[PATCH 3/3] Update wpa_supplicant/hostapd for 2017-01 vulnerability release.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Nov 8 14:10:48 UTC 2017
hostapd: Avoid key reinstallation in FT handshake
Prevent reinstallation of an already in-use group key
Extend protection of GTK/IGTK reinstallation of WNM-Sleep Mode cases
Fix TK configuration to the driver in EAPOL-Key 3/4 retry case
Prevent installation of an all-zero TK
Fix PTK rekeying to generate a new ANonce
TDLS: Reject TPK-TK reconfiguration
WNM: Ignore Key Data in WNM Sleep Mode Response frame if no PMF in use
WNM: Ignore WNM-Sleep Mode Response if WNM-Sleep Mode has not been used
WNM: Ignore WNM-Sleep Mode Response without pending request
FT: Do not allow multiple Reassociation Response frames
TDLS: Ignore incoming TDLS Setup Response retries
Submitted by:	jhb
Obtained from:	https://w1.fi/security/2017-01/ (against later version)
Security:	FreeBSD-SA-17:07
Security:	CERT VU#228519
Security:	CVE-2017-13077
Security:	CVE-2017-13078
Security:	CVE-2017-13079
Security:	CVE-2017-13080
Security:	CVE-2017-13081
Security:	CVE-2017-13082
Security:	CVE-2017-13086
Security:	CVE-2017-13087
Security:	CVE-2017-13088
Differential Revision:	https://reviews.freebsd.org/D12693
 freebsd/contrib/wpa/src/ap/wpa_auth.c              |  32 ++++-
 freebsd/contrib/wpa/src/ap/wpa_auth.h              |   1 +
 freebsd/contrib/wpa/src/ap/wpa_auth_ft.c           |  10 ++
 freebsd/contrib/wpa/src/ap/wpa_auth_i.h            |   1 +
 freebsd/contrib/wpa/src/common/wpa_common.h        |  12 ++
 freebsd/contrib/wpa/src/rsn_supp/tdls.c            |  46 +++++-
 freebsd/contrib/wpa/src/rsn_supp/wpa.c             | 157 ++++++++++++++-------
 freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c          |   8 ++
 freebsd/contrib/wpa/src/rsn_supp/wpa_i.h           |   7 +
 freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c    |   1 +
 freebsd/contrib/wpa/wpa_supplicant/events.c        |   1 +
 freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c       |  16 +++
 .../contrib/wpa/wpa_supplicant/wpa_supplicant_i.h  |   1 +
 13 files changed, 240 insertions(+), 53 deletions(-)
diff --git a/freebsd/contrib/wpa/src/ap/wpa_auth.c b/freebsd/contrib/wpa/src/ap/wpa_auth.c
index ed48bbf6818..97d446204de 100644
--- a/freebsd/contrib/wpa/src/ap/wpa_auth.c
+++ b/freebsd/contrib/wpa/src/ap/wpa_auth.c
@@ -1895,6 +1895,21 @@ SM_STATE(WPA_PTK, AUTHENTICATION2)
+static int wpa_auth_sm_ptk_update(struct wpa_state_machine *sm)
+	if (random_get_bytes(sm->ANonce, WPA_NONCE_LEN)) {
+		wpa_printf(MSG_ERROR,
+			   "WPA: Failed to get random data for ANonce");
+		sm->Disconnect = TRUE;
+		return -1;
+	wpa_hexdump(MSG_DEBUG, "WPA: Assign new ANonce", sm->ANonce,
+		    WPA_NONCE_LEN);
+	sm->TimeoutCtr = 0;
+	return 0;
 SM_STATE(WPA_PTK, INITPMK)
 	u8 msk[2 * PMK_LEN];
@@ -2416,9 +2431,12 @@ SM_STEP(WPA_PTK)
 		SM_ENTER(WPA_PTK, AUTHENTICATION);
