}>x4MYA#-Jn9T4dvIO7B1(@KKaE
>>> z%y#;^Fo|Wk at thmRfI^p{64pg|(y;!*zUO_{PbwdPpKXUTVp at 0biL*2TViDn&hu$Wq
>>> zjLp!KIbIct+?boGDKpUxHg)LDJBj_X-&m~#ZJ*zuz7*TJdR>{dJmb4*T}8-Rx3lwm
>>> z{_4u4D{(DX!XL1PFue1>6r!!ZjyF2^N`C7DriQG+&QaLMj0y-`@B3j{lc9p`@0j#u
>>> zrG##&9*XvPR!tJ!uB!)pE_>P-en)eS`8nRJ?(NwR0}BO3qx}UMu-8 at Y^r?@?iS|z_
>>> zk^$;cPYpQ!+Tm*~|4 at z~bRN)L_zDSyUV+RI5SY{?phnvJMVESVQilP`^M2gDfR`}=
>>> zA__RB?{P*8?yay;(1ivTXQUk#MemeyX|_Uq^mUH|xXzDpM{!7*w^7Y}Ub+9Qo#!fa
>>> zM-i?oftm~IUuL?5InyEf@!)Hnimof5{J#|7%DO~#PCJ0BiL*@sXzBIvUqz6=Ur+xO
>>> z8^+K(>oLa+RKiJx)$z{5x&2EdSep5`M}v$Dbq`(T*3CYkW^Ah&P at 5O%2EVW_DrB+w
>>> z9{b4U>iG!#{*!Xfjb$p(7o7!l=M?~k+&*x`qdHKaB8wpAOoHT$COLneD@#ZOUFYGO
>>> zWUE5m*mr-AZUgpm7H8PgQCo_pD9vi}7SvSX+LNC>SllvMvd3uqi*qT{Z1282F2!s!
>>> zuW0b#g44q=n_?|G11>*woE;p_#fS`hPjJxS*VD=CK(1p>ZzQ__%W)N!T)4jhA0e2x
>>> z=<P2Q+MxwhbT+{@J$PviZjuTP-n{*)#ywPxE2rc0(<J>cL*%u&Q*qi9VHZ!MuRK)Z
>>> zbyR1tC=0e5QOwKw5aduUgNJcQiO#lM{*46IOGQatz!qip^q+C+{^J^(jnV#-qI&_<
>>> zB97{jF-vE6L4q*>ZGf0ur2UogcCWU;vpX!@)Z~dBFpK4_A4+_QOLnG<4pYy*e=5{o
>>> zUNYKb#K9>n{cmuDw7TECTU<Zqysx12UvrzhimdhB?>PQ$$6LQXzv+j;4dmFXR3jW0
>>> z$WdQlcr0msUuXVQ(x8rlW at i_uI0%e|Gj$0r<n{=IH;5^u2=yLEqV8Sekt4*9DZ#zx
>>> zxQ;j9yxNz!U}c5IGe#4m(X-i3T2gU3-6oc_HKHibWv&VHy<T4xP>AV+G&`02a)}`_
>>> z517&?HkHo)k*EnznhpGc{z4FMi7VcFTzCegcNC>?!89!!KI}D{vHWr at NIdOoX5TCT
>>> zny>(?BPI)zyK#Jp5Q{-xfHhlJmlc~$5H!j0aMkYE$KthpSXGaqdT0ef+br-Fy_-iT
>>> z4JR at dXn8Ef`6 at w}mIu+?(1<H8J$-pDW(vJFr5utQ5xQVjP3ld<ah%0vJ7IP#__|sA
>>> zoKrkU#DlAKDZ(X=xiZKMt}k)dVy(8)!|W_p-aUk}9hN0U%#R&Z_t1RGeEGxJlIL&z
>>> zS^)L>8(;Tt&jFEy4=byQv<}F^hm{(OI at dr=;w7Z97GvG1{9$IbFjUYt?m(2?a;w=*
>>> z_>D2-I}%WyKs!aaSzy&86%k~Lbw6{fW8qD9_|{1h?@dJ8`rfmGI9(nrSC-SU!@7;3
>>> z;*}n}+kW0>;s#|uf8LJZF5cd~zoKnaUqsn=ARywUezEVOm%Tvkt5 at J)vC7b$>xW>M
>>> z<sH^pg3k{?&|_hipu<eLjU0_GToD;VO|vcjq{@FFMLGg3bq>V=Fxcm|BTy@#pHxDK
>>> zpHu=+eV`%lmk2V45a4Yq!FKFHxb=*mR9amqTnvcx0aDD(LClPPOCHcUjt8nd`VpiQ
>>> z$Px(8L<pq31j>&bfkS5jMN(OT4S2ef_<^8G$QY2HuL12 at ef&vv8UuW5;_<*YSk13z
>>> zVTI)@|HqR&`rilnpC1v^IUsg_XxUL<Nk(Gt9x8-rUCXv%Ip5ipe&bv1!|db4N1KqM
>>> z+TY*!yJxa0rdDimxiCAxxzi^#`TMo3&H|X<ksNUFV~m(!O&TzV=!^40!!C8!^Yx)i
>>> z2A227z69T at ypNJh+&2$tU=5Nd1h_5|gc~UraYGxYhsN(;F<euXtD0$9Yp<uXCBidu
>>> z&A+|smcH+fF^PhBC-%cmzFQnqe9p?xF)au~dDL?Fdh|n|55Az9Pm0_#y8oYk&L2rD
>>> z(Hyq-7pVC&a*eN_8T$Yhk)H>hhdD at v%(4omVB0~=W#ZG?nn}YFvBi>I%kgr84{G*o
>>> zou~2{LOiec7u!M3YS#rgwdn>FrjDiZp3&0K`(a|8QUg{{(*)MoD8U@&akYULpBuf$
>>> z?v)rhr|EYgkU5bPUdXa-^BgvpT(F}IiC&WH??&Mw7G7>a$Gb>{`-pCX at ri5tz<d{9
>>> zUVG+ir0Ay^^br!T(=#&16P}H{Dr*y?zvJ+4FBmq&e_3 at 7|GQ%T=U2 at ChsLZM)+A-8
>>> ztC@`TQnSWm&Sq1<E|;M9R%U=~ScprI;Lu_W<br=~dxMa at OW7SY_GeYtkQ1fHJ3P=-
>>> z3jF<#)Wn?Ag{fx(pOoh`9jPn&Xa-HfKFVh`DxVbfx+;5A4Q?uJZ{Vf$&z_=ilz9=P
>>> zFozL)Y1)^|<vF6Jrt{jFgcC~h)Eh4anwPj(ErW`cs8py#oo6$`vu>!BWoFh2+O0h!
>>> zSSa~>nuJ7d#OdSCi5R~`v at Rt@irYN{+{+VXD9`G8t=I5k at 3@dVXyv at mkKB|`d at KC6
>>> zGAGdoXU9KYlvw0aLVoX`V8M72mgj>s1YzgWq$gMNpGr{LmfR)<0EY(;-+$k(YQCBr
>>> zIp<puAL0e!A>9~C8}tZaRsw3+gwH?1T6~O393XZuJ%ehsR>>zX4F~6N$xQ|1 at S06D
>>> zwNZqZ49n-d2NwV2DShN3y+>cFh%Fz8nquSr%H0XZLT(Vynz2Y>RbAo9DRi80#1rB(
>>> zRc`LmL6lG{CRO+`eC2!mit}7_kZhvW=WPmV-hA=?@DC_oTk-e2nt>Pb!xO*K?`^^2
>>> zxQ+vN1r)2A)Vv2)8dg&7?7Uw|>FoHp&|R`Qz3h=zwQA+?QcgE%=UO-~ob6D!g)INh
>>> zl9au9DJ1wCL?_NZp+HYI)dzeDyPYK!_CejqIoW<HE+(JowAJg>AQla!Lqpj=MAw{{
>>> zdKn@!Snp?KYpXfQwqV2YqUij?^XcX572 at Tr<{MS|JBSw^Qc at MZitkbo<u^iKnwn=;
>>> zXb4#X(duo at f8^ZU%ONH{Db%CC`FojNz1Em^0Jh#A^;Yu1rGzbN9SEAVk9<0u at ZNIO
>>> zMsU80tJoeB6TIHt0ro+BdRBI2t$lgHFZw6dlh#taLSbHIbX|*w&(%fnH+Z-8I6hW^
>>> z+2Ux|5_i=??K^5xXc=%=;qI$ICP#%VPKbE8CEUyhpz|sO_x9u8+7C?bh8R8Ca>hq3
>>> zOJwO8jknKUJO0JA&+G`}LT$^8yUV2`4 at X7;+%^wRZ^@am((dL<8tZ=tYp<QA!wg at X
>>> z>PAd{9s?BF9#0>0oT at GxaG(qli=$@}w{2(!9W1N*hF1KK%_BlHHiZ&mj~y-qpCPd|
>>> zV^UWZ6=3^-Z3UjA<Hu|%vIRsihe{0l_yZ?5jq|R*OQ7^WZGB|v>*wx77Q(eP#R;gs
>>> zG3}0DjU+5%7Na7+E?QQqEtdzs#Jo02W;xmZe9nA*N?lv-X`bc-P%n>8^8+x`BQr>n
>>> z>4Ep7K<%AG08ERIpZ$KoO{aQ}4=Z04{`IQ)>4waj(~T42oB4=0b{utGwZAASzeI=r
>>> ze*3-ARm0DUdl}KJ!tU=D4!&?(REfHIj!alBT;?a1FFz+dsq{)&XjNy<>{`vgXRdJ@
>>> z5LEmG;v=0y2VL<w|G5|+7Tp!vJ7$}%4BcAnpX#vLKLQk0U$RfI#^vKfrjA at R!Q(Hz
>>> z`pLfX#~-m at i9%{|)E!vJX_EG?hcq?39{Qkl%t_v%Up at dDvBz<iz|~Y|ADIhLX%2iK
>>> zkcm*g<><Tl)KI*T*dON}B;n}j+38a}$A@|h;JKwKrJo5Z=sVTtqn~Os!@h0(q?!mR
>>> za1NQ9slHq at 3J-4>l)Ce%u{Vg;j>BXscRR5mbmnXa{U*C<F>0B at 544Qs`-a&bUpwoQ
>>> zX^a)Dux%<OC!%Qh!8>EVy--9D6|RX8fRnm`dpeB1r++Fn=SOJwj9|KM!`4!}+IOE#
>>> z2v?Bu1B+YKXXv>2$`6fRjv5JRWTlWn;m^t(_0!LnRjgOez?AWz5Gzm<p?b9IYeTnz
>>> z5(=7KKRQ&2Qufi`(nuS8BH;?^wNALoz%VCwede}Zxt}j~fomT*Bm(v(aVvyG>)2ff
>>> z>Zy^_x#lKn(pe2pGhdv0(L#4LB2Jbv81a6a2EO~Xbht>8HK(n7_{#kp)A7WYw82_7
>>> znen=X(oSpN3B(S>*X at l>tYvjBy!o2H>Ye0x4@^%*IZd4ZtMFGoo1DnheI!9hG0dR~
>>> zM$l=vx_)d0Yn12Z<8Ic-5qJxJha7IEUc09IO~(oMO-&}z+%N4UOajcm<dMo9XPeV&
>>> zdY1dh27GJ)?*bff+FC(P_n4dD4S!WQSt18$fnv>kENSqQ>J>nzTj(Y~9cu{r<@;N~
>>> z*35vj8n7Kl*oS4Hg_{ay`<M=J?Q?+x1cU{D5i{ugMKoZ(uH8mi$pQrIyp1W at 3#eV-
>>> zexc+eIOXyzGwcVLVgRPxA|?OzSA#L=o0PZlFbog)NET(GAa$tqD-eP23j?G~1o%h}
>>> z^&LFVi#sIK01r9 at 9PlpKU&KE^M%f#@Qmsfi4;YYm@%=v@;8z^-lgh*sas<StfK%J@
>>> zzfbY+js*&M*G<yi?~$;1SA4v2L*<&;P>VjW{T&WjDFLk|o%bDnf5(8n=oiMW_?j$2
>>> z52*vhtQ4$D1_}ayk2Qm&Fw6wu?F}-fFz at rorkXzXjVY7){Sk&6%*3R5wHOrz4CIl&
>>> zT~h-K4i=Go8<!j5ZN#*S1yv8Z3{G3VkoASXpJOsK at NQ#0rg(p{tuNv;4{e5>NP%af
>>> zx2KMIP{NIK_rC7gG0T+`4 at tjGRP%VR>QT`|T8KAveEx@~^zWEhHg0&re0H{5!h0?b
>>> znJv1QktSy|KKnX^q(4$OQI?)0&TxSK9`&NU*9;-Exmbm=m+Maqx`&xnQ9M%C7)Pem
>>> z8O)hpMG}h^j?Gsj3p0!I#_uqxn5V4STzHUedk56qV9A?EG>q6*6Yhv>7Tms1I&_aX
>>> z<8G<2%w2!hZ-yIpK756RNoK=&&2BDdw=&?m*Q(_)?3J1F-3_W>@t&+$ZP|J_>O09S
>>> z-wZAu+fFcQ(Wbq at PjX(7U^J9zV>drl;AnB~ts6(=_C`@%IV3qJ*oKidKMMc=-c-fh
>>> z&sP}Fa%3Oj;$64DK3~|zch18s;f#6d$;VI!o1i{yUS?$JU$9O7EiCb$S5yB_{k{_%
>>> zTv4ME3xToqGM2 at wcR#-s@!vESnObe>Pt5A_S*MXGd{NznOeH}u at zM#LM;apsY~*)w
>>> zR}>b|Y0ej!Q;Qxv^H{avQ>E*J4-?Ga2);^jM5Hzd;?5 at ppuAFv<_IkureRo7Gq&~z
>>> zdc`JpZZUB>>S6q*)v-U98tHw+f-~?>%(Nc9QdHWOl91=Qi;(j-Z*1od6T15F_~LPB
>>> zvj(4Z_G4kg{U46dbN93Rljtxu8Cfgh7lb(QNK47?5!DBvRD1+q4_9F4$d8TN9$Gut
>>> z$UX5}xKRGoQTxRAZ%k=&yk#yiFexL8GK`XM9_?Oh4}6fs5hA+x;`x5gm(u2c${+~)
>>> zRmUzb6XA5*+3VEKm4QmG`MQ=?_EY*gN1nP!NV at bL{6w|2cB}6Bqd;@MD+pPK!N-Jc
>>> zJGuU7HG5#dk{6W07DtdaJ{m{2obSI;=w?v5`$*<Dp>b78dq|;?Aoh}4#Y6zDQ<Uyj
>>> z&#H&78lJ^7-B&{TleXZPA#$k%^?G`EJ)}AP)YC6N-oK_IqKD|`Sc$iU&L3S|FGHLX
>>> z0H{%gG<+kAm=Zy*nT}}(=+*9WIzBs&rWw9-I-qWC at bSo=Td3V)2m4fPWb1(U<ue}h
>>> z(!qF}#79r;=z;#Oo6?*{PvA?2;`4Nod6Q4-vjguqd~vouC37zePUX>SY22aiJQebT
>>> zR8x19tr96xDE$vd%Wi13Na at p=^+fV`N6xc}-fCyN4vRf{b5Dd`BdTKdJXXzI-QSw8
>>> z&+_#`ibIcv%%IJE2kvVrgvkyY);LpXne>MJV|C=px~#HzpLlbf*4%!Yz!i<m1}TM}
>>> z`rMnxrZ1FwA5QszrF`Ht-`!^q4Wf=O)_x*fxr>5KD`<o_j5QDf8$5&F!59z*gdn?W
>>> z(?#n33}jr4rsGV<p1l$KJg%;8nn}D7%9$kku+ at Qzfymr^(OHZ2A at Y$GGNO)uK`+<Q
>>> zidpYao%z<ew)2efQ|R$U<-pIt&}hsrM#T?r$oVsL at M-zp$)_ib8bmjACe!4&Y1e9t
>>> zZ-}&aQhdIP at Aj71_suvChknW_hF|?_(B=P?&+9-BBW~)!LS6Q|a~|f>XD{=miON|y
>>> z*qsQJxspnKe`i(m<q<3T at j%pG!P40dekwDQ><_a#yh<B={6sFVZiY&x1h$AyI*hgX
>>> zctAhvVkli~O4tqI+q=5ug|fEaPPZ(A!kjzUe at IJ<*+)s0>t)3R6lXE=xmx}9d7qU!
>>> z(oat&QmoIn8IWK3hf&f$ik|*|a{k1_i*_+GCMFMAt`B`nyQ*y3As_8ww?y+!JkP!}
>>> z at 8Y=@rJ`lVG;a^XGjq8E1Ep2en~`~PN{0^c?%IRU)RUZ_- at 14kADJ<Qs4G3$zc95>
>>> zToz_}sM#N6w!nT_;YFQU$#vDpG&{x at C#@U>zx6<*6Am96x0Ib>5}SBgnIppEW!Nt6
>>> zT at +A~28`k7>;EiEYx3}-g~$nZE{hB`?gUbGv1}dww*7uyf}1l#%+-Z0 at 1IoCpagSu
>>> zk4%1+L>e4Y%ij-FdoN{j3FA!v<Mux8C`~W$TCce#9D0lE*etCgvS3OC9OjF%=jv-R
>>> z5k!IgQeI;+KLAvhLc!`-*WB05FA^(RRj<!~zI70zWk|<1aQZ%eecoQtx0T9m)x?Av
>>> zUM%6{srU=BIQI{qdKADjg!$6MqVR4vsEV)B+_vXSlr`6Wm-eA!dd%H)ho;S=Cj3=g
>>> zd;*o-XYo<N*NRU4aYF*6PiP4X2FvsVI)!}wC;qP**xzI?Qs+yMq%L-9TvtXyoT+Qc
>>> z_j3h9LMcU0s?AO**26vU>JHpi^H;s)qnpM~f9W1<yCZU%if=!c?JMJ<wwHO<YwFHz
>>> zYwtXfVrE49QhdR_oh{sn>ZIj8&gJ4u7XF-U!-?<<CRJs|KpTMnJ5oab_C4Yl)TH=9
>>> z0)BgAHvqRlkTS%5&f;sRoOQN#8hvns+sn1mAzAJ*%W{QRY~!lcgK&)`MrN^nD4R2B
>>> z8m=neD`G$Pz}6X(q)=ZzopX%vG={vUqcE7_G578hj4;xs<V}UW$3$4p5E!$F;4P8C
>>> zxW9VLr+Lx-5O5^Tzr&E at I=kR1!ZzW}IA|BhUr>Xe<sktOhQa{B+lUUYLum=HJgus@
>>> z3VI(GJ$(C8k`-Uw99bL)Hi4dFRXFz!A~BkYk-MLs&^I%=d0~~qP4EHs<V{`LPm(ys
>>> zhanjeR(3-5JhhQKQ?6QuspRE>&v0`wY*3bTQQkoQwtBn)WGHt&*h@=>k?p8vXnm!>
>>> z_{@`!WzS9XKG9A9#j`5XCnf%qrC_c;k6?L9Ig8`_Hjg+r!wc3NESg!P%>6bPV0@`Z
>>> zVfbVW)e7~O at H+8>4^)&!6sOm0vm)wPv=G5 at Z!kmUZKnH{&bOBFU^S?7c=KIX?Q9H(
>>> z>!zr{ruRPj+uJ$hMD3h;tNWW2htN7U?B~%s{k$W at qmqjfdwlN6+}*QkU&YQ`ky)%Y
>>> zAIQ_C6IMg-4iTAxW^s36;g_qshD#B|Q`YD`F@!hSd6{6OTKoYcXjY(`FP}pc9%)!!
>>> zN8JLSk?o_M7gP3yn0UQfY0vWEv8+wIH8~x{R?IfkkhKCd?+V3z%8ZO2Ln=4Y2w!<2
>>> zkckq8YCxwE92#s;bh;w$)Jq@*6k$H00r%rE8*;iBJlWU%qkTC*Kf%PaBNGi*1Vml1
>>> zpQ2EtE3@=C)w7aBbse%sAiB#O>rxW^z$D(!aMD+Ug=JpB;6_<qpGlpi(exU8N<|z`
>>> zN8vNTuPAHdlAAw`1BA^t1}o|w>F(+t0AkzH162vR>2Hcr2rlaZqQlC>5bRVAIrk8N
>>> zPVp=|;H6~B2`J{SVIQX}EfHox(t;2~%{$Bh{=q9#j3EaX at Y}3$YuDEgN at L22@|b#)
>>> zU<b at rSdq<Xlcj at Z#y4gHVg>ydtAA0}(m&Uy=DwB=h>!a;TkAY+>9ry&DcZQS<;*a-
>>> zII}jHPV)ueNtWh@*Lf5X+^q<a-eh;(`jnnK<r<)20qI_r_X{RnZr#tiwKe%?>ak54
>>> za=61*sqp6xQEI|a9|+T$h)w(M#?H-U5!>v|*n1I|Vy>@3B4O+(yZ#B)HgGw(70L1x
>>> z!j#=GAP- at 8;y4a&@eehG_l8^M3q)6_H<v8l=Q)pXB0nU5sN<iPqK3AlQ{(*JdM^zI
>>> zY2{4xu<hrkD+g6LF1(|{mx at 2bzB34@=5zfp?@=yl`*f$tra!T8eB5ce0$dPeiaUHM
>>> zYk0BAuH<(AI%i6Z*t3J--0oDK?4w6)f{p^^Zs^kC!{<O*Zy6=vANp0lIIQ9?2|4qw
>>> zI!%bu2!Pn=sOv77li}|~G%b(8F#fiq=`K+4g_<^BG&F>{9;yNQ^;+%#XyGeM%yqjL
>>> z*K#0yFx)l3>r|NM5wccluiqkyBjnRPo<I_Yqhusz^wzqUx6ZN=fb>ibg0~4^<CtSa
>>> z>2gVW+o&VicnY5-ewGqu^a at 1~Z}^38-~opBMs8gL7LccWofi9(N)Cl%Ib at 0?0ZIZ9
>>> zi6r00!j$unS6CV~NAvn`KdFq;0+5qqZ#gw>b+=<<Mm83CG+%u`st<*3B7I!9DLOwE
>>> z)Qn&DsppP-3`(jWsjNp`(G$t6FI~CuZ<*CaHP?A1(q-JoHa^j`k%t3&Z{HryXjo~n
>>> zbb9 at y3OYtNp-PN4J@D7C%bUDK{`ze-I-zB~lKm}SYaSYK2Q|;yoVGH(qCtZzv2Wg!
>>> zK6#4wwk?eXX$YnBWgX^LL`*EGQKvpRQczTE(Ny95Elqnmy*?RoZO=E;_gTwR;mP9x
>>> z7WTJ-m4U}Y_Lr0-+CBO-%2%(=!{6`EP6{7*<Ipkkh_ma6^M;7xRmIW=PVBiY$FIV<
>>> zGQD^rA4rTFa^30_2t?QU3%9595yEi&xA76Lw)+Y((^`yUGr{S%f)>x*O)C-mx^TXe
>>> zR~&CNkKPC%>iFj#<N|_gu8f%B<O!j|`Q97A5LdaMa~wGO+T$Y-ThUQvW>rWNat%mH
>>> zf=U%%1!>Jmjd?X{FyY-&CyZW~)jqIoD8JSrmDH;iN5!XL at 5bXvkBsZwb?Ik`&evzr
>>> zNn$t%Dz at qCG28q`K0A+ysH2a2Hp<8w_XKvob=bo+q9RA*?%bkq&*^+|UBN=%`t;n|
>>> z0YKF<cenHJI|9FL-D~VOp3R~53@<JO+D67I<P<rXsTii6*h*j9 at re}aC{#U1b&P&n
>>> zxv7pj<1G3J)P_1aZC#hCG&o9ra;9~TswYv6h{nP;6Y(EgAuM1Q5ZhBa<62;LgIg|s
>>> zT&?j<EwyEq<&f!8z9anr;rHFs<7Fx}{Bxb?uWaOq*^uU_JSuYZ;9|BbTiXnRBmDbH
>>> z3`4DOiW at 89_9ikk$T+6WHdmioQ%~C06$QQvGizx~XYG`|D)gvryzJ|~jPcT|%XCsD
>>> zX&;S0)|goJ4d~WdBZ>!Po>pG4R400Gn%rf_gnebwbR%$rlAY2Uwj|2)N!b8w^0#r)
>>> ze`gJY;RI2m4$pfW%@Bs{*eV9O+NlK}>}Gm<-PPIGUjtmSE^baAm}@wz&3{LU<}>&w
>>> zZ43I?dmS7{lDf#rU{@3`P+n2sT1SKJ<!`dMm!9+4 at YpIvqPW$weE7QVx2V!v3h!U#
>>> zzDzBKe$dvxEU>UVG*K&Chh~0nd@#&Avbn3eW3^46@`&8PHKSNjqnfFAo5A8J{-Bt!
