[PATCH] Upgrade to 5.0.0
Sat Nov 11 04:06:33 UTC 2017
On 10/11/2017 17:30, Sebastian Huber wrote:
> On 09/11/17 23:52, Joel Sherrill wrote:
>> My question about the version number went unanswered. Is this the point
>> were we are switching to two digit versions? This thread has 5.0.0 in the
>> title (3 digits, no change in style)  but the current tools are "*-rtems5" which
>> implies two digit release numbering.  Can I get a clarification on that?
> Yes, the new number scheme.
> Master 5.0.0
> First release 5.1.0 (spelled as 5.1 in documents, etc.; exactly one commit has
> this version)
> Branch after first release 5.1.1
> Second release in this series 5.2.0 (spelled as 5.2)
> Branch after second release 5.2.1
How do the milestones now work in Trac? I see we have 5.0, 5.1 etc. Will there
be milestones for 5.1.0, 5.1.1, etc?
> Next master 6.0.0
> Tools use just "5".
I have been wondering about this for a while because I was concerned about
rtems5 and no rtems5.1, rtems5.2, etc as we have had for the 4 series. I think
rtems5 will work if we add configure checks for newlib into the kernel, libbsd etc.
GCC's interfaces are stable and do not move that much, it is newlib that changes
requiring us to build new tools. If a check for gcc and newlib was added to the
top level configure script of RTEMS we would be able protect users from
attempting to build RTEMS with the wrong version of tools. If this is something
that should happen I can create a ticket.
This change means users need to use prefixes when supporting more than one
release. I would need to review the User manual and see what it says.
