[PATCH] c-user/configuring_a_system.rst: Delete notepads section
    Joel Sherrill
    joel at rtems.org
    Thu Nov  2 15:14:24 UTC 2017
closes #3215.
 c-user/configuring_a_system.rst | 32 --------------------------------
 1 file changed, 32 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index c91c8b6..c0b7151 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -559,38 +559,6 @@ NOTES:
 .. COMMENT: XXX - Add xref to CONFIGURE_MAXIMUM_POSIX_THREADS.
-.. COMMENT: === CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS ===
-.. _Specify Maximum Classic API Timers:
-Specify Maximum Classic API Timers
-.. index:: CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS
-CONSTANT:
-    ``CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default, and Classic API Notepads are not supported.
-DESCRIPTION:
-    ``CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS`` should be defined if the
-    user wants to have support for Classic API Notepads in their application.
-NOTES:
-    Disabling Classic API Notepads saves the allocation of sixteen (16)
-    thirty-two bit integers. This saves sixty-four bytes per task/thread
-    plus the allocation overhead. Notepads are rarely used in applications
-    and this can save significant memory in a low RAM system. Classic API
-    Notepads are deprecated, and this option has been removed from
-    post 4.11 versions of RTEMS.
 .. COMMENT: === CONFIGURE_MAXIMUM_TIMERS ===
1.8.3.1
