[PATCH] tests: Use ld to map (wrap) printf, puts and putchar to tester functions.
Wed Nov 8 02:29:53 UTC 2017
- Remove the macro defines and the need for tmacro.h by remapping the
  symbols using ld's wrap option.
- Remove FLUSH_OUTPUT, it was empty.
- Move rtems_test_exit to libmisc/testsupport as a function.
Update #3199.
 cpukit/libmisc/Makefile.am                  |  1 +
 cpukit/libmisc/testsupport/test.h           |  6 ++++
 cpukit/libmisc/testsupport/testbeginend.c   |  6 ++++
 cpukit/libmisc/testsupport/testwrappers.c   | 48 +++++++++++++++++++++++++++++
 testsuites/automake/compile.am              |  5 +--
 testsuites/automake/local.am                |  2 ++
 testsuites/libtests/rtmonuse/task1.c        |  2 --
 testsuites/sptests/sp14/asr.c               |  2 --
 testsuites/sptests/sp14/task1.c             |  5 +--
 testsuites/sptests/sp14/task2.c             |  1 -
 testsuites/support/include/buffer_test_io.h | 28 -----------------
 testsuites/support/include/tmacros.h        | 13 --------
 12 files changed, 67 insertions(+), 52 deletions(-)
 create mode 100644 cpukit/libmisc/testsupport/testwrappers.c
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index 786782931c..e1343ddf11 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -182,6 +182,7 @@ libtestsupport_a_SOURCES += testsupport/testbeginend.c
 libtestsupport_a_SOURCES += testsupport/testbusy.c
 libtestsupport_a_SOURCES += testsupport/testextension.c
 libtestsupport_a_SOURCES += testsupport/testparallel.c
+libtestsupport_a_SOURCES += testsupport/testwrappers.c
 ## fsmount
 noinst_LIBRARIES += libfsmount.a
diff --git a/cpukit/libmisc/testsupport/test.h b/cpukit/libmisc/testsupport/test.h
index 116b92d1ae..2b4fcd1073 100644
--- a/cpukit/libmisc/testsupport/test.h
+++ b/cpukit/libmisc/testsupport/test.h
@@ -105,6 +105,12 @@ int rtems_test_begin(const char* name, const RTEMS_TEST_STATE state);
 int rtems_test_end(const char* name);
+ * @brief Exit the test without calling exit() since it closes stdin, etc and
+ * pulls in stdio code
+void rtems_test_exit(int status);
  * @brief Prints via the RTEMS printer.
  * @returns As specified by printf().
diff --git a/cpukit/libmisc/testsupport/testbeginend.c b/cpukit/libmisc/testsupport/testbeginend.c
index 04748cb796..f9dab4ea32 100644
--- a/cpukit/libmisc/testsupport/testbeginend.c
+++ b/cpukit/libmisc/testsupport/testbeginend.c
@@ -123,6 +123,12 @@ int rtems_test_end(const char* name)
+  (void) status;
+  rtems_shutdown_executive(0);
 int rtems_test_printf(
   const char* format,
diff --git a/cpukit/libmisc/testsupport/testwrappers.c b/cpukit/libmisc/testsupport/testwrappers.c
new file mode 100644
index 0000000000..c86c4cc3f8
--- /dev/null
+++ b/cpukit/libmisc/testsupport/testwrappers.c
@@ -0,0 +1,48 @@
+ * Copyright (c) 2017 Chris Johns <chrisj at rtems.org>. All rights reserved.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/test.h>
+int __wrap_printf(const char* format, ...);
+int __wrap_puts(const char *str);
+int __wrap_putchar(int c);
+int __wrap_printf(
+ const char* format,
+  va_list ap;
+  int len;
+  va_start(ap, format);
+  len = rtems_vprintf(
+    &rtems_test_printer,
+    format,
+    ap
+  va_end(ap);
+  return len;
+int __wrap_puts(
+  const char *str
+  return rtems_test_printf( "%s\n", str );
+  int c
+  return rtems_test_printf( "%c", c );
