[PATCH] score: Optimize scheduler priority updates
Fri Nov 17 14:53:36 UTC 2017
On 17/11/17 15:48, Joel Sherrill wrote:
> What architecture were those sizes on? Do the size changes hold on
> other architectures?
Please see below, sparc, arm, powerpc. The erc32 numbers are with SMP
disabled.
> Good spot if it is consistent.
>     Before:
>        text filename
>         136
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
>         464
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
>          24
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
>         108
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
>         292
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
>         264
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
>        text filename
>         280
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
>         488
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
>         200
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
>         164
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
>         328
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
>         200
>     sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
>        text filename
>       24112
>     arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
>        text filename
>       37204
>     sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
>        text filename
>       42236
>     powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
>     After:
>        text filename
>         136
>         272
>          24
>         108
>         292
>         264
>        text filename
>         280
>         488
>         208
>         164
>         332
>         200
>        text filename
>       18860
>        text filename
>       28520
>        text filename
>       32664
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