>>> zSP(=@PQl_0UpnVN2r-BELRxND4BG}=_I2Inm(9w0WEb7%=hNnGC*%Ef*xsVB%&t%c
>>> zPguLJriN#;2FOpr*WkB}LpLF>!MGhboRL!k0|^7kU}6%VXGH;^SaM7MCCZhCRWcm>
>>> zw4WFHBb^W5b{Mrc%dqO6IX&6tQX^3}Q22)3YWsq|u(IY4crG$5*~11BgS^Q4amjDm
>>> z(%x&SBweX{m&c^#hx><FAN$Peg9`Ph9dePL)oZGzg{#H~09nP9DlhH5ZWESQRyp5^
>>> zi<N_pC!KjH<u-F_kR8!7hz3X3nr7L|CyC!a(0RSrl_WlCw4uLRS0VOA!+*|RO?t(7
>>> zhNOygOc%wmN6)*mFU&lhD33C);5emVq`-AY&At2uzgXkkivZ;E$AeBRpy`K)aLrTB
>>> zz~-*95sPuO)I`Q0u0xzcEP_NG-f;8s{24<<>DEVU0*R^<=!OHd>9J}Xf^G-Of#Lb6
>>> z)O;^r?0r>RuWnnLmub|j*qyf)4aF<Z7ujqAE~-`R|8}p3eRDg7)Iks?x{$O9NFwwp
>>> z;%x4q8k^%>uigRqVNH2ystxC*imDVL$syLB0R2>9sQ66Bld&K{y}N7mPO1`8Ul2=B
>>> zgXSsfk9a0VP*jtaiocRdBDZguNkZAyCYR#^^wV9#Rwe3hDfi!UcG<-vZr}A1b+EaG
>>> z)Y=F#=uZ!FCYlG)6TI*@@8KMx>- at -X=B<@J)s?D9>`@>eF6trF?#QNQNBXO;4>epQ
>>> z-NEU!p&|wexs4ac(R(7>d;?z^+SDtzjqiQ%{r-B2&c-9=InH?pagaq$(oiGmlIutT
>>> zSO_hFh3MR3 at v@ZN4>oBgO&?Ut{S>i~WdA5!n<r-E;Bdnf*WUr62h^Yn;S8kf1Kiiq
>>> zFwEuZYD>GolYO at S7>3CVKbwLUu6|w>^Dg`G21m<lX$-^4j>6*lNqPs9W}C<iGIKkW
>>> z4<}^ZIHrb{{7(L&lI^HGcu<zpy-2%MpKANL+Ws at rFc*E-SS#3rwDT9J==)PikyL>6
>>> z^5 at NC)0NC7kB`s<*FS!eS?`t76Z!OS#T4;Wg9F#kiW`@l9g$~cS~w+bB$s|aA9t3M
>>> zmHGWc8&%WBeV|L(2^ST>$etF-{FHL at V$$46lh!yYlI|vjm0F$c2!)4H7%l@$l~ewi
>>> zhX8ud<V}M=MH#)x)}AXdJ6>d>`L5}-nd3A6&PMh3`^XQ#YMaZM<u({sfHD&-Y3UMm
>>> zi=+e|?O$1iy+bCp;nVL$<jt*Ff9YOs#n#>Ek}kJaH2+Y1WD1Mv*c at Ra1OVNDB?#L;
>>> zscz&pLr84100Roh5QHQJ`KqGk6A8Bz@`Y9G55Y&uR;cv at Q&RsHfOXFUJqvoJNVMeU
>>> z%&&Da`BTmirZNeeRa^a!(;D1w%r4y!S95Bm(!KQfP^i**BSTOmUov;)TuQ>-<U5&>
>>> zVv&F8A0hb&`*^-(jMT<QEDSW3lUfrVZ(D4~HkcHtyAW&p=Kcx#lc^50JWooH7Oall
>>> z*$29nJL+e0ueLt9KcS?iQm<DMb)~l3K#)*6_7q^@+94;*J7&wS&YtU!D%)msEX3d+
>>> z9mr%%^m2aO1UXGXdXsK=EJ#Z0K*hI|COuiI6g3jVA at H2&miBt7aEL at 2>gEWRiRHVJ
>>> zgHmzg6MC`X>VP;uo4vb<i0oKFR%7dkUVsYuFBtoO=Q{K at kUTJ^r<-$A_kl0xqSxjB
>>> zI0IV>C;Pz39q4X6lJuq!Hi<em(GYHh90`8|9c)vQS(qvGBRFECjRMZ7O_XFmhoJYb
>>> zaCV+N?{eH1dvg4h?Ctx)?{l9DYBnMVAK at 71bQgZL>_QM(ufhl;LFa*u6PQ17!FVqU
>>> zs_Z8fnL{0#FQpfAzWGkNv9?KwTfbSd at 1w@|Jo2~U%%VdEW&4hb_-hM4siJ`_a3c{p
>>> zZr3q5K@!JFzJWPlh&{F9)1co%`uv|n((`hviDhG6%%$?pq38QIT9DKJffNQhobT~y
>>> zK*lxy%+dB65svmX9xj-AP3B&hCeXbJwlLfvlpaAjZ=jP)e%=G=Oa5INIF#laeg?3h
>>> zOyLc7Q7c0kA07$niAj>#YO;XYnxTL8<3oF(e>It{B5ng_u=*}5Hs)x}`89sK6?rm9
>>> z24_i#=zt0ilH{|a!s6C$*L_#X_Q;ds4-^res5NWO<>bMqQ2c&UxiG&zM#E9=Qrwf%
>>> zv-(0GFw-X19QtK5W=bb(-{)L{1>{_iv5OBm_3RV#w|SSNMgMyyGD`_*$<9ZJi3U1<
>>> zBTB<^N%P%;)qxzofG&%J8a<i%k;%ZaLEV)Du$~WyAhO)(s&cIF?>+nactUi3tzWP5
>>> z{_KiimG<gd`7KzJ9`w|^)40mEAeInV=~aIqXW0D>5N)8D`whXkCn~=ZWL&U*;en3e
>>> z^pBC0%lswbO7}Q9g+XE7K+2JpLQaj~zlGP{8b?1~w^6Y&1qbM*pl<FtCDzfjbPXn6
>>> zwMzA_AFUV!dhE;&Jm-yQK~CPBGipV$X=bc82v^~@N}n~k7OQDG9vG>^aYY}V9zK4-
>>> zS|$8de&6M4?|Dg0W&TLgS#l{*ssXSSgH99DFtoVeYO<dz)IL%xb`Dfd%!uQ--l{>}
>>> z#FXag$*eBEhd#JSfENYbB8PgfM?<%)Z<_rmf3W9>6jTlvm5;gK!?&O#=a^1ZUaBck
>>> z`$@%S&aK8ID|$Dw9$Pv|>Ibz+o%ZD6V0`3X8oq9LU#~y0Ij1^vGOosH!bVa;wQTdr
>>> z=<IF6P at 6(JJ;8k5ozqEr+G at 3iJ>DaKM$4&Su<p)pgH?B0Pqf{^3Oq))+ at vtv!(AiP
>>> ziR10Y00PGSUpY;mL-)u!)m%a)W($RJwSF9bYgDdlLn=;DWc$oOnOjE0rNk#(JW+T+
>>> z0h+{ec;M}_J*ak<xuW(`|DsKd56^TT*u=wly?2U$I4e%@Fk-eOJLX#4ldM)xEbei2
>>> z50G&4MBsLiFCzql#PN^kyeZ#-z-Xan4 at 3){MggN3T~3f|NAJ7SP4_hdv!0&!b>$m)
>>> zMj{v1h`=pj4 at BlDumcaQQ@9O6P>*X6CIhST33CLPR^y`o%~lGvt8JHi`As_?=fHsF
>>> zta$EDo(r-}tWn<byH!Pg7al(Cu7@~?ba+>S?K+j*n+(OiJKA$OwV5C-)?|Y!413p$
>>> zYJHE2`zIM6U~5YBU)x9eKfW{2#eK at mgqjv8+~--UGdg$=jL}H~U=?f=w<&L&j?5|a
>>> zJ$R4>UT0%>ew%jfu+qE>W4Z1-w2)TG>H5X^;3h)L|1tlNulO2#;%*Z8MT0a8uva7=
>>> zQX-v>^#Y<~#((>E-fZbD*^~rt^RVK54HOaOKi*&L6_Z~TFP2Qr5UKU9v+xCTz#gHF
>>> z^o&}VzW`bG&pkDiu=p)RK5{wtfE(yso=uWIUV|LF)FM|NXsjNm9Q8AS7c9Ye6j?}k
>>> z17%=zBq at zLILk~{z3&6)NPR+dY8r at f=K-uo9>Xl$5M~tl#cJ(2>O~z_!J7G*i}PE%
>>> zT9qk|x2R6^b?Pcnc?O!fAm}w%BRUE8IO1hP at O&CjCyj-Utg at X!1X4~og9?7QZ81<@
>>> zFDEgD`aLt>)7e!fYK at IMA}WR3qQM5G<wF~;b^1QM_4Q>pl(5$qPTspi#mPp@$0=eW
>>> zTC8;r#0fWHc|qzpb at G0HNLjv{q@<j<qd?+BAN!LhBDw-`&bY~g55TY!32lI9b8nUs
>>> z<wSYWKn3fHByj?r7C3GJI{ci at I~4jH`lb8j0x9OeXLv`DMwVefpR%54_6)G&KItN8
>>> z;XdsX>~I7?bH3L3Csq4;)vYTPAxaXqF{kaW=U+Tq at aY*9%?l+qw~WM_52ZWR&aaQ6
>>> zjKeN^Q#f;0Gl+s}>SAuVNSikxR+1jMx`CA>Ntm6NI^iGD0y{6cpT?&Zxn!-;J}?(N
>>> zQ1qfuy;%km;RFQTHbSNN+-9S*{w)R}Ym)|Ox!PduKJj;%_agn1?lQ5y<93dEVKj<D
>>> z7)|n={N*-~%&5*V5 at b4z_U?-xTFx<(-d8rkiRZoH<jdg=;E2-iX4hm|e-w;l1UfF;
>>> z9Y?f-7(6Ap=j!0{jqQ40#H79IKAL-H3EK~uSrA(A5KV#<PX7*m`%TgQ+fBZ{r<qB-
>>> zvLXwqA9yY`#tuA>CEc5YF at fErLIL9k)byU4nADj^Fg#dExtdaukw*w0o#1}_QYici
>>> zbz}f%wc`+DWqRP831tQg!WkggzjnG;-uGl;CIz=a62T?RP1DR+zfG+Gj1h~ClUW0(
>>> z{Kw~E_so*_t!StC$@a at v=?r$VV2vm3(w4`=xfOH5TC#`Z1`hq!chn(_L4ug8%PmE|
>>> zu#er(61lp(G-n2)9P2NaCf5y)qRaaS>&+<)QaBca;pp<><W}`yS>I{L<KM)&Ury04
>>> zMWf`|iZNh<2xx;m9}Q*X1_ELhf7M>Ge1+Q2nQc|6kJ7mW7{C)Q)Kiha0YeOh_G#(5
>>> z^0#sIyLuYokkKd?0M at m`EH_Do+Hm4?TMkAg*s+!d3OnsP8+~yc;Q?mXZ*}r_J&H*k
>>> z<(zWA at NlK)yy<vVhgq`S4-AwCr~k%dST=}b6k}6a%cY+fI9gL*oouvNP6QP<2ojR#
>>> zV01yseA0NSw{j9vEke at xHD=#p)~1G)*HK5=`_!^Vk0AU`vp8ee3kz4$Hw#Vd_PO?=
>>> z8$G!z16RQ6=Kbl{;CaZ`03i(${*5wFI!m}VZ~i(+E6<;~i5>NHP|n$T`lWr1XKoz*
>>> z1nuJ}K6<5g=WQbbuw!qmEPNXznHgP&Robsw%ayvU%Vb<6h}<{_`@XeRdE~3+0;3{0
>>> zG(9MGLB3g^7oWef?PMJFFiYZ5V1t7&duq|qy$z%@9GAR#h@)w<xe{trJ))*FSCJT!
>>> zoql=9OyrGlU94JU=<qk1Df0<4#iWVw4{VERBlVlv-F#eg at 6<d+slv^8&S~~(L4_z2
>>> zpc24v|LUDVje|!9(MW!CK1s=Rk^H|Xd((I*!@qBML}_Cx`#RZDmSl@;lO##Vo^>io
>>> zO!h2k7)!`HArvx|grv#7&)5}7*0GN<_I1WGhFQAL{@3$7*Zo|d`^EFT at d9H`=W)()
>>> z{C?l<w}$a%ko)Ev6D8ABG%b(nxQeYV!)Snypj`~!4g(=vXOb<cD_h``u!*L~w|o1S
>>> z_l(btTIU7D#ol1AK6qw+$~FH@;}I?SY`mGaR{-=BLy8!h%U_F&`7(4+pQS*w#k=gu
>>> z3_3pVeLP{R{khb2Cun6w{-#XcY=~FsY|>AKv|4LJA(?nxkeDgrImu_DVFnzvJ5j2x
>>> zJ_YL($n34QAWoe2<Da=H;TC*zqR{5SmDQ2P3fA!}6cI-<t{Kcp(=fv2n8Wy7CUX|z
>>> z6DmhWe&ozbBTuOHiv~|DXYXfGm6&hz#29dz-z<TLMyEg6&=$MnLCqY=%DeXA^w*f5
>>> z?0&z=%DH|vIg7NeH(!q&k<Y_>J9-5ufe})~B41Y$_k~icmETU^W8?#%$h7sQP3eJK
>>> z<MK6s4!#355%x$#FmT3q26QoQtpV_4^^Q61JgQmD-7aN%Eo8NoTyg)Kx~Y)ZDP#yU
>>> z&)5;jwtc$k0FWIV3}&t`a at J}V)8_o at Q6rLsU(+SKw?fL1$q2_8TBG4-c((Xk8O9m&
>>> zFG2(63U2vszBi7F!H*5ihF%JkUasN`Y68R9V#yG-4$J2L!o(LVKlN{|8p%FnT?h<A
>>> ze>hMiq69;pcVbUf;~6rTWfzHl?@RX^%ifrX_;Mc;6Uoz`3uZ3}JZfx}o({yR096ym
>>> z9xcA)F{C=l1teg{MFav)MxCPF8kE}tPAdAAM}%Jf at lHi6N;UUn_<~V8LNukbi6!=X
>>> z#3S0K?#bq(#^GvuUst0m`FA0^pJ;g>d|l#vajU6)?awMqwx{ug5qwDxa2JL!zHTX@
>>> znvrcM5gq`;LS!HQ3)+eGWFe65P1@!oNH0Q6y&lHZ{mZfjR;DU;<M#$%=7s)GY#GCm
>>> zCy(l`9)M{~fI3p56tdcN0X5RiN0`M1Dq`q~n$JWq(HrxHFy at i%Rv2F at Q{T|=PBMYl
>>> zo=xF*J4h4L6EaH}4{==o3!0Fkz|K5FR{QEqcmOFQQU_qv47eGs#JY)Tbpe{l)N5Tp
>>> z^<xEG+f at e8z<-n{X94BU2?$I5P8Wqf^Qe`x6ZPU3TPKou5vZ6*Rk94F%}BzIJqsu&
>>> zh>ouR1XP<3w}#d?kaLC0n{>$oI+XF+kH$upPC~Y3(r)YJoi2yaZ#7+BFjg#mc<K7q
>>> z>!kAQFT5XUbG3uLo9Kbx1g_B<fEwFHF3y15)sADMq3knEx?Df4QfsX0ixk?Wz1t($
>>> zdP70&5p%J+M|C at b?&rr<Efu(r6Fw~6BgL3xM<t`TCJH~0ZTc9zMl%~ZB*$dVyJSp<
>>> zvoLF%Jnm9T&3g24+%OE)sMvo`fK!u$GL0n<VoIxY&kS0W*TrsiukdD1hur1O)VR~#
>>> zZFEPU<GC;+2H3Ep8Ar5?5+rB at Vxo*Q^p0CKMeEv|)8+&6vEpf<(<z+4ibBg|hoLiQ
>>> zn79lD(w2yhc9FvRtT!E3)r;D$RrGU1=bbf|Zf(E!kdXu;UeYsA>??a(VL#*73ny2W
>>> zB56;Nc7BB~#*S!5Tw>U_old(m&?s6r8Dt4Jp{LP_GP-A=CJ!HhTbeuJvzV8Jnz$B1
>>> zEI~Msz~OmWTpb at MCW(~XSTwAt&K$kTD}Z{M{z2hWhNj?TZJ$#ht}3hRF6$WUmj(ce
>>> zokk18J*iq8f<02H+mol6qpuh9PN*Db<N!&eoX(7=%rE?OSS(PO9C at 71Wzepnx}YB{
>>> z@!%($>t41UM-9~X at -s=y%aCXu69E(UDC40_AiZIP6)Vn7Gfa1_eJ<7^YBn#*$2)We
>>> z at y*|{@?iC`VOVi>J*1umqI_ZK)AaL0e&Y at C2yNFdj)^%YrjO2(>b7!Tr>1H6eux$1
>>> z8fy_^FSy6JMH?iOh~h7 at rlFLecklO0Sjq6%%$1pK);He6qrT53DuX4P&IzWS(ERX{
>>> zBSn2YG3hY-dqEQDIO_?*ezw$(L|Ct27M6PQ;26?*QVHFEHu^@r3TnrM&q{&hYHkPq
>>> zTrvLkO=|Y|TW4XvB<nAxV?oQMSoi3enisWtI=y98a5L*mA%VRzVvk<u*4_KGfqC4$
>>> z<*{B}xY7$eQ;9Q%rKD at wvh7obM#iO;Ic^3tWB=04!6rLk8W$?ES1yu>Oz19*a=caE
>>> zyf?d1?`Tew?OWRv&*88WMkZ`LN<P#`nDG95O{<JOGJT at zHgX1yt9S{V{y>m?%A(UN
>>> zJUfb)F#9>op at Vjq&&M?}Xcef5eul>tAucjY^iD7w at m5CUuEaBguve_rTO$&egU{^D
>>> z>Jk*<(p!~v#Fe9AM%O!DrTOc3Ahm$-DoE=)*%_ntOsqKBkXq<fm?IKqW$y7!!_ at QF
>>> z+Ivor_;DaKQWs7oP`xO??$C}N4IuU<?HbFVt(pc;+714U8Z`HjpXia;dla8T`SwkG
>>> z_Bbuq(CM7qG3z+5ccm=%NRq&dE4GGdGny!=(knA%w#L>qI!+(w#ca||WedJ#Pff4>
>>> zVfc{xjw7_lhJ<*8`z#l<ZCs{4d3(w at sq8nO9Y=$B_xtn|HcWCLaBvWsO*O1Crzgy5
>>> zahTS^`Nr=9_wIf=I98ba7o^TdfiQSQX8EfytO-?``14iN8uWw*mD2IRanICGM>06)
>>> z at l0A;XPr)R;{$9K?HC=*5TV4aWzC=kXw4xgTRf10roI0#+VZiKVXA?g9Oj<#&pG at N
>>> zDd;cCn}b at XLkZS<{#!wMxbx(!NE-Zw at 0GtGf!~$W7k{5BfXkfUzCm~1S|O-7jLFuG
>>> zBip)Jhe<3$pG3~(&v*ZgFMB$Df{6=1McbQQj6;Zg4Dp$@!4`fcbh&xRETA8MkC)cI
>>> zu~nmRZBaDB6G;nRTqFGjT}AUDXQ;ObWb~RbS-u6vv!lcxg1k+U*7}|LOl<yj1sp8-
>>> z_2tCt44qTln(Bi$&^%hHi|@3ZU8d at HbaV!VW*l3F?>Y!p*=1}^l>|6W;hL(}114GW
>>> z2(y9kQ;5TOJqcRcpv{n)^Vt?^QRNR(8j&%U9~o3qexdE=r{uOId;&uVnBOUi at TXx}
>>> zC&-z}q(m-Lg@;Y5o+Cm12J;{8+;9a#>)r%09y4pL!892{hX6~Nnad`63R=0YiRs;>
>>> z$=>9o{slD(0`1QW%k4tQ*1&X$MxU~^YQ5ksFMm_{<*BLz9^z(<J-;6 at +^b!)sApC4
>>> zne`n{+vI$++zb+2_hH}E-5%ck?c8BqGdf-4dIR?HT&8x2gWYvd#bJ(DDp&i&s{)Vk
>>> zMgr5tP_tK|L^iyLXtJK`z69ob at wxZo&}?6_Rf!<BG~B&I4>*9Lq8Mi>s17Br5a?|(
