[PATCH 1/2] Change RTEMS version from 4.12 to 5
Sebastian Huber
Wed Nov 8 09:37:51 UTC 2017
rtems/config/4.12/rtems-all.bset | 20 --------------------
rtems/config/4.12/rtems-tier-3.bset | 18 ------------------
rtems/config/{4.12 => 5}/rtems-aarch64.bset | 2 +-
rtems/config/5/rtems-all.bset | 20 ++++++++++++++++++++
rtems/config/{4.12 => 5}/rtems-arm.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-autotools-base.bset | 2 +-
.../config/{4.12 => 5}/rtems-autotools-internal.bset | 4 ++--
rtems/config/{4.12 => 5}/rtems-autotools.bset | 6 +++---
rtems/config/{4.12 => 5}/rtems-bfin.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-default.bset | 6 +++---
rtems/config/{4.12 => 5}/rtems-epiphany.bset | 6 +++---
rtems/config/{4.12 => 5}/rtems-i386.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-lm32.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-m32c.bset | 6 +++---
rtems/config/{4.12 => 5}/rtems-m68k.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-microblaze.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-mips.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-moxie.bset | 4 ++--
rtems/config/{4.12 => 5}/rtems-nios2.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-or1k.bset | 6 +++---
rtems/config/{4.12 => 5}/rtems-powerpc.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-riscv32.bset | 6 +++---
rtems/config/{4.12 => 5}/rtems-riscv64.bset | 6 +++---
rtems/config/{4.12 => 5}/rtems-sh.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-sparc.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-sparc64.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-tier-1.bset | 4 ++--
rtems/config/{4.12 => 5}/rtems-tier-2.bset | 0
rtems/config/5/rtems-tier-3.bset | 18 ++++++++++++++++++
rtems/config/{4.12 => 5}/rtems-tier-4.bset | 8 ++++----
rtems/config/{4.12 => 5}/rtems-tools.bset | 4 ++--
rtems/config/{4.12 => 5}/rtems-v850.bset | 2 +-
rtems/config/{4.12 => 5}/rtems-x86_64.bset | 2 +-
rtems/config/rtems-version.bset | 4 ++--
.../{rtems-kernel-4.12.cfg => rtems-kernel-5.cfg} | 2 +-
.../{rtems-tools-4.12-1.cfg => rtems-tools-5-1.cfg} | 2 +-
36 files changed, 91 insertions(+), 91 deletions(-)
delete mode 100644 rtems/config/4.12/rtems-all.bset
delete mode 100644 rtems/config/4.12/rtems-tier-3.bset
rename rtems/config/{4.12 => 5}/rtems-aarch64.bset (66%)
create mode 100644 rtems/config/5/rtems-all.bset
rename rtems/config/{4.12 => 5}/rtems-arm.bset (65%)
rename rtems/config/{4.12 => 5}/rtems-autotools-base.bset (84%)
rename rtems/config/{4.12 => 5}/rtems-autotools-internal.bset (68%)
rename rtems/config/{4.12 => 5}/rtems-autotools.bset (87%)
rename rtems/config/{4.12 => 5}/rtems-bfin.bset (56%)
rename rtems/config/{4.12 => 5}/rtems-default.bset (75%)
rename rtems/config/{4.12 => 5}/rtems-epiphany.bset (94%)
rename rtems/config/{4.12 => 5}/rtems-i386.bset (65%)
rename rtems/config/{4.12 => 5}/rtems-lm32.bset (89%)
rename rtems/config/{4.12 => 5}/rtems-m32c.bset (87%)
rename rtems/config/{4.12 => 5}/rtems-m68k.bset (56%)
rename rtems/config/{4.12 => 5}/rtems-microblaze.bset (59%)
rename rtems/config/{4.12 => 5}/rtems-mips.bset (81%)
rename rtems/config/{4.12 => 5}/rtems-moxie.bset (71%)
rename rtems/config/{4.12 => 5}/rtems-nios2.bset (56%)
rename rtems/config/{4.12 => 5}/rtems-or1k.bset (88%)
rename rtems/config/{4.12 => 5}/rtems-powerpc.bset (74%)
rename rtems/config/{4.12 => 5}/rtems-riscv32.bset (75%)
rename rtems/config/{4.12 => 5}/rtems-riscv64.bset (75%)
rename rtems/config/{4.12 => 5}/rtems-sh.bset (65%)
rename rtems/config/{4.12 => 5}/rtems-sparc.bset (65%)
