[PATCH 2/2] Port BBB sd driver files to RTEMS.
Sichen Zhao 1473996754 at qq.com
Wed Nov 8 13:43:32 UTC 2017
So BBB can mount and read eMMC and SD card.
 Makefile.todo                                 |  26 ++++
 libbsd.py                                     |  36 +++++
 libbsd_waf.py                                 |   8 +
 rtemsbsd/include/bsp/nexus-devices.h          |   2 +
 rtemsbsd/include/machine/fdt.h                |   0
 rtemsbsd/include/rtems/bsd/local/gpiobus_if.h | 152 ++++++++++++++++++
 rtemsbsd/include/rtems/bsd/local/sdhci_if.h   | 216 ++++++++++++++++++++++++++
 rtemsbsd/local/gpiobus_if.c                   |  62 ++++++++
 rtemsbsd/local/sdhci_if.c                     |  90 +++++++++++
 9 files changed, 592 insertions(+)
 create mode 100644 rtemsbsd/include/machine/fdt.h
 create mode 100644 rtemsbsd/include/rtems/bsd/local/gpiobus_if.h
 create mode 100644 rtemsbsd/include/rtems/bsd/local/sdhci_if.h
 create mode 100644 rtemsbsd/local/gpiobus_if.c
 create mode 100644 rtemsbsd/local/sdhci_if.c
diff --git a/Makefile.todo b/Makefile.todo
index c69908b..8890fd2 100644
--- a/Makefile.todo
+++ b/Makefile.todo
@@ -35,6 +35,10 @@ GENERATED += $(LOCAL_SRC)/mmcbus_if.c
 GENERATED += $(LOCAL_SRC)/rtwn-rtl8192cfwT.c
 GENERATED += $(LOCAL_SRC)/rtwn-rtl8188eufw.c
 GENERATED += $(LOCAL_SRC)/runfw.c
+GENERATED += $(LOCAL_INC)/sdhci_if.h
+GENERATED += $(LOCAL_SRC)/sdhci_if.c
+GENERATED += $(LOCAL_INC)/gpiobus_if.h
+GENERATED += $(LOCAL_SRC)/gpiobus_if.c
 GENERATED += rtemsbsd/include/machine/rtems-bsd-regdomain.h
 GENERATED += rtemsbsd/rtems/rtems-bsd-regdomain.c
 GENERATED += freebsd/contrib/libpcap/grammar.h
@@ -157,6 +161,28 @@ $(LOCAL_INC)/gpio_if.h: $(FREEBSD_SRC)/sys/dev/gpio/gpio_if.m
 	awk -f $(TOOLS)/makeobjops.awk $< -h
 	mv gpio_if.h $@
+$(LOCAL_INC)/gpiobus_if.h: $(FREEBSD_SRC)/sys/dev/gpio/gpiobus_if.m
+	awk -f $(TOOLS)/makeobjops.awk $< -h
+	mv gpiobus_if.h $@
+$(LOCAL_SRC)/gpiobus_if.c: $(FREEBSD_SRC)/sys/dev/gpio/gpiobus_if.m
+	awk -f $(TOOLS)/makeobjops.awk $< -c
+	sed -i gpiobus_if.c \
+	    -e '1 i\#include <machine/rtems-bsd-kernel-space.h>\n' \
+	    -e 's|#include "gpiobus_if.h"|#include <rtems/bsd/local/gpiobus_if.h>|'
+	mv gpiobus_if.c $@
+$(LOCAL_INC)/sdhci_if.h: $(FREEBSD_SRC)/sys/dev/sdhci/sdhci_if.m
+	mv sdhci_if.h $@
+$(LOCAL_SRC)/sdhci_if.c: $(FREEBSD_SRC)/sys/dev/sdhci/sdhci_if.m
+	sed -i sdhci_if.c \
+	    -e 's|#include "sdhci_if.h"|#include <rtems/bsd/local/sdhci_if.h>|'
+	mv sdhci_if.c $@
 $(LOCAL_SRC)/gpio_if.c: $(FREEBSD_SRC)/sys/dev/gpio/gpio_if.m
 	mv gpio_if.c $@
diff --git a/libbsd.py b/libbsd.py
index 5ec2f91..5553168 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -497,6 +497,41 @@ def mmc(mm):
     return mod
+# MMC
+def mmc_ti(mm):
+    mod = builder.Module('mmc_ti')
+    mod.addKernelSpaceHeaderFiles(
+            'sys/arm/ti/ti_cpuid.h',
+            'sys/arm/ti/ti_prcm.h',
+            'sys/arm/ti/ti_hwmods.h',
+            'sys/dev/sdhci/sdhci.h',
+            'sys/dev/sdhci/sdhci_fdt_gpio.h',
+            'sys/dev/gpio/gpiobusvar.h',
+    mod.addKernelSpaceSourceFiles(
+            'sys/dev/sdhci/sdhci.c',
+            'sys/arm/ti/ti_sdhci.c',
+            'sys/arm/ti/ti_hwmods.c',
+            'sys/dev/sdhci/sdhci_fdt_gpio.c',
+            'sys/dev/gpio/ofw_gpiobus.c',
+            'sys/dev/gpio/gpiobus.c',
+        mm.generator['source']()
+    mod.addRTEMSSourceFiles(
+            'local/sdhci_if.c',
