[PATCH 06/10] wpa_supplicant: Add lock.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Nov 8 12:33:05 UTC 2017
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 freebsd/contrib/wpa/wpa_supplicant/main.c          |  6 +-
 libbsd.py                                          |  1 +
 libbsd_waf.py                                      |  1 +
 .../include/machine/rtems-bsd-wpa-supplicant.h     | 55 +++++++++++++++++
 rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c       | 68 ++++++++++++++++++++++
 5 files changed, 130 insertions(+), 1 deletion(-)
 create mode 100644 rtemsbsd/include/machine/rtems-bsd-wpa-supplicant.h
 create mode 100644 rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c
diff --git a/freebsd/contrib/wpa/wpa_supplicant/main.c b/freebsd/contrib/wpa/wpa_supplicant/main.c
index 40950d2c769..77d6a5bb535 100644
--- a/freebsd/contrib/wpa/wpa_supplicant/main.c
+++ b/freebsd/contrib/wpa/wpa_supplicant/main.c
@@ -23,6 +23,7 @@
 #include <assert.h>
 #include <sys/mutex.h>
 #include <machine/rtems-bsd-program.h>
+#include <machine/rtems-bsd-wpa-supplicant.h>
 #endif /* __rtems__ */
 static void usage(void)
@@ -170,7 +171,10 @@ int rtems_bsd_command_wpa_supplicant(int argc, char **argv)
 	int exit_code;
 	rtems_status_code sc;
-	exit_code = rtems_bsd_program_call_main("wpa_supplicant", main, argc, argv);
+	rtems_bsd_wpa_supplicant_lock();
+	exit_code = rtems_bsd_program_call_main("wpa_supplicant", main,
+	    argc, argv);
+	rtems_bsd_wpa_supplicant_unlock();
 	return exit_code;
diff --git a/libbsd.py b/libbsd.py
index c36d8925108..9963f2b28c6 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -118,6 +118,7 @@ def rtems(mm):
             'rtems/rtems-kernel-termioskqueuepoll.c',
             'rtems/rtems-kernel-thread.c',
             'rtems/rtems-kernel-vprintf.c',
+            'rtems/rtems-kernel-wpa-supplicant.c',
             'rtems/rtems-legacy-rtrequest.c',
             'rtems/rtems-legacy-newproc.c',
             'rtems/rtems-legacy-mii.c',
diff --git a/libbsd_waf.py b/libbsd_waf.py
index afafbe718b6..52608a37094 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -2351,6 +2351,7 @@ def build(bld):
               'rtemsbsd/rtems/rtems-kernel-thread.c',
               'rtemsbsd/rtems/rtems-kernel-timesupport.c',
               'rtemsbsd/rtems/rtems-kernel-vprintf.c',
+              'rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c',
               'rtemsbsd/rtems/rtems-kvm.c',
               'rtemsbsd/rtems/rtems-legacy-mii.c',
               'rtemsbsd/rtems/rtems-legacy-newproc.c',
diff --git a/rtemsbsd/include/machine/rtems-bsd-wpa-supplicant.h b/rtemsbsd/include/machine/rtems-bsd-wpa-supplicant.h
new file mode 100644
index 00000000000..d6f6d77ef1d
--- /dev/null
+++ b/rtemsbsd/include/machine/rtems-bsd-wpa-supplicant.h
@@ -0,0 +1,55 @@
+ * @file
+ * @ingroup rtems_bsd_machine
+ * @brief TODO.
+ * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_WPA_SUPPLICANT_H_
+#define _RTEMS_BSD_MACHINE_RTEMS_BSD_WPA_SUPPLICANT_H_
+#include <sys/cdefs.h>
+__BEGIN_DECLS
+void
+rtems_bsd_wpa_supplicant_lock(void);
+void
+rtems_bsd_wpa_supplicant_unlock(void);
+__END_DECLS
+#endif /* _RTEMS_BSD_MACHINE_RTEMS_BSD_WPA_SUPPLICANT_H_ */
diff --git a/rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c b/rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c
index 00000000000..0403f443f51
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c
@@ -0,0 +1,68 @@
+ * @file
+ * @ingroup rtems_bsd_rtems
+ * @brief Mutex for protecting wpa_supplicant.
+ * The wpa_supplicant needs it's own mutex so it can be used in background.
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ * are met:
+ * SUCH DAMAGE.
+#include <machine/rtems-bsd-kernel-space.h>
+#include <machine/rtems-bsd-thread.h>
+#include <sys/types.h>
+#include <sys/kernel.h>
+#include <sys/lock.h>
+#include <sys/mutex.h>
+static struct mtx wpa_supplicant_mtx;
+MTX_SYSINIT(rtems_bsd_wpa_supplicant, &wpa_supplicant_mtx, "BSD WPA Supplicant",
+    MTX_DEF);
+void
+	mtx_lock(&wpa_supplicant_mtx);
+void
+	mtx_unlock(&wpa_supplicant_mtx);
2.12.3