rename rtems/config/{4.12 => 5}/rtems-sparc64.bset (57%)
rename rtems/config/{4.12 => 5}/rtems-tier-1.bset (56%)
rename rtems/config/{4.12 => 5}/rtems-tier-2.bset (100%)
create mode 100644 rtems/config/5/rtems-tier-3.bset
rename rtems/config/{4.12 => 5}/rtems-tier-4.bset (67%)
rename rtems/config/{4.12 => 5}/rtems-tools.bset (72%)
rename rtems/config/{4.12 => 5}/rtems-v850.bset (56%)
rename rtems/config/{4.12 => 5}/rtems-x86_64.bset (66%)
rename rtems/config/tools/{rtems-kernel-4.12.cfg => rtems-kernel-5.cfg} (88%)
rename rtems/config/tools/{rtems-tools-4.12-1.cfg => rtems-tools-5-1.cfg} (91%)
diff --git a/rtems/config/4.12/rtems-all.bset b/rtems/config/4.12/rtems-all.bset
deleted file mode 100644
index 8ec3a09..0000000
--- a/rtems/config/4.12/rtems-all.bset
+++ /dev/null
@@ -1,20 +0,0 @@
-4.12/rtems-arm
-4.12/rtems-bfin
-4.12/rtems-epiphany
-4.12/rtems-i386
-4.12/rtems-lm32
-4.12/rtems-m32c
-4.12/rtems-m68k
-4.12/rtems-microblaze
-4.12/rtems-mips
-4.12/rtems-moxie
-4.12/rtems-nios2
-4.12/rtems-or1k
-4.12/rtems-powerpc
-4.12/rtems-riscv32
-4.12/rtems-riscv64
-4.12/rtems-sh
-4.12/rtems-sparc
-4.12/rtems-sparc64
-4.12/rtems-v850
-4.12/rtems-x86_64
diff --git a/rtems/config/4.12/rtems-tier-3.bset b/rtems/config/4.12/rtems-tier-3.bset
index c15744f..0000000
--- a/rtems/config/4.12/rtems-tier-3.bset
+++ /dev/null
@@ -1,18 +0,0 @@
-# Tier 3 architectures. Must build.
-4.12/rtems-arm
-4.12/rtems-bfin
-4.12/rtems-i386
-4.12/rtems-lm32
-4.12/rtems-m32c
-4.12/rtems-m68k
-4.12/rtems-mips
-4.12/rtems-moxie
-4.12/rtems-nios2
-4.12/rtems-or1k
-4.12/rtems-powerpc
-4.12/rtems-sh
-4.12/rtems-sparc
-4.12/rtems-sparc64
-4.12/rtems-v850
diff --git a/rtems/config/4.12/rtems-aarch64.bset b/rtems/config/5/rtems-aarch64.bset
similarity index 66%
rename from rtems/config/4.12/rtems-aarch64.bset
rename to rtems/config/5/rtems-aarch64.bset
index 98fc6b4..f38aff3 100644
--- a/rtems/config/4.12/rtems-aarch64.bset
+++ b/rtems/config/5/rtems-aarch64.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch aarch64
%define with_libgomp
-%include 4.12/rtems-default.bset
+%include 5/rtems-default.bset
diff --git a/rtems/config/5/rtems-all.bset b/rtems/config/5/rtems-all.bset
new file mode 100644
index 0000000..19f1a03
--- /dev/null
+++ b/rtems/config/5/rtems-all.bset
@@ -0,0 +1,20 @@
+5/rtems-arm
+5/rtems-bfin
+5/rtems-epiphany
+5/rtems-i386
+5/rtems-lm32
+5/rtems-m32c
+5/rtems-m68k
+5/rtems-microblaze
+5/rtems-mips
+5/rtems-moxie
+5/rtems-nios2
+5/rtems-or1k
+5/rtems-powerpc
+5/rtems-riscv32
+5/rtems-riscv64
+5/rtems-sh
+5/rtems-sparc
+5/rtems-sparc64
+5/rtems-v850
+5/rtems-x86_64
diff --git a/rtems/config/4.12/rtems-arm.bset b/rtems/config/5/rtems-arm.bset
similarity index 65%
rename from rtems/config/4.12/rtems-arm.bset
rename to rtems/config/5/rtems-arm.bset
index ead6dda..896c534 100644
--- a/rtems/config/4.12/rtems-arm.bset
+++ b/rtems/config/5/rtems-arm.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch arm
diff --git a/rtems/config/4.12/rtems-autotools-base.bset b/rtems/config/5/rtems-autotools-base.bset
similarity index 84%
rename from rtems/config/4.12/rtems-autotools-base.bset
rename to rtems/config/5/rtems-autotools-base.bset
index e208a10..12ebffa 100644
--- a/rtems/config/4.12/rtems-autotools-base.bset
+++ b/rtems/config/5/rtems-autotools-base.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS 4.12 Internal Autotools Stable
+# Tools Set for RTEMS 5 Internal Autotools Stable
%define release 1
diff --git a/rtems/config/4.12/rtems-autotools-internal.bset b/rtems/config/5/rtems-autotools-internal.bset