+            'local/gpiobus_if.c',
+    return mod
 # Input
 def dev_input(mm):
@@ -4465,6 +4500,7 @@ def sources(mm):
     mm.addModule(fdt(mm))
     mm.addModule(tty(mm))
     mm.addModule(mmc(mm))
+    mm.addModule(mmc_ti(mm))
     mm.addModule(dev_input(mm))
     mm.addModule(evdev(mm))
diff --git a/libbsd_waf.py b/libbsd_waf.py
index 29405d3..07cef63 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -1688,8 +1688,10 @@ def build(bld):
               'freebsd/sys/arm/ti/am335x/am335x_musb.c',
               'freebsd/sys/arm/ti/am335x/am335x_prcm.c',
               'freebsd/sys/arm/ti/am335x/am335x_usbss.c',
+              'freebsd/sys/arm/ti/ti_hwmods.c',
               'freebsd/sys/arm/ti/ti_prcm.c',
               'freebsd/sys/arm/ti/ti_scm.c',
+              'freebsd/sys/arm/ti/ti_sdhci.c',
               'freebsd/sys/arm/xilinx/zy7_slcr.c',
               'freebsd/sys/cam/cam.c',
               'freebsd/sys/cam/scsi/scsi_all.c',
@@ -1748,6 +1750,8 @@ def build(bld):
               'freebsd/sys/dev/fdt/simplebus.c',
               'freebsd/sys/dev/ffec/if_ffec.c',
               'freebsd/sys/dev/fxp/if_fxp.c',
+              'freebsd/sys/dev/gpio/gpiobus.c',
+              'freebsd/sys/dev/gpio/ofw_gpiobus.c',
               'freebsd/sys/dev/kbd/kbd.c',
               'freebsd/sys/dev/led/led.c',
               'freebsd/sys/dev/mii/brgphy.c',
@@ -1861,6 +1865,8 @@ def build(bld):
               'freebsd/sys/dev/rtwn/usb/rtwn_usb_reg.c',
               'freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c',
               'freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c',
+              'freebsd/sys/dev/sdhci/sdhci.c',
+              'freebsd/sys/dev/sdhci/sdhci_fdt_gpio.c',
               'freebsd/sys/dev/smc/if_smc.c',
               'freebsd/sys/dev/tsec/if_tsec.c',
               'freebsd/sys/dev/tsec/if_tsec_fdt.c',
@@ -2250,6 +2256,7 @@ def build(bld):
               'rtemsbsd/local/cryptodev_if.c',
               'rtemsbsd/local/device_if.c',
               'rtemsbsd/local/gpio_if.c',
+              'rtemsbsd/local/gpiobus_if.c',
               'rtemsbsd/local/if_dwc_if.c',
               'rtemsbsd/local/ifdi_if.c',
               'rtemsbsd/local/miibus_if.c',
@@ -2262,6 +2269,7 @@ def build(bld):
               'rtemsbsd/local/rtwn-rtl8188eufw.c',
               'rtemsbsd/local/rtwn-rtl8192cfwT.c',
               'rtemsbsd/local/runfw.c',
+              'rtemsbsd/local/sdhci_if.c',
               'rtemsbsd/local/usb_if.c',
               'rtemsbsd/mdns/mdns-hostname-default.c',
               'rtemsbsd/mdns/mdns.c',
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index f0ce1bd..b91601c 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -56,6 +56,8 @@ SYSINIT_DRIVER_REFERENCE(ti_scm, simplebus);
 SYSINIT_DRIVER_REFERENCE(am335x_prcm, simplebus);
 SYSINIT_DRIVER_REFERENCE(usbss, simplebus);
 SYSINIT_DRIVER_REFERENCE(musbotg, usbss);
+SYSINIT_DRIVER_REFERENCE(sdhci_ti, simplebus);
+SYSINIT_DRIVER_REFERENCE(mmcsd, mmc);
 SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
 SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
 SYSINIT_MODULE_REFERENCE(wlan_sta);
diff --git a/rtemsbsd/include/machine/fdt.h b/rtemsbsd/include/machine/fdt.h
new file mode 100644
index 0000000..e69de29
diff --git a/rtemsbsd/include/rtems/bsd/local/gpiobus_if.h b/rtemsbsd/include/rtems/bsd/local/gpiobus_if.h
index 0000000..fb270f2