diff --git a/testsuites/automake/compile.am b/testsuites/automake/compile.am
index d5545c5a2f..ee1f77381a 100644
--- a/testsuites/automake/compile.am
+++ b/testsuites/automake/compile.am
@@ -10,7 +10,8 @@ STRIP = @STRIP@
 AM_CPPFLAGS = $(TEST_FLAGS)
-AM_CFLAGS =
-AM_CXXFLAGS =
+AM_CFLAGS   = $(TEST_C_FLAGS)
+AM_CXXFLAGS = $(TEST_CXX_FLAGS)
+AM_LDFLAGS  = $(TEST_LD_FLAGS)
 CLEANFILES = *.num *.nxe *.elf *.srec* *.bin *.bt *.ralf
diff --git a/testsuites/automake/local.am b/testsuites/automake/local.am
index aaf86ac44c..31299028d6 100644
--- a/testsuites/automake/local.am
+++ b/testsuites/automake/local.am
@@ -2,3 +2,5 @@ preinstall:
 .PHONY: preinstall
 PROJECT_TOOLS = $(PROJECT_RELEASE)/build-tools
+TEST_LD_FLAGS = -Wl,--wrap=printf -Wl,--wrap=puts -Wl,--wrap=putchar
diff --git a/testsuites/libtests/rtmonuse/task1.c b/testsuites/libtests/rtmonuse/task1.c
index 9e8cf8fce7..b0db7fe4be 100644
--- a/testsuites/libtests/rtmonuse/task1.c
+++ b/testsuites/libtests/rtmonuse/task1.c
@@ -105,8 +105,6 @@ rtems_task Task_1_through_5(
         printf( "TA5 - PERIODS CHECK OK (%" PRIu32 ")\n", pass );
-        FLUSH_OUTPUT();
         if ( pass == 10 ) {
           puts( "" );
           rtems_rate_monotonic_report_statistics();
diff --git a/testsuites/sptests/sp14/asr.c b/testsuites/sptests/sp14/asr.c
index e9187cc778..4239a34183 100644
--- a/testsuites/sptests/sp14/asr.c
+++ b/testsuites/sptests/sp14/asr.c
@@ -32,7 +32,6 @@ rtems_asr Process_asr(
     case RTEMS_SIGNAL_0:
     case RTEMS_SIGNAL_1:
       puts( "ASR - rtems_task_wake_after - yield processor" );
-      FLUSH_OUTPUT();
       status = rtems_task_wake_after( RTEMS_YIELD_PROCESSOR );
       directive_failed( status, "rtems_task_wake_after yield" );
       break;
@@ -44,5 +43,4 @@ rtems_asr Process_asr(
     "ASR - EXIT  - signal => %08" PRIxrtems_signal_set "\n",
      the_signal_set
-  FLUSH_OUTPUT();
diff --git a/testsuites/sptests/sp14/task1.c b/testsuites/sptests/sp14/task1.c
index e71070d368..7a8559d875 100644
--- a/testsuites/sptests/sp14/task1.c
+++ b/testsuites/sptests/sp14/task1.c
@@ -52,9 +52,7 @@ rtems_task Task_1(
   status = rtems_signal_catch( Process_asr, RTEMS_NO_ASR );
   directive_failed( status, "rtems_signal_catch" );
-  FLUSH_OUTPUT();
-rtems_test_pause();
+  rtems_test_pause();
   puts( "TA1 - rtems_signal_send - RTEMS_SIGNAL_1 to self" );
   status = rtems_signal_send( RTEMS_SELF, RTEMS_SIGNAL_1 );
@@ -98,7 +96,6 @@ rtems_test_pause();
   puts( "TA1 - rtems_task_mode - enable ASRs" );
-  FLUSH_OUTPUT();
   status = rtems_task_mode( RTEMS_ASR, RTEMS_ASR_MASK, &previous_mode );
   directive_failed( status, "rtems_task_mode" );
diff --git a/testsuites/sptests/sp14/task2.c b/testsuites/sptests/sp14/task2.c
index 9e1714fe87..da14dc8ce3 100644
--- a/testsuites/sptests/sp14/task2.c
+++ b/testsuites/sptests/sp14/task2.c
@@ -44,7 +44,6 @@ rtems_task Task_2(
   directive_failed( status, "rtems_signal_send" );
   puts( "TA2 - rtems_task_wake_after - yield processor" );
-  FLUSH_OUTPUT();
   directive_failed( status, "rtems_task_wake_after" );
diff --git a/testsuites/support/include/buffer_test_io.h b/testsuites/support/include/buffer_test_io.h
index 8fbcd68b3e..ea68fea0d8 100644
--- a/testsuites/support/include/buffer_test_io.h
+++ b/testsuites/support/include/buffer_test_io.h
@@ -11,34 +11,6 @@
 extern "C" {
 #endif
-#undef printf
-#define printf(...) \