similarity index 68%
rename from rtems/config/4.12/rtems-autotools-internal.bset
rename to rtems/config/5/rtems-autotools-internal.bset
index 772c032..67dae0d 100644
--- a/rtems/config/4.12/rtems-autotools-internal.bset
+++ b/rtems/config/5/rtems-autotools-internal.bset
@@ -1,5 +1,5 @@
# Do not use via the command line.
@@ -10,4 +10,4 @@
%define _disable_reporting yes
%define _disable_installing yes
-%include 4.12/rtems-autotools-base.bset
+%include 5/rtems-autotools-base.bset
diff --git a/rtems/config/4.12/rtems-autotools.bset b/rtems/config/5/rtems-autotools.bset
similarity index 87%
rename from rtems/config/4.12/rtems-autotools.bset
rename to rtems/config/5/rtems-autotools.bset
index 340328d..c50f988 100644
--- a/rtems/config/4.12/rtems-autotools.bset
+++ b/rtems/config/5/rtems-autotools.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS 4.12 Autotools Stable
+# Tools Set for RTEMS 5 Autotools Stable
# Autoconf and automake are not relocatable and cannot be cross-compiled.
# RTEMS uses autoconf and automake and building RTEMS in the RSB requires
@@ -23,5 +23,5 @@
%define mail_disable
-4.12/rtems-autotools-internal
-4.12/rtems-autotools-base
+5/rtems-autotools-internal
+5/rtems-autotools-base
diff --git a/rtems/config/4.12/rtems-bfin.bset b/rtems/config/5/rtems-bfin.bset
similarity index 56%
rename from rtems/config/4.12/rtems-bfin.bset
rename to rtems/config/5/rtems-bfin.bset
index bf4c9c5..ae30324 100644
--- a/rtems/config/4.12/rtems-bfin.bset
+++ b/rtems/config/5/rtems-bfin.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch bfin
diff --git a/rtems/config/4.12/rtems-default.bset b/rtems/config/5/rtems-default.bset
similarity index 75%
rename from rtems/config/4.12/rtems-default.bset
rename to rtems/config/5/rtems-default.bset
index f16d465..6f70b7c 100644
--- a/rtems/config/4.12/rtems-default.bset
+++ b/rtems/config/5/rtems-default.bset
@@ -7,11 +7,11 @@
%include rtems-base.bset
+5/rtems-autotools
devel/expat-2.1.0-1
tools/rtems-binutils-2.29-1
tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1
tools/rtems-gdb-8.0.1-1
-tools/rtems-tools-4.12-1
-tools/rtems-kernel-4.12
+tools/rtems-tools-5-1
+tools/rtems-kernel-5
diff --git a/rtems/config/4.12/rtems-epiphany.bset b/rtems/config/5/rtems-epiphany.bset
similarity index 94%
rename from rtems/config/4.12/rtems-epiphany.bset
rename to rtems/config/5/rtems-epiphany.bset
index 20f7243..181c158 100644
--- a/rtems/config/4.12/rtems-epiphany.bset
+++ b/rtems/config/5/rtems-epiphany.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS Epiphany 4.12 Stable
