[PATCH v2] cpukit: Add a Version API.
Chris Johns
chrisj at rtems.org
Tue Nov 7 16:02:17 UTC 2017
Provide functions to get the version string, major, minor and revision
numbers and the version control identifer that is a unique tag for
the version control system.
Update #3199.
cpukit/sapi/Makefile.am | 35 +++++++++++-
cpukit/sapi/include/rtems/version.h | 77 ++++++++++++++++++++++++++
cpukit/sapi/preinstall.am | 4 ++
cpukit/sapi/src/version.c | 63 +++++++++++++++++++++
cpukit/sapi/vc-key.sh | 38 +++++++++++++
cpukit/sapi/version-vc-key.h.in | 7 +++
testsuites/sptests/Makefile.am | 1 +
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/spversion01/Makefile.am | 20 +++++++
testsuites/sptests/spversion01/init.c | 58 +++++++++++++++++++
testsuites/sptests/spversion01/spversion01.doc | 24 ++++++++
testsuites/sptests/spversion01/spversion01.scn | 21 +++++++
12 files changed, 348 insertions(+), 1 deletion(-)
create mode 100644 cpukit/sapi/include/rtems/version.h
create mode 100644 cpukit/sapi/src/version.c
create mode 100755 cpukit/sapi/vc-key.sh
create mode 100644 cpukit/sapi/version-vc-key.h.in
create mode 100644 testsuites/sptests/spversion01/Makefile.am
create mode 100644 testsuites/sptests/spversion01/init.c
create mode 100644 testsuites/sptests/spversion01/spversion01.doc
create mode 100644 testsuites/sptests/spversion01/spversion01.scn
diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
index 50d065be7e..0c67b46076 100644
--- a/cpukit/sapi/Makefile.am
+++ b/cpukit/sapi/Makefile.am
@@ -22,6 +22,7 @@ include_rtems_HEADERS += include/rtems/rbtree.h
include_rtems_HEADERS += include/rtems/scheduler.h
include_rtems_HEADERS += include/rtems/timecounter.h
include_rtems_HEADERS += include/rtems/timespec.h
+include_rtems_HEADERS += include/rtems/version.h
EXTRA_DIST = include/rtems/README
@@ -34,7 +35,7 @@ libsapi_a_SOURCES = src/extension.c src/extensioncreate.c \
src/getversionstring.c \
src/chainappendnotify.c src/chaingetnotify.c src/chaingetwait.c \
src/chainprependnotify.c src/rbheap.c src/interrtext.c \
- src/fatalsrctext.c
+ src/fatalsrctext.c src/version.c
libsapi_a_SOURCES += src/chainprotected.c
libsapi_a_SOURCES += src/cpucounterconverter.c
libsapi_a_SOURCES += src/delayticks.c
@@ -47,5 +48,37 @@ libsapi_a_SOURCES += src/profilingreportxml.c
libsapi_a_SOURCES += src/tcsimpleinstall.c
libsapi_a_CPPFLAGS = $(AM_CPPFLAGS)
+# Create a new Version VC Key header if the VC state has changed.
+vc_key_stamp = $(am__leading_dot)vc-key-stamp
+$(vc_key_stamp): version-vc-key.h.in vc-key.sh
+ @+rm -f $(vc_key_stamp)
+.PHONY: ../version-vc-key.h
+../version-vc-key.h:
+ @+current_vc_key=""; \
+ if test -f $(vc_key_stamp); then \
+ current_vc_key=`cat $(vc_key_stamp)`; \
+ fi; \
+ vc_key=`$(top_srcdir)/sapi/vc-key.sh $(top_srcdir) $$current_vc_key`; \
+ if test "$$vc_key" != "matches"; then \
+ echo "Generating version-vc-key.h"; \
+ if test "$$vc_key" == "release"; then \
+ vc_header_key="\/\* No version control key found; release\? \*\/"; \
+ else \
+ vc_header_key="#define RTEMS_VERSION_VC_KEY \"$$vc_key\""; \
+ fi; \
+ cat $(top_srcdir)/sapi/version-vc-key.h.in | \
+ sed -e "s/@VERSION_VC_KEY@/$$vc_header_key/g" > ../version-vc-key.h; \
+ echo "$$vc_key" > $(vc_key_stamp); \
+ fi
+all-local: ../version-vc-key.h
+src/version.c: ../version-vc-key.h
include $(srcdir)/preinstall.am
include $(top_srcdir)/automake/local.am
diff --git a/cpukit/sapi/include/rtems/version.h b/cpukit/sapi/include/rtems/version.h
new file mode 100644
index 0000000000..b806cb8c2f
--- /dev/null
+++ b/cpukit/sapi/include/rtems/version.h
@@ -0,0 +1,77 @@
+ * @file
+ * @brief Version API.