>>> zq5aLSbAWC2prUl`;5z@|>}R$z3Wh)Ly|0yykrgZ1u+4PFT{Hoi>+eHuu^zG5f!A~O
>>> zk?*;qXl6T+K%4gmunx<4Cuf9o1JwFHH+P at 1ea7*$Qh3Lw(n1sT0L0kmgumX=Uu0{Q
>>> z0vX{~uM2uFdRdo#j+^W2LQeD$``VFX8l5hj<k%Qe1NhYH<>JTbE4G)HpGc|5=AMvg
>>> zyY%aM^Zs)xCJpxxnT+M7ouJ=@yIi7#znkT{)w$i4w(Q%HKheH at Oni3SDI=A{7S#Hz
>>> zFZ5u7TFgviaWl>{lN*glsAJ0qm0DA!^Ixuct6z~xwly9W3MxCx_-drSwYcU+Mz+9&
>>> zaUN61Ru`QbY~6qtLQ$O|IY4=jyyETUYLz<VmC>nt;LC+Da}%9%f6C`!G+yFQUB%`Z
>>> z?Euvfvi*vS(4&m41NBUoc_q&RAJ6eSIC<>Ie038G`JSD1+?=d$Y)Hm+SPY8n^oXmj
>>> zva$xStg<F&Bg4ue344C+muIZ)K_~el&WfH<?E^;bC;<~SHplRO7e3M6q;?*ulNHZT
>>> z3KZX^CKu$|h8i}#_ME<cv+R9%!L=E8d?c)3uD|!={O%%uy+2E%AJXn}4o^P#<V#p7
>>> z)#``mj6Zio24`j2F;^L=WUNg1B;k0t0K$hN5UFE8#J$W4{f(0B2)KxLeN5I{8o6qd
>>> zM-(KtRfRbNU_9?Qt%nGWZM^?kKhWp%YPJowz at 4l6OSfd6Oa}YCS0dbOLQn@*H~=>K
>>> z3IH>qD0e}ZlxDibp#AqSQ{adq5vm|f<=GSfvWcg$$&Pe`$$TU-^;tsaBh73+he{>5
>>> z(&k-&yHNVy`r&H1)BoKMBS^C_z(7KTzQD?@hI8Q&%9P7}b^}!x6fVBonb7B_&5hoL
>>> zRBnv=y$ae<-&0H;va5fnVY}TGz)^(ZE&J{kc=nXOm_8>oIa~tSa$QeEBL)X|R_(I&
>>> zT^mHe?&ri!L{b}krCx=e?7XKpS2j0?UqY|hQv?zE%t#%H#i?UeKH%a%o1Oai{;<sh
>>> zBTpTq(udNA7BDiuDK at GOGzAlvjj{n?dsB0pg~bZ-i$s)vyYN#=MtFMNdj8kz?CR{t
>>> z`I=^W!FG6qRfjED5`YIIl*rJTwLA at q=Suo=Nig3RM~{B#ES{edn%3Oig>3ey-ao>-
>>> z1`;P4(p2~DNEilh)~xanOCdy-`0i8lxCg)27f;8VQhm9v<IU;DqTU4Rc$2q8FRp^j
>>> zgMlQvt at QOF1ZU1u;`oXF-8EFRt)h|SYjT?|$qj~jYjoTUa@}eMgPK+zsYD(LL3U{&
>>> zsWu-con7FUgZlMjy<SFiX}??ZzuIM}zH_nQ>)2BL;gQm>E0?v*vfw->fx*ElUA#B7
>>> zDpXH_#6M#JLwXdFp(@VBeEET*yIza3r37xToNT|}Q69cBWnRtx1G<VCgaC&s(DX>c
>>> zFVQAiV8_3Ho3HG58$420Y#?;jS+!64PVDZ{d#Mq-KKES^0rj-onVP?BD?F(V-aC4&
>>> zF8uQdgV{hAksou*#19t?yUpJgn1)k!aE;jsJIevfN at sw-t&eoy<X+XdY at 3CZqxi*C
>>> zzpXSqFPNLs;P6cH$DXM8`|SCge{iY#)xMZ;`Kae&DnPxSF5iZGxH(EEx_6k5Y4y!=
>>> zrT|)@Kt&UaraVo_swQ~IIw_t}u4j?fkr6LVO6_tu2tl?$k?uS{26XOlK7p6py*1!z
>>> zAN^v1;WSfDt9Q9g|GIdAtP!_;eBVVyv%c!FajT`-W&gyAs@%|hN$AOcmk9-0rqiq6
>>> z$6Z`#6)oLsryt?fK5fP89(ydE^>|NHyfFagzO2>xu9Ox&Xgd&iLd?#j9`&obvErRu
>>> z>_c54dt;6;u5c692)Z2Hx)}p4f47K2urr$qSG2t5j_GJPMCNI~oPTvAAT_n}Rmf_d
>>> zC(w}Bw1>Hv3xrG%z1HVDrc=e=GAlkCN^LkkGIou<S2riWUnbVXW_eX4M|*ysr5Ece
>>> z%B`pD4L5?I_r=}$X at GqVbHr};+nEv at s}C3L2TS0~-8qSlj&DtD2c7d!yJNv#`!8jO
>>> ztcr{GGz;w}(cMMz^GYeWDqI^X0>}S!^9ZfYkn%0Rc-ljG#m^*v+_C3O`?kp`TNQI5
>>> zt~apvQXB!JVUDmX3>Rh=ix+6N)7 at q<Vjc$_)1 at AtWnL(G6g8fh`;_*B&0=Wd?fxDR
>>> zn6c2`S<l~6Sr~}z8u#UL5iHEP;K%D}!qvS|%y630fSVnl`(Vkt4N5!+4~kE`g5|8X
>>> zn4M!iF5-5Abh6Cb$s=qpr?#K=c~{ZxhyZl~ZXpOF?vU}(m3=1}w-Rme>ToZW-;RkV
>>> z3}2Y&l$^=D?|=8a!ZGcDlwn#Gh25y)kDgY at MB72Au{ioOJS!-u?5D&7sTB9?hf$Wi
>>> z+|ThFs959!aHJkTE%iOE#Ar}QU%d2_=baUPmCI#PpZq({ra?1MXH|+ at W=Of)ungZA
>>> zo#9z{m`&G>y3G|T{Vj8UC%LrQx7)vOebhGn=}H(ZZNxki-SvgF7>4d!rAQrRk)8aF
>>> z7a9d-Yu2^N$eEEcW)=y`TZDH|mJYpv_Qq=%-qchOm`7<s!?J2hLxWKW17On)ZUGC0
>>> z)D~u|DROUHjOG_bab`hi^ZzQ{6FOG{D2r4Ac_Er4=3|kz*nUu<S5oB7<=ZUvW9H0J
>>> zju*`&_N1qn`q}WaB at yrB)Fg9PyuxbA7=<&zFNA{m?sPq>Yx1yaAxb^-M_78?G8@;H
>>> z5nOc(4)p%Yw1ko^(UA%5kP{4B0LFXTpm1qdsG)E1DzIg|Mw|?4CU<q*jSCJ_>0t-j
>>> z^X+{*b1;KvoBDLi=xqV5IM>&lx|+oFRsM$v|HJ+6-m8Zt3 at 4BQ;G>+rrM!<9sF=kp
>>> zehyQ at H?q}`m64$U710NynbXY>XK8(3etr&7?ciAT5P0*n^xEizGv9`VV?1c{d$l$x
>>> zVQ=1DL8be~)n+DqznE4??7>AsssR<)4)`eC;f02az=%|slm$33Muy*7I^xLHd)!BW
>>> z=-~t%w%OApaKtn>#W!w^<ost{T}g?KMI5^br5vmgQ_hyAymQhGDX`2Lnb3>tr4flo
>>> zoLeh>g+5z2*jx&!odyUYUgvz7pfuB4D)j>^y?UFAo5_%B*)~)pQoxn$p7<0d>gkZb
>>> z+&}#(+c2Z@)mrdVP-S|jftyIRa>}!_mwhITW~$<vmADXBM*>Y9Z&p(d{W`EsR{!|3
>>> zxJT5ghb=Wfe$2w8?d;(<>?w6K;Xr&+%k?d&Pmj(SRicTL=r*gK#4vmgTdSgrGn8lr
>>> zbP-y>EGJ5u!d+bKndW at rrdJhzl!)eox=h6gwlovzq-R~dgICn&44}Ow3xVX?K!Kj;
>>> zu<Kv(UVG3R?I9+_1-s at eMyD3GOTkZweQV?CIj_&{TV|$?udjY`aLmI2($1V2L_m2L
>>> zaWg^SxTcZm#b5ID?ZDi?HE>n<i`HM{Lo?Bv_yWXLp!Wx?q3_>1=t{M}5tP!JEX3&^
>>> z)r30GLphEe=}%v|2|@>??CxGs3$W?iT@<LQL-LS)&aC>LWPPo*<;(Z>@mTl5wEgUP
>>> z1Wd_A+H7S5fRQhw^8W}JJ;%8-RR$fHReHjY>yzaD3Ri>~{52LD#;&Q=T8l;9WkLWz
>>> zh5Mj{B5VO}HeuwN!T*IcA#smVpui1{{u&DAA7hmtXH=v}=DEKx#{eNJsE)>)37G+r
>>> zN!6jqxgXI+^+Vxo;nUS=Q_nurTl5q!1Z+ikOGf!)Q2NqWx3qPUCbj`>0iO*5yyVP%
>>> zRE|leni*UW;(+)Dz+xffJ7_k5#`ls(@;Nq3eW!T8%2JpU6?x;wQL=mVtWQ|iG|mj^
>>> zN)SgwfW_5oWDisCdROdWTX+Mz6!g>U<)GiL at -x#sdfm6*r(S=5mMPDsnC^viNfw(t
>>> zESt43`s<rBL}ee at 4Bybp4IZC*ZbuSe at RoFyeqlT(+qJEF)Hpm2H6cuc^bbAHny5tC
>>> zq{v8(8?3;oE?ytR<{rF1iN2=_XeKcWeY3GONXi83ICxgO^g{Lmk~ieT6SX9NoqV~8
>>> z@!Y2n$xibjz<1&Uag{mA`&fU~(stK`b!>_D4wa!(FL>9-))<k2UUW5?)rc^P#@$1W
>>> z(Vc4Jeh%x{6s;b-9^+7H<wl=8A66~l_b=-?V-LmP;X#8K&JT<MblF at NIht47M>{_q
>>> z=}I(@B~&0|pSGV~KCp=`aQA*IdyF^KQ%O24#ATrYN;?N(q;DpocbSEMK}&V33+1`O
>>> ztrWHMnDVrJx;nCRjkbnj6BQ6_<Hr87+^5SRo2JkKK$sheh>n1rd`b`qsWGJ-DJYm;
>>> zDO)b<`eeYHe$3^{LymZ9{hB9=44ZDoab}UuY5LVw7s+z6H)?kM%Fg5anaforcO^M)
>>> zIh}{ed8qDz9mqa_j1`C;h|y&PdV*POFnlbqcFGx!T{wZg^JnjR%=r!OW%2EX<nHmA
>>> zzq}u1>aQMFHP+O(V<$^4k!+{wCd at wTggF$-%l_K;T9<&td41}`??@N-Nej;*o{>Z#
>>> zAOrxMB~{(^-caimFw3N_XxrFkq^T=hi*@55P1-p_4nFK)xS5}!b1mVQ{(?peo&x}-
>>> z0~RA-YyEvYd-?*d4${X^k1R;;CD(cqxNf~l+<BdbjMj-Gy05p8+h+H=-mw!2v1;I#
>>> z{0<|S#jw0E+s+Y9UPF#_WmmDb>Y(<~)?G}wO`=@p)T`0C2RJl%G<X5nvOh8|*~(;T
>>> zp at 1O7A(ai>2MD0RZ-S|}?03qlv~-sS<ygWEz2jMhYXoC3w at Uc&SqGtT+fT*aNssmm
>>> ze(mS37_Klr;yxp_(A7qaPYttOOk at j?2>u<v5!Y<z#*Ag1i2OqnxY>nYy93N|Sx@~7
>>> zx^R&OfU7Vva#=y0{(&sOx(%PHB|*ti%Yr?w(4{;0NZ=1_UFkf)G0!v8m!*J1rw at QA
>>> zSEry%RrWb#60`=Gam?Q~i)!o9<(%cvyF5r5dV2RFtHblj$cD1QA=Byb^~lbE3cca|
>>> zNct6q(I4z7U~a`}TFk78uEU<ufGJ^IVqn(T9jWy at g!gQ);aMTxt*OJ|A6Wgca%f9~
>>> zc{ExuT>kUBQXp!{WyEg0KZ|bKh_2FGzPlfG$tiPUFxOSoZb50SYX;2Cuw>RE1ZI5r
>>> z+5#`ed^yqLn>navrc)vkZ*`K}s8={oizFuBIV+ok^aN5cEEaHeUKw+xVY=Y{Mqwuq
>>> zjZ?EU%koRn^D7GG>UHmmYSg)q89kZno(GV^{C^#&t__vuI9uUYoBDb5FUS!K-vG0R
>>> z)VIxYwnDjRc;kdEE_sKtgslPjDx0^ifs-1CrP&8RsBZy?O;kAR_X|-EJsA%1L#wDQ
>>> z7T at mX3my4SG$~?GGEw*Vl?VNmCD$v<j2~WHJ#*IPFiJW?E6=<%JU*>W(?(`@*|5X|
>>> z&}#*CQEK7^QCurTKx_47XSEZffn8be at y^>GVL3uH5$??Idcuqov?hTlhW$qx!D3i?
>>> zkc8#&;13#TFKf_Bdh0FaHI`fpN^;F>o76jlFz&}HAvpT66131h>#}}zJM`MC6$|NL
>>> zkfF{i<-i+m9F<=EC_zjoFtqXfo4=qWR;3u~#d^SB5YijIlTH;}WF7M&x1bcdET!`n
>>> z>1G>^lZCqNvjJad_EkT5*FV>*)$F5zlM=vV%!%Pv?V68!Rt4krP3ta~$^}ZV)x-Ii
>>> zs!QhLA)Q^#kYflVlA^6hL$a#jU_n!T%CJqr!(@|FAKvO~?(uEm+Rzg<M1gi(qJw+%
>>> zPLopS0blQ&1`qP_YG&pu`xa6DfytX&T25tm&YW8m{3+DsK!uIFvTh5Iz{~_Y+<{C9
>>> z*@XIx%mLvA+HCV9A>7+{ng$iB><djAax}&?W3 at dBQu!KuZjON~Y at JNdq)YZO$9WZo
>>> z_RLGCGMl(J4+A`Hp3KY|LA|#?(}b(nqXQQxhhY4MdQMDy>srOfLuWofKswrAr|wRe
>>> zlED0G+!o)|OfQ_g*gUi5F^}^7L2rv5;<?KY1m!~`H5`(BO+GM82lJ6legOsJyr{{w
>>> zx<`!2Zz)PN*}b*Jd9HEugka2JT#YEtZu3|4DIhLNkHeW}%feqz>~OICN`{nASAQEk
>>> z`iXVMCiZBr7AoQ5+&k?cm6jp$=^JWaj07k8e{M0U=8K<TA9gj`%#)B{tWt=BscW;i
>>> zOy$V>M>ms~t!e?y?e1U^P#ea{_3U;F=H|A{xS5%1gxQf${B|N;k)c0~g at jLH*_sA1
>>> z7Zuk6bsuo4+9s&RWRK4pzT6a}W^wBtr@;D`u3CFfnsM5yFOjiGg~8*Cn&TEhK@&r?
>>> zK5-qXIMCv2@@VL{g5&)Q(OK<Z*U$G{&vDTHR0%ghAE8CFj*F3f+QOkD3=Jf)FMbnQ
>>> zKrnIlC3{qRiRgG+B&7Qv6XGm_m}M*hBt4M89R<|F9)ZLrnB&lHZ_rrv<k(W?gPG>3
>>> z{&xwTqT(eusits#guQh5Fp}rlI5<&VJRs?Gppw)y&h04*@Xj~q6IWrhn|2+c3w7Va
>>> za28rUAL_D7u%L}GOiuUq+UBK<#};#q!o$m6cvC9Wm%`cVb0XwgihV+_%*!Nrr+H?M
>>> zrN4(&u(z#6(z8;xk_AWq)jt3}UaKd-aG~wJXK0hL(WD7oxUFhfo|jqYi1yRd`U<^u
>>> z`L#j6M^i2}rpd3;b7%@r$2NVw<yTbJT-)x|mXr3>s^Dn`9SX?aM-eyI!pJb9Pp7j~
>>> zm-wl{-5=^xYPY-`R&Ac$5t0na&Cr3Qj{0l<4xPbAAzN-Do`0bQ%z&eH1U@@E0mBBL
>>> zPh<|AG>z14DmSV>2LSt(OE)*Gv8k?<{cvZi(<zk&Vs$~m<*;~KjM*7txDx3Jw|T3}
>>> zK!)&_fxy7Dw8htRU#AA5Z0)9WYjov1kTn2}4j at Kep3hH&8MIF;XUd-6daQN#am^w9
>>> z<J*n;Wh=)x%hZ1W)OI)a$RUFeyV>9RKun4o>MuwJ{}Wk;TmuN at Wb82tECCUAt|HK<
>>> z&=X!bJ~le_k~j6tk6&{ap4=ZgdHN52lAU#oPQP;M*Z{&>FMBPjQ9)cgUU|s%<)`IN
>>> zm0?+?>aL445yuf?r&{v*(diDG(i`2DrVi_}{arX$fm^_inv7r{s(M<}P)>_`fAuC;
>>> zAo5ddKc-kxXbus^iyy_FpzOV1Nrdnd+NV!axZ++`%16K4Sa;mW<HlREOPx$A0r?t<
>>> z;uld}eWTB37Nh at y+{}eSa4lW!4mavPc$9md((U~0o&ZxioZ5EC_o_~kT`!t!j)HjB
>>> zbFNqU%mmiehk at J2!&-YD_q`bjxet$d#ob#i>y-5Hbnc9+gAmI-x@(}7L=sq6bcblT
>>> zCTft=BWYPLlqdCD)#dex7Z;CLdlYrtvaK3N)Oc*G7i2r4>kp5*pFFm!E587Z2bdI~
>>> z)`7g3K3D$-pkvNBd$J^|HPNR1PqG*8_U+mK9*y?v&f at S(b=FwFKyo$!`Uq8uNXLQo
>>> zz{E;*wtMP*KXDCx_4au0H109m*Qa+d?dUNd;*C at ap4wv09n!jIA#6A5t!{dC;)h{J
>>> zza>uTO+b{x9TV}8ZyS=cqBlfNn;eTt2$UUOt14%pG60 at jG)L!W0Jl_MiJ7L3;$X6N
>>> zfN`gs<#6FgO9w^A=bummz at c#X0!{EM;2xXpaydGvPzR7m^{)RR?B_B7g4HjQaJy^~
>>> zeL(+K2J|iHiae2^^x0Q{Nfl$9kj at g@r)&NN{gLf3$~#!g=>6HDL0irv;1P%5OoG53
>>> zhIRXZeFoj>bCMBA)741Ux#0F~blGo3<?fr^#}85-ETz_+HIhoMeFbjHjqbt(%;NZI
>>> z&s$thHBi6_RZ|*m^)g?gb=P-#MB%wJ54Vihju`KKvm%<eA~_j?G*`eP1LpqV_3>wz
>>> z%&N at P&v)%9MWx%PbMJFP92gP6bM}H^G{VrQyPM4LV{1`uEdH{ZWA3>(@T#p9mF?W0
>>> zKBX4zOaMOjZKs85yUZI^PYbLJKjVWLYI;%;jcPq1+bMGMb+_kDj?@)CgR2{>HC at R`
>>> zb6CQJdAU=mz)d>LLu1Qd*%}{{O<`CF>kZcp?1YSH?1>}FF6(_!y$h%Y(UEmefKOT5
>>> z=~0hrfFl~{CWRjgZzCLTyib=7k?NSf2s^!UFkSVz3n~45MbSI;Ys4i(8!^t}xrL_a
>>> z|J+y-OJDo~@How7%ng)u at V)<HIA~llF~mFpi6cuXbl9}m7AEE{8+Y`WIyvV!0GNr*
>>> zl1GRvb%Tj+gkuap<6f%!a5~?<*7i at A7!f5aTb6nG=|5d!SRz~}__BwNN|%lbsQ*Wj
>>> zkn>HBQ$`%80<syV%u1Xa;0A+n=!u0GbcnO1+m)x#E#W6}v?ua?lWzN*^=*GBdQo`*
>>> zn*-coe}vIUqXk`?R?{NfwBEZ#vptv`HCCRyUtMP>&uy-07kf=t!?nuiHRXu<BPF(!
