parallel make failure?
Sat Nov 18 00:30:41 UTC 2017
On 18/11/17 1:45 am, Joel Sherrill wrote:
> On Thu, Nov 16, 2017 at 6:32 PM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 17/11/2017 10:57, Joel Sherrill wrote:
>     > I started a build on rtbf64c which is Centos 7 (6 real cores, 12 virtual). I
>     > I built "everything". It pretty quickly had the Altera BSP do this:
>     > /usr/bin/install -c -m 644
>     > /home/joel/rtems-work/rtems/c/src/libchip/i2c/spi-flash-m25p40.h
>     > ../../../altcycv_devkit_smp/lib/include/libchip/spi-flash-m25p40.h
>     This is wrong. There is no message like this in the build any more. It
>     should be:
>     Installing lib/include/rtems.h
> OK. Not sure what happened. My overnight results are on the build@ log.
> I just updated again and started another build.
> Average BSP Build Time: 0:00:19.064294
> Total Time 8:17:15.620426
> Passes: 1502   Failures: 63
> 205541.45user 44682.47system 8:17:27elapsed 838%CPU (0avgtext+0avgdata
> 683108maxresident)k
> 1224inputs+1712685408outputs (0major+30150341701minor)pagefaults 0swaps
> More results in 8-12 hours, it looks like.
I cannot tell anything from the bsp builder output, it is limited to avoid
creating a huge email.