 	else if (sm->ReAuthenticationRequest)
 		SM_ENTER(WPA_PTK, AUTHENTICATION2);
-	else if (sm->PTKRequest)
-		SM_ENTER(WPA_PTK, PTKSTART);
-	else switch (sm->wpa_ptk_state) {
+	else if (sm->PTKRequest) {
+		if (wpa_auth_sm_ptk_update(sm) < 0)
+			SM_ENTER(WPA_PTK, DISCONNECTED);
+		else
+			SM_ENTER(WPA_PTK, PTKSTART);
+	} else switch (sm->wpa_ptk_state) {
 	case WPA_PTK_INITIALIZE:
 		break;
 	case WPA_PTK_DISCONNECT:
@@ -3211,6 +3229,14 @@ int wpa_auth_sta_wpa_version(struct wpa_state_machine *sm)
+int wpa_auth_sta_ft_tk_already_set(struct wpa_state_machine *sm)
+	if (!sm || !wpa_key_mgmt_ft(sm->wpa_key_mgmt))
+		return 0;
+	return sm->tk_already_set;
 int wpa_auth_sta_clear_pmksa(struct wpa_state_machine *sm,
 			     struct rsn_pmksa_cache_entry *entry)
diff --git a/freebsd/contrib/wpa/src/ap/wpa_auth.h b/freebsd/contrib/wpa/src/ap/wpa_auth.h
index fd04f169433..1b1442f414f 100644
--- a/freebsd/contrib/wpa/src/ap/wpa_auth.h
+++ b/freebsd/contrib/wpa/src/ap/wpa_auth.h
@@ -271,6 +271,7 @@ int wpa_auth_pairwise_set(struct wpa_state_machine *sm);
 int wpa_auth_get_pairwise(struct wpa_state_machine *sm);
 int wpa_auth_sta_key_mgmt(struct wpa_state_machine *sm);
 int wpa_auth_sta_wpa_version(struct wpa_state_machine *sm);
+int wpa_auth_sta_ft_tk_already_set(struct wpa_state_machine *sm);
 			     struct rsn_pmksa_cache_entry *entry);
diff --git a/freebsd/contrib/wpa/src/ap/wpa_auth_ft.c b/freebsd/contrib/wpa/src/ap/wpa_auth_ft.c
index 32622b4db52..19530a3177e 100644
--- a/freebsd/contrib/wpa/src/ap/wpa_auth_ft.c
+++ b/freebsd/contrib/wpa/src/ap/wpa_auth_ft.c
@@ -782,6 +782,14 @@ void wpa_ft_install_ptk(struct wpa_state_machine *sm)
 		return;
+	if (sm->tk_already_set) {
+		/* Must avoid TK reconfiguration to prevent clearing of TX/RX
+		 * PN in the driver */
+		wpa_printf(MSG_DEBUG,
+			   "FT: Do not re-install same PTK to the driver");
+		return;
 	/* FIX: add STA entry to kernel/driver here? The set_key will fail
 	 * most likely without this.. At the moment, STA entry is added only
 	 * after association has been completed. This function will be called
@@ -794,6 +802,7 @@ void wpa_ft_install_ptk(struct wpa_state_machine *sm)
 	/* FIX: MLME-SetProtection.Request(TA, Tx_Rx) */
 	sm->pairwise_set = TRUE;
+	sm->tk_already_set = TRUE;
@@ -900,6 +909,7 @@ static int wpa_ft_process_auth_req(struct wpa_state_machine *sm,
 	sm->pairwise = pairwise;
 	sm->PTK_valid = TRUE;
+	sm->tk_already_set = FALSE;
 	wpa_ft_install_ptk(sm);
 	buflen = 2 + sizeof(struct rsn_mdie) + 2 + sizeof(struct rsn_ftie) +
diff --git a/freebsd/contrib/wpa/src/ap/wpa_auth_i.h b/freebsd/contrib/wpa/src/ap/wpa_auth_i.h
index 57b098f2ed7..234d84c8468 100644
--- a/freebsd/contrib/wpa/src/ap/wpa_auth_i.h
+++ b/freebsd/contrib/wpa/src/ap/wpa_auth_i.h
@@ -64,6 +64,7 @@ struct wpa_state_machine {
 	struct wpa_ptk PTK;
 	Boolean PTK_valid;
 	Boolean pairwise_set;
