[PATCH 1/5] sapi: New implementation of rtems_panic()
Tue Nov 21 14:14:18 UTC 2017
The previous rtems_panic() implementation was quite heavy weight.  It
depended on _exit() which calls the global destructors.  It used
fprintf(stderr, ...) for output which depends on an initialized console
device and the complex fprintf().
Introduce a new fatal source RTEMS_FATAL_SOURCE_PANIC for rtems_panic()
and output via vprintk().
Update #3244.
 cpukit/libcsupport/include/rtems/error.h  | 10 +---------
 cpukit/libcsupport/src/error.c            | 15 ---------------
 cpukit/sapi/Makefile.am                   |  1 +
 cpukit/sapi/include/rtems/fatal.h         | 12 ++++++++++++
 cpukit/sapi/src/panic.c                   | 32 +++++++++++++++++++++++++++++++
 cpukit/score/include/rtems/score/interr.h |  7 +++++++
 testsuites/sptests/sperror03/init.c       | 15 +++++----------
 7 files changed, 58 insertions(+), 34 deletions(-)
 create mode 100644 cpukit/sapi/src/panic.c
diff --git a/cpukit/libcsupport/include/rtems/error.h b/cpukit/libcsupport/include/rtems/error.h
index f72d78c700..617f59642b 100644
--- a/cpukit/libcsupport/include/rtems/error.h
+++ b/cpukit/libcsupport/include/rtems/error.h
@@ -48,7 +48,7 @@
 #define _RTEMS_RTEMS_ERROR_H
-#include <rtems/score/interr.h>
+#include <rtems/fatal.h>
 #include <stdarg.h>
@@ -124,14 +124,6 @@ int rtems_verror(
   va_list             arglist
- * rtems_panic is shorthand for rtems_error(RTEMS_ERROR_PANIC, ...)
-void rtems_panic(
-  const char *printf_format,
-) RTEMS_NO_RETURN;
 extern int rtems_panic_in_progress;
 #ifdef __cplusplus
diff --git a/cpukit/libcsupport/src/error.c b/cpukit/libcsupport/src/error.c
index 44cc1ee688..0e65f8929b 100644
--- a/cpukit/libcsupport/src/error.c
+++ b/cpukit/libcsupport/src/error.c
@@ -98,18 +98,3 @@ int rtems_error(
   return chars_written;
-void rtems_panic(
-  va_list arglist;
-  va_start(arglist, printf_format);
-  (void) rtems_verror(RTEMS_ERROR_PANIC, printf_format, arglist);
-  va_end(arglist);
-  rtems_error(0, "fatal error, exiting");
-  _exit(errno);
diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
index 85d89ef494..326d67f193 100644
--- a/cpukit/sapi/Makefile.am
+++ b/cpukit/sapi/Makefile.am
@@ -43,6 +43,7 @@ libsapi_a_SOURCES += src/delaynano.c
 libsapi_a_SOURCES += src/rbtree.c
 libsapi_a_SOURCES += src/rbtreefind.c
 libsapi_a_SOURCES += src/rbtreeinsert.c
+libsapi_a_SOURCES += src/panic.c
 libsapi_a_SOURCES += src/profilingiterate.c
 libsapi_a_SOURCES += src/profilingreportxml.c
 libsapi_a_SOURCES += src/tcsimpleinstall.c
diff --git a/cpukit/sapi/include/rtems/fatal.h b/cpukit/sapi/include/rtems/fatal.h
index 80929cd274..291af42c6e 100644
--- a/cpukit/sapi/include/rtems/fatal.h
+++ b/cpukit/sapi/include/rtems/fatal.h
@@ -89,6 +89,18 @@ RTEMS_NO_RETURN RTEMS_INLINE_ROUTINE void rtems_fatal(
+ * @brief Prints the specified message via printk() and terminates the system.
+ * @param[in] fmt The message format.
+ * @param[in] ... The message parameters.
+ * @see _Terminate().
+RTEMS_NO_RETURN void rtems_panic(
+  const char *fmt, ...
+) RTEMS_PRINTFLIKE( 1, 2 );
  * @brief Returns a text for a fatal source.
  * The text for each fatal source is the enumerator constant.
diff --git a/cpukit/sapi/src/panic.c b/cpukit/sapi/src/panic.c
new file mode 100644
index 0000000000..34b6f75213
--- /dev/null
+++ b/cpukit/sapi/src/panic.c
@@ -0,0 +1,32 @@
+ * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stdarg.h>
+void rtems_panic( const char *fmt, ... )
+  va_list ap;
+  va_start( ap, fmt );
+  vprintk( fmt, ap );
+  va_end( ap);
+  _Terminate( RTEMS_FATAL_SOURCE_PANIC, (Internal_errors_t) fmt );
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 4de9406200..a93eaf659c 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -124,6 +124,13 @@ typedef enum {
   RTEMS_FATAL_SOURCE_SMP = 10,
+   * @brief Fatal source of rtems_panic().
+   * @see rtem
+  RTEMS_FATAL_SOURCE_PANIC = 11,
    * @brief The last available fatal source.
    * This enum value ensures that the enum type needs at least 32-bits for
diff --git a/testsuites/sptests/sperror03/init.c b/testsuites/sptests/sperror03/init.c
index f4323a5001..ad42d96a47 100644
--- a/testsuites/sptests/sperror03/init.c
+++ b/testsuites/sptests/sperror03/init.c
@@ -16,8 +16,7 @@
 const char rtems_test_name[] = "SPERROR 3";
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
+static const char fmt[] = "Dummy panic\n";
 static void fatal_extension(
   rtems_fatal_source source,
@@ -26,24 +25,20 @@ static void fatal_extension(
   if (
-    source == RTEMS_FATAL_SOURCE_EXIT
+    source == RTEMS_FATAL_SOURCE_PANIC
       && !always_set_to_false
-      && error == 0
+      && error == (rtems_fatal_code) fmt
     TEST_END();
-rtems_task Init(
+static rtems_task Init(
   TEST_BEGIN();
-  rtems_panic(
-    "Dummy panic\n"
+  rtems_panic( fmt );
   rtems_test_assert(0);
2.12.3
