Pre-processor magic or test library?
Thu Nov 2 12:01:06 UTC 2017
On 30/10/17 21:56, Chris Johns wrote:
> On 31/10/2017 01:21, Joel Sherrill wrote:
>> On Oct 30, 2017 8:43 AM, "Chris Johns" <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>>      On 28/10/2017 22:42, Sebastian Huber wrote:
>>      > we have currently some pre-processor magic to map the standard output
>>      functions to the RTEMS test printer. This works only if you include
>>      <tmacros.h> in every test file in the right spot. An alternative would be to
>>      use a separate library for all tests, e.g. librtemstest.a which provides
>>      puts(), printf(), fprintf(), etc. How do you think about this?
>>      I like it.
>> I like the idea but not using the same names for the.methods. this will mean
>> that if the linker magic isn't right, you end up getting the wrong implementation
> The testing output routings could postfix a character like '|' to '\n' and the
> tester can check the output always have that character in column 1 and flag the
> test and incorrectly linked if it does not?
Using the wrong output facility is not a catastrophe. Most tests work
fine with an interrupt driven console driver. I tried to provide a
special console driver using the polled char input/output functions
(attached patch), however, most console drivers define
console_initialize() and the BSP_output_char in one file. Changing this
would require more work than I can dedicate to this task.
Getting rid of printf(), fprintf() and Termios would enable test runs on
more low-end targets.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171102/d419eabb/attachment.bin>