+	Boolean tk_already_set;
 	int keycount;
 	Boolean Pair;
 	struct wpa_key_replay_counter {
diff --git a/freebsd/contrib/wpa/src/common/wpa_common.h b/freebsd/contrib/wpa/src/common/wpa_common.h
index c08f6514ab5..a04e759373b 100644
--- a/freebsd/contrib/wpa/src/common/wpa_common.h
+++ b/freebsd/contrib/wpa/src/common/wpa_common.h
@@ -213,8 +213,20 @@ struct wpa_ptk {
 	size_t kck_len;
 	size_t kek_len;
 	size_t tk_len;
+	int installed; /* 1 if key has already been installed to driver */
+struct wpa_gtk {
+	u8 gtk[WPA_GTK_MAX_LEN];
+	size_t gtk_len;
+#ifdef CONFIG_IEEE80211W
+struct wpa_igtk {
+	u8 igtk[WPA_IGTK_MAX_LEN];
+	size_t igtk_len;
+#endif /* CONFIG_IEEE80211W */
 /* WPA IE version 1
  * 00-50-f2:1 (OUI:OUI type)
diff --git a/freebsd/contrib/wpa/src/rsn_supp/tdls.c b/freebsd/contrib/wpa/src/rsn_supp/tdls.c
index c8be56aa913..337fb80c18e 100644
--- a/freebsd/contrib/wpa/src/rsn_supp/tdls.c
+++ b/freebsd/contrib/wpa/src/rsn_supp/tdls.c
@@ -115,6 +115,7 @@ struct wpa_tdls_peer {
 		u8 tk[16]; /* TPK-TK; assuming only CCMP will be used */
 	} tpk;
 	int tpk_set;
+	int tk_set; /* TPK-TK configured to the driver */
 	int tpk_success;
 	int tpk_in_progress;
@@ -195,6 +196,20 @@ static int wpa_tdls_set_key(struct wpa_sm *sm, struct wpa_tdls_peer *peer)
 	u8 rsc[6];
 	enum wpa_alg alg;
+	if (peer->tk_set) {
+		 * This same TPK-TK has already been configured to the driver
+		 * and this new configuration attempt (likely due to an
+		 * unexpected retransmitted frame) would result in clearing
+		 * the TX/RX sequence number which can break security, so must
+		 * not allow that to happen.
+		wpa_printf(MSG_INFO, "TDLS: TPK-TK for the peer " MACSTR
+			   " has already been configured to the driver - do not reconfigure",
+			   MAC2STR(peer->addr));
+		return -1;
 	os_memset(rsc, 0, 6);
 	switch (peer->cipher) {
@@ -212,12 +227,15 @@ static int wpa_tdls_set_key(struct wpa_sm *sm, struct wpa_tdls_peer *peer)
 		return -1;
+	wpa_printf(MSG_DEBUG, "TDLS: Configure pairwise key for peer " MACSTR,
 	if (wpa_sm_set_key(sm, alg, peer->addr, -1, 1,
 			   rsc, sizeof(rsc), peer->tpk.tk, key_len) < 0) {
 		wpa_printf(MSG_WARNING, "TDLS: Failed to set TPK to the "
 			   "driver");
 		return -1;
+	peer->tk_set = 1;
 	return 0;
@@ -693,7 +711,7 @@ static void wpa_tdls_peer_clear(struct wpa_sm *sm, struct wpa_tdls_peer *peer)
 	peer->cipher = 0;
 	peer->qos_info = 0;
 	peer->wmm_capable = 0;
-	peer->tpk_set = peer->tpk_success = 0;
+	peer->tk_set = peer->tpk_set = peer->tpk_success = 0;
 	peer->chan_switch_enabled = 0;
 	os_memset(&peer->tpk, 0, sizeof(peer->tpk));
 	os_memset(peer->inonce, 0, WPA_NONCE_LEN);
@@ -1156,6 +1174,7 @@ skip_rsnie:
 		wpa_tdls_peer_free(sm, peer);
 		return -1;
+	peer->tk_set = 0; /* A new nonce results in a new TK */
 	wpa_hexdump(MSG_DEBUG, "TDLS: Initiator Nonce for TPK handshake",
 		    peer->inonce, WPA_NONCE_LEN);
