[PATCH] Fix comments for object lookup err. -> status map
Martin Erik Werner
martinerikwerner.aac at gmail.com
Mon Nov 20 17:53:22 UTC 2017
Based on correlation with the enum for object lookup errors in
cpukit/score/include/rtems/score/objectimpl.h:
typedef enum {
OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL,
OBJECTS_INVALID_NAME,
OBJECTS_INVALID_ADDRESS,
OBJECTS_INVALID_ID,
OBJECTS_INVALID_NODE
} Objects_Name_or_id_lookup_errors;
update the comments regarding the object lookup error to status map to
match.
Signed-off-by: Martin Erik Werner <martin.werner at aacmicrotec.com>
cpukit/rtems/src/status.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/cpukit/rtems/src/status.c b/cpukit/rtems/src/status.c
index 810c0e18de..3eadea59f0 100644
--- a/cpukit/rtems/src/status.c
+++ b/cpukit/rtems/src/status.c
@@ -17,13 +17,13 @@
const rtems_status_code _Status_Object_name_errors_to_status[] = {
- /** This maps OBJECTS_SUCCESSFUL to RTEMS_SUCCESSFUL. */
+ /** This maps OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL to RTEMS_SUCCESSFUL. */
RTEMS_SUCCESSFUL,
/** This maps OBJECTS_INVALID_NAME to RTEMS_INVALID_NAME. */
RTEMS_INVALID_NAME,
- /** This maps OBJECTS_INVALID_ADDRESS to RTEMS_INVALID_NAME. */
+ /** This maps OBJECTS_INVALID_ADDRESS to RTEMS_INVALID_ADDRESS. */
RTEMS_INVALID_ADDRESS,
- /** This maps OBJECTS_INVALID_ID to RTEMS_INVALID_ADDRESS. */
+ /** This maps OBJECTS_INVALID_ID to RTEMS_INVALID_ID. */
RTEMS_INVALID_ID,
/** This maps OBJECTS_INVALID_NODE to RTEMS_INVALID_NODE. */
RTEMS_INVALID_NODE
2.11.0
