[PATCH] Fix comments for object lookup err. -> status map
Joel Sherrill
joel at rtems.org
Tue Nov 21 18:40:57 UTC 2017
Pushed. Thanks.
On Mon, Nov 20, 2017 at 11:53 AM, Martin Erik Werner <
martinerikwerner.aac at gmail.com> wrote:
> Based on correlation with the enum for object lookup errors in
> cpukit/score/include/rtems/score/objectimpl.h:
> typedef enum {
> OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL,
> OBJECTS_INVALID_NAME,
> OBJECTS_INVALID_ADDRESS,
> OBJECTS_INVALID_ID,
> OBJECTS_INVALID_NODE
> } Objects_Name_or_id_lookup_errors;
> update the comments regarding the object lookup error to status map to
> match.
> Signed-off-by: Martin Erik Werner <martin.werner at aacmicrotec.com>
> cpukit/rtems/src/status.c | 6 +++---
> 1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/cpukit/rtems/src/status.c b/cpukit/rtems/src/status.c
> index 810c0e18de..3eadea59f0 100644
> --- a/cpukit/rtems/src/status.c
> +++ b/cpukit/rtems/src/status.c
> @@ -17,13 +17,13 @@
> #include <errno.h>
> const rtems_status_code _Status_Object_name_errors_to_status[] = {
> - /** This maps OBJECTS_SUCCESSFUL to RTEMS_SUCCESSFUL. */
> + /** This maps OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL to
> RTEMS_SUCCESSFUL,
> /** This maps OBJECTS_INVALID_NAME to RTEMS_INVALID_NAME. */
> RTEMS_INVALID_NAME,
> - /** This maps OBJECTS_INVALID_ADDRESS to RTEMS_INVALID_NAME. */
> + /** This maps OBJECTS_INVALID_ADDRESS to RTEMS_INVALID_ADDRESS. */
> RTEMS_INVALID_ADDRESS,
> - /** This maps OBJECTS_INVALID_ID to RTEMS_INVALID_ADDRESS. */
> + /** This maps OBJECTS_INVALID_ID to RTEMS_INVALID_ID. */
> RTEMS_INVALID_ID,
> /** This maps OBJECTS_INVALID_NODE to RTEMS_INVALID_NODE. */
> RTEMS_INVALID_NODE
> 2.11.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171121/5dc861aa/attachment.html>