 	os_memcpy(ftie->Snonce, peer->inonce, WPA_NONCE_LEN);
@@ -1748,6 +1767,19 @@ static int wpa_tdls_addset_peer(struct wpa_sm *sm, struct wpa_tdls_peer *peer,
+static int tdls_nonce_set(const u8 *nonce)
+	int i;
+	for (i = 0; i < WPA_NONCE_LEN; i++) {
+		if (nonce[i])
+			return 1;
+	return 0;
 static int wpa_tdls_process_tpk_m1(struct wpa_sm *sm, const u8 *src_addr,
 				   const u8 *buf, size_t len)
@@ -2001,7 +2033,8 @@ skip_rsn:
 	peer->rsnie_i_len = kde.rsn_ie_len;
 	peer->cipher = cipher;
-	if (os_memcmp(peer->inonce, ftie->Snonce, WPA_NONCE_LEN) != 0) {
+	if (os_memcmp(peer->inonce, ftie->Snonce, WPA_NONCE_LEN) != 0 ||
+	    !tdls_nonce_set(peer->inonce)) {
 		 * There is no point in updating the RNonce for every obtained
 		 * TPK M1 frame (e.g., retransmission due to timeout) with the
@@ -2017,6 +2050,7 @@ skip_rsn:
 				"TDLS: Failed to get random data for responder nonce");
 			goto error;
 #if 0
@@ -2173,6 +2207,14 @@ static int wpa_tdls_process_tpk_m2(struct wpa_sm *sm, const u8 *src_addr,
 			   "ignore TPK M2 from " MACSTR, MAC2STR(src_addr));
 		return -1;
+	if (peer->tpk_success) {
+		wpa_printf(MSG_INFO, "TDLS: Ignore incoming TPK M2 retry, from "
+			   MACSTR " as TPK M3 was already sent",
+			   MAC2STR(src_addr));
+		return 0;
 	wpa_tdls_tpk_retry_timeout_cancel(sm, peer, WLAN_TDLS_SETUP_REQUEST);
 	if (len < 3 + 2 + 1) {
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa.c b/freebsd/contrib/wpa/src/rsn_supp/wpa.c
index a738c986446..c4181bdf3c9 100644
--- a/freebsd/contrib/wpa/src/rsn_supp/wpa.c
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa.c
@@ -607,6 +607,12 @@ static int wpa_supplicant_install_ptk(struct wpa_sm *sm,
 	const u8 *key_rsc;
 	u8 null_rsc[8] = { 0, 0, 0, 0, 0, 0, 0, 0 };
+	if (sm->ptk.installed) {
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG,
+			"WPA: Do not re-install same PTK to the driver");
+		return 0;
 		"WPA: Installing PTK to the driver");
@@ -645,6 +651,7 @@ static int wpa_supplicant_install_ptk(struct wpa_sm *sm,
 	/* TK is not needed anymore in supplicant */
 	os_memset(sm->ptk.tk, 0, WPA_TK_MAX_LEN);
+	sm->ptk.installed = 1;
 	if (sm->wpa_ptk_rekey) {
 		eloop_cancel_timeout(wpa_sm_rekey_ptk, sm, NULL);
@@ -694,11 +701,23 @@ struct wpa_gtk_data {
 static int wpa_supplicant_install_gtk(struct wpa_sm *sm,
 				      const struct wpa_gtk_data *gd,
-				      const u8 *key_rsc)
+				      const u8 *key_rsc, int wnm_sleep)
 	const u8 *_gtk = gd->gtk;
 	u8 gtk_buf[32];
+	/* Detect possible key reinstallation */
+	if ((sm->gtk.gtk_len == (size_t) gd->gtk_len &&
+	     os_memcmp(sm->gtk.gtk, gd->gtk, sm->gtk.gtk_len) == 0) ||
+	    (sm->gtk_wnm_sleep.gtk_len == (size_t) gd->gtk_len &&
+	     os_memcmp(sm->gtk_wnm_sleep.gtk, gd->gtk,
+		       sm->gtk_wnm_sleep.gtk_len) == 0)) {
+			"WPA: Not reinstalling already in-use GTK to the driver (keyidx=%d tx=%d len=%d)",
+			gd->keyidx, gd->tx, gd->gtk_len);