-  do { \
-     rtems_printf( &rtems_test_printer, __VA_ARGS__ ); \
-  } while (0)
-#undef puts
-#define puts(_s) \
-  do { \
-     rtems_printf( &rtems_test_printer, "%s\n", _s ); \
-  } while (0)
-#undef putchar
-#define putchar(_c) \
-  do { \
-     rtems_printf( &rtems_test_printer, "%c", _c ); \
-  } while (0)
-/* Do not call exit() since it closes stdin, etc and pulls in stdio code */
-#define rtems_test_exit(_s) \
-  do { \
-    rtems_shutdown_executive(0); \
-  } while (0)
-#define FLUSH_OUTPUT() \
-  do { \
-  } while (0)
 #define TEST_BEGIN() rtems_test_begin(rtems_test_name, TEST_STATE)
 #define TEST_END()   rtems_test_end(rtems_test_name)
diff --git a/testsuites/support/include/tmacros.h b/testsuites/support/include/tmacros.h
index 354d4cf60f..60da7647dc 100644
--- a/testsuites/support/include/tmacros.h
+++ b/testsuites/support/include/tmacros.h
@@ -64,7 +64,6 @@ extern "C" {
         "\n_Thread_Dispatch_disable_level is (%i)" \
            " not %d detected at %s:%d\n", \
          !_Thread_Dispatch_is_enabled(), (_expect), __FILE__, __LINE__ ); \
-      FLUSH_OUTPUT(); \
       rtems_test_exit( 1 ); \
   } while ( 0 )
@@ -84,7 +83,6 @@ extern "C" {
         __FILE__, \
         __LINE__ \
-      FLUSH_OUTPUT(); \
   } while ( 0 )
@@ -107,7 +105,6 @@ extern "C" {
     if ( (_stat) != (_desired) ) { \
       printf( "\n%s FAILED -- expected (%s) got (%s)\n", \
               (_msg), rtems_status_text(_desired), rtems_status_text(_stat) ); \
-      FLUSH_OUTPUT(); \
       rtems_test_exit( _stat ); \
   } while ( 0 )
@@ -137,7 +134,6 @@ extern "C" {
     printf( "\n%s FAILED -- expected (%d - %s) got (%ld %d - %s)\n", \
 	    (_msg), _desired, strerror(_desired), \
             statx, errno, strerror(errno) ); \
-    FLUSH_OUTPUT(); \
@@ -153,7 +149,6 @@ extern "C" {
               (_msg), _desired, strerror(_desired), _stat, strerror(_stat) ); \
       printf( "\n FAILED -- errno (%d - %s)\n", \
-      FLUSH_OUTPUT(); \
   } while ( 0 )
@@ -166,7 +161,6 @@ extern "C" {
     check_dispatch_disable_level( 0 ); \
     printf( "\n%s FAILED -- expected (-1) got (%p - %d/%s)\n", \
 	    (_msg), _ptr, errno, strerror(errno) ); \
-    FLUSH_OUTPUT(); \
     rtems_test_exit( -1 ); \
@@ -178,7 +172,6 @@ extern "C" {
     printf( "\n%s FAILED -- expected (-1) got (%" PRId32 " - %d/%s)\n", \
-    FLUSH_OUTPUT(); \
@@ -202,7 +195,6 @@ extern "C" {
       printf( "\n%s FAILED -- expected (%d) got (%d)\n", \
               (_msg), (_desired), (_stat) ); \
-      FLUSH_OUTPUT(); \
   } while ( 0 )
@@ -229,7 +221,6 @@ extern "C" {
 #define put_dot( _c ) \
   do { \
     putchar( _c ); \
-    FLUSH_OUTPUT(); \
   } while ( 0 )
 #define new_line  puts( "" )
@@ -240,20 +231,17 @@ extern "C" {
 #define rtems_test_pause() \
     do { \
       printf( "<pause>\n" ); \
-      FLUSH_OUTPUT(); \
   } while ( 0 )
 #define rtems_test_pause_and_screen_number( _screen ) \
   do { \
     printf( "<pause - screen %d>\n", (_screen) ); \
-    FLUSH_OUTPUT(); \
   } while ( 0 )
 #else
   do { \
     char buffer[ 80 ]; \
     printf( "<pause>" ); \
-    FLUSH_OUTPUT(); \
     gets( buffer ); \
     puts( "" ); \
   } while ( 0 )
@@ -262,7 +250,6 @@ extern "C" {
   do { \
     printf( "<pause - screen %d>", (_screen) ); \
-    FLUSH_OUTPUT(); \
     gets( buffer ); \
     puts( "" ); \
   } while ( 0 )
2.13.2