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/local/gpiobus_if.h
@@ -0,0 +1,152 @@
+ * This file is produced automatically.
+ * Do not modify anything in here by hand.
+ * Created from source file
+ *   freebsd-org/sys/dev/gpio/gpiobus_if.m
+ * with
+ *   makeobjops.awk
+ * See the source file for legal information
+#ifndef _gpiobus_if_h_
+#define _gpiobus_if_h_
+/** @brief Unique descriptor for the GPIOBUS_ACQUIRE_BUS() method */
+extern struct kobjop_desc gpiobus_acquire_bus_desc;
+/** @brief A function implementing the GPIOBUS_ACQUIRE_BUS() method */
+typedef int gpiobus_acquire_bus_t(device_t busdev, device_t dev, int how);
+static __inline int GPIOBUS_ACQUIRE_BUS(device_t busdev, device_t dev, int how)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)busdev)->ops,gpiobus_acquire_bus);
+	return ((gpiobus_acquire_bus_t *) _m)(busdev, dev, how);
+/** @brief Unique descriptor for the GPIOBUS_RELEASE_BUS() method */
+extern struct kobjop_desc gpiobus_release_bus_desc;
+/** @brief A function implementing the GPIOBUS_RELEASE_BUS() method */
+typedef void gpiobus_release_bus_t(device_t busdev, device_t dev);
+static __inline void GPIOBUS_RELEASE_BUS(device_t busdev, device_t dev)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)busdev)->ops,gpiobus_release_bus);
+	((gpiobus_release_bus_t *) _m)(busdev, dev);
+/** @brief Unique descriptor for the GPIOBUS_PIN_SET() method */
+extern struct kobjop_desc gpiobus_pin_set_desc;
+/** @brief A function implementing the GPIOBUS_PIN_SET() method */
+typedef int gpiobus_pin_set_t(device_t dev, device_t child, uint32_t pin_num,
+                              uint32_t pin_value);
+static __inline int GPIOBUS_PIN_SET(device_t dev, device_t child,
+                                    uint32_t pin_num, uint32_t pin_value)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,gpiobus_pin_set);
+	return ((gpiobus_pin_set_t *) _m)(dev, child, pin_num, pin_value);
+/** @brief Unique descriptor for the GPIOBUS_PIN_GET() method */
+extern struct kobjop_desc gpiobus_pin_get_desc;
+/** @brief A function implementing the GPIOBUS_PIN_GET() method */
+typedef int gpiobus_pin_get_t(device_t dev, device_t child, uint32_t pin_num,
+                              uint32_t *pin_value);
+static __inline int GPIOBUS_PIN_GET(device_t dev, device_t child,
+                                    uint32_t pin_num, uint32_t *pin_value)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,gpiobus_pin_get);
+	return ((gpiobus_pin_get_t *) _m)(dev, child, pin_num, pin_value);
+/** @brief Unique descriptor for the GPIOBUS_PIN_TOGGLE() method */
+extern struct kobjop_desc gpiobus_pin_toggle_desc;
+/** @brief A function implementing the GPIOBUS_PIN_TOGGLE() method */
+typedef int gpiobus_pin_toggle_t(device_t dev, device_t child,
+                                 uint32_t pin_num);
+static __inline int GPIOBUS_PIN_TOGGLE(device_t dev, device_t child,
+                                       uint32_t pin_num)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,gpiobus_pin_toggle);
+	return ((gpiobus_pin_toggle_t *) _m)(dev, child, pin_num);
+/** @brief Unique descriptor for the GPIOBUS_PIN_GETCAPS() method */
+extern struct kobjop_desc gpiobus_pin_getcaps_desc;
+/** @brief A function implementing the GPIOBUS_PIN_GETCAPS() method */
+typedef int gpiobus_pin_getcaps_t(device_t dev, device_t child,
+                                  uint32_t pin_num, uint32_t *caps);
