GCC Master and Parallel Builds
Tue Nov 21 00:11:26 UTC 2017
On 21/11/2017 04:26, Joel Sherrill wrote:
> I was doing a test sweep of the GCC master since GCC 8 is coming up and I wanted
> to pass along that doing a "make -j" on a 6 real code (12 hyper-threaded) CentOS
> 7 computer resulted in all *rtems targets failing to build.
> Does anyone have insight into this or know the GCC PR to pile onto? I recall
> Chris mentioning this issue at least.
That ticket is specific APFS and effects libstdc++. I would be surprised if the
failures are the same.
