[PATCH 0/4] LEON: updates to SpaceWire Router driver
Tue Nov 14 21:59:42 UTC 2017
On 15/11/2017 01:47, Joel Sherrill wrote:
> Chris suggested that a Users Manual include sections on each BSP with
> instructions on setting the hardware up, debugging, etc. It makes sense that
> this is user facing information specific to a set of BSPs. So in the outline of
> what Chris proposed it would either be in a SPARC > General or SPARC > LEON3
> subsection.
There is a section called 'Hardware'. I think the 'Tiers' section can be moved
to after 'Targets' and then 'Architectures / SPARC' and/or 'Board Support
Packages (BSP) / LEON3' can be added.
I am adding a new section after 'Hardware' to this document called 'Running and
Testing Executables' that details the set up and operation of 'rtems-test' and
'rtems-run'.