+static __inline int GPIOBUS_PIN_GETCAPS(device_t dev, device_t child,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,gpiobus_pin_getcaps);
+	return ((gpiobus_pin_getcaps_t *) _m)(dev, child, pin_num, caps);
+/** @brief Unique descriptor for the GPIOBUS_PIN_GETFLAGS() method */
+extern struct kobjop_desc gpiobus_pin_getflags_desc;
+/** @brief A function implementing the GPIOBUS_PIN_GETFLAGS() method */
+typedef int gpiobus_pin_getflags_t(device_t dev, device_t child,
+                                   uint32_t pin_num, uint32_t *flags);
+static __inline int GPIOBUS_PIN_GETFLAGS(device_t dev, device_t child,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,gpiobus_pin_getflags);
+	return ((gpiobus_pin_getflags_t *) _m)(dev, child, pin_num, flags);
+/** @brief Unique descriptor for the GPIOBUS_PIN_SETFLAGS() method */
+extern struct kobjop_desc gpiobus_pin_setflags_desc;
+/** @brief A function implementing the GPIOBUS_PIN_SETFLAGS() method */
+typedef int gpiobus_pin_setflags_t(device_t dev, device_t child,
+                                   uint32_t pin_num, uint32_t flags);
+static __inline int GPIOBUS_PIN_SETFLAGS(device_t dev, device_t child,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,gpiobus_pin_setflags);
+	return ((gpiobus_pin_setflags_t *) _m)(dev, child, pin_num, flags);
+/** @brief Unique descriptor for the GPIOBUS_PIN_GETNAME() method */
+extern struct kobjop_desc gpiobus_pin_getname_desc;
+/** @brief A function implementing the GPIOBUS_PIN_GETNAME() method */
+typedef int gpiobus_pin_getname_t(device_t dev, uint32_t pin_num, char *name);
+static __inline int GPIOBUS_PIN_GETNAME(device_t dev, uint32_t pin_num,
+                                        char *name)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,gpiobus_pin_getname);
+	return ((gpiobus_pin_getname_t *) _m)(dev, pin_num, name);
+/** @brief Unique descriptor for the GPIOBUS_PIN_SETNAME() method */
+extern struct kobjop_desc gpiobus_pin_setname_desc;
+/** @brief A function implementing the GPIOBUS_PIN_SETNAME() method */
+typedef int gpiobus_pin_setname_t(device_t dev, uint32_t pin_num,
+                                  const char *name);
+static __inline int GPIOBUS_PIN_SETNAME(device_t dev, uint32_t pin_num,
+                                        const char *name)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,gpiobus_pin_setname);
+	return ((gpiobus_pin_setname_t *) _m)(dev, pin_num, name);
+#endif /* _gpiobus_if_h_ */
diff --git a/rtemsbsd/include/rtems/bsd/local/sdhci_if.h b/rtemsbsd/include/rtems/bsd/local/sdhci_if.h
index 0000000..531090f
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/local/sdhci_if.h
@@ -0,0 +1,216 @@
+ *   freebsd-org/sys/dev/sdhci/sdhci_if.m
+ * with
+ *   makeobjops.awk
+#ifndef _sdhci_if_h_
+#define _sdhci_if_h_
+/** @brief Unique descriptor for the SDHCI_READ_1() method */
+extern struct kobjop_desc sdhci_read_1_desc;
+/** @brief A function implementing the SDHCI_READ_1() method */
+typedef uint8_t sdhci_read_1_t(device_t brdev, struct sdhci_slot *slot,
+                               bus_size_t off);
+static __inline uint8_t SDHCI_READ_1(device_t brdev, struct sdhci_slot *slot,
+                                     bus_size_t off)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_read_1);
+	return ((sdhci_read_1_t *) _m)(brdev, slot, off);
+/** @brief Unique descriptor for the SDHCI_READ_2() method */
