parallel make failure?
Fri Nov 17 00:32:49 UTC 2017
On 17/11/2017 10:57, Joel Sherrill wrote:
> I started a build on rtbf64c which is Centos 7 (6 real cores, 12 virtual). I
> I built "everything". It pretty quickly had the Altera BSP do this:
> /usr/bin/install -c -m 644
> /home/joel/rtems-work/rtems/c/src/libchip/i2c/spi-flash-m25p40.h
> ../../../altcycv_devkit_smp/lib/include/libchip/spi-flash-m25p40.h
This is wrong. There is no message like this in the build any more. It should be:
Installing lib/include/rtems.h
