[PATCH] confdefs.h: Add SMP enabled field to configuration
Joel Sherrill
joel at rtems.org
Fri May 12 09:15:50 UTC 2017
On May 12, 2017 3:44 AM, "Sebastian Huber" <
On 12/05/17 10:39, Chris Johns wrote:
> On 12/05/2017 18:11, Sebastian Huber wrote:
>> Do not use the processor count to determine if SMP is enabled. Instead
>> use a dedicated configuration option. Enable SMP by default in SMP
>> configurations.
>> Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
>> otherwise.
> I think adding a comment to the test explaining the reason would be good
> to have.
This is a new issue and not a 4.12 release blocker from my point of view:
https://devel.rtems.org/ticket/3020
This does not address Chris' question. Whether a blocker or not, it needs a
comment for each test. You can't add this patch without the comments before
or after branching.
My first thought was that your answer was comparable to "Ice cream has no
rocks."
Sebastian Huber, embedde brains GmbH
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170512/9a663c77/attachment-0002.html>
