[PATCH] Upgrade to 5.0.0
Thu Nov 16 09:18:08 UTC 2017
On 15/11/17 22:13, Chris Johns wrote:
> On 13/11/2017 18:56, Sebastian Huber wrote:
>> There will be no 5.1.X release with X != 0. We have a version scheme change and
>> not simply a major version number bump. I think is quite good explained in the
>> GCC development page how it works (Version Numbering Scheme for GCC 5 and Up):
>> https://gcc.gnu.org/develop.html
> I knew there was some discussion about using this model, I was not aware this
> was the agreed path. I am fine with this approach and support it.
>> We need something similar in the new engineering guide.
> Yes. Should the wiki page [1] be updated to make it clear the approach we are
> taking until we have an engineering doc?
I updated:
https://devel.rtems.org/wiki/Developer/Release#RTEMSRelease5SeriesAndHigherNumbering
>> What do you mean with separate prefixes? I doubt that you can build a RTEMS 4.1
>> with the tool chain of RTEMS 4.10 and vice versa.
> Using the gcc approach changes this and what you say makes sense. In this
> context I was out by a dot number.
>> /opt/rtems/5/bin/X-rtems5-gcc
>> /opt/rtems/6 (maybe with the new build system)
>> /opt/rtems/7/bin/X-rtems7-gcc
> I am looking at the parallel install issue (#3083) and unfortunately a rather
> complex fix to it I am attempting to find the simplest path into the build
> system and stumbled across this in cpukit/aclocal/rtems-top.m4:
>   AC_PREFIX_DEFAULT([/opt/rtems-][_RTEMS_API])
> Does this need to change to:
>   AC_PREFIX_DEFAULT([/opt/rtems/][_RTEMS_API])
Yes, I think this is more in line with:
https://docs.rtems.org/branches/master/user/installation/prefixes-sandboxing.html#project-sandboxing
In this manual:
|/bd/rtems/4.11.0/tools|
    Production prefix for RTEMS 4.11.0 compiler, debuggers and tools.
|/bd/rtems/4.11.0/bsps|
    Production prefix for RTEMS 4.11.0 Board Support Packages (BSPs).
What should be the content of "tools" and "bsps"?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
