[PATCH 09/10] libbsd.txt: Describe current state of WLAN.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Nov 8 12:33:08 UTC 2017
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 libbsd.txt | 52 ++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 52 insertions(+)
diff --git a/libbsd.txt b/libbsd.txt
index f57faba37da..71d5cc8d214 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -1154,6 +1154,58 @@ The following is necessary to use PF on RTEMS:
   systems (on FreeBSD that means systems with less than 100 MB RAM). This is
   fixed in +pfctl_init_options()+.
+== Wireless Network (WLAN) ==
+The libbsd provides a basic support for WLAN. Note that currently this support
+is still in an early state. The following gives a rough overview over the
+necessary steps to connect to an encrypted network with an RTL8188EU based WiFi
+dongle:
+- Reference all necessary module for your BSP. For some BSPs this is already
+  done in the nexus-devices.h:
+	SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
+	SYSINIT_MODULE_REFERENCE(wlan_sta);
+	SYSINIT_MODULE_REFERENCE(wlan_amrr);
+	SYSINIT_MODULE_REFERENCE(wlan_wep);
+	SYSINIT_MODULE_REFERENCE(wlan_tkip);
+	SYSINIT_MODULE_REFERENCE(wlan_ccmp);
+	SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
+	SYSINIT_REFERENCE(rtwn_rtl8188eufw);
+- Create your wlan device using ifconfig:
+  +ifconfig wlan0 create wlandev rtwn0 up+
+- Start a wpa_supplicant instance for that device:
+  + wpa_supplicant_fork -Dbsd -iwlan0 -c/media/mmcsd-0-0/wpa_supplicant.conf+
+Note that the wpa_supplicant will only be active till the device goes down. A
+workaround is to just restart it every time it exits.
+=== Known restrictions ===
+- The network interface (e.g. wlan0) is currently not automatically created. It
+  would be nice, if some service would create it as soon as for example a USB
+  device is connected. In FreeBSD the names are assigned via rc.conf with lines
+  like +wlans_rtwn0="wlan0"+.
+- wpa_supplicant hast to be started after the device is created. It has to be
+  restarted every time the connection goes down. Instead of this behaviour,
+  there should be some service that starts and restarts wpa_supplicant
+  automatically if a interface is ready. Probably the dhcpcd hooks could be used
+  for that.
+- The current wpa_supplicant implementation is protected with a lock so it can't
+  be started more than one time. If multiple interface should be used, all have
+  to be handled by that single instance. That makes it hard to add interfaces
+  dynamically. wpa_supplicant should be reviewed thoroughly whether multiple
+  instances could be started in parallel.
+- The control interface of wpa_supplicant most likely doesn't work. The wpa_cli
+  application is not ported.
 == Problems to report to FreeBSD ==
 The MMAP_NOT_AVAILABLE define is inverted on its usage.  When it is
2.12.3
