[PATCH] Upgrade to 5.0.0
Thu Nov 16 09:59:31 UTC 2017
On 16/11/17 10:32, Chris Johns wrote:
>> In this manual:
>> |/bd/rtems/4.11.0/tools|
>>     Production prefix for RTEMS 4.11.0 compiler, debuggers and tools.
>> |/bd/rtems/4.11.0/bsps|
>>     Production prefix for RTEMS 4.11.0 Board Support Packages (BSPs).
>> What should be the content of "tools" and "bsps"?
> If you are working on a BSP and installing in a prefix to use, for example with
> libbsd, keeping the tools and bsp under separate prefixes lets you delete the
> bsp tree without needing to rebuild the tools. If you use the same prefix for
> the tools and bsp you either need to rebuild both parts or run the risk a stale
> file could still be present and effect how things work. There is only an install
> and no upgrade for a BSP.
I always use the same prefix for tools and BSPs. I simply remove a BSP
with "rm -r $prefix/$arch-rtems$version/$bsp". I never had a problem
with stale BSP files this way.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