+		return 0;
 	wpa_hexdump_key(MSG_DEBUG, "WPA: Group Key", gd->gtk, gd->gtk_len);
 		"WPA: Installing GTK to the driver (keyidx=%d tx=%d len=%d)",
@@ -733,6 +752,15 @@ static int wpa_supplicant_install_gtk(struct wpa_sm *sm,
 	os_memset(gtk_buf, 0, sizeof(gtk_buf));
+	if (wnm_sleep) {
+		sm->gtk_wnm_sleep.gtk_len = gd->gtk_len;
+		os_memcpy(sm->gtk_wnm_sleep.gtk, gd->gtk,
+			  sm->gtk_wnm_sleep.gtk_len);
+	} else {
+		sm->gtk.gtk_len = gd->gtk_len;
+		os_memcpy(sm->gtk.gtk, gd->gtk, sm->gtk.gtk_len);
 	return 0;
@@ -790,7 +818,7 @@ static int wpa_supplicant_pairwise_gtk(struct wpa_sm *sm,
 	    (wpa_supplicant_check_group_cipher(sm, sm->group_cipher,
 					       gtk_len, gtk_len,
 					       &gd.key_rsc_len, &gd.alg) ||
-	     wpa_supplicant_install_gtk(sm, &gd, key->key_rsc))) {
+	     wpa_supplicant_install_gtk(sm, &gd, key->key_rsc, 0))) {
 			"RSN: Failed to install GTK");
 		os_memset(&gd, 0, sizeof(gd));
@@ -804,6 +832,58 @@ static int wpa_supplicant_pairwise_gtk(struct wpa_sm *sm,
+static int wpa_supplicant_install_igtk(struct wpa_sm *sm,
+				       const struct wpa_igtk_kde *igtk,
+				       int wnm_sleep)
+	size_t len = wpa_cipher_key_len(sm->mgmt_group_cipher);
+	u16 keyidx = WPA_GET_LE16(igtk->keyid);
+	if ((sm->igtk.igtk_len == len &&
+	     os_memcmp(sm->igtk.igtk, igtk->igtk, sm->igtk.igtk_len) == 0) ||
+	    (sm->igtk_wnm_sleep.igtk_len == len &&
+	     os_memcmp(sm->igtk_wnm_sleep.igtk, igtk->igtk,
+		       sm->igtk_wnm_sleep.igtk_len) == 0)) {
+			"WPA: Not reinstalling already in-use IGTK to the driver (keyidx=%d)",
+			keyidx);
+		return  0;
+		"WPA: IGTK keyid %d pn %02x%02x%02x%02x%02x%02x",
+		keyidx, MAC2STR(igtk->pn));
+	wpa_hexdump_key(MSG_DEBUG, "WPA: IGTK", igtk->igtk, len);
+	if (keyidx > 4095) {
+		wpa_msg(sm->ctx->msg_ctx, MSG_WARNING,
+			"WPA: Invalid IGTK KeyID %d", keyidx);
+		return -1;
+	if (wpa_sm_set_key(sm, wpa_cipher_to_alg(sm->mgmt_group_cipher),
+			   broadcast_ether_addr,
+			   keyidx, 0, igtk->pn, sizeof(igtk->pn),
+			   igtk->igtk, len) < 0) {
+			"WPA: Failed to configure IGTK to the driver");
+		return -1;
+	if (wnm_sleep) {
+		sm->igtk_wnm_sleep.igtk_len = len;
+		os_memcpy(sm->igtk_wnm_sleep.igtk, igtk->igtk,
+			  sm->igtk_wnm_sleep.igtk_len);
+	} else {
+		sm->igtk.igtk_len = len;
+		os_memcpy(sm->igtk.igtk, igtk->igtk, sm->igtk.igtk_len);
+	return 0;
 static int ieee80211w_set_keys(struct wpa_sm *sm,
 			       struct wpa_eapol_ie_parse *ie)
@@ -814,30 +894,14 @@ static int ieee80211w_set_keys(struct wpa_sm *sm,
 	if (ie->igtk) {
 		size_t len;
 		const struct wpa_igtk_kde *igtk;
-		u16 keyidx;
 		if (ie->igtk_len != WPA_IGTK_KDE_PREFIX_LEN + len)
 			return -1;
 		igtk = (const struct wpa_igtk_kde *) ie->igtk;
-		keyidx = WPA_GET_LE16(igtk->keyid);
-		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: IGTK keyid %d "
-			"pn %02x%02x%02x%02x%02x%02x",