+# Tools Set for RTEMS Epiphany 5 Stable
%define release 1
@@ -38,9 +38,9 @@
# Tools configuration.
+5/rtems-autotools
devel/expat-2.1.0-1
tools/rtems-binutils-2.23.1-1
tools/rtems-gcc-4.9.2-newlib-2.5.0.20170922-1.cfg
tools/rtems-gdb-7.8.1-1
diff --git a/rtems/config/4.12/rtems-i386.bset b/rtems/config/5/rtems-i386.bset
rename from rtems/config/4.12/rtems-i386.bset
rename to rtems/config/5/rtems-i386.bset
index c765249..7fd0313 100644
--- a/rtems/config/4.12/rtems-i386.bset
+++ b/rtems/config/5/rtems-i386.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch i386
diff --git a/rtems/config/4.12/rtems-lm32.bset b/rtems/config/5/rtems-lm32.bset
similarity index 89%
rename from rtems/config/4.12/rtems-lm32.bset
rename to rtems/config/5/rtems-lm32.bset
index 3508d79..e54ad34 100644
--- a/rtems/config/4.12/rtems-lm32.bset
+++ b/rtems/config/5/rtems-lm32.bset
@@ -7,4 +7,4 @@
%patch add gdb https://devel.rtems.org/raw-attachment/ticket/3030/gdb-7.9-lm32uart-2.diff
%hash sha256 gdb-7.9-lm32uart-2.diff 7a266c1800829dcb5e493073ef98ad7d7f38a69715b93154dfaaffd34073dff3
diff --git a/rtems/config/4.12/rtems-m32c.bset b/rtems/config/5/rtems-m32c.bset
rename from rtems/config/4.12/rtems-m32c.bset
rename to rtems/config/5/rtems-m32c.bset
index 9113805..a1166fd 100644
--- a/rtems/config/4.12/rtems-m32c.bset
+++ b/rtems/config/5/rtems-m32c.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS M32C 4.12 Stable
+# Tools Set for RTEMS M32C 5 Stable
%define release 1
@@ -38,9 +38,9 @@
+5/rtems-autotools
devel/expat-2.1.0-1
tools/rtems-binutils-2.24-1
tools/rtems-gcc-4.8.3-newlib-2.5.0.20170922-1
tools/rtems-gdb-7.9-1
diff --git a/rtems/config/4.12/rtems-m68k.bset b/rtems/config/5/rtems-m68k.bset
rename from rtems/config/4.12/rtems-m68k.bset
rename to rtems/config/5/rtems-m68k.bset
index c82a0ea..6ed64eb 100644
--- a/rtems/config/4.12/rtems-m68k.bset
+++ b/rtems/config/5/rtems-m68k.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch m68k
diff --git a/rtems/config/4.12/rtems-microblaze.bset b/rtems/config/5/rtems-microblaze.bset
similarity index 59%
rename from rtems/config/4.12/rtems-microblaze.bset
rename to rtems/config/5/rtems-microblaze.bset
index a030a83..e5c23af 100644
--- a/rtems/config/4.12/rtems-microblaze.bset
+++ b/rtems/config/5/rtems-microblaze.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch microblaze
diff --git a/rtems/config/4.12/rtems-mips.bset b/rtems/config/5/rtems-mips.bset
similarity index 81%
rename from rtems/config/4.12/rtems-mips.bset
rename to rtems/config/5/rtems-mips.bset
index 414ec16..de77469 100644
--- a/rtems/config/4.12/rtems-mips.bset
+++ b/rtems/config/5/rtems-mips.bset
@@ -2,5 +2,5 @@
%define rtems_arch mips
%define gdb-sim-options --enable-sim-hardware
%define win32-gdb-disable-sim
tools/rtems-mipstx39-gdb-7.9-1
diff --git a/rtems/config/4.12/rtems-moxie.bset b/rtems/config/5/rtems-moxie.bset
similarity index 71%
rename from rtems/config/4.12/rtems-moxie.bset
rename to rtems/config/5/rtems-moxie.bset
index e5bebaa..5051b85 100644
--- a/rtems/config/4.12/rtems-moxie.bset
+++ b/rtems/config/5/rtems-moxie.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS Moxie 4.12 Stable
+# Tools Set for RTEMS Moxie 5 Stable
%define release 1
@@ -9,4 +9,4 @@
# Moxie needs dtc to build gdb, then pick up the rest of the set
devel/dtc-1.4.1-1
diff --git a/rtems/config/4.12/rtems-nios2.bset b/rtems/config/5/rtems-nios2.bset
rename from rtems/config/4.12/rtems-nios2.bset
rename to rtems/config/5/rtems-nios2.bset
index 218d42f..4a20854 100644
--- a/rtems/config/4.12/rtems-nios2.bset