+extern struct kobjop_desc sdhci_read_2_desc;
+/** @brief A function implementing the SDHCI_READ_2() method */
+typedef uint16_t sdhci_read_2_t(device_t brdev, struct sdhci_slot *slot,
+                                bus_size_t off);
+static __inline uint16_t SDHCI_READ_2(device_t brdev, struct sdhci_slot *slot,
+                                      bus_size_t off)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_read_2);
+	return ((sdhci_read_2_t *) _m)(brdev, slot, off);
+/** @brief Unique descriptor for the SDHCI_READ_4() method */
+extern struct kobjop_desc sdhci_read_4_desc;
+/** @brief A function implementing the SDHCI_READ_4() method */
+typedef uint32_t sdhci_read_4_t(device_t brdev, struct sdhci_slot *slot,
+                                bus_size_t off);
+static __inline uint32_t SDHCI_READ_4(device_t brdev, struct sdhci_slot *slot,
+                                      bus_size_t off)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_read_4);
+	return ((sdhci_read_4_t *) _m)(brdev, slot, off);
+/** @brief Unique descriptor for the SDHCI_READ_MULTI_4() method */
+extern struct kobjop_desc sdhci_read_multi_4_desc;
+/** @brief A function implementing the SDHCI_READ_MULTI_4() method */
+typedef void sdhci_read_multi_4_t(device_t brdev, struct sdhci_slot *slot,
+                                  bus_size_t off, uint32_t *data,
+                                  bus_size_t count);
+static __inline void SDHCI_READ_MULTI_4(device_t brdev, struct sdhci_slot *slot,
+                                        bus_size_t count)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_read_multi_4);
+	((sdhci_read_multi_4_t *) _m)(brdev, slot, off, data, count);
+/** @brief Unique descriptor for the SDHCI_WRITE_1() method */
+extern struct kobjop_desc sdhci_write_1_desc;
+/** @brief A function implementing the SDHCI_WRITE_1() method */
+typedef void sdhci_write_1_t(device_t brdev, struct sdhci_slot *slot,
+                             bus_size_t off, uint8_t val);
+static __inline void SDHCI_WRITE_1(device_t brdev, struct sdhci_slot *slot,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_write_1);
+	((sdhci_write_1_t *) _m)(brdev, slot, off, val);
+/** @brief Unique descriptor for the SDHCI_WRITE_2() method */
+extern struct kobjop_desc sdhci_write_2_desc;
+/** @brief A function implementing the SDHCI_WRITE_2() method */
+typedef void sdhci_write_2_t(device_t brdev, struct sdhci_slot *slot,
+                             bus_size_t off, uint16_t val);
+static __inline void SDHCI_WRITE_2(device_t brdev, struct sdhci_slot *slot,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_write_2);
+	((sdhci_write_2_t *) _m)(brdev, slot, off, val);
+/** @brief Unique descriptor for the SDHCI_WRITE_4() method */
+extern struct kobjop_desc sdhci_write_4_desc;
+/** @brief A function implementing the SDHCI_WRITE_4() method */
+typedef void sdhci_write_4_t(device_t brdev, struct sdhci_slot *slot,
+                             bus_size_t off, uint32_t val);
+static __inline void SDHCI_WRITE_4(device_t brdev, struct sdhci_slot *slot,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_write_4);
+	((sdhci_write_4_t *) _m)(brdev, slot, off, val);
+/** @brief Unique descriptor for the SDHCI_WRITE_MULTI_4() method */
+extern struct kobjop_desc sdhci_write_multi_4_desc;
+/** @brief A function implementing the SDHCI_WRITE_MULTI_4() method */