+ * Copyright (C) 2017.
+ * Chris Johns <chrisj at rtems.org>
+#ifndef _RTEMS_VERSION_H
+#define _RTEMS_VERSION_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup ClassicVersion Version
+ * @ingroup ClassicVersion
+ * @brief The Version API provides functions to return the version or parts of
+ * the version of RTEMS you are using.
+ * @brief Returns the version string.
+ * @retval text The version as a string.
+const char *rtems_version( void );
+ * @brief Returns the version's major number.
+ * @retval int The version's major number.
+int rtems_version_major( void );
+ * @brief Returns the version's minor number.
+ * @retval int The version's minor number.
+int rtems_version_minor( void );
+ * @brief Returns the version's revision number.
+ * @retval int The version's revision number.
+int rtems_version_revision( void );
+ * @brief Returns the version control key for the current version of code that
+ * has been built. The key is specific to the version control system being used
+ * and allows the built version to be identified.
+ * @retval int The version's version control key.
+const char *rtems_version_control_key( void );
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/sapi/preinstall.am b/cpukit/sapi/preinstall.am
index b1bdf48ac2..a6b0ba30df 100644
--- a/cpukit/sapi/preinstall.am
+++ b/cpukit/sapi/preinstall.am
@@ -94,3 +94,7 @@ $(PROJECT_INCLUDE)/rtems/timespec.h: include/rtems/timespec.h $(PROJECT_INCLUDE)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/timespec.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/timespec.h
+$(PROJECT_INCLUDE)/rtems/version.h: include/rtems/version.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/version.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/version.h
diff --git a/cpukit/sapi/src/version.c b/cpukit/sapi/src/version.c
index 0000000000..d240b1b0df
--- /dev/null
+++ b/cpukit/sapi/src/version.c
@@ -0,0 +1,63 @@
+ * @file
+ * @brief Creates the version strings from the various pieces of version
+ * information. The main version number is part of the build system and is
+ * stamped into rtems/score/cpuopts.h. The version control key string is
+ * extracted from the version control tool when the code is being built and is
+ * updated if it has changed. The key may indicate there are local
+ * modification.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/version.h>
+#include "version-vc-key.h"
+#ifdef RTEMS_VERSION_VC_KEY
+ return RTEMS_VERSION "." RTEMS_VERSION_VC_KEY;
+#else
+ return RTEMS_VERSION;
+#endif
+ return __RTEMS_MAJOR__;
+ return __RTEMS_MINOR__;
+ return __RTEMS_REVISION__;
+ return RTEMS_VERSION_VC_KEY;
+#else
+ return NULL;
+#endif
diff --git a/cpukit/sapi/vc-key.sh b/cpukit/sapi/vc-key.sh
new file mode 100755
index 0000000000..7c0b3f992b
--- /dev/null
+++ b/cpukit/sapi/vc-key.sh
@@ -0,0 +1,38 @@
+#! /bin/sh
+git=$(command -v git)
+# Git command not found or not a valid git repo is a release.
+vc_ident="release"
+if test $# -ge 1; then
+ repo=$1
+ shift
+ if test -d $repo; then
+ cwd=$(pwd)
+ cd $repo
+ if test -n ${git}; then
+ git rev-parse --git-dir> /dev/null 2>&1
+ if test $? == 0; then
+ if git diff-index --quiet HEAD --; then
+ modified=""
+ else
+ modified="-modified"
+ fi
+ vc_ident="$(git rev-parse --verify HEAD)${modified}"
+ if test $# -ge 1; then
+ if test "${vc_ident}" == "$1"; then
+ vc_ident="matches"
+ fi
+ fi
+ fi
+ fi
+ cd $cwd
+ fi
+fi
+echo ${vc_ident}
+exit 0
diff --git a/cpukit/sapi/version-vc-key.h.in b/cpukit/sapi/version-vc-key.h.in
index 0000000000..738e24d19d
--- /dev/null
+++ b/cpukit/sapi/version-vc-key.h.in
@@ -0,0 +1,7 @@
+ * Automatically generated. Do not edit.
