Build Windows: FAILED 5/rtems-nios2.bset on x86_64-w64-mingw32 (nios2-rtems5-gcc-7.2.0-newlib-2.5.0.20170922-x86_64-w64-mingw32-1)
Sebastian Huber
Fri Nov 10 11:56:18 UTC 2017
On 10/11/17 12:44, Chris Johns wrote:
> /D/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/build/./gcc/xgcc -B/D/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/build/./gcc/ -nostdinc -B/D/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/build/nios2-rtems5/newlib/ -isystem/D/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/build/nios2-rtems5/newlib/targ-include
> -isystem
> /D/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/gcc-7.2.0/newlib/libc/include
> -B/D/opt/rtems/5/nios2-rtems5/bin/ -B/D/opt/rtems/5/nios2-rtems5/lib/ -isystem/D/opt/rtems/5/nios2-rtems5/include -isystem
> /D/opt/rtems/5/nios2-rtems5/sys-include -g -O2 -mhw-mul -mhw-mulx
> -mhw-div -mcustom-fadds=253 -mcustom-fdivs=255 -mcustom-fmuls=252
> -mcustom-fsubs=254 -O2 -I../../../../../../../../../../gcc-7.2.0/libgcc/../newlib/libc/sys/rtems/include -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wstrict-prototypes -Wmissing-prototypes -Wold-style-definition -isystem ./include -g -DIN_LIBGCC2 -fbuilding-libgcc -fno-stack-protector -Dinhibi!
> t_libc -I. -I. -I../../../../../../../../.././gcc -I../../../../../../../../../../gcc-7.2.0/libgcc
> -I../../../../../../../../../../gcc-7.2.0/libgcc/../gcc
> -I../../../../../../../../../../gcc-7.2.0/libgcc/../include -DHAVE_CC_TLS -o _gcov_merge_ior.o -MT _gcov_merge_ior.o -MD -MP -MF _gcov_merge_ior.dep -DL_gcov_merge_ior -c ../../../../../../../../../../gcc-7.2.0/libgcc/libgcov-merge.c
> make[4]: *** [../../../../../../../../../../gcc-7.2.0/libgcc/static-object.mk:17: unwind-dw2-fde.o] Error 1
> make[4]: *** Waiting for unfinished jobs....
> In file included from D:/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/gcc-7.2.0/newlib/libc/include/sys/unistd.h:8:0,
> from D:/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/gcc-7.2.0/newlib/libc/include/unistd.h:4,
> from D:/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/gcc-7.2.0/newlib/libc/include/pthread.h:25,
> from ./gthr-default.h:31,
> from ../../../../../../../../../../gcc-7.2.0/libgcc/gthr.h:148,
> from ../../../../../../../../../../gcc-7.2.0/libgcc/unwind-sjlj.c:31:
> D:/opt/rtems/rsb.git/rtems/build/nrg7n2xwm1/gcc-7.2.0/newlib/libc/include/pthread.h:236:5: error: unknown type name 'cpu_set_t'
I think this is a known problem of the Newlib/GCC build. During the
libgcc build the default header files are picked up, e.g.
newlib/libc/include/sys/_pthreadtypes.h
later during Newlib build, some header files are copied into the build
tree. Then a copy of
newlib/libc/sys/rtems/include/sys/_pthreadtypes.h
is used (nios2-rtems5/newlib/targ-include/sys/_pthreadtypes.h).
I made several attempts to fix this, but its quite convoluted. You
change one thing, and it breaks another thing.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
