GCC Master and Parallel Builds
Mon Nov 20 17:26:06 UTC 2017
Hi
I was doing a test sweep of the GCC master since GCC 8 is coming up and I
wanted to pass along that doing a "make -j" on a 6 real code (12
hyper-threaded) CentOS 7 computer resulted in all *rtems targets failing to
build.
Does anyone have insight into this or know the GCC PR to pile onto? I
recall Chris mentioning this issue at least.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171120/1c7ce412/attachment.html>