+typedef void sdhci_write_multi_4_t(device_t brdev, struct sdhci_slot *slot,
+static __inline void SDHCI_WRITE_MULTI_4(device_t brdev,
+                                         struct sdhci_slot *slot,
+                                         bus_size_t count)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_write_multi_4);
+	((sdhci_write_multi_4_t *) _m)(brdev, slot, off, data, count);
+/** @brief Unique descriptor for the SDHCI_PLATFORM_WILL_HANDLE() method */
+extern struct kobjop_desc sdhci_platform_will_handle_desc;
+/** @brief A function implementing the SDHCI_PLATFORM_WILL_HANDLE() method */
+typedef int sdhci_platform_will_handle_t(device_t brdev,
+                                         struct sdhci_slot *slot);
+static __inline int SDHCI_PLATFORM_WILL_HANDLE(device_t brdev,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_platform_will_handle);
+	return ((sdhci_platform_will_handle_t *) _m)(brdev, slot);
+/** @brief Unique descriptor for the SDHCI_PLATFORM_START_TRANSFER() method */
+extern struct kobjop_desc sdhci_platform_start_transfer_desc;
+/** @brief A function implementing the SDHCI_PLATFORM_START_TRANSFER() method */
+typedef void sdhci_platform_start_transfer_t(device_t brdev,
+                                             uint32_t *intmask);
+static __inline void SDHCI_PLATFORM_START_TRANSFER(device_t brdev,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_platform_start_transfer);
+	((sdhci_platform_start_transfer_t *) _m)(brdev, slot, intmask);
+/** @brief Unique descriptor for the SDHCI_PLATFORM_FINISH_TRANSFER() method */
+extern struct kobjop_desc sdhci_platform_finish_transfer_desc;
+/** @brief A function implementing the SDHCI_PLATFORM_FINISH_TRANSFER() method */
+typedef void sdhci_platform_finish_transfer_t(device_t brdev,
+static __inline void SDHCI_PLATFORM_FINISH_TRANSFER(device_t brdev,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_platform_finish_transfer);
+	((sdhci_platform_finish_transfer_t *) _m)(brdev, slot);
+/** @brief Unique descriptor for the SDHCI_MIN_FREQ() method */
+extern struct kobjop_desc sdhci_min_freq_desc;
+/** @brief A function implementing the SDHCI_MIN_FREQ() method */
+typedef uint32_t sdhci_min_freq_t(device_t brdev, struct sdhci_slot *slot);
+static __inline uint32_t SDHCI_MIN_FREQ(device_t brdev, struct sdhci_slot *slot)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_min_freq);
+	return ((sdhci_min_freq_t *) _m)(brdev, slot);
+/** @brief Unique descriptor for the SDHCI_GET_CARD_PRESENT() method */
+extern struct kobjop_desc sdhci_get_card_present_desc;
+/** @brief A function implementing the SDHCI_GET_CARD_PRESENT() method */
+typedef bool sdhci_get_card_present_t(device_t brdev, struct sdhci_slot *slot);
+static __inline bool SDHCI_GET_CARD_PRESENT(device_t brdev,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_get_card_present);
+	return ((sdhci_get_card_present_t *) _m)(brdev, slot);
+/** @brief Unique descriptor for the SDHCI_SET_UHS_TIMING() method */
+extern struct kobjop_desc sdhci_set_uhs_timing_desc;
+/** @brief A function implementing the SDHCI_SET_UHS_TIMING() method */
+typedef void sdhci_set_uhs_timing_t(device_t brdev, struct sdhci_slot *slot);
+static __inline void SDHCI_SET_UHS_TIMING(device_t brdev,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_set_uhs_timing);
+	((sdhci_set_uhs_timing_t *) _m)(brdev, slot);
+#endif /* _sdhci_if_h_ */