+++ b/rtems/config/5/rtems-nios2.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch nios2
diff --git a/rtems/config/4.12/rtems-or1k.bset b/rtems/config/5/rtems-or1k.bset
similarity index 88%
rename from rtems/config/4.12/rtems-or1k.bset
rename to rtems/config/5/rtems-or1k.bset
index 9ee866f..a91fe45 100644
--- a/rtems/config/4.12/rtems-or1k.bset
+++ b/rtems/config/5/rtems-or1k.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS or1k 4.12 Stable
+# Tools Set for RTEMS or1k 5 Stable
%define release 1
@@ -30,9 +30,9 @@
+5/rtems-autotools
devel/expat-2.1.0-1
tools/rtems-binutils-2.26-1
tools/rtems-gcc-4.9.3-newlib-2.5.0.20170922-1
tools/rtems-gdb-7.11-1
diff --git a/rtems/config/4.12/rtems-powerpc.bset b/rtems/config/5/rtems-powerpc.bset
similarity index 74%
rename from rtems/config/4.12/rtems-powerpc.bset
rename to rtems/config/5/rtems-powerpc.bset
index ae6fcf2..25e0ae2 100644
--- a/rtems/config/4.12/rtems-powerpc.bset
+++ b/rtems/config/5/rtems-powerpc.bset
@@ -5,4 +5,4 @@
%define rtems_arch powerpc
diff --git a/rtems/config/4.12/rtems-riscv32.bset b/rtems/config/5/rtems-riscv32.bset
rename from rtems/config/4.12/rtems-riscv32.bset
rename to rtems/config/5/rtems-riscv32.bset
index c13ba4c..3c11da1 100644
--- a/rtems/config/4.12/rtems-riscv32.bset
+++ b/rtems/config/5/rtems-riscv32.bset
@@ -7,10 +7,10 @@
+5/rtems-autotools
devel/expat-2.1.0-1
diff --git a/rtems/config/4.12/rtems-riscv64.bset b/rtems/config/5/rtems-riscv64.bset
rename from rtems/config/4.12/rtems-riscv64.bset
rename to rtems/config/5/rtems-riscv64.bset
index 406c0c9..c599481 100644
--- a/rtems/config/4.12/rtems-riscv64.bset
+++ b/rtems/config/5/rtems-riscv64.bset
@@ -7,10 +7,10 @@
+5/rtems-autotools
devel/expat-2.1.0-1
diff --git a/rtems/config/4.12/rtems-sh.bset b/rtems/config/5/rtems-sh.bset
rename from rtems/config/4.12/rtems-sh.bset
rename to rtems/config/5/rtems-sh.bset
index e9deacf..5a14c87 100644
--- a/rtems/config/4.12/rtems-sh.bset
+++ b/rtems/config/5/rtems-sh.bset
@@ -3,4 +3,4 @@
%define release 1
%define rtems_arch sh
diff --git a/rtems/config/4.12/rtems-sparc.bset b/rtems/config/5/rtems-sparc.bset
rename from rtems/config/4.12/rtems-sparc.bset
rename to rtems/config/5/rtems-sparc.bset
index 4eaeee7..187d337 100644
--- a/rtems/config/4.12/rtems-sparc.bset
+++ b/rtems/config/5/rtems-sparc.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch sparc
diff --git a/rtems/config/4.12/rtems-sparc64.bset b/rtems/config/5/rtems-sparc64.bset
similarity index 57%
rename from rtems/config/4.12/rtems-sparc64.bset
rename to rtems/config/5/rtems-sparc64.bset
index a6ad478..a56ad71 100644
--- a/rtems/config/4.12/rtems-sparc64.bset
+++ b/rtems/config/5/rtems-sparc64.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch sparc64
diff --git a/rtems/config/4.12/rtems-tier-1.bset b/rtems/config/5/rtems-tier-1.bset
rename from rtems/config/4.12/rtems-tier-1.bset
rename to rtems/config/5/rtems-tier-1.bset
index db84f70..3e2dbe6 100644
--- a/rtems/config/4.12/rtems-tier-1.bset
+++ b/rtems/config/5/rtems-tier-1.bset
@@ -1,5 +1,5 @@
# Tier 1 architectures. Must build.
-4.12/rtems-arm
-4.12/rtems-i386
+5/rtems-arm
+5/rtems-i386
diff --git a/rtems/config/4.12/rtems-tier-2.bset b/rtems/config/5/rtems-tier-2.bset
similarity index 100%
rename from rtems/config/4.12/rtems-tier-2.bset
rename to rtems/config/5/rtems-tier-2.bset
diff --git a/rtems/config/5/rtems-tier-3.bset b/rtems/config/5/rtems-tier-3.bset
index 0000000..0a66121
--- /dev/null
+++ b/rtems/config/5/rtems-tier-3.bset
@@ -0,0 +1,18 @@
+# Tier 3 architectures. Must build.
