[PATCH] Fixes typos in README.txt
Tanu Hari Dixit tokencolour at gmail.com
Wed May 31 10:24:16 UTC 2017
Hello Chris,
I have fixed the above authorship issue and sent the patch again. Thank you.
Regards,
Tanu.
On Wed, May 31, 2017 at 7:26 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 29/05/2017 22:29, Tanu Hari Dixit wrote:
>> From: tokencolour <tokencolour at gmail.com>
> Could we please have your name in the commit? It make the git log much more
> meaningful. For example:
> From: Tanu Hari Dixit <tokencolour at gmail.com>
> Thanks
> Chris
>> 2 typos fixed
>>   README.txt | 4 ++--
>>   1 file changed, 2 insertions(+), 2 deletions(-)
>> diff --git a/README.txt b/README.txt
>> index f09317e..c1b7e6f 100644
>> --- a/README.txt
>> +++ b/README.txt
>> @@ -316,7 +316,7 @@ existing documentation for an example and if unsure
>> ask.
>>         Heading   Description
>>         1  ###### Part
>>         2  ****** Section
>> -      3  ====== Sub-ection
>> +      3  ====== Sub-section
>>         4  ------ Sub-sub-section
>>         5  ^^^^^^ Sub-sub-sub-section
>>         6  ~~~~~~ Sub-sub-sub-sub-section
>> @@ -392,7 +392,7 @@ existing documentation for an example and if unsure
>> ask.
>>        users        : Users Mailing List
>>        vc           : Version Control Mailing List
>>   -  The valif URLs are:
>> +  The valid URLs are:
>>          trac         : https://devel.rtems.org/
>>        devel        : https://devel.rtems.org/