>>> zgvF}ClnJLT#5Hna>=)lBA-I at T>w|JY`(h)Hd3J3Xv#I`c^4q(?fvzR*!lDU}P`BRQ
>>> z^{J-h<VG&_j`odW(VLAGs>-1AqG|BiK3-&tJ`MmExmH!}?WbrZoi}7h2bV$}-rU_A
>>> zAN+ah{)Xnxxkdm3wIHoK8qw@$l-ND8f^9R$cRPAVzDT?($`(N?7>T%kspxiutewOs
>>> zhj${&``W<C=nBG1gd3?6ujIXsFg*7bez<@VrIxI?zA)AN+c-C+wpmcjGr;LDNKB!J
>>> z4n35mV(0A=KNhwy$w^c?POO#j3+A)_vh*Jrj7ztfK=ANX;YSad>4Pu at V00#oolT-q
>>> zk>UzG5AU6`Ap2Kt|7(_-8JVb79RE at FROVaP4dmkHcs&K6R+!9O`v7L at Y-;+1OL{i^
>>> zKTxa!i7wwx5}jKuKO=WVvv7YIsQ;yav1o^V_7JdX+`j56;V><4u#<2Mp-vLh5-ADO
>>> zb{bgU717+d7H at lD*8YyB<yEh5Dr``PJ_?~7d=zn+e48arsd>4x$+c8=PiO<3<sELV
>>> zpPBkw(}sf{SPD6@#P4#N=JSE(c*EZ6=756a_rVc+jq<jWaM4?Lw|u`GF_#rhhs6Rw
>>> zGOk_By#reFsEQbm at y2~eD0%sKxO(=zY3z!5lzBBjx#QEg@#0ZzR8taNE7LB*#$h3+
>>> ze5(nk2>#8GBzMM%`#sz`uo2VIvHqe#ZOTqFR>Z3=+}c?7+#O?16d_xTu<Um|&$J!M
>>> zph!8y+>NO(AMhH{5LyFN*L(BNhoQ7*u;xZEtsq<h at JEybV0YRocxG=+nXKIoOgAC4
>>> zZSsbsK=?ehMyiObx at IdDC2A55v(r}+4!c|e5&`gsnxt4_z_A9|j|l-F4$c9)L^CG~
>>> zOF2*Lfl%h+^5_p5S7f_&>u`SJ>*5;zjViw&q(`{PpASS}WTi$6K?rb+;$NttPBL!C
>>> zS>e?ky)Ji~H0kv|uy at aRU^(yoCgyO9^aV`ai^3k6+>?RJu(LEDsu&GSREihoOi(jb
>>> zYA^E~*ULZ5e4VzcB>Cyj59w>xyKEU|U{0|EJABMdS)G&!wn&(9x<a?wKeB7HP|1~I
>>> zerAPicpGq<{V5SfV9?{6y<v)vcFN{pyewVDC7Swu4#FuN8?ORqCkeQzmSFbmieI0k
>>> z8b{1bL~qOw9STedP*)v3N8{rfO8wV=)!S&E=_nXm_wlP=f(+o!H(Jf=+K~#^OV8z(
>>> ztk_*MKSRq<RGc>YQCXAioBA>7-eFr1NNX-P%{07e6sUEf?k_9fNYqtOyw;W)T!>Yl
>>> z4K6_1uSIaq$j^NrWBFwd6_MqXUpP0B4n(eybJ~z#@?A~J!`0z-d}6xw*L)F&WkvDi
>>> z at eR`k-7{ARv}bnB17<q%6nAzE!$bkOf3XQoj9ZT;o6O=8N-GsP+k+i$H2L1F9t><y
>>> z^-@?AYSnYN>^%`YN9Aipw&8H at GCCgO7og7m2CxiR6=$odJfLlOE*p!GLKauQrHXi2
>>> znLjUXbGqt039`S&=<ZMBR*kyg8i4o<l8?f~&%M5wZW3nHIxS8!=z3E;Z_it%rmU0p
>>> z+G&kcP-B;|H~hT*Nk3EQhOt4~-Nj-|uAVk)kadKK1~|nDu+U at H#UW(1*L?PfDgXGf
>>> zsAmt4a4p<^5k?%;h5JxlDOG#zuu&6YU*fK at TkY`0orTz~XW=^o6W!E}#i?vbr0~Dw
>>> z;;6hdy|W03E(k?wNEIMy8l$jry1(Tty2EP>ZVWl#a$pPLx&Rn7>V$8<NnY^INpf at G
>>> znGXss6ap&14oEE>e4SYpe%up)8K*YebC?Fs<j;xxm~$CE?j>V|6ByZ)^Phd>&bv7O
>>> ztbQmGFL>p*rtB}EPo4P$V=w(SCGjU**7K-<q)C|Eki;r5Ap4?CLonYq=b9V+B8{Eo
>>> z-i$m&tLYkC#ecUCiE`FzGq1v3>Ns&!aX!uENbsdp>+OEdg0KWYuL8V%j{j3MPw~w5
>>> zw=0s3PUkdUQffT|i~S9a1E=<P%MM_t$b at K7)w~B=lU=Jea#lIEF?Et(vlD_Xy#jqq
>>> z)>3yjqZsBMB%c>pVM at w7u3_xEZyrGh$+^K2*GqUQ3Pqw9&R)g~fzYK-hx<aT+QyMD
>>> zup&$0`~&>ffS>s2lczgrrW>yegu8?@b;^#vf4JrMQ~eKq+S2k4>N3 at C7n)A#<EE&K
>>> zi?jOPZV|#Amyz0s5h%J($iy8o6o~Ba2-Y%e&#ceGC}>?*y)o)$|7O2dw?g=b%9X|F
>>> zRG5=pJE3MTPH7j=H>6ZOa}~L*rfY_`e8>4X^6@)tLIuBGr184Tqwt0Dl?{=tiiMEu
>>> zK&jWW&d|hEmeHcd8XuY7LO2ce(sehb;NmKAJj>a^F|tk76*yFH%p=E=>nDGNAT#Zc
>>> zjBp^vI-g<2?vpuZ%%*VUf^eSuAr=6|k&I$zG3@|vu{H(TOgM&wI|sDu>Ee0X4%8Q8
>>> z3I}KE;U169nC%6nB)&|2+1<G)9kdFo&;kRI>)P$wJhy0dGbiF7LK~t?y^lW9;Vx at 9
>>> z!h~iZve<P_^jLfPZ#!?oSz2gL;;(Z2>!K0g#f4C97-gsd7<bP(W6lI@;yBt(03M-y
>>> zf&LQ!l2{6uR&On2hlDGjR4*BLqV5H?F4xfVTK}BymHTX at LZQfvt<yR+_w at cSS~K(P
>>> z2I@~LEI^c>|JF(_>?fqa=weG%;4P at X)Xk6Om9Zng&wG`Ad?|hBdZZ0#<}iB%NU-Y`
>>> zEubAoz5{+SeTG(AN`pEAqQ41Kt6M{#zBdF7Dso)AIXC(XJRZzD^D1adej`mo;}_dm
>>> zSKSiw_P>U8Gz3Pi9c=XT at a8e4grn=-FGO5ir-(*RD8B*MDLj+TCWl}yb<AAytQH<u
>>> z4^zq?oI~m}#c9x3T4B7*Yj@?W&9hS)LjLsr;nJ!`Z${}t_{`X(QSj%MK;C#Ym5+`7
>>> z5{Lg&Ls>-I!spPVm{|#0G at UKvYG1&@$~464BdqxB_e=kX^o5v at S9Fba&EP9Use2kS
>>> z=9XH=_r43(KJXn{HS&<|>((rcTb+CMTVA1*Vv+lvvF~WNUuu`GQ$vDw0*y47rY)Py
>>> zaH#)u;5pUdnK}N{Sf+jJrWqf5d2zF?>-N(ljimqYOgB01zc_ZRe25gW;A=~%+VgY6
>>> zfr_~(y$6;u&~@p at fX>Scz5*USK?E{H){F$=y-R<Eb|qq9cOFT>6)T at 5OqrJ*-vS at 3
>>> z?qISC@*YrxR$KdPDx&r(@!qU&T^qHVCsh>CtqD2?D9eM5a~_sXy at rN0@GeZ9kQvL*
>>> zXe3Xa7Dt4}>9M2Ru~#VkIm9M$Nw&QC{h-CUWRQ|ns9dqPRv;#27fd_9*9_;ncK6-@
>>> zRvLb%<W!BVgK2#yN%uv~(P;)Ilx9Sw(jvcx<WpBh8kH31yQl&&>+dVetCZd}j!D>m
>>> zdUc-UrxGJgHQeE&YP4*Qy3PaxZJHY{Zu&e$R8MXwuoT`l68df^-}dpfs*c70-s6q;
>>> zgV#B~9rhdPtI+Y*`UU}g%+Q^z9~(VDRJ4X4CVKNWyCYz7!?H=noxERPTYvnV-jstV
>>> zb>8;*=<Kq{(80{Oa55}$0BmFrd>VcRHvIpo5lVn?$xXr-(5C+aT6&sZS~Wt0&duNi
>>> zCL|@ZcL<-$n!Q`)1+j=?bsGm}rCL6Ict%1lG@`qZGdhJS|1n7uou at Nc2wz>sf0$hm
>>> zBph<#|Je4Y<4Z0kbKNm}97Y(YqfJ9_9YNR=H1mIct2=<-YW$zy%Ei!=?{moe_yXS#
>>> zFGUhQG)udW;3R;_-IxjOW`YRvkvZ*Z<LUg6!P~WU!}s#2&JPC0&rct1tN!DfZP4&*
>>> zG!$G9r?R(WMZZ(r+i<5s9Pirwb7Cz6PONk1dr$u8ua6atvU&5+U$s*nU|;_*v-JcK
>>> zr)dI2*r^cVHoGbu79al8cP}*Y_VH(DprD=o*H493M at Mqq6*@JIyQ6QRm6{07YL^aF
>>> z4Wd{4_{H<wkEeCg at 78le56veA=QRzFByAH$SE*@ajWrtj)Ewn=#_YSBw1~T5Nsp_2
>>> zZ{BI4zMJ@!Zj`j&lVmp?E(RR1F$fU~1hoU<^1uqyat>2Vidx*f at mgVN?d7*t5*teg
>>> zPwCzBXZz=6cwjyTpepz-Wr`|`hpub3N<XzsxOdsE*Bco|ZJLRpw<*iIyjlN^)Zc-Q
>>> z!e+p6h`{{SgGX7jhC^x-qZmc|-7NWq_Lf%}n^F1EEt}c<EWy}NvRXLiyqsOA?)tCI
>>> z1N7IB#dz{ZQM)%rnguUIR<CVv`NPHx(x$ftvoa5S!VZ`(&!u~ZLJa<bMlgBd=fj6_
>>> zhgqjr?SzdI5LVQ8;i5unr7Bb3+;1<&c6Aq~BsK47w(ynFjYEL+dSDcV0Y#uQ^mZqg
>>> zZI9_Gdy{DT+i%h)A(PxMO1eu2tHRHP_u!82pi!{utABL7!ir7rQ$>=kEHZ^C>J#$k
>>> z?)(_ at cF@mU1*9NmlC#1zCqspE!WV|ncICsEKMdCv!cmo6`nfI&|8oc5mirg83%#Fd
>>> zb{MY=_FqusFKrsGVoD%s7mS)KGqPBxQ3+e15VwJ~2tAU<y&)=^Y^fBnrxA7KDKx(R
>>> zsnJ)wmQ9)d?$(Aq?kxO+`9Dl`w)>y%KPfu8#yRbMJ+Np1C%y?+yG#|oQ2lOJ@(Ql{
>>> z-LHpaLH3rGMX}YatOP5ZI<$RnTD4h7{<)~b_8`y$AX9g;+I*6s+~F6O0tg5w#W1Cg
>>> z>Z>>C&6l5d=qgmro82|{;YprX;3G{s#uAqLoZ?gP{Sq=VVHXyGtlp%iBo;ZpAQR%H
>>> zE1HzQA2}G2j}|SO at ogCf3(n*wiNg=9&tvae9^=?LCi at NE4-n#+Znr$YdTDBFd*K;x
>>> zDdAc)eWS>-QTv%ytv63 at JH4N$$U7{LNv{>~zssb;O>l`UneZv(aV$UL357GF(TGTR
>>> z8LZWrs?wn|!hadXo|!D_rR4vDOsaZ{y}+!*a?-S0utLM?rS8 at m;|nOSFB3~6nJ!`T
>>> zjT)zqx$=1VC_>;TixFGkYsVPT%(8ME*^-bz1WizBNB;Qz1zr3eo^f!P>`E1(Y0MJF
>>> z+?!n#D8-b^HM3$q*D8nH^K>mf+#Gl;m8O|t9X52s2AFa(c`ht>mhvV^mmB8S0K1+R
>>> zv|LB$JVi4mV!*z?O>-Y at VfbFY5Y4#!Y4L(p(!08^`MeW2yN^aD0Lhv at 1D}%iA@(KQ
>>> z>0FE_+^QVqEbi#nWB}nN<_tL+lZ+$jCJoTQ?bN-!%%#%6&%a|&6zP-BX at JTXlY27y
>>> zgfO5wV8O$}fA?_|bLY$^20#8`f24Bl&J1HzDp%AGmZFv1^%8rOHIjF(iW~%t5ru~f
>>> zP!4arg%@9Mac;LXVSAvQq*CIZ6fipcV0&#*E>||$B3F8SW5c~|nkU3#mLI|wM|8+o
>>> zdhocz__?E|cGJbCMflRVN6B=b>z>`L-8z!2O>|GVxC1#A^3Bw!oxikt(X4;nbm+Ur
>>> z(;(PX$w~i$a&3IF5zs<O(RdHuMDBp&Dc8;P{v4PVCp~A>$du9C$I(RaD9=n7p)E{!
>>> zyM1-G)Tdp5KeZQ$WPa=4AE at W_=eq&w5gu&<{!s+0Pi54}0PZ^5b7flc%+ry#Nx+kR
>>> z=#n3vGht_CXx0IhhptEnEhuqsciYk7Zn2~a{+wO4PD#tQNOE-05G;IJ|7l}=@&H0~
>>> z??T3+g(~B{8`%M&&8-k#ksP6qAs6re*4y!BlmD%8 at y2sJhST-;4Q=o?4Zm$bG(YW$
>>> zJB0Hp+U0^+)Y|K)&e|(%e17Sr5kzs~%@A~bwUl&p`L~fLD>Fipo1HB$rzsTge!_kG
>>> zSFx#0av`U?R~2p_qD$&~AsBwNi|8I%D);7zwNvr7<6Hl&smp2R#^-=X{khXNG9D(V
>>> z2VqE&zre+z6y3}i_+`UNLt&G|Oh_B=trJ&vo100}c0X&N|HzihHK^l{kvvtrVzSi(
>>> zUN$02(sj0sj&NA`ke=?a&U3my!eB^Uq at j4Na>|o*dr;z;-d(TtxsWXP`)LKNZ$LD!
>>> z*}r=l-uG&$`VYY&q at 1;-IqY7iH7J`sbF!Kjqyq1Z4a<3SH{pA8QK#Be)B5!44)k_=
>>> zh&geO<Kf$I`NRU3QiPM!YY+Pymo2=W20JZl1P7NJ3qr_SxJcxV9K#+!<^Bsee at 1Sg
>>> z5^2s9Bxxa<yxCgMiCU{Fb^N_`Zdk#~wZ>fTn5<W?SX<3h5@~*J1j*3erUIYD_vQ(}
>>> zF&`!q1Op>oH=`jZ!c~@7n&jlzI_`$g@!{Qghp*|9Zvp;b{lEEx at H3*u>mSzLI7Lb(
>>> zo(Jkdp`9U;TfeUL6g|k4N^|M$p8OJo$erFE%*OXGh1u}%CjsQN-;WOC+o%{RjIPHn
>>> z)qVRGki-xPMC1Q=p27b}CHOzY6x94bF$MDfTTH<`Y%Gpi{1+7KPu@)UiX$HJ5kz`V
>>> zI{t8^!`H5{ovB@(GtS-Ig_td_z-XaTUoM7o&ZVOFMI!-Uk=!<V)M!Sd6_u37MN15%
>>> zNVVd~sePZF?YkZj#)ECAEq|nC2}W6SrIp}y<u_xQ0J7xP++am~1}ltL*Mn|7!djhe
>>> zp>W;C=6<hz*$I9)(tz90!@9SUv9Jys|8A9*+55-6siyL!&aAf8 at UH;v3+Qru>?t)Z
>>> zN<1{X8#G5ZVo9l^S!T!PM&mUf4(0Bo6k7=&@rCg&$YnM$`9;*|9`Rcp3AoaR<}Cip
>>> zR(h$#bxTEeE9`MZE&o*GXp47FwoUT2MV-a>lJ&?5=nQu{8A at WM2N1dRytJFOn6J{!
>>> zB0s13lsg&5WQ%R7D$5=_tI*D(M9kPN5!N6i+zDC(^-|S9WwOY%KaJ+Z{gEE$=-X8(
>>> zlg?tex_aLTZ<VtxuIY6Swd9Z|F8AMc#=6>W6_$Sey8bQ4XUTWw(%m)u%lz10`175>
>>> zTR#IF9p&xe*zx=g4xzTo#$v|=F$<2QF)8XYt$$mE)a8IX>kl0)Sb`sTCV at VIUEuq#
>>> zX?rM|cV99`#8t{d=_|j!gD2A;n^0$<Q$^5CC{T9VgvSUkUO_XTqgb!Qi<e<!3qsUo
>>> zagpz3^?-QoinroADZvPJyF%_)5u238J<{3TLjYXX)~&~Z{8LN;>fOVcFveTQP^C34
>>> zx(+PF<aT52K;!L4*#j3KJtOlrJ(6Y3i*==d=kx!zHUOx@!L79zz4I2vX6W55Jr}G-
>>> zGZcOip?7gFco at 0mzNoYwN528U+EEnqNDM;YGp*1x&akpRVP3sRGX9fF<&(>R0QB at 0
>>> z_da!(j$<7Ip2~Cbvsiy5QK!BSx-);@*`1-iNA>T7mLqIXVL`VJfK=`lfE(tad4&;S
>>> zY!k5YWr5I~6&}T at v3I}vL at mlrhH{n3LSPO_SrWgB7y3jJ{DMujp%+KA7{-)<NJ<{W
>>> zAZF{RZ9<`DE&X~m5F0W7YkDi_&p0g(U?0&Zu_B&80?}s-cj5>8_eyHH6?IUB$N5=7
>>> zOT6I`Jg_|BzaR!LzKuV$F*U at U=u%ZWhHB6&C^fpb{&Vp`*JaMaUi5tz58yUlqS!G0
>>> zf+`_x1de9|7vH)Qx4%5IZ&j=4Q`1Hj+tiQ-{kp8sHp~Q^J0u#b#!OJ#6ry#tga#)B
>>> zPFdZlvv<dBA5GExw3VrTwZ-=`Pp<pI9QhJu?6+G|uWV%VPlHs?ah#9rBoI+v$U$CY
>>> zBi5EAJhtx8xn3&lo1Tz>n5?OMKjFz$J at 5APb+Atcglx@yg$6;>bAjEf+Gaa$U5V}j
>>> zEc<nY{GUb*02J6qh}U};QwMzm3Ds|LPbq5?)DTJ=PcDA7jQJV}o4D4Fe&GWC`4?39
>>> z2ynNT%xq3<&fr at KvFM7z=qeZ+P0E0b%@3SalAL{hKA|#|nP)rhZ!QGFqw{7|Y4_y1
>>> zvFB8x97+_CTh?K5F*;U6e)&XSHGf2Asi;Z%T<#a+BCK6~;KRHuM- at DShwTO-MTh%H
>>> zil!`j|7akl3F>i=bL}uCf*VbK37G4bGBMH68NjX>KteGAfy|x+EHoSl)Y!U*7KE-@
>>> z0LO8^q6>}-Xx-FsZP4FF3)AX1rZxIlSR!&~iihI!KOzhWU?7Rm!4AmOJL7rT?u1t`
>>> zykOFlBkBEGU~+fvDgFJ3nJ55;fc}qHEt&Kf!QQxYj at 0RBo6ZNG3ED%m(s>96kA|#i
>>> z+ngFA1#!_e$mx;6#qAwv-XgOWXvN(8fpW=U64|Q$8CZq1Ap*@CHlD>wNJJ9V3xLa4
>>> zM_y}HV`sa{{=Q%on~_gE*^Ap3?4tl8(O+2u8d1=tq&DQd66+B(57+_z->(cW0*EQT
>>> z#xP1W^$rCbA1=8H(5X{3iSA`lbE7R@)rYGpQ>~tyPw*Y6`zf?vKXWn+RTg&PD#%ya
>>> zCC|K#HYqM)Q<9Wn=$_w%6N3JrnV)XFPt240SrFOm3%LA@&f`3|%^qg1PUUmD<EQtP
>>> zJ%#l47#u^x|CPtEYQZ=_ssYb>9|KM3RH6%i1I(_jb~}g3?5x{%GhNJ=^+v2$ZLq%0
>>> zbwG_LyGKc6b(Y|mg2PNU1PBnd^U;)nF709}pq09WpU(vrPD%&X_ZM^vDntfi3IUV~
>>> z(9;&E;^j2xJ-fyK`HC5`rz<m-SYwc_w9Q1wE&%wm(%N7^j{!o?bzn~-M-x9GmrttG
>>> zEa(rB-6mKCB%T2|FyRVcWv~J7$p62;;{pPZCQ9Y{0G;~)Y6JEuj*(*~@E3%63j7zp
>>> zz}!qMbY2*%2z-MMX38gEj{}v7X9S at JnotAsn{oW=H^|iL#P0sjUpw*d*N{JVLNKg$
>>> z6EyQ;*_YqILKd|iC^2i%zz^qI-O(gqulv*w^|84D7GuJ<dsxS9LCiRv^H+hp(i#Zw
>>> zW7fg&OQAcMJ|I`po$-bc16>OR=;;CZl>@9CVBs}H8tkt&tN#Uwa9#keFLBEqIBZ*#
>>> zZy=siLd2uZzjs1c3p&EFk|+i7fAeu)0GIRt`GZM`W;H56cdo4NQlYyB%T7ArzaYs_
>>> z7_=8{u~P)2lv7x*aXUlcUL5U0rU2E3EDrifv6D_h)2KNNcpq-&4Ld4Dc91Um7qr~k
>>> z1mxfXyWP2x8DQO!)N#*kK(lm?bBZ?q7vzg%{;-RV2OjlSbRlcB4`1Gnn|1U<l3)iJ
>>> zx1lpd>|nC`4PU|pC<)N`=`}`E4VWcZF~%X9A}|a*q|2C+myax3jXk*BzqUUAQX=;J
>>> zKA^#$dhHGBJi1sU4t($r>jQF2veN2TVD3%KGs2o9U6mnEn<7hfIP9Sms!B?4b-B>R
>>> z8XP<o4=K1 at H~$lOC7^GhaT4K&N{~~Kx)tQOPVQVB^Zi77B!1`~?DP%)*6mv>=nmvp
>>> z>-p*ulg;8CU{h(irFR&l57>&MfBpr%aRYXpb9V0#&P*(poAwt(b*J=2?Vz|3CRMnR
>>> zO8d3a`3As(c6Lj`qPDc>)D<x{3?L$i1KM848&A=EJ3!^Q^E#h(3?SX3(Q7E)^v!QK
>>> z;e^t-+0a+Mub0P`nUBMvS&QN9_bAq7YL6cbE&nw3YIMd=Y at mMmjQYB>jwg~^L?GLz
>>> zr(*l0ZZ~Yw{$=3?P%s&KVyrI05j{S}<Nn6L879=R2EWsyG$y`i{mce2nkS%b&Ut?A
>>> zir6;(2)5+*`jsn-rJ;=yX|pQ7M2l^!CUg1;CNc+*!#gi2^5;q6(jVTqC3xnZ at 61_D
>>> zNL;WgmW5v~^|;uy12N>a8-_%S8&T-2+c1(j^JOTG^{N-v+ZEX;RTQ#K0>?Ire44a(
>>> zSPA`I$oKARjbXd~WQIt0$*C(lm}LlQkMRcAiKd_0MKUF_acJCF5j(JiY&88>+z2~2
>>> zG at VhkZzpb<?9|3}?8y#&4%OahnlD^e&7E7FiCUCKeFm_Qae%ZHv(vjkyIpW&lIs>7
>>> za$sb{(6%C>nOw+YKt=8v_80UckRB<Fd9BI0YUu^rKy_nd$lO+8Qc8>yEVf-3<)jL9
>>> zK8tl2*eDpa%(uY4)0cog0)^wiw9O9T&4|q%xXAOOxx`!8x at T_-Vp4s}9p5)=_VvPw
>>> z{7%0AF((ctnvd3P=*98A2VIh1D*svt&a$9d^Hgn?U<-%m-iiyzwb4&%A!>Z=!tA?g
>>> zgRS*S$ynjla2^U*HsSGj>FdlI-?C1NP8D52(M!7epafPh!;uIGw^=>V8ll($JCp-?
>>> z>R{SKBSl$kw at lMW2l0cFX~dos$HzQLqj$PMXwS*{&XmIVjhMW|0tfYuUvGLY>#dyM
>>> zSZkL{nU6v0jI+u}o8v%BWA9bk+XX~-gj62{zJK-R>4Xhbj&3A;BnY~xVFlyq+DKlK
>>> zLw4aBya1FKT*jQ*F-UP0d{oh4 at 0N=i-)87gmj`LV)OS~&`TVJ%<j-Of|AIVl<JIHT
>>> zF7t-o34;QfkAcy}2exN91XniJez)&6FTDp(ZjP<a{7wZle~<bb#U7WLe#xNUsCh0Z
>>> zPc5lo{{`Lnc1VdX2eu5L*-;XS$VB8L<an!?7Qw34cuf{%MILE5^9DN*xhIv<(w~tL
>>> zF>`vU73UAs9_Zvy_b#Qenwu22&po=Hs#ItH7C|1br;)+P=DVj>*G5;k0(>3KRocVg
>>> zG!`-$SBi37Ru at i;Do3rIKtBA0g)G!;>|;txd$Ems3wvLmmnGk at cIWWd5N6pkxW3ub
>>> z+yQ<{$GE7=PcbF6)Pdk6Q)?wJZCUc_{i|d9&$C&d`4Z2Vf9UvMl)ZOUlV8^@3Zi16
>>> zSSTV$R6wLFf^=e~h=A14qaq+6AR;{^0 at 6zaM3fc<0TCh6JE0 at eq$4c_q$3F>1W4l9
>>> z{@!!$cfR+%<D7f{U@%7VjO59F_FikQxz?HsC4*!ckVagm%rvDQ{DhXx$X~9gNYN8?
>>> z^N`gYhOk%M6b^_+p7#oTA}+g~Tpu(j_aQZVi|ZV9boN(vpoc50zQGz&3{2&Li?mZG
>>> zPk_3TCJi*zAqBdlq=Wz4PaYT#(xo;J3|I%Hi!pSLqWXXO#gq0KB#?6Ef!<XQ^lyG!
