[rtems-bsp-builder] 2017-11-10 14:47:44: Profile(s): everything
Joel Sherrill
joel at rtems.org
Sun Nov 12 15:42:47 UTC 2017
On Sat, Nov 11, 2017 at 9:46 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 12/11/17 4:55 am, joel at rtems.org wrote:
> > RTEMS Tools Project - RTEMS Kernel BSP Builder, 5 (9f34b38edf2a)
> > Host: #1 SMP Tue Sep 12 22:26:13 UTC 2017
> > command: ./rtems-tools/tester/rtems-bsp-builder
> --rtems=/home/joel/rtems-\
> > work/rtems --build-path=build --prefix=/home/joel/rtems-
> work/bsps\
> > --log=build.log --warnings-report=warnings.log --mail --mail-\
> > from=joel at rtems.org --mail-to=build at rtems.org\
> > --profiles=everything --jobs=8
> > Total Time : 21:07:44.882315 for 1565 completed job(s)
> > Average BSP Build Time: 0:00:48.603758
> > Failures Report
> > 1 posix-debug arm/altcycv_devkit build:
> > configure: /home/joel/rtems-work/rtems/configure
> --target=arm-rtems5\
> > --enable-rtemsbsp=altcycv_devkit --prefix=/home/joel/rtems-
> work/bsps\
> > --enable-debug --enable-posix
> I ran the same build ...
> https://lists.rtems.org/pipermail/build/2017-November/000221.html
> and I did not get an error. Is there a tool set missing or rtems.git needs
> a
> bootstrap?
Looks like a race condition. The v850 failed similarly.
/usr/bin/install -c -m 644
/home/joel/rtems-work/rtems/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/include/arm-a9mpcore-irq.h
../../../../../.././altcycv_devkit/lib/include/bsp/arm-a9mpcore-irq.h
/usr/bin/install: cannot change permissions of
‘../../../../../.././altcycv_devkit/lib/include/bsp/arm-a9mpcore-irq.h’:
No such file or directory
/home/joel/rtems-work/rtems/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/include/arm-a9mpcore-regs.h
../../../../../.././altcycv_devkit/lib/include/bsp/arm-a9mpcore-regs.h
gmake[8]: ***
[../../../../../.././altcycv_devkit/lib/include/bsp/arm-a9mpcore-irq.h]
Error 1
gmake[8]: Leaving directory
`/data/home/joel/rtems-work/build/arm/altcycv_devkit.posix-debug/arm-rtems5/c/altcycv_devkit/lib/libbsp/arm/altera-cyclone-v'
gmake[7]: *** [preinstall-altera-cyclone-v] Error 1
Weird that it appears to be inside the middle of install. I assume it
copied the file
and then couldn't change the permissions.
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171112/3548100e/attachment.html>
