rtems-test runtime errors qemu.cfg
Cillian O'Donnell
cpodonnell8 at gmail.com
Tue May 30 19:12:42 UTC 2017
Hi,
I'm trying to run rtems-test for pc386 with the added --coverage tag for
couverture-qemu. All tests default to dry-run because of errors in qemu.cfg
error: qemu.cfg:81: execute failed: qemu-system-i386 -m 128 -boot b -hda
/home/cpod/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/rtems-boot.img
-no-reboot -serial null -serial mon:stdio -nographic -append
"--console=com1;boot;" -kernel
/home/cpod/development/rtems/pc386/i386-rtems4.12/c/pc386/testsuites/samples/unlimited/unlimited.exe
-exec-trace coverage/unlimited.exe.cov: exit-code:2
warning: switched to dry run due to errors
The exit code I believe refers to 'no such file or directory'. In qemu.cfg
the line is:
%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable} %{coverage_arg}
It's a bit tricky to trace those macros back to different files and see
what they have. Is there any way to just print those out when it runs so I
can take a look at them.
I tried %print %{qemu_cmd} and %echo %{qemu_cmd}. Is there any way to do
this in a config file?
Thanks,
Cillian.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170530/9f03573b/attachment.html>