>>> z`JZAP6cD4ThdZ=MSoZ#f+^qHp*2=vGxix^?cg*(85%y$U2Xq`c(T+S>I{M{#*$-mz
>>> zV^FXY?Y1b|t8={b>_mi}uhUt|^6uV0^4fava4!Fc-oT&}dVg1&fXW4+Vip<-Di<=@
>>> z4OgpG7*b1e;dt&k4KkKcgeE|bh;`cu51uwG?oe-s!R5`9*E^C at 68b7Uf3TXg{N#HO
>>> z-u?L@#XzP<17nR{SE8h~^>X#nMA%w>a!9s4SklrPzb*IdQof+AZpE6I+tnrH3FKro
>>> zK&a3tnmBr85=E#Oz&Ya_z1f+6&-9C#B%-zY472(owhc3p#x#zg++-4QyHCon<LIAh
>>> zOrt$AirHpu$l#L-eTkb5jNeLOz6rt%92O%g9Yuwpnc3NsSFt&QJejYTq&8b<Pj;?Q
>>> zXMu*5HT~YMGj7+b3=15cI4IaYvcYWA!!ZOr;2(jK6g>-1LJ#WyVHwQGLAn7ypbGtU
>>> z7KWip+5!OD6+j<^0>6eiyns`IOf~=q+8IUS-rWH}Mc)YO4g0V=0tM9bEM^%;<pOEc
>>> z+o at xA5z7{TM}j4y06ZE~MKSnXH(hWoP82?F8hH!;jy{Aq2%yR0Uua at K2f$DcXiUbx
>>> z at YitNc}3#{xM`4V&+O;{pP=_1yV&>~+xr)|`xG+8b|B*zecX<)18(a#YS)sIvikcy
>>> zn3rB>8 at qvekcnDcy3BAT;At1~pp{C|O`;&deAsIU{IIRKpv64|>boMs8Wf>WA-gbM
>>> z1OPt!!Fx#y6gVR?1-ff%ucrp?Is51Wjyi+-ciaLKox#`)TCjAzIA|@-dww$)It?#G
>>> zzV0Ko75~40GaSon2*}<viC}2gfxy)HaNH5x6ZDR*ZyS0SG^+ez(S3lOLcM^lKg1t|
>>> zuG}7gZib(x_kq`Ez2de|yGD$z%~#;ooB>kb`i)_}3noD-<yufQL(~He_ubyHz5<$^
>>> z*@)Yr18H68^G`Jsu4t;B2x&MAP|s8P_0!PR<3LmyHt6pI6otZmMLRL=3ZuldtHVA*
>>> zso!8L(;uAOP`Nfg?QW&;RUTI`Zk>@_YAleTo=t%Fo|(16tPF#rdn)0$gS?+o+diGj
>>> zM;cS_gF0z??laJ})QRY|7d at ALzVxZjVFVzxQwW?E6yJSLh%+$DPkVRlY76|eK0d_L
>>> zelmn6C$Br at _IP{CTaUL0>WUUMo<AR=E4s^pX~w0koq)UG%HVXK3smc4q?vX*3BAA*
>>> zT8J2*SK0z11IlK)RCDoa>=<A+PLkp<FHwXH;d4V}U8|#-k|7%6I;mG$^Ph)(^jxKS
>>> zO7z|H9BAMIzub$i<Z%o+D14R{6}T at brg_{i<i}TKFy%EtXT_(r#0iTx89kW7XSjD$
>>> zzUBVe-)Y9E(Y(3nUG)L<p{I_%?WZEgJ?*|H57+;4(-1ShXILo(byA0BTlo1lsTu_5
>>> zG|OyGUF}uVvuF|(_55Tew8ynY0|51aWCvXdWSC<#50rlgXRUAR4-2#qIeDA;WnMfp
>>> zuO2A^$`f(3yL9o;aLxVY9UuO%7~n|tvg$9*4M-JrhB3QhLmBYn=TvGt2R}^&Rt!w8
>>> zpd39WOo;F%?9Y?8$lTFoa*!p}`i$Z368)T?6P;|*r3#@3^<Jv%;A+vx at -<*K*3rQ#
>>> zP|6(yh#s2$h1wF3-*KR;0ULuU_Km3XoH+w+J?UEM>+5-EWc=f+3uE)ojmkWKaA{lZ
>>> z%KcYa<lhWlU0soo_LizaZ2qV90(hYH&EHjf0)$kOO+fd;!%UI!zH#O9uD<S_>Y!ga
>>> zYi?IHjTyNpH^Z<$ECQe;*bUWa$J38M<+^NF@|9>`&9`?GQnSx^bl*xX!W}4x`&5CG
>>> z`IVizL~%qd+^$(g?;wk at l>qDDf#Q6SNSn;c_-w?^XdYdRkpe{EKoJj$gk>39qSn+;
>>> zr;nUeoX#4QOB at i5Wl`rSGfJO<%Gv3g2}LLsrW&_D%wg|x!x&cm>PFa+ at iGMUmWXFZ
>>> z%w|>xT{CVMIejljjNa+D71#`5Imwncl5scomzr=us3CTMo3zQ(F5vD@!rb-1(ToE*
>>> zn05^^sLoNu-HuZf#}9+dh8*k?&-r!#`N`4sEs87CpqAvph)a!NChNh6lo#Qt<b8iw
>>> z9=8Wzd$qU42Tw9 at +bA)Q;CA)dzA-g}|FCe#P~LBJyx0Q0_nR|{NIql- at H|a=4Sd3@
>>> zp9~X$hfA?s-iH0fi`f6di$`$wz*KlNWA_dLqx`XShyn~lSUUe_5D&cy5(G#+(zOjj
>>> z$OmeLqNv+VTB at e*ED1Vb<DGtM>am@&4A0qwhWE|uQ9Hzd*gl at Of)Yc!yvmH>L at pxs
>>> z1FLf4e-8;k9}zIX|E)VGpL~*e*YKZU*6?pIn at aYj#}{W}|Awj6$b>~yt0K{Z41DL{
>>> zCFnU6Aq%zsN=j~zXBD;S-GfX(wwzU>pBN+}iRp3LP}-GRY!9Ax5kvoYu#4HI24 at I*
>>> z0jKk|gPzq#L@`=XoAbVU5vbXmwg70aD6IiEbBnx9TSP5>?ijJ=*8mecp0XI-My8^;
>>> z{)*fF2O#g8Ul{~<&q}+7T5>Ig?C`qovi+x?)CLuRk=HN&2EWBcU4K}#WstV*xOIhQ
>>> z6x<mSLyH43 at fU9J`W@|MkPf=ic(WB>%poilGN~6t)Hjeyyw)Y?|1HF9*Zpz&AC~GZ
>>> zEO1^Sj<mI|5#)J<LTv^`;j(K0;!)hk{9}_s0k7O}a)rnbe)G*0nJP3n5}MuR$muSt
>>> z0jJ{E3EQ`dUr%Z at okc&D+5wuksda{dWYDFcOKAC`G-h|kNB^jGT+@*db64%Y5}hW1
>>> zQTEl)LK&f&Ei;<kjL{v}byP6E4MKj`T6H&IKvCl-(va*-M^DI&2X<%^M_1%1{H?_X
>>> z4~9 at BcI{2cFCKV$MT$7|8RvpsL_P^mgnWg(FlmQY#$yU?Zio)h#q&Dzzge6qyexc|
>>> zO{B_67P_1f1U%pY849U|fQ`U$%3Kg!lYKOT9aNSQa(NJ{L2lQjZJ{*^en1K7(=2XB
>>> zsrn-be^2gYe^Q|(vsY)?`N>^95UcBV4B2B(rK9K<J!Mp_+oNl@@EecQ2YzDt`#;oO
>>> z6vboPcFNEaU=81gus5!3O?`O;eBw7%U`+{cQR{{cvZzri01{dAU(hs3?n#=E-`R?i
>>> z>kwPb|Gc8;F{;yEZkcJD9SvE3Dz^BCr7B?oMK;FnT*e$hjcvJt^8*_OQ3v_1;SQwX
>>> z5^6Lof*GL^2<k}+n0K9;F;opJ5Zi+WKNRR=WNNR)Lbiwx{;+)Lv$Ds{V)MWUR+KXC
>>> z68m<vg-|rWzbRh%7n5LjX74VlGlUMVExxn;hvimzU at U4WVxUg#-(^f0Z1P~fW+77m
>>> zd6#*EfZ4hD6tYE40s6`R!Okt*0`bWneg at v>y8`fzgf8vD)(~#<r!V|R6ce(IYj2Qh
>>> z!R+w$(LDfuh+ at cW0`!uIKl+E|{ts{#%hB^DR6vTqPWkHyur%oAo70RD+CJ#afd&q5
>>> z at L2eDfU_{TG)gr5j}wn2vor5n|3CDVO*%L!|BEL2w5x;aEF+?Jw+;WW+-+=Q<h0|*
>>> z1ZP;!pok~xp|ADfF{rO&5b`D}oDFXb?!#dUIlvr*tl!6-LaiA8!%+Uc1W(TqCq|6^
>>> z>k3&Ja6i<eBhX!A?(8*ssym=~u->?>GngM)pQL&Nb_a0B2lA$%COUsup5YAQ7nrB5
>>> zv&jX_BjSG#dkI)`gV8 at MT9c!T;wu0{UM!`-|FC#M7%Eevb9g$BA=8-60mQo*SY})`
>>> zcEE7Vo at wMn#xY6IU9Vbfca<;mjtwlEPC`BN!vT^*JObAN_N~6T2HU?sJi0X_9GujU
>>> zkBI-J0y}Q_- at Cs4{V8V0pk{+Ywm?QAbYTyCcv>{B31Cj6pNu0H4+Qvrysu<GHaG|b
>>> zW<Pp>?`BopwH{-hhNfU&eioz_(H?z#gle|TV*~oyXHfSfwq19?AXxy2?a3X?_9<{U
>>> z?~t%dteUGxCt_*+5oW<UFvw~7(i33)4j3{d#n%~>#|c0z|1K!UG<Ok-$5FOqQ1?DZ
>>> z^RsxuyGGlvJF06 at IO<gw$gUZ9eI^Iaf~vFEfX$!X1snNW!Cy`d1~%9G3;nek%<>&Y
>>> z at Ub`8x at o8CqelF|dqK$3(b-Wt?@<P-5m!_S4hQe1IyhtJUGP8>{585=GX{{mUeEgW
>>> z!2evyGkE$*y*WlQ!iO75F~cy#LU6jnu*W3aRVX19vhFgi3Z5ijv=(LRk+0EJn#s7s
>>> zsBc*jA7+EjfqfDgl?ob~`xqtS;m83xvJrF2vmGH8__se6$M=WjK`)As58+^4%m53d
>>> zpW?lz`|l?bDZ^|*t-r>ELu~&(-W2ckI`AY!R=B^QHa{X6n?ZWab4t9Z(Hi`2eBTIU
>>> zB9fctUD<ZB*DKHW518JNgY-Z(slGtbE^;ooUnl2GYct9!u>;VF7^aacMVm>){}WN+
>>> z|9eDbsQFK at v<T_FP5^E_6JT;|GHP at 9<hH))eabYZEWlXq=2jkTF_L+ at Sn%`e;%Iz1
>>> zeTzAH6GVlms2NWizyjEd1Dep$>NGP9^P71dmx-B(odJXx<=U&O3AynZD3Yaf8xjSQ
>>> zg)tA9iaR>Y+FgDut*01H<%BZSZtZas*;hBnzKxJl{@^;^LO&;xS$lrg!VgQEE~mVo
>>> zb+Y~MjZMo366Mu`?a;vDNYGCHmDq1X)A at kmShw{84;>sHk6=4x1{lmk!?mh9MdGbS
>>> z6x0H{+Cwc8735V9KID0-A|Bip;QMb`VuKUv`YY!;Reee-bIMfxA_NFlJ)U~}5p6XM
>>> z0|=_i<YZs!G;_4R4h?piYu`8y)GC2+$WD+vA6f<%SWF2(ewDkBVp(1pEuVQe^2Xcw
>>> zSM&2{3cy%#!dsS0G}2E|$O_^_AgZ;wA^I=b$n1q~9;O)WE|)+I$-JvjcCdJB5vYB?
>>> zC<3$~=lpTminGigdk)KnRV{NXXEWb!!1HW2CXUK}yJG2dtm9!0zw2~gXU<?Z!k)Ai
>>> zK_<`eHvc at J+CT5<NsUsZTbL%}ub><zwDZ?J=saqKKP)kHFM`Jb+Gz9X+tfOBl`}(D
>>> zIdSQZx-YNzJ2;ra--W!L at VOEj8hcQYBDeBu5AGKO8bZ0U2{bx?jvuCFyQVJnb(VFt
>>> zjQa>I{^Glv#FWPtu#gPhoq8zB=P-Nk;ij2SSZNBjiTfq|m{_XeDY_~-v)ua<<JasP
>>> zsWXFHe^}mhRv6L)>Ny6(FY{jR6AUfvG+OiaF2_M`&Q`H^+|54ROeV&Qbs<Y%hPunj
>>> zdnVSUSJb%=y7%1C$k^6|lb!zl3a3cKr#gN1X!XO-P$P<~5#xnJgr~y$dbO)#VIxQm
>>> zS{`|sBvY$TfS;zhwz1y3(qfN9E7%W{dbgG|*Q04`?GUm7I;3VoUnyJ>!bcOHhg64;
>>> zuh>p-8JfMlf@!|qxVXIYj<P}cUAiaF98iTuJW+SPS{QU8g%1nrxhLvh{|L|Y3z-Q#
>>> z)7Wfq^ZtCE)dodi&Of;YBVceP!mkzyA#)dY*2$0y(4O2!TP()Mo|qWi$<Wzo at 9NuN
>>> zEC(e)vt?ReH5Shc1xb-Rs4Fz+43vvGnt7InW}s0h!rC$ED;M(J-0h^C&G&~9U&S9U
>>> z2 at YRjtBrl-x&@)?Q+}6H)TqbEuxPsem8s?R!>iaL%aXyeE9wt##;<(-xHs1joj86t
>>> z>v^hZve1L%@SEH>cT%@E?v}*+r?gCa8Vnc?d&94+%d*Wp>1u9}YpuMa=%C*lr!$o!
>>> znp-p at WvkYtFdp!@pVmo^U>*_7r$LB$Vd}i3z6f)x3Un5z2Y;eeqrcqr?0kq=l%DoQ
>>> z2jB5*sC-C})T+lp<`k;5FXonn7b&oh-S(T-S;~RXTkIni+wD+3-bG;r#v3LJZO(Fb
>>> z6v<C}rk1Z|wR|`3%LT{zIT`nF;M~?@+8c~1K#c*6L(6g(CBx$pM#Ox~>rmrxwS{9F
>>> z&8zE^Tp1RaLcbr)l&c3W4yL=bJ;_9G()$J|miS=0iHd344{XXvlDl!te2m)^ZpVK#
>>> z at P_z;Rxk;}O)I#iZ_=XrJC1ZlB|^!{d(*2W)@kjW`sg*yXFnH1RH=>FxfFehcpT0N
>>> zK0aYnNzRM>&2LKXh!h_znhn<q=hStZf1Dv|a9w-MPo<rttv<S$oo7?{JIu*1IK<Gs
>>> z<dX&vae-QGRRu<(%Ce2+Bcusiu$pC1dv2%Tca<hwbfR474mP4SmnikD%fNgnd3;<q
>>> zw{m0=(hY0Afg*lE3ZTX&a)BSQF=JfUV!fMb;JOp^pMH}|ZVL$U_Jv~_u}e6SZB*_$
>>> z2&-(c%zA*M2C_sWYq=qXNM7LPZXZN>EGw>p!u5<i2z6u*=Z*OdBf|b2SioAjcfjQn
>>> z-)P()cHzqa#A3~$)Ird-E}#N1gB4v)JfGPQAW_B?0yxP7Aeu=G1{<Sk`wz>m{E<B=
>>> z>L~!%Ea`FpwW68nzn5p=G>J9(Ywnj&DmMTJ{jXqGy at 7<u7ibHBUT&J9&1*Y495BX9
>>> zd+4^rZzx&c!JHAUZkd3g75&C-hBxDGP>TYP<vZZU_YZ?OkDubiK&QZWZ$5y3 at ZMAh
>>> zi2HmjlxEnj4jkWkVK+d8!DmB&Aj^B`xg%Y}Wy@#mZ`TcYtLey<EqD2ZEKNV>7Ameu
>>> zcDNsSOoy)TVtkC-%2>DHvO;PpR76u0)pS+yFdgO%Nc#2wjfM=VHMAb(STbjW?vA-%
>>> zLYG|bY at eO$e4!Wh0OO+q=91-OO<~F at ljg<LS&7<7|2eruc*C?6SM&ijHeSkD(f;oR
>>> zdhf&`+Du<fHbG*pZe&toOlS~hVNiR+BXCa at Ibe6RRtZHe)I4utqgAbR+AM8So-073
>>> z6uM|7EWmgVLU7<lrd5ia>6SC5$%pK-{R)dNggj>#<nU!F3DJ^IGyHH6mmO4)PH+Up
>>> z&V<~%?5l7B$P`j^2<XBgJP|IFNpAUmsgE}TE0tRY9v(WHWWd2}YEpMRc~W7}$_<xV
>>> zyqirnAtAwlFschE=+}^+T1hf~5tF9$B+c^2>o at A#tV4ut<Ggx5r_~<vByEk#Ju0_S
>>> zNN2#C2QQRAVVP`KUYBK|9>3C{_O|UQj;x;+HOB}kr{%oSeNaiMpEaMrg=zLUwsIR)
>>> zr!#c1bz5qJwuahugKI?VG{H2VaMDT4v{qw*+>a3L8MuFVgY)a#rhq<37#+po^Y_3;
>>> zraMJ-d8+vMLgLf2uh#zD>tasB3_CFZNstX7ks{iR_jEHdiAqcyY*qEEExt>ZEiBQ2
>>> z`$VN<c4rSDdu$9jb6$_aPPB2>9eR|254(L2aCNLnG}uPivsCN~fZGR7J>tBW)-)|S
>>> zohLLoeprbmC?}Y*+JJkAdcqye*KiE1+Oy@|+~iLOF>OAS#eiEsD)D+BrPl#BNBJ%K
>>> zgbLUaxn`Bh;gav01!}7N%m#+$%-+dG0pc2URLH?^veL>wE5z8^OV;$);>x7h`V+bb
>>> z<-&*0$bJ<0UO}gfoss7ZH&0G^ycV+0{n7DOolTvPq?M1E&s=vEew4XFIBDWqWM(pd
>>> zLhfQk!q4&6y0CbKL)qfu?|Erm;6N<Uo*}O98M<PQVIOQr*Ij-v`?EF_T|OCZruj1R
>>> zWxZD%VXFx{aqn|irs0gO`hk}z!%Oy(2s1&H7}E_`EestPjQk4Dx`n1t)1o$;fn=A1
>>> zgcyi1+z0Pfx;r9ykyD`2*MZnKzR?Oj4p1!?TX%-U%F&fSVVx2^ZWeqFOsaVK<o$zM
>>> zmfthViWBs6V70=RknA*PqTvC*QsVHN!t8}q+lDmG-$?;vo5=T34~_f33)oUW^>x3;
>>> z++n2shgTxYokn({SP)*)>#n$?bbv;(WxR8>MowPw+Tg2vB#oNxn}J0VZQM9)?;5~u
>>> zZ+Dre4mMDO5b;maI^y|z`~uk%DB&>4O>)1{%f+62(X1?toPx$Lo}!%<V3jsd|7VA^
>>> zCH#MM4D+~H6d?`D?S0ZyJcRB=LUZ1we?0yAGX7dbCcnoU!t<q8Pz9j$|Ho&H at Kz-$
>>> zc8T%6?KhAar})sJ1d-t`_2UFtl^i>pGjE6D0zBuQ7u+r{>Uwwar&7)!<{d*$dqbkn
>>> zz5__Y)Pn5`#FZT2tTW8;BKjYeuCn3X%egj%YY{7J$1dp-Elq{rUt$OLAE4hRedz2k
>>> z0$^Z!L*|4&{Cb=Fj)w2A-RyP4>>(j_t?x-w`oPzmP~T%7esNG!#pe&ptIIR!-9xZt
>>> z$*j-h%b5YAvmo$c`%Qla3_FxLE47vWoVTY5x_%-14~qwC(O3hO!<Q-Uh}u31B5Gqz
>>> zJw`PPgsg{&X0JN!%S>ODqU=#kX`Mt=Fs^K>BTn7gp~ywmb)od9sH*94y-U82$Aomx
>>> zb0Bcj*fF_ at B&LxEMSJnD_v;<Ni9+qy!ZeT3I`?3cw43b}qoV=xkG-b%m)AVD(1|-z
>>> z at F-Bta}6%lmQX|s<@&lR0Z3lgX=}_6sCKo(Wpbd(8<&sd>G8a>d$jbRWWn)O*A3{c
>>> z6wsGUmSWfBr4>CxEeJe9QGdS$M#b18_{kWUF98$iptn4!M=h`A_ at MswgLE@iMcU5B
>>> zD~~=B$N~DOph1KU)Ei-Vk*X`<^+g5}%mCErH+sQx1FQA_Y`mvyP%0{&N$|K#S;~d<
>>> zq}%qNmtjg at wdD_Z>pJ?fh9t7izZZpVUA-pAvW1Q8qo3TPdT%t at inkWNsMD;LSlsM5
>>> zQ?U9WBU0d9q;eO_;h6?0_Y>bd{ht@;9UGjl=-u;z=e=v%jG}l%`1Nro_jk at 1Ny~r2
>>> zs2dO1b!v?y;TqQ}Z|;mRN)CgFA_W1X;vyilqX&>n2v##tHOfzue+r$wJ)njfj8&wW
>>> z{oiYB&`ltSQvH{Xk@(`-6#C8oDzPzyN!Hf*EW*1}I<P6!CE5=j7AR3|n8wD$<SH_h
>>> zF!jLPo};WW4NGUV8E8;*@TSL#hGwqaq#LfQAYXQ>ugL?D;rX|EXVJRF1xkcJ4gy)y
>>> z^Gm2P-p`cms{+?gtyv-k0nP~e0AlBt at LiTdpTEul8D)6KrGw%w#~>lG8-Q+z0bEmy
>>> zIb9!M1zx*<@!X5MHlJ7nC}<BacsKXIQw2G^Omg20JpCyf%Hkikn~ERgg-Z}|WUxpB
>>> zk0HG&tJ-8#JA at PJvL;~Xva3kX6d2yBjk~Emd{=s8^mvzqr@*TRH?ePdQ_jZMw*^HJ
>>> zur!I-=<^k{DDoI|8(XIq7=qWiFr$I`g(bqj at LL7NQ89`+TOaw~BuQA_&tPjOY#lJ%
>>> zkL2A*iGw~e{5jvA*d+sgg00}4TF(TpES+61w&jWwpA2gyimIPhJP5(6{`7ucoiU!s
>>> zc=Ctk=C21ceTO_X&B7WzGtDGRS~}h+O6X5LPD+tekj6{m>P1&8Z?ZSxD=Jr(XHE*)
>>> zcf6umt>5gaj4Vv;>)QQ(JrafQoqmhWQ|Ph3GqU-~Tjr$s;Fg=J87J>>a<d^%Ozf=c
>>> zi7IRl7$wxCK$mzv&_nQu%skg`vtBV?pAIYD-nn@$Hh%IIJ`Qnw?-Jb<^c{JO&omu>
>>> zoSHlvz=tiewp`kE`F^{;^~$#dwI?cqjVhd at k_R6n^xxfg9n5|^5SP1>4$rNqU7M9e
>>> zvOk6MJG|{i9duL_B2(s)CBFulrrJyvm+w4E+TOBi$lLV6cukaRX2<*%+UkQ^CE~6@
>>> z6W%o4=DBw%EBYeK|N6srVrY_b^dI=5Vqm0p8IIU=q$aZmd5H0$NF6Nf;an`K{_^t!
>>> zRabA`t_hKuoB58%^@QJ@>AZ0{ev9ZS3%3?bG5w%N@~Q01+l45$?KmJhE*6GoyE{J{
>>> z-<1)?EFb`K{f`N6pAPI7n$J{L#%4C`NA_lNGB65#$1VM?z$lt|9$$JmQnW3r!p+Si
>>> zmG9*$XLoP~gu-vi`fRkpx$b`^tS>#6#0DtgrhnRqzZq$CFnv1Qa4|2?rQD5~*NrL1
>>> zHp|g$AjN%=3T~Q{J)|IMPLmr=vy(SY?btImrK`527NjUZY?t;8d6YSts#WmG;0Mjb
>>> z++$@b$k)x{eL{n7WQPUbH6UzSZFJK_ayGOql_u2+%$%V|h at B)2jrB{l^&oMfujZj-
>>> zCM!}M80kL!WwDm6F4XQDvxz*#Y|1PwQq3d-;Wk*?K>PjGzB6kh6UcmwQd`~SxK{fG
>>> z$5TfGbv%4sCp?CsBEM;~+(&d09j~&4pE^4anWtdqQ>ZwaR{@QUN~N at JQ&Xfq`bC(f
>>> zSPi;=JFgb}l=&q36eT%fN at s;dqYcUM6K|&YsSzC`h!)=ZaI5lxCo^Rgbwj_js}q%f
>>> zNczV{MtAeDW>jk!80b6FKza=u+;D-Ws?Xkm6dbJ6&JijR8^|CRpPCX3IeoQ*B5|-@
>>> z_WZYBX%9q>uJ^dq6ik>cpv?SuN!?W^RsFsX*({nxi0QQLb(s#LwFa$iZIwQ2YLN5j
>>> zJZuDMILGFp@^^HT9GCt at irCbLfmFEU?Q37y*un*bAO_8q;JXQ^(iFx4x)FdofTlY=
>>> z4_YL}<r;0ZjZ;YzrnICF?LF%g7E3=A9&5x_tSik8>oLz1lP{sVM=7pQ>d6w25LaCv
>>> zqU9dGt;IE+w|FIo!0WGCQV<i9<UV2rw?@cqAoHvNhsDN7$1Q+d3;hI?HrkInguFzP
>>> zn(=6HUE}pTF~?liDI3BYzAIY2%XLAA^y&rB>yY%?+QcTHh!YSt=z{CtOm3)}9P=jj
>>> zGm;%~oSfHa_;NQQln(ji7h^mqr|7RJ;V|M9ZTS+*bD8&`@{FJl7~m%^y77ZsPclFA
>>> zdyU1nwi{DQxSJ$ppz%SxCI3!SsKCx5tw8e4FTevixQ@|5A|WIN0Ue$o at dr1ETaW8{
>>> zW`T at p#_3%LcDLFNg~Yb1O+orLOQxpDsu8mjS0M)!gdrsvl`WtQOfFJkk8zbrvXFI?
