[PATCH] Added documentation for rtems-tester in rtems-docs
Wed May 31 00:39:35 UTC 2017
On 31/05/2017 03:10, Tanu Hari Dixit wrote:
> I just added the image following what was already in rtems-tools.git
> repo. Maybe it is not really needed there. Maybe it was added to the
> previous doc because it was a stand-alone doc.
Yes this is correct. The User Manual is newer and has a consistent feel
we must maintain.
> I will pull that out.
> What do you think? What does Chris think?
The text needs to be merged into the User Manual converting it to ReST
format. I suggest you review the RTEMS BSP Builder [1] command as an
example. That format _must_ be followed for the Tools. Please create a
new file for this command and include after the RTEMS BSP Builder command.
Thanks
[1]
https://docs.rtems.org/branches/master/user/tools/index.html#rtems-bsp-builder