+5/rtems-arm
+5/rtems-bfin
+5/rtems-i386
+5/rtems-lm32
+5/rtems-m32c
+5/rtems-m68k
+5/rtems-mips
+5/rtems-moxie
+5/rtems-nios2
+5/rtems-or1k
+5/rtems-powerpc
+5/rtems-sh
+5/rtems-sparc
+5/rtems-sparc64
+5/rtems-v850
diff --git a/rtems/config/4.12/rtems-tier-4.bset b/rtems/config/5/rtems-tier-4.bset
similarity index 67%
rename from rtems/config/4.12/rtems-tier-4.bset
rename to rtems/config/5/rtems-tier-4.bset
index 3839468..2820fda 100644
--- a/rtems/config/4.12/rtems-tier-4.bset
+++ b/rtems/config/5/rtems-tier-4.bset
@@ -4,7 +4,7 @@
# Tools listed here may not have a BSP in the kernel and are here to support
# anyone working on adding a BSP.
-4.12/rtems-riscv32
-4.12/rtems-x86_64
+5/rtems-epiphany
+5/rtems-microblaze
+5/rtems-riscv32
+5/rtems-x86_64
diff --git a/rtems/config/4.12/rtems-tools.bset b/rtems/config/5/rtems-tools.bset
similarity index 72%
rename from rtems/config/4.12/rtems-tools.bset
rename to rtems/config/5/rtems-tools.bset
index 6332b5c..12a3302 100644
--- a/rtems/config/4.12/rtems-tools.bset
+++ b/rtems/config/5/rtems-tools.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS 4.12 Tools Stable
+# Tools Set for RTEMS 5 Tools Stable
%define release 1
@@ -14,4 +14,4 @@
diff --git a/rtems/config/4.12/rtems-v850.bset b/rtems/config/5/rtems-v850.bset
rename from rtems/config/4.12/rtems-v850.bset
rename to rtems/config/5/rtems-v850.bset
index 1f2a08e..e09bc4f 100644
--- a/rtems/config/4.12/rtems-v850.bset
+++ b/rtems/config/5/rtems-v850.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch v850
diff --git a/rtems/config/4.12/rtems-x86_64.bset b/rtems/config/5/rtems-x86_64.bset
rename from rtems/config/4.12/rtems-x86_64.bset
rename to rtems/config/5/rtems-x86_64.bset
index d91748d..452f9a8 100644
--- a/rtems/config/4.12/rtems-x86_64.bset
+++ b/rtems/config/5/rtems-x86_64.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch x86_64
diff --git a/rtems/config/rtems-version.bset b/rtems/config/rtems-version.bset
index e77f38b..b2db1ba 100644
--- a/rtems/config/rtems-version.bset
+++ b/rtems/config/rtems-version.bset
@@ -1,5 +1,5 @@
-# Current version is RTEMS 4.12
+# Current version is RTEMS 5
-%define rtems_version 4.12
+%define rtems_version 5
diff --git a/rtems/config/tools/rtems-kernel-4.12.cfg b/rtems/config/tools/rtems-kernel-5.cfg
rename from rtems/config/tools/rtems-kernel-4.12.cfg
rename to rtems/config/tools/rtems-kernel-5.cfg
index 8ed8392..5d5d654 100644
--- a/rtems/config/tools/rtems-kernel-4.12.cfg
+++ b/rtems/config/tools/rtems-kernel-5.cfg
@@ -1,5 +1,5 @@
-# RTEMS 4.12
+# RTEMS 5
diff --git a/rtems/config/tools/rtems-tools-4.12-1.cfg b/rtems/config/tools/rtems-tools-5-1.cfg
similarity index 91%
rename from rtems/config/tools/rtems-tools-4.12-1.cfg
rename to rtems/config/tools/rtems-tools-5-1.cfg
index 0a7a7e2..6efc4e3 100644
--- a/rtems/config/tools/rtems-tools-4.12-1.cfg
+++ b/rtems/config/tools/rtems-tools-5-1.cfg
@@ -1,5 +1,5 @@
-# RTEMS Tools for 4.12.
+# RTEMS Tools for 5.
2.12.3
