[PATCH] CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
Sebastian Huber
Mon Nov 6 12:02:41 UTC 2017
Close #3170.
Update #3199.
c-user/configuring_a_system.rst | 38 ++++++++++++++++++++++++++++++++++++++
1 file changed, 38 insertions(+)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 0d4ebd7..2890a95 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -3822,6 +3822,44 @@ NOTES:
BSPs should be constructed in a manner that allows ``printk()`` to work
properly without the need for the console driver to be configured.
+ The ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` configuration option is
+ mutually exclusive with the
+ ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` configuration option.
+.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+CONSTANT:
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+ This is not defined by default.
+DESCRIPTION:
+ ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` is defined if the
+ application wishes to include the Simple Console Device Driver.
+NOTES:
+ This device driver is responsible for providing standard input and output
+ using */dev/console*.
+ This device driver writes via ``rtems_putc()`` and reads via
+ ``getchark()``. The Termios framework is not used. There is no support to
+ change device settings, e.g. baud, stop bits, parity, etc.
+ The ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` configuration
+ option is mutually exclusive with the
+ ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` configuration option.
.. _CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER:
2.12.3
