[rtems-bsp-builder] 2017-11-10 14:47:44: Profile(s): everything
Chris Johns
chrisj at rtems.org
Sun Nov 12 03:46:51 UTC 2017
On 12/11/17 4:55 am, joel at rtems.org wrote:
> RTEMS Tools Project - RTEMS Kernel BSP Builder, 5 (9f34b38edf2a)
> Host: #1 SMP Tue Sep 12 22:26:13 UTC 2017
> command: ./rtems-tools/tester/rtems-bsp-builder --rtems=/home/joel/rtems-\
> work/rtems --build-path=build --prefix=/home/joel/rtems-work/bsps\
> --log=build.log --warnings-report=warnings.log --mail --mail-\
> from=joel at rtems.org --mail-to=build at rtems.org\
> --profiles=everything --jobs=8
> Total Time : 21:07:44.882315 for 1565 completed job(s)
> Average BSP Build Time: 0:00:48.603758
> Failures Report
> 1 posix-debug arm/altcycv_devkit build:
> configure: /home/joel/rtems-work/rtems/configure --target=arm-rtems5\
> --enable-rtemsbsp=altcycv_devkit --prefix=/home/joel/rtems-work/bsps\
> --enable-debug --enable-posix
I ran the same build ...
https://lists.rtems.org/pipermail/build/2017-November/000221.html
and I did not get an error. Is there a tool set missing or rtems.git needs a
bootstrap?
