[PATCH] Change RTEMS version from 4.12 to 5
Sebastian Huber
Wed Nov 8 08:47:38 UTC 2017
rtemstoolkit/version.py | 2 +-
tester/rtems/version.cfg | 2 +-
wscript | 2 +-
3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/rtemstoolkit/version.py b/rtemstoolkit/version.py
index b90b3ea..6c2e5e6 100644
--- a/rtemstoolkit/version.py
+++ b/rtemstoolkit/version.py
@@ -53,7 +53,7 @@ except (ValueError, SystemError):
# Default to an internal string.
-_version = '4.12'
+_version = '5'
_revision = 'not_released'
_version_str = '%s.%s' % (_version, _revision)
_released = False
diff --git a/tester/rtems/version.cfg b/tester/rtems/version.cfg
index 22e850b..2cd9073 100644
--- a/tester/rtems/version.cfg
+++ b/tester/rtems/version.cfg
@@ -32,4 +32,4 @@
# RTEMS Version
-%define rtems_version 4.12
+%define rtems_version 5
diff --git a/wscript b/wscript
index 11c93f3..0a34d47 100644
--- a/wscript
+++ b/wscript
@@ -38,7 +38,7 @@ subdirs = ['rtemstoolkit',
'tools/gdb/python']
def get_version(ctx):
- version = '4.12'
+ version = '5'
release = '%s.%s' % (version, revision)
if os.path.exists('VERSION'):
2.12.3