diff --git a/rtemsbsd/local/gpiobus_if.c b/rtemsbsd/local/gpiobus_if.c
index 0000000..a1c7dd5
--- /dev/null
+++ b/rtemsbsd/local/gpiobus_if.c
@@ -0,0 +1,62 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * with
+ *   makeobjops.awk
+#include <sys/param.h>
+#include <sys/queue.h>
+#include <sys/kernel.h>
+#include <sys/kobj.h>
+#include <sys/bus.h>
+#include <sys/gpio.h>
+#include <rtems/bsd/local/gpiobus_if.h>
+struct kobjop_desc gpiobus_acquire_bus_desc = {
+	0, { &gpiobus_acquire_bus_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_release_bus_desc = {
+	0, { &gpiobus_release_bus_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_pin_set_desc = {
+	0, { &gpiobus_pin_set_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_pin_get_desc = {
+	0, { &gpiobus_pin_get_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_pin_toggle_desc = {
+	0, { &gpiobus_pin_toggle_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_pin_getcaps_desc = {
+	0, { &gpiobus_pin_getcaps_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_pin_getflags_desc = {
+	0, { &gpiobus_pin_getflags_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_pin_setflags_desc = {
+	0, { &gpiobus_pin_setflags_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_pin_getname_desc = {
+	0, { &gpiobus_pin_getname_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc gpiobus_pin_setname_desc = {
+	0, { &gpiobus_pin_setname_desc, (kobjop_t)kobj_error_method }
diff --git a/rtemsbsd/local/sdhci_if.c b/rtemsbsd/local/sdhci_if.c
index 0000000..1d6c26d
--- /dev/null
+++ b/rtemsbsd/local/sdhci_if.c
@@ -0,0 +1,90 @@
+ * with
+ *   makeobjops.awk
+#include <sys/types.h>
+#include <sys/sysctl.h>
+#include <sys/taskqueue.h>
+#include <dev/mmc/bridge.h>
+#include <dev/sdhci/sdhci.h>
+static void
+null_set_uhs_timing(device_t brdev __unused,
+    struct sdhci_slot *slot __unused)
+#include <rtems/bsd/local/sdhci_if.h>
+struct kobjop_desc sdhci_read_1_desc = {
+	0, { &sdhci_read_1_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_read_2_desc = {
+	0, { &sdhci_read_2_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_read_4_desc = {
+	0, { &sdhci_read_4_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_read_multi_4_desc = {
+	0, { &sdhci_read_multi_4_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_write_1_desc = {
+	0, { &sdhci_write_1_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_write_2_desc = {
+	0, { &sdhci_write_2_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_write_4_desc = {
+	0, { &sdhci_write_4_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_write_multi_4_desc = {
+	0, { &sdhci_write_multi_4_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_platform_will_handle_desc = {
+	0, { &sdhci_platform_will_handle_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_platform_start_transfer_desc = {
+	0, { &sdhci_platform_start_transfer_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_platform_finish_transfer_desc = {
+	0, { &sdhci_platform_finish_transfer_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc sdhci_min_freq_desc = {
+	0, { &sdhci_min_freq_desc, (kobjop_t)sdhci_generic_min_freq }
+struct kobjop_desc sdhci_get_card_present_desc = {
+	0, { &sdhci_get_card_present_desc, (kobjop_t)sdhci_generic_get_card_present }
+struct kobjop_desc sdhci_set_uhs_timing_desc = {
+	0, { &sdhci_set_uhs_timing_desc, (kobjop_t)null_set_uhs_timing }
2.7.4