-			keyidx, MAC2STR(igtk->pn));
-		wpa_hexdump_key(MSG_DEBUG, "WPA: IGTK",
-				igtk->igtk, len);
-		if (keyidx > 4095) {
-			wpa_msg(sm->ctx->msg_ctx, MSG_WARNING,
-				"WPA: Invalid IGTK KeyID %d", keyidx);
-			return -1;
-		if (wpa_sm_set_key(sm, wpa_cipher_to_alg(sm->mgmt_group_cipher),
-				   broadcast_ether_addr,
-				   keyidx, 0, igtk->pn, sizeof(igtk->pn),
-				   igtk->igtk, len) < 0) {
-				"WPA: Failed to configure IGTK to the driver");
+		if (wpa_supplicant_install_igtk(sm, igtk, 0) < 0)
 			return -1;
 	return 0;
@@ -1485,7 +1549,7 @@ static void wpa_supplicant_process_1_of_2(struct wpa_sm *sm,
 	if (ret)
 		goto failed;
-	if (wpa_supplicant_install_gtk(sm, &gd, key->key_rsc) ||
+	if (wpa_supplicant_install_gtk(sm, &gd, key->key_rsc, 0) ||
 	    wpa_supplicant_send_2_of_2(sm, key, ver, key_info))
 		goto failed;
@@ -2253,7 +2317,7 @@ void wpa_sm_deinit(struct wpa_sm *sm)
 void wpa_sm_notify_assoc(struct wpa_sm *sm, const u8 *bssid)
-	int clear_ptk = 1;
+	int clear_keys = 1;
 	if (sm == NULL)
 		return;
@@ -2279,11 +2343,11 @@ void wpa_sm_notify_assoc(struct wpa_sm *sm, const u8 *bssid)
 		/* Prepare for the next transition */
 		wpa_ft_prepare_auth_request(sm, NULL);
-		clear_ptk = 0;
+		clear_keys = 0;
 #endif /* CONFIG_IEEE80211R */
-	if (clear_ptk) {
+	if (clear_keys) {
 		 * IEEE 802.11, 8.4.10: Delete PTK SA on (re)association if
 		 * this is not part of a Fast BSS Transition.
@@ -2293,6 +2357,12 @@ void wpa_sm_notify_assoc(struct wpa_sm *sm, const u8 *bssid)
 		os_memset(&sm->ptk, 0, sizeof(sm->ptk));
 		sm->tptk_set = 0;
 		os_memset(&sm->tptk, 0, sizeof(sm->tptk));
+		os_memset(&sm->gtk, 0, sizeof(sm->gtk));
+		os_memset(&sm->gtk_wnm_sleep, 0, sizeof(sm->gtk_wnm_sleep));
+		os_memset(&sm->igtk, 0, sizeof(sm->igtk));
+		os_memset(&sm->igtk_wnm_sleep, 0, sizeof(sm->igtk_wnm_sleep));
 #ifdef CONFIG_TDLS
@@ -2324,6 +2394,9 @@ void wpa_sm_notify_disassoc(struct wpa_sm *sm)
 #ifdef CONFIG_TDLS
 	wpa_tdls_disassoc(sm);
 #endif /* CONFIG_TDLS */
+#ifdef CONFIG_IEEE80211R
+	sm->ft_reassoc_completed = 0;
+#endif /* CONFIG_IEEE80211R */
 	/* Keys are not needed in the WPA state machine anymore */
 	wpa_sm_drop_sa(sm);
@@ -2809,6 +2882,12 @@ void wpa_sm_drop_sa(struct wpa_sm *sm)
 	os_memset(sm->pmk, 0, sizeof(sm->pmk));
 	os_memset(sm->xxkey, 0, sizeof(sm->xxkey));
 	os_memset(sm->pmk_r0, 0, sizeof(sm->pmk_r0));
@@ -2872,7 +2951,7 @@ int wpa_wnmsleep_install_key(struct wpa_sm *sm, u8 subelem_id, u8 *buf)
 		wpa_hexdump_key(MSG_DEBUG, "Install GTK (WNM SLEEP)",
 				gd.gtk, gd.gtk_len);
-		if (wpa_supplicant_install_gtk(sm, &gd, key_rsc)) {
+		if (wpa_supplicant_install_gtk(sm, &gd, key_rsc, 1)) {
 			wpa_printf(MSG_DEBUG, "Failed to install the GTK in "
 				   "WNM mode");
@@ -2881,29 +2960,11 @@ int wpa_wnmsleep_install_key(struct wpa_sm *sm, u8 subelem_id, u8 *buf)
 	} else if (subelem_id == WNM_SLEEP_SUBELEM_IGTK) {
-		struct wpa_igtk_kde igd;