>>> zZs_NseBWz->MM27 at l^XI*1iikOK-+eEs9*Y+;hWY&OWNWX#eBUOTFv7i4w1=4jMs0
>>> zXhjM%5=zK~vnbZv1*So1`gKx*6-2j>E}#12y&9|H?RR%Q?aUv%a#Xk?VgHm<N$hjN
>>> zwz?Q;{*dD&uXdPUMTXgt69y-9+>GbS*FHPzcH9;n&Ws%Z-ZBK)o8`!ELD69={_(N1
>>> zFYgbFU4tx8WpPGF;DwmSX(lbqeKGL5%E59kUlhvw{)6ZXm%b&m^_f2bM&|`=*auEF
>>> zkb5zb8f&6oh%g*70tEmW#$zHuh}uUUL$Hs2DO4GnI2OS%s3~kQww!tFhxFFDPw&cH
>>> zhxhbbnbz9x#Hw`lI6qQ;oG_4*c03w&xytIb>od_&ef-XubhS23j;9TQFS|?dg{B!Q
>>> zcI&@>MLXw?>)tWwyH(b(_F)}MKS7_9i)XJs{THIG8IHr5cTdi+GoqFLin*~7v{yz6
>>> zeLv at x+u-D|Wnt-|2cuzM>ug=-4*R at SU#(TIG7;EFQ^CS19bpP<5c+uvf2eoVn#^W~
>>> zt6}2zCB3Ug7j=0Go`~tN3oLO4`fHlOIg_NNM{&+_^%dnin0K^<j-Te<B%4yYR8mXL
>>> zYcZcMs|GwnWm}<@UgUqT+WyzzIU1Jew4z6 at B(iq|v6JM&)o)YwEn5#*d6eG%JZ)89
>>> zyYoYr&E2#@Yf+-32kxxB%`Lit-}s`eB;M*UCSi<qtyaozc%!$e0sR;exubNNqR7!A
>>> z`RqAS>k^{>7vj6O=;o at kjPAv(=-t5`8u-T|`9BMvd0x!txjg2cOZ)#YC~gifglxng
>>> zLY_rfQ{-Z|Fem7DDu>JKZ|HSJuB@#L99v7AV6(o=CYsKtp&_+`I^gFr*n~NZP$Do?
>>> zT?^urZVt+9PN>M<d1rO;yw0oYd#q0`cCx^l$?Z2|8tsdDUB#SNo#wqZGLI3z_}IRC
>>> zSTL%ql{@0Q^mB0NZ`#|~%s&eM;+pb|2HIsW92rZ6X22&zn8vmgdnOLBw*wZg+o0$5
>>> zzm0thq9yEc&@a;RD7CGbniTO!<ax_wtJY<iR#k6C*0nHuQ&zT#%k4bg5B;!(b^OEv
>>> z=s|=i5TxE*Ec&gmdQ`7+&`qpH(g8Fh+uvxrcA(-DxZk#?RPE at dIg8XS<6jx8SYNMQ
>>> zuXZ`!5 at At7camh|cY_MP%O-VCu%|skOP4=uTK!+Esj(yYSm=>W2#DklcyqJRGXJnx
>>> z4sKd^K6qpKyjn!JDgN4W=y~OKQxvz$I(G=XM7st10>!t*%}-Oar4;_o@&DMFrzec{
>>> zbyKi2>Ed}AEOfkLwO>5oOP@#^tncDOLW-zcP*4D(B}Coq+cVse4b3yHci@&-iK-mI
>>> z_5ss at x*CM^Zd(9s9!=*dW#0Apube3|tPLamTQq$e%THS*-)zPUGfyox9HSt!NoUmV
>>> zlnjduC2aa<#hWLKyg7SRS1_*D!Tqw`@1U3Y(OpaZc@*8pNNu9wiTmqZGL4QF?Zc8L
>>> z#>vT3Uv?oGsQ;d=MK*LWKLtt6p at QM1kYJos531F-;mC-(b^aNbL+5Kx4-eOUxOMxR
>>> z#IF{C{c9S}RIoW&DzSTzJ9EVJnhJK=yc?CR*qzGV%=vhP(;Es*fV5##U8$87R-KHg
>>> zJ=C_i^zNVVPysMzW at LUw9CXi3(I2$F{O=Lm8Z;iqN*AH*HI5sG(;Yt1V)O^g_V5)q
>>> zFQ7enj0LXBKYJ8?J@)eI^jFRO%$`gRMrIM+6v6++4{H<y=WC{T7etDUyU|zE)IZs`
>>> zBj$R&?96P?yqf3YRm4^XDt75I$R~SrNc7GDxq}oT8411RXNk_w_A03T`4m(b^xZ}!
>>> zoyUvVUQELN+-??D>R)we5I$L#4sSaq-ETd0C{#aq*zA2Q<l0ZdKG!+u7><ged6V^s
>>> z9x>`NGkvRRiVedcZ9A3mu1foYXk0d7_V`yw2N^p)A2Pk(t5ftKnj~;6yW=cJ{Kxwt
>>> z-1~(R*5JZ^Yt)kr3>a;5wD6A1Q46x$a7T|6E%4sD$W&5du}+B==9ZbAs&`K6?5W{*
>>> z(k*OaeXfd9yU5$LK+-(t5a^c?GP#pC{JQ#ss`;GVwnl2u$BCNy!BX41ATBuoyfu|$
>>> zY5F2NWOF}?k^?+RFtZoF$q$lhhaq%VG at N#!udx}#V=u8l=xsbFq3 at RyU_c|DAUHs3
>>> z9!nZ!a)7aHT-g(zu=Q&z7IG}m1rh#jIp(!3a1o{g(u9eI3v8nI`9Y0F9VrKMOBe~V
>>> zWtGuae%)HHu!c@)DQ?-Io)QwTMAKS`=oM`;_Fpy?0&MEcUcKubc}Av;Idwz_(i5U{
>>> z>XP0gk6MX^7L3)Nrd(A3z|<K*!gnd_S<{MQYMZMcXqd>Msv837{2T@!ztW?BW83=t
>>> z?Z#zP{N3iC-MN at mZ%;53`OlIRJtBWh*%}LTaC$!_w~%wHJuPebsoj*e%kdlu!EiOR
>>> zch}W at 6&aUkeJ$ol1)3QN#qMG<IpJLMJHaz|s_TiFgHB!)=~-AX>sR_CVOJu^lM_<$
>>> zY=}B&3{tANZ at -HVoE`yZZ}aC<5{%A<ae8=q2YGmH$f^)yyDqoi!@ksAmn|BfUa-LZ
>>> z)%kiOFW8LX?Nf)WObBZ;51Il&xV~V_rX&Ie$PhO)$YL8qXcuse%>WQLTT)!bv2=ZD
>>> z at Bq*>pUTF*T|rF{Fc1a+%a$O4YPV!GLw3n{dM$lF&<le%aU6snp_{fp<yow-6eriJ
>>> z!xrSft$g-+acz0 at mFvbN_=c;<L!#0BG%V?p)HlbWFHyUwj=Y;&*xIc^u`Sd=mjG3l
>>> zfbe+tRl7;MF&_S7zm1hXI5=>}uA34 at s}q6Ps+dx|?jII8nY!OWPDiDej9+`fc*;s`
>>> zm1=!f3g at e7eS7}QA3ZaD(XM1{^ET7zC0zq>JSQ#RzkX8RAaLNB>PK7F1)J(wR&)XC
>>> z0rV%4c?Ka4BIXQI?Q!<lI_)Q%=_fCU4z5^p6!cB`U;3hbulD+yRRaXzxj at 9Re)XW-
>>> z<qa1wHUe>j3e)of<s{7E)!(PiwDg!(m^<`|x;HI6JIuTN+9+7~@_Oj{M!QCR!MDzJ
>>> zA=8b+GsPowdlG6BOaaJP<~dsBtA0Ya(qVFT>W6yg at 9IS!+HTCr`b8hz+m8`xd$x$f
>>> z5J9M;Uim<w5#8fGd&7 at 0xjvO~jtZPE4~J9sXP_e(&v?_IGEHY^<Py?MoB{Uc9)4sE
>>> zIX+&J at Jsf$_|ehss1iej`x#I4LijDSdu(nq`R>{{MT!y{dcQ9eattZE+ at OFPs`Ji*
>>> zyQFB%1?uyyk4PDvWAl=%ul*|htmBn at fKjWBT2w)7UR;x!sWtxAD#LPzm(UmMe*xYy
>>> z*2_-{lOQbReIr$;+hi8hj10!?$=5FDjbGiqXSZm+T>-m1IX-zyEX41vs!pu at Dd8}k
>>> zv!QrJ`nX?Za}Bl;G7(j_>Z_kF7hb2$yY=3y%+5+%*>CFba{ay;b+#t#0*vU<k_HLG
>>> z9Z<mTTdbLnth at ek@k3&Jkc;1JRkX;rnCG7DNAi1F_rG|`#logW@@;~Lqxj1d2I(lG
>>> z8t2nn(Eg(Mg(A1k<&sC|hJ at v-$34F({%ln_U^B>Vp!;bk{PP}M58JqdXIHmuB=dR1
>>> zgDey_q*Yc|xyW){)+Wiw&DB}0BdsWL5T5>bv%klc){cuNxoApNCO0}pZJNsnbWABf
>>> zdGwr+V1jCC1Zilw-J>)>_w7eB6}zWUP0B!D7v3ptwcW<4Dvy_`Z^(BsQX_a&IIc|&
>>> zLCC9UaNHE>pcJVoBjpdvxl#UdQcj*IcYgdyAP`YQEB^(s_4(c};QebjCwW4gb(`o6
>>> z+i58<)-dQcd7i`{!IVVs57c=R1%Bs|nYj*oLMeQ665J^wtv^i`D3!n9{80KySHgXF
>>> zbxR67IFT#Q0mBg49sLP8j6D4qcc_8wF`gR%_5BQAs4+35T5bs(|9wjDO7GtH^Ac*a
>>> zPabHW!on|PK3|4nwIullCh&$o=zFaQXt=`ql1JDQEE(zDv+CB>=?q^f^sh$3ph7sp
>>> zdpx&y1{-w@({aVprXrY>Cg>9niZ(7EjXY;@T6&(fxiv0c{?KwykQ|wtI!jX`to;;h
>>> zWFDu)W}X|^TIDye7Ras~jHT!l(?2Z{Hl^aZ&(7g)(%lFihw0bJGWamM^9N_<xgWA$
>>> z9m;BNXc5!pzp5pK`#Ch7i9<N#gLP72?pw0 at ILeor(yD*(D(cNh3oL9VHh at jx1c)+;
>>> zqu;#L`5wS{UwFFYF4<0FDNv*D>NW(VD3ODkn}Pu9sVb)8cY1WSWG~nM9{lCw(xY}E
>>> zbqo*OODM7z1w57EKb|VE8B?*=h(Ap?{DBaE?~*B!W-+{WVxZ^3z-a|}mBy}<jdOJ!
>>> z%rm8AB~TzNjoFL(iCRDNJo6|cn91#TbcQ=Z-6 at NfLUL#?%))C2K2GtadK^#Sg8A`%
>>> zzB3yTy_f at wVtn)`?#E(35a;|1_l<BBG>^8a)?wdJD;4V}_G;}$HE`4vvSvO-gepWs
>>> z6IRbl$a%ZgUv?}jHz at 7dpYM5^+vo8MU>kHm_E=^S&Wdwgs52t1LXA!v6;};<^M=R_
>>> zPVh^5{YvCA%LWzH at O~T5e4EN%uO{j$Tmf;9kpRMBQ;J(Vu88J1bBD5 at u(O*P<1<q7
>>> z-O$`yAnxt9;|)VED+)h1$x}JiqFXvKp9}3Yv_Ti31d4xKzw688G?XVTEV)|aGZ&k~
>>> zEAV){|5JzAXICe$J{a at J;XT!`opKb96AL8^nm1Anm`ElbzrUzKcxfaPWJX_N;iJD-
>>> zA5{*n989!7d3U*(_iZLmsjO$x!j-082w5K&+~6$UhT?6YK2_8^&s|9maIE(tZm&3z
>>> zp~Qw7?;w#|LyG#&MsM&&BXXSGZ$2cvE^{us1xXLTsG}Zg(d4OU-JVw(4Z1Er#9 at Np
>>> zO5Um9U-teiV`?31;_B{5O0^xYt at u7q5^prYOkfDb-&82m at qU1PU69&+dPa)ScLdo8
>>> zVW*!1T%O&fL3I;~tef?%;leGoTeU;d)8cOqn>%pvjh)Cz!K5j#!ToO6cB#c11WD4A
>>> z#9Dt1xwO|8O$}%43V~WHL!J`NtKDDC*7J4SUyBKNX{W%XwkCHvsAXi?0t!Esi?SWQ
>>> zsUy4$v({PrLX36D3G`32KXs<-ynOJ|ZKM*i6C&^&5)3I1!bjD?T!R=fL0LA=Fsw`3
>>> zY?+L-ari}l<;PcNus!hpqvwl7V-qirG?>%g?FrHk(b7n at g<dA)wvn)+$=FHwf|BFV
>>> zH~*bf`P1j83roeT6=)F=6y;c3X~z?~rV-ku%yN+?Jb#HzS_EbC3Z_5(>)SVYMK!P6
>>> zomz5QBbiIixhsSHd3ncx@|oe!v3N!FNr)jWvFeQH<mkA0iV at z~JmqVx`pK+L0f(mX
>>> z77_FZY~Kv9j}x>rbqS=t=$?3_n{n6rSu3xdQM~!pP{V$==d_$eoz)K(+5VnYVfR=c
>>> zvIxwib2r!D&9p2_XVzt<=pn_M{8DbV?A`+`$>(w@{k`eIagd{{tE&P1L9;0J{}@hy
>>> zYlQ4v_6UVg&o4rDZ*n5`z_}5i8Bq*pe52HZNQTGgw at OFKqeiSFpD*v-3O>^QX&-xq
>>> zeeA`hRtntOPYz%)j=zdB?2Ci8lg{IODIU4wde2S2Q?8$A4~u?r)XgZ71q+ENQ8(w7
>>> zZyo)dBE9AoSc}P~wUH`rwx$atI#>wkjx at JR`o<;C7+mrR^47ld{g4W_Lyjh))MAng
>>> z^0OXof=9hA6axXJ_E+5)9r>*P^7i9S_(!unh at CDajmRFxR6?9hYtocUF{v0xos;@h
>>> zr0~;7_Q4zZu}4nYY~g3=c_FUjB=wv*<-`4OzU5(*IrJ*o9-ZApw+`=Ks$5B)F_N)<
>>> znVgyNWL32GBXS?&4(;b>#0^G<CKm!)w|70Jsm86RZbRoMzrp%yR57!y=2o@(EUpmw
>>> zgV~1Sgc0XgjuRjFy7#-<ofWqpI=WBr%IBSHjB^&W72UPebypPa!dl~)x3WW0E1X9*
>>> zQHg`x_1Wr4QhKtQ8xLXcm_G at 3?TgGz>A;7wmy#{}q&>3|!obLS0*ms>0mSxEGE<2=
>>> zCR0klN!E<FkZMj(g!}KY$7fz9_j<RCA(FzgFZNSQ3ydkAu%y>tur*%kIc~{WDal{K
>>> z%=;aX^*A5}IMmJ=_<n?WS$X38ZGGv5n%AE{#=vwxrk<D%rZ2LnKdZ}3-krA$Xiv^v
>>> z4&a<lE*KkkNp+jll8Vu*dikn5;&Vwt2zPzZRsYu=mz%n{rm&?eBOSzPJ_-ZLLAoPQ
>>> zFNs*<H;!BF5s*^AXb=161aWs_f2vWNXeQ(W>aAijBpz;CGOW<G{O*LS>q$=@O4qqp
>>> zm(I=}vwV%FdQCUH{a37G9myP{sC0N{X+kq at l2AZA9t>F5cMt56GUTOQ)7eYq6f|jd
>>> z(N$@l6n)SA-~|f{t4$REoKNT+Dt$4UGM<CX3jp9p!Q~=aC|9{&KQ_7d`r((%S|t0L
>>> zWxE@}9fdATwHJ at cGp|ek#gpwIp;l|Dr?->gOIPQnJ_C)pxM(ODL<}=_AIK at xESd?W
>>> zl%zi&hB$!wVzV?-<Av|84Dh;<CFVCHdg3Y4nLnB=NAu|bK>svT21V!vIRDl1DDnvN
>>> z+aDG#BpbrAf#MOmwI+yP;t#l+`n-5q$!ERoS6zaR&haLJZ;wqHr1~3&N#c<qtvA$D
>>> zMkdB+z0%EoSA?=^JC`5YU6>|iRNK at shV#02>#tNMVSuWKYF3OUOl27l8OXsFK{K#V
>>> zbCvLPiLL!Pb&b5y+sZbH7t34n={N*{OG!nvG?1rt1W{#<@#q$pDy$KC?jL9_NKtC#
>>> z^lJ5GiqYP2Wq)=#X*a3OmF*~ULg&}Fdv3aH(tcC$z^2-7g6ZG11>@zBRcmnmW`AKR
>>> zR at iaXPO+<nPC?bUZf5%KO}~OylyLS7*>CRX6SEaHAFnTq=}P(1M4zFKA=IZY(L`pT
>>> zht_mPt$(<0lDZApF>GzUDr|GB at ZQSizGKsf{a{vz8rBb|HFU0qT=8YOV6j=<=InTX
>>> z70au`M_S{bYDw){J~CfY>A3gQb$%@dUMk*%i>)bfLCTXqsjhc?bs2x&<MzC3Oik{D
>>> zeFb at Jb!dcc*s at hTkOSuy{cI8dcPjkDa^)LYsf}Lya$#n at Zu<4-`xMWzYMCDX at 1#vP
>>> z+dJ~5!-|iFsp?^<zo_-A5zd at qe3kX=0vbr}EDs5*ZRUdL354Vsv5#^KNgWURO>RDH
>>> z-Fq}D2@?45edF2>Na&c$`&wU~&d6l{+VepHLte!M2Zy4XjVR{VRHc^8Ei~(8Sc{;p
>>> zZSYR+<+&j7VRg`<*)B&0+`VBJB)Z{z4UMwr<%h8)zlr$N<3$RxJgGbQm1CVVis$~P
>>> z1s&UtuYKxAn9&GUVmlet=)vx%oAF5XLX>NsyUD9t$3!jJnXH+v-N at t2ZXA09r;EHx
>>> zCMUUFaobR)-0cSOx9p8q^2drNgacR1`fk2r!6MIczqVh at bS({|A&U;0Ns&Y|?x3yR
>>> z at Ee*Q?O^!rI#cSyi|^~v^5NX<!WJ77sa9H&i&qn)<K7h3R;-rL0i+Iz`or at 5+7sN0
>>> z3CIfcS1Ru6?s1^LOEdZZuuOs+hJmj)e>-{%#8-J8a<P~FM%!xE;x-xPGOB9lxDxz5
>>> zc(fFJ9Yl5aNBGzVpACMYykuB~5TUtdgSltySqL at q>Rf(Mmb1*IvNWRvVdBeD^`82K
>>> z<GOf}nIp<=UcUsm<Tx{6ZKisOx)XM*sDx#|FjCRYbU*lOGL_HRFJ1lpyx;iMIMoE;
>>> zJrZ|>lR%^TIHo%or1#hp=%C9eiJvwIig$&vpz+}fY-48+&|2TGX>x-;%u!ITlKlpk
>>> zjS`@_^tEG-)EN?1?*yi~DcKIlDoj+nMSscXp{N_&`+D{&BsR1M;Ysiq<0nF1AmwOY
>>> z?E%mzrl_q;jSStlBHtJFxSwBZvbK3VU*zo5L)ZwCO$={b2XSej{6qazO)k=-UHwXY
>>> zx0kd`z+vUV^53h}B+c1#6(NV4*mfYyawIErGIM`gBZhnrer(A+L`S+#d%x9G!rf1>
>>> zS8so@?CvC7!RRxpunV00N1l20o!VT5s~`dy?+|Qz*X?NTs8e`aiXP^+?wbKOzPVEw
>>> ztvPzq;T9hcJd4)46tJ7VYXeI%ly6!$p$+OIaly+J9QRO9$(obiOpHF<P at Dz<rN=@I
>>> zk}f!5)Z;+8V=>OtOSU401FNg(Zp2We|M%?vBGI?#hf=#jv<HMPj|hC}Xei>OTXE9u
>>> zf%|3tJooj^pWP7cc-U8su7!0XIl+EGA%w`VHXIkN)^N1p{1R+jW)t>iWH*eFeO<Kp
>>> z>vP!?KXqAO3mu$q(B|EK?mzZScRrdxv_bQ~EVMozQ>nhEw%||aZSkArL}*E!@o+Yt
>>> zP+P2}yKO^~P-N3<?DUJ10n3m*G!P>Cw~<*Za5SzI9s+&riav^Jb}pb{@7l7ubH3_#
>>> ze;?ytwO+Zl at gPZg{a&nny*^ol`Wy(O?&SJKcQvKrqPEn693MZbQSE7!FDbj;9Co=)
>>> zSlMgnbl5A>=y7%Ll+vwHqMnDzffkG5w#4o)^+~o{G#;NVI=2#|hR#|*zs7i3uDq$I
>>> zTQ108GYYlh`x^4-d7MM^jn67>#oa5~S(F~63$h&wp^KA6NWQTSl#GU==Wfs1PlXMK
>>> zRi)~PMoqnzcgkiLLEm9)j|o@@gjU at TU0j5pL)>IUB3WplZC7c$yFqxUPVTeanT@{p
>>> zc8m<mPSLMX!zAOt)oW^7;;K$N2PJb=Ptk=E^Up|AQ6nAO>|u7Yv!^t9+MZ%g416M&
>>> z=XB>8O!m9A{mdPSYSUE=a!<Dk at LC3@Za*V~$9~Vg?bIqLO92P^^tv2~Oe at x!p at PWo
>>> zn#yF~;2Fx*YV5Mr-4UI{#W;?8T1&SQYfq+2y1TQxyJFGI!(gDHqyDrw?F-R=+*|Lg
>>> z;Bw4erdGXE3#J&`xON1gNzsbPT1b7Z6fl=2o8et(=s%Bd<M_<`Qkw8ln}z=U#kzk7
>>> zZ+bpO_WX%FlSGN!I;Isf?*j)aL_q6&{FQyh-k(j<A0;_!Q4)QVN_@=g-(cO8pyId(
>>> zb*PpBP5xJh`lu=FSbC`J^6oKc3v-(`3iNiN58+|BLz-#}(BtZtNzh3CfRR^&L8&rU
>>> z)ZtZpZ-|cdvz!_wT?=$tVbE*c*@I0>N?b2DiyF8(DFQxRrUgHhE^PV^fQjr~3{iEh
>>> zPTFA9V at Cm#*ZIw{_jj_Ly7P<;4Mq}&m_DfgTNCrnHc5Ns3OSpEX<s|xx7P}Ytth8L
>>> z*OOl=k1dW;qxSK}-P_Ooq~ny)a1^Pbf(#G;LKh$>wb*eF=GImXmdVKC^~>HY<R_Ct
>>> z#Nv+fvha;(i?Z5GY9x at rz`P6frqxb?u2YlS>JKT_=RkpGr~DU=kIN72dDYs#Q}Rx!
>>> zY1U-3kw(MZ)jju=Xv<9_ at d;DQNJwpQrN5wyXyUE!FEQKEV5%gUc4j7$xgR+te2U@`
>>> z{k%upDFXZ3t=w86@@Qn;H^+*kUk^1MHjcXWJ at JAMq)8SFhJzMkKN at yV7IBK!RG0y8
>>> z%j8?HyJq6*vTL*E_G|{z0Q>bScFWrZA612HP|cCn64o`%E2jp*dgoIJ=$IWRj{Bt?
