New "RTEMS Contributor Guide"
Thu Nov 9 04:48:54 UTC 2017
On 08/11/2017 20:33, Sebastian Huber wrote:
> Hello,
> I would like to merge the "RTEMS BSP and Driver Guide", the "RTEMS Porting
> Guide", parts of the "RTEMS CPU Architecture Supplement", the
> https://devel.rtems.org/wiki/Developer/Coding/Conventions and the
> https://devel.rtems.org/wiki/Developer/Release into a new document "RTEMS
> Contributor Guide". The aim is to have a single document useful for RTEMS
> contributors.
Things like the coding standard should be moved to "RTEMS Software Engineering
Standards". I said I would create this document but have not. I will try and do
that this weekend.
I am not sure about the other parts of the documents you refer too. I have not
looked at them in detail to where they could go where. We have a User Manual and
we will have a "RTEMS Software Engineering Standards" so do we need more
documents or should be looking to reduce the number we have?