-		u16 keyidx;
-		os_memset(&igd, 0, sizeof(igd));
-		keylen = wpa_cipher_key_len(sm->mgmt_group_cipher);
-		os_memcpy(igd.keyid, buf + 2, 2);
-		os_memcpy(igd.pn, buf + 4, 6);
-		keyidx = WPA_GET_LE16(igd.keyid);
-		os_memcpy(igd.igtk, buf + 10, keylen);
-		wpa_hexdump_key(MSG_DEBUG, "Install IGTK (WNM SLEEP)",
-				igd.igtk, keylen);
-				   keyidx, 0, igd.pn, sizeof(igd.pn),
-				   igd.igtk, keylen) < 0) {
-			wpa_printf(MSG_DEBUG, "Failed to install the IGTK in "
-				   "WNM mode");
+		const struct wpa_igtk_kde *igtk;
+		igtk = (const struct wpa_igtk_kde *) (buf + 2);
+		if (wpa_supplicant_install_igtk(sm, igtk, 1) < 0)
 			return -1;
 	} else {
 		wpa_printf(MSG_DEBUG, "Unknown element id");
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c b/freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c
index 509a20e0a91..ea5b419fde1 100644
--- a/freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c
@@ -155,6 +155,7 @@ static u8 * wpa_ft_gen_req_ies(struct wpa_sm *sm, size_t *len,
 	u16 capab;
 	sm->ft_completed = 0;
 	buf_len = 2 + sizeof(struct rsn_mdie) + 2 + sizeof(struct rsn_ftie) +
 		2 + sm->r0kh_id_len + ric_ies_len + 100;
@@ -683,6 +684,11 @@ int wpa_ft_validate_reassoc_resp(struct wpa_sm *sm, const u8 *ies,
 		return -1;
+	if (sm->ft_reassoc_completed) {
+		wpa_printf(MSG_DEBUG, "FT: Reassociation has already been completed for this FT protocol instance - ignore unexpected retransmission");
+		return 0;
 	if (wpa_ft_parse_ies(ies, ies_len, &parse) < 0) {
 		wpa_printf(MSG_DEBUG, "FT: Failed to parse IEs");
 		return -1;
@@ -783,6 +789,8 @@ int wpa_ft_validate_reassoc_resp(struct wpa_sm *sm, const u8 *ies,
 		return -1;
+	sm->ft_reassoc_completed = 1;
 	if (wpa_ft_process_gtk_subelem(sm, parse.gtk, parse.gtk_len) < 0)
 		return -1;
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa_i.h b/freebsd/contrib/wpa/src/rsn_supp/wpa_i.h
index 965a9c1d577..85cc8628264 100644
--- a/freebsd/contrib/wpa/src/rsn_supp/wpa_i.h
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa_i.h
@@ -30,6 +30,12 @@ struct wpa_sm {
 	u8 rx_replay_counter[WPA_REPLAY_COUNTER_LEN];
 	int rx_replay_counter_set;
 	u8 request_counter[WPA_REPLAY_COUNTER_LEN];
+	struct wpa_gtk gtk;
+	struct wpa_gtk gtk_wnm_sleep;
+	struct wpa_igtk igtk;
+	struct wpa_igtk igtk_wnm_sleep;
 	struct eapol_sm *eapol; /* EAPOL state machine from upper level code */
@@ -121,6 +127,7 @@ struct wpa_sm {
 	size_t r0kh_id_len;
 	u8 r1kh_id[FT_R1KH_ID_LEN];
 	int ft_completed;
+	int ft_reassoc_completed;
 	int over_the_ds_in_progress;
 	u8 target_ap[ETH_ALEN]; /* over-the-DS target AP */
 	int set_ptk_after_assoc;
diff --git a/freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c b/freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c
index b4da3f0a7dd..d540fc8ccd2 100644
--- a/freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c
