RTEMS Tier Allocations.
Sebastian Huber
Mon Nov 6 10:20:12 UTC 2017
On 27/10/17 07:13, Chris Johns wrote:
> On 26/10/2017 18:50, Sebastian Huber wrote:
>> with the change to the INI format files, the
>> target_pretest_command
>> target_exe_filter_command
>> disappeared.
> Oh I changed some names as part of a clean up.
>> I am not sure how I can invoke the tester for a board using U-Boot
>> connected via TTY or telnet. Do you have an example command line?
> Of course, with the removal of my local set up there is nothing left in the BSP configurations as examples.
> A command line is:
> $ sudo rtems-test --rtems-tools=/opt/work/rtems/4.12 \
> --rtems-bsp=xilinx_zynq_zedboard \
> --timeout=60 --log=t.txt \
> --user-config=$HOME/.rtemstesterrc \
> --mail .
How did you setup your mail configuration? A
sudo /opt/rtems-4.12/bin/rtems-test --rtems-bsp=imx7
--rtems-tools=/opt/rtems-4.12
/build/git-build/b-imx7/arm-rtems4.12/c/imx7/testsuites/samples/ticker/
--timeout=180 --user-config=$HOME/.rtemstesterrc --debug-trace=output
--log=l.txt --mail-from="sebastian.huber at embedded-brains.de" --mail
yields
error: no valid from address for mail
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