>>> zX{tFA1WJO70pDC4i6|ooGmcq%K9VxFZU$@!NToJ<eeugH7TM!m*FY=tZjHWFhvm at b
>>> ziFOer2A6J5|5o6w+7kbVmrJ#lt99AOMw`K8tV*(Cj*qY;t at K3FD`?pYS#`4~*Kj6v
>>> z57n4?e6a2SIk2VSaQ|E_=1%_;`_j_DO7nMFaW{%cpWmnZvcP=w)rrF>yI51VJUOpl
>>> zb=uj)dUYB8<}KGdVC2{5@$Xj`9~Zj+9Z}E(YK4BCy$YvFfaq#rB9$S^2#5aSLmmCY
>>> z@>>MRWU1A}%xJHm$b&N}?WgKoNmIV<yT}5*j5Dtybm}UjMNX at gB#MUItd(tib*)jz
>>> zTYOUUI9;*7;TVFgU-JyjXT!9iU*XMLEB#O3&`+B!GaaYDMSfgMpo9rMtgFjD*G4S;
>>> zO#2-5Ojpfy3cIek(JIILOlYQ=o)_`8B&n77i(Rd~zsz|krgZsB%C}!oXY|e`cr27E
>>> zVfT-E7U-g`C2^)S_f6<EWois<GPI2c74oWGtG+zMOSXx9r0AZtBPl+c|EZ5$|M#x7
>>> zD15Oa#{M%{06pZH#hQ%diVt~HxAWUH>RYeRyfaAgIr3Fx|FMA6<f<P1c?(5$$5p4F
>>> z8;|>jk#WgSH|g>uUDEw|eaUzugI*(3h`eF8%c5q)(rNH<*P%}L>XxP at jh{Y!uD!WC
>>> zVh2LK0~|DNXQJ(mH7!ir>4y9>wSv~rm261H1<iYwkw>cA4NylaNkD3Lw2}Lmt1qnL
>>> zm0wG<>y;F~-K(D(Y#ya&6ev6+IH|J*j~!_$1N-SI;&AzpeX3g^>CJ}|nGY~#<%gIZ
>>> z4keYdw*$T5Jj(}8yZMf84bi*Uxmj(Mhx4T$y2ALowr!<Qvt7fGxA2nr76zQezuH7N
>>> zs&RF|a%HpUAt%ffvtQf8!{hvSy~^uVpRP~7IfY$dUP&e#- at +=>9LRyhzGgXg{VW<=
>>> z%hgogFTaJC?yt(U4YIy)NbdA)H(*s3P-atH=si+p`Y=1>n!wC1EW4QwmBw-qFQfxO
>>> z(8@&ZcE1hMir=1kUepKO!4F#MUyW%QQ<FK410J^@O~?53{Q`Pyqx1~lR{WlzA~!?w
>>> z4ek>-m~0d<nRbGJk7_vUnkj;#$hCg+K4Wq(l}b|f7QB2aQCs##sEdw(ef!ehH0SiS
>>> z$+;WKlb%Ui9RWn5I-2)IL1f0G#5D8LhDrQfkkf!*n at vRQB^5=X5 at Qcef&2~a6iZ26
>>> zYh2TL7y1-f*91_*QKw60Z$e%jlo79sY2F?^jGF!6wVz+=nEY2rW8uDif$nEYLBMYQ
>>> zyLW`y?y5KOSa$V7Y=^>?v(FQBn#@g__WLMq`d8Qr`JC|cSMvgFGA|7i;}_U&Ml*^0
>>> zTHSWaOI5zUqQ<%X4nvM_coz}{FZNx%NstTCWT9w>)%hPRc60mW5)<U)`{0SJ*360a
>>> z{)SWb42!eDy{@Yiu#XNf(kbXw3=d{6_#5<H4#junz at 8>88=kq_+tQlJnfTD|)(>xu
>>> z;zV81ml<Ma%dr<(ST3<6l|el}@*v=&+F%r?iGRY&2)JNq6Gir5?9<KHVy9La&O49+
>>> zgl=o*VNY`>m~yvRbdFVFdRAijfL@;bB7QbrZf0$@jU3nxDM7~}L<m4=xv<DJ)pd~~
>>> zy6YKo at r_~ftfPJ75$ikztOp0CTt$qx*YCMqpLt!DslnYmq9h|TBYSL8|K!BSYnzki
>>> zx~Jlw@(6EH+W{TEf01?|&-HSj|0nwG(GPa|MIQ>96O at WCH3|Bx3{&AD>TDppAAw{m
>>> zCy$0~3UadDssu7>9xi!v>WJP}Fdat4Q50h}$o*>0VlqhG{648Z^Sh?OJf8<?bpKO4
>>> z`%DSf at i6B)+o5^$PO*#Y-$zP4Qf^fn4_E9$uQGBFocVw}4M&Rjsp*7U*PE~DTYgy`
>>> ziW@!ABx!RVkgFl+LZm2AG~#=X`XB9mXH-*Lv~EHX>7rC=DoQURNQZz52poD-S`bu-
>>> z^d`kX00l8rLGeg0(mMoDI?_Z1q)UeY(j}or2=T6*bKZFOzBk4l_x*Z*&X4^o*?X at w
>>> z*SFSQ>zm)4GYnS8!zYLj&d+8~9+Ovce^=Sn;9|Rc+e3UeVX*MRE_~4I1??(I27Z-j
>>> zdXk_<gS5o!k2RMExUXpA+4>od@&U0rbbD_0{trRN8T8pFNw!4I1PAFmDR-LwB32*P
>>> ztC_ZEa#SPZFZbYn1nYXYW6P(Drcxx0jgw=`&d0cp6_us$?e3AkCZztxYm=>L4VC%T
>>> z_#S>M)4y<$j#`z*CP at E=sB0e_mTQxF>8my80QYthFjah)|D-0DEWVO~?OZ3`UF-HE
>>> z>!Hd$$j3U$>7zHHa=#$~T_k>D*#6wdifFsDgkjuA4~_snEGd{zc|!b)?c|^EubLJx
>>> zk*();AP5D>r>SWPUZt!2b-o#Da+c?u?L?|W%W!{mzd3WOQdWB~T>Bif+o#*p>u4Eg
>>> zI^PqiMor{SYFA at z9k1mT*{7BIBc-;}`z!AtTc~so=hShfSIkm|SEzD48$qwbP7W6_
>>> z{#?a6doAPQx1VN#2bMTm<9LM&{0$w2_rjTPhz<2!do+=6Q8 at nSy8N(9CS#l3mE~!g
>>> z9yTBG;<F`Bk>4=s`D?ue&51t at MAl2U+~ncua0-+=fB5W~lSCxr0*oCNwU_RrIefM|
>>> zAbYrpFs;2)Qc~i5nzH<~;>O6)-2X|W+_eIN at 0xk`ic&qF2e3Gz^f@`rx;G_SgYm at E
>>> zXbYh^|2#)jN1fWK`~PKr*_mJIVzn>ozKTEu8xBenGNHRF<~D9Yf4(;;O`CSbc>5y|
>>> zlE4kBv`q-$-vo=F28tCm{}NQKXfByQ+ at is)ET&}$s6iV?C5LaZV~@9zA2PNCzIh1U
>>> zAQiQW{`z|~Ns+D5aDvQVO1i_=u*@36aFkPHD=R-WS=5v>p8Va85r~>}fv71}<-KFi
>>> z5m}rNXKe}#__Nf^p=iJE81)v<<MkXDnW1NOm)iAKRmk?G%nrPy%cR(*k9B{KCEkDW
>>> zO<2n*f{)%PGSIK6-KlUo^@&AIHKNz^nnsTX8s`Y0Ky{KfVC&SmwKvG)xL at HwSj5q{
>>> z|Az1rrE(BzS4W!k at +a0Twbm#0T>f<Q-fT2j6gQ!eUKRT>0>JEsWN_{wnrE`#-b7(G
>>> z<FrW><`4a3mZMN+F*dTbhr8G2Rpg%y^{%yCEQ^X0-F|DTmpqQFJG85--JjkVAhOaQ
>>> zcu&H~`+Z*R1A*P6 at gIg;Pw>$n=Xg<%`nbVzRyUfeQ-dR(H-kIZ(_Z;n;^if23>6|-
>>> z7l(~25>Yq6$Hj5}o&uj3p(@Q2g(+?Q#e98}p8 at 3P2y3NBT6<I=)ObFOH)*)Gm-#V1
>>> zo}ani2<<4o=fI#8Igt=Z^%z$*VR`1^tCL8f#H-CS^}qOwJzMz#U~S)fQtwBfvp$n6
>>> z+<mP&u6as#w&6%7>*N)Zz6dFQ5*ETo at URNo+|S1(9vsYSPU3sL#QIsD<El%FUw$tt
>>> zMzO+N;LrF^tBHJ>-#-6HX{H5}-0NvFu8&A^T=DqIY{$&D_tLzBjU?^^ze0qc#Hw);
>>> zT?sw%aVmE!0uBvFGlrDmVmeKAXx^7Ah|c7n{>Yy6*|eaOhmw&pjNuU~bOy%N<JB;V
>>> zg|AbQyX7LCi|?yVV at 3OYLcW9q>b;dPJ at i9`_5b7Ol<_~PN6R~MkvdWMLJ)@#9v0Hy
>>> zq6Zi((bwUL9LH>ti*av-xXR&wEiV5Vj=m_Ienps$ZyZUGP~=(c?eNC5W^%TNJ(P6I
>>> zGPD?PKK_Anzv!L{h3*DRG|C at 1Kts%@5tgldF!wEQsng#dG0a}WNAxY1np}|b at bL29
>>> z;kw-Y_?bno>Q&~&6TykLx&|}$N=lxqS_1JuXqG7{6$k89H+o6uNCR_pAq-ZwnG^w5
>>> zyvjxm5Sw-RbE;h<S&w&l(u;#$>lfeV at f4dN7UHx92duUiLijUm>5|IC`rUs{Nv*H+
>>> z5Z16iIbx+bRpj8hX1Mov-gjh7 at 3e}#y_>Ysyi)R{v19 at zGb@T4tHB8!j3gP3`u28`
>>> zxbSD~tOR1{3ooVV&=;wikBHD@=<t^8?|?*@EXS%k`8OrHv$0=vW^Sr5=gM%#`(5VY
>>> zvHS*OYoS1j5qcdx_~V<T-HL3ji`eV&e;gcouBgx&g<GaYxE88lTdb2vw9PnCm*>8C
>>> zsV-|jaW9^rylnIBu!fPeV4VtP#+Oc9=2p>=MPZ#e+rgu99}tepg9>XmjCQn37JO!7
>>> zUEsuJH;!1}e{_Jj{<!>533yY;hh%P0sN`KnBdT&~<>{QliOWs};EHSWhyf?%Q=O!<
>>> z!~3w!fz4If8AZv9Q$9Ym=}!agladi~p^9rD!3&ur%y<Y}0JCOYrU<w_`E?KGB2d-L
>>> z?aUE;VjyQDjA{B2=~A78+rH|ft?~y^^WG&po$nkkhP!hqs6wPC48f!s<*~ec at 5zkE
>>> z(Q`V&(*+I+hvJ8C&vuS=D!lJ9_^dSbc*HgR^`yz;310urfq54YtnnLCS>KUKvtC(S
>>> zSAZyx9ru*}m6MFMeDCYwhq$eVZB=cZFKFE{QUkGS-_?FYKne*BctsRNJ~eV2RQj;T
>>> zNo~<!`I+Vd2JYY=r}?@BI$-qK*H1qUe8w*IqeC!ceNUiZ9CkC~{=V3<6z%gF;k=OE
>>> zib4K(f-%<MoGAV*k9KNZu84WsFY~$Uw+9|frNF%w;5dEwFKHAz>iaK0z{$z69dX#n
>>> z;N<6 at N2o!Gf+I-&`IDQSR>^Oll=K$$O4g{De7zEo9Tn;jCtc$z)^4+u5d_^Fok>^_
>>> zz2|*o_6TWg;q-}6(ixxvqS32<B{SCRmQLsTIk`xTtLLD_#$jr7yT2iTz&x{;83Cu-
>>> z-{yB2n at s-^`|d`y?ahMDc$rgv8W<U2A#tUbc42nGc-X?vmw40p^2T|IpbfL?!F^{7
>>> z<+qq$EJ8-*<#KPd_ye`gRmB(#YY$8g;B4v5K|J3F+%|<aLzI=_E>nh`gm#c%D3dbs
>>> zCczY2=QE`bWW7tDft#Ub-syxclMTq{t-<2o`>G493NAz at hc2Qe{;m$Jy=VdoY~j28
>>> zf9Z$BupCDd9#sVXG*q`2;95b33~mygB~GPsVgZI;;y-$RCkC}N6A}<IGRL#GJ*ju_
>>> z0(VfhV94ZR!9J#BvIf!=>Q?wa{(<24jJxJ_I0B(vQ5!wF!a+ReG5?1=zE>!!McD3E
>>> zYY5lAn102k?qp=oH}sJV5Y~3#tQXj`Qr<jM;dO0TXDlh6>p%1t8CK@%W%&(hqZs2%
>>> z%Z!o{e!^q3c;0QpZ4XdKOg;`fOd@@2CvaX9mi)<PpmJ{QV<ne(eReo^3UIJ<i~**1
>>> zxK%Wj)pAR3omSKD{4OXSN2_`ISsbm2_NkWW2aHK`ygs_D!fl+awTJKjkiEL+sLQQ+
>>> z=LAOiwBT9C#|T)Y=$EAsS#V&~Y2i+nT9kU)B6z2xZqByKO~zO(EjXXDL0;&1fP3rc
>>> z=0+bf0uNh!Om-MQCMeG<FTZCAkkZMRy-Sa*m+U{w4*NOvPA}5}WeTr{)y{QP5bnY&
>>> zGh;D at 7kB+^<;IWU`gCfJ5|!83;Qs2Xu(^tl%uo553kccA#ss0Zgxo)`tLm`-ywh{k
>>> z==*CW1lEA=S*H$xbrH at Jko`uv at 4RS{Go#=f<8z{Rq=eV9OvPPiFnHi(D)MSesOes>
>>> znBMTjXJftN`qlVp=I at yc)kxS$Sd)arXhT<7K)line$`8XPyL{iLQ?sx%ZApaYZPft
>>> z3ViuF)phkXLs_-8FC at 0IW3*Xy4vozqtW0gt7_&rS@!;ERM+cNN43d1T7cu7XyA{z2
>>> zaV?+(NR2LN2;#Fxue@*b*=oDnzY4I=w_I>f7ihW^k-Urg+Sc`Bi4&4^R%>O~T#;M9
>>> z!ZzBmO&cUWnq$Sl)YjT2<3`Sb1Hfv;`l0~g?`Rka<5rXITa0ISnN=O$cf!Pte;)FX
>>> z$a#K0aMJ5aWBQ!*ihluL3mo9#JAn&C8o|3Nh+Jfu2eSWK0ZZ|Y**zNiwcyQ=xef(5
>>> z^@G><W)bkSRVpQu!c%WjE2J9sHvP__$f6$jm5J*xHr;j|`V(}ASI-|wG2=@T-LIeE
>>> z7Y}}pUjp?OvicUKIBjOFx-L;192{~;T}=GL$yw7iX&6F+6 at yJ-yIc$Pl_6!|)zAA_
>>> z)Qh$?7;piVWhj5Kz>SDPCz&9j8YiYvjS7cRdYtVG`7q)x_$0bWed~v!ve~|9s#$`<
>>> zyyfc`pLWy6%ogL8V=isyZys+(cX==(VI9~F+&h=C&arsWgE}LNQMtV!RoA5EGQSTS
>>> zlSr1ywKG;9<vQq2FLDih&ZW%EssOdhvqC6Fk%(jFSZ(dP<ekM1t0t at TPU+x9x8*Oa
>>> zr8L1U4)VMdRZEuBpNn(pu8JgSP<Kl4;I(DlBY1hexeSdo*2R9xFfd35++A4OOROT+
>>> zwl|qZEleNNr<&Ld<z5$qVH!&I8X8*lrit7qAQOl)>J*U%?-cJwbWbT>C0&U8*7L;C
>>> zT~NB$)u~M^ZQ<F<T3xG_ENrS~UOr02EqC?2dlgo(mREO2Oxaj4YBlz9T=55ofaT)x
>>> zc+|c4iQkYOKEamJarMzAp+ejA-PY&Z#HcT4y)8u877cR>f$VjFZ2?r$t8dR_Al~}c
>>> zq<IgELd)2#$>V0Hw7m-NHfh~XQ;MX2#B?n;n+<>0oifUM-K%40>D8sfjfX!Et4^f5
>>> zryb|FIk6in3M()2qKnu9O1yWq=%lAo_0P`OjaR!KF at y3@a at lzK13;h7_X!6c<sGD4
>>> zu6mlC5^zN?DoL#rFG{)&W~VsPWROG&@=arzx$itmSeu(TJa2pW(yir*{KK0c5)!n|
>>> ztFXWa>4cqIT<cqFk=uC719O59-rwqtCEybD%UdtK6fApZbG at wd?K<3}SHM%v$wGm%
>>> zUu+o5#NX-Q#ab0`_lgPcL9k&I?n&2X$)#RtqGE<g8tzU>-CFGcJ2q#}O)$lH>`>oL
>>> z?E4Pb&;O<D-7Wb?_$J$m!@(xLkitpA0G{MI<qgAaRfLs(HAIJqXARI at SC*t9QJ8=*
>>> zK5#ZdeFHH+zagi{%2k_|DRgTh&9 at W7Hk#iMY0g%#C3&fo3tm8Rk{*o&4vgJ4$Z9`S
>>> zNOiX>xUQ^4VJgGW>*;WF$P;<8%+1rD1L%TY0AZ#D{0%Y4m*}#`C@&6G>04srYQ5ny
>>> z)obS>=^tloTejOg at ENI}+a^n at AQc;6TBHzLsI6H8TTl*q2bMnY|08-JzGH$<jOML_
>>> z%cx$me_iv;z|em~cIUyK;3|IHT%03jI(5e%^MQQR5-F|uMS8TB3}*gq{iuQcif2uh
>>> zfI=Y=R2O0B3?Y168P?;4^m at u{nOBi*SzY$S$`=n`=Xn;py`WDPpsum<iqk=VEi#Fv
>>> zO4XnJIl~YVt0r>a=G<FHmmk%MvA4CPm*eG%E!8H0z&B}&nbdR%gr8Eo)Xxz`^HZJc
>>> z&hwUm6rWYrx2gnsW52SgQ_Vv&l%b}dt-nI=RQN>nUTXO$jV$8t`~IS6^i^^naInMw
>>> zPPeEJLgs6XK#WF_%h6MDjkXJXO5<&$|G6hWKyZ=o{LPEq^k-z^O=E&AyKx!X=r;3C
>>> z-D(~E{L<|j)DM(i at I|7<r+^M<(%=`Kw93JhOxZy5rJ^hDM<3x~I|Z>YH;=GcD50Q?
>>> zpxkLy5Orw`Qxbn^&3?%07Gr3D>+aYG$G?xU(N4$kF0Os at X(tbVxG98tgLUfmU<ugn
>>> z<P#*k^eEZjunX>dd_E%QW5J_x*6THAt|}+l#1oYr!Jdc_#omf at dH_;w`Qq6E-kK*C
>>> zoc5kGGzkBEHRDthBS&ln+Wdp#fQxm;mz3F`AWc$S_%Vr&{#fm1zKx;N6Kvx~6jo5o
>>> zE4TWsb>*}nzbX7RtopFy#2U-I)r&j&_;Coaxi{m$Xlnjv5v_-ZJJ$65%Cfkn{Yued
>>> zMrJ`>CddO3#@>L|mutk|G=3JmDtTScn0xozW}O8ws-irE3&}_D!98!^ac*TM$~a|P
>>> zeO~zafMICByCXZ%@=7X~0 at eKed4_SS9q}od&Y`0C<rw?z2aTlCU<>Z9Oy&TA%U`cH
>>> zU8LK0!D4fkEj~+ECmQAsr(+UFC$}yKncdydP&qdeWcF&*s3dH7!=U0@{9<0Eu_h}6
>>> zIo9ZZT_UB$J(qp<3yjqnPiHMLg<!HE3Y>X4q36xyd<GVEs`Q+G3><f7YKn<XQ$d*C
>>> z64&U$y?rvvl+gC_&MR at 4O$W3vJ-KMmX?0Zug|H1YY|8-L%%ZJMqxep`=<>_njXpIr
>>> z<YCvI06t4AtePXULN}Pzl~M)sNkNGBn!aeEd0W3~uk8B&j+1>S$|N&2n~a9&=W?#(
>>> zD}94-bxE*Nho_iHFFj1xgvfmP!;yyH)BwVO1^>ALRYB`V$2i98`mx at jf<W84E*i~f
>>> zAx4ZS<)pHSYi-n=ydut7;<7nam*Z~tSm{TvYJ(3-G-TB1!&J9H&`<*H3M?Hw{uu<?
>>> z!- at e$5H3BA>OJ~a%;qT*@2#)&x1kW`5{Zi4GFqd1z)pAENB43c9hny9-Dl@?G|gaE
>>> z4b1(bKGCCwIT8u~X0ORB^DD&@ss#b9wmJ2hx>_4%B_}!W^@)cM3z~m{^POm3wb{81
>>> zv>z)Z6grfQ7KWChztVCE6v$>#b5ipBNJfiOoME;h`KEFR#Wf>FOdic&fG|MAZhtEE
>>> z2G8<iZBvKzpOP61&)NqWM>QdWgKPRbBb5p(8-_WdT+3OCQ+)~$nXs6BFp8BXY&43z
>>> zT8t8`keQN<SFENZriD4}_cE*;ITemlJRwf37$c~@D0fA^(r{tcsVy7dJP6Y(j1fEC
>>> z4XC0l#)$H9%u4H6`Va_XekaOohj7kmy8vN2CE}bDN_Qg*R5>D#)4f>EGa5wj(p*Ya
>>> zpRr^#Mf+{DbBT)J^=BA-b0KL%gX*VGoua0q&=7bD`U|<IDNaiRx;sx11C8?mJzzEd
>>> z`;skA?&VqJ%F1~;w at WrO=qHUGCgP^wzzP5rCyT~_BDv8FOw^!1W9E*DibvmAG(Pd1
>>> zfbph)K;|7{d@@i<R>IImj^Q0ySKH%CnGJ9w*K)o_yTV$cGfN at FJ}sz9_DGm5VL(DU
>>> zh9_7bSPE?=%xPlpJ`e<M%wx^a-cZ-1x!{vVwg;<8TY|Tej{yW67*>EeXd*&}Y4|H)
>>> z-ONq?0Va4eXj;-a2+SBB4X-*aK%xu7eSy60&P@!mU#q{FcANkM>Evc*Uvk;r6ydyZ
>>> z$l5_AQSVJ*wyd*W at cp3T&%XCQ8y_MVEHU*pb;-?}+tVi<;G4^p$>5oRNH{T^4EC0>
>>> zAq~Gt%1C|Q(JSc!oNH${SwaWXzdZdGGm^@oI7!=m4RIrahLTHBws!9mQFZ<21)~pb
>>> z-3HF0Og{a=YtH%m&`4Q(4VqoDr5W}ItgM9TsRd7M9)gkK#yBYy0JC2-vQ}M%Ff2Bc
>>> zr&vO$K_GF>Ig66>-6ZYhm?ei~v;`P<`ulMR=X}b?QarwS-7?#Hn(SmS0DxkQ?KuV1
>>> z4QP=21=Mt8RAfgyyTFG@)h-~Lof~t1e`WR+gocbUfQV0hVAMh(2FhtER>E0SZ8I65
>>> zYzTxhi#)rZa=oLYF(jk;0>C62)e;yKD1=fW at 1K=Q<TO=yP#hUajFT;yW!#oS>6&5}
>>> zDra)zTGNFgPGl2cOv#b<lt1_<kFgv?vH0)WJ?Gz@<MgxD9YH90S#;34`*6$GeJA$t
>>> zt-%?{t{0xvIc~xfHhtvQ6yjhb7vY*KI at DXI^WCW-D=PTP^<%2R+=d!q at n+^cJ}Y|$
>>> zKGi-XNlf6V+ewd0aZMk=?YI4e^n4?b2JIm<pXSfBP+6BDsncJt)`Xs25t1C!ho^4o
>>> zsmK3xtW?-A5GAiN5HQ(WLWv3L5FV33vgHj0WFb(6pWX=PEDAKRh$w9 at mn<0A9<udV
>>> z%!EJ2(A_AuzI=a?bzK-r5z!CfQvAyxj+a{e8CGWFC4!l4_6r8pOCtjjG4_k=h&E`N
>>> z$)I}oYZGsE!Pt^%C-QU7K$MKkcvjMmhXyr6|Cy<LR{mT^X~U~v0RumS##}v9oII^A
>>> j#OtO07l8h05V=wRUjN$QUkv<<fqyaZ|AqnP-xL1<ly<Oc
>>> literal 0
>>> HcmV?d00001
>>> diff --git a/user/tools/rtems-tester.rst b/user/tools/rtems-tester.rst
>>> new file mode 100644
>>> index 0000000..24c62dd
>>> --- /dev/null
>>> +++ b/user/tools/rtems-tester.rst
>>> @@ -0,0 +1,639 @@
>>> +RTEMS Tester
>>> +.. image:: ../../images/user/rtemswhitebg.jpg
>>> +   :width: 400
>>> +   :align: center
>>> +Chris Johns <chrisj at rtems.org>
>>> +1.0, June 2014
>>> +RTEMS Tester
>>> +The RTEMS Tester is a test framework. It includes a command line interface to
>>> +run tests on supported targets. The framework provides back-end support for
>>> +common simulators and debuggers. The board support package (BSP) configurations
>>> +for RTEMS are provided and can be used to run all the tests provided with
>>> +RTEMS. The framework is not specific to RTEMS and can be configured to run any
>>> +suitable application.