+#if !defined(_RTEMS_VERSION_VC_KEY_H_)
+#define _RTEMS_VERSION_VC_KEY_H_
+ at VERSION_VC_KEY@
+#endif
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index f02d277142..d068a50aa3 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -81,6 +81,7 @@ _SUBDIRS += sptimer_err01 sptimer_err02
_SUBDIRS += sptimerserver01
_SUBDIRS += spclock_err02
_SUBDIRS += spcpuset01
+_SUBDIRS += spversion01
include $(top_srcdir)/../automake/subdirs.am
include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 8ecd9b75f1..cca94ebfe5 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -252,5 +252,6 @@ spcpuset01/Makefile
spregion_err01/Makefile
sppartition_err01/Makefile
sprmsched01/Makefile
+spversion01/Makefile
AC_OUTPUT
diff --git a/testsuites/sptests/spversion01/Makefile.am b/testsuites/sptests/spversion01/Makefile.am
index 0000000000..0ab6da4756
--- /dev/null
+++ b/testsuites/sptests/spversion01/Makefile.am
@@ -0,0 +1,20 @@
+rtems_tests_PROGRAMS = spversion01
+spversion01_SOURCES = init.c
+dist_rtems_tests_DATA = spversion01.scn spversion01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spversion01_OBJECTS)
+LINK_LIBS = $(spversion01_LDLIBS)
+spversion01$(EXEEXT): $(spversion01_OBJECTS) $(spversion01_DEPENDENCIES)
+ @rm -f spversion01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spversion01/init.c b/testsuites/sptests/spversion01/init.c
index 0000000000..3fc6f0a89c
--- /dev/null
+++ b/testsuites/sptests/spversion01/init.c
@@ -0,0 +1,58 @@
+ * COPYRIGHT (c) 1989-2011.
+ * On-Line Applications Research Corporation (OAR).
+#ifdef HAVE_CONFIG_H
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+const char rtems_test_name[] = "VERSION 1";
+static rtems_task Init(
+ rtems_task_argument argument
+ TEST_BEGIN();
+ printf("Release : %s\n", rtems_version());
+ printf("Major : %d\n", rtems_version_major());
+ printf("Minor : %d\n", rtems_version_minor());
+ printf("Revision : %d\n", rtems_version_revision());
+ printf("VC Key : %s\n", rtems_version_control_key());
+ TEST_END();
+ rtems_test_exit(0);
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS (4 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_DISABLE_SMP_CONFIGURATION
+#include <rtems/confdefs.h>
+/* global variables */
diff --git a/testsuites/sptests/spversion01/spversion01.doc b/testsuites/sptests/spversion01/spversion01.doc
index 0000000000..5c82a933dc
--- /dev/null
+++ b/testsuites/sptests/spversion01/spversion01.doc
@@ -0,0 +1,24 @@
+# Copyright (C) 2017
+# Chris Johns <chrisj at rtems.org>
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: spversion01
+directives:
+ rtems_version - return the RTEMS version string with VC indent if present.
+ rtems_major - return the RTEMS major version number.
+ rtems_minor - return the RTEMS minor version number.
+ rtems_release - return the RTEMS version release number.
+ rtems_vc_ident - return the RTEMS Version Control (VC) indent string.
+concepts:
++ Ensure the files are correctly generated and the headers can be built and
+ the API is usable.
diff --git a/testsuites/sptests/spversion01/spversion01.scn b/testsuites/sptests/spversion01/spversion01.scn
index 0000000000..a0f2282510
--- /dev/null
+++ b/testsuites/sptests/spversion01/spversion01.scn
@@ -0,0 +1,21 @@
+Valid version control:
+*** BEGIN OF TEST VERSION 1 ***
+Release : 4.11.99.0.d71542c8bef50261bc3904ef6a17f0b6087d04d9-modified
+Major : 4
+Minor : 11
+Revision : 99
+VC Key : d71542c8bef50261bc3904ef6a17f0b6087d04d9-modified
+*** END OF TEST VERSION 1 ***
+No valid version control:
+Major : 4
+Minor : 11
+Revision : 99
+VC Key : (null)
2.13.2