+++ b/freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c
@@ -6893,6 +6893,7 @@ static void wpa_supplicant_ctrl_iface_flush(struct wpa_supplicant *wpa_s)
 	eloop_cancel_timeout(wpas_network_reenabled, wpa_s, NULL);
+	wpa_s->wnmsleep_used = 0;
diff --git a/freebsd/contrib/wpa/wpa_supplicant/events.c b/freebsd/contrib/wpa/wpa_supplicant/events.c
index b4d5d85ba99..3cf22d4cf0e 100644
--- a/freebsd/contrib/wpa/wpa_supplicant/events.c
+++ b/freebsd/contrib/wpa/wpa_supplicant/events.c
@@ -305,6 +305,7 @@ void wpa_supplicant_mark_disassoc(struct wpa_supplicant *wpa_s)
 	wpa_s->key_mgmt = 0;
 	wpas_rrm_reset(wpa_s);
diff --git a/freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c b/freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c
index 34332e2aa9f..d38b06eb0fd 100644
--- a/freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c
+++ b/freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c
@@ -140,6 +140,8 @@ int ieee802_11_send_wnmsleep_req(struct wpa_supplicant *wpa_s,
 	if (res < 0)
 		wpa_printf(MSG_DEBUG, "Failed to send WNM-Sleep Request "
 			   "(action=%d, intval=%d)", action, intval);
+	else
+		wpa_s->wnmsleep_used = 1;
 	os_free(wnmsleep_ie);
 	os_free(wnmtfs_ie);
@@ -190,6 +192,12 @@ static void wnm_sleep_mode_exit_success(struct wpa_supplicant *wpa_s,
 	end = ptr + key_len_total;
 	wpa_hexdump_key(MSG_DEBUG, "WNM: Key Data", ptr, key_len_total);
+	if (key_len_total && !wpa_sm_pmf_enabled(wpa_s->wpa)) {
+		wpa_msg(wpa_s, MSG_INFO,
+			"WNM: Ignore Key Data in WNM-Sleep Mode Response - PMF not enabled");
+		return;
 	while (ptr + 1 < end) {
 		if (ptr + 2 + ptr[1] > end) {
 			wpa_printf(MSG_DEBUG, "WNM: Invalid Key Data element "
@@ -250,6 +258,12 @@ static void ieee802_11_rx_wnmsleep_resp(struct wpa_supplicant *wpa_s,
 	u8 *tfsresp_ie_end = NULL;
 	size_t left;
+	if (!wpa_s->wnmsleep_used) {
+			   "WNM: Ignore WNM-Sleep Mode Response frame since WNM-Sleep Mode operation has not been requested");
+		return;
 	if (len < 3)
 		return;
 	key_len_total = WPA_GET_LE16(frm + 1);
@@ -285,6 +299,8 @@ static void ieee802_11_rx_wnmsleep_resp(struct wpa_supplicant *wpa_s,
 		return;
 	if (wnmsleep_ie->status == WNM_STATUS_SLEEP_ACCEPT ||
 	    wnmsleep_ie->status == WNM_STATUS_SLEEP_EXIT_ACCEPT_GTK_UPDATE) {
 		wpa_printf(MSG_DEBUG, "Successfully recv WNM-Sleep Response "
diff --git a/freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h b/freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h
index 58df48c548e..318768bc277 100644
--- a/freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h
+++ b/freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h
@@ -658,6 +658,7 @@ struct wpa_supplicant {
 	unsigned int reattach:1; /* reassociation to the same BSS requested */
 	unsigned int mac_addr_changed:1;
 	unsigned int added_vif:1;
+	unsigned int wnmsleep_used:1;
 	struct os_reltime last_mac_addr_change;
 	int last_mac_addr_style;
2.12.3