>>> +RTEMS is an embedded operating system and is cross-compiled on a range of host
>>> +machines. The executables run on the target hardware and this can vary widely
>>> +from open source simulators, commercial simulators, debuggers with simulators,
>>> +to debuggers with hardware specific pods and devices. Testing RTEMS requires
>>> +the cross-compiled test executable is transferred to the target hardware,
>>> +executed and the output returned to the host where it is analyzed to determine
>>> +the test result. The RTEMS Tester provides a framework to do this.
>>> +Running all the RTEMS tests on your target is very important. It provides you
>>> +with a traceable record showing that your RTEMS version and its tools are
>>> +working at the level the RTEMS development team expect when releasing
>>> +RTEMS. Being able to easily run the tests and verify the results is critical in
>>> +maintaining a high standard.
>>> +The RTEMS Tester contains:
>>> +* Command line tool (``rtems-test``)
>>> +* BSP Configuration scripts
>>> +* Back-end Configuration scripts
>>> +* Back-end Python classes
>>> +* Python based framework
>>> +This document is for users of the RTEMS Tester as well as those wanting to
>>> +develop, extend and investigate the RTEMS Tester.
>>> +License
>>> +The RTEMS Tester is part of the RTEMS Tools Project. The code is released under
>>> +the OSI approved "The BSD 2-Clause License". It is free to use and we encourage
>>> +this, including on operating systems other than RTEMS.
>>> +The code and command line tools must retain the same names and always reference
>>> +the RTEMS Tools Project.
>>> +Quick Start
>>> +The quick start will show you how to run the test suite for a BSP. It will
>>> +explain how to get the RTEMS Tester, set it up and run the tests for the erc32
>>> +BSP. It assumes you have a valid SPARC tool chain and have built the erc32 BSP
>>> +version of RTEMS 4.12.
>>> +Setup
>>> +Set up a development work space:
>>> +.. code-block:: shell
>>> +    $ cd
>>> +    $ mkdir -p development/rtems/test
>>> +    $ cd development/rtems/test
>>> +First fetch the RTEMS tester from the RTEMS Tools repository:
>>> +    $ git clone git://git.rtems.org/rtems-tools.git rtems-tools.git
>>> +    $ cd rtems-tools.git/tester
>>> +Available BSP testers
>>> +You can list the available BSP testers with:
>>> +    $ ./rtems-test --list-bsps
>>> +    arm920
>>> +    beagleboardxm
>>> +    jmr3904-run
>>> +    jmr3904
>>> +    mcf5235
>>> +    psim-run
>>> +    psim
>>> +    realview_pbx_a9_qemu
>>> +    sis-run
>>> +    sis
>>> +    xilinx_zynq_a9_qemu
>>> +    xilinx_zynq_a9_qemu_smp
>>> +    xilinx_zynq_zc706
>>> +    xilinx_zynq_zc706_qemu
>>> +.. note:: The list is growing all the time and if your BSP is not supported we
>>> +          encourage you to add it and submit the configuration back to the project.
>>> +Some of the BSPs may appear more than once in the list. These are aliased BSP
>>> +configurations that may use a different back-end. An example is the SPARC
>>> +Instruction Simulator (SIS) BSP. There is the 'sis' tester which uses the GDB
>>> +back-end and the 'sis-run' tester which uses the command line version of the SIS
>>> +simulator. We will show how to use ``rtems-test`` command with the SIS BSP
>>> +because it is easy to build an use.
>>> +Adding support for a BSP to the tester
>>> +To add support for a BSP, one should add a configuration file in
>>> +``rtems-tools.git/tester/rtems/testing/bsps``. The configuration files
>>> +should be specified in an INI file. The configuration files provide a
>>> +means to the backend of `rtems-tester` to automate the running of tests.
>>> +There is the ``<bsp>`` tester which uses the GDB back-end and the ``<bsp>-run``
>>> +tester which uses the command line version of the respective simulator.
>>> +The general format for specifying an INI configuration file is as follows:
>>> +<bsp>.ini:
>>> +    [<bsp_name>]
>>> +    bsp = '<bsp_name>'
>>> +    gdb = '%{_rtscripts}/gdb.cfg'
>>> +    arch = '<arch_name>'
>>> +    [gdb_script]
>>> +    gdb_script ='<bsp>_gdb_script'
>>> +    <bsp>_gdb_script =   '<Instructions for gdb
>>> +<bsp>-run.ini:
>>> +    [<bsp_name>]
>>> +    [run]
>>> +    run = '%{_rtscripts}/run.cfg'
>>> +    bsp_run_cmd = '%{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run'
>>> +    bsp_run_opts = '<options>'
>>> +Here is an example:
>>> +arm7tdmi.ini:
>>> +    [arm7tdmi]
>>> +    bsp = 'arm7tdmi'
>>> +    arch = 'arm'
>>> +    [gdb_script]
>>> +    gdb_script ='arm7tdmi_gdb_script'
>>> +    arm7tdmi_gdb_script =   'target sim
>>> +        load
>>> +        run'
>>> +arm7tdmi-run.ini:
>>> +    [arm7tdmi]
>>> +    bsp = 'arm7tdmi'
>>> +    [run]
>>> +    arch = 'arm'
>>> +    bsp_run_opts = '-a -nouartrx'
>>> +If the tester should run the tests on qemu for a bsp, the given pattern can
>>> +be followed:
>>> +    [<bsp_name>]
>>> +    [qemu-script]
>>> +    run = '%{_rtscripts}/qemu.cfg'
>>> +    opts = '%{qemu_opts_base} %{qemu_opts_no_net} -m 32M'
>>> +For instance,
>>> +generic_or1k.ini:
>>> +    [generic_or1k]
>>> +    bsp = 'generic_or1k'
>>> +    [qemu-script]
>>> +    arch = 'or32'
>>> +User can also provide a "settings.ini" file in case a configuration file needs
>>> +a path to, for instance, a first stage bootloader (fsbl) that is placed
>>> +somewhere in the host machine. The settings.ini file can be passed with
>>> +``rtems-test --with-settings = /path/to/settings/file`` option. The
>>> +<bsp_name>.ini can contain defaults and the settings file can contain the
>>> +user-specified configuration.
>>> +xilinx_zynq_zc706.ini:
>>> +    [<xilinx_zynq_zc706>]
>>> +    bsp =  'xilinx_zynq_zc706'
>>> +    jobs = '1'
>>> +    [gdb-script]
>>> +    arch =  'arm'
>>> +    bsp_tty_dev =  ${settings:bsp_tty_dev}
>>> +    gdb_script =  'xilinx_zynq_zc706_gdb_script'
>>> +    xilinx_zynq_zc706_gdb_script =  'target remote kaka:3333
>>> +    mon load_image ${settings:path_to_fsbl} 0 elf
>>> +        mon resume 0
>>> +        mon sleep 4000
>>> +        mon halt
>>> +        load
>>> +        b bsp_reset
>>> +        continue'
>>> +settings.ini:
>>> +    [settings]
>>> +    bsp_tty_dev = '/dev/cu.SLAB_USBtoUART'
>>> +    path_to_fsbl = '/home/chris/development/si/work/hydra/boot/xilinx-zynq-fsbl/build/arm-rtems4.11-xilinx_zynq_zc706/hydra-fsbl.elf'
>>> +Building RTEMS Tests
>>> +Build RTEMS with a configuration command line something similar to:
>>> +.. note:: The following assumes a Unix-type host and that the tools have been
>>> +          built with a prefix of ``$HOME/development/rtems/4.12``.
>>> +    $ cd
>>> +    $ export PATH=$HOME/development/rtems/4.12/bin:$PATH
>>> +    $ mkdir -p development/rtems/kernel
>>> +    $ cd development/rtems/kernel
>>> +    $ git clone git://git.rtems.org/rtems.git rtems.git
>>> +    $ cd rtems.git
>>> +    $ ./bootstrap -c && ./bootstrap -p && ./bootstrap
>>> +    $ cd ..
>>> +    $ mkdir -p builds/erc32
>>> +    $ cd builds/erc32
>>> +    $ ../../rtems.git/configure --target=sparc-rtems4.12 \
>>> +                        --enable-tests --enable-rtemsbsp=erc32
>>> +    $ make
>>> +Add the -j option to the make command with the number of cores to run the
>>> +build parallel where it can.
>>> +Building all the tests takes time and it uses more disk so be patient. When
>>> +finished all the tests will be built and ready to run. Before running all the
>>> +tests it is a good idea to run the ``hello`` test. The ``hello`` test is an
>>> +RTEMS version of the classic "Hello World" example and running it shows you
>>> +have a working tool chain and build of RTEMS ready to run the tests. Using the
>>> +run command:
>>> +    $ sparc-rtems4.12-run sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
>>> +    *** BEGIN OF TEST HELLO WORLD ***
>>> +    Hello World
>>> +    *** END OF TEST HELLO WORLD ***
>>> +The run command is the GDB simulator without the GDB part.
>>> +Running the example using GDB:
>>> +    $ sparc-rtems4.12-gdb sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
>>> +    GNU gdb (GDB) 7.12
>>> +    Copyright (C) 2016 Free Software Foundation, Inc.
>>> +    License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
>>> +    This is free software: you are free to change and redistribute it.
>>> +    There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
>>> +    and "show warranty" for details.
>>> +    This GDB was configured as "--host=x86_64-linux-gnu --target=sparc-rtems4.12".
>>> +    Type "show configuration" for configuration details.
>>> +    For bug reporting instructions, please see:
>>> +    <http://www.gnu.org/software/gdb/bugs/>.
>>> +    Find the GDB manual and other documentation resources online at:
>>> +    <http://www.gnu.org/software/gdb/documentation/>.
>>> +    For help, type "help".
>>> +    Type "apropos word" to search for commands related to "word"...
>>> +    Reading symbols from
>>> +    sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe...done.
>>> +    (gdb) target sim
>>> +    Connected to the simulator.
>>> +    (gdb) load
>>> +    (gdb) r
>>> +    Starting program: sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
>>> +    Hello World
>>> +    [Inferior 1 (process 42000) exited normally]
>>> +    (gdb) q
>>> +The command r is used to debug set break points before issuing the GDB run
>>> +command.
>>> +There are currently close to 500 separate tests and you can run them all with a
>>> +single RTEMS Tester command.
>>> +.. note:: Use a recent RSB version to build a SPARC tool chain. A recent patch
>>> +          fixes issues with the GDB simulator and it improves the test results.
>>> +          It is also recommended you use a recent RTEMS 4.11 version as the
>>> +          tests have been cleaned up to improve the results.
>>> +Running the Tests
>>> +The ``rtems-test`` command line accepts a range of options. These are discussed
>>> +later in the manual. Any command line argument without a `--` prefix is a test
>>> +executable. You can pass more than one executable on the command line. If the
>>> +executable is a path to a directory the directories under that path are
>>> +searched for any file with a ``.exe`` extension. This is the default extension
>>> +for RTEMS executables built within RTEMS.
>>> +To run the erc32 tests enter the following command from the top of the erc32 BSP
>>> +build tree:
>>> +    $ ~/development/rtems/test/rtems-tools.git/tester/rtems-test \
>>> +             --log=log_erc32_run \
>>> +             --rtems-bsp=erc32-run \
>>> +             --rtems-tools=$HOME/development/rtems/4.12 \
>>> +    RTEMS Testing - Tester, 4.12.not_released
>>> +    [ 1/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: base_sp.exe
>>> +    [ 2/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: capture.exe
>>> +    [ 3/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: cdtest.exe
>>> +    [ 4/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: fileio.exe
>>> +    [ 5/13] p:2  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: hello.exe
>>> +    [ 6/13] p:2  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: cxx_iostream.exe
>>> +    [ 8/13] p:2  f:0  u:0  e:0  I:0  B:0  t:2  i:0  | sparc/erc32: minimum.exe
>>> +    [ 7/13] p:2  f:0  u:0  e:0  I:0  B:0  t:2  i:0  | sparc/erc32: loopback.exe
>>> +    [ 9/13] p:3  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: nsecs.exe
>>> +    [10/13] p:3  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: paranoia.exe
>>> +    [11/13] p:4  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: pppd.exe
>>> +    [12/13] p:6  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: ticker.exe
>>> +    [13/13] p:6  f:0  u:0  e:0  I:0  B:0  t:3  i:0  | sparc/erc32: unlimited.exe
>>> +    Passed:         7
>>> +    Failed:         0
>>> +    User Input:     0
>>> +    Expected Fail:  0
>>> +    Indeterminate:  0
>>> +    Benchmark:      0
>>> +    Timeout:        5
>>> +    Invalid:        1
>>> +    Total:         13
>>> +    Average test time: 0:00:27.963000
>>> +    Testing time     : 0:06:03.519012
>>> +* The RTEMS Tester's test command. In this example we are using an absolute
>>> +  path.
>>> +* The ``--log`` option sends the output to a log file. By default only failed
>>> +  tests log the complete output.
>>> +* Select the erc32 BSP and use GDB.
>>> +* Path to the RTEMS tools so GDB can be found.
>>> +* Path to the erc32 BSP built with all tests to run. If you add subdirectories
>>> +  to the path specific tests can be run.
>>> +* The output has been shortened so it fits nicely here.
>>> +* The test results shows passes, fails, timeouts, and invalid results. In
>>> +  this run 13 tests passed and 5 tests timed out and 1 is invalid. The
>>> +  timeouts are probably due to the tests not having enough execute time to
>>> +  complete. The default timeout is 180 seconds and some of the interrupt tests
>>> +  need longer. The amount of time depends on the performance of your host CPU
>>> +  running the simulations.
>>> +* The output shows the average time per test and the total time taken to run
>>> +  all the tests.
>>> +* If the path to the testsuites was put to
>>> +  ``sparc-rtems4.12/c/erc32/testsuites`` instead of
>>> +  ``sparc-rtems4.12/c/erc32/testsuites/samples`` then all the executables
>>> +  would have been tested and not just those in samples.
>>> +This BSP requires the ``--rtems-tools`` option because the SPARC GDB is the
>>> +``sparc-rtems4.11-gdb`` command that is part of the RTEMS tools. Not every BSP
>>> +will require this option so you will need to check the specifics of the BSP
>>> +configuration to determine if it is needed.
>>> +The output you see is each test starting to run. The ``rtems-test`` command by
>>> +default runs multiple tests in parallel so you will see a number start quickly
>>> +and then new tests start as others finish. The output shown here is from an
>>> +8 core processor so the first 8 are started in parallel and the status shows
>>> +the order in which they actually started, which is not 1 to 8.
>>> +The test start line shows the current status of the tests. The status reported
>>> +is when the test starts and not the result of that test. A fail, timeout or
>>> +invalid count changing means a test running before this test started failed,
>>> +not the starting test. The status here has 7 tests passed, no failures, 5
>>> +timeouts and 1 invalid test.
>>> +* [ 5/13] indicates the test number, in this case test 5 of 13 tests.
>>> +* p is the passed test count (2 in this case)
>>> +* f is the failed test count (0 in this case)
>>> +* u is the count for test marked as "user-input" as they expect input from user
>>> +* e is the expected-fail count (tests that are expected to fail)
>>> +* I is the count for tests the results of which are indeterminate
>>> +* B is the count for benchmarked tests
>>> +* t is the timeout test count
>>> +* i is the invalid test count.
>>> +* sparc/erc32 is the architecture and BSP names.
>>> +* hello.exe is the executable name.
>>> +The test log records all the tests and results. The reporting mode by default
>>> +only provides the output history if a test fails, times out, or is invalid. The
>>> +time taken by each test is also recorded.
>>> +The tests must complete in a specified time or the test is marked as timed
>>> +out. The default timeout is 3 minutes and can be globally changed using the
>>> +``--timeout`` command line option. The time required to complete a test can
>>> +vary. When simulators are run in parallel the time taken depends on the
>>> +specifics of the host machine being used. A test per core is the most stable
>>> +method even though more tests can be run than available cores. If your machine
>>> +needs longer or you are using a VM you may need to lengthen the timeout.
>>> +Test Status
>>> +Tests can be marked with one of the following:
>>> +* Pass
>>> +* Fail
>>> +* Timeout
>>> +* Invalid
>>> +The RTEMS console or stdout output from the test is needed to determine the
>>> +result of the test.
>>> +Pass
>>> +A test passes if the start and end markers are seen in the test output. The
>>> +start marker is ``***`` and the end mark is ``*** END OF TEST``. All tests in
>>> +the RTEMS test suite have these markers.
>>> +Fail
>>> +A test fails if the start marker is seen and there is no end marker.
>>> +Timeout
>>> +If the test does not complete within the timeout setting the test is marked as
>>> +having timed out.
>>> +Invalid
>>> +If no start marker is seen the test is marked as invalid. If you are testing on
>>> +real target hardware things can sometimes go wrong and the target may not
>>> +initialize or respond to the debugger in an expected way.
>>> +Reporting
>>> +The report written to the log has the following modes:
>>> +* All (``all``)
>>> +* Failures (``failures``)
>>> +* None (``none``)
>>> +The mode is controlled using the command line option ``--report-mode`` using
>>> +the values listed above.
>>> +All
>>> +The output of all tests is written to the log.
>>> +Failures
>>> +The output of the all tests that do not pass is written to the log.
>>> +None
>>> +No output is written to the log.
>>> +The output is tagged so you can determine where it comes from. The following is
>>> +the complete output for the In Memory File System test ``imfs_fslink.exe``
>>> +running on a Coldfire MCF5235 using GDB and a BDM pod:
>>> +    [ 11/472] p:9   f:0   t:0   i:1   | m68k/mcf5235: imfs_fslink.exe
>>> +    > gdb: ..../bin/m68k-rtems4.11-gdb -i=mi --nx --quiet ..../imfs_fslink.exe
>>> +    > Reading symbols from ..../fstests/imfs_fslink/imfs_fslink.exe...
>>> +    > done.
>>> +    > target remote | m68k-bdm-gdbserver pipe 003-005
>>> +    > Remote debugging using | m68k-bdm-gdbserver pipe 003-005
>>> +    > m68k-bdm: debug module version 0
>>> +    > m68k-bdm: detected MCF5235
>>> +    > m68k-bdm: architecture CF5235 connected to 003-005
>>> +    > m68k-bdm: Coldfire debug module version is 0 (5206(e)/5235/5272/5282)
>>> +    > Process 003-005 created; pid = 0
>>> +    > 0x00006200 in ?? ()
>>> +    > thb *0xffe254c0
>>> +    > Hardware assisted breakpoint 1 at 0xffe254c0
>>> +    > continue
>>> +    > Continuing.
>>> +    ] External Reset
>>> +    ] ColdFire MCF5235 on the BCC
>>> +    ] Firmware v3b.1a.1a (Built on Jul 21 2004 17:31:28)
>>> +    ] Copyright 1995-2004 Freescale Semiconductor, Inc.  All Rights Reserved.
>>> +    ] Enter 'help' for help.
>>> +    > Temporary breakpoint
>>> +    > 1, 0xffe254c0 in ?? ()
>>> +    > load
>>> +    > Loading section .text, size 0x147e0 lma 0x40000
>>> +    > Loading section .data, size 0x5d0 lma 0x547e0
>>> +    > Start address 0x40414, load size 85424
>>> +    > Transfer rate: 10 KB/sec, 1898 bytes/write.
>>> +    > b bsp_reset
>>> +    > Breakpoint 2 at 0x41274: file ..../shared/bspreset_loop.c, line 14.
>>> +    > continue
>>> +    > Continuing.
>>> +    ] dBUG>
>>> +    ] *** FILE SYSTEM TEST ( IMFS ) ***
>>> +    ] Initializing filesystem IMFS
>>> +    ] *** LINK TEST ***
>>> +    ] link creates hardlinks
>>> +    ] test if the stat is the same
>>> +    ] chmod and chown
>>> +    ] unlink then stat the file
>>> +    ] *** END OF LINK TEST ***
>>> +    ] Shutting down filesystem IMFS
>>> +    ] *** END OF FILE SYSTEM TEST ( IMFS ) ***
>>> +    > Breakpoint
>>> +    > 2, bsp_reset () at ..../m68k/mcf5235/../../shared/bspreset_loop.c:14
>>> +    > 14    {
>>> +    Result: passed     Time: 0:00:10.045447
>>> +* GDB command line (Note: paths with \'....' have been shortened)
>>> +* Lines starting with ``>`` are from GDB's console.
>>> +* Line starting with ``]`` are from the target's console.
>>> +* The result with the test time.
>>> +Running Tests in Parallel
>>> +The RTEMS Tester supports parallel execution of tests by default. This only
>>> +makes sense if the test back-end can run in parallel without resulting in
>>> +resource contention. Simulators are an example of back-ends that can run in
>>> +parallel. A hardware debug tool like a BDM or JTAG pod can manage only a
>>> +single test at once so the tests need to be run one at a time.
>>> +The test framework manages the test jobs and orders the output in the report
>>> +log in test order. Output is held for completed tests until the next test to be
>>> +reported has finished.
>>> +Command Line Help
>>> +The ``rtems-test`` command line accepts a range of options. You can review the
>>> +available option by the ``--help`` option:
>>> +    RTEMS Tools Project (c) 2012-2014 Chris Johns
>>> +    Options and arguments:
>>> +    --always-clean               : Always clean the build tree, even with an error
>>> +    --debug-trace                : Debug trace based on specific flags
>>> +    --dry-run                    : Do everything but actually run the build
>>> +    --force                      : Force the build to proceed
>>> +    --jobs=[0..n,none,half,full] : Run with specified number of jobs, default: num CPUs.
>>> +    --keep-going                 : Do not stop on an error.
>>> +    --list-bsps                  : List the supported BSPs
>>> +    --log file                   : Log file where all build output is written to
>>> +    --macros file[,file]         : Macro format files to load after the defaults
>>> +    --no-clean                   : Do not clean up the build tree
>>> +    --quiet                      : Quiet output (not used)
>>> +    --report-mode                : Reporting modes, failures (default),all,none
>>> +    --rtems-bsp                  : The RTEMS BSP to run the test on
>>> +    --rtems-tools                : The path to the RTEMS tools
>>> +    --target                     : Set the target triplet
>>> +    --timeout                    : Set the test timeout in seconds (default 180 seconds)
>>> +    --trace                      : Trace the execution
>>> +    --warn-all                   : Generate warnings
>>> +Development
>>> +The RTEMS Tester framework and command line tool is under active
>>> +development. These are changing, being fixed, broken and generally improved. If
>>> +you want to help please see the Wiki page for open items.
>>> +History
>>> +The RTEMS Tester is based on a refactored base of Python code used in the RTEMS
>>> +Source Builder. This code provided a working tested base that has been extended
>>> +and expanded to meet the requirements for the RTEMS Tester. The tester uses the
>>> +specifics found in the various scripts and configurations in the
>>> +rtems-testing.git repo that has been accumulated over many years. The shell
>>> +script implementation is restricted in what it can do and, per BSP script, is a
>>> +maintenance burden. For example the command lines and options vary between each
>>> +script.
>>> 2.1.4
>> devel mailing list
>> devel at rtems.org
